path: root/drivers
2009-04-07fbdev: i.MX31: fix panning, error handling, clean upGuennadi Liakhovetski
1. check for errors returned from clk_get() 2. fix "Unbalanced enable for IRQ 160" 3. fix transmit descriptor handling in panning 4. clean frame buffer on blank - useful for OLED displays 5. formatting clean up Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07tdfxfb: make use of DDC information about connected monitorKrzysztof Helt
Read DDC information from a connected monitor and use it to select initial mode (if the mode is not specified). Also, use the information to protect against modes outside the monitor specs. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Tested-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07tdfxfb: move I2C functionality into the tdfxfbKrzysztof Helt
The I2C functionality provided by the i2c-voodoo3 driver is moved into the tdfxfb (frame buffer driver for Voodoo3 cards). This way there is no conflict between the i2c driver and the fb driver. The tdfxfb does not make use from the DDC functionality yet but provides all the functionality of the i2c-voodoo3 driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07spi_imx: set spi_master.dma_alignment = 4Mike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Cc: Bryan Wu <bryan.wu@analog.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07pxa2xx_spi: set spi_master.dma_alignment = 8Mike Rapoport
2009-04-07spi_bfin5xx: remove unused IS_DMA_ALIGNED macroMike Rapoport
2009-04-07spi: pxa2xx_spi: introduce chipselect GPIO to simplify the common casesEric Miao
Most SPI peripherals use GPIOs as their chip selects, introduce .gpio_cs for this. Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07spi: limit reaches -1, tested 0Roel Kluin
With a postfix decrement limit will reach -1 rather than 0, so the warning will not be issued. Also, add a cpu_relax() into the busy-wait loop. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Mariusz Ceier <mceier@gmail.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: Make mmc_spi driver work on BlackfinWolfgang Muees
1. Rewrite of the non-dma data transfer functions to use only ONE mode of TIMOD (TIMOD=0x1). With TIMOD=0, it was not possible to set the TX bit pattern. So the TDBR = 0xFFFF inside the read calls won't work. 2. Clear SPI_RDBR before reading and before duplex transfer. Otherwise the garbage data in RDBR will get read. Since mmc_spi uses a lot of duplex transfers, this is the main cause of mmc_spi failure. 3. Poll RXS for transfer completion. Polling SPIF or TXS cannot guarantee transfer completion. This may interrupt a transfer before it is finished. Also this may leave garbage data in buffer and affect next transfer. [Yi Li <yi.li@analog.com>: add a field "u16 idle_tx_val" in "struct bfin5xx_spi_chip" to specify the value to transmit if no TX value is supplied.] Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de> Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: Add GPIO controlled SPI Slave Select supportMichael Hennerich
Add support for GPIO controlled SPI Chip Selects. To make use of this feature, set chip_select = 0 and add a proper cs_gpio to your controller_data. struct spi_board_info .chip_select = 0 struct bfin5xx_spi_chip .cs_gpio = GPIO_P### There are various SPI devices that require SPI MODE_0, and need to have the Chip Selects asserted during the entire transfer. Consider using SPI_MODE_3 (SPI_CPHA | SPI_CPOL) if your device allows it. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: fix NULL pointer crashMike Frysinger
Fix NULL pointer crash when cleaning up from invalid platform resources Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: use bfin_spi_ prefix on all functionsMike Frysinger
Do this because when things crash, we get simple names like "setup" and "start_queue" which is pretty difficult to trace back to the real thing: the spi driver Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: fix bug - correct usage of struct spi_transfer.cs_changeYi Li
According to comments in linux/spi/spi.h: * All SPI transfers start with the relevant chipselect active. Normally * it stays selected until after the last transfer in a message. Drivers * can affect the chipselect signal using cs_change. * * (i) If the transfer isn't the last one in the message, this flag is * used to make the chipselect briefly go inactive in the middle of the * message. Toggling chipselect in this way may be needed to terminate * a chip command, letting a single spi_message perform all of group of * chip transactions together. * * (ii) When the transfer is the last one in the message, the chip may * stay selected until the next transfer. On multi-device SPI busses * with nothing blocking messages going to other devices, this is just * a performance hint; starting a message to another device deselects * this one. But in other cases, this can be used to ensure correctness. * Some devices need protocol transactions to be built from a series of * spi_message submissions, where the content of one message is determined * by the results of previous messages and where the whole transaction * ends when the chipselect goes intactive. Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: fix bug - spi controller driver does not ↵Yi Li
assert/deassert CS correctly This bug can be observed when two SPI devices are sharing the spi bus: One device is set as SPI CS 7, another one is using SPI CS 4. In spi_bfin5xx.c: cs_active(), cs_deactive() are used to control SPI_FLG register. From the debug bellow: cs_active: flag: 0x7f91, chip->flag: 0x7f80, cs: 7 cs_active: flag: 0xef91, chip->flag: 0xef10, cs: 4 When device A (cs_7) activate CS 7, SPI_FLG is set as 0x7f91 (however, SPI_FLG should be set as 0x7f80, or 0x6f91 if in broadcast mode). Due to some HW bug (very possibly), if SPI_FLG is set as 0x7f91, SPISSEL7 is asserted, however SPISSEL4 will be asserted too (I can see this using the scope). This is unreasonable according to HRM. Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: tweak magic spi dma sequence to get it working on BF54xMike Frysinger
Without this change, SPI DMA is not reliably under stress tests. Obiviously it's a hardware issue which is not addressed by any document. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: add timeout while waiting for SPIF in dma irq handlerMike Frysinger
The "while" endless loop will cause the system hang if hardware error, so we add timeout control to make the system alive. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: get dma working for SPI flashesMike Frysinger
When using a BF533-STAMP here with a W25X10 SPI flash. It works fine when enable_dma is disabled, but doesn't work at all when turning DMA on. We get just 0xff bytes back when trying to read the device. Change the code around so that it programs the SPI first and then enables DMA, it seems to work a lot better ... Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: SPI slave select code cleanupMike Frysinger
- remove duplicated definition MAX_SPI_SSEL - remove unnecessary array size Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: use the properl BIT_CTL_xxx definesMike Frysinger
use the properl BIT_CTL_... defines rather than the internal driv er CFG_SPI_... defines Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: do not check for SPI errors if DMA itself did not flag anyMike Frysinger
We only need to check SPI error when DMA failes, cause that is the DMA IRQ handling routine. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: add a few more DMA debug messagesMike Frysinger
Because of DMA hardware issue, we were trying to use software workaround. This patch add some useful debug messages to help us debugging the DMA code. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: drop bogus cast and touchup dma labelMike Frysinger
Blackfin's related DMA callback API doesn't need void * cast, so drop it. And this driver is for all Blackfin processors not only for BF53x, we update the DMA request label for more meaningful information. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: unify duplicated code in dma read/write pathsMike Frysinger
For DMA TX/RX operation in pump_transfers, DMA contriguration code in TX and RX paths are almost the same. This patch unify the duplicated DMA code to make it more readable. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: pass DMA overflow error to the higher levelMike Frysinger
If the SPI bus registers a receive overflow error, pass the result back up to the higher levels. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: use len_in_bytes when we care about the number of bytes ↵Mike Frysinger
transferred Use len_in_bytes when we care about the number of bytes transferred rather than the number of spi transactions. (this value will be the same for 8bit transfers, but not any other sizes) Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: remove useless <asm/cplbinit.h>Mike Frysinger
We already moved bfin_addr_dcachable() and friends into the cacheflush header where it belongs, so don't need to include <asm/cplbinit.h> here. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: Fix erroneous SPI Clock divisor calculationMichael Hennerich
Fix erroneous SPI Clock divisor calculation. Make sure SPI_BAUD is always >= 2. Writing a value of 0 or 1 to the SPI_BAUD register disables the serial clock. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: ensure cache coherency before doing DMAVitja Makarov
Flush or invalidate caches before doing DMA transfer, if needed. [Mike Frysinger <vapier.adi@gmail.com>: add comment to address the issue "Full duplex only works for non-DMA transfers".] Signed-off-by: Vitja Makarov <vitja.makarov@gmail.com> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07hwmon: add support for GMT G760A fan speed PWM controllerHerbert Valerio Riedel
This controller can be found on the D-Link DNS-323 for instance, where it is to be configured via static i2c_board_info in the board-specific mach-orion/dns323-setup.c; this driver supports only the new-style driver model. Tested-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Signed-off-by: Matthew Palmer <mpalmer@debian.org> Signed-off-by: Laurie Bradshaw <bradshaw.laurie@googlemail.com> Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07esp: fix section mismatch warningRandy Dunlap
Not critical. WARNING: drivers/char/esp.o(.text+0x278): Section mismatch in reference from the function show_serial_version() to the variable .init.data:serial_version The function show_serial_version() references the variable __initdata serial_version. This is often because show_serial_version lacks a __initdata annotation or the annotation of serial_version is wrong. WARNING: drivers/char/esp.o(.text+0x27d): Section mismatch in reference from the function show_serial_version() to the variable .init.data:serial_name The function show_serial_version() references the variable __initdata serial_name. This is often because show_serial_version lacks a __initdata annotation or the annotation of serial_name is wrong. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andrew J. Robinson <arobinso@nyx.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07PCI: Fix oops in pci_vpd_truncateAnton Vorontsov
pci_vpd_truncate() should check for dev->vpd->attr, otherwise this might happen: sky2 driver version 1.22 Unable to handle kernel paging request for data at address 0x0000000c Faulting instruction address: 0xc01836fc Oops: Kernel access of bad area, sig: 11 [#1] [...] NIP [c01836fc] pci_vpd_truncate+0x38/0x40 LR [c029be18] sky2_probe+0x14c/0x518 Call Trace: [ef82bde0] [c029bda4] sky2_probe+0xd8/0x518 (unreliable) [ef82be20] [c018a11c] local_pci_probe+0x24/0x34 [ef82be30] [c018a14c] pci_call_probe+0x20/0x30 [ef82be50] [c018a330] __pci_device_probe+0x64/0x78 [ef82be60] [c018a44c] pci_device_probe+0x30/0x58 [ef82be80] [c01aa270] really_probe+0x78/0x1a0 [ef82bea0] [c01aa460] __driver_attach+0xa4/0xa8 [ef82bec0] [c01a96ac] bus_for_each_dev+0x60/0x9c [ef82bef0] [c01aa0b4] driver_attach+0x24/0x34 [ef82bf00] [c01a9e08] bus_add_driver+0x12c/0x1cc [ef82bf20] [c01aa87c] driver_register+0x6c/0x110 [ef82bf30] [c018a770] __pci_register_driver+0x4c/0x9c [ef82bf50] [c03782c8] sky2_init_module+0x30/0x40 [ef82bf60] [c0001dbc] do_one_initcall+0x34/0x1a0 [ef82bfd0] [c0362240] do_initcalls+0x38/0x58 This happens with CONFIG_SKY2=y, and "ip=on" kernel command line, so pci_vpd_truncate() is called before late_initcall(pci_sysfs_init), therefore ->attr isn't yet initialized. Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (28 commits) powerpc: Fix oops when loading modules powerpc: Wire up preadv and pwritev powerpc/ftrace: Fix printf format warning powerpc/ftrace: Fix #if that should be #ifdef powerpc: Fix ptrace compat wrapper for FPU register access powerpc: Print information about mapping hw irqs to virtual irqs powerpc: Correct dependency of KEXEC powerpc: Disable VSX or current process in giveup_fpu/altivec powerpc/pseries: Enable relay in pseries_defconfig powerpc/pseries: Fix ibm,client-architecture comment powerpc/pseries: Scan for all events in rtasd powerpc/pseries: Add dispatch dispersion statistics powerpc: Clean up some prom printouts powerpc: Print progress of ibm,client-architecture method powerpc: Remove duplicated #include's powerpc/pmac: Fix internal modem IRQ on Wallstreet PowerBook powerpc/wdrtas: Update wdrtas_get_interval to use rtas_data_buf fsl-diu-fb: Pass the proper device for dma mapping routines powerpc/pq2fads: Update device tree for use with device-tree-aware u-boot. cpm_uart: Disable CPM udbg when re-initing CPM uart, even if not the console. ...
2009-04-07powerpc/pmac: Fix internal modem IRQ on Wallstreet PowerBookBenjamin Herrenschmidt
The (relatively) new pmac_zilog driver doesn't use the pre-munged IRQ numbers from the macio_dev unlike other macio things, it directly maps it off the OF device-tree. It does that because it can be initialized much earlier than the registration of the macio devices, in order to get a serial console early. Unfortunately, that means that it "misses" some fixups done by the macio layer to work around missing interrupt descriptions in the device-tree of the Wallstreet machines. This patch brings the necessary workaround into the pmac_zilog driver itself to bring it back to working condition. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07powerpc/wdrtas: Update wdrtas_get_interval to use rtas_data_bufMark Nelson
The buffer passed to the ibm,get-system-parameter RTAS call must be in the RMA. To ensure we pass an address in the RMA use rtas_data_buf for the actual RTAS call and then copy the result to value. We can't just make it static because this can be compiled in as a module. Also add the WDRTAS_SP_SPI_LEN so we don't litter '4' throughout the function. Signed-off-by: Mark Nelson <markn@au1.ibm.com> Tested-by: Adrian Reber <adrian@lisas.de> Acked-by: Utz Bacher <utz.bacher@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2009-04-07Merge branch 'next' of ↵Paul Mackerras
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into merge
2009-04-06Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (120 commits) cx231xx: Convert to snd_card_create() V4L/DVB (11440): PWC: fix build error when CONFIG_INPUT=m V4L/DVB (11439): UVC: uvc_status_cleanup(): undefined reference to `input_unregister_device' V4L/DVB (11438): au0828: fix Kconfig dependance V4L/DVB (11437): pvrusb2: Drop client_register/unregister stubs V4L/DVB (11436): radio-mr800: convert to to v4l2_device V4L/DVB (11435): dsbr100 radio: convert to to v4l2_device V4L/DVB: zr364xx: remove unused #include <version.h> V4L/DVB: usbvision: remove unused #include <version.h> V4L/DVB (11427): gspca - m5602: Minor cleanups V4L/DVB (11426): gspca - m5602: Don't touch hflip/vflip register on Read/Modify/Write V4L/DVB (11425): gspca - m5602: Move the vflip quirk to probe stage. V4L/DVB (11424): gspca - m5602-ov9650: Use the local ctrl cache. Adjust image on vflip. V4L/DVB (11423): gspca - m5602-ov9650: Add a disconnect hook, setup a ctrl cache ctrl. V4L/DVB (11422): gspca - m5602-ov9650: Replace a magic constant with a define V4L/DVB (11421): gspca - m5602-ov9650: Synthesize modesetting. V4L/DVB (11420): gspca - m5602: Improve error handling in the ov9650 driver V4L/DVB (11419): gspca - m5602-ov9650: Don't read exposure data from COM1. V4L/DVB (11418): gspca - m5602-ov9650: Auto white balancing is on by default V4L/DVB (11417): gspca - m5602-ov9650: Autogain is on by default ...
2009-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: b44: Use kernel DMA addresses for the kernel DMA API forcedeth: Fix resume from hibernation regression. xfrm: fix fragmentation on inter family tunnels ibm_newemac: Fix dangerous struct assumption gigaset: documentation update gigaset: in file ops, check for device disconnect before anything else bas_gigaset: use tasklet_hi_schedule for timing critical tasklets net/802/fddi.c: add MODULE_LICENSE smsc911x: remove unused #include <linux/version.h> axnet_cs: fix phy_id detection for bogus Asix chip. bnx2: Use request_firmware() b44: Fix sizes passed to b44_sync_dma_desc_for_{device,cpu}() socket: use percpu_add() while updating sockets_in_use virtio_net: Set the mac config only when VIRITO_NET_F_MAC myri_sbus: use request_firmware e1000: fix loss of multicast packets vxge: should include tcp.h Conflict in firmware/WHENCE (SCSI vs net firmware)
2009-04-06b44: Use kernel DMA addresses for the kernel DMA APIMichael Buesch
We must not use the device DMA addresses for the kernel DMA API, because device DMA addresses have an additional offset added for the SSB translation. Use the original dma_addr_t for the sync operation. Cc: stable@kernel.org Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-06forcedeth: Fix resume from hibernation regression.Ed Swierk
Reset phy state on resume, fixing a regression caused by powering down the phy on hibernate. Signed-off-by: Ed Swierk <eswierk@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-06cx231xx: Convert to snd_card_create()Mauro Carvalho Chehab
Convert from snd_card_new() to the new snd_card_create() function. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11440): PWC: fix build error when CONFIG_INPUT=mRandy Dunlap
Fix build errors when USB_PWC=y and INPUT=m. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Laurent Pinchart <laurent.pinchart@skynet.be> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11439): UVC: uvc_status_cleanup(): undefined reference to ↵Randy Dunlap
`input_unregister_device' Fix build errors when USB_VIDEO_CLASS=y and INPUT=m. Fixes kernel bugzilla #12671. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Laurent Pinchart <laurent.pinchart@skynet.be> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11438): au0828: fix Kconfig dependanceAlexander Beregalov
Fix this build error: ERROR: "videobuf_queue_vmalloc_init" [drivers/media/video/au0828/au0828.ko] undefined! ERROR: "videobuf_vmalloc_free" [drivers/media/video/au0828/au0828.ko] undefined! ERROR: "videobuf_to_vmalloc" [drivers/media/video/au0828/au0828.ko] undefined! Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11437): pvrusb2: Drop client_register/unregister stubsJean Delvare
The client_register and client_unregister methods are optional so there is no point in defining stub ones. Especially when these methods are likely to be removed soon. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Mike Isely <isely@pobox.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11436): radio-mr800: convert to to v4l2_deviceAlexey Klimov
radio-mr800: convert to to v4l2_device. Signed-off-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11435): dsbr100 radio: convert to to v4l2_deviceAlexey Klimov
dsbr100: convert to v4l2_device. Signed-off-by: Alexey Klimov <klimov.linux@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB: zr364xx: remove unused #include <version.h>Huang Weiyi
Remove unused #include <version.h> in drivers/media/video/zr364xx.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB: usbvision: remove unused #include <version.h>Huang Weiyi
Remove unused #include <version.h> in drivers/media/video/usbvision/usbvision-i2c.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11427): gspca - m5602: Minor cleanupsErik Andr?n
Remove an unnecessary error check and reorder some code. Signed-off-by: Erik Andr?n <erik.andren@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11426): gspca - m5602: Don't touch hflip/vflip register on ↵Erik Andr?n
Read/Modify/Write Touching the hflip/vflip register while doing the read/modify/write corrupts the image. Just read from the sensor ctrl cache instead and all is good. Signed-off-by: Erik Andr?n <erik.andren@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
