md_make_request was calling bio_sectors() for part_stat_add
after it was calling the make_request function. This is
bad because the make_request function can free the bio and
because the bi_size field can change around.
The fix here was suggested by Jens Axboe. It saves the
sector count before the make_request call. I hit this
with CONFIG_DEBUG_PAGEALLOC turned on while trying to break
his pretty fusionio card.
Cc: <stable@kernel.org>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
Signed-off-by: NeilBrown <neilb@suse.de>
With commit 554d1d027b19265c4aa3f718b3126d2b86e09a08 only one RF_KILL
interrupt will be seen by the driver when the interface is down.
Re-enable the interrupt when it occurs to see all transitions.
Signed-off-by: Don Fry <donald.h.fry@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
Cc: stable@kernel.org
This fixes parsing of the device invariants (MAC address)
for PCMCIA SSB devices.
ssb_pcmcia_do_get_invariants expects an iv pointer as data
argument.
Tested-by: dylan cristiani <d.cristiani@idem-tech.it>
Signed-off-by: Michael Buesch <mb@bu3sch.de>
git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6
* 'ixp4xx' of git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6:
arm/ixp4xx: Rename FREQ macro to avoid collisions
IXP4xx: Fix qmgr_release_queue() flushing unexpected queue entries.
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
lockdep, timer: Fix del_timer_sync() annotation
RTC: Prevents a division by zero in kernel code.
Prevent packets duplication for frames targeting FCoE L2 ring:
packets were arriving to stack from both L2 RSS and from FCoE
L2 in a promiscuous mode.
Configure FCoE L2 ring to DROP_ALL rx mode, when interface is
configured to PROMISC, and to accept only unicast frames, when
interface is configured to ALL_MULTI.
Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
FREQ is a ridiculously short name for a platform-specific macro in a
generic header, and it now conflicts with an enumeration in the
gspca/ov519 driver.
Also delete conditional reference to ixp4xx_get_board_tick_rate()
which is not defined anywhere.
Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
Fix memory leak in error path of sis900_rx(). If we don't do this we'll
leak the skb we dev_alloc_skb()'ed just a few lines above when the
variable goes out of scope.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Found by: Jesper Juhl <jj@chaosbits.net>
Signed-off-by: Ajit Khaparde <ajit.khaparde@emulex.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (68 commits)
net: can: janz-ican3: world-writable sysfs termination file
net: can: at91_can: world-writable sysfs files
MAINTAINERS: update email ids of the be2net driver maintainers.
bridge: Don't put partly initialized fdb into hash
r8169: prevent RxFIFO induced loops in the irq handler.
r8169: RxFIFO overflow oddities with 8168 chipsets.
r8169: use RxFIFO overflow workaround for 8168c chipset.
include/net/genetlink.h: Allow genlmsg_cancel to accept a NULL argument
net: Provide compat support for SIOCGETMIFCNT_IN6 and SIOCGETSGCNT_IN6.
net: Support compat SIOCGETVIFCNT ioctl in ipv4.
net: Fix bug in compat SIOCGETSGCNT handling.
niu: Fix races between up/down and get_stats.
tcp_ecn is an integer not a boolean
atl1c: Add missing PCI device ID
s390: Fix possibly wrong size in strncmp (smsgiucv)
s390: Fix wrong size in memcmp (netiucv)
qeth: allow OSA CHPARM change in suspend state
qeth: allow HiperSockets framesize change in suspend
qeth: add more strict MTU checking
qeth: show new mac-address if its setting fails
This patch reverts the following commit
ath9k: remove bfs_paprd_timestamp from struct ath_buf_state
Under high interference/noisy environment conditions where PAPRD frames
fails heavily introduces a possibility of double freeing skb's and causes
kernel panic after some time.This patch reverts back to the original approach
of using paprd_timestamp before freeing the PAPRD frame skb's
[ 194.193705] Pid: 0, comm: swapper Tainted: G D WC
2.6.35-22-generic #33-Ubuntu
[ 194.193712] Call Trace:
[ 194.193722] [<c05c6468>] ? printk+0x2d/0x35
[ 194.193732] [<c05c63c3>] panic+0x5a/0xd2
[ 194.193741] [<c05ca3ed>] oops_end+0xcd/0xd0
[ 194.193750] [<c0105f74>] die+0x54/0x80
[ 194.193758] [<c05c9a16>] do_trap+0x96/0xc0
[ 194.193837] [<c0103fb0>] ? do_invalid_op+0x0/0xa0
[ 194.193846] [<c010403b>] do_invalid_op+0x8b/0xa0
[ 194.193856] [<c020bd4c>] ? kfree+0xec/0xf0
[ 194.193866] [<c012ce18>] ? default_spin_lock_flags+0x8/0x10
[ 194.193877] [<c01de47a>] ? free_one_page+0x12a/0x2d0
[ 194.193888] [<c01e04dc>] ? __free_pages+0x1c/0x40
[ 194.193897] [<c05c97a7>] error_code+0x73/0x78
[ 194.193906] [<c020bd4c>] ? kfree+0xec/0xf0
[ 194.193915] [<c04ecdd0>] ? skb_release_data+0x70/0xa0
[ 194.193924] [<c04ecdd0>] skb_release_data+0x70/0xa0
[ 194.193933] [<c04ec997>] __kfree_skb+0x17/0x90
[ 194.193941] [<c04eca31>] consume_skb+0x21/0x40
[ 194.193964] [<f85e0b70>] ieee80211_tx_status+0x760/0x860 [mac80211]
[ 194.193979] [<f85caddf>] ath_tx_complete_buf+0x1bf/0x2c0 [ath9k]
[ 194.193988] [<c05c8b9f>] ? _raw_spin_lock_irqsave+0x2f/0x50
[ 194.193997] [<c04ec40e>] ? skb_queue_tail+0x3e/0x50
[ 194.194010] [<f85cc803>] ath_tx_complete_aggr+0x823/0x940 [ath9k]
[ 194.194021] [<c0108a28>] ? sched_clock+0x8/0x10
[ 194.194030] [<c016bf14>] ? sched_clock_local+0xa4/0x180
[ 194.194040] [<c0139f57>] ? enqueue_sleeper+0x1e7/0x2b0
[ 194.194051] [<c013a194>] ? enqueue_entity+0x174/0x200
[ 194.194064] [<f85ce83d>] ath_tx_edma_tasklet+0x2bd/0x3b0 [ath9k]
[ 194.194074] [<c05c8b9f>] ? _raw_spin_lock_irqsave+0x2f/0x50
[ 194.194088] [<f85c7b9f>] ath9k_tasklet+0x9f/0x190 [ath9k]
[ 194.194097] [<c01505d7>] tasklet_action+0xa7/0xb0
[ 194.194107] [<c015127c>] __do_softirq+0x9c/0x1b0
[ 194.194117] [<c01a7f64>] ? irq_to_desc+0x14/0x20
[ 194.194126] [<c0124fc4>] ? ack_apic_level+0x64/0x1f0
[ 194.194136] [<c01513d5>] do_softirq+0x45/0x50
[ 194.194145] [<c0151545>] irq_exit+0x65/0x70
[ 194.194153] [<c05cf665>] do_IRQ+0x55/0xc0
[ 194.194162] [<c016a6c7>] ? hrtimer_start+0x27/0x30
[ 194.194171] [<c0103630>] common_interrupt+0x30/0x38
[ 194.194181] [<c012c21a>] ? native_safe_halt+0xa/0x10
[ 194.194268] [<c010a2f9>] default_idle+0x49/0xb0
[ 194.194277] [<c0101fcc>] cpu_idle+0x8c/0xd0
[ 194.194286] [<c05b2431>] rest_init+0x71/0x80
[ 194.194295] [<c081981a>] start_kernel+0x36e/0x374
[ 194.194305] [<c08199dd>] ? pass_all_bootoptions+0x0/0xa
[ 194.194314] [<c08190d7>] i386_start_kernel+0xd7/0xdf
[ 194.194364] panic occurred, switching back to text console
Signed-off-by: Mohammed Shafi Shajakhan <mshajakhan@atheros.com>
This patch fixes a off-by-one bug which bugged
the driver's PS-POLL capability.
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
Don't allow everybody to set terminator via sysfs.
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Don't allow everybody to write to mb0_id file.
Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be>
This adds the N8 to the list of devices in cdc-acm, in order to get the
secondary ACM device exposed.
In the spirit of:
http://kerneltrap.org/mailarchive/linux-usb/2010/9/4/6264554
Signed-off-by: Arvid Ephraim Picciani <arvid.picciani@nokia.com>
Cc: stable <stable@kernel.org>
Trying to compile drivers/usb/gadget/f_mass_storage.o currently fails and
spews a ton of warnings :
CC drivers/usb/gadget/f_mass_storage.o
drivers/usb/gadget/f_mass_storage.c:436:22: error: field ‘function’ has incomplete type
drivers/usb/gadget/f_mass_storage.c: In function ‘fsg_from_func’:
drivers/usb/gadget/f_mass_storage.c:466:9: warning: type defaults to ‘int’ in declaration of ‘__mptr’
drivers/usb/gadget/f_mass_storage.c:466:9: warning: initialization from incompatible pointer type
drivers/usb/gadget/f_mass_storage.c: At top level:
drivers/usb/gadget/f_mass_storage.c:2743:15: warning: ‘struct usb_composite_dev’ declared inside parameter list
drivers/usb/gadget/f_mass_storage.c:2743:15: warning: its scope is only this definition or declaration, which is probably not what you want
drivers/usb/gadget/f_mass_storage.c: In function ‘fsg_common_init’:
drivers/usb/gadget/f_mass_storage.c:2745:34: error: dereferencing pointer to incomplete type
drivers/usb/gadget/f_mass_storage.c:2775:23: error: dereferencing pointer to incomplete type
drivers/usb/gadget/f_mass_storage.c:2779:3: error: implicit declaration of function ‘usb_string_id’
drivers/usb/gadget/f_mass_storage.c:2984:60: warning: ‘struct usb_configuration’ declared inside parameter list
drivers/usb/gadget/f_mass_storage.c:3003:57: warning: ‘struct usb_configuration’ declared inside parameter list
drivers/usb/gadget/f_mass_storage.c: In function ‘fsg_bind’:
drivers/usb/gadget/f_mass_storage.c:3006:31: error: dereferencing pointer to incomplete type
drivers/usb/gadget/f_mass_storage.c:3013:2: error: implicit declaration of function ‘usb_interface_id’
drivers/usb/gadget/f_mass_storage.c:3033:3: error: dereferencing pointer to incomplete type
drivers/usb/gadget/f_mass_storage.c:3034:6: error: dereferencing pointer to incomplete type
drivers/usb/gadget/f_mass_storage.c:3043:4: error: dereferencing pointer to incomplete type
drivers/usb/gadget/f_mass_storage.c:3044:7: error: dereferencing pointer to incomplete type
drivers/usb/gadget/f_mass_storage.c:3045:26: error: dereferencing pointer to incomplete type
drivers/usb/gadget/f_mass_storage.c:3067:14: warning: ‘struct usb_configuration’ declared inside parameter list
drivers/usb/gadget/f_mass_storage.c:3067:14: warning: ‘struct usb_composite_dev’ declared inside parameter list
drivers/usb/gadget/f_mass_storage.c: In function ‘fsg_bind_config’:
drivers/usb/gadget/f_mass_storage.c:3093:2: error: implicit declaration of function ‘usb_add_function’
drivers/usb/gadget/f_mass_storage.c:3103:9: warning: ‘struct usb_configuration’ declared inside parameter list
drivers/usb/gadget/f_mass_storage.c:3103:9: warning: ‘struct usb_composite_dev’ declared inside parameter list
drivers/usb/gadget/f_mass_storage.c: In function ‘fsg_add’:
drivers/usb/gadget/f_mass_storage.c:3105:2: warning: passing argument 1 of ‘fsg_bind_config’ from incompatible pointer type
drivers/usb/gadget/f_mass_storage.c:3065:12: note: expected ‘struct usb_composite_dev *’ but argument is of type ‘struct usb_composite_dev *’
drivers/usb/gadget/f_mass_storage.c:3105:2: warning: passing argument 2 of ‘fsg_bind_config’ from incompatible pointer type
drivers/usb/gadget/f_mass_storage.c:3065:12: note: expected ‘struct usb_configuration *’ but argument is of type ‘struct usb_configuration *’
drivers/usb/gadget/f_mass_storage.c:3190:23: warning: ‘struct usb_composite_dev’ declared inside parameter list
drivers/usb/gadget/f_mass_storage.c:3195:23: warning: ‘struct usb_composite_dev’ declared inside parameter list
drivers/usb/gadget/f_mass_storage.c:3193:1: error: conflicting types for ‘fsg_common_from_params’
drivers/usb/gadget/f_mass_storage.c:3188:1: note: previous declaration of ‘fsg_common_from_params’ was here
drivers/usb/gadget/f_mass_storage.c: In function ‘fsg_common_from_params’:
drivers/usb/gadget/f_mass_storage.c:3199:2: warning: passing argument 2 of ‘fsg_common_init’ from incompatible pointer type
drivers/usb/gadget/f_mass_storage.c:2741:27: note: expected ‘struct usb_composite_dev *’ but argument is of type ‘struct usb_composite_dev *’
make[1]: *** [drivers/usb/gadget/f_mass_storage.o] Error 1
make: *** [drivers/usb/gadget/f_mass_storage.o] Error 2
This is due to the missing include of linux/usb/composite.h - this patch
adds the missing include.
In addition there's also a problem in fsg_common_init() where we memset
'common', but we use the size of a pointer to 'struct fsg_common' as the
size argument to memset(), not the actual size of the struct. This patch
fixes the sizeof so we zero the entire struct as intended.
This patch fixes the below compilation errors.
CC drivers/usb/gadget/ci13xxx_msm.o
CC net/mac80211/led.o
drivers/usb/gadget/ci13xxx_msm.c: In function 'ci13xxx_msm_notify_event':
drivers/usb/gadget/ci13xxx_msm.c:42: error: 'USB_AHBBURST' undeclared (first use in this function)
drivers/usb/gadget/ci13xxx_msm.c:42: error: (Each undeclared identifier is reported only once
drivers/usb/gadget/ci13xxx_msm.c:42: error: for each function it appears in.)
drivers/usb/gadget/ci13xxx_msm.c:43: error: 'USB_AHBMODE' undeclared (first use in this function)
make[4]: *** [drivers/usb/gadget/ci13xxx_msm.o] Error 1
make[3]: *** [drivers/usb/gadget] Error 2
MSM USB driver is not supported on boards like trout (MSM7201) which
has an external PHY.
Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (27 commits)
gpu/stub: fix acpi_video build error, fix stub kconfig dependencies
drm/radeon/kms: dynamically allocate power state space
drm/radeon/kms: fix s/r issues with bios scratch regs
agp: ensure GART has an address before enabling it
Revert "agp: AMD AGP is used on UP1100 & UP1500 alpha boxen"
amd-k7-agp: remove non-x86 code
drm/radeon/kms/evergreen: always set certain VGT regs at CP init
drm/radeon/kms: add updated ib_execute function for evergreen
drm/radeon: remove 0x4243 pci id
drm/radeon/kms: Enable new pll calculation for avivo+ asics
drm/radeon/kms: add new pll algo for avivo asics
drm/radeon/kms: add pll debugging output
drm/radeon/kms: switch back to min->max pll post divider iteration
drm/radeon/kms: rv6xx+ thermal sensor fixes
drm/nv50: fix display on 0x50
drm/nouveau: correctly pair hwmon_init and hwmon_fini
drm/i915: Only bind to function 0 of the PCI device
drm/i915: Suppress spurious vblank interrupts
drm: Avoid leak of adjusted mode along quick set_mode paths
drm: Simplify and defend later checks when disabling a crtc
In drm_crtc_helper_set_config, instead of always forcing all outputs
to DRM_MODE_DPMS_ON, only set them if the CRTC is actually getting a
mode set, as any mode set will turn all outputs on.
This fixes https://lkml.org/lkml/2011/1/24/457
Signed-off-by: Keith Packard <keithp@keithp.com>
Cc: stable@kernel.org (2.6.37)
Reported-and-tested-by: Carlos R. Mafra <crmafra2@gmail.com>
Tested-by: Takashi Iwai <tiwai@suse.de>
While the RxFIFO interruption is masked for most 8168, nothing prevents
it to appear in the irq status word. This is no excuse to crash.
Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
Cc: Ivan Vecera <ivecera@redhat.com>
Cc: Hayes <hayeswang@realtek.com>
Some experiment-based action to prevent my 8168 chipsets locking-up hard
in the irq handler under load (pktgen ~1Mpps). Apparently a reset is not
always mandatory (is it at all ?).
- RTL_GIGA_MAC_VER_12
- RTL_GIGA_MAC_VER_25
Missed ~55% packets. Note:
- this is an old SiS 965L motherboard
- the 8168 chipset emits (lots of) control frames towards the sender
- RTL_GIGA_MAC_VER_26
The chipset does not go into a frenzy of mac control pause when it
crashes yet but it can still be crashed. It needs more work.
I found that one of the 8168c chipsets (concretely XID 1c4000c0) starts
generating RxFIFO overflow errors. The result is an infinite loop in
interrupt handler as the RxFIFOOver is handled only for ...MAC_VER_11.
With the workaround everything goes fine.
Signed-off-by: Ivan Vecera <ivecera@redhat.com>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
The comments under "config STUB_POULSBO" are close to correct,
but they are not being followed. This patch updates them to reflect
the requirements for THERMAL.
This build error is caused by STUB_POULSBO selecting ACPI_VIDEO
when ACPI_VIDEO's config requirements are not met.
ERROR: "thermal_cooling_device_register" [drivers/acpi/video.ko] undefined!
ERROR: "thermal_cooling_device_unregister" [drivers/acpi/video.ko] undefined!
Tested-by: Ingo Molnar <mingo@elte.hu>
There is a msleep with spin lock held during ehci pci suspend, which will
cause kernel BUG: scheduling while atomic. Fix that.
[ 184.139620] BUG: scheduling while atomic: kworker/u:11/416/0x00000002
[ 184.139632] 4 locks held by kworker/u:11/416:
[ 184.139640] #0: (events_unbound){+.+.+.}, at: [<c104ddd4>] process_one_work+0x1b3/0x4cb
[ 184.139669] #1: ((&entry->work)){+.+.+.}, at: [<c104ddd4>] process_one_work+0x1b3/0x4cb
[ 184.139686] #2: (&__lockdep_no_validate__){+.+.+.}, at: [<c127cde3>] __device_suspend+0x2c/0x154
[ 184.139706] #3: (&(&ehci->lock)->rlock){-.-...}, at: [<c132f3d8>] ehci_pci_suspend+0x35/0x7b
[ 184.139725] Modules linked in: serio_raw pegasus joydev mrst_gfx(C) battery
[ 184.139748] irq event stamp: 52
[ 184.139753] hardirqs last enabled at (51): [<c14fdaac>] mutex_lock_nested+0x258/0x293
[ 184.139766] hardirqs last disabled at (52): [<c14fe7b4>] _raw_spin_lock_irqsave+0xf/0x3e
[ 184.139777] softirqs last enabled at (0): [<c10371c1>] copy_process+0x3d2/0x109d
[ 184.139789] softirqs last disabled at (0): [< (null)>] (null)
[ 184.139802] Pid: 416, comm: kworker/u:11 Tainted: G C 2.6.37-6.3-adaptation-oaktrail #37
[ 184.139809] Call Trace:
[ 184.139820] [<c102eeff>] __schedule_bug+0x5e/0x65
[ 184.139829] [<c14fbca5>] schedule+0xac/0xc4c
[ 184.139840] [<c11d4845>] ? string+0x37/0x8b
[ 184.139853] [<c1044f21>] ? lock_timer_base+0x1f/0x3e
[ 184.139863] [<c14fe7da>] ? _raw_spin_lock_irqsave+0x35/0x3e
[ 184.139876] [<c1061590>] ? trace_hardirqs_off+0xb/0xd
[ 184.139885] [<c14fccdc>] schedule_timeout+0x283/0x2d9
[ 184.139896] [<c104516f>] ? process_timeout+0x0/0xa
[ 184.139906] [<c14fcd47>] schedule_timeout_uninterruptible+0x15/0x17
[ 184.139916] [<c104566a>] msleep+0x10/0x16
[ 184.139926] [<c132f316>] ehci_adjust_port_wakeup_flags+0x69/0xf6
[ 184.139937] [<c132f3eb>] ehci_pci_suspend+0x48/0x7b
[ 184.139946] [<c1326587>] suspend_common+0x52/0xbb
[ 184.139956] [<c1326625>] hcd_pci_suspend+0x26/0x28
[ 184.139967] [<c11e7182>] pci_pm_suspend+0x5f/0xd0
[ 184.139976] [<c127ca3a>] pm_op+0x5d/0xf0
[ 184.139986] [<c127ceac>] __device_suspend+0xf5/0x154
[ 184.139996] [<c127d2c8>] async_suspend+0x16/0x3a
[ 184.140006] [<c1058f54>] async_run_entry_fn+0x89/0x111
[ 184.140016] [<c104deb6>] process_one_work+0x295/0x4cb
[ 184.140026] [<c1058ecb>] ? async_run_entry_fn+0x0/0x111
[ 184.140036] [<c104e3d0>] worker_thread+0x17f/0x298
[ 184.140045] [<c104e251>] ? worker_thread+0x0/0x298
[ 184.140055] [<c105277f>] kthread+0x64/0x69
[ 184.140064] [<c105271b>] ? kthread+0x0/0x69
[ 184.140075] [<c1002efa>] kernel_thread_helper+0x6/0x1a
Signed-off-by: Yin Kangkai <kangkai.yin@intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
CC: David Brownell <dbrownell@users.sourceforge.net>
CC: stable@kernel.org
* 'for-greg' of git://gitorious.org/usb/usb:
usb: ehci-omap: Show fatal probing time errors to end user
usb: musb: introduce api for dma code to check compatibility with usb request
usb: musb: maintain three states for buffer mappings instead of two
usb: musb: disable double buffering when it's broken
usb: musb: hsdma: change back to use musb_read/writew
usb: musb: core: fix IRQ check
usb: musb: fix kernel panic during s2ram(v2)
This patch (as1444) adds an unusual_devs entry for an MP3 player from
Coby electronics. The device has two nasty bugs.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Jasper Mackenzie <scarletpimpernal@hotmail.com>
Add the USB Vendor ID and Product ID for a Acton Research Corp.
spectrograph device with a FTDI chip for serial I/O.
Signed-off-by: Michael H Williamson <michael.h.williamson@gmail.com>
The USB core keeps track of pending resume requests for root hubs, in
order to resolve races between wakeup requests and suspends. However
the code that does this is subject to another race (between wakeup
requests and resumes) because the WAKEUP_PENDING flag is cleared
before the resume occurs, leaving a window in which another wakeup
request might arrive.
This patch (as1447) fixes the problem by clearing the WAKEUP_PENDING
flag after the resume instead of before it.
This fixes Bugzilla #24952.
Tested-by: Paul Bender <pebender@san.rr.com>
Tested-by: warpme <warpme@o2.pl>
Cc: stable <stable@kernel.org> [.36+]
If anyone comes across a high-speed hub that (by mistake or by design)
claims to have no Transaction Translators, plugging a full- or
low-speed device into it will cause the USB stack to crash. This
patch (as1446) prevents the problem by ignoring such devices, since
the kernel has no way to communicate with them.
Tested-by: Perry Neben <neben@vmware.com>
CC: <stable@kernel.org>
Signed-off-by: Yusuke Goda <yusuke.goda.sx@renesas.com>
Acked-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
on ST Micro Connect Lite we have 4 port
Part A and B for the JTAG
Port C Uart
Port D for PIO
This device suffers from the off-by-one error when reporting the capacity,
so add entry with US_FL_FIX_CAPACITY.
Signed-off-by: Nick Holloway <Nick.Holloway@pyrites.org.uk>
In drivers/usb/host/sl811-hcd.c::sl811h_urb_enqueue(), memory is allocated
with kzalloc() and assigned to 'ep'. If we leave via the 'fail' label due
to 'if (ep->maxpacket > H_MAXPACKET)', then 'ep' will go out of scope
without having been assigned to anything, so we'll leak the memory we
allocated.
This patch fixes the leak by simply calling kfree(ep); before jumping to
the 'fail' label.
If usb_deregister() is called after usb_serial_deregister() when
the device is plugged in, the following Oops occurs:
[ 95.337377] BUG: unable to handle kernel NULL pointer dereference at 00000010
[ 95.338236] IP: [<c0776b2d>] klist_put+0x12/0x62
[ 95.338356] *pdpt = 000000003001a001 *pde = 0000000000000000
[ 95.338356] Oops: 0000 [#1] SMP
[ 95.340499] last sysfs file: /sys/devices/pci0000:00/0000:00:1d.2/usb8/idVendor
[ 95.340499] Modules linked in: ti_usb_3410_5052(-) usbserial cpufreq_ondemand acpi_cpufreq mperf iptable_nat nf_nat iptable_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter ip6_tables ipv6 uinput arc4 ecb iwlagn iwlcore mac80211 cfg80211 microcode pcspkr acer_wmi joydev wmi sky2 [last unloaded: scsi_wait_scan]
[ 95.341908]
[ 95.341908] Pid: 1532, comm: modprobe Not tainted 2.6.37-rc7+ #6 Eiger /Aspire 5930
[ 95.341908] EIP: 0060:[<c0776b2d>] EFLAGS: 00010246 CPU: 0
[ 95.341908] EIP is at klist_put+0x12/0x62
[ 95.341908] EAX: 00000000 EBX: eedc0c84 ECX: c09c21b4 EDX: 00000001
[ 95.341908] ESI: 00000000 EDI: efaa0c1c EBP: f214fe2c ESP: f214fe1c
[ 95.341908] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 95.341908] Process modprobe (pid: 1532, ti=f214e000 task=efaaf080 task.ti=f214e000)
[ 95.341908] Stack:
[ 95.341908] f214fe24 eedc0c84 efaaf080 efaa0c1c f214fe34 c0776ba8 f214fe5c c0776c76
[ 95.341908] c09c21b4 c09c21b4 eedc0c84 efaaf080 00000000 c0634398 eafe2d1c f7b515f0
[ 95.341908] f214fe6c c0631b5c eafe2d50 eafe2d1c f214fe7c c0631ba2 eafe2d1c eafe2c00
[ 95.341908] Call Trace:
[ 95.341908] [<c0776ba8>] ? klist_del+0xd/0xf
[ 95.341908] [<c0776c76>] ? klist_remove+0x48/0x74
[ 95.341908] [<c0634398>] ? devres_release_all+0x49/0x51
[ 95.341908] [<c0631b5c>] ? __device_release_driver+0x7b/0xa4
[ 95.341908] [<c0631ba2>] ? device_release_driver+0x1d/0x28
[ 95.341908] [<c06317c4>] ? bus_remove_device+0x92/0xa1
[ 95.341908] [<c062f3d8>] ? device_del+0xf9/0x13e
[ 95.341908] [<f7b06146>] ? usb_serial_disconnect+0xd9/0x116 [usbserial]
[ 95.341908] [<c0681e3f>] ? usb_disable_interface+0x32/0x40
[ 95.341908] [<c0683972>] ? usb_unbind_interface+0x48/0xfd
[ 95.341908] [<c0631b43>] ? __device_release_driver+0x62/0xa4
[ 95.341908] [<c06320b9>] ? driver_detach+0x62/0x81
[ 95.341908] [<c0631a41>] ? bus_remove_driver+0x8f/0xae
[ 95.341908] [<c063214c>] ? driver_unregister+0x50/0x57
[ 95.341908] [<c0682f95>] ? usb_deregister+0x77/0x84
[ 95.341908] [<f7b505b6>] ? ti_exit+0x26/0x28 [ti_usb_3410_5052]
[ 95.341908] [<c046a307>] ? sys_delete_module+0x181/0x1de
[ 95.341908] [<c04e2727>] ? path_put+0x1a/0x1d
[ 95.341908] [<c047f4c5>] ? audit_syscall_entry+0x116/0x138
[ 95.341908] [<c04094df>] ? sysenter_do_call+0x12/0x28
[ 95.341908] Code: 00 83 7d f0 00 74 09 85 f6 74 05 89 f0 ff 55 f0 8b 43 04 5a 5b 5e 5f 5d c3 55 89 e5 57 56 53 89 c3 83 ec 04 8b 30 83 e6 fe 89 f0 <8b> 7e 10 88 55 f0 e8 47 26 01 00 8a 55 f0 84 d2 74 17 f6 03 01
[ 95.341908] EIP: [<c0776b2d>] klist_put+0x12/0x62 SS:ESP 0068:f214fe1c
[ 95.341908] CR2: 0000000000000010
[ 95.342357] ---[ end trace 8124d00ad871ad18 ]---
Signed-off-by: Ionut Nicu <ionut.nicu@mindbit.ro>
The major and minor number saved in the product_info structure
were copied from the address instead of the data, causing an
inconsistency in the reported versions during firmware loading:
usb 4-1: firmware: requesting edgeport/down.fw
/usr/src/linux/drivers/usb/serial/io_edgeport.c: downloading firmware version (930) 1.16.4
/usr/src/linux/drivers/usb/serial/io_edgeport.c: edge_startup - time 3 4328191260
/usr/src/linux/drivers/usb/serial/io_edgeport.c: FirmwareMajorVersion 0.0.4
This can cause some confusion whether firmware loaded successfully
or not.
Signed-off-by: Bjørn Mork <bjorn@mork.no>
As reported by Flavio Leitner, there is no synchronization to protect
NIU's get_stats method from seeing a NULL pointer in either
np->rx_rings or np->tx_rings. In fact, as far as ->ndo_get_stats
is concerned, these values are set completely asynchronously.
Flavio attempted to fix this using a RW semaphore, which in fact
works most of the time. However, dev_get_stats() can be invoked
from non-sleepable contexts in some cases, so this fix doesn't
work in all cases.
So instead, control the visibility of the np->{rx,tx}_ring pointers
when the device is being brough up, and use properties of the device
down sequence to our advantage.
In niu_get_stats(), return immediately if netif_running() is false.
The device shutdown sequence first marks the device as not running (by
clearing the __LINK_STATE_START bit), then it performans a
synchronize_rcu() (in dev_deactive_many()), and then finally it
invokes the driver ->ndo_stop() method.
This guarentees that all invocations of niu_get_stats() either see
netif_running() as false, or they see the channel pointers before
->ndo_stop() clears them out.
If netif_running() is true, protect against startup races by loading
the np->{rx,tx}_rings pointer into a local variable, and punting if
it is NULL. Use ACCESS_ONCE to prevent the compiler from reloading
the pointer on us.
Also, during open, control the order in which the pointers and the
ring counts become visible globally using SMP write memory barriers.
We make sure the np->num_{rx,tx}_rings value is stable and visible
before np->{rx,tx}_rings is.
Such visibility control is not necessary on the niu_free_channels()
side because of the RCU sequencing that happens during device down as
described above. We are always guarenteed that all niu_get_stats
calls are finished, or will see netif_running() false, by the time
->ndo_stop is invoked.
Reported-by: Flavio Leitner <fleitner@redhat.com>
We previously used a static array, but some new systems
had more states then we had array space, so dynamically
allocate space based on the number of states in the vbios.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=33851
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
The accelerate mode bit gets checked by certain atom
command tables to set up some register state. It needs
to be clear when setting modes and set when not.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=26942
Some BIOSs (eg. the AMI BIOS on the Asus P4P800 motherboard) don't
initialise the GART address, and pcibios_assign_resources() can ignore it
because it can be marked as a host bridge (see
https://bugzilla.kernel.org/show_bug.cgi?id=24392#c5 for details). This
was handled correctly up to 2.6.35, but the pci_enable_device() cleanup in
2.6.36 96576a9e1a0cdb8 ("agp: intel-agp: do not use PCI resources before
pci_enable_device()") means that the kernel tries to enable the GART
before assigning it an address; in such cases the GART overlaps with other
device assignments and ends up being disabled.
This patch fixes https://bugzilla.kernel.org/show_bug.cgi?id=24392
Note that I imagine efficeon-agp.c probably has the same problem, but
I can't test that and I'd like to make sure this patch is suitable for
-stable (since 2.6.36 and 2.6.37 are affected).
Signed-off-by: Stephen Kitt <steve@sk2.org>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Kulikov Vasiliy <segooon@gmail.com>
Cc: Florian Mickler <florian@mickler.org>
This reverts commit f191f144079b0083c6fa7d01a4acbd7263fb5032.
The AMD 751 and 761 chipsets are used on the UP1000, UP1100, and UP1500
OEM motherboards, but they neglect to do anything to make AGP work.
According to Ivan Kokshaysky:
There is quite fundamental conflict between the Alpha architecture and
x86 AGP implementation - Alpha is entirely cache coherent by design,
while x86 AGP is not (I mean native AGP DMA transactions, not a PCI over
AGP). There are no such things as non-cacheable mappings or software
support for cache flushing/invalidation on Alpha, so x86 AGP code won't
work on Nautilus.
So there's no point in allowing this driver to be configured on Alpha.
Signed-off-by: Matt Turner <mattst88@gmail.com>
amd-k7-agp can't be built on Alpha anymore, so remove now unnecessary
code.
These should be handled by the clear_state setup, but set them
directly as well just to be sure.
Adds new packet to disable DX9 constant emulation.
The RX lock is used to protect the RX buffer from concurrent access in DMA
mode between the timer and RX interrupt routines. It is independent from
the uart lock which is used to protect the TX buffer. It is possible for
a uart TX transfer to be started up from the RX interrupt handler if low
latency is enabled. So we need to split the locks to avoid deadlocking in
this situation.
In PIO mode, the RX lock is not necessary because the handle_simple_irq
and handle_level_irq functions ensure driver interrupt handlers are called
once on one core.
And now that the RX path has its own lock, the TX interrupt has nothing to
do with the RX path, so disabling it at the same time.
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
Commit 0587102cf9f427c185bfdeb2cef41e13ee0264b1 replaced a direct
implementation of SIOCGICOUNT with an implementation of
tty_operations::get_icount, but it did not actually set
rs_360_ops.get_icount.
Cc: stable@kernel.org [2.6.37]
This field is settable but did not get copied.
Signed-off-by: Ken Mills <ken.k.mills@intel.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Commit 728674a7e466628df2aeec6d11a2ae1ef968fb67 moved virtio_console.c
to drivers/tty/hvc/ under the perception of this being an hvc driver.
It was such once, but these days it has generic communication
capabilities as well, so move it to drivers/char/.
In the future, the hvc part from this file can be split off and moved
under drivers/tty/hvc/.
Signed-off-by: Amit Shah <amit.shah@redhat.com>
CC: Rusty Russell <rusty@rustcorp.com.au>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6:
[SCSI] libsas: fix runaway error handler problem
[SCSI] fix incorrect value of SCSI_MAX_SG_CHAIN_SEGMENTS due to include file ordering
[SCSI] arcmsr: Fix the issue of system hangup after commands timeout on ARC-1200
[SCSI] mpt2sas: fix Integrated Raid unsynced on shutdown problem
[SCSI] mpt2sas: Kernel Panic during Large Topology discovery
[SCSI] mpt2sas: Fix the race between broadcast asyn event and scsi command completion
[SCSI] mpt2sas: Correct resizing calculation for max_queue_depth
[SCSI] mpt2sas: fix internal device reset for older firmware prior to MPI Rev K
[SCSI] mpt2sas: Fix device removal handshake for zoned devices
This patch prevents a user space program from calling the RTC_IRQP_SET
ioctl with a negative value of frequency. Also, if this call is make
with a zero value of frequency, there would be a division by zero in the
kernel code.
[jstultz: Also initialize irq_freq to 1 to catch other divbyzero issues]
CC: Alessandro Zummo <a.zummo@towertech.it>
CC: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
Signed-off-by: John Stultz <john.stultz@linaro.org>
wl1251_op_bss_info_changed()
In drivers/net/wireless/wl1251/main.c:wl1251_op_bss_info_changed() we make
a call to ieee80211_beacon_get() which may return NULL, but we do not
check the return value before dereferencing the pointer.
