Wait for the scheduled work to finish before freeing memory, prevent oops.
http://bugzilla.kernel.org/show_bug.cgi?id=6596
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
This updates the EHCI driver by adding an improved scheduler for the
transaction translators, found in USB 2.0 hubs and used for low and
full speed devices.
- adds periodic_tt_usecs() and some helper functions, which does
the same thing that "periodic_usecs" does, except on the other
side of the TT, i.e. it calculates the low/fullspeed bandwidth
usage instead of highspeed.
- adds a tt_available() function which is the new implementation
of what tt_no_collision() does ... while tt_no_collision() ensures
that each TT handles only 1 periodic transfer at a time (a very
pessimistic approach) this version instead tracks bandwidth and
allows each TT to handle as many transfers as will fit on each TT's
downstream bus (closer to best-case).
The new scheduler is selected by a config option, marked as EXPERIMENTAL
so it can be tested (and more broadly reviewed) for a while until it
seems safe to remove the original scheduler.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
This patch uses completion timeout instead of a timer to implement
a timeout when submitting an URB.
It also put the task in interruptible state instead of an
uninterruptible one while waiting for the completion.
Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com>
Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Remove the silly trailing backslash.
Add a couple of supported devices into the help message.
It's a long story... I promised this comment changed to a user long ago,
so I'd like to have that promise kept. In reality though, nobody is
likely to read this anyway.
I'm going to throw schedule_work away, it's retarded. But for starters,
let's have it encapsulated.
Also, generic and whiteheat were both calling usb_serial_port_softint
and scheduled work. Only one was necessary.
Clean up the unicode handling in io_edgeport. Make get_string size-limited.
This patch (as693b) makes the usbtest driver report errors in the
isochronous bulk transfer tests instead of always returning 0. As an
arbitrary cutoff, an error is returned if more than 10% of the packet
transfers fail. It also stops a test immediately upon receiving an URB
submission error.
For a test harness, it's especially important to report when errors occur!
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as692) fixes a few memory leaks in some unimportant error
pathways of the gadgetfs driver.
Acked-by: David Brownell <david-b@pacbell.net>
This patch (as691) fixes a few errors in the AIO interface for the
gadgetfs driver. Now requests will complete properly instead of hanging.
By the way I have to ask you to add new (vid,pid) pair to cp2101 driver.
This device is argussoft's avr in-system programmer AS3M,
http://atmel.argussoft.ru/hard.htm
it's based on cp2101 chip and works pretty well with the linux driver.
It could be used with argussoft's `asisp1109.exe'
(http://atmel.argussoft.ru/download/software/as-tools.soft/asisp.zip)
tool run under wine.
Signed-off-by: Vitja Makarov <vitja.makarov@gmail.com>
Really just a wrapper around usb_bulk_msg() but now it's documented
much better.
ctrl_complete functions acquires ctx->lock and tries to unlink
all queued urbs in case of errors through usb_unlink_urb func.
In its turn usb_unlink_urb calls, through the hcd driver,
usb_hcd_giveback_urb which calls ctrl_complete again. At this
time, ctx->lock is already taken by the same function.
Cc: David Brownell <david-b@pacbell.net>
This patch (as690) does the same thing for ISO TDs as as680 did for
non-ISO TDs: free them as they are used rather than all at once when an
URB is complete. At the same time it fixes a minor buglet (I'm not
aware of it ever affecting anyone): An ISO TD should be retired when its
frame is over, regardless of whether or not the hardware has marked it
inactive.
This patch (as689) stores the period for periodic transfers (interrupt
and ISO) in the queue header. This is necessary for proper bandwidth
tracking (not yet implemented). It also makes the scheduling of ISO
transfers a bit more rigorous, with checks for out-of-bounds frame
numbers.
This patch (as688) fixes a small race in uhci-hcd. Because ISO queues
aren't controlled by queue headers, they can't be unlinked. Only
individual URBs can. So whenever multiple ISO URBs are dequeued, it's
necessary to make sure the hardware is done with each one. We can't
assume that dequeuing the first URB will suffice to unlink the entire
queue.
This patch (as687) changes uhci-hcd to keep track of frame numbers as
full-sized integers rather than 11-bit values. This makes them a lot
easier to handle and makes it possible to schedule beyond a 2-second
window, should anyone ever want to do so.
This patch increases an arbitrary limit on the size of
individual isochronous packets submitted via usbfs. The
limit is still arbitrary, but it's now large enough to
support the maximum packet size used by high-bandwidth
isochronous transfers.
Signed-off-by: Micah Dowty <micah@vmware.com>
This patch removes the artificial 4088-byte limit that usbfs
currently places on Control transfers. The USB spec does not
specify a strict limit on the size of an entire control transfer.
It does, however, state that the data stage "follows the same
protocol rules as bulk transfers." (USB 2, 8.5.3)
The level of support for large control transfers in real host
controllers varies, but it's important to support at least 4K
transfers. Windows enforces a maximum control transfer size
of 4K, so there exists some hardware that requires a full 4096
byte data stage. Without this patch, we fall short of that by
8 bytes on architectures with a 4K page size, and it becomes
impossible to support such hardware with a user-space driver.
Since any limit placed on control transfers by usbfs would be
arbitrary, this patch replaces the PAGE_SIZE limit with the same
arbitrary limit used by bulk transfers.
Some old Intel UHCI controllers have a bug that has shown up in a few
systems (the PIIX3 "Neptune" chip set). Until now there has not been
any simple way to work around the bug, but the lastest changes in
uhci-hcd have made it easy. This patch (as684) adds the work-around.
This patch (as683) re-implements Full-Speed Bandwidth Reclamation (FSBR)
properly. It keeps track of which endpoint queues have advanced, and
when none have advanced for a sufficiently long time, FSBR is turned
off. The next TD on each of the non-moving queues is modified to
generate an interrupt on completion, so that FSBR can be re-enabled as
soon as the hardware starts to make some progress.
This patch (as682) gets rid of the TD-removal list in uhci-hcd. It is
no longer needed because now TDs are not freed until we know the
hardware isn't using them. It also simplifies the code for adding and
removing TDs to/from URBs.
This patch (as681) moves some code for cleaning up after unlinked URBs
out of the general completion pathway into the unlinking pathway.
This patch (as680) frees non-isochronous TDs as they are used, rather
than all at once when an URB is complete. Although not a terribly
important change in itself, it opens the door to a later enhancement
that will reduce storage requirements by allocating only a limited
number of TDs at any time for each endpoint queue.
This patch (as679) combines the result routine for Control URBs with the
routine for Bulk/Interrupt URBs. Along the way I eliminated the
debugging printouts for Control transfers unless the debugging level is
set higher than 1. I also eliminated a long-unused (#ifdef'ed-out)
section that works around some buggy old APC BackUPS devices.
It seems to be relatively common for USB keyboards and mice to dislike
being polled for reports. Since there's no need to poll a keyboard or
a mouse, this patch (as685) automatically sets the HID_QUIRK_NOGET flag
for devices that advertise themselves as either sort of device with boot
protocol support.
This won't cure all the problems since some devices don't support the
boot protocol, but it's simple and easy and it should fix quite a few
problems.
that make Apple Mighty Mouse work poorly
Transposed lines of code in drivers/usb/input/hid-input.c causes the
capability bits for a new HID device to be set before quirks are applied
at configuration time. When an HID event is then sent up to the input
layer, it may then be discarded as irrelevant because the wrong
capability bit is set.
Further, the quirks for the Apple Mighty Mouse are not quite right: the
horizontal scrolling needs its axis reversed, and the left and center
buttons are transposed. Also, the mouse is labeled in the kernel with
its earlier name (I think) of Apple PowerMouse.
Steps to reproduce problem: Plug in an Apple Mighty Mouse. Note that
horizontal scrolling doesn't work at all, and in fact doesn't generate
any input events on /dev/input/eventN. Note also that pushing the
middle button performs the right button action, and vice versa. Once
you have the horizontal scrolling working, note that it is backward WRT
both to vertical scrolling and to common sense.
This patch maybe should be broken up, as it does address two problems.
The transposed code in hidinput_configure_usage() probably creates bugs
beyond just the Mighty Mouse. The rest of the patch renames POWERMOUSE
to MIGHTYMOUSE everywhere (which I *believe* is correct), fixes the
MIGHTYMOUSE quirk to swap the center and right mouse buttons, and adds a
new quirk HID_QUIRK_INVERT_HWHEEL also assigned to the MIGHTYMOUSE with
code in hidinput_hid_event() to implement it.
Signed-off-by: Bart Massey <bart@cs.pdx.edu>
This patch (as676) fixes a small bug in uhci-hcd's enqueue routine. When
an URB is unlinked or gets an error and the completion handler queues
another URB for the same endpoint, the queue shouldn't be allowed to start
up again until the handler returns. Not even if the new URB is the only
one on its queue.
This patch (as675) simplifies uhci-hcd slightly by storing each endpoint's
type in the corresponding Queue Header structure.
The net2280 board has an annoying habit of surviving soft reboots with
interrupts enabled. This patch (as674) adds a shutdown routine to the
driver so that the board can be put in a quiescent state.
Unfortunately it looks like the transport entry for this subdriver was merged
into the protocol section, making this driver unusable :(
Signed-off-by: Daniel Drake <dsd@gentoo.org>
After some further testing with my flash device I realised that our current
probe doesn't always work (e.g. when no media is inserted).
Now that Peter Chubb's patch has simplified the detection of 99% of the HP CD
writers out there, we have a much smaller range of hardware to work with on
the shared device ID, so it should be possible to try some of the previous
probe options again: we just need to find another tester with a USBAT2-based HP
CD writer.
This patch hardcodes the flash detection until someone comes along with one of
these obscure CD drives. Note that these devices are extremely rare, so even if
we can't ever find a decent probe method, at least we will be supporting almost
all of the USBAT-based hardware out there.
Use USB vendor and product IDs to determine whether the attached
device is a CDROM or a Flash device. Daniel Drake says that the
*same* vendor and product IDs for non-HP vendor ID could be either
flash or cdrom, so try to probe for them.
Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au>
I've worked out what's going wrong. The scsi layer is now much
more likely to pass down scatterlists instead of plain buffers. So
you have to make sure that they're handled correctly. In one of the
changes along the way, usbat_write_block and friends stopped obeying
the srb->use_sg flag.
Anyway, with the appended patch, and the one I'm putting in the next email, it
all seems to work for the HP cd4e. Of course, someone's going to have
to test it with the flash drives as well....
This patch teaches the usbat_{read,write}_block functions to
obey the use_sg flag in the scsi-request.
Make inputs pollable using sysfs_notify and add support for the Phidget
InterfaceKit 0/16/16. Various cleanups.
Signed-off-by: Sean Young <sean@mess.org>
Signed-off-by: Daniel Saakes <daniel@saakes.net>
We #include <linux/netdevice.h> only because <linux/etherdevice.h>
needed it, but didn't #include it itself. But that's been fixed now.
Signed-off-by: Duncan Sands <baldrick@free.fr>
Remove pointless inline.
Remove the check for NULL which makes no sense. Suggested by Al.
Some hubs claim not to support port-power switching, and right now the
hub driver believes them and does not enable power to their ports.
However it turns out that even though they don't actually switch power,
they do ignore all events on a port until told to turn on the power!
This problem has been reported by several users.
This revised patch (as672b) makes the hub driver always try to turn on
port power to all hubs, regardless of what the hub descriptor says. It
also adds a comment explaining the need for this.
Add support for MacBook touchpad in appletouch driver.
Thanks to Alex Harper for the informations.
Use u16 instead of int16_t in atp_is_geyser* functions.
Acked-by: Johannes Berg <johannes@sipsolutions.net>
Acked-by: Stelian Pop <stelian@popies.net>
Signed-off-by: Nicolas Boichat <nicolas@boichat.ch>
Prevent sending further output to a USB-serial console after the dongle is
disconnected, take care not to leak kref.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Prevent ENODEV on a /dev/ttyUSBx, used as a USB-serial console.
Prevent NULL dereference when used as a USB-serial console.
Append Carriage-Returns after Line-Feeds, analogous to the serial driver.
In some systems we may have both a platform EHCI controller and PCI EHCI
controller. Previously we couldn't build the EHCI support as a module due
to conflicting module_init() calls in the code.
This patch contains the following possible cleanups:
- make needlessly global functions static
- function and struct declarations belong into header files
- make SiS_VCLKData const
- #if 0 the following unused global functions:
- sisusb.c: sisusb_writew()
- sisusb.c: sisusb_readw()
- sisusb_init.c: SiSUSB_GetModeID()
Convert the semaphores-used-as-mutex to mutexes in the sisusb video driver;
this required manual checking due to the "return as locked" stuff in this
driver, but the ->lock semaphore is still used as mutex in the end.
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Cc: Thomas Winischhofer <winischhofer.net>
Add support for detection and dworking with a ASIX 88178 based USB-Gigabit
adaptor. With the patch, it is detected and handled correctly by the asix
module.
This includes an MTU fixup which could affect larger packets with newer
Zaurii, described as http://bugzilla.kernel.org/show_bug.cgi?id=6286;
plus minor whitespace cleanup.
this fixes the "duplicated text" bug. There's a modem that cannot cope
with large transfers and more than one urb in flight. This patch adds a
special case to the driver.
Signed-off-by: Oliver Neukum <oliver@neukum.name>
