path: root/drivers
2009-04-21driver synchronization: make scsi_wait_scan more advancedArjan van de Ven
There is currently only one way for userspace to say "wait for my storage device to get ready for the modules I just loaded": to load the scsi_wait_scan module. Expectations of userspace are that once this module is loaded, all the (storage) devices for which the drivers were loaded before the module load are present. Now, there are some issues with the implementation, and the async stuff got caught in the middle of this: The existing code only waits for the scsy async probing to finish, but it did not take into account at all that probing might not have begun yet. (Russell ran into this problem on his computer and the fix works for him) This patch fixes this more thoroughly than the previous "fix", which had some bad side effects (namely, for kernel code that wanted to wait for the scsi scan it would also do an async sync, which would deadlock if you did it from async context already.. there's a report about that on lkml): The patch makes the module first wait for all device driver probes, and then it will wait for the scsi parallel scan to finish. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: go7007: Convert to the new i2c device binding model
2009-04-21bfin_5xx: misplaced parenthesesRoel Kluin
`!' has a higher precedence than `&', parentheses are misplaced. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Sonic Zhang <sonic.zhang@analog.com> Cc: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21edac: ppc mpc85xx fix mc err detectDave Jiang
Error found by Jeff Haran. The error detect register is 0s when no errors are detected. The check code is incorrect, so reverse check sense. Reported-by: Jeff Haran <jharan@Brocade.COM> Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Doug Thompson <dougthompson@xmission.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21scsi: mpt: suppress debugobjects warningEric Paris
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=13133 ODEBUG: object is on stack, but not annotated ------------[ cut here ]------------ WARNING: at lib/debugobjects.c:253 __debug_object_init+0x1f3/0x276() Hardware name: VMware Virtual Platform Modules linked in: mptspi(+) mptscsih mptbase scsi_transport_spi ext3 jbd mbcache Pid: 540, comm: insmod Not tainted 2.6.28-mm1 #2 Call Trace: [<c042c51c>] warn_slowpath+0x74/0x8a [<c0469600>] ? start_critical_timing+0x96/0xb7 [<c060c8ea>] ? _spin_unlock_irqrestore+0x2f/0x3c [<c0446fad>] ? trace_hardirqs_off_caller+0x18/0xaf [<c044704f>] ? trace_hardirqs_off+0xb/0xd [<c060c8ea>] ? _spin_unlock_irqrestore+0x2f/0x3c [<c042cb84>] ? release_console_sem+0x1a5/0x1ad [<c05013e6>] __debug_object_init+0x1f3/0x276 [<c0501494>] debug_object_init+0x13/0x17 [<c0433c56>] init_timer+0x10/0x1a [<e08e5b54>] mpt_config+0x1c1/0x2b7 [mptbase] [<e08e3b82>] ? kmalloc+0x8/0xa [mptbase] [<e08e3b82>] ? kmalloc+0x8/0xa [mptbase] [<e08e6fa2>] mpt_do_ioc_recovery+0x950/0x1212 [mptbase] [<c04496c2>] ? __lock_acquire+0xa69/0xacc [<c060c8f1>] ? _spin_unlock_irqrestore+0x36/0x3c [<c060c3af>] ? _spin_unlock_irq+0x22/0x26 [<c04f2d8b>] ? string+0x2b/0x76 [<c04f310e>] ? vsnprintf+0x338/0x7b3 [<c04496c2>] ? __lock_acquire+0xa69/0xacc [<c060c8ea>] ? _spin_unlock_irqrestore+0x2f/0x3c [<c04496c2>] ? __lock_acquire+0xa69/0xacc [<c044897d>] ? debug_check_no_locks_freed+0xeb/0x105 [<c060c8f1>] ? _spin_unlock_irqrestore+0x36/0x3c [<c04488bc>] ? debug_check_no_locks_freed+0x2a/0x105 [<c0446b8c>] ? lock_release_holdtime+0x43/0x48 [<c043f742>] ? up_read+0x16/0x29 [<c05076f8>] ? pci_get_slot+0x66/0x72 [<e08e89ca>] mpt_attach+0x881/0x9b1 [mptbase] [<e091c8e5>] mptspi_probe+0x11/0x354 [mptspi] Noticing that every caller of mpt_config has its CONFIGPARMS struct declared on the stack and thus the &pCfg->timer is always on the stack I changed init_timer() to init_timer_on_stack() and it seems to have shut up..... Cc: "Moore, Eric Dean" <Eric.Moore@lsil.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Thomas Gleixner <tglx@linutronix.de> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Cc: <stable@kernel.org> [2.6.29.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21sgi-xp/sgi-gru: allow modules to load on non-uv systemsRobin Holt
For an upcoming distro release, we need to have the xp kernel module loadable even when not on UV equipment. The xpc module will not load. This will allow one set of modules dependent upon xp to work on either UV or non-UV equipment. Signed-off-by: Robin Holt <holt@sgi.com> Signed-off-by: Jack Steiner <steiner@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21rtc-cmos: fix printk outputKrzysztof Halasa
With no IRQ available/defined, RTC-CMOS driver prints something like: rtc0: alarms up to one no, y3k, 114 bytes nvram ^^^^ I guess the following is a bit easier to understand: rtc0: no alarms, y3k, 114 bytes nvram Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21spi: pxa2xx: limit reaches -1Roel Kluin
On line 944 the return value of flush() is considered as a boolean, but limit reaches -1 upon timeout which evaluates to true. On 540, 594, 720 the same occurs for wait_ssp_rx_stall() On 536 the same occurs for wait_dma_channel_stop() Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Eric Miao <eric.miao@marvell.com> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21pxa2xx_spi: restore DRCMR on resumeDaniel Ribeiro
If DMA is enabled, any spi_sync call after suspend/resume would block forever, because DRCMR is lost on suspend. This patch restores DRCMR to the same values set by probe. Signed-off-by: Daniel Ribeiro <drwyrm@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21drivers/input/serio/hp_sdc.c: fix crash when removing hp_sdc moduleHelge Deller
On parisc machines, which don't have HIL, removing the hp_sdc module panics the kernel. Fix this by returning early in hp_sdc_exit() if no HP SDC controller was found. Add functionality to probe for the hp_sdc_mlc kernel module (which takes care of the upper layer HIL functionality on parisc) after two seconds. This is needed to get all the other HIL drivers (keyboard / mouse/ ..) drivers automatically loaded by udev later as well. Signed-off-by: Helge Deller <deller@gmx.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Frans Pop <elendil@planet.nl> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21ipmi: add oem message handlingdann frazier
Enable userspace to receive messages that a BMC transmits using an OEM medium. This is used by the HP iLO2. Based on code originally written by Patrick Schoeller. Signed-off-by: dann frazier <dannf@hp.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21ipmi: fix statistics counting issuesCorey Minyard
Bela Lubkin noticed that the statistics for send IPMB and LAN commands in the IPMI driver could be incremented even if an error occurred. Move the increments to the proper place to avoid this. Also add some statistics for retransmissions that failed, and some little helper functions to neaten up the code a little. Signed-off-by: Corey Minyard <cminyard@mvista.com> Cc: Bela Lubkin <blubkin@vmware.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21ipmi: test for event buffer before usingCorey Minyard
The IPMI driver would attempt to use the event buffer even if that didn't exist on the BMC. This patch modified the IPMI driver to check for the event buffer's existence before trying to use it. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21ipmi: fix platform return checkCorey Minyard
The wrong return value is being tested when allocating a platform device in the IPMI SI code. Check the right value. Signed-off-by: Corey Minyard <minyard@acm.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21clocksource: pass clocksource to read() callbackMagnus Damm
Pass clocksource pointer to the read() callback for clocksources. This allows us to share the callback between multiple instances. [hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods] [akpm@linux-foundation.org: cleanup] Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21pxafb: lcsr1 is unused without CONFIG_FB_PXA_OVERLAYDenis V. Lunev
Fixes the warning: drivers/video/pxafb.c: In function 'pxafb_handle_irq': drivers/video/pxafb.c:1442: warning: unused variable 'lcsr1' [akpm@linux-foundation.org: save an ifdef] Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Eric Miao <eric.miao@marvell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21asiliantfb: add missing return statementVlada Peric
Commit 032220ba (asiliantfb: fix cmap memory leaks) changed the function init_asiliant from void to int, resulting in the following compile warning: drivers/video/asiliantfb.c: In function `init_asiliant': drivers/video/asiliantfb.c:536: warning: control reaches end of non-void function Fix the warning by returning 0. Signed-off-by: Vlada Peric <vlada.peric@gmail.com> Cc: Andres Salomon <dilinger@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21go7007: Convert to the new i2c device binding modelJean Delvare
Move the go7007 driver away from the legacy i2c binding model, which is going away really soon now. The I2C addresses of the audio and video chips in s2250-board didn't look quite right, apparently they were left-aligned values when Linux wants right-aligned values, so I fixed them too. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-21Merge branch 'sh/for-2.6.30' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh/for-2.6.30' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Fix mmap2 for handling differing PAGE_SIZEs. sh: sh7723: Don't default enable the RTC clock. sh: sh7722: Don't default enable the RTC clock. rtc: rtc-sh: clock framework support.
2009-04-21Merge branch 'sh/stable-updates' into sh/for-2.6.30Paul Mundt
2009-04-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: PM/Suspend: Introduce two new platform callbacks to avoid breakage
2009-04-20Merge branch 'drm-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: agp: zero pages before sending to userspace drm: check for minor master before allowing drop master. drm: set/clear is_master when master changed drm: clean dirty memory after device release drm: count reaches -1
2009-04-20Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: support bitmaps on RAID10 arrays larger then 2 terabytes md: update sync_completed and reshape_position even more often. md: improve usefulness and accuracy of sysfs file md/sync_completed. md: allow setting newly added device to 'in_sync' via sysfs. md: tiny md.h cleanups
2009-04-20driver: dont update dev_name via device_add pathKay Sievers
notice one system /proc/iomem some entries missed the name for pci_devices it turns that dev->dev.kobj name is changed after device_add. for pci code: via acpi_pci_root_driver.ops.add (aka acpi_pci_root_add) ==> pci_acpi_scan_root is used to scan pci bus/device, and at the same time we read the resource for pci_dev in the pci_read_bases, we have res->name = pci_name(pci_dev); pci_name is calling dev_name. later via acpi_pci_root_driver.ops.start (aka acpi_pci_root_start) ==> pci_bus_add_device to add all pci_dev in kobj tree. pci_bus_add_device will call device_add. actually in device_add /* first, register with generic layer. */ error = kobject_add(&dev->kobj, dev->kobj.parent, "%s", dev_name(dev)); if (error) goto Error; will get one new name for that kobj, old name is freed. [Impact: fix corrupted names in /proc/iomem ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-20md: support bitmaps on RAID10 arrays larger then 2 terabytesNeilBrown
.. and other arrays with components larger than 2 terabytes. We use a "long" rather than a "sector_t" in part of the bitmap size calculations, which is sad. Reported-by: "Mario 'BitKoenig' Holbe" <Mario.Holbe@TU-Ilmenau.DE> Signed-off-by: NeilBrown <neilb@suse.de>
2009-04-20agp: zero pages before sending to userspaceShaohua Li
AGP pages might be mapped into userspace finally, so the pages should be set to zero before userspace can use it. Otherwise there is potential information leakage. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-04-20drm: check for minor master before allowing drop master.Dave Airlie
When fast user switching a lot eventually we get to the point, where we were checking for the wrong thing in this function. Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-04-20drm: set/clear is_master when master changedJonas Bonn
The variable is_master is being used to track the drm_file that is currently master, so its value needs to be updated accordingly when the master is changed. Signed-off-by: Jonas Bonn <jonas@southpole.se> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-04-20drm: clean dirty memory after device releaseMa Ling
In current code we register/unregister connector object by drm_sysfs_connector_add/remove function. However under some cases, we need to dynamically register or unregister device multiple times, so we have to go through register -> unregister ->register routine. Because after device_unregister function our memory is dirty, we need to do clean operation in order to re-register the device, otherwise the system will crash. The patch intends to clean device after device release. Signed-off-by: Ma Ling <ling.ma@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-04-20drm: count reaches -1Roel Kluin
With a postfix decrement in the test count will reach -1 rather than 0, subsequent tests fail. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2009-04-19PM/Suspend: Introduce two new platform callbacks to avoid breakageRafael J. Wysocki
Commit 900af0d973856d6feb6fc088c2d0d3fde57707d3 (PM: Change suspend code ordering) changed the ordering of suspend code in such a way that the platform .prepare() callback is now executed after the device drivers' late suspend callbacks have run. Unfortunately, this turns out to break ARM platforms that need to talk via I2C to power control devices during the .prepare() callback. For this reason introduce two new platform suspend callbacks, .prepare_late() and .wake(), that will be called just prior to disabling non-boot CPUs and right after bringing them back on line, respectively, and use them instead of .prepare() and .finish() for ACPI suspend. Make the PM core execute the .prepare() and .finish() platform suspend callbacks where they were executed previously (that is, right after calling the regular suspend methods provided by device drivers and right before executing their regular resume methods, respectively). It is not necessary to make analogous changes to the hibernation code and data structures at the moment, because they are only used by ACPI platforms. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Len Brown <len.brown@intel.com>
2009-04-19Merge ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-lguest-and-virtio * git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-lguest-and-virtio: lguest: document 32-bit and PAE requirements lguest: tell git to ignore Documentation/lguest/lguest virtio: fix suspend when using virtio_balloon lguest: fix guest crash on non-linear addresses in gdt pvops lguest: fix crash on vmlinux images
2009-04-19Revert "console ASCII glyph 1:1 mapping"Samuel Thibault
This reverts commit 1c55f18717304100a5f624c923f7cb6511b4116d. Ingo Brueckl was assuming that reverting to 1:1 mapping for chars >= 128 was not useful, but it happens to be: due to the limitations of the Linux console, when a blind user wants to read BIG5 on it, he has no other way than loading a font without SFM and let the 1:1 mapping permit the screen reader to get the BIG5 encoding. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-19virtio: fix suspend when using virtio_balloonMarcelo Tosatti
Break out of wait_event_interruptible() if freezing has been requested, in the vballoon thread. Without this change vballoon refuses to stop and the system can't suspend. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: stable@kernel.org
2009-04-19lguest: fix guest crash on non-linear addresses in gdt pvopsRusty Russell
Fixes guest crash 'lguest: bad read address 0x4800000 len 256' The new per-cpu allocator ends up handing a non-linear address to write_gdt_entry. We do __pa() on it, and hand it to the host, which kills us. I've long wanted to make the hypercall "LOAD_GDT_ENTRY" to match the IDT code, but had no pressing reason until now. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: lguest@ozlabs.org
2009-04-19lguest: fix crash on vmlinux imagesMatias Zabaljauregui
Typical message: 'lguest: unhandled trap 6 at 0x418726 (0x0)' vmlinux guests were broken by 4cd8b5e2a159f18a1507f1187b44a1acbfa6341b 'lguest: use KVM hypercalls', which rewrites guest text from kvm hypercalls to trap 31. The Launcher mmaps the kernel image. The Guest executes and immediately faults in the first text page (read-only). Then it hits a hypercall, and we rewrite that hypercall, causing a copy-on-write. But the Guest pagetables still refer to the old page: we fault again, but as Host we see the hypercall already rewritten, and pass the fault back to the Guest. The Guest hasn't set up an IDT yet, so we kill it. This doesn't happen with bzImages: they unpack themselves and so the text pages are already read-write. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Patrick McHardy <kaber@trash.net>
2009-04-18cs5536: define dma_sff_read_status() methodSergei Shtylyov
The driver somehow got merged with the initializer for the dma_sff_read_status() method missing which caused kernel panic on bootup. This should fix the kernel.org bug #13026... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Reported-by: Arnd Hannemann <hannemann@nets.rwth-aachen.de> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-18ide: fix barriers supportBartlomiej Zolnierkiewicz
Freeing non-slab objects is bad and results in an oops. Fix it. Reported-and-tested-by: Andrew Price <andy@andrewprice.me.uk> Cc: Theodore Tso <tytso@mit.edu> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-18ide: Remove void castsJack Stone
Remove uneeded void casts Signed-off-by: Jack Stone <jwjstone@fastmail.fm> Cc: jeff@garzik.org Cc: kernel-janitors@vger.kernel.org Cc: Jack Stone <jwjstone@fastmail.fm> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-18hpt366: use ATA_DMA_* constantsSergei Shtylyov
Use ATA_DMA_* constants instead of the bare numbers for the BMIDE register bits. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-18hpt366: fix HPT370 DMA timeoutsSergei Shtylyov
The big driver change in 2.4.19-rc1 introduced a regression for many HPT370[A] chips -- DMA stopped to work completely, only causing endless timeouts... The culprit has been identified (at last!): it turned to be the code resetting the DMA state machine before each transfer. Stop doing it now as this counter- measure has clearly caused more harm than good. This should fix the kernel.org bug #7703. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2009-04-17Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/libata-dev: [libata] fix build error on drivers/ata/pata_legacy.c pata_via: Cache and rewrite the device bit sata_mv: workaround for multi_count errata sata24 sata_mv: tidy up qc->tf usage in qc_prep() functions
2009-04-17[libata] fix build error on drivers/ata/pata_legacy.cZhenwen Xu
fix those errors: drivers/ata/pata_legacy.c: In function ‘pdc_data_xfer_vlb’: drivers/ata/pata_legacy.c:289: error: ‘ap’ undeclared (first use in this function) drivers/ata/pata_legacy.c:289: error: (Each undeclared identifier is reported only once drivers/ata/pata_legacy.c:289: error: for each function it appears in.) drivers/ata/pata_legacy.c: At top level: drivers/ata/pata_legacy.c:869: error: ‘ATA_PFLAG_PIO32_CHANGE’ undeclared here (not in a +function) make[2]: *** [drivers/ata/pata_legacy.o] Error 1 make[1]: *** [drivers/ata] Error 2 Signed-off-by: Zhenwen Xu <helight.xu@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-17pata_via: Cache and rewrite the device bitAlan Cox
Some VIA chipsets will reset the DEV bit after IEN changes on ctl. Our optimised write path avoids doing this but we need to remove the optimisation on these devices. [Identified and some original patches proposed by Josehn Chan @ VIA but discussion then all ground to a halt so given a test case I dug it back out] Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk Tested-by: Christoph Bisping (bug #13086) Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-17sata_mv: workaround for multi_count errata sata24Mark Lord
Workaround for errata SATA#24 in sata_mv. This errata affects WRITE_MULTI* commands when the device multi_count produces a DRQ block size >= 4Kbytes. We work around it here by converting such operations into ordinary PIO_WRITEs instead. Note that this might result in a PIO FUA write unavoidably being converted into a non-FUA write. In practice, any system using FUA is also going to be using DMA rather than PIO, so this shouldn't affect anyone in the real world. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-17sata_mv: tidy up qc->tf usage in qc_prep() functionsMark Lord
Tidy up qc->tf accesses in the mv_qc_prep() functions. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2009-04-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (43 commits) staging: slicoss: update README otus/zdusb.c: additional USB idnetifier Staging: go7007: fix build issues Staging: sxg: Fix leaks and checksum errors in transmit code path Staging: sxg: Fix sleep in atomic context warning while loading driver Staging: sxg: Use correct queue_id for transmitting non-TCP packets Staging: sxg: Fire watchdog timer at end of open routine to change the link Staging: Pohmelfs: Add load balancing between network states with the same priority. Staging: Pohmelfs: Added IO permissions and priorities. Staging: Pohmelfs: Added ->show_stats() callback. Staging: Pohmelfs: Drop ftrans debugging code. Staging: Pohmelfs: Use wait_on_page_timeout when waiting for remote directory sync instead of hardcoded 25 seconds. Staging: Pohmelfs: Reduce debugging noise about non-existing objects. Staging: Pohmelfs: Sync fs before killing it, since dentry cache is shrunk before writeback is invoked via generic_shutdown_super() Staging: Pohmelfs: Extend remount option. Staging: Pohmelfs: Set NETFS_INODE_REMOTE_SYNCED and clear NETFS_INODE_OWNED bits in the root inode. Staging: Pohmelfs: Added 'need_lock' variable into debug print. Staging: Pohmelfs: Disable read lock in pohmelfs_getattr(). Staging: Pohmelfs: Move parent lock to the place where we really have to send a lookup request to the server. Staging: pohmelfs: Populate dentry cache when receiving the new readdir entry. ...
2009-04-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: UIO: fix specific device driver missing statement for depmod Driver core: remove pr_fmt() from dynamic_dev_dbg() printk driver core: prevent device_for_each_child from oopsing dynamic debug: resurrect old pr_debug() semantics as pr_devel() Driver Core: early platform driver proc: mounts_poll() make consistent to mdstat_poll sysfs: sysfs poll keep the poll rule of regular file. driver core: allow non-root users to listen to uevents driver core: fix driver_match_device sysfs: don't use global workqueue in sysfs_schedule_callback()
2009-04-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (22 commits) WUSB: correct format of wusb_chid sysfs file WUSB: fix oops when completing URBs for disconnected devices WUSB: disconnect all devices when stopping a WUSB HCD USB: whci-hcd: check return value of usb_hcd_link_urb_to_ep() USB: whci-hcd: provide a endpoint_reset method USB: add reset endpoint operations USB device codes for Motorola phone. usb-storage: fix mistake in Makefile USB: usb-serial ch341: support for DTR/RTS/CTS Revert USB: usb-serial ch341: support for DTR/RTS/CTS USB: musb: fix possible panic while resuming USB: musb: fix isochronous TXDMA (take 2) USB: musb: sanitize clearing TXCSR DMA bits (take 2) USB: musb: bugfixes for multi-packet TXDMA support USB: musb_host, fix ep0 fifo flushing USB: usb-storage: augment unusual_devs entry for Simple Tech/Datafab USB: musb_host, minor enqueue locking fix (v2) USB: fix oops in cdc-wdm in case of malformed descriptors USB: qcserial: Add extra device IDs USB: option: Add ids for D-Link DWM-652 3.5G modem ...
2009-04-17Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: (48 commits) [ARM] S3C24XX: ADC: Check pending queue before freeing adc client [ARM] S3C: Fix ADC driver sparse warning [ARM] Osiris: Fix double initialisation in machine block [ARM] Anubis: Fix sparse warnings for items that should be static [ARM] JIVE: Fix sparse warnings about items which should be static [ARM] S3C: Fix sparse warning from missing 's3c_device_hwmon' [ARM] S3C24XX: Fix sparse error in gpiolib.c [ARM] 5455/1: Fix IRQ noise from VIC code [ARM] 5454/1: ep93xx_eth: fix sparse warnings [ARM] remove .gitignore from include/asm-arm Update MAINTAINERS mxc defconfig updates mx31ads: Mark as having full regulatoion constraints with 1133-EV1 board mx31ads: Depend on all the WM8350 core dependencies for WM1133-EV1 board Fix ifdef in plat-mxc/irc.c MX1ADS: remove I2C ifdefs qong: remove AIPS[12] mappings from machine-specific iotable mx31ads: imoux pins should be passed in as unsigned int MXC: remove orphan imx_init_uart() definition mx31: pin definition for csi ...
