Some Spansion chips have a method for determining eraseblock size that
is incompatible with similar ID chips of other sizes. This implements
some heuristic detection of these differences.
This patch checks for a 5-byte ID with trailing zeros as well as a
512-byte page size to ensure that chips are not misdetected as the
S30MLxxxP ORNAND series.
[Tweaked by Artem a bit]
Signed-off-by: Brian Norris <norris@broadcom.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Drivers may (and do) return negative errno values other than -1 from the
ecc.correct callback.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev
* 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev:
ahci: fix module refcount breakage introduced by libahci split
libata depends on scsi_host_template for module reference counting and
sht's should be owned by each low level driver. During libahci split,
the sht was left with libahci.ko leaving the actual low level drivers
not reference counted. This made ahci and ahci_platform always
unloadable even while they're being actively used.
Fix it by defining AHCI_SHT() macro in ahci.h and defining a sht for
each low level ahci driver.
stable: only applicable to 2.6.35.
Reported-by: Pedro Francisco <pedrogfrancisco@gmail.com>
Tested-by: Michael Tokarev <mjt@tls.msk.ru>
Cc: stable@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging
* 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging:
hwmon (coretemp): Fix build breakage if SMP is undefined
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6:
PCI: fix pci_resource_alignment prototype
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (47 commits)
tcp: Fix >4GB writes on 64-bit.
net/9p: Mount only matching virtio channels
de2104x: fix ethtool
tproxy: check for transparent flag in ip_route_newports
ipv6: add IPv6 to neighbour table overflow warning
tcp: fix TSO FACK loss marking in tcp_mark_head_lost
3c59x: fix regression from patch "Add ethtool WOL support"
ipv6: add a missing unregister_pernet_subsys call
s390: use free_netdev(netdev) instead of kfree()
sgiseeq: use free_netdev(netdev) instead of kfree()
rionet: use free_netdev(netdev) instead of kfree()
ibm_newemac: use free_netdev(netdev) instead of kfree()
smsc911x: Add MODULE_ALIAS()
net: reset skb queue mapping when rx'ing over tunnel
br2684: fix scheduling while atomic
de2104x: fix TP link detection
de2104x: fix power management
de2104x: disable autonegotiation on broken hardware
net: fix a lockdep splat
e1000e: 82579 do not gate auto config of PHY by hardware during nominal use
Commit e40cc4bdfd4b89813f072f72bd9c7055814d3f0f introduced
a build breakage if CONFIG_SMP is undefined. This commit
fixes the problem.
This fix is only a workaround. For a real fix, cpu_sibling_mask() should
be defined in UP include code, eg in linux/smp.h, and asm/smp.h should not be
included directly. This fix is currently not possible because asm/smp.h defines
cpu_sibling_mask() unconditionally and is included directly from many source
files.
Reported-by: Ingo Molnar <mingo@elte.hu>
Tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
The PKT_CTRL_CMD_STATUS device ioctl retrieves a pointer to a
pktcdvd_device from the global pkt_devs array. The index into this
array is provided directly by the user and is a signed integer, so the
comparison to ensure that it falls within the bounds of this array will
fail when provided with a negative index.
This can be used to read arbitrary kernel memory or cause a crash due to
an invalid pointer dereference. This can be exploited by users with
permission to open /dev/pktcdvd/control (on many distributions, this is
readable by group "cdrom").
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
[ Rather than add a cast, just make the function take the right type -Linus ]
When the interface is up, using ethtool breaks it because:
a) link is put down but media_timer interval is not shortened to NO_LINK
b) rxtx is stopped but not restarted
Also manual 10baseT-HD (and probably FD too - untested) mode does not work -
the link is forced up, packets are transmitted but nothing is received.
Changing CSR14 value to match documentation (not disabling link check) fixes this.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Acked-by: Jeff Garzik <jgarzik@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
RDMA/cxgb3: Turn off RX coalescing for iWARP connections
* master.kernel.org:/home/rmk/linux-2.6-arm: (28 commits)
ARM: 6411/1: vexpress: set RAM latencies to 1 cycle for PL310 on ct-ca9x4 tile
ARM: 6409/1: davinci: map sram using MT_MEMORY_NONCACHED instead of MT_DEVICE
ARM: 6408/1: omap: Map only available sram memory
ARM: 6407/1: mmu: Setup MT_MEMORY and MT_MEMORY_NONCACHED L1 entries
ARM: pxa: remove pr_<level> uses of KERN_<level>
ARM: pxa168fb: clear enable bit when not active
ARM: pxa: fix cpu_is_pxa*() not expanding to zero when not configured
ARM: pxa168: fix corrected reset vector
ARM: pxa: Use PIO for PI2C communication on Palm27x
ARM: pxa: Fix Vpac270 gpio_power for MMC
ARM: 6401/1: plug a race in the alignment trap handler
ARM: 6406/1: at91sam9g45: fix i2c bus speed
leds: leds-ns2: fix locking
ARM: dove: fix __io() definition to use bus based offset
dmaengine: fix interrupt clearing for mv_xor
ARM: kirkwood: Unbreak PCIe I/O port
ARM: Fix build error when using KCONFIG_CONFIG
ARM: 6383/1: Implement phys_mem_access_prot() to avoid attributes aliasing
ARM: 6400/1: at91: fix arch_gettimeoffset fallout
ARM: 6398/1: add proc info for ARM11MPCore/Cortex-A9 from ARM
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp:
amd64_edac: Fix driver module removal
git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel
* 'drm-intel-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ickle/drm-intel:
drm/i915/sdvo: Handle unsupported GET_SUPPORTED_ENHANCEMENTS gracefully
drm/i915/sdvo: Cleanup connector on error path
drm/i915: Fix 945GM regression in e259befd
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc:
mmc: sdhci-s3c: fix NULL ptr access in sdhci_s3c_remove
mmc: sdhci-s3c: fix incorrect spinlock usage after merge
mmc: MAINTAINERS: add myself as MMC maintainer
git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6
* 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
pcmcia: pd6729: Fix error path
pcmcia: preserve configuration information if request_io fails partly
* git://git.infradead.org/iommu-2.6:
intel-iommu: Use symbolic values instead of magic numbers in Lenovo w/a
intel-iommu: Abort IOMMU setup for igfx if BIOS gave no shadow GTT space
This patch (commit 690a1f2002a3091bd18a501f46c9530f10481463) added a
new call site for acpi_set_WOL() without checking that the function is
actually suitable to be called via
vortex_set_wol+0xcd/0xe0 [3c59x]
dev_ethtool+0xa5a/0xb70
dev_ioctl+0x2e0/0x4b0
T.961+0x49/0x50
sock_ioctl+0x47/0x290
do_vfs_ioctl+0x7f/0x340
sys_ioctl+0x80/0xa0
system_call_fastpath+0x16/0x1b
i.e. outside of code paths run when the device is not yet enabled or
already disabled. In particular, putting the device into D3hot is a
pretty bad idea when it was already brought up.
Furthermore, all prior callers of the function made sure they're
actually dealing with a PCI device, while the newly added one didn't.
In the same spirit, the .get_wol handler shouldn't indicate support
for WOL for non-PCI devices.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
The HW by default has RX coalescing on. For iWARP connections, this
causes a 100ms delay in connection establishement due to the ingress
MPA Start message being stalled in HW. So explicitly turn RX
coalescing off when setting up iWARP connections.
This was causing very bad performance for NP64 gather operations using
Open MPI, due to the way it sets up connections on larger jobs.
Signed-off-by: Steve Wise <swise@opengridcomputing.com>
Cc: <stable@kernel.org>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
f4347553b30ec66530bfe63c84530afea3803396 removed the edac polling
mechanism in favor of using a notifier chain for conveying MCE
information to edac. However, the module removal path didn't test
whether the driver had setup the polling function workqueue at all and
the rmmod process was hanging in the kernel at try_to_del_timer_sync()
in the cancel_delayed_work() path, trying to cancel an uninitialized
work struct.
Fix that by adding a balancing check to the workqueue removal path.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Freeing netdev without free_netdev() leads to net, tx leaks.
I might lead to dereferencing freed pointer.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
struct net_device* dev;
-kfree(dev)
+free_netdev(dev)
-kfree(dev)
+free_netdev(dev)
-kfree(dev)
+free_netdev(dev)
-kfree(dev)
+free_netdev(dev)
This enables auto loading for the smsc911x ethernet driver.
Signed-off-by: Vincent Stehlé <vincent.stehle@laposte.net>
Compex FreedomLine 32 PnP-PCI2 cards have only TP and BNC connectors but the
SROM contains AUI port too. When TP loses link, the driver switches to
non-existing AUI port (which reports that carrier is always present).
Connecting TP back generates LinkPass interrupt but de_media_interrupt() is
broken - it only updates the link state of currently connected media, ignoring
the fact that LinkPass and LinkFail bits of MacStatus register belong to the
TP port only (the chip documentation says that).
This patch changes de_media_interrupt() to switch media to TP when link goes
up (and media type is not locked) and also to update the link state only when
the TP port is used.
Also the NonselPortActive (and also SelPortActive) bits of SIAStatus register
need to be cleared (by writing 1) after reading or they're useless.
At least my 21041 cards come out of suspend with bus mastering disabled so
they did not work after resume(no data transferred).
After adding pci_set_master(), the driver oopsed immediately on resume -
because de_clean_rings() is called on suspend but de_init_rings() call
was missing in resume.
Also disable link (reset SIA) before sleep (de4x5 does this too).
If not all clocks have been defined in platform data, the driver will
cause a null pointer dereference when it is removed. This patch fixes
this issue.
Signed-off-by: Chris Ball <cjb@laptop.org>
In the commit f522886e202a34a2191dd5d471b3c4d46410a9a0 a merge conflict
in the sdhci-s3c driver been fixed. However the fix used incorrect
spinlock operation - it caused a race with sdhci interrupt service. The
correct way to solve it is to use spin_lock_irqsave/irqrestore() calls.
In error return path
call pci_disable_device() which was enabled earlier.
Signed-off-by: Rahul Ruikar <rahul.ruikar@gmail.com>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
At least on older 21041-AA chips (mine is rev. 11), TP duplex autonegotiation
causes the card not to work at all (link is up but no packets are transmitted).
de4x5 disables autonegotiation completely. But it seems to work on newer
(21041-PA rev. 21) so disable it only on rev<20 chips.
x86/hwmon: pkgtemp has no dependency on PCI
MAINTAINERS: Update hwmon entry
x86/hwmon: register alternate sibling upon CPU removal
x86/hwmon: fix initialization of pkgtemp
x86/hwmon: fix initialization of coretemp
x86/hwmon: don't leak device attribute file from pkgtemp_probe() and pkgtemp_remove()
x86/hwmon: avoid deadlock on CPU removal in pkgtemp
x86/hwmon: fix module init for hotplug-but-no-device-found case
hwmon: (lis3) Fix Oops with NULL platform data
While fb isn't active, we should clear CFG_GRA_ENA bit. The existing code
can't clear this bit.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Acked-by: Marek Vasut <marek.vasut@gmail.com>
Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6:
USB: update Kconfig help text for CONFIG_USB_SUSPEND
usb: musb: gadget: restart request on clearing endpoint halt
usb: musb: host: Issue a memory barrier before starting DMA
usb: musb: gadget: fix dma length in txstate
usb: musb: gadget: complete request only if data is transfered over
usb: musb: gadget: fix DMA length for OUT transfer
usb: musb: gadget: enable autoclear for OUT transfer in both DMA 0 and DMA 1
usb: musb: gadget: fix bulk IN infinit hangs in double buffer case
usb: musb: gadget: fix kernel panic if using out ep with FIFO_TXRX style
USB: fix bug in initialization of interface minor numbers
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6:
Staging: ti-st: remove st_get_plat_device
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
vgaarb: trivial fix
drm: radeon cleanup fixes...
drm: fix trivial coding errors
drm: ttm sparse fixes.
drm/nouveau: fix panels using straps-based mode detection
drm/ttm: Clear the ghost cpu_writers flag on ttm_buffer_object_transfer.
drm/radeon: don't allow device to be opened if powered down
Other than coretemp, from which this code was apparently derived, there
is no PCI specific code in this driver.
Just like pkgtemp registers another core of the same package when one
gets removed, coretemp should register another hyperthread (if
available) in that situation.
As pointed out in the patch fixing the respective code in pkgtemp, the
list protectng mutex must be dropped before calling
coretemp_device_add(), and due to the restructured loop (including an
explicit return) the "safe" variant of the list iterator isn't needed
anymore.
Cc: Rudolf Marek <r.marek@assembler.cz>
Feature availability should also be checked in the hotplug code path.
Using cpuid_eax() to determine feature availability on other than
the current CPU is invalid. And feature availability should also be
pkgtemp_remove()
While apparently inherited from coretemp source, this particular error handling
cleanup and exit path wasn't copied properly (or perhaps got discarded
intermediately and not re-added properly later).
(added device file removal in pkgtemp_remove)
pkgtemp_device_remove(), holding the list protecting mutex, calls
pkgtemp_device_add(), which itself wants to acquire the same mutex.
Holding the mutex over the entire loop body in pkgtemp_device_remove()
isn't really necessary, as long as the loop gets exited after
processing the matched CPU.
Once exiting the loop after removing an eventual match, there's no
need for using the "safe" list iterator anymore.
In commit 0dca94baeab4a1a514841b0a4c8e3a51dfb4d5ae the call to
platform_driver_unregister() was made conditional upon !HOTPLUG_CPU,
but the return value from coretemp_init() was left to indicate an
error. This isn't correct, as the negative return value indicates to
the module loader that initialization failed, which isn't intended
here and results in dangling pointers.
Cc: Chen Gong <gong.chen@linux.intel.com>
The recent addition of threaded irq handler causes a NULL dereference
when used with hp_accel driver, which has NULL pdata.
Acked-by: Samu Onkalo <samu.p.onkalo@nokia.com>
This patch (as1429) updates the Kconfig help text for
CONFIG_USB_SUSPEND. The power/level file is now deprecated; we should
tell people to use power/control instead.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Commit 46034dca515bc4ddca0399ae58106d1f5f0d809f (USB: musb_gadget_ep0: stop
abusing musb_gadget_set_halt()) forgot to restart a queued request after
clearing the endpoint halt feature. This results in a couple of USB resets
while enumerating the file-backed storage gadget due to CSW packet not being
sent for the MODE SENSE(10) command.
Signed-off-by: Felipe Balbi <balbi@ti.com>
This patch fixes the issue which was observed while transfering
a large file ( > 20MB) over USB (OMAP MUSB controller acts as USB host)
to an attached USB thumb drive.
It was found that CDB field of CBW packet was set to 0x0. This was
due to missing a barrier before DMA engine starts transfer.
This buffer is allocated using dma_alloc_coherent which gives
non-cacheble but bufferable memory and hence needed a write
memory barrier to flush the write buffer.
More info on this thread is here:
http://www.spinics.net/lists/linux-omap/msg33987.html
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Signed-off-by: Maulik Mankad <x0082077@ti.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
DMA length should not go beyond the availabe space
of request buffer, so fix it.
Also set max_len of cppi dma channel as max size of
int type, so make musb dma handling happier.
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: Anand Gadiyar <gadiyar@ti.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
