path: root/drivers
2007-02-17[PARISC] Convert soft power switch driver to kthreadHelge Deller
And remove it's reference in time.c. Allow lcd_print() to take a const char *. Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] lba_pci format warningsMatthew Wilcox
Fix resource_size_t warnings in a variety of ways Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17Merge branch 'parisc' from /home/kyle/repos/parisc-2.6.gitKyle McMartin
Conflicts: arch/parisc/hpux/sys_hpux.c arch/parisc/mm/ioremap.c
2007-02-08[PATCH] parisc: fix module_param iommu permissionRandy Dunlap
Fix/change module_param permissions parameter from an init value to a permission value. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-02-03[PATCH] fix rtl8150Al Viro
That code doesn't do what its author apparently thought it would do... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-03Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] sd: udev accessing an uninitialized scsi_disk field results in a crash [SCSI] st: A MTIOCTOP/MTWEOF within the early warning will cause the file number to be incorrect [SCSI] qla4xxx: bug fixes [SCSI] Fix scsi_add_device() for async scanning
2007-02-03[PATCH] net/smc911x: match up spin lock/unlockPeter Korsgaard
smc911x_phy_configure's error handling unconditionally unlocks the spinlock even if it wasn't locked. Patch fixes it. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Cc: Jeff Garzik <jeff@garzik.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-02[SCSI] sd: udev accessing an uninitialized scsi_disk field results in a crashNagendra Singh Tomar
sd_probe() calls class_device_add() even before initializing the sdkp->device variable. class_device_add() eventually results in the user mode udev program to be called. udev program can read the the allow_restart attribute of the newly created scsi device. This is resulting in a crash as the show function for allow_restart (i.e sd_show_allow_restart) returns the attribute value by reading the sdkp->device->allow_restart variable. As the sdkp->device is not initialized before calling the user mode hotplug helper, this results in a crash. The patch below solves it by calling class_device_add() only after the necessary fields in the scsi_disk structure are initialized properly. Signed-off-by: Nagendra Singh Tomar <nagendra_tomar@adaptec.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata: Initialize nbytes for internal sg commands libata: Fix ata_busy_wait() kernel docs pata_via: Correct missing comments pata_atiixp: propogate cable detection hack from drivers/ide to the new driver ahci/pata_jmicron: fix JMicron quirk
2007-02-02libata: Initialize nbytes for internal sg commandsBrian King
Some LLDDs, like ipr, use nbytes and pad_len to determine the total data transfer length of a command. Make sure nbytes gets initialized for internally generated commands. Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-02pata_via: Correct missing commentsAlan
The 8237S was added to the chipsets but not to the comments. Fix this Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-02pata_atiixp: propogate cable detection hack from drivers/ide to the new driverAlan
2007-02-02ahci/pata_jmicron: fix JMicron quirkTejun Heo
For all JMicrons except for 361 and 368, AHCI mode enable bits in the Control(1) should be set. This used to be done in both ahci and pata_jmicron but while moving programming to PCI quirk, it was removed from ahci part while still left in pata_jmicron. The implemented JMicron PCI quirk was incorrect in that it didn't program AHCI mode enable bits. If pata_jmicron is loaded first and programs those bits, the ahci ports work; otherwise, ahci device detection fails miserably. This patch makes JMicron PCI quirk clear SATA IDE mode bits and set AHCI mode bits and remove the respective part from pata_jmicron. Tested on JMB361, 363 and 368. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: spidernet : fix memory leak in spider_net_stop e100: fix napi ifdefs removing needed code netxen patches
2007-02-02spidernet : fix memory leak in spider_net_stopJens Osterkamp
We forget to call spider_net_free_rx_chain_contents which does the actual dev_kfree_skb. New skbs are allocated from skbuff_head_cache on each "ifconfig up" letting the cache grow infinitely. This patch fixes it. Signed-off-by: Jens Osterkamp <jens@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-02e100: fix napi ifdefs removing needed codeAuke Kok
e100: fix napi ifdefs removing needed code From: Auke Kok <auke-jan.h.kok@intel.com> The e100 driver is NAPI mode only. We need to netif_poll_disable during suspend and shutdown. The non-NAPI driver code was removed and is only avaiable in the out-of-tree e100 kernel driver. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-02Merge ../linux-2.6Jeff Garzik
2007-02-02[BNX2]: PHY workaround for 5709 A0.Michael Chan
5709 A0 copper devices will not link up with some link partners without this workaround. Update driver to 1.5.5. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-01[PATCH] via82cxxx: fix typo ("cx7000" should be corrected to "cx700")Bartlomiej Zolnierkiewicz
Noticed by JosephChan@via.com.tw. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] sysrq: showBlockedTasks is sysrq-WRandy Dunlap
Change SysRq showBlockedTasks from sysrq-X to sysrq-W and show that in the Help message. It was previously done via X, but X is already used for Xmon on ppc & powerpc platforms and this collision needs to be avoided. All callers of register_sysrq_key() are now marked in the sysrq op/key table. I didn't mark 'h' as Help because Help is just printed for any unknown key, such as '?'. Added some omitted sysrq key entries in the sysrq.txt file. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] KVM: fix lockup on 32-bit intel hosts with nx disabled in the biosAvi Kivity
Intel hosts, without long mode, and with nx support disabled in the bios have an efer that is readable but not writable. This causes a lockup on switch to guest mode (even though it should exit with reason 34 according to the documentation). Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] pci: remove warning messagesAndrew Morton
Remove these recently-added warnings. They don't tell us anythng very interesting and Kumar says "On an embedded PPC reference system I see this message 6 times when I've got no cards in the PCI slots." Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] via quirk updateJean Delvare
Add special handling for the VT82C686. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] radio modems sitting on serial port are not for s390Al Viro
Won't build (request_irq()/free_irq()), even if you manage to find an s390 box with 8250-compatible UART they are expecting. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] ide section fixesAl Viro
a) cleanup_module() should be __exit b) externs should match reality Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-31netxen patchesAl Viro
Have fun. >From 24f4a1a77431575a9cdfaae25adda85842099f70 Mon Sep 17 00:00:00 2001 From: Al Viro <viro@zeniv.linux.org.uk> Date: Mon, 1 Jan 2007 15:22:56 -0500 Subject: [PATCH] netxen trivial annotations Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-30Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jikos/hid: HID: fix pb_fnmode and move it to generic HID HID: fix hid-input mapping for Firefly Mini Remote Control USB HID: fix hid_blacklist clash for 0x08ca/0x0010 HID: fix memleaking of collection
2007-01-30[PATCH] IPMI: fix timeout list handlingDavid Barksdale
Fix a dangling pointer bug in ipmi_timeout_handler. A list of timedout messages is not re-initialized before reuse, causing the head of the list to point to freed memory. Signed-off-by: David Barksdale <amatus@ocgnet.org> Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] jmicron: 40/80pin primary detectionethanhsiao@jmicron.com
jmicron module detects all JMB36x as JMB361 and PATA0 has wrong pin status of XICBLID. Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] Fix VIA quirksJean Delvare
Fix VIA quirks that were recently broken by Alan Cox in the upstream kernel (commit 1597cacbe39802d86656d1f2e6329895bd2ef531). My understanding is that pci_find_present() doesn't work yet at the time the quirks are run. So I used a two-step quirk as is done for some other quirks already. First we detect the VIA south bridges and set the right low and high device limits, then we are ready to actually run the quirks on the affected devices. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30Revert "net: ifb error path loop fix"Linus Torvalds
This reverts commit 0c0b3ae68ec93b1db5c637d294647d1cca0df763. Quoth David: "Jeff, please revert It's wrong. We had a lengthy analysis of this piece of code several months ago, and it is correct. Consider, if we run the loop and we get an error the following happens: 1) attempt of ifb_init_one(i) fails, therefore we should not try to "ifb_free_one()" on "i" since it failed 2) the loop iteration first increments "i", then it check for error Therefore we must decrement "i" twice before the first free during the cleanup. One to "undo" the for() loop increment, and one to "skip" the ifb_init_one() case which failed." Reported-by: David Miller <davem@davemloft.net> Acked-by: Jeff Garzik <jgarzik@pobox.com> Cc: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata: fix translation for START STOP UNIT libata-scsi: ata_task_ioctl should return ATA registers from sense data pata_platform: set_mode fix ata_if_xfermask() word 51 fix pata_sil680: PIO1 taskfile transfers overclocking fix (repost) libata: fix ata_eh_suspend() return value ahci: port_no should be used when clearing IRQ in ahci_thaw() Fix trivial conflict in drivers/ata/pata_platform.c manually
2007-01-30Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreqLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/cpufreq: [CPUFREQ] Remove unneeded errata workaround from p4-clockmod. [CPUFREQ] check sysfs_create_link return value
2007-01-30Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] Add new IDs to VIA AGP. [AGPGART] Remove pointless assignment. [AGPGART] Remove pointless typedef in ati-agp [AGPGART] Prevent (unlikely) memory leak in amd_create_gatt_pages() [AGPGART] intel_agp: restore graphics device's pci space early in resume
2007-01-30Merge master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/bart/ide-2.6: via82cxxx/pata_via: correct PCI_DEVICE_ID_VIA_SATA_EIDE ID and add support for CX700 and 8237S ide: unregister idepnp driver on unload ide: add missing __init tags to IDE PCI host drivers ia64: add pci_get_legacy_ide_irq() ide/generic: Jmicron has its own drivers now atiixp.c: add cable detection support for ATI IDE atiixp.c: sb600 ide only has one channel atiixp.c: remove unused code jmicron: fix warning ide: update MAINTAINERS entry
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6 * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6: Broadcom 4400 resume small fix b44: src_desc->addr is little-endian e100: fix irq leak on suspend/resume bonding: ARP monitoring broken on x86_64 ehea: Fixed missing tasklet_kill() call ehea: Fixed wrong jumbo frames status query 82596 warning fixes FS_ENET: OF-related fixup for FEC and SCC MAC's net: ifb error path loop fix b44: Fix frequent link changes
2007-01-30[PATCH] b44: src_desc->addr is little-endianAl Viro
2007-01-30[PATCH] pata_platform: fallout from set_mode() changeAl Viro
2007-01-30[PATCH] sym53c500_cs: remove bogus call fo free_dma()Al Viro
What DMA for 16bit pcmcia card, anyway? We never do request_dma() there and ->dma_channel never changes since initialization to -1. IOW, that call is dead code. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30[PATCH] mtd/nand/cafe.c missing include of dma-mapping.hAl Viro
2007-01-30Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: [ARM] 4117/1: S3C2412: Fix writel() usage in selection code [ARM] 4111/1: Allow VFP to work with thread migration on SMP [ARM] 4112/1: Only ioremap to supersections if DOMAIN_IO is zero [ARM] 4106/1: S3C2410: typo fixes in register definitions [ARM] 4102/1: Allow for PHYS_OFFSET on any valid 2MiB address [ARM] Fix AMBA serial drivers for non-first serial ports [ARM] 4100/1: iop3xx: fix cpu mask for iop333 [ARM] Update mach-types [ARM] Fix show_mem() for discontigmem [ARM] 4096/1: S3C24XX: change return code form s3c2410_gpio_getcfg() [ARM] 4095/1: S3C24XX: Fix GPIO set for Bank A [ARM] 4092/1: i.MX/MX1 CPU Frequency scaling latency definition [ARM] 4089/1: AT91: GPIO wake IRQ cleanup [ARM] 4088/1: AT91: Unbalanced IRQ in serial driver suspend/resume [ARM] 4087/1: AT91: CPU reset for SAM9x processors [ARM] 4086/1: AT91: Whitespace cleanup [ARM] 4085/1: AT91: Header fixes. [ARM] 4084/1: Remove CONFIG_DEBUG_WAITQ
2007-01-30[PATCH] Fix "CONFIG_X86_64_" typo in drivers/kvm/svm.cRobert P. J. Day
Fix what looks like an obvious typo in the file drivers/kvm/svm.c. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-30Broadcom 4400 resume small fixDmitriy Monakhov
Some issues in b44_resume(). - Return value of pci_enable_device() was ignored. - If request_irq() has failed we have to just disable device and exit. Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-30b44: src_desc->addr is little-endianAl Viro
2007-01-30e100: fix irq leak on suspend/resumeAuke Kok
e100: fix irq leak on suspend/resume From: Frederik Deweerdt <frederik.deweerdt@gmail.com> The e100_resume() function should be calling netif_device_detach and free_irq. This fixes multiple irq's being allocated after resume. Signed-off-by: Frederik Deweerdt <frederik.deweerdt@gmail.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-30bonding: ARP monitoring broken on x86_64Andy Gospodarek
While working with the latest bonding code I noticed a nasty problem that will prevent arp monitoring from always functioning correctly on x86_64 systems. Comparing ints to longs and expecting reliable results on x86_64 is a bad idea. With this patch, arp monitoring works correctly again. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Hemminger <shemminger@osdl.org> Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-30ehea: Fixed missing tasklet_kill() callThomas Klein
NEQ-Tasklet wasn't killed when module is removed. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-30ehea: Fixed wrong jumbo frames status queryThomas Klein
This patch fixes the wrong query and logging of the per interface jumbo frames enabled/disabled status. Signed-off-by: Thomas Klein <tklein@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-3082596 warning fixesAndrew Morton
drivers/net/82596.c: In function 'i596_start_xmit': drivers/net/82596.c:1069: warning: cast from pointer to integer of different size drivers/net/82596.c: In function 'i82596_probe': drivers/net/82596.c:1249: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int' Cc: Jeff Garzik <jeff@garzik.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-01-30FS_ENET: OF-related fixup for FEC and SCC MAC'sVitaly Bordug
Updated direct resource pass with ioremap call, make it grant proper IRQ mapping, stuff incompatible with the new approach were respectively put under #ifndef CONFIG_PPC_MERGE. It is required so that both ppc and powerpc could utilize fs_enet effectively. Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
