path: root/drivers
2011-03-22pnp: only assign IORESOURCE_DMA if CONFIG_ISA_DMA_API is enabledDavid Rientjes
IORESOURCE_DMA cannot be assigned without utilizing the interface provided by CONFIG_ISA_DMA_API, specifically request_dma() and free_dma(). Thus, there's a strict dependency on the config option and limits IORESOURCE_DMA only to architectures that support ISA-style DMA. ia64 is not one of those architectures, so pnp_check_dma() no longer needs to be special-cased for that architecture. pnp_assign_resources() will now return -EINVAL if IORESOURCE_DMA is attempted on such a kernel. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22rtc: add real-time clock driver for NVIDIA TegraAndrew Chew
This is a platform driver that supports the built-in real-time clock on Tegra SOCs. Signed-off-by: Andrew Chew <achew@nvidia.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Jon Mayo <jmayo@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/rtc/rtc-ds1511.c: world-writable sysfs nvram fileVasiliy Kulikov
Don't allow everybogy to write to NVRAM. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Andy Sharp <andy.sharp@onstor.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/rtc/rtc-isl1208.c: add alarm supportRyan Mallon
Add alarm/wakeup support to rtc isl1208 driver Signed-off-by: Ryan Mallon <ryan@bluewatersys.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22rtc: convert DS1374 to dev_pm_opsMark Brown
There is a general move to replace bus-specific PM ops with dev_pm_ops in order to facilitate core improvements. Do this conversion for DS1374. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/mmc/host/omap_hsmmc.c: use resource_size()Chris Ball
Use resource_size(). Signed-off-by: Chris Ball <cjb@laptop.org> Cc: Madhusudhan Chikkature <madhu.cr@ti.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/mmc/host/omap.c: use resource_size()Chris Ball
Signed-off-by: Chris Ball <cjb@laptop.org> Cc: Jarkko Lavinen <jarkko.lavinen@nokia.com> Cc: Tony Lindgren <tony@atomide.com> Cc: <linux-mmc@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22sigma-firmware: loader for Analog Devices' SigmaStudioMike Frysinger
Analog Devices' SigmaStudio can produce firmware blobs for devices with these DSPs embedded (like some audio codecs). Allow these device drivers to easily parse and load them. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22kstrto*: converting strings to integers done (hopefully) rightAlexey Dobriyan
1. simple_strto*() do not contain overflow checks and crufty, libc way to indicate failure. 2. strict_strto*() also do not have overflow checks but the name and comments pretend they do. 3. Both families have only "long long" and "long" variants, but users want strtou8() 4. Both "simple" and "strict" prefixes are wrong: Simple doesn't exactly say what's so simple, strict should not exist because conversion should be strict by default. The solution is to use "k" prefix and add convertors for more types. Enter kstrtoull() kstrtoll() kstrtoul() kstrtol() kstrtouint() kstrtoint() kstrtou64() kstrtos64() kstrtou32() kstrtos32() kstrtou16() kstrtos16() kstrtou8() kstrtos8() Include runtime testsuite (somewhat incomplete) as well. strict_strto*() become deprecated, stubbed to kstrto*() and eventually will be removed altogether. Use kstrto*() in code today! Note: on some archs _kstrtoul() and _kstrtol() are left in tree, even if they'll be unused at runtime. This is temporarily solution, because I don't want to hardcode list of archs where these functions aren't needed. Current solution with sizeof() and __alignof__ at least always works. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/dca/dca-core.c: use list_move() instead of list_del()/list_add() ↵Kirill A. Shutemov
combination Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Maciej Sosnowski <maciej.sosnowski@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/misc/pch_phub.c: add MODULE_DEVICE_TABLEAxel Lin
The device table is required to load modules based on modaliases. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Masayuki Ohtak <masa-korg@dsn.okisemi.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/misc/ep93xx_pwm.c: world-writable sysfs filesVasiliy Kulikov
Don't allow everybody to change device settings. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Acked-by: Hartley Sweeten <hartleys@visionengravers.com> Cc: Matthieu Crapet <mcrapet@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/misc/atmel_tclib.c: fix a memory leakAxel Lin
request_mem_region() will call kzalloc to allocate memory for struct resource. release_resource() unregisters the resource but does not free the allocated memory, thus use release_mem_region() instead to fix the memory leak. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/misc/hmc6352.c: fix wrong return value checking for i2c_master_recv()Axel Lin
i2c_master_recv() returns negative errno, or else the number of bytes read. Thus i2c_master_recv(client, i2c_data, 2) returns 2 instead of 1 in success case. [akpm@linux-foundation.org: make `ret' signed] Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Kalhan Trisal <kalhan.trisal@intel.com> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/misc/apds9802als.c: put the device into runtime suspend after ↵Hong Liu
resume()/probe() is handled Put the device into runtime suspend after resume()/probe() is handled by the PM core and the device core code. No need to manually add them in each single driver. And correct the runtime state in remove(). Signed-off-by: Hong Liu <hong.liu@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22ST SPEAr: PCIE gadget suppportPratyush Anand
This is a configurable gadget. can be configured by configfs interface. Any IP available at PCIE bus can be programmed to be used by host controller.It supoorts both INTX and MSI. By default, the gadget is configured for INTX and SYSRAM1 is mapped to BAR0 with size 0x1000 Signed-off-by: Pratyush Anand <pratyush.anand@st.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Viresh Kumar <viresh.kumar@st.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/misc/bmp085.c: free initmem memoryShubhrajyoti Datta
Free the memory that is used only at init Signed-off-by: Shubhrajyoti Datta <shubhrajyoti@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22bh1780gli: convert to dev pm opsShubhrajyoti Datta
2011-03-22pwm_backlight: add check_fb() hookRobert Morell
In systems with multiple framebuffer devices, one of the devices might be blanked while another is unblanked. In order for the backlight blanking logic to know whether to turn off the backlight for a particular framebuffer's blanking notification, it needs to be able to check if a given framebuffer device corresponds to the backlight. This plumbs the check_fb hook from core backlight through the pwm_backlight helper to allow platform code to plug in a check_fb hook. Signed-off-by: Robert Morell <rmorell@nvidia.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Arun Murthy <arun.murthy@stericsson.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/video/backlight/jornada720_*.c: make needlessly global symbols staticAxel Lin
The following symbols are needlessly defined global: jornada_bl_init, jornada_bl_exit, jornada_lcd_init, jornada_lcd_exit. Make them static. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Kristoffer Ericson <kristoffer.ericson@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22backlight: apple_bl depends on ACPIRandy Dunlap
apple_bl uses ACPI interfaces (data & code), so it should depend on ACPI. drivers/video/backlight/apple_bl.c:142: warning: 'struct acpi_device' declared inside parameter list drivers/video/backlight/apple_bl.c:142: warning: its scope is only this definition or declaration, which is probably not what you want drivers/video/backlight/apple_bl.c:201: warning: 'struct acpi_device' declared inside parameter list drivers/video/backlight/apple_bl.c:215: error: variable 'apple_bl_driver' has initializer but incomplete type drivers/video/backlight/apple_bl.c:216: error: unknown field 'name' specified in initializer ... Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mbp_nvidia_bl: rename to apple_blMatthew Garrett
It works on hardware other than Macbook Pros, and it works on GPUs other than Nvidia. It should even work on iMacs, so change the name to match reality more precisely and include an alias so existing users don't get confused. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Cc: Mourad De Clerck <mourad@aquazul.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mbp_nvidia_bl: check that the backlight control functionsMatthew Garrett
The SMI-based backlight control functionality may fail to work if the system is running under EFI rather than BIOS. Check that the hardware responds as expected, and exit if it doesn't. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Cc: Mourad De Clerck <mourad@aquazul.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22mbp_nvidia_bl: remove DMI dependencyMatthew Garrett
This driver only has to deal with two different classes of hardware, but right now it needs new DMI entries for every new machine. It turns out that there's an ACPI device that uniquely identifies Apples with backlights, so this patch reworks the driver into an ACPI one, identifies the hardware by checking the PCI vendor of the root bridge and strips out all the DMI code. It also changes the config text to clarify that it works on devices other than Macbook Pros and GPUs other than nvidia. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Richard Purdie <richard.purdie@linuxfoundation.org> Cc: Mourad De Clerck <mourad@aquazul.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22acpi: tie ACPI backlight devices to PCI devices if possibleMatthew Garrett
Dual-GPU machines may provide more than one ACPI backlight interface. Tie the backlight device to the GPU in order to allow userspace to identify the correct interface. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22nouveau: change the backlight parent device to the connector, not the PCI devMatthew Garrett
We may eventually end up with per-connector backlights, especially with ddcci devices. Make sure that the parent node for the backlight device is the connector rather than the PCI device. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Cc: Alex Deucher <alexdeucher@gmail.com> Acked-by: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22radeon: expose backlight class device for legacy LVDS encoderMichel Dänzer
Allows e.g. power management daemons to control the backlight level. Inspired by the corresponding code in radeonfb. [mjg@redhat.com: updated to add backlight type and make the connector the parent device] Signed-off-by: Michel Dänzer <michel@daenzer.net> Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Acked-by: Alex Deucher <alexdeucher@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Tested-by: Sedat Dilek <sedat.dilek@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22backlight: add backlight typeMatthew Garrett
There may be multiple ways of controlling the backlight on a given machine. Allow drivers to expose the type of interface they are providing, making it possible for userspace to make appropriate policy decisions. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/leds/leds-lp5523.c: world-writable engine* sysfs filesVasiliy Kulikov
Don't allow everybody to change LED settings. Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22drivers/leds/leds-lp5521.c: world-writable sysfs engine* filesVasiliy Kulikov
2011-03-22drivers/vidfeo/backlight: ld9040 amoled driver supportDonghwa Lee
Add a ld9040 amoled panel driver. Signed-off-by: Donghwa Lee <dh09.lee@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Inki Dae <inki.dae@samsung.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22leds: make *struct gpio_led_platform_data.leds constUwe Kleine-König
And fix a typo. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22leds: add driver for LM3530 ALSShreshtha Kumar Sahu
Simple backlight driver for National Semiconductor LM3530. Presently only manual mode is supported, PWM and ALS support to be added. Signed-off-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com> Cc: Linus Walleij <linus.walleij@stericsson.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22leds: convert bd2802 driver to dev_pm_opsMark Brown
There is a move to deprecate bus-specific PM operations and move to using dev_pm_ops instead in order to reduce the amount of boilerplate code in buses and facilitiate updates to the PM core. Do this move for the bs2802 driver. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Kim Kyuwon <q1.kim@samsung.com> Cc: Kim Kyuwon <chammoru@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-clientLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: use watch/notify for changes in rbd header libceph: add lingering request and watch/notify event framework rbd: update email address in Documentation ceph: rename dentry_release -> d_release, fix comment ceph: add request to the tail of unsafe write list ceph: remove request from unsafe list if it is canceled/timed out ceph: move readahead default to fs/ceph from libceph ceph: add ino32 mount option ceph: update common header files ceph: remove debugfs debug cruft libceph: fix osd request queuing on osdmap updates ceph: preserve I_COMPLETE across rename libceph: Fix base64-decoding when input ends in newline.
2011-03-22tty: stop using "delayed_work" in the tty layerLinus Torvalds
Using delayed-work for tty flip buffers ends up causing us to wait for the next tick to complete some actions. That's usually not all that noticeable, but for certain latency-critical workloads it ends up being totally unacceptable. As an extreme case of this, passing a token back-and-forth over a pty will take two ticks per iteration, so even just a thousand iterations will take 8 seconds assuming a common 250Hz configuration. Avoiding the whole delayed work issue brings that ping-pong test-case down to 0.009s on my machine. In more practical terms, this latency has been a performance problem for things like dive computer simulators (simulating the serial interface using the ptys) and for other environments (Alan mentions a CP/M emulator). Reported-by: Jef Driesen <jefdriesen@telenet.be> Acked-by: Greg KH <gregkh@suse.de> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22rbd: use watch/notify for changes in rbd headerYehuda Sadeh
Send notifications when we change the rbd header (e.g. create a snapshot) and wait for such notifications. This allows synchronizing the snapshot creation between different rbd clients/rools. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-22Merge branch 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linuxLinus Torvalds
* 'for-linus/2639/i2c-2' of git://git.fluff.org/bjdooks/linux: i2c-pxa2xx: Don't clear isr bits too early i2c-pxa2xx: Fix register offsets i2c-pxa2xx: pass of_node from platform driver to adapter and publish i2c-pxa2xx: check timeout correctly i2c-pxa2xx: add support for shared IRQ handler i2c-pxa2xx: Add PCI support for PXA I2C controller ARM: pxa2xx: reorganize I2C files i2c-pxa2xx: use dynamic register layout i2c-mxs: set controller to pio queue mode after reset i2c-eg20t: support new device OKI SEMICONDUCTOR ML7213 IOH i2c/busses: Add support for Diolan U2C-12 USB-I2C adapter
2011-03-22sd: Fail discard requests when logical block provisioning has been disabledMartin K. Petersen
Ensure that we kill discard requests after logical block provisioning has been disabled in sysfs. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Reviewed-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (33 commits) IPVS: Use global mutex in ip_vs_app.c ipvs: fix a typo in __ip_vs_control_init() veth: Fix the byte counters net ipv6: Fix duplicate /proc/sys/net/ipv6/neigh directory entries. macvlan: Fix use after free of struct macvlan_port. net: fix incorrect spelling in drop monitor protocol can: c_can: Do basic c_can configuration _before_ enabling the interrupts net/appletalk: fix atalk_release use after free ipx: fix ipx_release() snmp: SNMP_UPD_PO_STATS_BH() always called from softirq l2tp: fix possible oops on l2tp_eth module unload xfrm: Fix initialize repl field of struct xfrm_state netfilter: ipt_CLUSTERIP: fix buffer overflow netfilter: xtables: fix reentrancy netfilter: ipset: fix checking the type revision at create command netfilter: ipset: fix address ranges at hash:*port* types niu: Rename NIU parent platform device name to fix conflict. r8169: fix a bug in rtl8169_init_phy() bonding: fix a typo in a comment ftmac100: use resource_size() ...
2011-03-21veth: Fix the byte countersEric W. Biederman
Commit 44540960 "veth: move loopback logic to common location" introduced a bug in the packet counters. I don't understand why that happened as it is not explained in the comments and the mut check in dev_forward_skb retains the assumption that skb->len is the total length of the packet. I just measured this emperically by setting up a veth pair between two noop network namespaces setting and attempting a telnet connection between the two. I saw three packets in each direction and the byte counters were exactly 14*3 = 42 bytes high in each direction. I got the actual packet lengths with tcpdump. So remove the extra ETH_HLEN from the veth byte count totals. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21macvlan: Fix use after free of struct macvlan_port.Eric W. Biederman
When the macvlan driver was extended to call unregisgter_netdevice_queue in 23289a37e2b127dfc4de1313fba15bb4c9f0cd5b, a use after free of struct macvlan_port was introduced. The code in dellink relied on unregister_netdevice actually unregistering the net device so it would be safe to free macvlan_port. Since unregister_netdevice_queue can just queue up the unregister instead of performing the unregiser immediately we free the macvlan_port too soon and then the code in macvlan_stop removes the macaddress for the set of macaddress to listen for and uses memory that has already been freed. To fix this add a reference count to track when it is safe to free the macvlan_port and move the call of macvlan_port_destroy into macvlan_uninit which is guaranteed to be called after the final macvlan_port_close. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21can: c_can: Do basic c_can configuration _before_ enabling the interruptsJan Altenberg
I ran into some trouble while testing the SocketCAN driver for the BOSCH C_CAN controller. The interface is not correctly initialized, if I put some CAN traffic on the line, _while_ the interface is being started (which means: the interface doesn't come up correcty, if there's some RX traffic while doing 'ifconfig can0 up'). The current implementation enables the controller interrupts _before_ doing the basic c_can configuration. I think, this should be done the other way round. The patch below fixes things for me. Signed-off-by: Jan Altenberg <jan@linutronix.de> Acked-by: Kurt Van Dijck <kurt.van.dijck@eia.be> Acked-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21i2c-pxa2xx: Don't clear isr bits too earlyVasily Khoruzhick
isr is passed later into i2c_pxa_irq_txempty and i2c_pxa_irq_rxfull and they may use some other bits than irq sources. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ben Dooks <ben-linux@fluff.org>
2011-03-21Merge branches 'for-2639/i2c/i2c-ce4100-v6', 'for-2639/i2c/i2c-eg20t-v3' and ↵Ben Dooks
'for-2639/i2c/i2c-imx' into for-linus/2639/i2c-2
2011-03-21Reduce sequential pointer derefs in scsi_error.c and reduce size as wellJesper Juhl
This patch reduces the number of sequential pointer derefs in drivers/scsi/scsi_error.c This has been submitted a number of times over a couple of years. I believe this version adresses all comments it has gathered over time. Please apply or reject with a reason. The benefits are: - makes the code easier to read. Lots of sequential derefs of the same pointers is not easy on the eye. - theoretically at least, just dereferencing the pointers once can allow the compiler to generally slightly faster code, so in theory this could also be a micro speed optimization. - reduces size of object file (tiny effect: on x86-64, in at least one configuration, the text size decreased from 9439 bytes to 9400) - removes some pointless (mostly trailing) whitespace. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21matroxfb: remove incorrect Matrox G200eV supportGary Hade
Remove incorrect Matrox G200eV support that was previously added by commit e3a1938805d2e81b27d3d348788644f3bad004f2 A serious issue with the incorrect G200eV support that reproduces on the Matrox G200eV equipped IBM x3650 M2 is the total lack of text (login banner, login prompt, etc) on the console when X is not running and total lack of text on all of the virtual consoles after X is started. Any concerns that the incorrect code (upstream since October 2008) has been successfully used on non-IBM G200eV equipped system(s) appear to be unwarranted. In addition to the serious/non-intermittent nature of issues that have been spotted on IBM systems, complete removal of the incorrect code is clearly supported by the following Matrox (Yannick Heneault) provided input: "It impossible that this patch should have work on a system. The patch only declare the G200eV as a regular G200 which is not case. Many registers are different, including at least the PLL programming sequence. If the G200eV is programmed like a regular G200, it will not display anything." v1 - Initial patch that removed the incorrect code for _all_ G200eV equipped systems. v2 - Darrick Wong provided patch that blacklisted the incorrect code on G200eV equipped IBM systems leaving it enabled on all G200eV equipped non-IBM systems. v3 - Same code changes included with v1 plus additional justification for complete removal of the incorrect code. Signed-off-by: Gary Hade <garyhade@us.ibm.com> Cc: Darrick J. Wong <djwong@us.ibm.com> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Petr Vandrovec <vandrove@vc.cvut.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Yannick Heneault <yannick_heneault@matrox.com> Cc: Christian Toutant <ctoutant@matrox.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (ads1015) Make gain and datarate configurable hwmon: (ads1015) Drop dynamic attribute group hwmon: Add support for Texas Instruments ADS1015 hwmon: New driver for SMSC SCH5627 hwmon: (abituguru*) Update my email address hwmon: (lm75) Speed up detection hwmon: (lm75) Add detection of the National Semiconductor LM75A hp_accel: Fix driver name Move lis3lv02d drivers to drivers/misc Move hp_accel to drivers/platform/x86 Let Kconfig handle lis3lv02d dependencies hwmon: (sht15) Fix integer overflow in humidity calculation hwmon: (sht15) Spelling fix hwmon: (w83795) Document pin mapping
2011-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: core: ignore link-active bit of new nodes, fix device recognition firewire: sbp2: revert obsolete 'fix stall with "Unsolicited response"' firewire: core: increase default SPLIT_TIMEOUT value firewire: ohci: Misleading kfree in ohci.c::pci_probe/remove firewire: ohci: omit IntEvent.busReset check rom AT queueing firewire: ohci: prevent starting of iso contexts with empty queue firewire: ohci: prevent iso completion callbacks after context stop firewire: core: rename some variables firewire: nosy: should work on Power Mac G4 PCI too firewire: core: fix card->reset_jiffies overflow firewire: cdev: remove unneeded reference firewire: cdev: always wait for outbound transactions to complete firewire: cdev: remove unneeded idr_find() from complete_transaction() firewire: ohci: log dead DMA contexts
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6: [PARISC] Convert to new irq_chip functions [PARISC] fix per-cpu flag problem in the cpu affinity checkers [PARISC] fix vmap flush/invalidate eliminate special FLUSH flag from page table parisc: flush pages through tmpalias space
