Pull battery fixes from Anton Vorontsov:
"Two fixes:
- fix build error caused by max17042_battery conversion to the regmap
API.
- fix kernel oops when booting with wakeup_source_activate enabled"
* tag 'for-v3.13-fixes' of git://git.infradead.org/battery-2.6:
max17042_battery: Fix build errors caused by missing REGMAP_I2C config
power_supply: Fix Oops from NULL pointer dereference from wakeup_source_activate
Pull ACPI and PM fixes and new device IDs from Rafael Wysocki:
"These commits, except for one, are regression fixes and the remaining
one fixes a divide error leading to a kernel panic. The majority of
the regressions fixed here were introduced during the 3.12 cycle, one
of them is from this cycle and one is older.
Specifics:
- VGA switcheroo was broken for some users as a result of the
ACPI-based PCI hotplug (ACPIPHP) changes in 3.12, because some
previously ignored hotplug events started to be handled. The fix
causes them to be ignored again.
- There are two more issues related to cpufreq's suspend/resume
handling changes from the 3.12 cycle addressed by Viresh Kumar's
fixes.
- intel_pstate triggers a divide error in a timer function if the
P-state information it needs is missing during initialization.
This leads to kernel panics on nested KVM clients and is fixed by
failing the initialization cleanly in those cases.
- PCI initalization code changes during the 3.9 cycle uncovered BIOS
issues related to ACPI wakeup notifications (some BIOSes send them
for devices that aren't supposed to support ACPI wakeup). Work
around them by installing an ACPI wakeup notify handler for all PCI
devices with ACPI support.
- The Calxeda cpuilde driver's probe function is tagged as __init,
which is incorrect and causes a section mismatch to occur during
build. Fix from Andre Przywara removes the __init tag from there.
- During the 3.12 cycle ACPIPHP started to print warnings about
missing _ADR for devices that legitimately don't have it. Fix from
Toshi Kani makes it only print the warnings where they make sense"
* tag 'pm+acpi-3.13-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
ACPIPHP / radeon / nouveau: Fix VGA switcheroo problem related to hotplug
intel_pstate: Fail initialization if P-state information is missing
ARM/cpuidle: remove __init tag from Calxeda cpuidle probe function
PCI / ACPI: Install wakeup notify handlers for all PCI devs with ACPI
cpufreq: preserve user_policy across suspend/resume
cpufreq: Clean up after a failing light-weight initialization
ACPI / PCI / hotplug: Avoid warning when _ADR not present
Merge patches from Andrew Morton:
"Ten fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
epoll: do not take the nested ep->mtx on EPOLL_CTL_DEL
sh: add EXPORT_SYMBOL(min_low_pfn) and EXPORT_SYMBOL(max_low_pfn) to sh_ksyms_32.c
drivers/dma/ioat/dma.c: check DMA mapping error in ioat_dma_self_test()
mm/memory-failure.c: transfer page count from head page to tail page after split thp
MAINTAINERS: set up proper record for Xilinx Zynq
mm: remove bogus warning in copy_huge_pmd()
memcg: fix memcg_size() calculation
mm: fix use-after-free in sys_remap_file_pages
mm: munlock: fix deadlock in __munlock_pagevec()
mm: munlock: fix a bug where THP tail page is encountered
Check DMA mapping return values in function ioat_dma_self_test() to get
rid of following warning message.
WARNING: CPU: 0 PID: 1203 at lib/dma-debug.c:937 check_unmap+0x4c0/0x9a0()
ioatdma 0000:00:04.0: DMA-API: device driver failed to check map error[device address=0x000000085191b000] [size=2000 bytes] [mapped as single]
Modules linked in: ioatdma(+) mac_hid wmi acpi_pad lp parport hidd_generic usbhid hid ixgbe isci dca libsas ahci ptp libahci scsi_transport_sas meegaraid_sas pps_core mdio
CPU: 0 PID: 1203 Comm: systemd-udevd Not tainted 3.13.0-rc4+ #8
Hardware name: Intel Corporation BRICKLAND/BRICKLAND, BIOS BRIVTIIN1.86B.0044.L09.1311181644 11/18/2013
Call Trace:
dump_stack+0x4d/0x66
warn_slowpath_common+0x7d/0xa0
warn_slowpath_fmt+0x4c/0x50
debug_dma_unmap_page+0x81/0x90
ioat_dma_self_test+0x3d2/0x680 [ioatdma]
ioat3_dma_self_test+0x12/0x30 [ioatdma]
ioat_probe+0xf4/0x110 [ioatdma]
ioat3_dma_probe+0x268/0x410 [ioatdma]
ioat_pci_probe+0x122/0x1b0 [ioatdma]
local_pci_probe+0x45/0xa0
pci_device_probe+0xd9/0x130
driver_probe_device+0x171/0x490
__driver_attach+0x93/0xa0
bus_for_each_dev+0x6b/0xb0
driver_attach+0x1e/0x20
bus_add_driver+0x1f8/0x2b0
driver_register+0x81/0x110
__pci_register_driver+0x60/0x70
ioat_init_module+0x89/0x1000 [ioatdma]
do_one_initcall+0xe2/0x250
load_module+0x2313/0x2a00
SyS_init_module+0xd9/0x130
system_call_fastpath+0x1a/0x1f
---[ end trace 990c591681d27c31 ]---
Mapped at:
debug_dma_map_page+0xbe/0x180
ioat_dma_self_test+0x1ab/0x680 [ioatdma]
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Vinod Koul <vinod.koul@intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 fixes from Martin Schwidefsky:
"Two small bug fixes and a follow-up to the CONFIG_NR_CPUS change.
A kernel compiled with CONFIG_NR_CPUS=256 will waste quite a bit of
memory for the per-cpu arrays. Under z/VM the maximum number of CPUs
is 64, the code now limits the possible cpu mask to 64 if running
under z/VM"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux:
s390/pci: obtain function handle in hotplug notifier
s390/3270: fix allocation of tty3270_screen structure
s390/smp: improve setup of possible cpu mask
Pull radeon drm fixes from Dave Airlie:
"Just piping a bunch of fixes from pre-xmas from Alex for radeon, all
either fix bad hw setup issues or regressions"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/radeon: Bump version for CIK DCE tiling fix
drm/radeon: set correct number of banks for CIK chips in DCE
drm/radeon: set correct pipe config for Hawaii in DCE
drm/radeon: expose render backend mask to the userspace
drm/radeon: fix render backend setup for SI and CIK
drm/radeon: 0x9649 is SUMO2 not SUMO
drm/radeon: fix UVD 256MB check
Pull crypto fix from Herbert Xu:
"Fix a build error on ARM that was introduced in 3.13-rc1"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: ixp4xx - Fix kernel compile error
into drm-fixes
Radeon fixes, Christmas eve edition. Fix incorrect family for 0x9649
which lead to bogus rendering, tiling and RB fixes for SI and CIK,
and a UVD fix.
* 'drm-fixes-3.13' of git://people.freedesktop.org/~agd5f/linux:
drivers/crypto/ixp4xx_crypto.c: In function 'ixp_module_init':
drivers/crypto/ixp4xx_crypto.c:1419:2: error: 'dev' undeclared (first use in this function)
Now builds. Not tested on real hw.
Signed-off-by: Krzysztof Hałasa <khalasa@piap.pl>
* pm-cpufreq:
* pm-cpuidle:
* acpi-pci-pm:
* acpi-pci-hotplug:
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"A fix for a panic in gpio-keys driver when set up with absolute
events, a fixup to the new zforce driver and a new keycode definition"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: allocate absinfo data when setting ABS capability
Input: define KEY_WWAN for Wireless WAN
Input: zforce - fix possible driver hang during suspend
We need to make sure we allocate absinfo data when we are setting one of
EV_ABS/ABS_XXX capabilities, otherwise we may bomb when we try to emit this
event.
Rested-by: Paul Cercueil <pcercuei@gmail.com>
The changes in the ACPI-based PCI hotplug (ACPIPHP) subsystem made
during the 3.12 development cycle uncovered a problem with VGA
switcheroo that on some systems, when the device-specific method
(ATPX in the radeon case, _DSM in the nouveau case) is used to turn
off the discrete graphics, the BIOS generates ACPI hotplug events for
that device and those events cause ACPIPHP to attempt to remove the
device from the system (they are events for a device that was present
previously and is not present any more, so that's what should be done
according to the spec). Then, the system stops functioning correctly.
Since the hotplug events in question were simply silently ignored
previously, the least intrusive way to address that problem is to
make ACPIPHP ignore them again. For this purpose, introduce a new
ACPI device flag, no_hotplug, and modify ACPIPHP to ignore hotplug
events for PCI devices whose ACPI companions have that flag set.
Next, make the radeon and nouveau switcheroo detection code set the
no_hotplug flag for the discrete graphics' ACPI companion.
Fixes: bbd34fcdd1b2 (ACPI / hotplug / PCI: Register all devices under the given bridge)
References: https://bugzilla.kernel.org/show_bug.cgi?id=61891
References: https://bugzilla.kernel.org/show_bug.cgi?id=64891
Reported-and-tested-by: Mike Lothian <mike@fireburn.co.uk>
Reported-and-tested-by: <madcatx@atlas.cz>
Reported-and-tested-by: Joaquín Aramendía <samsagax@gmail.com>
Cc: Alex Deucher <alexdeucher@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: 3.12+ <stable@vger.kernel.org> # 3.12+
If pstate.current_pstate is 0 after the initial
intel_pstate_get_cpu_pstates(), this means that we were unable to
obtain any useful P-state information and there is no reason to
continue, so free memory and return an error in that case.
This fixes the following divide error occuring in a nested KVM
guest:
Intel P-state driver initializing.
Intel pstate controlling: cpu 0
cpufreq: __cpufreq_add_dev: ->get() failed
divide error: 0000 [#1] SMP
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.13.0-0.rc4.git5.1.fc21.x86_64 #1
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
task: ffff88001ea20000 ti: ffff88001e9bc000 task.ti: ffff88001e9bc000
RIP: 0010:[<ffffffff815c551d>] [<ffffffff815c551d>] intel_pstate_timer_func+0x11d/0x2b0
RSP: 0000:ffff88001ee03e18 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff88001a454348 RCX: 0000000000006100
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000000
RBP: ffff88001ee03e38 R08: 0000000000000000 R09: 0000000000000000
R10: ffff88001ea20000 R11: 0000000000000000 R12: 00000c0a1ea20000
R13: 1ea200001ea20000 R14: ffffffff815c5400 R15: ffff88001a454348
FS: 0000000000000000(0000) GS:ffff88001ee00000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000000 CR3: 0000000001c0c000 CR4: 00000000000006f0
Stack:
fffffffb1a454390 ffffffff821a4500 ffff88001a454390 0000000000000100
ffff88001ee03ea8 ffffffff81083e9a ffffffff81083e15 ffffffff82d5ed40
ffffffff8258cc60 0000000000000000 ffffffff81ac39de 0000000000000000
Call Trace:
<IRQ>
[<ffffffff81083e9a>] call_timer_fn+0x8a/0x310
[<ffffffff81083e15>] ? call_timer_fn+0x5/0x310
[<ffffffff815c5400>] ? pid_param_set+0x130/0x130
[<ffffffff81084354>] run_timer_softirq+0x234/0x380
[<ffffffff8107aee4>] __do_softirq+0x104/0x430
[<ffffffff8107b5fd>] irq_exit+0xcd/0xe0
[<ffffffff81770645>] smp_apic_timer_interrupt+0x45/0x60
[<ffffffff8176efb2>] apic_timer_interrupt+0x72/0x80
<EOI>
[<ffffffff810e15cd>] ? vprintk_emit+0x1dd/0x5e0
[<ffffffff81757719>] printk+0x67/0x69
[<ffffffff815c1493>] __cpufreq_add_dev.isra.13+0x883/0x8d0
[<ffffffff815c14f0>] cpufreq_add_dev+0x10/0x20
[<ffffffff814a14d1>] subsys_interface_register+0xb1/0xf0
[<ffffffff815bf5cf>] cpufreq_register_driver+0x9f/0x210
[<ffffffff81fb19af>] intel_pstate_init+0x27d/0x3be
[<ffffffff81761e3e>] ? mutex_unlock+0xe/0x10
[<ffffffff81fb1732>] ? cpufreq_gov_dbs_init+0x12/0x12
[<ffffffff8100214a>] do_one_initcall+0xfa/0x1b0
[<ffffffff8109dbf5>] ? parse_args+0x225/0x3f0
[<ffffffff81f64193>] kernel_init_freeable+0x1fc/0x287
[<ffffffff81f638d0>] ? do_early_param+0x88/0x88
[<ffffffff8174b530>] ? rest_init+0x150/0x150
[<ffffffff8174b53e>] kernel_init+0xe/0x130
[<ffffffff8176e27c>] ret_from_fork+0x7c/0xb0
Code: c1 e0 05 48 63 bc 03 10 01 00 00 48 63 83 d0 00 00 00 48 63 d6 48 c1 e2 08 c1 e1 08 4c 63 c2 48 c1 e0 08 48 98 48 c1 e0 08 48 99 <49> f7 f8 48 98 48 0f af f8 48 c1 ff 08 29 f9 89 ca c1 fa 1f 89
RIP [<ffffffff815c551d>] intel_pstate_timer_func+0x11d/0x2b0
RSP <ffff88001ee03e18>
---[ end trace f166110ed22cc37a ]---
Kernel panic - not syncing: Fatal exception in interrupt
Reported-and-tested-by: Kashyap Chamarthy <kchamart@redhat.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
Cc: All applicable <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree fixes from Rob Herring:
- Fix 2 regressions found on PPC
- Allow NULL ptr in unflatten_and_copy_device_tree
- Update my email address
* tag 'dt-fixes-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux:
MAINTAINERS: Update Rob Herring's email address
of/irq: Fix device_node refcount in of_irq_parse_raw()
of/Kconfig: Spelling s/one/once/
Revert "of/address: Handle #address-cells > 2 specially"
of: Fix NULL dereference in unflatten_and_copy()
Pull networking fixes from David Miller:
"Some holiday bug fixes for 3.13... There is still one bug I'd like to
get fixed before 3.13-final.
The vlan code erroneously assignes the header ops of the underlying
real device to the VLAN device above it when the real device can
hardware offload VLAN handling. That's completely bogus because
header ops are tied to the device type, so they only expect to see a
'dev' argument compatible with their ops.
The fix is the have the VLAN code use a special set of header ops that
does the pass-thru correctly, by calling the underlying real device's
header ops but _also_ passing in the real device instead of the VLAN
device.
That fix is currently waiting some testing.
Anyways, of note here:
1) Fix bitmap edge case in radiotap, from Johannes Berg.
2) Fix oops on driver unload in rtlwifi, from Larry Finger.
3) Bonding doesn't do locking correctly during speed/duplex/link
changes, from Ding Tianhong.
4) Fix header parsing in GRE code, this bug has been around for a few
releases. From Timo Teräs.
5) SIT tunnel driver MTU check needs to take GSO into account, from
Eric Dumazet.
6) Minor info leak in inet_diag, from Daniel Borkmann.
7) Info leak in YAM hamradio driver, from Salva Peiró.
8) Fix route expiration state handling in ipv6 routing code, from Li
RongQing.
9) DCCP probe module does not check request_module()'s return value,
from Wang Weidong.
10) cpsw driver passes NULL device names to request_irq(), from
Mugunthan V N.
11) Prevent a NULL splat in RDS binding code, from Sasha Levin.
12) Fix 4G overflow test in tg3 driver, from Nithin Sujir.
13) Cure use after free in arc_emac and fec driver's software
timestamp handling, from Eric Dumazet.
14) SIT driver can fail to release the route when
iptunnel_handle_offloads() throws an error. From Li RongQing.
15) Several batman-adv fixes from Simon Wunderlich and Antonio
Quartulli.
16) Fix deadlock during TIPC socket release, from Ying Xue.
17) Fix regression in ROSE protocol recvmsg() msg_name handling, from
Florian Westphal.
18) stmmac PTP support releases wrong spinlock, from Vince Bridgers"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (73 commits)
stmmac: Fix incorrect spinlock release and PTP cap detection.
phy: IRQ cannot be shared
net: rose: restore old recvmsg behavior
xen-netback: fix guest-receive-side array sizes
fec: Do not assume that PHY reset is active low
tipc: fix deadlock during socket release
netfilter: nf_tables: fix wrong datatype in nft_validate_data_load()
batman-adv: fix vlan header access
batman-adv: clean nf state when removing protocol header
batman-adv: fix alignment for batadv_tvlv_tt_change
batman-adv: fix size of batadv_bla_claim_dst
batman-adv: fix size of batadv_icmp_header
batman-adv: fix header alignment by unrolling batadv_header
batman-adv: fix alignment for batadv_coded_packet
netfilter: nf_tables: fix oops when updating table with user chains
netfilter: nf_tables: fix dumping with large number of sets
ipv6: release dst properly in ipip6_tunnel_xmit
netxen: Correct off-by-one errors in bounds checks
net: Add some clarification to skb_tx_timestamp() comment.
arc_emac: fix potential use after free
Commit 2361613206e6, "of/irq: Refactor interrupt-map parsing" changed
the refcount on the device_node causing an error in of_node_put():
ERROR: Bad of_node_put() on /pci@800000020000000
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.13.0-rc3-dirty #2
Call Trace:
[c00000003e403500] [c0000000000144fc] .show_stack+0x7c/0x1f0 (unreliable)
[c00000003e4035d0] [c00000000070f250] .dump_stack+0x88/0xb4
[c00000003e403650] [c0000000005e8768] .of_node_release+0xd8/0xf0
[c00000003e4036e0] [c0000000005eeafc] .of_irq_parse_one+0x10c/0x280
[c00000003e4037a0] [c0000000005efd4c] .of_irq_parse_pci+0x3c/0x1d0
[c00000003e403840] [c000000000038240] .pcibios_setup_device+0xa0/0x2e0
[c00000003e403910] [c0000000000398f0] .pcibios_setup_bus_devices+0x60/0xd0
[c00000003e403990] [c00000000003b3a4] .__of_scan_bus+0x1a4/0x2b0
[c00000003e403a80] [c00000000003a62c] .pcibios_scan_phb+0x30c/0x410
[c00000003e403b60] [c0000000009fe430] .pcibios_init+0x7c/0xd4
This patch adjusts the refcount in the walk of the interrupt tree.
When a match is found, there is no need to increase the refcount
on 'out_irq->np' as 'newpar' is already holding a ref. The refcount
balance between 'ipar' and 'newpar' is maintained in the skiplevel:
goto label.
This patch also removes the usage of the device_node variable 'old'
which seems useless after the latest changes.
Signed-off-by: Cédric Le Goater <clg@fr.ibm.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org>
This reverts commit e38c0a1fbc5803cbacdaac0557c70ac8ca5152e7.
Nikita Yushchenko reports:
While trying to make freescale p2020ds and mpc8572ds boards working
with mainline kernel, I faced that commit e38c0a1f (Handle
Both these boards have uli1575 chip.
Corresponding part in device tree is something like
uli1575@0 {
reg = <0x0 0x0 0x0 0x0 0x0>;
#size-cells = <2>;
#address-cells = <3>;
ranges = <0x2000000 0x0 0x80000000
0x0 0x20000000
0x1000000 0x0 0x0
0x1000000 0x0 0x0
0x0 0x10000>;
isa@1e {
I.e. it has #address-cells = <3>
With commit e38c0a1f reverted, devices under uli1575 are registered
correctly, e.g. for rtc
OF: ** translation for device /pcie@ffe09000/pcie@0/uli1575@0/isa@1e/rtc@70 **
OF: bus is isa (na=2, ns=1) on /pcie@ffe09000/pcie@0/uli1575@0/isa@1e
OF: translating address: 00000001 00000070
OF: parent bus is default (na=3, ns=2) on /pcie@ffe09000/pcie@0/uli1575@0
OF: walking ranges...
OF: ISA map, cp=0, s=1000, da=70
OF: parent translation for: 01000000 00000000 00000000
OF: with offset: 70
OF: one level translation: 00000000 00000000 00000070
OF: parent bus is pci (na=3, ns=2) on /pcie@ffe09000/pcie@0
OF: default map, cp=a0000000, s=20000000, da=70
OF: default map, cp=0, s=10000, da=70
OF: with offset: 70
OF: one level translation: 01000000 00000000 00000070
OF: PCI map, cp=0, s=10000, da=70
OF: with offset: 70
OF: parent bus is default (na=2, ns=2) on /
OF: parent translation for: 00000000 ffc10000
OF: with offset: 70
OF: one level translation: 00000000 ffc10070
OF: reached root node
With commit e38c0a1f in place, address translation fails:
OF: with offset: 70
OF: not found !
Thierry Reding confirmed this commit was not needed after all:
"We ended up merging a different address representation for Tegra PCIe
and I've confirmed that reverting this commit doesn't cause any obvious
regressions. I think all other drivers in drivers/pci/host ended up
copying what we did on Tegra, so I wouldn't expect any other breakage
either."
There doesn't appear to be a simple way to support both behaviours, so
reverting this as nothing should be depending on the new behaviour.
Cc: stable@vger.kernel.org # v3.7+
Commit 60a66e370007e8535b7a561353b07b37deaf35ba changed the Calxeda
cpuidle driver to a platform driver, copying the __init tag from the
_init() to the newly used _probe() function. However, "probe should
not be __init." (Rob said ;-)
Remove the __init tag to fix a section mismatch in the Calxeda
cpuidle driver.
Signed-off-by: Andre Przywara <andre.przywara@linaro.org>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
This patch corrects a problem in stmmac_ptp.c, functions
stmmac_adjust_time and stmmac_adjust_freq where the incorrect spinlocks
were released. This patch also addresses a problem in stmmac_main,
function stmmac_init_ptp where the capability detection for
advanced timestamping was masked by message masking.
This patch was touch tested using linuxptp, and runs without the previously
observed instabilities. More extensive testing is ongoing.
Vince
Signed-off-by: Vince Bridgers <vbridgers2013@gmail.com>
With the way PHY IRQ handler is implemented (all real handling being pushed to
the workqueue and returning IRQ_HANDLED all the time PHY is active), we cannot
really claim that PHY IRQ can be shared when calling request_irq().
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
Acked-by: Florian Fainelli <f.fainelli@gmail.com>
The sizes chosen for the metadata and grant_copy_op arrays on the guest
receive size are wrong;
- The meta array is needlessly twice the ring size, when we only ever
consume a single array element per RX ring slot
- The grant_copy_op array is way too small. It's sized based on a bogus
assumption: that at most two copy ops will be used per ring slot. This
may have been true at some point in the past but it's clear from looking
at start_new_rx_buffer() that a new ring slot is only consumed if a frag
would overflow the current slot (plus some other conditions) so the actual
limit is MAX_SKB_FRAGS grant_copy_ops per ring slot.
This patch fixes those two sizing issues and, because grant_copy_ops grows
so much, it pulls it out into a separate chunk of vmalloc()ed memory.
Signed-off-by: Paul Durrant <paul.durrant@citrix.com>
Acked-by: Wei Liu <wei.liu2@citrix.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: David Vrabel <david.vrabel@citrix.com>
We should not assume that the PHY reset is always active low.
Retrieve this information from the device tree instead, so that the PHY reset
can work on both cases.
Reported-by: Philipp Zabel <p.zabel@pengutronix.de>
It turns out that some BIOSes don't report wakeup GPEs through
_PRW, but use them for signaling wakeup anyway, which causes GPE
storms to occur on some systems after resume from system suspend.
This issue has been uncovered by commit d2e5f0c16ad6 (ACPI / PCI:
Rework the setup and cleanup of device wakeup) during the 3.9
development cycle.
Work around the problem by installing wakeup notify handlers for all
PCI devices with ACPI support (i.e. having ACPI companions) regardless
of whether or not the BIOS reports ACPI wakeup support for them. The
presence of the wakeup notify handlers alone is not harmful in any
way if there are no events for them to handle (they are simply never
executed then), but on some systems they are needed to take care of
spurious events.
Fixes: d2e5f0c16ad6 (ACPI / PCI: Rework the setup and cleanup of device wakeup)
References: https://bugzilla.kernel.org/show_bug.cgi?id=63021
Reported-and-tested-by: Agustin Barto <abarto@gmail.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Pull x86 fixes from Peter Anvin:
"There is a small EFI fix and a big power regression fix in this batch.
My queue also had a fix for downing a CPU when there are insufficient
number of IRQ vectors available, but I'm holding that one for now due
to recent bug reports"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/efi: Don't select EFI from certain special ACPI drivers
x86 idle: Repair large-server 50-watt idle-power regression
Pull ACPI and power management fixes and new device IDs from Rafael Wysocki:
- Fix for a cpufreq regression causing stale sysfs files to be left
behind during system resume if cpufreq_add_dev() fails for one or
more CPUs from Viresh Kumar.
- Fix for a bug in cpufreq causing CONFIG_CPU_FREQ_DEFAULT_* to be
ignored when the intel_pstate driver is used from Jason Baron.
- System suspend fix for a memory leak in pm_vt_switch_unregister()
that forgot to release objects after removing them from
pm_vt_switch_list. From Masami Ichikawa.
- Intel Valley View device ID and energy unit encoding update for the
(recently added) Intel RAPL (Running Average Power Limit) driver from
Jacob Pan.
- Intel Bay Trail SoC GPIO and ACPI device IDs for the Low Power
Subsystem (LPSS) ACPI driver from Paul Drews.
* tag 'pm+acpi-3.13-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
powercap / RAPL: add support for ValleyView Soc
PM / sleep: Fix memory leak in pm_vt_switch_unregister().
cpufreq: Use CONFIG_CPU_FREQ_DEFAULT_* to set initial policy for setpolicy drivers
cpufreq: remove sysfs files for CPUs which failed to come back after resume
ACPI: Add BayTrail SoC GPIO and LPSS ACPI IDs
Prevent __cpufreq_add_dev() from overwriting the existing values of
user_policy.{min|max|policy|governor} with defaults during resume
Fixes: 5302c3fb2e62 ("cpufreq: Perform light-weight init/teardown during suspend/resume")
Reported-by: Bjørn Mork <bjorn@mork.no>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
[rjw: Changelog]
If cpufreq_policy_restore() returns NULL during system resume,
__cpufreq_add_dev() should just fall back to the full initialization
instead of returning an error, because that may actually make things
work. Moreover, it should not leave stale fallback data behind after
it has failed to restore a previously existing policy.
This change is based on Viresh Kumar's work.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
netxen_process_lro() contains two bounds checks. One for the ring number
against the number of rings, and one for the Rx buffer ID against the
array of receive buffers.
Both of these have off-by-one errors, using > instead of >=. The correct
versions are used in netxen_process_rcv(), they're just wrong in
netxen_process_lro().
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
skb_tx_timestamp(skb) should be called _before_ TX completion
has a chance to trigger, otherwise it is too late and we access
freed memory.
Fixes: e4f2379db6c6 ("ethernet/arc/arc_emac - Add new driver")
Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
Cc: Richard Cochran <richardcochran@gmail.com>
The current driver assumes that an skb fragment can only be upto jumbo
size. Presumably this was a fast-path optimization. This assumption is
no longer true as fragments can be upto 32k.
v2: Remove unnecessary parantheses per Eric Dumazet.
Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
* powercap:
* acpi-lpss:
* pm-cpufreq:
* pm-sleep:
There are inconsistencies wrt. feature propagation/inheritance between
macvlan and the underlying interface.
When a feature is turned off on the real device before a macvlan is
created on top, these will remain enabled on the macvlan device, whereas
turning off the feature on the lower device after macvlan creation the
kernel will propagate the changes to the macvlan.
The second issue is that, when propagating changes from underlying device
to the macvlan interface, macvlan can erronously lose its NETIF_F_LLTX flag,
as features are anded with the underlying device.
However, LLTX should be kept since it has no dependencies on physical
hardware (LLTX is set on macvlan creation regardless of the lower
device properties, see 8ffab51b3dfc54876f145f15b351c41f3f703195
(macvlan: lockless tx path).
The LLTX flag is now forced regardless of user settings in absence of
layer2 hw acceleration (a6cc0cfa72e0b6d9f2c8fd858aa,
net: Add layer 2 hardware acceleration operations for macvlan devices).
Use netdev_increment_features to rebuild the feature set on capability
changes on either the lower device or on the macvlan interface.
As pointed out by Ben Hutchings, use netdev_update_features on
NETDEV_FEAT_CHANGE event (it calls macvlan_fix_features/netdev_features_change
if needed).
Pull block fixes from Jens Axboe:
- fix for a memory leak on certain unplug events
- a collection of bcache fixes from Kent and Nicolas
- a few null_blk fixes and updates form Matias
- a marking of static of functions in the stec pci-e driver
* 'for-linus' of git://git.kernel.dk/linux-block:
null_blk: support submit_queues on use_per_node_hctx
null_blk: set use_per_node_hctx param to false
null_blk: corrections to documentation
null_blk: warning on ignored submit_queues param
null_blk: refactor init and init errors code paths
null_blk: documentation
null_blk: mem garbage on NUMA systems during init
drivers: block: Mark the functions as static in skd_main.c
bcache: New writeback PD controller
bcache: bugfix for race between moving_gc and bucket_invalidate
bcache: fix for gc and writeback race
bcache: bugfix - moving_gc now moves only correct buckets
bcache: fix for gc crashing when no sectors are used
bcache: Fix heap_peek() macro
bcache: Fix for can_attach_cache()
bcache: Fix dirty_data accounting
bcache: Use uninterruptible sleep in writeback
bcache: kthread don't set writeback task to INTERUPTIBLE
block: fix memory leaks on unplugging block device
bcache: fix sparse non static symbol warning
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata fixes from Tejun Heo:
"There's one interseting commit - "libata, freezer: avoid block device
removal while system is frozen". It's an ugly hack working around a
deadlock condition between driver core resume and block layer device
removal paths through freezer which was made more reproducible by
writeback being converted to workqueue some releases ago. The bug has
nothing to do with libata but it's just an workaround which is easy to
backport. After discussion, Rafael and I seem to agree that we don't
really need kernel freezables - both kthread and workqueue. There are
few specific workqueues which constitute PM operations and require
freezing, which will be converted to use workqueue_set_max_active()
instead. All other kernel freezer uses are planned to be removed,
followed by the removal of kthread and workqueue freezer support,
hopefully.
Others are device-specific fixes. The most notable is the addition of
NO_NCQ_TRIM which is used to disable queued TRIM commands to Micro
M500 SSDs which otherwise suffers data corruption"
* 'for-3.13-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
libata, freezer: avoid block device removal while system is frozen
libata: implement ATA_HORKAGE_NO_NCQ_TRIM and apply it to Micro M500 SSDs
libata: disable a disk via libata.force params
ahci: bail out on ICH6 before using AHCI BAR
ahci: imx: Explicitly clear IMX6Q_GPR13_SATA_MPLL_CLK_EN
libata: add ATA_HORKAGE_BROKEN_FPDMA_AA quirk for Seagate Momentus SpinPoint M8
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband
Pull infiniband fixes from Roland Dreier:
"Last batch of InfiniBand/RDMA changes for 3.13 / 2014:
- Additional checks for uverbs to ensure forward compatibility,
handle malformed input better.
- Fix potential use-after-free in iWARP connection manager.
- Make a function static"
* tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband:
IB/uverbs: Check access to userspace response buffer in extended command
IB/uverbs: Check input length in flow steering uverbs
IB/uverbs: Set error code when fail to consume all flow_spec items
IB/uverbs: Check reserved fields in create_flow
IB/uverbs: Check comp_mask in destroy_flow
IB/uverbs: Check reserved field in extended command header
IB/uverbs: New macro to set pointers to NULL if length is 0 in INIT_UDATA()
IB/core: const'ify inbuf in struct ib_udata
RDMA/iwcm: Don't touch cm_id after deref in rem_ref
RDMA/cxgb4: Make _c4iw_write_mem_dma() static
Pull drm fixes from Dave Airlie:
"Xmas fixes pull, all small nothing major, intel, radeon, one ttm
regression, and one build fix"
drm/ttm: Fix swapin regression
gpu: fix qxl missing crc32_le
drm/radeon: fix asic gfx values for scrapper asics
drm/i915: Use the correct GMCH_CTRL register for Sandybridge+
drm/radeon: check for 0 count in speaker allocation and SAD code
drm/radeon/dpm: disable ss on Cayman
drm/radeon/dce6: set correct number of audio pins
drm/i915: get a PC8 reference when enabling the power well
drm/i915: change CRTC assertion on LCPLL disable
drm/i915: Fix erroneous dereference of batch_obj inside reset_status
drm/i915: Prevent double unref following alloc failure during execbuffer
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio balloon driver fixes from Rusty Russell:
"Refactoring broke the balloon driver, and fixing kallsyms on ARM broke
some (non-ARM) MMUless setups, so we're making that fix ARM-only for
now.
Unfortunately, the ARM refactoring which broke kallsyms/perf was
CC:stable, so the fix (which broken non-ARM) was also CC:stable, so
now the partial reversion is also CC:stable..."
* tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
scripts/link-vmlinux.sh: only filter kernel symbols for arm
virtio_balloon: update_balloon_size(): update correct field
Note when CIK DCE tiling was fixed.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
We don't have the NUM_BANKS parameter, so we have to calculate it
from the other parameters. NUM_BANKS is not constant on CIK.
This fixes 2D tiling for the display engine on CIK.
Signed-off-by: Marek Olšák <marek.olsak@amd.com>
This will allow userspace to correctly program the PA_SC_RASTER_CONFIG
register, so it can be considered a fix.
Only the render backends of the first shader engine were enabled. The others
were erroneously disabled. Enabling the other render backends improves
performance a lot.
Unigine Sanctuary on Bonaire:
Before: 15 fps
After: 90 fps
Judging from the fan noise, the GPU was also underclocked when the other
render backends were disabled, resulting in horrible performance. The fan is
a lot noisy under load now.
Otherwise the kernel might reject our decoding requests.
Signed-off-by: Christian König <christian.koenig@amd.com>
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes
Besides the 2 fixes for tricky corner cases in gem from Chris I've
promised already two patche from Paulo to fix pc8 warnings (both ported
from -next, bug report from Dave Jones) and one patch from to fix vga
enable/disable on snb+. That one is a really old bug, but apparently it
can cause machine hangs if you try hard enough with vgacon/efifb handover.
* tag 'drm-intel-fixes-2013-12-18' of git://people.freedesktop.org/~danvet/drm-intel:
