commit e791ce27c3f6a1d3c746fd6a8f8e36c9540ec6f9 upstream.
Once the reserved page array is unused we can reset the 'res_in_use'
state; here we can do a lazy update without holding the mutex as we only
need to check against concurrent access, not concurrent release.
[mkp: checkpatch]
Fixes: 1bc0eb044615 ("scsi: sg: protect accesses to 'reserved' page array")
Signed-off-by: Hannes Reinecke <hare@suse.com>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Todd Poynor <toddpoynor@google.com>
commit 1bc0eb0446158cc76562176b80623aa119afee5b upstream.
The 'reserved' page array is used as a short-cut for mapping data,
saving us to allocate pages per request. However, the 'reserved' array
is only capable of holding one request, so this patch introduces a mutex
for protect 'sg_fd' against concurrent accesses.
Tested-by: Johannes Thumshirn <jthumshirn@suse.de>
[toddpoynor@google.com: backport to 3.18-4.9, fixup for bad ioctl
SG_SET_FORCE_LOW_DMA code removed in later versions and not modified by
the original patch.]
Signed-off-by: Todd Poynor <toddpoynor@google.com>
commit 735bb39ca3bed8469b3b3a42d8cc57bdb9fc4dd7 upstream.
With gcc-7, I got a new warning for this driver:
wilc1000/linux_wlan.c: In function 'wilc_netdev_cleanup':
wilc1000/linux_wlan.c:1224:15: error: 'vif[1]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
wilc1000/linux_wlan.c:1224:15: error: 'vif[0]' may be used uninitialized in this function [-Werror=maybe-uninitialized]
A closer look at the function reveals that it's more complex than
it needs to be, given that based on how the device is created
we always get
netdev_priv(vif->ndev) == vif
Based on this assumption, I found a few other places in the same file
that can be simplified. That code appears to be a relic from times
when the assumption above was not valid.
commit 5cfa2a3c7342bd0b50716c8bb32ee491af43c785 upstream.
I'm getting a new warning with gcc-7:
isci/remote_node_context.c: In function 'sci_remote_node_context_destruct':
isci/remote_node_context.c:69:16: error: array subscript is above array bounds [-Werror=array-bounds]
This is odd, since we clearly cover all values for enum
scis_sds_remote_node_context_states here. Anyway, checking for an array
overflow can't harm and it makes the warning go away.
commit 6f17581788206444cbbcdbc107498f85e9765e3d upstream.
gcc 7 complains:
drivers/net/wireless/intersil/p54/fwio.c: In function 'p54_scan':
drivers/net/wireless/intersil/p54/fwio.c:491:4: warning: 'memset' used with length equal to number of elements without multiplication by element size [-Wmemset-elt-size]
Fix that by passing the correct size to memset.
Cc: Christian Lamparter <chunkeey@googlemail.com>
Cc: Kalle Valo <kvalo@codeaurora.org>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 98529b9272e06a7767034fb8a32e43cdecda240a upstream.
Commit 2a5708409e4e (ACPI / EC: Fix a gap that ECDT EC cannot handle
EC events) introduced acpi_ec_ecdt_start(), but that function is
invoked before acpi_ec_query_init(), which is too early. This causes
the kernel to crash if an EC event occurs after boot, when ec_query_wq
is not valid:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000102
Workqueue: events acpi_ec_event_handler
task: ffff9f539790dac0 task.stack: ffffb437c0e10000
RIP: 0010:__queue_work+0x32/0x430
Normally, the DSDT EC should always be valid, so acpi_ec_ecdt_start()
is actually a no-op in the majority of cases. However, commit
c712bb58d827 (ACPI / EC: Add support to skip boot stage DSDT probe)
caused the probing of the DSDT EC as the "boot EC" to be skipped when
the ECDT EC is valid and uncovered the bug.
Fix this issue by invoking acpi_ec_ecdt_start() after acpi_ec_query_init()
in acpi_ec_init().
Link: https://jira01.devtools.intel.com/browse/LCK-4348
Fixes: 2a5708409e4e (ACPI / EC: Fix a gap that ECDT EC cannot handle EC events)
Fixes: c712bb58d827 (ACPI / EC: Add support to skip boot stage DSDT probe)
Reported-by: Wang Wendy <wendy.wang@intel.com>
Tested-by: Feng Chenzhou <chenzhoux.feng@intel.com>
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
[ rjw: Changelog ]
commit 7d64f82cceb21e6d95db312d284f5f195e120154 upstream.
When removing a GHES device notified by SCI, list_del_rcu() is used,
ghes_remove() should call synchronize_rcu() before it goes on to call
kfree(ghes), otherwise concurrent RCU readers may still hold this list
entry after it has been freed.
Signed-off-by: James Morse <james.morse@arm.com>
Reviewed-by: "Huang, Ying" <ying.huang@intel.com>
Fixes: 81e88fdc432a (ACPI, APEI, Generic Hardware Error Source POLL/IRQ/NMI notification type support)
commit e3d5092b6756b9e0b08f94bbeafcc7afe19f0996 upstream.
The on-stack resource-window 'win' in setup_res() is not
properly initialized. This causes the pointers in the
embedded 'struct resource' to contain stale addresses.
These pointers (in my case the ->child pointer) later get
propagated to the global iomem_resources list, causing a #GP
exception when the list is traversed in
iomem_map_sanity_check().
Fixes: c183619b63ec (x86/irq, ACPI: Implement ACPI driver to support IOAPIC hotplug)
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit f3fd2afed8eee91620d05b69ab94c14793c849d7 upstream.
It seems that under certain scenarios the SPAD can have bogus values caused
by an agent (i.e. BIOS or other software) that is not the kernel driver, and
that causes memory window setup failure. This should not cause the link to
be disabled because if we do that, the driver will never recover again. We
have verified in testing that this issue happens and prevents proper link
recovery.
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Acked-by: Allen Hubbe <Allen.Hubbe@dell.com>
Signed-off-by: Jon Mason <jdmason@kudzu.us>
Fixes: 84f766855f61 ("ntb: stop link work when we do not have memory")
commit 88931ec3dc11e7dbceb3b0df455693873b508fbe upstream.
Do not sleep in ntb_async_tx_submit, which could deadlock.
This reverts commit "8c874cc140d667f84ae4642bb5b5e0d6396d2ca4"
Fixes: 8c874cc140d6 ("NTB: Address out of DMA descriptor issue with NTB")
Reported-by: Jia-Ju Bai <baijiaju1990@163.com>
Signed-off-by: Allen Hubbe <Allen.Hubbe@dell.com>
Acked-by: Dave Jiang <dave.jiang@intel.com>
commit 8e8496e0e9564b66165f5219a4e8ed20b0d3fc6b upstream.
A divide by zero error occurs if qp_count is less than mw_count because
num_qps_mw is calculated to be zero. The calculation appears to be
incorrect.
The requirement is for num_qps_mw to be set to qp_count / mw_count
with any remainder divided among the earlier mws.
For example, if mw_count is 5 and qp_count is 12 then mws 0 and 1
will have 3 qps per window and mws 2 through 4 will have 2 qps per window.
Thus, when mw_num < qp_count % mw_count, num_qps_mw is 1 higher
than when mw_num >= qp_count.
Signed-off-by: Logan Gunthorpe <logang@deltatee.com>
Fixes: e26a5843f7f5 ("NTB: Split ntb_hw_intel and ntb_transport drivers")
commit cb827ee6ccc3e480f0d9c0e8e53eef55be5b0414 upstream.
In cases where there are more mw's than spads/2-2, the mw count gets
reduced to match the limitation. ntb_transport also tries to ensure that
there are fewer qps than mws but uses the full mw count instead of
the reduced one. When this happens, the math in
'ntb_transport_setup_qp_mw' will get confused and result in a kernel
paging request bug.
This patch fixes the bug by reducing qp_count to the reduced mw count
instead of the full mw count.
commit f299aec6ebd747298e35934cff7709c6b119ca52 upstream.
Add support for USB Device Rosewill RNX-N150NUB.
VendorID: 0x0bda, ProductID: 0xffef
Signed-off-by: Charles Milette <charles.milette@gmail.com>
commit f1664eaacec31035450132c46ed2915fd2b2049a upstream.
It has been reported for a while that with iio-sensor-proxy service the
rotation only works after one suspend/resume cycle. This required a wait
in the systemd unit file to avoid race. I found a Yoga 900 where I could
reproduce this.
The problem scenerio is:
- During sensor driver init, enable run time PM and also set a
auto-suspend for 3 seconds.
This result in one runtime resume. But there is a check to avoid
a powerup in this sequence, but rpm is active
- User space iio-sensor-proxy tries to power up the sensor. Since rpm is
active it will simply return. But sensors were not actually
powered up in the prior sequence, so actaully the sensors will not work
- After 3 seconds the auto suspend kicks
If we add a wait in systemd service file to fire iio-sensor-proxy after
3 seconds, then now everything will work as the runtime resume will
actually powerup the sensor as this is a user request.
To avoid this:
- Remove the check to match user requested state, this will cause a
brief powerup, but if the iio-sensor-proxy starts immediately it will
still work as the sensors are ON.
- Also move the autosuspend delay to place when user requested turn off
of sensors, like after user finished raw read or buffer disable
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Tested-by: Bastien Nocera <hadess@hadess.net>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
commit fdd0d32eb95f135041236a6885d9006315aa9a1d upstream.
According to the datasheet, the range of the acceleration is [-10 g, + 10 g],
so the scale factor should be 10 instead of 5.
Signed-off-by: Dragos Bogdan <dragos.bogdan@analog.com>
Acked-by: Lars-Peter Clausen <lars@metafoo.de>
commit b2a6d1b999a4c13e5997bb864694e77172d45250 upstream.
Commit c4ea41ba195d ("binder: use group leader instead of open thread")'
was incomplete and didn't update a check in binder_mmap(), causing all
mmap() calls into the binder driver to fail.
Signed-off-by: Martijn Coenen <maco@android.com>
Tested-by: John Stultz <john.stultz@linaro.org>
commit 00b40d613352c623aaae88a44e5ded7c912909d7 upstream.
Use wake_up_interruptible_sync() to hint to the scheduler binder
transactions are synchronous wakeups. Disable preemption while waking
to avoid ping-ponging on the binder lock.
Signed-off-by: Todd Kjos <tkjos@google.com>
Signed-off-by: Omprakash Dhyade <odhyade@codeaurora.org>
commit c4ea41ba195d01c9af66fb28711a16cc97caa9c5 upstream.
The binder allocator assumes that the thread that
called binder_open will never die for the lifetime of
that proc. That thread is normally the group_leader,
however it may not be. Use the group_leader instead
of current.
commit a2b18708ee14baec4ef9c0fba96070bba14d0081 upstream.
This reverts commit a906d6931f3ccaf7de805643190765ddd7378e27.
The patch introduced a race in the binder driver. An attempt to fix the
race was submitted in "[PATCH v2] android: binder: fix dangling pointer
comparison", however the conclusion in the discussion for that patch
was that the original patch should be reverted.
The reversion is being done as part of the fine-grained locking
patchset since the patch would need to be refactored when
proc->vmm_vm_mm is removed from struct binder_proc and added
in the binder allocator.
commit 436c4c45b5b9562b59cedbb51b7343ab4a6dd8cc upstream.
This reverts commit 5ab92a7cb82c66bf30685583a38a18538e3807db.
System cannot enter suspend mode because of heartbeat led trigger.
In autosleep_wq, try_to_suspend function will try to enter suspend
mode in specific period. it will get wakeup_count then call pm_notifier
chain callback function and freeze processes.
Heartbeat_pm_notifier is called and it call led_trigger_unregister to
change the trigger of led device to none. It will send uevent message
and the wakeup source count changed. As wakeup_count changed, suspend
will abort.
Fixes: 5ab92a7cb82c ("leds: handle suspend/resume in heartbeat trigger")
Signed-off-by: Zhang Bo <bo.zhang@nxp.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Jacek Anaszewski <jacek.anaszewski@gmail.com>
commit fd1adef3bff0663c5ac31b45bc4a05fafd43d19b upstream.
The VSL and HSL bits in the DSMR register set the corresponding
horizontal and vertical sync signal polarity to active high. The code
got it the wrong way around, fix it.
Signed-off-by: Koji Matsuoka <koji.matsuoka.xm@renesas.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Thong Ho <thong.ho.px@rvc.renesas.com>
Signed-off-by: Nhan Nguyen <nhan.nguyen.yb@renesas.com>
commit 9cdced8a39c04cf798ddb2a27cb5952f7d39f633 upstream.
There is a bug in the setting of the DES (Display Enable Signal)
register. This current setting occurs 1 dot left shift. The DES
register should be set minus one value about the specifying value
with H/W specification. This patch corrects it.
commit 05ee29e94acf0d4b3998c3f93374952de8f90176 upstream.
When an encoder fails to initialize the driver prints an error message
to the kernel log. The message contains the name of the encoder's DT
node, which is NULL for internal encoders. Use the of_node_full_name()
macro to avoid dereferencing a NULL pointer, print the output number to
add more context to the error, and make sure we still own a reference to
the encoder's DT node by delaying the of_node_put() call.
Reviewed-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit a0ffc51e20e90e0c1c2491de2b4b03f48b6caaba upstream.
The last part of drm_atomic_check_only is testing whether we need to
fail with -EINVAL when modeset is not allowed, but forgets to return
the value when atomic_check() fails first.
This results in -EDEADLK being replaced by -EINVAL, and the sanity
check in drm_modeset_drop_locks kicks in:
[ 308.531734] ------------[ cut here ]------------
[ 308.531791] WARNING: CPU: 0 PID: 1886 at drivers/gpu/drm/drm_modeset_lock.c:217 drm_modeset_drop_locks+0x33/0xc0 [drm]
[ 308.531828] Modules linked in:
[ 308.532050] CPU: 0 PID: 1886 Comm: kms_atomic Tainted: G U W 4.13.0-rc5-patser+ #5225
[ 308.532082] Hardware name: NUC5i7RYB, BIOS RYBDWi35.86A.0246.2015.0309.1355 03/09/2015
[ 308.532124] task: ffff8800cd9dae00 task.stack: ffff8800ca3b8000
[ 308.532168] RIP: 0010:drm_modeset_drop_locks+0x33/0xc0 [drm]
[ 308.532189] RSP: 0018:ffff8800ca3bf980 EFLAGS: 00010282
[ 308.532211] RAX: dffffc0000000000 RBX: ffff8800ca3bfaf8 RCX: 0000000013a171e6
[ 308.532235] RDX: 1ffff10019477f69 RSI: ffffffffa8ba4fa0 RDI: ffff8800ca3bfb48
[ 308.532258] RBP: ffff8800ca3bf998 R08: 0000000000000000 R09: 0000000000000003
[ 308.532281] R10: 0000000079dbe066 R11: 00000000f760b34b R12: 0000000000000001
[ 308.532304] R13: dffffc0000000000 R14: 00000000ffffffea R15: ffff880096889680
[ 308.532328] FS: 00007ff00959cec0(0000) GS:ffff8800d4e00000(0000) knlGS:0000000000000000
[ 308.532359] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 308.532380] CR2: 0000000000000008 CR3: 00000000ca2e3000 CR4: 00000000003406f0
[ 308.532402] Call Trace:
[ 308.532440] drm_mode_atomic_ioctl+0x19fa/0x1c00 [drm]
[ 308.532488] ? drm_atomic_set_property+0x1220/0x1220 [drm]
[ 308.532565] ? avc_has_extended_perms+0xc39/0xff0
[ 308.532593] ? lock_downgrade+0x610/0x610
[ 308.532640] ? drm_atomic_set_property+0x1220/0x1220 [drm]
[ 308.532680] drm_ioctl_kernel+0x154/0x1a0 [drm]
[ 308.532755] drm_ioctl+0x624/0x8f0 [drm]
[ 308.532858] ? drm_atomic_set_property+0x1220/0x1220 [drm]
[ 308.532976] ? drm_getunique+0x210/0x210 [drm]
[ 308.533061] do_vfs_ioctl+0xd92/0xe40
[ 308.533121] ? ioctl_preallocate+0x1b0/0x1b0
[ 308.533160] ? selinux_capable+0x20/0x20
[ 308.533191] ? do_fcntl+0x1b1/0xbf0
[ 308.533219] ? kasan_slab_free+0xa2/0xb0
[ 308.533249] ? f_getown+0x4b/0xa0
[ 308.533278] ? putname+0xcf/0xe0
[ 308.533309] ? security_file_ioctl+0x57/0x90
[ 308.533342] SyS_ioctl+0x4e/0x80
[ 308.533374] entry_SYSCALL_64_fastpath+0x18/0xad
[ 308.533405] RIP: 0033:0x7ff00779e4d7
[ 308.533431] RSP: 002b:00007fff66a043d8 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[ 308.533481] RAX: ffffffffffffffda RBX: 000000e7c7ca5910 RCX: 00007ff00779e4d7
[ 308.533560] RDX: 00007fff66a04430 RSI: 00000000c03864bc RDI: 0000000000000003
[ 308.533608] RBP: 00007ff007a5fb00 R08: 000000e7c7ca4620 R09: 000000e7c7ca5e60
[ 308.533647] R10: 0000000000000001 R11: 0000000000000246 R12: 0000000000000070
[ 308.533685] R13: 0000000000000000 R14: 0000000000000000 R15: 000000e7c7ca5930
[ 308.533770] Code: ff df 55 48 89 e5 41 55 41 54 53 48 89 fb 48 83 c7
50 48 89 fa 48 c1 ea 03 80 3c 02 00 74 05 e8 94 d4 16 e7 48 83 7b 50 00
74 02 <0f> ff 4c 8d 6b 58 48 b8 00 00 00 00 00 fc ff df 4c 89 ea 48 c1
[ 308.534086] ---[ end trace 77f11e53b1df44ad ]---
Solve this by adding the missing return.
This is also a bugfix because we could end up rejecting updates with
-EINVAL because of a early -EDEADLK, while if atomic_check ran to
completion it might have downgraded the modeset to a fastset.
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Testcase: kms_atomic
Link: https://patchwork.freedesktop.org/patch/msgid/20170815095706.23624-1-maarten.lankhorst@linux.intel.com
Fixes: d34f20d6e2f2 ("drm: Atomic modeset ioctl")
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit fe4600a548f2763dec91b3b27a1245c370ceee2a upstream.
This is the same bug as we fixed in commit f6cd7daecff5 ("drm: Release
driver references to handle before making it available again"), but now
the exposure is via the PRIME lookup tables. If we remove the
object/handle from the PRIME lut, then a new request for the same
object/fd will generate a new handle, thus for a short window that
object is known to userspace by two different handles. Fix this by
releasing the driver tracking before PRIME.
Fixes: 0ff926c7d4f0 ("drm/prime: add exported buffers to current fprivs
imported buffer list (v2)")
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: David Airlie <airlied@linux.ie>
Cc: Daniel Vetter <daniel.vetter@intel.com>
Cc: Rob Clark <robdclark@gmail.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Thierry Reding <treding@nvidia.com>
Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20170819120558.6465-1-chris@chris-wilson.co.uk
commit a23318feeff662c8d25d21623daebdd2e55ec221 upstream.
The commit 8503ff166504 ("i2c: designware: Avoid unnecessary resuming
during system suspend"), may suggest to the PM core to try out the so
called direct_complete path for system sleep. In this path, the PM core
treats a runtime suspended device as it's already in a proper low power
state for system sleep, which makes it skip calling the system sleep
callbacks for the device, except for the ->prepare() and the ->complete()
callbacks.
However, the PM core may unset the direct_complete flag for a parent
device, in case its child device are being system suspended before. In this
scenario, the PM core invokes the system sleep callbacks, no matter if the
device is runtime suspended or not.
Particularly in cases of an existing i2c slave device, the above path is
triggered, which breaks the assumption that the i2c device is always
runtime resumed whenever the dw_i2c_plat_suspend() is being called.
More precisely, dw_i2c_plat_suspend() calls clk_core_disable() and
clk_core_unprepare(), for an already disabled/unprepared clock, leading to
a splat in the log about clocks calls being wrongly balanced and breaking
system sleep.
To still allow the direct_complete path in cases when it's possible, but
also to keep the fix simple, let's runtime resume the i2c device in the
->suspend() callback, before continuing to put the device into low power
state.
Note, in cases when the i2c device is attached to the ACPI PM domain, this
problem doesn't occur, because ACPI's ->suspend() callback, assigned to
acpi_subsys_suspend(), already calls pm_runtime_resume() for the device.
It should also be noted that this change does not fix commit 8503ff166504
("i2c: designware: Avoid unnecessary resuming during system suspend").
Because for the non-ACPI case, the system sleep support was already broken
prior that point.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Tested-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Acked-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 4a646580f793d19717f7e034c8d473b509c27d49 upstream.
Fixed the issue that two finger scroll does not work correctly
on V8 protocol. The cause is that V8 protocol X-coordinate decode
is wrong at SS4 PLUS device. I added SS4 PLUS X decode definition.
Mote notes:
the problem manifests itself by the commit e7348396c6d5 ("Input: ALPS
- fix V8+ protocol handling (73 03 28)"), where a fix for the V8+
protocol was applied. Although the culprit must have been present
beforehand, the two-finger scroll worked casually even with the
wrongly reported values by some reason. It got broken by the commit
above just because it changed x_max value, and this made libinput
correctly figuring the MT events. Since the X coord is reported as
falsely doubled, the events on the right-half side go outside the
boundary, thus they are no longer handled. This resulted as a broken
two-finger scroll.
One finger event is decoded differently, and it didn't suffer from
this problem. The problem was only about MT events. --tiwai
Fixes: e7348396c6d5 ("Input: ALPS - fix V8+ protocol handling (73 03 28)")
Signed-off-by: Masaki Ota <masaki.ota@jp.alps.com>
Tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Paul Donohue <linux-kernel@PaulSD.com>
commit 1d2226e45040ed4aee95b633cbd64702bf7fc2a1 upstream.
Add ELAN0602 to the list of known ACPI IDs to enable support for ELAN
touchpads found in Lenovo Yoga310.
Signed-off-by: KT Liao <kt.liao@emc.com.tw>
commit ec667683c532c93fb41e100e5d61a518971060e2 upstream.
Synaptics add new TP firmware ID: 0x2 and 0x3, for now both lower 2 bits
are indicated as TP. Change the constant to bitwise values.
This makes trackpoint to be recognized on Lenovo Carbon X1 Gen5 instead
of it being identified as "PS/2 Generic Mouse".
Signed-off-by: Aaron Ma <aaron.ma@canonical.com>
[ Upstream commit ca3d89a3ebe79367bd41b6b8ba37664478ae2dba ]
enable_4k_uar module parameter was added in patch cited below to
address the backward compatibility issue in SRIOV when the VM has
system's PAGE_SIZE uar implementation and the Hypervisor has 4k uar
implementation.
The above compatibility issue does not exist in the non SRIOV case.
In this patch, we always enable 4k uar implementation if SRIOV
is not enabled on mlx4's supported cards.
Fixes: 76e39ccf9c36 ("net/mlx4_core: Fix backward compatibility on VFs")
Signed-off-by: Huy Nguyen <huyn@mellanox.com>
Reviewed-by: Daniel Jurgens <danielj@mellanox.com>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
[ Upstream commit eac2c68d663effb077210218788952b5a0c1f60e ]
The while loop that performs the dma page unmapping never decrements
index counter f and hence loops forever. Fix this with a pre-decrement
on f.
Detected by CoverityScan, CID#1357309 ("Infinite loop")
Fixes: 4c3523623dc0 ("net: add driver for Netronome NFP4000/NFP6000 NIC VFs")
Acked-by: Jakub Kicinski <jakub.kicinski@netronome.com>
commit bed9ff165960921303a100228585f2d1691b42eb upstream.
Signed-off-by: Hector Martin <marcan@marcan.st>
commit ed18c5fa945768a9bec994e786edbbbc7695acf6 upstream.
This optimization significantly reduces xhci driver load time.
In ACPI tables the acpi companion port devices are children of
the hub device. The port devices are identified by their port number
returned by the ACPI _ADR method.
_ADR 0 is reserved for the root hub device.
The current implementation to find a acpi companion port device
loops through all acpi port devices under that parent hub, evaluating
their _ADR method each time a new port device is added.
for a xHC controller with 25 ports under its roothub it
will end up invoking ACPI bytecode 625 times before all ports
are ready, making it really slow.
The _ADR values are already read and cached earler. So instead of
running the bytecode again we can check the cached _ADR value first,
and then fall back to the old way.
As one of the more significant changes, the xhci load time on
Intel kabylake reduced by 70%, (28ms) from
initcall xhci_pci_init+0x0/0x49 returned 0 after 39537 usecs
to
initcall xhci_pci_init+0x0/0x49 returned 0 after 11270 usecs
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 277867ade8262583f4280cadbe90e0031a3706a7 upstream.
of_find_compatible_node() is calling of_node_put() on its first argument
thus leading to an unbalanced of_node_get/put() issue if the node has not
been retained before that.
Instead of passing the root node, pass NULL, which does exactly the same:
iterate over all DT nodes, starting from the root node.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Reported-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Fixes: 3d61467f9bab ("irqchip: atmel-aic: Implement RTC irq fixup")
commit 469bcef53c546bb792aa66303933272991b7831d upstream.
aic_common_irq_fixup() is calling twice of_node_put() on the same node
thus leading to an unbalanced refcount on the root node.
Fixes: b2f579b58e93 ("irqchip: atmel-aic: Add irq fixup infrastructure")
commit b15bd8cb37598afb2963f7eb9e2de468d2d60a2f upstream.
Since commit d05d7f40791c ("Merge branch 'for-4.8/core' of
git://git.kernel.dk/linux-block") and 3fc9d690936f ("Merge branch
'for-4.8/drivers' of git://git.kernel.dk/linux-block"), blkfront_resume()
has been using an index for iterating ring_info to check request when
iterating blk_shadow in an inner loop. This seems to have been
accidentally introduced during the massive rewrite of the block layer
macros in the commits.
This may cause crash like this:
[11798.057074] BUG: unable to handle kernel NULL pointer dereference at 0000000000000048
[11798.058832] IP: [<ffffffff814411fa>] blkfront_resume+0x10a/0x610
[11798.061063] Call Trace:
[11798.061063] [<ffffffff8139ce93>] xenbus_dev_resume+0x53/0x140
[11798.061063] [<ffffffff8139ce40>] ? xenbus_dev_probe+0x150/0x150
[11798.061063] [<ffffffff813f359e>] dpm_run_callback+0x3e/0x110
[11798.061063] [<ffffffff813f3a08>] device_resume+0x88/0x190
[11798.061063] [<ffffffff813f4cc0>] dpm_resume+0x100/0x2d0
[11798.061063] [<ffffffff813f5221>] dpm_resume_end+0x11/0x20
[11798.061063] [<ffffffff813950a8>] do_suspend+0xe8/0x1a0
[11798.061063] [<ffffffff813954bd>] shutdown_handler+0xfd/0x130
[11798.061063] [<ffffffff8139aba0>] ? split+0x110/0x110
[11798.061063] [<ffffffff8139ac26>] xenwatch_thread+0x86/0x120
[11798.061063] [<ffffffff810b4570>] ? prepare_to_wait_event+0x110/0x110
[11798.061063] [<ffffffff8108fe57>] kthread+0xd7/0xf0
[11798.061063] [<ffffffff811da811>] ? kfree+0x121/0x170
[11798.061063] [<ffffffff8108fd80>] ? kthread_park+0x60/0x60
[11798.061063] [<ffffffff810863b0>] ? call_usermodehelper_exec_work+0xb0/0xb0
[11798.061063] [<ffffffff810864ea>] ? call_usermodehelper_exec_async+0x13a/0x140
[11798.061063] [<ffffffff81534a45>] ret_from_fork+0x25/0x30
Use the right index in the inner loop.
Fixes: d05d7f40791c ("Merge branch 'for-4.8/core' of git://git.kernel.dk/linux-block")
Fixes: 3fc9d690936f ("Merge branch 'for-4.8/drivers' of git://git.kernel.dk/linux-block")
Signed-off-by: Munehisa Kamata <kamatam@amazon.com>
Reviewed-by: Thomas Friebel <friebelt@amazon.de>
Reviewed-by: Eduardo Valentin <eduval@amazon.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Roger Pau Monne <roger.pau@citrix.com>
Cc: xen-devel@lists.xenproject.org
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 462cdace790ac2ed6aad1b19c9c0af0143b6aab0 upstream.
The current test for bio vec merging is not fully accurate and can be
tricked into merging bios when certain grant combinations are used.
The result of these malicious bio merges is a bio that extends past
the memory page used by any of the originating bios.
Take into account the following scenario, where a guest creates two
grant references that point to the same mfn, ie: grant 1 -> mfn A,
grant 2 -> mfn A.
These references are then used in a PV block request, and mapped by
the backend domain, thus obtaining two different pfns that point to
the same mfn, pfn B -> mfn A, pfn C -> mfn A.
If those grants happen to be used in two consecutive sectors of a disk
IO operation becoming two different bios in the backend domain, the
checks in xen_biovec_phys_mergeable will succeed, because bfn1 == bfn2
(they both point to the same mfn). However due to the bio merging,
the backend domain will end up with a bio that expands past mfn A into
mfn A + 1.
Fix this by making sure the check in xen_biovec_phys_mergeable takes
into account the offset and the length of the bio, this basically
replicates whats done in __BIOVEC_PHYS_MERGEABLE using mfns (bus
addresses). While there also remove the usage of
__BIOVEC_PHYS_MERGEABLE, since that's already checked by the callers
of xen_biovec_phys_mergeable.
Reported-by: "Jan H. Schönherr" <jschoenh@amazon.de>
Signed-off-by: Roger Pau Monné <roger.pau@citrix.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
commit 76988690402dde2880bfe06ecccf381d48ba8e1c upstream.
Add 2 new IDs (ELAN0609 and ELAN060B) to the list of ACPI IDs that should
be handled by the driver.
commit 1874064eed0502bd9bef7be8023757b0c4f26883 upstream.
Similar to commit 722c5ac708b4f ("Input: elan_i2c - add ELAN0605 to the
ACPI table"), ELAN0608 should be handled by elan_i2c.
This touchpad can be found in Lenovo ideapad 320-14IKB.
BugLink: https://bugs.launchpad.net/bugs/1708852
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
commit 28389575a8cf933a5f3c378556b9f4d3cce0efd2 upstream.
In commit 0f987e25cb8a, the source processing has been moved in front of
the destination processing, but the error handling path has not been
modified accordingly.
Free resources in the correct order to avoid some leaks.
Fixes: 0f987e25cb8a ("crypto: ixp4xx - Fix false lastlen uninitialised warning")
Reported-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
commit 4098116039911e8870d84c975e2ec22dab65a909 upstream.
For 64bit kernels the lmmio_space_offset of the host bridge window
isn't set correctly on systems with dino/cujo PCI host bridges.
This leads to not assigned memory bars and failing drivers, which
need to use these bars.
Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de>
Acked-by: Helge Deller <deller@gmx.de>
Signed-off-by: Helge Deller <deller@gmx.de>
commit 34e61801a3b9df74b69f0e359d64a197a77dd6ac upstream.
GPIODV_18 entry was missing in the original driver push.
Fixes: 468c234f9ed7 ("pinctrl: amlogic: Add support for Amlogic Meson GXBB SoC")
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Reviewed-by: Jerome Brunet <jbrunet@baylibre.com>
commit 3fa53ec2ed885b0aec3f0472e3b4a8a6f1cd748c upstream.
The irq chip callbacks irq_request/release_resources() have absolutely no
business with masking and unmasking the irq.
The core code unmasks the interrupt after complete setup and masks it
before invoking irq_release_resources().
The unmask is actually harmful as it happens before the interrupt is
completely initialized in __setup_irq().
Remove it.
Fixes: f6a8249f9e55 ("pinctrl: exynos: Lock GPIOs as interrupts when used as EINTs")
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: linux-samsung-soc@vger.kernel.org
Cc: linux-gpio@vger.kernel.org
Acked-by: Tomasz Figa <tomasz.figa@gmail.com>
commit 1bd303dc04c3f744474e77c153575087b657f7e1 upstream.
The pingroups dump of debugfs hits WARN_ON() in pinctrl_groups_show().
Filling non-existing ports with '-1' turned out a bad idea.
Fixes: 336306ee1f2d ("pinctrl: uniphier: add UniPhier PH1-LD20 pinctrl driver")
commit 9592bc256d50481dfcdba93890e576a728fb373c upstream.
Fixes: 70f2f9c4cf25 ("pinctrl: uniphier: add UniPhier PH1-LD11 pinctrl driver")
commit 5d996132d921c391af5f267123eca1a6a3148ecd upstream.
UART pin lists consist GPIO numbers which is simply wrong.
Replace it by pin numbers.
Fixes: 4e80c8f50574 ("pinctrl: intel: Add Intel Merrifield pin controller support")
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
commit d81ece747d8727bb8b1cfc9a20dbe62f09a4e35a upstream.
The PH16 pin has a function with mux id 0x5, which is the DET pin of the
"sim" (smart card reader) IP block.
This function is missing in old versions of A10/A20 SoCs' datasheets and
user manuals, so it's also missing in the old drivers. The newest A10
Datasheet V1.70 and A20 Datasheet V1.41 contain this pin function, and
it's discovered during implementing R40 pinctrl driver.
Add it to the driver. As we now merged A20 pinctrl driver to the A10
one, we need to only fix the A10 driver now.
Fixes: f2821b1ca3a2 ("pinctrl: sunxi: Move Allwinner A10 pinctrl
driver to a driver of its own")
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
commit d466d3c1217406b14b834335b5b4b33c0d45bd09 upstream.
In order to select the alternate voltage reference pair (VALTH/VALTL), the
right value for the REFSEL field in the ADCx_CFG register is "01", leading
to 0x800 as register mask. See section 8.2.6.4 in the reference manual[1].
[1] http://www.nxp.com/docs/en/reference-manual/VFXXXRM.pdf
Fixes: a775427632fd ("iio:adc:imx: add Freescale Vybrid vf610 adc driver")
Signed-off-by: Stefan-Gabriel Mirea <stefan-gabriel.mirea@nxp.com>
commit e788787ef4f9c24aafefc480a8da5f92b914e5e6 upstream.
Certain HP keyboards would keep inputting a character automatically which
is the wake-up key after S3 resume
On some AMD platforms USB host fails to respond (by holding resume-K) to
USB device (an HP keyboard) resume request within 1ms (TURSM) and ensures
that resume is signaled for at least 20 ms (TDRSMDN), which is defined in
USB 2.0 spec. The result is that the keyboard is out of function.
In SNPS USB design, the host responds to the resume request only after
system gets back to S0 and the host gets to functional after the internal
HW restore operation that is more than 1 second after the initial resume
request from the USB device.
As a workaround for specific keyboard ID(HP Keyboards), applying port reset
after resume when the keyboard is plugged in.
Signed-off-by: Sandeep Singh <Sandeep.Singh@amd.com>
Signed-off-by: Shyam Sundar S K <Shyam-sundar.S-k@amd.com>
cc: Nehal Shah <Nehal-bakulchandra.Shah@amd.com>
Reviewed-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit 7496cfe5431f21da5d27a8388c326397e3f0a5db upstream.
Moshi USB to Ethernet Adapter internally uses a Genesys Logic hub to
connect to Realtek r8153.
The Realtek r8153 ethernet does not work on the internal hub, no-lpm quirk
can make it work.
Since another r8153 dongle at my hand does not have the issue, so add
the quirk to the Genesys Logic hub instead.
