commit 31574d321c70f6d3b40fe98f9b2eafd9a903fef9 upstream.
The current code passes the address of tpm_chip as the argument to
dev_get_drvdata() without prior NULL check in
tpm_ibmvtpm_get_desired_dma. This resulted an oops during kernel
boot when vTPM is enabled in Power partition configured in active
memory sharing mode.
The vio_driver's get_desired_dma() is called before the probe(), which
for vtpm is tpm_ibmvtpm_probe, and it's this latter function that
initializes the driver and set data. Attempting to get data before
the probe() caused the problem.
This patch adds a NULL check to the tpm_ibmvtpm_get_desired_dma.
fixes: 9e0d39d8a6a0 ("tpm: Remove useless priv field in struct tpm_vendor_specific")
Signed-off-by: Hon Ching(Vicky) Lo <honclo@linux.vnet.ibm.com>
Reviewed-by: Jarkko Sakkine <jarkko.sakkinen@linux.intel.com>
Signed-off-by: Jarkko Sakkinen <jarkko.sakkinen@linux.intel.com>
commit 8ae584d1951f241efd45499f8774fd7066f22823 upstream.
Axius clock error path returns without disabling clock and suspend clock.
Fix it to disable them before returning error.
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit 990758c53eafe5a220a780ed12e7b4d51b3df032 upstream.
'cdev->os_desc_req' has been allocated with 'usb_ep_alloc_request()' so
'usb_ep_free_request()' should be used to free it.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
commit 948588e25b8af5e66962ed3f53e1cae1656fa5af upstream.
Starting from MPU6500, accelerometer dlpf is set in a separate
register named ACCEL_CONFIG_2.
Add this new register in the map and set it for the corresponding
chips.
Signed-off-by: Jean-Baptiste Maneyrol <jmaneyrol@invensense.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit f16443a034c7aa359ddf6f0f9bc40d01ca31faea upstream.
Using the syzkaller kernel fuzzer, Andrey Konovalov generated the
following error in gadgetfs:
> BUG: KASAN: use-after-free in __lock_acquire+0x3069/0x3690
> kernel/locking/lockdep.c:3246
> Read of size 8 at addr ffff88003a2bdaf8 by task kworker/3:1/903
> CPU: 3 PID: 903 Comm: kworker/3:1 Not tainted 4.12.0-rc4+ #35
> Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
> Workqueue: usb_hub_wq hub_event
> Call Trace:
> __dump_stack lib/dump_stack.c:16 [inline]
> dump_stack+0x292/0x395 lib/dump_stack.c:52
> print_address_description+0x78/0x280 mm/kasan/report.c:252
> kasan_report_error mm/kasan/report.c:351 [inline]
> kasan_report+0x230/0x340 mm/kasan/report.c:408
> __asan_report_load8_noabort+0x19/0x20 mm/kasan/report.c:429
> __lock_acquire+0x3069/0x3690 kernel/locking/lockdep.c:3246
> lock_acquire+0x22d/0x560 kernel/locking/lockdep.c:3855
> __raw_spin_lock include/linux/spinlock_api_smp.h:142 [inline]
> _raw_spin_lock+0x2f/0x40 kernel/locking/spinlock.c:151
> spin_lock include/linux/spinlock.h:299 [inline]
> gadgetfs_suspend+0x89/0x130 drivers/usb/gadget/legacy/inode.c:1682
> set_link_state+0x88e/0xae0 drivers/usb/gadget/udc/dummy_hcd.c:455
> dummy_hub_control+0xd7e/0x1fb0 drivers/usb/gadget/udc/dummy_hcd.c:2074
> rh_call_control drivers/usb/core/hcd.c:689 [inline]
> rh_urb_enqueue drivers/usb/core/hcd.c:846 [inline]
> usb_hcd_submit_urb+0x92f/0x20b0 drivers/usb/core/hcd.c:1650
> usb_submit_urb+0x8b2/0x12c0 drivers/usb/core/urb.c:542
> usb_start_wait_urb+0x148/0x5b0 drivers/usb/core/message.c:56
> usb_internal_control_msg drivers/usb/core/message.c:100 [inline]
> usb_control_msg+0x341/0x4d0 drivers/usb/core/message.c:151
> usb_clear_port_feature+0x74/0xa0 drivers/usb/core/hub.c:412
> hub_port_disable+0x123/0x510 drivers/usb/core/hub.c:4177
> hub_port_init+0x1ed/0x2940 drivers/usb/core/hub.c:4648
> hub_port_connect drivers/usb/core/hub.c:4826 [inline]
> hub_port_connect_change drivers/usb/core/hub.c:4999 [inline]
> port_event drivers/usb/core/hub.c:5105 [inline]
> hub_event+0x1ae1/0x3d40 drivers/usb/core/hub.c:5185
> process_one_work+0xc08/0x1bd0 kernel/workqueue.c:2097
> process_scheduled_works kernel/workqueue.c:2157 [inline]
> worker_thread+0xb2b/0x1860 kernel/workqueue.c:2233
> kthread+0x363/0x440 kernel/kthread.c:231
> ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:424
> Allocated by task 9958:
> save_stack_trace+0x1b/0x20 arch/x86/kernel/stacktrace.c:59
> save_stack+0x43/0xd0 mm/kasan/kasan.c:513
> set_track mm/kasan/kasan.c:525 [inline]
> kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:617
> kmem_cache_alloc_trace+0x87/0x280 mm/slub.c:2745
> kmalloc include/linux/slab.h:492 [inline]
> kzalloc include/linux/slab.h:665 [inline]
> dev_new drivers/usb/gadget/legacy/inode.c:170 [inline]
> gadgetfs_fill_super+0x24f/0x540 drivers/usb/gadget/legacy/inode.c:1993
> mount_single+0xf6/0x160 fs/super.c:1192
> gadgetfs_mount+0x31/0x40 drivers/usb/gadget/legacy/inode.c:2019
> mount_fs+0x9c/0x2d0 fs/super.c:1223
> vfs_kern_mount.part.25+0xcb/0x490 fs/namespace.c:976
> vfs_kern_mount fs/namespace.c:2509 [inline]
> do_new_mount fs/namespace.c:2512 [inline]
> do_mount+0x41b/0x2d90 fs/namespace.c:2834
> SYSC_mount fs/namespace.c:3050 [inline]
> SyS_mount+0xb0/0x120 fs/namespace.c:3027
> entry_SYSCALL_64_fastpath+0x1f/0xbe
> Freed by task 9960:
> kasan_slab_free+0x72/0xc0 mm/kasan/kasan.c:590
> slab_free_hook mm/slub.c:1357 [inline]
> slab_free_freelist_hook mm/slub.c:1379 [inline]
> slab_free mm/slub.c:2961 [inline]
> kfree+0xed/0x2b0 mm/slub.c:3882
> put_dev+0x124/0x160 drivers/usb/gadget/legacy/inode.c:163
> gadgetfs_kill_sb+0x33/0x60 drivers/usb/gadget/legacy/inode.c:2027
> deactivate_locked_super+0x8d/0xd0 fs/super.c:309
> deactivate_super+0x21e/0x310 fs/super.c:340
> cleanup_mnt+0xb7/0x150 fs/namespace.c:1112
> __cleanup_mnt+0x1b/0x20 fs/namespace.c:1119
> task_work_run+0x1a0/0x280 kernel/task_work.c:116
> exit_task_work include/linux/task_work.h:21 [inline]
> do_exit+0x18a8/0x2820 kernel/exit.c:878
> do_group_exit+0x14e/0x420 kernel/exit.c:982
> get_signal+0x784/0x1780 kernel/signal.c:2318
> do_signal+0xd7/0x2130 arch/x86/kernel/signal.c:808
> exit_to_usermode_loop+0x1ac/0x240 arch/x86/entry/common.c:157
> prepare_exit_to_usermode arch/x86/entry/common.c:194 [inline]
> syscall_return_slowpath+0x3ba/0x410 arch/x86/entry/common.c:263
> entry_SYSCALL_64_fastpath+0xbc/0xbe
> The buggy address belongs to the object at ffff88003a2bdae0
> which belongs to the cache kmalloc-1024 of size 1024
> The buggy address is located 24 bytes inside of
> 1024-byte region [ffff88003a2bdae0, ffff88003a2bdee0)
> The buggy address belongs to the page:
> page:ffffea0000e8ae00 count:1 mapcount:0 mapping: (null)
> index:0x0 compound_mapcount: 0
> flags: 0x100000000008100(slab|head)
> raw: 0100000000008100 0000000000000000 0000000000000000 0000000100170017
> raw: ffffea0000ed3020 ffffea0000f5f820 ffff88003e80efc0 0000000000000000
> page dumped because: kasan: bad access detected
> Memory state around the buggy address:
> ffff88003a2bd980: fb fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
> ffff88003a2bda00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
> >ffff88003a2bda80: fc fc fc fc fc fc fc fc fc fc fc fc fb fb fb fb
> ffff88003a2bdb00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
> ffff88003a2bdb80: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
What this means is that the gadgetfs_suspend() routine was trying to
access dev->lock after it had been deallocated. The root cause is a
race in the dummy_hcd driver; the dummy_udc_stop() routine can race
with the rest of the driver because it contains no locking. And even
when proper locking is added, it can still race with the
set_link_state() function because that function incorrectly drops the
private spinlock before invoking any gadget driver callbacks.
The result of this race, as seen above, is that set_link_state() can
invoke a callback in gadgetfs even after gadgetfs has been unbound
from dummy_hcd's UDC and its private data structures have been
deallocated.
include/linux/usb/gadget.h documents that the ->reset, ->disconnect,
->suspend, and ->resume callbacks may be invoked in interrupt context.
In general this is necessary, to prevent races with gadget driver
removal. This patch fixes dummy_hcd to retain the spinlock across
these calls, and it adds a spinlock acquisition to dummy_udc_stop() to
prevent the race.
The net2280 driver makes the same mistake of dropping the private
spinlock for its ->disconnect and ->reset callback invocations. The
patch fixes it too.
Lastly, since gadgetfs_suspend() may be invoked in interrupt context,
it cannot assume that interrupts are enabled when it runs. It must
use spin_lock_irqsave() instead of spin_lock_irq(). The patch fixes
that bug as well.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: Andrey Konovalov <andreyknvl@google.com>
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit f50b878fed33e360d01dcdc31a8eeb1815d033d5 upstream.
A NULL-pointer dereference bug in gadgetfs was uncovered by syzkaller:
> kasan: GPF could be caused by NULL-ptr deref or user memory access
> general protection fault: 0000 [#1] SMP KASAN
> Dumping ftrace buffer:
> (ftrace buffer empty)
> Modules linked in:
> CPU: 2 PID: 4820 Comm: syz-executor0 Not tainted 4.12.0-rc4+ #5
> task: ffff880039542dc0 task.stack: ffff88003bdd0000
> RIP: 0010:__list_del_entry_valid+0x7e/0x170 lib/list_debug.c:51
> RSP: 0018:ffff88003bdd6e50 EFLAGS: 00010246
> RAX: dffffc0000000000 RBX: 0000000000000000 RCX: 0000000000010000
> RDX: 0000000000000000 RSI: ffffffff86504948 RDI: ffffffff86504950
> RBP: ffff88003bdd6e68 R08: ffff880039542dc0 R09: ffffffff8778ce00
> R10: ffff88003bdd6e68 R11: dffffc0000000000 R12: 0000000000000000
> R13: dffffc0000000000 R14: 1ffff100077badd2 R15: ffffffff864d2e40
> FS: 0000000000000000(0000) GS:ffff88006dc00000(0000) knlGS:0000000000000000
> CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
> CR2: 000000002014aff9 CR3: 0000000006022000 CR4: 00000000000006e0
> Call Trace:
> __list_del_entry include/linux/list.h:116 [inline]
> list_del include/linux/list.h:124 [inline]
> usb_gadget_unregister_driver+0x166/0x4c0 drivers/usb/gadget/udc/core.c:1387
> dev_release+0x80/0x160 drivers/usb/gadget/legacy/inode.c:1187
> __fput+0x332/0x7f0 fs/file_table.c:209
> ____fput+0x15/0x20 fs/file_table.c:245
> task_work_run+0x19b/0x270 kernel/task_work.c:116
> do_exit+0x18a3/0x2820 kernel/exit.c:878
> do_group_exit+0x149/0x420 kernel/exit.c:982
> get_signal+0x77f/0x1780 kernel/signal.c:2318
> do_signal+0xd2/0x2130 arch/x86/kernel/signal.c:808
> exit_to_usermode_loop+0x1a7/0x240 arch/x86/entry/common.c:157
> RIP: 0033:0x4461f9
> RSP: 002b:00007fdac2b1ecf8 EFLAGS: 00000246 ORIG_RAX: 00000000000000ca
> RAX: fffffffffffffe00 RBX: 00000000007080c8 RCX: 00000000004461f9
> RDX: 0000000000000000 RSI: 0000000000000000 RDI: 00000000007080c8
> RBP: 00000000007080a8 R08: 0000000000000000 R09: 0000000000000000
> R10: 0000000000000000 R11: 0000000000000246 R12: 0000000000000000
> R13: 0000000000000000 R14: 00007fdac2b1f9c0 R15: 00007fdac2b1f700
> Code: 00 00 00 00 ad de 49 39 c4 74 6a 48 b8 00 02 00 00 00 00 ad de
> 48 89 da 48 39 c3 74 74 48 c1 ea 03 48 b8 00 00 00 00 00 fc ff df <80>
> 3c 02 00 0f 85 92 00 00 00 48 8b 13 48 39 f2 75 66 49 8d 7c
> RIP: __list_del_entry_valid+0x7e/0x170 lib/list_debug.c:51 RSP: ffff88003bdd6e50
> ---[ end trace 30e94b1eec4831c8 ]---
> Kernel panic - not syncing: Fatal exception
The bug was caused by dev_release() failing to turn off its
gadget_registered flag after unregistering the gadget driver. As a
result, when a later user closed the device file before writing a
valid set of descriptors, dev_release() thought the gadget had been
registered and tried to unregister it, even though it had not been.
This led to the NULL pointer dereference.
The fix is simple: turn off the flag when the gadget is unregistered.
commit d2f48f05cd2a2a0a708fbfa45f1a00a87660d937 upstream.
When plugging an USB webcam I see the following message:
[106385.615559] xhci_hcd 0000:04:00.0: WARN Successful completion on short TX: needs XHCI_TRUST_TX_LENGTH quirk?
[106390.583860] handle_tx_event: 913 callbacks suppressed
With this patch applied, I get no more printing of this message.
Signed-off-by: Corentin Labbe <clabbe.montjoie@gmail.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit b72eb8435b25be3a1880264cf32ac91e626ba5ba upstream.
xHCI host controllers can have both USB 3.1 and 3.0 extended speed
protocol lists. If the USB3.1 speed is parsed first and 3.0 second then
the minor revision supported will be overwritten by the 3.0 speeds and
the USB3 roothub will only show support for USB 3.0 speeds.
This was the case with a xhci controller with the supported protocol
capability listed below.
In xhci-mem.c, the USB 3.1 speed is parsed first, the min_rev of usb3_rhub
is set as 0x10. And then USB 3.0 is parsed. However, the min_rev of
usb3_rhub will be changed to 0x00. If USB 3.1 device is connected behind
this host controller, the speed of USB 3.1 device just reports 5G speed
using lsusb.
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 01 08 00 00 00 00 00 40 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 02 08 10 03 55 53 42 20 01 02 00 00 00 00 00 00 //USB 3.1
30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 02 08 00 03 55 53 42 20 03 06 00 00 00 00 00 00 //USB 3.0
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 08 00 02 55 53 42 20 09 0E 19 00 00 00 00 00 //USB 2.0
70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
This patch fixes the issue by only owerwriting the minor revision if
it is higher than the existing one.
[reword commit message -Mathias]
Signed-off-by: YD Tseng <yd_tseng@asmedia.com.tw>
commit 8128a31eaadbcdfa37774bbd28f3f00bac69996a upstream.
c2port_device_register() never returns NULL, it uses error pointers.
Link: http://lkml.kernel.org/r/20170412083321.GC3250@mwanda
Fixes: 65131cd52b9e ("c2port: add c2port support for Eurotech Duramar 2150")
Acked-by: Rodolfo Giometti <giometti@linux.it>
commit 816c9311f1144a03da1fdc4feb2f6b0d3299fca0 upstream.
This function only has one caller. Freeing "vdev" here leads to a use
after free bug. There are several other error paths in this function
but this is the only one which frees "vdev". It looks like the kfree()
can be safely removed.
Fixes: 61e9c905df78 ("misc: mic: Enable VOP host side functionality")
commit 1427228d5869f5804b03d47acfa4a88122572a78 upstream.
This fixes the below crash when ath10k probe firmware fails, NAPI polling tries
to access a rx ring resource which was never allocated. An easy way to
reproduce this is easy to remove all the firmware files, load ath10k modules
and ath10k will crash when calling 'rmmod ath10k_pci'. The fix is to call
napi_enable() from ath10k_pci_hif_start() so that it matches with
napi_disable() being called from ath10k_pci_hif_stop().
Big thanks to Mohammed Shafi Shajakhan who debugged this and provided first
version of the fix. In this patch I just fix the actual problem in pci.c
instead of having a workaround in core.c.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: __ath10k_htt_rx_ring_fill_n+0x19/0x230 [ath10k_core]
Call Trace:
[<ffffffffa113ec62>] ath10k_htt_rx_msdu_buff_replenish+0x42/0x90
[ath10k_core]
[<ffffffffa113f393>] ath10k_htt_txrx_compl_task+0x433/0x17d0
[ath10k_core]
[<ffffffff8114406d>] ? __wake_up_common+0x4d/0x80
[<ffffffff811349ec>] ? cpu_load_update+0xdc/0x150
[<ffffffffa119301d>] ? ath10k_pci_read32+0xd/0x10 [ath10k_pci]
[<ffffffffa1195b17>] ath10k_pci_napi_poll+0x47/0x110 [ath10k_pci]
[<ffffffff817863af>] net_rx_action+0x20f/0x370
Reported-by: Ben Greear <greearb@candelatech.com>
Fixes: 3c97f5de1f28 ("ath10k: implement NAPI support")
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
commit dd14a3e9b92ac6f0918054f9e3477438760a4fa6 upstream.
The timeout for BULK packets was 300ms which is a long time if other
endpoints or devices are waiting for their turn. Changing it to 50ms
greatly increased the overall performance for multi-endpoint devices.
Fixes: 5d3043586db4 ("usb: r8a66597-hcd: host controller driver for R8A6659")
Signed-off-by: Chris Brandt <chris.brandt@renesas.com>
commit 1f873d857b6c2fefb4dada952674aa01bcfb92bd upstream.
If multiple endpoints on a single device have pending IN URBs and one
endpoint times out due to NAKs (perfectly legal), select a different
endpoint URB to try.
The existing code only checked to see another device address has pending
URBs and ignores other IN endpoints on the current device address. This
leads to endpoints never getting serviced if one endpoint is using NAK as
a flow control method.
commit d81182ce30dbd497a1e7047d7fda2af040347790 upstream.
Flag the first and only port as removable while also leaving the
remaining bits (including the reserved bit zero) unset in accordance
with the specifications:
"Within a byte, if no port exists for a given location, the bit
field representing the port characteristics shall be 0."
Also add a comment marking the legacy PortPwrCtrlMask field.
Fixes: 1cd8fd2887e1 ("usb: gadget: dummy_hcd: add SuperSpeed support")
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: Tatyana Brokhman <tlinder@codeaurora.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 6830733d53a4517588e56227b9c8538633f0c496 upstream.
The driver uses a relatively large data structure on the stack, which
showed up on my radar as we get a warning with the "latent entropy"
GCC plugin:
drivers/media/usb/pvrusb2/pvrusb2-eeprom.c:153:1: error: the frame size of 1376 bytes is larger than 1152 bytes [-Werror=frame-larger-than=]
The warning is usually hidden as we raise the warning limit to 2048
when the plugin is enabled, but I'd like to lower that again in the
future, and making this function smaller helps to do that without
build regressions.
Further analysis shows that putting an 'i2c_client' structure on
the stack is not really supported, as the embedded 'struct device'
is not initialized here, and we are only saved by the fact that
the function that is called here does not use the pointer at all.
Fixes: d855497edbfb ("V4L/DVB (4228a): pvrusb2 to kernel 2.6.18")
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit ec963b412a54aac8e527708ecad06a6988a86fb4 upstream.
Fix up the root-hub descriptor to accommodate the variable-length
DeviceRemovable and PortPwrCtrlMask fields, while marking all ports as
removable (and leaving the reserved bit zero unset).
Also add a build-time constraint on VHCI_HC_PORTS which must never be
greater than USB_MAXCHILDREN (but this was only enforced through a
KConfig constant).
This specifically fixes the descriptor layout whenever VHCI_HC_PORTS is
greater than seven (default is 8).
Fixes: 04679b3489e0 ("Staging: USB/IP: add client driver")
Cc: Takahiro Hirofuchi <hirofuchi@users.sourceforge.net>
Cc: Valentina Manea <valentina.manea.m@gmail.com>
Acked-by: Shuah Khan <shuahkh@osg.samsung.com>
commit 1a744d2eb76aaafb997fda004ae3ae62a1538f85 upstream.
Free memory allocated for address0_mutex if allocation of bandwidth_mutex
failed.
Fixes: feb26ac31a2a ("usb: core: hub: hub_port_init lock controller instead of bus")
Signed-off-by: Anton Bondarenko <anton.bondarenko.sama@gmail.com>
commit 93491ced3c87c94b12220dbac0527e1356702179 upstream.
Add define for the maximum number of ports on a SuperSpeed hub as per
USB 3.1 spec Table 10-5, and use it when verifying the retrieved hub
descriptor.
This specifically avoids benign attempts to update the DeviceRemovable
mask for non-existing ports (should we get that far).
Fixes: dbe79bbe9dcb ("USB 3.0 Hub Changes")
commit 940f538a100c84c6e72813e4ac88bd1753a86945 upstream.
This controller disallows to change the PIPE until reading/writing
a packet finishes. However. the previous code is not enough to hold
the lock in some functions. So, this patch fixes it.
Fixes: 746bfe63bba3 ("usb: gadget: renesas_usb3: add support for Renesas USB3.0 peripheral controller")
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
commit 067d6fdc558d2c43f0bfdc7af99630dd5eb08dc5 upstream.
This patch fixes an issue that this driver is possible to cause
deadlock by double-spinclocked in renesas_usb3_stop_controller().
So, this patch removes spinlock API calling in renesas_usb3_stop().
(In other words, the previous code had a redundant lock.)
commit cdc876877ebc3f0677b267756d4564e2a429e730 upstream.
This patch fixes an issue that this driver is possible to access
the registers before pm_runtime_get_sync() if a gadget driver is
installed first. After that, oops happens on R-Car Gen3 environment.
To avoid it, this patch changes the pm_runtime call timing from
probe/remove to udc_start/udc_stop.
commit de8d6e02efbdb259c67832ccf027d7ace9b91d5d upstream.
The logic was broken as it failed to update the response length for
architectures with PAGE_SIZE larger than 4kB. As a result further
extension of the ucontext response struct would fail.
Fixes: d69e3bcf7976 ('IB/mlx5: Mmap the HCA's core clock register to user-space')
Signed-off-by: Eli Cohen <eli@mellanox.com>
Reviewed-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Saeed Mahameed <saeedm@mellanox.com>
commit 5ba5b437efaa7a502eec393c045d3bf90c92c4e9 upstream.
We should be allocating enough information for a tiadc_device struct
which is about 400 bytes but instead we allocate enough for a second
iio_dev struct which is over 2000 bytes.
Fixes: fea89e2dfcea ("iio: adc: ti_am335x_adc: use variable names for sizeof() operator")
commit 6272c0de13abf1480f701d38288f28a11b4301c4 upstream.
According to the datasheet the RCO must be recalibrated
on every power-on-reset. Also remove mutex locking in the
calibration function since callers other than the probe
function (which doesn't need it) will have a lock.
Fixes: 24ddb0e4bba4 ("iio: Add AS3935 lightning sensor support")
Cc: George McCollister <george.mccollister@gmail.com>
Signed-off-by: Matt Ranostay <matt.ranostay@konsulko.com>
commit 1b211d48abaa0e12e6e6177c0316ff55d11fdfce upstream.
Datasheet of each device (lps331ap, lps25h, lps001wp, lps22hb) says that
the pressure and temperature data is a 2's complement.
I'm sending this the slow way, as negative pressures on these are pretty
unusual and the nature of the fixing of multiple device introduction patches
will make it hard to apply to older kernels - Jonathan.
Fixes: 217494e5b780 ("iio:pressure: Add STMicroelectronics pressures driver")
Fixes: 2f5effcbd097 ("iio: pressure-core: st: Expand and rename LPS331AP's channel descriptor")
Fixes: 7885a8ce6800 ("iio: pressure: st: Add support for new LPS001WP pressure sensor")
Fixes: e039e2f5b4da ("iio:st_pressure:initial lps22hb sensor support")
Signed-off-by: Marcin Niestroj <m.niestroj@grinn-global.com>
commit cf6c77323a96fc40309cc8a4921ef206cccdd961 upstream.
Standard deviation is calculated as the square root of the variance
where variance is the mean of sample_sum and length. Correct the
computation of statP->stddev in accordance to the proper calculation.
Fixes: 3c97c08b5735 ("staging: iio: add TAOS tsl2x7x driver")
Reported-by: Abhiram Balasubramanian <abhiram@cs.utah.edu>
Signed-off-by: Eva Rachel Retuya <eraretuya@gmail.com>
commit 784047eb2d3405a35087af70cba46170c5576b25 upstream.
The "len" could be as low as -14 so we should check for negatives.
Fixes: 9a7fe54ddc3a ("staging: r8188eu: Add source files for new driver - part 1")
commit 8b8a84c54aff4256d592dc18346c65ecf6811b45 upstream.
Commit 16fa3dc75c22 ("mfd: omap-usb-tll: HOST TLL platform driver")
added support for USB TLL, but uses OMAP_TLL_CHANNEL_CONF_ULPINOBITSTUFF
bit the wrong way. The comments in the code are correct, but the inverted
use of OMAP_TLL_CHANNEL_CONF_ULPINOBITSTUFF causes the register to be
enabled instead of disabled unlike what the comments say.
Without this change the Wrigley 3G LTE modem on droid 4 EHCI bus can
be only pinged few times before it stops responding.
Fixes: 16fa3dc75c22 ("mfd: omap-usb-tll: HOST TLL platform driver")
Acked-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit 5f76895e4c712b1b5af450cf344389b8c53ac2c2 upstream.
When changing hardware control flow for a UART with dedicated RTS/CTS
pins, the new AUTORTS state is not immediately reflected in the
hardware, but only when RTS is raised. However, the serial core does
not call .set_mctrl() after .set_termios(), hence AUTORTS may only
become effective when the port is closed, and reopened later.
Note that this problem does not happen when manually using stty to
change CRTSCTS, as AUTORTS will work fine on next open.
To fix this, call .set_mctrl() from .set_termios() when dedicated
RTS/CTS pins are present, to refresh the AUTORTS or RTS state.
This is similar to what other drivers supporting AUTORTS do (e.g.
omap-serial).
Reported-by: Baumann, Christoph (C.) <cbaumann@visteon.com>
Fixes: 33f50ffc253854cf ("serial: sh-sci: Fix support for hardware-assisted RTS/CTS")
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
commit be40597a1bc173bf9dadccdf5388b956f620ae8f upstream.
UARTn_FRAME_PARITY_ODD is 0x0300
UARTn_FRAME_PARITY_EVEN is 0x0200
So if the UART is configured for EVEN parity, it would be reported as ODD.
Fix it by correctly testing if the 2 bits are set.
Fixes: 3afbd89c9639 ("serial/efm32: add new driver")
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
commit ca39b449f6d03e8235969f12f5dd25b8eb4304d6 upstream.
If a CMA allocation failed, the partially constructed BO would be
unreferenced through the normal path, and we might choose to put it in
the BO cache. If we then reused it before it expired from the cache,
the kernel would OOPS.
Signed-off-by: Eric Anholt <eric@anholt.net>
Fixes: c826a6e10644 ("drm/vc4: Add a BO cache.")
Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170301185602.6873-2-eric@anholt.net
commit 014580ffab654bb83256783a2b185cf6c06dffaa upstream.
mtk_hdmi_setup_vendor_specific_infoframe will return before handle
mtk_hdmi_hw_send_info_frame.Because hdmi_vendor_infoframe_pack
returns the number of bytes packed into the binary buffer or
a negative error code on failure.
So correct it.
Fixes: 8f83f26891e1 ("drm/mediatek: Add HDMI support")
Signed-off-by: Nickey Yang <nickey.yang@rock-chips.com>
Signed-off-by: CK Hu <ck.hu@mediatek.com>
commit b3addcf0d1f04f53fcc302577d5a5e964c18531a upstream.
Currently VBUS is turned off while a usb device is detached, and turned
on again by the polling routine. This short period VBUS loss prevents
usb modem to switch mode.
VBUS should be constantly on for host-only mode, so this changes the
driver to not turn off VBUS for host-only mode.
Fixes: 2f3fd2c5bde1 ("usb: musb: Prepare dsps glue layer for PM runtime support")
Reported-by: Moreno Bartalucci <moreno.bartalucci@tecnorama.it>
Signed-off-by: Bin Liu <b-liu@ti.com>
commit c380f681245d7ae57f17d9ebbbe8f8f1557ee1fb upstream.
Current it's strictly checked if PVINFO version matches 1.0
for GVT-g i915 guest which doesn't help for compatibility at
all and forces GVT-g host can't extend PVINFO easily with version
bump for real compatibility check.
This fixes that to check minimal required PVINFO version instead.
v2:
- drop unneeded version macro
- use only major version for sanity check
v3:
- fix up PVInfo value with kernel type
- one indent fix
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Cc: Chuanxiao Dong <chuanxiao.dong@intel.com>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Signed-off-by: Zhenyu Wang <zhenyuw@linux.intel.com>
Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170609074805.5101-1-zhenyuw@linux.intel.com
(cherry picked from commit 0c8792d00d38de85b6ceb1dd67d3ee009d7c8e42)
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit bea10413934dcf98cb9b2dfcdc56e1d28f192897 upstream.
Commit d63c277dc672e0
("drm/amdgpu: Make display watermark calculations more accurate")
made watermark calculations more accurate, but not for > 4k
resolutions on 32-Bit architectures, as it introduced an integer
overflow for those setups and resolutions.
Fix this by proper u64 casting and division.
Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com>
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Fixes: d63c277dc672 ("drm/amdgpu: Make display watermark calculations more accurate")
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 5ebb6dd36c9f5fb37b1077b393c254d70a14cb46 upstream.
We should ensure that 'plane_no' is '< vb->num_planes' as done in
'vb2_plane_cookie' just a few lines below.
Fixes: e23ccc0ad925 ("[media] v4l: add videobuf2 Video for Linux 2 driver framework")
Reviewed-by: Sakari Ailus <sakari.ailus@linux.intel.com>
commit b8e11f7d2791bd9320be1c6e772a60b2aa093e45 upstream.
Commit 27ed3cd2ebf4 (cpufreq: conservative: Fix the logic in frequency
decrease checking) removed the 10 point substraction when comparing the
load against down_threshold but did not remove the related limit for the
down_threshold value. As a result, down_threshold lower than 11 is not
allowed even though values from 1 to 10 do work correctly too. The
comment ("cannot be lower than 11 otherwise freq will not fall") also
does not apply after removing the substraction.
For this reason, allow down_threshold to take any value from 1 to 99
and fix the related comment.
Fixes: 27ed3cd2ebf4 (cpufreq: conservative: Fix the logic in frequency decrease checking)
Signed-off-by: Tomasz Wilczyński <twilczynski@naver.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
commit 5cda3ee5138e91ac369ed9d0b55eab0dab077686 upstream.
This patch adds the missing kfree() in gs_cmd_reset() to free the
memory that is not used anymore after usb_control_msg().
Cc: Maximilian Schneider <max@schneidersoft.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 4e3aed844547f63614363a386de126e6304e55fb upstream.
On some systems there can be a race condition in which no crtc state is
added to the first atomic commit. This results in all crtc's having a
null DDB allocation, causing a FIFO underrun on any update until the
first modeset.
Changes since v1:
- Do not take the connection_mutex, this is already done below.
Reported-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Inspired-by: Mahesh Kumar <mahesh1.kumar@intel.com>
Signed-off-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com>
Fixes: 98d39494d375 ("drm/i915/gen9: Compute DDB allocation at atomic
check time (v4)")
Cc: Mahesh Kumar <mahesh1.kumar@intel.com>
Cc: Matt Roper <matthew.d.roper@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20170531154236.27180-1-maarten.lankhorst@linux.intel.com
Reviewed-by: Mahesh Kumar <mahesh1.kumar@intel.com>
Reviewed-by: Matt Roper <matthew.d.roper@intel.com>
(cherry picked from commit 367d73d2806085bb507ab44c1f532640917fd5ca)
commit 8f4d38099b3098eae75f7755e1801931f8141350 upstream.
The scanline counter is bonkers on VLV/CHV DSI. The scanline counter
increment is not lined up with the start of vblank like it is on
every other platform and output type. This causes problems for
both the vblank timestamping and atomic update vblank evasion.
On my FFRD8 machine at least, the scanline counter increment
happens about 1/3 of a scanline ahead of the start of vblank (which
is where all register latching happens still). That means we can't
trust the scanline counter to tell us whether we're in vblank or not
while we're on that particular line. In order to keep vblank
timestamping in working condition when called from the vblank irq,
we'll leave scanline_offset at one, which means that the entire
line containing the start of vblank is considered to be inside
the vblank.
For the vblank evasion we'll need to consider that entire line
to be bad, since we can't tell whether the registers already
got latched or not. And we can't actually use the start of vblank
interrupt to get us past that line as the interrupt would fire
too soon, and then we'd up waiting for the next start of vblank
instead. One way around that would using the frame start
interrupt instead since that wouldn't fire until the next
scanline, but that would require some bigger changes in the
interrupt code. So for simplicity we'll just poll until we get
past the bad line.
v2: Adjust the comments a bit
Cc: Jonas Aaberg <cja@gmx.net>
Tested-by: Jonas Aaberg <cja@gmx.net>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=99086
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/20161215174734.28779-1-ville.syrjala@linux.intel.com
Tested-by: Mika Kahola <mika.kahola@intel.com>
Reviewed-by: Mika Kahola <mika.kahola@intel.com>
(cherry picked from commit ec1b4ee2834e66884e5b0d3d465f347ff212e372)
commit e5c86679d5e864947a52fb31e45a425dea3e7fa9 upstream.
Linux IRQ #0 is reserved for error reporting and may not be used.
Increase NR_IRQS for one additional slot and increase
irq_domain_add_legacy parameter first_irq value to 1, so that linux
IRQ #0 is not associated with hardware IRQ #0 in legacy IRQ domains.
Introduce macro XTENSA_PIC_LINUX_IRQ for static translation of xtensa
PIC hardware IRQ # to linux IRQ #. Use this macro in XTFPGA platform
data definitions.
This fixes inability to use hardware IRQ #0 in configurations that don't
use device tree and allows for non-identity mapping between linux IRQ #
and hardware IRQ #.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
[ Upstream commit 59e8970b3798e4cbe575ed9cf4d53098760a2a86 ]
Return the maximum supported amount of inline data, not the qp's current
configured inline data size, when filling out the results of a query
qp call.
Signed-off-by: Ram Amrani <Ram.Amrani@cavium.com>
Signed-off-by: Michal Kalderon <Michal.Kalderon@cavium.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit c78c31496111f497b4a03f955c100091185da8b6 ]
It is normal to flush CQEs if the QP is in error state. Hence there's no
use in printing a message per CQE to dmesg.
[ Upstream commit 933e6dcaa0f65eb2f624ad760274020874a1f35e ]
Fail QP state transition from error to reset if SQ/RQ are not empty
and still in the process of flushing out the queued work entries.
[ Upstream commit 9c1e0228ab35e52d30abf4b5629c28350833fbcb ]
Free the PD if no internal resources were available. Move userspace
code under the relevant 'if'.
Signed-off-by: Ariel Elior <Ariel.Elior@cavium.com>
[ Upstream commit f449c7a2d822c2d81b5bcb2c50eec80796766726 ]
Relying on qede to trigger qedr on startup is problematic. When probing
both if qedr loads slowly then qede can assume qedr is missing and not
trigger it. This patch adds a triggering from qedr and protects against
a race via an atomic bit.
[ Upstream commit 0516ffd88fa0d006ee80389ce14a9ca5ae45e845 ]
Propagate the error when vhost_vq_init_access() fails and set
vq->private_data to NULL.
Signed-off-by: Stefan Hajnoczi <stefanha@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 3ba7b7795b7e8889af1377904c55c7fae9e0c775 ]
While testing musb host mode cable plugging on a BeagleBone, I came across this
error:
Unhandled fault: external abort on non-linefetch (0x1008) at 0xd1dcfc60
[<bf668390>] (musb_default_readb [musb_hdrc]) from [<bf668578>] (musb_irq_work+0x1c/0x180 [musb_hdrc])
[<bf668578>] (musb_irq_work [musb_hdrc]) from [<c0156554>] (process_one_work+0x2b4/0x808)
[<c0156554>] (process_one_work) from [<c015767c>] (worker_thread+0x3c/0x550)
[<c015767c>] (worker_thread) from [<c015d568>] (kthread+0x104/0x148)
[<c015d568>] (kthread) from [<c01078d0>] (ret_from_fork+0x14/0x24)
[ Upstream commit 90c694bb71819fb5bd3501ac397307d7e41ddeca ]
bnxt_get_port_module_status() calls bnxt_update_link() which expects
RTNL to be held. In bnxt_sp_task() that does not hold RTNL, we need to
call it with a prior call to bnxt_rtnl_lock_sp() and the call needs to
be moved to the end of bnxt_sp_task().
Signed-off-by: Michael Chan <michael.chan@broadcom.com>
[ Upstream commit 0eaa24b971ae251ae9d3be23f77662a655532063 ]
bnxt_update_link() is called from multiple code paths. Most callers,
such as open, ethtool, already hold RTNL. Only the caller bnxt_sp_task()
does not. So it is a bug to take RTNL inside bnxt_update_link().
Fix it by removing the RTNL inside bnxt_update_link(). The function
now expects the caller to always hold RTNL.
In bnxt_sp_task(), call bnxt_rtnl_lock_sp() before calling
bnxt_update_link(). We also need to move the call to the end of
bnxt_sp_task() since it will be clearing the BNXT_STATE_IN_SP_TASK bit.
