path: root/drivers
2010-12-15xen: Provide a variant of __RING_SIZE() that is an integer constant expressionJeremy Fitzhardinge
Without this, gcc 4.5 won't compile xen-netfront and xen-blkfront, where this is being used to specify array sizes. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: David Miller <davem@davemloft.net> Cc: Stable Kernel <stable@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-14Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: protect against NULL reference when waiting to start a raid10. md: fix bug with re-adding of partially recovered device. md: fix possible deadlock in handling flush requests. md: move code in to submit_flushes. md: remove handling of flush_pending in md_submit_flush_data
2010-12-14dw_spi: Fix missing final read in some polling situationsMajor Lee
There is a possibility that the last word of a transaction will be lost if data is not ready. Re-read in poll_transfer() to solve this issue when poll_mode is enabled. Verified on SPI touch screen device. Signed-off-by: Major Lee <major_lee@wistron.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-14i2c_intel_mid: Fix slash in sysfs nameAlan Cox
This gets caught by the new sanity check code. Instead of the slash use a different symbol. This was originally found by Major Lee who proposed a rather more complex patch which changed the name according to the chip type. On the basis that we are in a late -rc and making Linus grumpy isn't always a good idea (however fun) this is a simple alternative. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-14Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: OMAP2: PRCM: fix some SHIFT macros that were actually bitmasks OMAP2+: PM/serial: fix console semaphore acquire during suspend OMAP1: SRAM: fix size for OMAP1611 SoCs arm: omap2: io: fix clk_get() error check arm: plat-omap: counter_32k: use IS_ERR() instead of NULL check omap: nand: remove hardware ECC as default omap: zoom: wl1271 slot is MMC_CAP_POWER_OFF_CARD omap: PM debug: fix wake-on-timer debugfs dependency
2010-12-14Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ARM: 6535/1: V6 MPCore v6_dma_inv_range and v6_dma_flush_range RWFO fix ARM: 6534/1: Make CONFIG_FPE_NWFPE depend on !CONFIG_THUMB2_KERNEL ARM: 6533/1: Thumb-2: Make CONFIG_THUMB2_KERNEL depend on !CPU_V6 Change bcmring Maintainer list. ARM: Update mach-types ARM: 6528/1: Use CTR for the I-cache line size on ARMv7 ARM: 6527/1: Use CTR instead of CCSIDR for the D-cache line size on ARMv7 ARM: pxa/palm: fix ifdef around gen_nand driver registration ARM: pxa: fix pxa2xx-flash section mismatch ARM: mmp2: remove not used clk_rtc
2010-12-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (75 commits) pppoe.c: Fix kernel panic caused by __pppoe_xmit WAN: Fix a TX IRQ causing BUG() in PC300 and PCI200SYN drivers. bnx2x: Advance a version number to 1.60.01-0 bnx2x: Fixed a compilation warning bnx2x: LSO code was broken on BE platforms qlge: Fix deadlock when cancelling worker. net: fix skb_defer_rx_timestamp() cxgb4vf: Ingress Queue Entry Size needs to be 64 bytes phy: add the IC+ IP1001 driver atm: correct sysfs 'device' link creation and parent relationships MAINTAINERS: remove me from tulip SCTP: Fix SCTP_SET_PEER_PRIMARY_ADDR to accpet v4mapped address enic: Bug Fix: Pass napi reference to the isr that services receive queue ipv6: fix nl group when advertising a new link connector: add module alias net: Document the kernel_recvmsg() function r8169: Fix runtime power management hso: IP checksuming doesn't work on GE0301 option cards xfrm: Fix xfrm_state_migrate leak net: Convert netpoll blocking api in bonding driver to be a counter ...
2010-12-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] hpsa: fix redefinition of PCI_DEVICE_ID_CISSF [SCSI] qla2xxx: Update version number to 8.03.05-k0. [SCSI] qla2xxx: Properly set the return value in qla2xxx_eh_abort function. [SCSI] qla2xxx: Correct issue where NPIV-config data was not being allocated for 82xx parts. [SCSI] qla2xxx: Change MSI initialization from using incorrect request_irq parameter. [SCSI] qla2xxx: Populate Command Type 6 LUN field properly. [SCSI] zfcp: Issue FCP command without holding SCSI host_lock [SCSI] zfcp: Prevent usage w/o holding a reference [SCSI] zfcp: No ERP escalation on gpn_ft eval [SCSI] zfcp: Correct false abort data assignment. [SCSI] zfcp: Fix common FCP request reception [SCSI] Eliminate error handler overload of the SCSI serial number [SCSI] pmcraid: disable msix and expand device config entry [SCSI] bsg: correct fault if queue object removed while dev_t open [SCSI] osd: checking NULL instead of ERR_PTR()
2010-12-14Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kgdboc,input: Fix regression with keyboard release key and early debugging
2010-12-14Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI / PM: Do not save/restore NVS on Sony Vaio VGN-NW130D ACPI/HEST: adjust section selection ACPI: eliminate unused variable warning for !ACPI_SLEEP ACPI/PNP: avoid section mismatch warning ACPI thermal: remove two unused functions ACPI: fix a section mismatch ACPI, APEI, use raw spinlock in ERST ACPI: video: fix build for CONFIG_ACPI=n ACPI: video: fix build for VIDEO_OUTPUT_CONTROL=n ACPI: fix allowing to add/remove multiple _OSI strings acpi: fix _OSI string setup regression ACPI: EC: Add another dmi match entry for MSI hardware ACPI battery: update status upon sysfs query ACPI ac: update AC status upon sysfs query ACPI / PM: Do not refcount power resources that can't be turned on ACPI / PM: Check device state before refcounting power resources
2010-12-14Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: intel_idle: recognize ARAT on WSM-EX
2010-12-14Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6 * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: fbdev: Fix fb_find_nearest_mode refresh comparison
2010-12-14Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/staging: hwmon: (ltc4215) make sysfs file match the alarm cause
2010-12-14Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: dmaengine: at_hdmac: fix buffer transfer size specification fsldma: fix issue of slow dma dmaengine i.MX SDMA: initialize on module_init dma : EG20T PCH: Fix miss-setting DMA descriptor intel_mid_dma: fix section mismatch warnings dmaengine: imx-sdma: fix bug in buffer descriptor initialization drivers/dma/ppc4xx: Use printf extension %pR for struct resource drivers/dma/ioat: Use the ccflag-y instead of EXTRA_CFLAGS drivers/dma/: Use the ccflag-y instead of EXTRA_CFLAGS dma: intel_mid_dma: fix double free on mid_setup_dma error path dma: imx-dma: fix imxdma_probe error path
2010-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/uverbs: Handle large number of entries in poll CQ
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: ohci: fix regression with Agere FW643 rev 06, disable MSI firewire: ohci: fix regression with VIA VT6315, disable MSI
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: regulator: tps6586x: correct register table regulator: tps6586x: Handle both enable reg/bits being the same regulator: tps6586x: Fix TPS6586X_DVM to store goreg/bit regulator: tps6586x: Add missing bit mask generation
2010-12-14Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bpLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: amd64_edac: Fix interleaving check EDAC: Correct MiB_TO_PAGES() macro EDAC: Fix workqueue-related crashes
2010-12-14Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/radeon/kms: don't apply 7xx HDP flush workaround on AGP drm: use after free in drm_queue_vblank_event() drm/kms: remove spaces from connector names (v2)
2010-12-14fbdev: Fix fb_find_nearest_mode refresh comparisonAndrew Kephart
Refresh rate nearness is not calculated or reset when nearest resolution changes. This patch resets the refresh rate differential measurement whenever a new nearest resolution is discovered. This fixes two error cases; first, wherein the first mode's refresh rate differential is never calculated and second, when the closest refresh rate from a previous nearest resolution is erroneously preserved. Signed-off-by: Andrew Kephart <andrew.kephart@alereon.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-12-14dmaengine: at_hdmac: fix buffer transfer size specificationNicolas Ferre
Buffer transfer size is the number of transfers to be performed in relation with the width of the _source_ interface. So in the DMA_FROM_DEVICE case, it should be the register width that should be taken into account. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-12-13kgdboc,input: Fix regression with keyboard release key and early debuggingJason Wessel
The commit 111c182340cd22e238ab1cc6564df336c6ebd7cb (kgdboc: reset input devices (keyboards) when exiting debugger) introduced a regression in early debugging such that you get a kernel oops on continue (with the go command) if you boot a kernel with: earlyprintk=vga ekgdboc=kbd kgdbwait The restore kgdboc_restore_input() routine schedules work for the purpose of sending key release events for any keys that were in the depressed state prior to entering the kernel debugger. A simple fix to the crash is to not invoke the schedule_work() if the kernel system_state is anything other than SYSTEM_RUNNING. Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Reviewed-by: Sergei Shtylyov <sshtylyov@mvista.com>
2010-12-13Merge branch 'bugzilla-23002' into releaseLen Brown
2010-12-13ACPI / PM: Do not save/restore NVS on Sony Vaio VGN-NW130DRafael J. Wysocki
The saving of the NVS memory area during suspend and restoring it during resume causes problems to appear on Sony Vaio VGN-NW130D, so blacklist that machine to avoid those problems. Addresses https://bugzilla.kernel.org/show_bug.cgi?id=23002 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Adriano <adriano.vilela@yahoo.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-13fsldma: fix issue of slow dmaForrest Shi
Fixed fsl dma slow issue by initializing dma mode register with bandwidth control. It boosts dma performance and should works with 85xx board. Signed-off-by: Forrest Shi <b29237@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2010-12-13hwmon: (ltc4215) make sysfs file match the alarm causeIra W. Snyder
The ltc4215 driver used the chip's "power good" status bit to provide the power1_alarm file. This is wrong: the chip is really reporting the status of one of the monitored voltages. Change the sysfs file from power1_alarm to in2_min_alarm instead. This matches the voltage that the chip is raising an alarm for. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-12-12Merge branch 'fix' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/ycmiao/pxa-linux-2.6
2010-12-12pppoe.c: Fix kernel panic caused by __pppoe_xmitAndrej Ota
__pppoe_xmit function return value was invalid resulting in additional call to kfree_skb on already freed skb. This resulted in memory corruption and consequent kernel panic after PPPoE peer terminated the link. This fixes commit 55c95e738da85373965cb03b4f975d0fd559865b. Reported-by: Gorik Van Steenberge <gvs@zemos.net> Reported-by: Daniel Kenzelmann <kernel.bugzilla@kenzelmann.dyndns.info> Reported-by: Denys Fedoryshchenko <nuclearcat@nuclearcat.com> Reported-by: Pawel Staszewski <pstaszewski@artcom.pl> Diagnosed-by: Andrej Ota <andrej@ota.si> Diagnosed-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Denys Fedoryshchenko <nuclearcat@nuclearcat.com> Tested-by: Pawel Staszewski <pstaszewski@artcom.pl> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: Andrej Ota <andrej@ota.si> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12WAN: Fix a TX IRQ causing BUG() in PC300 and PCI200SYN drivers.Krzysztof Halasa
We must not wake the TX queue without free TX descriptors. sca_xmit() expects at least one free descriptor and BUGs otherwise. Problem reported and fix tested by Bernie Innocenti and Ward Vandewege. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12bnx2x: Advance a version number to 1.60.01-0Vladislav Zolotarov
Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12bnx2x: Fixed a compilation warningVladislav Zolotarov
bnx2x_src_init_t2() is used only when BCM_CNIC is defined. So, to avoid a compilation warning, we won't define it unless BCM_CNIC is defined. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12bnx2x: LSO code was broken on BE platformsVladislav Zolotarov
Make the LSO code work on BE platforms: parsing_data field of a parsing BD (PBD) for 57712 was improperly composed which made FW read wrong values for TCP header's length and offset and, as a result, the corresponding PCI device was performing bad DMA reads triggering EEH. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12qlge: Fix deadlock when cancelling worker.Ron Mercer
Removing usage of rtnl_lock() to protect firmware interface registers. These registers are accessed in some worker threads and can create a deadlock if rtnl_lock is taken by upper layers while the worker is still pending. We remove rtnl_lock and use a driver mutex just while mailboxes are accessed. Signed-off-by: Ron Mercer <ron.mercer@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-12Merge branch 'vhost-net' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
2010-12-12firewire: ohci: fix regression with Agere FW643 rev 06, disable MSIStefan Richter
Agere FW643 rev 06, listed as "11c1:5901 (rev 06) (prog-if 10 [OHCI])", produced SBP-2 I/O errors since kernel 2.6.36. Disabling MSI fixes it. Since MSI work on Agere FW643-E (same vendor and device ID, but rev 07), introduce a device revision field into firewire-ohci's quirks list so that different quirks can be defined for older and newer revisions. Reported-by: Jonathan Isom <jeisom@gmail.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: <stable@kernel.org> # 2.6.36.y
2010-12-12firewire: ohci: fix regression with VIA VT6315, disable MSIStefan Richter
"VIA Technologies, Inc. VT6315 Series Firewire Controller [1106:3403]" does not generate any interrupts if Message Signaled Interrupts were enabled. This is a regression since kernel 2.6.36 in which MSI support was added to firewire-ohci. Hence blacklist MSI on all VIA controllers. Reported-by: Robin Cook <rcook@wyrms.net> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: <stable@kernel.org> # 2.6.36.y
2010-12-11Merge branches 'bugzilla-15418', 'bugzilla-21722', 'bugzilla-22932', ↵Len Brown
'misc-2.6.37' and 'osi-regression' into release
2010-12-11ACPI/HEST: adjust section selectionJan Beulich
Properly const-, __init-, and __read_mostly-annotate this code. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-11ACPI: eliminate unused variable warning for !ACPI_SLEEPJan Beulich
2010-12-11ACPI/PNP: avoid section mismatch warningJan Beulich
2010-12-11ACPI thermal: remove two unused functionsZhang Rui
When CONFIG_CPU_FREQ=n ... drivers/acpi/processor_thermal.c:159:12: warning: ‘acpi_thermal_cpufreq_increase’ defined but not used drivers/acpi/processor_thermal.c:163:12: warning: ‘acpi_thermal_cpufreq_decrease’ defined but not used Remove unused declaration of ‘acpi_thermal_cpufreq_increase’ and ‘acpi_thermal_cpufreq_decrease’ Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-11ACPI: fix a section mismatchZhang Rui
WARNING: drivers/acpi/acpi.o(.text+0xeda): Section mismatch in reference from the function acpi_os_initialize1() to the function .init.text:set_osi_linux() The function acpi_os_initialize1() references the function __init set_osi_linux(). Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-11ACPI, APEI, use raw spinlock in ERSTHuang Ying
ERST writing may be used in NMI or Machine Check Exception handler. So it need to use raw spinlock instead of normal spinlock. This patch fixes it. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-11ACPI: fix allowing to add/remove multiple _OSI stringsLin Ming
commit b0ed7a91(ACPICA/ACPI: Add new host interfaces for _OSI suppor) introduced another regression that only one _OSI string can be added or removed. Now multiple _OSI strings can be added or removed, for example acpi_osi=Linux acpi_osi=FreeBSD acpi_osi="!Windows 2006" Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-11acpi: fix _OSI string setup regressionLin Ming
commit b0ed7a91(ACPICA/ACPI: Add new host interfaces for _OSI suppor) introduced a regression that _OSI string setup fails. There are 2 paths to setup _OSI string. DMI: acpi_dmi_osi_linux -> set_osi_linux -> acpi_osi_setup -> copy _OSI string to osi_setup_string Boot command line: acpi_osi_setup -> copy _OSI string to osi_setup_string Later, acpi_osi_setup_late will be called to handle osi_setup_string. If _OSI string is "Linux" or "!Linux", then the call path is, acpi_osi_setup_late -> acpi_cmdline_osi_linux -> set_osi_linux -> acpi_osi_setup -> copy _OSI string to osi_setup_string This actually never installs _OSI string(acpi_install_interface not called), but just copy the _OSI string to osi_setup_string. This patch fixes the regression. Reported-and-tested-by: Lukas Hejtmanek <xhejtman@ics.muni.cz> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-10cxgb4vf: Ingress Queue Entry Size needs to be 64 bytesCasey Leedom
Was using L1_CACHE_BYTES for the Ingress Queue Entry Size but it really needs to be 64 bytes in order to support the largest message sizes. Signed-off-by: Casey Leedom <leedom@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10phy: add the IC+ IP1001 driverGiuseppe CAVALLARO
This patch adds the IC+ IP1001 (Gigabit Ethernet Transceiver) driver. I've had to add an additional delay (2ns) to adjust RX clock phase at GMII/ RGMII interface (according to the PHY data-sheet). This helps to have the RGMII working on some ST platforms. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10atm: correct sysfs 'device' link creation and parent relationshipsDan Williams
The ATM subsystem was incorrectly creating the 'device' link for ATM nodes in sysfs. This led to incorrect device/parent relationships exposed by sysfs and udev. Instead of rolling the 'device' link by hand in the generic ATM code, pass each ATM driver's bus device down to the sysfs code and let sysfs do this stuff correctly. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10enic: Bug Fix: Pass napi reference to the isr that services receive queueVasanthy Kolluri
Pass reference to napi instead of enic device to the isr that services receive queue. Signed-off-by: Vasanthy Kolluri <vkolluri@cisco.com> Signed-off-by: Roopa Prabhu <roprabhu@cisco.com> Signed-off-by: David Wang <dwang2@cisco.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-10Merge branch 'master' of ↵David S. Miller
