disabled in UART config. The receive interrupt was attempting to schedule a work
queue only defined if EDMA is enabled.
kernel BUG at kernel/workqueue.c:1037!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
registrations in Linux.
interrupt instead of level triggered (low) to fix the following issue seen on
MVF platform.
Level Triggered interrupts are not One Shot in nature, resulting in interrupt
handler being called continusouly until a GPIO state change.
This patch was submitted by Roshni Shah <roshni.shah@timesys.com>
for ticket #52067
between cpu and dcu. This showed up when painting a large bootlogo. holes would appear and then fill in as the boot progressed.
When serial-transmit a file from host to target, an error "BUG: scheduling
while atomic: cat/998/0x00010002" occurs.
BUG: scheduling while atomic: cat/998/0x00010002 Modules linked in:
Pid: 998, comm: cat
CPU: 0 Not tainted (3.0.15 #1)
PC is at n_tty_write+0x260/0x43c
LR is at tty_write_room+0x20/0x2c
pc : <80204700> lr : <80206194> psr: 60000013
sp : 863b9e78 ip : 8038e378 fp : 863b9ec4
r10: 00000fff r9 : 863b6400 r8 : 86165d80
r7 : 863b8000 r6 : 86368b6c r5 : 86368800 r4 : 00000002
r3 : 00000010 r2 : 00000000 r1 : 00000040 r0 : 00000002
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 863f8059 DAC: 00000015 <80031f5c>
(show_regs+0x0/0x54) from <803761f0>
(__schedule_bug+0x4c/0x60)
r4:863b9e30 r3:60000193
<803761a4> (__schedule_bug+0x0/0x60) from <8037941c>
(__schedule+0x35c/0x3c4)
Thanks to Tadayoshi Arai <ara@lineo.co.jp> for reporting this and submitting
this patch
Allows the NAND to properly probe if cmdline partitioning
is not specified. Otherwise, it will fail silently.
From Singh Pradip-B09147. Integrate by Jason Jin
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
Add driver support for ADC Vybrid.
Signed-off-by: Wang Xiaojun <b41435@freescale.com>
Toggle PHYPWD.PWD after set PORTSC.SUSP with 8ms to trigger
the LS_SE0/LS_EOP append flag after resume within UTM block.
Signed-off-by: Jingchang Lu <b35083@freescale.com>
Handle usb suspend/resume, currently the BSP doesn't
support usb plug/unplug wakeup.
The ASRC driver supports stereo audio streams resample,
the ASRCK1 serial clock using audio external clock source
can not support 44.1K sample rate due to divider and
prescaler restriction.
Update power management part for DSPI driver.
Signed-off-by: Alison Wang <b18965@freescale.com>
Fix layers blending and reinitialization issue for DCU driver.
Update power management part for DCU driver.
Port the L2 switch driver from CF platform for Vybridi plaform.
This driver usually should work together with the RSTP demo
applications provided by fsl.
Add second FEC support for Vybrid.
Add watchdog driver support for Vybrid.
Add hardware flow control support,
Add transmit DMA support,
Add FIFO operation support,
Add MSB/LSB on data support,
Add 9-bits MARK/SPACE support.
Add Quad SPI driver support for Vybrid.
Xiaochun Li <b41219@freescale.com>
Add Compaq touch screen interface for nano-x.
Nano-x work with touch screen driver via Compaq touch
screen event format, this patch could add the support
above mouse device.
Add touch screen driver support for Vybird.
Update dspi driver support for Vybrid after debugging on board.
Signed-off-by: Jason Jin <jason.jin@freescale.com>
This patch enable the ADMA2 function for the SDHC module used
on Faraday board. Please note that the ADMA address should be 16
bytes aligned other than 4 byte in the spec.
This patch also increased the SDHC module frequency to 200MHz.
Only disable the high-speed device disconnection detction for
level-1 device, or the connection detecting would fail.
If framebuffer console support is enabled, blanking the screen will
occur after a long time. To avoid it, the option for disabling blanking
is added.
This patch is to update Edma driver after debugging on board.
mainly, fixed the bug that resulting the request source of DMA1 overflow
Signed-off-by: Xiaochun Li <b41219@freescale.com>
The call trace introduced by the card interrupt. This patch try to fix
this by disabling the card interrupt.
This patch is to tests eDMA driver.
a simple memory to memory transfer with a 32 bit
source and destination transfer size that generates
an interrupt when the transfer is complete.
Detection of high-speed USB device disconnection should be enable
on connection and disable on disconnection.
Add dspi driver support for Faraday.
