If the frequency can not be mapped to a channel structure log it and drop it.
Signed-off-by: Joseph J. Gunn <armadefuego@yahoo.com>
The return value of the tx operation is commonly
misused by drivers, leading to errors. All drivers
will drop frames if they fail to TX the frame, and
they must also properly manage the queues (if they
didn't, mac80211 would already warn).
Removing the ability for drivers to return a BUSY
value also allows significant cleanups of the TX
TX handling code in mac80211.
Note that this also fixes a bug in ath9k_htc, the
old "return -1" there was wrong.
Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> [ath5k]
Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> [rt2x00]
Acked-by: Larry Finger <Larry.Finger@lwfinger.net> [b43, rtl8187, rtlwifi]
Acked-by: Luciano Coelho <coelho@ti.com> [wl12xx]
Same fix as f844a709a7d8f8be61a571afc31dfaca9e779621
"iwlwifi: do not set tx power when channel is changing".
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
The callback sets slot time as specified in IEEE 802.11-2007
section 17.3.8.6 and raises round trip delay accordingly.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
On my G5 this fails to compile with
drivers/net/wireless/rtlwifi/rtl8192c/phy_common.c:701: error: __ksymtab__rtl92c_phy_txpwr_idx_to_dbm causes a section type conflict
drivers/net/wireless/rtlwifi/rtl8192c/phy_common.c:677: error: __ksymtab__rtl92c_phy_dbm_to_txpwr_Idx causes a section type conflict
since you can't export static functions.
As noted by Stephan Rothwell, an allyesconfig build fails since rtl8192cu
was merged with failures such as:
drivers/net/wireless/rtlwifi/rtl8192cu/built-in.o: In function `rtl92c_phy_sw_chnl':
(.opd+0xf30): multiple definition of `rtl92c_phy_sw_chnl'
drivers/net/wireless/rtlwifi/rtl8192ce/built-in.o:(.opd+0xb70): first defined here
drivers/net/wireless/rtlwifi/rtl8192cu/built-in.o: In function `rtl92c_fill_h2c_cmd':
(.opd+0x288): multiple definition of `rtl92c_fill_h2c_cmd'
drivers/net/wireless/rtlwifi/rtl8192ce/built-in.o:(.opd+0x288): first defined here
These are caused because the code shared between rtl8192ce and rtl8192cu
is included in both drivers. This has been fixed by creating a new modue that
contains the shared code.
On ARM, compilation of rtlwifi/efuse.c fails with the message:
ERROR: "__bad_udelay" [drivers/net/wireless/rtlwifi/rtlwifi.ko] undefined!
On inspection, the faulty calls are in routine efuse_reset_loader(), a
routine that is never used, and the faulty routine is deleted.
Signed-off-by: Willy Tarreau <w@1wt.eu>
On systems where PCI does not exist, a build of rtlwifi will fail.
Apply the same fix in case there are systems with PCI but not USB.
On the ARM system, a build fails due to missing include.
The wireless Makefile does not build rtlwifi for rtl8192cu unless
rtl8192ce is selected.
The flag isn't very descriptive -- the intention
is that the driver provides a TSF timestamp at
the beginning of the MPDU -- make that clearer
by renaming the flag to RX_FLAG_MACTIME_MPDU.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
ath9k_hif_usb_alloc_urbs() takes care of freeing
all the allocated URBs for the various endpoints when
an error occurs. Calling ath9k_hif_usb_dealloc_urbs() would
cause a panic since the URBs have already been freed.
Signed-off-by: Sujith Manoharan <Sujith.Manoharan@atheros.com>
Add ATH9K_RX_FILTER_UNCOMP_BA_BAR and ATH9K_RX_FILTER_PSPOLL
when mac80211 requires it.
There is no need to set the BSSID mask or opmode when
initializing RX, they would be set correctly in the HW reset
routine.
The target beacon transmission time has to be synced with the HW
TSF when configuring beacon timers in Adhoc mode. Failing to do this
would cause erroneous beacon transmission, for example, on completion
of a scan run to check for IBSS merges.
Handle multi-interface situations by checking if
AP interfaces are already present.
The time granularity for the ANI task is different for AP and
station mode.
This is required for allowing only one IBSS interface to be
configured.
This is required when issuing commands to the firmware.
There is no need to use a locally stored reference.
mac80211 stores the association state in ieee80211_bss_conf.
Use this and remove the local state, which is incorrect anyway
since it is stored globally and not on a per-VIF basis.
Restarting ANI and reconfiguration of HW beacon timers when a
scan run ends requires more work. This is handled by iterating
over the active interfaces.
Finally, remove the useless check for associated status in RX
processing.
CTS protection can be obtained from mac80211 directly.
mac80211's BSS info can be used for this.
Addition of a station might fail - handle this error
properly by removing the VAP on the target.
Also, bail out immediately if the max. no of interfaces
has been reached.
Update capabilites on the target once, when
start() is called, there is no need for redundant
updating on adding an interface.
Multiple interfaces can be configured if a slot is free
on the target. Monitor mode also requires a slot.
The maximum number of stations that can be handled in
the firmware is 8, manage the station slots accordingly.
Some AR7010 based devices are recognized as storage media.
Sending a CD-EJECT command to the device will 'convert' it into
a WLAN device. Do this within the driver itself, removing the
dependancy on an external program (usb_modeswitch).
mac80211 and mwl8k FW tx queue priorities map inversely to each other.
Fix this.
Signed-off-by: Pradeep Nemavat <pnemavat@marvell.com>
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Tested-by: Pradeep Nemavat <pnemavat@marvell.com>
All mwl8k parts perform rate control in firmware. Make this known to
mac80211 so that it does not launch minstrel. Also, because actual tx
rate information is not available from the firmware, invalidate the
rate status before returning the skb to mac80211.
Signed-off-by: Nishant Sarmukadam <nishants@marvell.com>
Signed-off-by: Thomas Pedersen <thomas@cozybit.com>
When configuring rx antennas using CMD_RF_ANTENNA, the argument input is
the number of antennas to be enabled. For AP, we support 3 rx antennas
and hence set the field to 3. For tx antennas, value is a bitmap, so 0x7
enables all three.
git://git.kernel.org/pub/scm/linux/kernel/git/luca/wl12xx
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-2.6
Update the PS mode of each link according to a bitmap polled from
fw_status. Manually notify mac80211 about PS mode changes in connected
stations.
mac80211 will only be notified about PS start when the station is in PS
and there is a small number of TX blocks from this link ready in HW.
This is required for waking up the remote station since the TIM is
updated entirely by FW.
When a station enters mac80211-PS-mode, we drop all the skbs in the
low-level TX queues belonging to this sta with STAT_TX_FILTERED
to keep our queues clean.
Signed-off-by: Arik Nemtsov <arik@wizery.com>
Signed-off-by: Luciano Coelho <coelho@ti.com>
Count the number of FW TX blocks allocated per link. We add blocks to a
link counter when allocated for a TX descriptor. We remove blocks
according to counters in fw_status indicating the number of freed blocks
in FW. These counters are polled after each IRQ.
Remove an active hlid when chip wakeup fails. In addition rename the
involved functions.
When operating in AP mode the wl1271 hardware filters out null-data
packets as well as management packets. This makes it impossible for
mac80211 to monitor the PS mode by using the PM bit of incoming frames.
Disable mac80211 automatic link PS-mode handling by supporting
IEEE80211_HW_AP_LINK_PS in HW flags.
Report a TX rate idx of -1 and count 0 when returning untransmitted
skbs to mac80211 using ieee80211_tx_status(). Otherwise mac80211
tries to use the returned (essentially garbage) status.
When operating in AP-mode we require a per link tx-queue.
This allows us to implement HW assisted PS mode for links,
as well as regulate per-link FW TX blocks consumption.
Split each link into ACs to support future QoS for AP-mode.
AC queues are emptied in priority and per-link queues are
scheduled in a simple round-robin fashion.
If a sta starts transmitting immediately after authentication, sometimes
the FW deauthenticates it. Fix this by marking the sta "in-connection"
in FW before sending the autentication response.
The "in-connection" entry is automatically removed when connection
succeeds or after a timeout.
Check the conditions for the high/low TX queue watermarks when the
spin-lock is taken. This prevents race conditions as tx_queue_count and
the flag checked are only modified when the spin-lock is taken.
The following race was in mind:
- Queues are almost full and wl1271_op_tx() will stop the queues, but it
doesn't get the spin-lock yet.
- (on another CPU) tx_work_locked() dequeues 15 skbs from this queue and
tx_queue_count is updated to reflect this
- wl1271_op_tx() does not check tx_queue_count after taking the
spin-lock and incorrectly stops the queue.
The mac_address should be set also when ht caps are disabled.
Signed-off-by: Eliad Peller <eliad@wizery.com>
Use the standard ALIGN() macro instead of redefining similar macros.
