Signed-off-by: Andri Schmidt <a.schmidt@scewo.ch>
SDHCI falls back to fixed sampling if there is an error during tuning.
However it also reports an error unless there is periodic re-tuning.
That is not the best option because:
a) there is a reasonable chance that fixed sampling will work, especially
at room temperature.
b) re-tuning will be done again anyway if there are CRC errors.
Change to return no error always when falling back to fixed sampling.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
(cherry picked from commit 0760c355525c08dd598e86edb2a310688ac8af4c)
Other unsigned properties return hexadecimal values, follow this
convention when printing b_vendor_code too. Also add newlines to
the OS Descriptor support related properties, like other sysfs
files use.
Reviewed-by: Krzysztof Opasiak <k.opasiak@samsung.com>
Signed-off-by: Stefan Agner <stefan@agner.ch>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
(cherry picked from commit e800e8cbdf42c73602b90258f82a2cfe86ec53a7)
Currently qw_sign requires UTF-8 character to set, but returns UTF-16
when read. This isn't obvious when simply using cat since the null
characters are not visible, but hexdump unveils the true string:
# echo MSFT100 > os_desc/qw_sign
# hexdump -C os_desc/qw_sign
00000000 4d 00 53 00 46 00 54 00 31 00 30 00 30 00 |M.S.F.T.1.0.0.|
Make qw_sign symmetric by returning an UTF-8 string too. Also follow
common convention and add a new line at the end.
(cherry picked from commit 76180d716f91f035d9c8639497cf5459b44e1a51)
The device tree property fsl,legacy-bch-geometry was only evaluated
when nand-on-flash-bbt was also defined. This looks wrong.
In mainline (as of 4.12) fsl,legacy-bch-geometry doesn't exist,
its functionality seems to be taken over by the fsl,use-minimum-ecc
property and it is used independent of nand-on-flash-bbt.
The move of code gets also rid of the following compiler warning:
drivers/mtd/nand/gpmi-nand/gpmi-nand.c:2274:2: warning: this 'if' clause does not guard... [-Wmisleading-indentation]
if (of_property_read_bool(this->dev->of_node,
drivers/mtd/nand/gpmi-nand/gpmi-nand.c:2278:3: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the 'if'
POWER_ENABLE_MOCI
Poweroff failed powering off the carrier board side of things
and did not deassert POWER_ENABLE_MOCI on poweroff. Fix this.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Backport 78de28c67 introduced the following compiler warning. The
later function prototype was changed to return a void* while
in 4.1 the function does not return a value.
drivers/of/fdt.c: In function '__unflatten_device_tree':
include/linux/stddef.h:8:14: warning: 'return' with a value, in function returning void
#define NULL ((void *)0)
drivers/of/fdt.c:416:10: note: in expansion of macro 'NULL'
return NULL;
With gcc 5.1 I get:
warning: switch condition has boolean value [-Wswitch-bool]
Signed-off-by: Tomer Barletz <barletz@gmail.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
(cherry picked from commit cc7fce80229067890365c1ee196be5d304d36dea)
Mainline commit 9386aae907d9ee79d54640f09d70909393e0ddeb addresses
macro collisions, however the mainline and downstream kernel driver
do not match.
Fix the issue addressed in mainline in the downstream codebase.
This reverts commit 9386aae907d9ee79d54640f09d70909393e0ddeb.
The fsl-quadspi from mainline is implemented differently, so do not
use it from the mainline backport.
Required to also revert merge conflict resolution.
Linux 4.1.44
* tag 'v4.1.44': (180 commits)
Linux 4.1.44
mtd: fsl-quadspi: fix macro collision problems with READ/WRITE
pinctrl: samsung: Remove bogus irq_[un]mask from resource management
pinctrl: sunxi: add a missing function of A10/A20 pinctrl driver
pnfs/blocklayout: require 64-bit sector_t
iio: adc: vf610_adc: Fix VALT selection value for REFSEL bits
usb:xhci:Add quirk for Certain failing HP keyboard on reset after resume
usb: quirks: Add no-lpm quirk for Moshi USB to Ethernet Adapter
USB: Check for dropped connection before switching to full speed
uas: Add US_FL_IGNORE_RESIDUE for Initio Corporation INIC-3069
iio: light: tsl2563: use correct event code
staging:iio:resolver:ad2s1210 fix negative IIO_ANGL_VEL read
USB: hcd: Mark secondary HCD as dead if the primary one died
USB: serial: pl2303: add new ATEN device id
USB: serial: cp210x: add support for Qivicon USB ZigBee dongle
USB: serial: option: add D-Link DWM-222 device ID
nfs/flexfiles: fix leak of nfs4_ff_ds_version arrays
fuse: initialize the flock flag in fuse_file on allocation
iscsi-target: Fix iscsi_np reset hung task during parallel delete
iscsi-target: fix memory leak in iscsit_setup_text_cmd()
Signed-off-by: Otavio Salvador <otavio@ossystems.com.br>
[ Upstream commit 04850c4d8613127a9b488321c0ad83bff7519311 ]
Change the READ/WRITE to FSL_READ/FSL_WRITE to resolve any possible
namespace collisions with READ/WRITE macros (e.g., from <linux/fs.h>).
Problems have been seen, for example, on mips:
>> drivers/mtd/spi-nor/fsl-quadspi.c:186:5: error: 'LUT_0' undeclared (first use in this function)
((LUT_##ins) << INSTR0_SHIFT))
>> drivers/mtd/spi-nor/fsl-quadspi.c:188:30: note: in expansion of macro 'LUT0'
On SPARC:
drivers/mtd/spi-nor/fsl-quadspi.c: In function 'fsl_qspi_init_lut':
drivers/mtd/spi-nor/fsl-quadspi.c:369:1: error: 'LUT_0' undeclared (first use in this function)
drivers/mtd/spi-nor/fsl-quadspi.c:418:1: error: pasting "LUT_" and "(" does not give a valid preprocessing token
drivers/mtd/spi-nor/fsl-quadspi.c:418:2: error: implicit declaration of function 'LUT_'
And surely on others.
Fixes: d26a22d06708 ("mtd: fsl-quadspi: allow building for other ARCHes with COMPILE_TEST")
Reported-by: Guenter Roeck <linux@roeck-us.net>
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Han Xu <b45815@freescale.com>
[Brian: rewrote commit description]
[ Upstream commit 3fa53ec2ed885b0aec3f0472e3b4a8a6f1cd748c ]
The irq chip callbacks irq_request/release_resources() have absolutely no
business with masking and unmasking the irq.
The core code unmasks the interrupt after complete setup and masks it
before invoking irq_release_resources().
The unmask is actually harmful as it happens before the interrupt is
completely initialized in __setup_irq().
Remove it.
Fixes: f6a8249f9e55 ("pinctrl: exynos: Lock GPIOs as interrupts when used as EINTs")
Cc: Krzysztof Kozlowski <krzk@kernel.org>
Cc: Sylwester Nawrocki <s.nawrocki@samsung.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Kukjin Kim <kgene@kernel.org>
Cc: linux-samsung-soc@vger.kernel.org
Cc: linux-gpio@vger.kernel.org
Acked-by: Tomasz Figa <tomasz.figa@gmail.com>
[ Upstream commit d81ece747d8727bb8b1cfc9a20dbe62f09a4e35a ]
The PH16 pin has a function with mux id 0x5, which is the DET pin of the
"sim" (smart card reader) IP block.
This function is missing in old versions of A10/A20 SoCs' datasheets and
user manuals, so it's also missing in the old drivers. The newest A10
Datasheet V1.70 and A20 Datasheet V1.41 contain this pin function, and
it's discovered during implementing R40 pinctrl driver.
Add it to the driver. As we now merged A20 pinctrl driver to the A10
one, we need to only fix the A10 driver now.
Fixes: f2821b1ca3a2 ("pinctrl: sunxi: Move Allwinner A10 pinctrl
driver to a driver of its own")
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
[ Upstream commit d466d3c1217406b14b834335b5b4b33c0d45bd09 ]
In order to select the alternate voltage reference pair (VALTH/VALTL), the
right value for the REFSEL field in the ADCx_CFG register is "01", leading
to 0x800 as register mask. See section 8.2.6.4 in the reference manual[1].
[1] http://www.nxp.com/docs/en/reference-manual/VFXXXRM.pdf
Fixes: a775427632fd ("iio:adc:imx: add Freescale Vybrid vf610 adc driver")
Signed-off-by: Stefan-Gabriel Mirea <stefan-gabriel.mirea@nxp.com>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
[ Upstream commit e788787ef4f9c24aafefc480a8da5f92b914e5e6 ]
Certain HP keyboards would keep inputting a character automatically which
is the wake-up key after S3 resume
On some AMD platforms USB host fails to respond (by holding resume-K) to
USB device (an HP keyboard) resume request within 1ms (TURSM) and ensures
that resume is signaled for at least 20 ms (TDRSMDN), which is defined in
USB 2.0 spec. The result is that the keyboard is out of function.
In SNPS USB design, the host responds to the resume request only after
system gets back to S0 and the host gets to functional after the internal
HW restore operation that is more than 1 second after the initial resume
request from the USB device.
As a workaround for specific keyboard ID(HP Keyboards), applying port reset
after resume when the keyboard is plugged in.
Signed-off-by: Sandeep Singh <Sandeep.Singh@amd.com>
Signed-off-by: Shyam Sundar S K <Shyam-sundar.S-k@amd.com>
cc: Nehal Shah <Nehal-bakulchandra.Shah@amd.com>
Reviewed-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Cc: stable <stable@vger.kernel.org>
[ Upstream commit 7496cfe5431f21da5d27a8388c326397e3f0a5db ]
Moshi USB to Ethernet Adapter internally uses a Genesys Logic hub to
connect to Realtek r8153.
The Realtek r8153 ethernet does not work on the internal hub, no-lpm quirk
can make it work.
Since another r8153 dongle at my hand does not have the issue, so add
the quirk to the Genesys Logic hub instead.
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
[ Upstream commit 94c43b9897abf4ea366ed4dba027494e080c7050 ]
Some buggy USB disk adapters disconnect and reconnect multiple times
during the enumeration procedure. This may lead to a device
connecting at full speed instead of high speed, because when the USB
stack sees that a device isn't able to enumerate at high speed, it
tries to hand the connection over to a full-speed companion
controller.
The logic for doing this is careful to check that the device is still
connected. But this check is inadequate if the device disconnects and
reconnects before the check is done. The symptom is that a device
works, but much more slowly than it is capable of operating.
The situation was made worse recently by commit 22547c4cc4fe ("usb:
hub: Wait for connection to be reestablished after port reset"), which
increases the delay following a reset before a disconnect is
recognized, thus giving the device more time to reconnect.
This patch makes the check more robust. If the device was
disconnected at any time during enumeration, we will now skip the
full-speed handover.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: Zdenek Kabelac <zkabelac@redhat.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
[ Upstream commit 89f23d51defcb94a5026d4b5da13faf4e1150a6f ]
Similar to commit d595259fbb7a ("usb-storage: Add ignore-residue quirk for
Initio INIC-3619") for INIC-3169 in unusual_devs.h but INIC-3069 already
present in unusual_uas.h. Both in same controller IC family.
Issue is that MakeMKV fails during key exchange with installed bluray drive
with following error:
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED'
occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:0'
Signed-off-by: Alan Swanson <reiver@improbability.net>
Acked-by: Oliver Neukum <oneukum@suse.com>
[ Upstream commit a3507e48d3f99a93a3056a34a5365f310434570f ]
The TSL2563 driver provides three iio channels, two of which are raw ADC
channels (channel 0 and channel 1) in the device and the remaining one
is calculated by the two. The ADC channel 0 only supports programmable
interrupt with threshold settings and this driver supports the event but
the generated event code does not contain the corresponding iio channel
type.
This is going to change userspace ABI. Hopefully fixing this to be
what it should always have been won't break any userspace code.
Cc: Jonathan Cameron <jic23@kernel.org>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
[ Upstream commit 105967ad68d2eb1a041bc041f9cf96af2a653b65 ]
gcc-7 points out an older regression:
drivers/staging/iio/resolver/ad2s1210.c: In function 'ad2s1210_read_raw':
drivers/staging/iio/resolver/ad2s1210.c:515:42: error: '<<' in boolean context, did you mean '<' ? [-Werror=int-in-bool-context]
The original code had 'unsigned short' here, but incorrectly got
converted to 'bool'. This reverts the regression and uses a normal
type instead.
Fixes: 29148543c521 ("staging:iio:resolver:ad2s1210 minimal chan spec conversion.")
Cc: stable@vger.kernel.org
[ Upstream commit cd5a6a4fdaba150089af2afc220eae0fef74878a ]
Make usb_hc_died() clear the HCD_FLAG_RH_RUNNING flag for the shared
HCD and set HCD_FLAG_DEAD for it, in analogy with what is done for
the primary one.
Among other thigs, this prevents check_root_hub_suspended() from
returning -EBUSY for dead HCDs which helps to work around system
suspend issues in some situations.
This actually fixes occasional suspend failures on one of my test
machines.
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
[ Upstream commit 3b6bcd3d093c698d32e93d4da57679b8fbc5e01e ]
This adds a new ATEN device id for a new pl2303-based device.
Reported-by: Peter Kuo <PeterKuo@aten.com.tw>
Cc: Johan Hovold <johan@kernel.org>
[ Upstream commit 9585e340db9f6cc1c0928d82c3a23cc4460f0a3f ]
The German Telekom offers a ZigBee USB Stick under the brand name Qivicon
for their SmartHome Home Base in its 1. Generation. The productId is not
known by the according kernel module, this patch adds support for it.
Signed-off-by: Stefan Triller <github@stefantriller.de>
Reviewed-by: Frans Klaver <fransklaver@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit fd1b8668af59a11bb754a6c9b0051c6c5ce73b74 ]
Add device id for D-Link DWM-222.
Signed-off-by: Hector Martin <marcan@marcan.st>
[ Upstream commit 978d13d60c34818a41fc35962602bdfa5c03f214 ]
This patch fixes a bug associated with iscsit_reset_np_thread()
that can occur during parallel configfs rmdir of a single iscsi_np
used across multiple iscsi-target instances, that would result in
hung task(s) similar to below where configfs rmdir process context
was blocked indefinately waiting for iscsi_np->np_restart_comp
to finish:
[ 6726.112076] INFO: task dcp_proxy_node_:15550 blocked for more than 120 seconds.
[ 6726.119440] Tainted: G W O 4.1.26-3321 #2
[ 6726.125045] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 6726.132927] dcp_proxy_node_ D ffff8803f202bc88 0 15550 1 0x00000000
[ 6726.140058] ffff8803f202bc88 ffff88085c64d960 ffff88083b3b1ad0 ffff88087fffeb08
[ 6726.147593] ffff8803f202c000 7fffffffffffffff ffff88083f459c28 ffff88083b3b1ad0
[ 6726.155132] ffff88035373c100 ffff8803f202bca8 ffffffff8168ced2 ffff8803f202bcb8
[ 6726.162667] Call Trace:
[ 6726.165150] [<ffffffff8168ced2>] schedule+0x32/0x80
[ 6726.170156] [<ffffffff8168f5b4>] schedule_timeout+0x214/0x290
[ 6726.176030] [<ffffffff810caef2>] ? __send_signal+0x52/0x4a0
[ 6726.181728] [<ffffffff8168d7d6>] wait_for_completion+0x96/0x100
[ 6726.187774] [<ffffffff810e7c80>] ? wake_up_state+0x10/0x10
[ 6726.193395] [<ffffffffa035d6e2>] iscsit_reset_np_thread+0x62/0xe0 [iscsi_target_mod]
[ 6726.201278] [<ffffffffa0355d86>] iscsit_tpg_disable_portal_group+0x96/0x190 [iscsi_target_mod]
[ 6726.210033] [<ffffffffa0363f7f>] lio_target_tpg_store_enable+0x4f/0xc0 [iscsi_target_mod]
[ 6726.218351] [<ffffffff81260c5a>] configfs_write_file+0xaa/0x110
[ 6726.224392] [<ffffffff811ea364>] vfs_write+0xa4/0x1b0
[ 6726.229576] [<ffffffff811eb111>] SyS_write+0x41/0xb0
[ 6726.234659] [<ffffffff8169042e>] system_call_fastpath+0x12/0x71
It would happen because each iscsit_reset_np_thread() sets state
to ISCSI_NP_THREAD_RESET, sends SIGINT, and then blocks waiting
for completion on iscsi_np->np_restart_comp.
However, if iscsi_np was active processing a login request and
more than a single iscsit_reset_np_thread() caller to the same
iscsi_np was blocked on iscsi_np->np_restart_comp, iscsi_np
kthread process context in __iscsi_target_login_thread() would
flush pending signals and only perform a single completion of
np->np_restart_comp before going back to sleep within transport
specific iscsit_transport->iscsi_accept_np code.
To address this bug, add a iscsi_np->np_reset_count and update
__iscsi_target_login_thread() to keep completing np->np_restart_comp
until ->np_reset_count has reached zero.
Reported-by: Gary Guo <ghg@datera.io>
Tested-by: Gary Guo <ghg@datera.io>
Cc: Mike Christie <mchristi@redhat.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: stable@vger.kernel.org # 3.10+
[ Upstream commit ea8dc5b4cd2195ee582cae28afa4164c6dea1738 ]
On receiving text request iscsi-target allocates buffer for
payload in iscsit_handle_text_cmd() and assigns buffer pointer
to cmd->text_in_ptr, this buffer is currently freed in
iscsit_release_cmd(), if iscsi-target sets 'C' bit in text
response then it will receive another text request from the
initiator with ttt != 0xffffffff in this case iscsi-target
will find cmd using itt and call iscsit_setup_text_cmd()
which will set cmd->text_in_ptr to NULL without freeing
previously allocated buffer.
This patch fixes this issue by calling kfree(cmd->text_in_ptr)
in iscsit_setup_text_cmd() before assigning NULL to it.
For the first text request cmd->text_in_ptr is NULL as
cmd is memset to 0 in iscsit_allocate_cmd().
Signed-off-by: Varun Prakash <varun@chelsio.com>
Cc: <stable@vger.kernel.org> # 4.0+
[ Upstream commit 6bf6b0aa3da84a3d9126919a94c49c0fb7ee2fb3 ]
If blk_mq_init_queue() returns an error, it gets assigned to
vblk->disk->queue. Then, when we call put_disk(), we end up calling
blk_put_queue() with the ERR_PTR, causing a bad dereference. Fix it by
only assigning to vblk->disk->queue on success.
Signed-off-by: Omar Sandoval <osandov@fb.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
[ Upstream commit c7702b8c22712a06080e10f1d2dee1a133ec8809 ]
There is a race condition with qla2xxx optrom functions where one thread
might modify optrom buffer, optrom_state while other thread is still
reading from it.
In couple of crashes, it was found that we had successfully passed the
following 'if' check where we confirm optrom_state to be
QLA_SREADING. But by the time we acquired mutex lock to proceed with
memory_read_from_buffer function, some other thread/process had already
modified that option rom buffer and optrom_state from QLA_SREADING to
QLA_SWAITING. Then we got ha->optrom_buffer 0x0 and crashed the system:
if (ha->optrom_state != QLA_SREADING)
return 0;
mutex_lock(&ha->optrom_mutex);
rval = memory_read_from_buffer(buf, count, &off, ha->optrom_buffer,
ha->optrom_region_size);
mutex_unlock(&ha->optrom_mutex);
With current optrom function we get following crash due to a race
condition:
[ 1479.466679] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 1479.466707] IP: [<ffffffff81326756>] memcpy+0x6/0x110
[ 1479.473673] Call Trace:
[ 1479.474296] [<ffffffff81225cbc>] ? memory_read_from_buffer+0x3c/0x60
[ 1479.474941] [<ffffffffa01574dc>] qla2x00_sysfs_read_optrom+0x9c/0xc0 [qla2xxx]
[ 1479.475571] [<ffffffff8127e76b>] read+0xdb/0x1f0
[ 1479.476206] [<ffffffff811fdf9e>] vfs_read+0x9e/0x170
[ 1479.476839] [<ffffffff811feb6f>] SyS_read+0x7f/0xe0
[ 1479.477466] [<ffffffff816964c9>] system_call_fastpath+0x16/0x1b
Below patch modifies qla2x00_sysfs_read_optrom,
qla2x00_sysfs_write_optrom functions to get the mutex_lock before
checking ha->optrom_state to avoid similar crashes.
The patch was applied and tested and same crashes were no longer
observed again.
Tested-by: Milan P. Gandhi <mgandhi@redhat.com>
Signed-off-by: Milan P. Gandhi <mgandhi@redhat.com>
Reviewed-by: Laurence Oberman <loberman@redhat.com>
Acked-by: Himanshu Madhani <himanshu.madhani@cavium.com>
[ Upstream commit f5992b72ebe0dde488fa8f706b887194020c66fc ]
The driver's ndo_get_stats64() method is not always called under RTNL.
So it can race with driver close or ethtool reconfigurations. Fix the
race condition by taking tp->lock spinlock in tg3_free_consistent()
when freeing the tp->hw_stats memory block. tg3_get_stats64() is
already taking tp->lock.
Reported-by: Wang Yufen <wangyufen@huawei.com>
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 0f1f9cbc04dbb3cc310f70a11cba0cf1f2109d9c ]
The R8A7740 GEther controller supports the packet checksum offloading
but the 'hw_crc' (bad name, I'll fix it) flag isn't set in the R8A7740
data, thus CSMR isn't cleared...
Fixes: 73a0d907301e ("net: sh_eth: add support R8A7740")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit dfa523ae9f2542bee4cddaea37b3be3e157f6e6b ]
Add a flag to indicate if a queue is rate-limited. Test the flag in
NAPI poll handler and avoid rescheduling the queue if true, otherwise
we risk locking up the host. The rescheduling will be done in the
timer callback function.
Reported-by: Jean-Louis Dupond <jean-louis@dupond.be>
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Tested-by: Jean-Louis Dupond <jean-louis@dupond.be>
Reviewed-by: Paul Durrant <paul.durrant@citrix.com>
[ Upstream commit 7b9a88a390dacb37b051a7b09b9a08f546edf5eb ]
The PHY library does not deal very well with bind and unbind events. The first
thing we would see is that we were not properly canceling the PHY state machine
workqueue, so we would be crashing while dereferencing phydev->drv since there
is no driver attached anymore.
Suggested-by: Russell King <rmk+kernel@armlinux.org.uk>
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
[ Upstream commit 7ad813f208533cebfcc32d3d7474dc1677d1b09a ]
Marc reported that he was not getting the PHY library adjust_link()
callback function to run when calling phy_stop() + phy_disconnect()
which does not indeed happen because we set the state machine to
PHY_HALTED but we don't get to run it to process this state past that
point.
Fix this with a synchronous call to phy_state_machine() in order to have
the state machine actually act on PHY_HALTED, set the PHY device's link
down, turn the network device's carrier off and finally call the
adjust_link() function.
Reported-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
Fixes: a390d1f379cf ("phylib: convert state_queue work to delayed_work")
Signed-off-by: Marc Gonzalez <marc_gonzalez@sigmadesigns.com>
[ Upstream commit 9476d393667968b4a02afbe9d35a3558482b943e ]
DMA transfers are not allowed to buffers that are on the stack.
Therefore allocate a buffer to store the result of usb_control_message().
Fixes these bugreports:
https://bugzilla.kernel.org/show_bug.cgi?id=195217
https://bugzilla.redhat.com/show_bug.cgi?id=1421387
https://bugzilla.redhat.com/show_bug.cgi?id=1427398
Shortened kernel backtrace from 4.11.9-200.fc25.x86_64:
kernel: ------------[ cut here ]------------
kernel: WARNING: CPU: 3 PID: 2957 at drivers/usb/core/hcd.c:1587
kernel: transfer buffer not dma capable
kernel: Call Trace:
kernel: dump_stack+0x63/0x86
kernel: __warn+0xcb/0xf0
kernel: warn_slowpath_fmt+0x5a/0x80
kernel: usb_hcd_map_urb_for_dma+0x37f/0x570
kernel: ? try_to_del_timer_sync+0x53/0x80
kernel: usb_hcd_submit_urb+0x34e/0xb90
kernel: ? schedule_timeout+0x17e/0x300
kernel: ? del_timer_sync+0x50/0x50
kernel: ? __slab_free+0xa9/0x300
kernel: usb_submit_urb+0x2f4/0x560
kernel: ? urb_destroy+0x24/0x30
kernel: usb_start_wait_urb+0x6e/0x170
kernel: usb_control_msg+0xdc/0x120
kernel: mcs_get_reg+0x36/0x40 [mcs7780]
kernel: mcs_net_open+0xb5/0x5c0 [mcs7780]
Regression goes back to 4.9, so it's a good candidate for -stable.
Though it's the decision of the maintainer.
Thanks to Dan Williams for adding the "transfer buffer not dma capable"
warning in the first place. It instantly pointed me in the right direction.
Patch has been tested with transferring data from a Polar watch.
Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
[ Upstream commit 6fb05e0dd32e566facb96ea61a48c7488daa5ac3 ]
Avoid a double fetch by reusing the values from the prior transfer.
Originally reported via https://bugzilla.kernel.org/show_bug.cgi?id=195559
Thanks to Pengfei Wang <wpengfeinudt@gmail.com> for reporting.
Signed-off-by: Steven Toth <stoth@kernellabs.com>
Reported-by: Pengfei Wang <wpengfeinudt@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
[ Upstream commit 9f5039ba440e499d85c29b1ddbc3cbc9dc90e44b ]
Since commit e8f4818895b3 ("[media] lirc: advertise
LIRC_CAN_GET_REC_RESOLUTION and improve") lircd uses the ioctl
LIRC_GET_REC_RESOLUTION to determine the shortest pulse or space that
the hardware can detect. This breaks decoding in lirc because lircd
expects the answer in microseconds, but nanoseconds is returned.
Cc: <stable@vger.kernel.org> # v2.6.36+
Reported-by: Derek <user.vdr@gmail.com>
Tested-by: Derek <user.vdr@gmail.com>
Signed-off-by: Sean Young <sean@mess.org>
[ Upstream commit fce50a2fa4e9c6e103915c351b6d4a98661341d6 ]
This patch fixes a NULL pointer dereference in isert_login_recv_done()
of isert_conn->cm_id due to isert_cma_handler() -> isert_connect_error()
resetting isert_conn->cm_id = NULL during a failed login attempt.
As per Sagi, we will always see the completion of all recv wrs posted
on the qp (given that we assigned a ->done handler), this is a FLUSH
error completion, we just don't get to verify that because we deref
NULL before.
The issue here, was the assumption that dereferencing the connection
cm_id is always safe, which is not true since:
commit 4a579da2586bd3b79b025947ea24ede2bbfede62
Author: Sagi Grimberg <sagig@mellanox.com>
Date: Sun Mar 29 15:52:04 2015 +0300
iser-target: Fix possible deadlock in RDMA_CM connection error
As I see it, we have a direct reference to the isert_device from
isert_conn which is the one-liner fix that we actually need like
we do in isert_rdma_read_done() and isert_rdma_write_done().
Reported-by: Andrea Righi <righi.andrea@gmail.com>
Tested-by: Andrea Righi <righi.andrea@gmail.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.me>
Cc: <stable@vger.kernel.org> # 3.10+
[ Upstream commit 105fa2f44e504c830697b0c794822112d79808dc ]
This patch fixes a BUG() in iscsit_close_session() that could be
triggered when iscsit_logout_post_handler() execution from within
tx thread context was not run for more than SECONDS_FOR_LOGOUT_COMP
(15 seconds), and the TCP connection didn't already close before
then forcing tx thread context to automatically exit.
This would manifest itself during explicit logout as:
[33206.974254] 1 connection(s) still exist for iSCSI session to iqn.1993-08.org.debian:01:3f5523242179
[33206.980184] INFO: NMI handler (kgdb_nmi_handler) took too long to run: 2100.772 msecs
[33209.078643] ------------[ cut here ]------------
[33209.078646] kernel BUG at drivers/target/iscsi/iscsi_target.c:4346!
Normally when explicit logout attempt fails, the tx thread context
exits and iscsit_close_connection() from rx thread context does the
extra cleanup once it detects conn->conn_logout_remove has not been
cleared by the logout type specific post handlers.
To address this special case, if the logout post handler in tx thread
context detects conn->tx_thread_active has already been cleared, simply
return and exit in order for existing iscsit_close_connection()
logic from rx thread context do failed logout cleanup.
Reported-by: Bart Van Assche <bart.vanassche@sandisk.com>
Tested-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: stable@vger.kernel.org # 3.14+
Tested-by: Chu Yuan Lin <cyl@datera.io>
[ Upstream commit da05d52d2f0f6bd61094a0cd045fed94bf7d673a ]
this patch makes sure VPFE_CMD_S_CCDC_RAW_PARAMS ioctl no longer works
for vpfe_capture driver with a minimal patch suitable for backporting.
- This ioctl was never in public api and was only defined in kernel header.
- The function set_params constantly mixes up pointers and phys_addr_t
numbers.
- This is part of a 'VPFE_CMD_S_CCDC_RAW_PARAMS' ioctl command that is
described as an 'experimental ioctl that will change in future kernels'.
- The code to allocate the table never gets called after we copy_from_user
the user input over the kernel settings, and then compare them
for inequality.
- We then go on to use an address provided by user space as both the
__user pointer for input and pass it through phys_to_virt to come up
with a kernel pointer to copy the data to. This looks like a trivially
exploitable root hole.
Due to these reasons we make sure this ioctl now returns -EINVAL and backport
this patch as far as possible.
Fixes: 5f15fbb68fd7 ("V4L/DVB (12251): v4l: dm644x ccdc module for vpfe capture driver")
Signed-off-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Cc: <stable@vger.kernel.org> # for v3.7 and up
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
[ Upstream commit 59a5e266c3f5c1567508888dd61a45b86daed0fa ]
My static checker complains that "devno" can be negative, meaning that
we read before the start of the loop. I've looked at the code, and I
think the warning is right. This come from /proc so it's root only or
it would be quite a quite a serious bug. The call tree looks like this:
proc_scsi_write() <- gets id and channel from simple_strtoul()
-> scsi_add_single_device() <- calls shost->transportt->user_scan()
-> ata_scsi_user_scan()
-> ata_find_dev()
Cc: stable@vger.kernel.org # all versions at this point
[ Upstream commit 9698b6f473555a722bf81a3371998427d5d27bde ]
This fix is to avoid calling fnic_fw_reset_handler through
fnic_host_reset when a finc reset is alreay in progress.
Signed-off-by: Satish Kharat <satishkh@cisco.com>
Signed-off-by: Sesidhar Baddela <sebaddel@cisco.com>
[ Upstream commit 08f9572671c8047e7234cbf150869aa3c3d59a97 ]
This headlamp contains a dummy HID descriptor which pretends to be
a mouse-like device, but can't be used as a mouse at all.
Reported-by: Lukas Ocilka <lukas.ocilka@suse.com>
[ Upstream commit 71eae1ca77fd6be218d8a952d97bba827e56516d ]
The RX descriptor word 0 on SH7734 has the RFS[9:0] field in bits 16-25
(bits 0-15 usually used for that are occupied by the packet checksum).
Thus we need to set the 'shift_rd0' field in the SH7734 SoC data...
Fixes: f0e81fecd4f8 ("net: sh_eth: Add support SH7734")
[ Upstream commit e19f32da5ded958238eac1bbe001192acef191a2 ]
Here, pci_iomap can fail, handle this case release selected
pci regions and return -ENOMEM.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit 4dcd19bfabaee8f9f4bcf203afba09b98ccbaf76 ]
Here, If devm_ioremap will fail. It will return NULL.
Kernel can run into a NULL-pointer dereference.
This error check will avoid NULL pointer dereference.
Acked-by: Yoichi Yuasa <yuasa@linux-mips.org>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[ Upstream commit 43aef5c2ca90535b3227e97e71604291875444ed ]
This fixes an error message that was probably copied and pasted. The same
message is used for both the in and out endpoints, so it makes it impossible
to know which one actually failed because both cases say "IN".
Make the out endpoint error message say "OUT".
Signed-off-by: David Lechner <david@lechnology.com>
[ Upstream commit c2a6bbaf0c5f90463a7011a295bbdb7e33c80b51 ]
The way acpi_find_child_device() works currently is that, if there
are two (or more) devices with the same _ADR value in the same
namespace scope (which is not specifically allowed by the spec and
the OS behavior in that case is not defined), the first one of them
found to be present (with the help of _STA) will be returned.
This covers the majority of cases, but is not sufficient if some of
the devices in question have a _HID (or _CID) returning some valid
ACPI/PNP device IDs (which is disallowed by the spec) and the
ASL writers' expectation appears to be that the OS will match
devices without a valid ACPI/PNP device ID against a given bus
address first.
To cover this special case as well, modify find_child_checks()
to prefer devices without ACPI/PNP device IDs over devices that
have them.
Suggested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Tested-by: Hans de Goede <hdegoede@redhat.com>
[ Upstream commit 13288bdf4adbaa6bd1267f10044c1bc25d90ce7f ]
Some system have multiple dw devices. Currently the driver uses a
fixed name for the debugfs dir. Append dev name to the debugfs dir
name to make it unique.
Signed-off-by: Phil Reid <preid@electromag.com.au>
Signed-off-by: Mark Brown <broonie@kernel.org>
