commit c8648508ebfc597058d2cd00b6c539110264a167 upstream.
On success, callback function returns 0. So invert the if condition
check so that we can break out of loop.
Signed-off-by: Ameya Palande <2ameya@gmail.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit 87f966d97b89774162df04d2106c6350c8fe4cb3 upstream.
On a MIPS Malta board, tons of fifo underflow errors have been observed
when using u-boot as bootloader instead of YAMON. The reason for that
is that YAMON used to set the pcnet device to SRAM mode but u-boot does
not. As a result, the default Tx threshold (64 bytes) is now too small to
keep the fifo relatively used and it can result to Tx fifo underflow errors.
As a result of which, it's best to setup the SRAM on supported controllers
so we can always use the NOUFLO bit.
Cc: <netdev@vger.kernel.org>
Cc: <linux-kernel@vger.kernel.org>
Cc: Don Fry <pcnet32@frontier.com>
Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
commit 391949b6f02121371e3d7d9082c6d17fd9853034 upstream.
With spidev the mesg->complete callback points to spidev_complete.
Calling this unblocks spidev_sync and so spidev_sync_write finishes. As
the struct spi_message just read is a local variable in
spidev_sync_write and recording the trace event accesses this message
the recording is better done first. The same can happen for
spidev_sync_read.
This fixes an oops observed on a 3.14-rt system with spidev activity
after
echo 1 > /sys/kernel/debug/tracing/events/spi/enable
Signed-off-by: Mark Brown <broonie@kernel.org>
REQ_WRITE_SAME
commit e5db29806b99ce2b2640d2e4d4fcb983cea115c5 upstream.
Since it's possible for the discard and write same queue limits to
change while the upper level command is being sliced and diced, fix up
both of them (a) to reject IO if the special command is unsupported at
the start of the function and (b) read the limits once and let the
commands error out on their own if the status happens to change.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit ab7c7bb6f4ab95dbca96fcfc4463cd69843e3e24 upstream.
__dm_destroy() must take the suspend_lock so that its presuspend and
postsuspend calls do not race with an internal suspend.
commit a104a45ba7a51b5b4c5e8437020d9d48edf22f89 upstream.
The commit 9cade1a46c77 (dma: dw: split driver to library part and platform
code) introduced a separate platform driver but missed to add a
MODULE_ALIAS("platform:dw_dmac"); to that module.
The patch adds this to get driver loaded automatically if platform device is
registered.
Reported-by: "Blin, Jerome" <jerome.blin@intel.com>
Fixes: 9cade1a46c77 (dma: dw: split driver to library part and platform code)
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 40c8790bcb7ac74f3038153cd09310e220c6a1df upstream.
When the driver sets this rate a power of zero value is set causing
data flow stoppage until another rate is tried.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
commit 163fe301b9f78b6de57d0014eafe504fd20c0cd4 upstream.
commit d7c146053dd195b90c79b9b8131431f44541d015 upstream.
The error code paths that require cleanup use a goto to jump to the
cleanup code and return an error code. However, the error code variable
res, which is initialized to -EINVAL when declared, is then overwritten
with the return value of of_parse_phandle_with_args(), and reused as the
return code from of_irq_parse_one(). This leads to an undetermined error
being returned instead of the expected -EINVAL value. Fix it.
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
Signed-off-by: Rob Herring <robh@kernel.org>
commit 2f1bce487cd0a02623cff3d877940f9a2026341c upstream.
devm_phy_create() stores the pointer to the new PHY at the address
returned by devres_alloc(). The res parameter passed to devm_phy_match()
is therefore the location where the pointer to the PHY is stored, hence
it needs to be dereferenced before comparing to the match data in order
to find the correct match.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
This reverts commit 5ac97a1b97e50ef197b64b72c1cd71779e4ecbbe
It was incorrectly applied, as it merged with fuzz.
Reported-by: Jiri Slaby <jslaby@suse.cz>
Signed-off-by: Greg Kroah-Hartman gregkh@linuxfoundation.org
commit 75c3d0bf9caebb502e96683b2bc37f9692437e68 upstream.
This patch fixes the incorrect use of __transport_register_session()
in tcm_qla2xxx_check_initiator_node_acl() code, that does not perform
explicit se_tpg->session_lock when accessing se_tpg->tpg_sess_list
to add new se_sess nodes.
Given that tcm_qla2xxx_check_initiator_node_acl() is not called with
qla_hw->hardware_lock held for all accesses of ->tpg_sess_list, the
code should be using transport_register_session() instead.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Giridhar Malavali <giridhar.malavali@qlogic.com>
Cc: Quinn Tran <quinn.tran@qlogic.com>
commit d556546e7ecd9fca199df4698943024d40044f8e upstream.
This patch adds a missing set of conditional check braces in
ft_invl_hw_context() originally introduced by commit dcd998ccd
when handling DDP failures in ft_recv_write_data() code.
commit dcd998ccdbf74a7d8fe0f0a44e85da1ed5975946
Author: Kiran Patil <kiran.patil@intel.com>
Date: Wed Aug 3 09:20:01 2011 +0000
tcm_fc: Handle DDP/SW fc_frame_payload_get failures in ft_recv_write_data
Cc: Kiran Patil <kiran.patil@intel.com>
commit 7b8f10da3bf1056546133c9f54f49ce389fd95ab upstream.
The initialisation of the efm32 clocksource first sets up the irq and only
after that initialises the data needed for irq handling. In case this
initialisation is delayed the irq handler would dereference a NULL pointer.
I'm not aware of anything that could delay the process in such a way, but it's
better to be safe than sorry, so setup the irq only when the clock event device
is ready.
Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Signed-off-by: Yongbae Park <yongbae2@gmail.com>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit 328f494d95aac8bd4896aea2328bc281053bcb71 upstream.
When inserting a new register into a block at the lower end the present
bitmap is currently shifted into the wrong direction. The effect of this is
that the bitmap becomes corrupted and registers which are present might be
reported as not present and vice versa.
Fix this by shifting left rather than right.
Fixes: 472fdec7380c("regmap: rbtree: Reduce number of nodes, take 2")
Reported-by: Daniel Baluta <daniel.baluta@gmail.com>
commit 1096be084ac59927158ce80ff1d31c33eed0e565 upstream.
The interrupt is enabled before the handler is set. Even this bug
did not appear, it is potentially dangerous as it can lead to a
NULL pointer dereference.
Fix the error by enabling the interrupt after
clockevents_config_and_register() is called.
commit 1ecc7586922662e3ca2f3f0c3f17fec8749fc621 upstream.
For PGR reservation of type Write Exclusive Access, allow all non
reservation holding I_T nexuses with active registrations to READ
from the device.
This addresses a bug where active registrations that attempted
to READ would result in an reservation conflict.
Signed-off-by: Lee Duncan <lduncan@suse.com>
commit ae450e246e8540300699480a3780a420a028b73f upstream.
This patch changes core_scsi3_pro_release() logic to allow an
existing AllRegistrants type reservation to be re-reserved by
any registered I_T nexus.
This addresses a issue where AllRegistrants type RESERVE was
receiving RESERVATION_CONFLICT status if dev_pr_res_holder did
not match the same I_T nexus, instead of just returning GOOD
status following spc4r34 Section 5.9.9:
"If the device server receives a PERSISTENT RESERVE OUT command
with RESERVE service action where the TYPE field and the SCOPE
field contain the same values as the existing type and scope
from a persistent reservation holder, it shall not make any
change to the existing persistent reservation and shall complete
the command with GOOD status."
Reported-by: Ilias Tsitsimpis <i.tsitsimpis@gmail.com>
Cc: Ilias Tsitsimpis <i.tsitsimpis@gmail.com>
Cc: Lee Duncan <lduncan@suse.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
commit 6c3c9baa0debeb4bcc52a78c4463a0a97518de10 upstream.
This patch fixes an issue with AllRegistrants reservations where
an unregister operation by the I_T nexus reservation holder would
incorrectly drop the reservation, instead of waiting until the
last active I_T nexus is unregistered as per SPC-4.
This includes updating __core_scsi3_complete_pro_release() to reset
dev->dev_pr_res_holder with another pr_reg for this special case,
as well as a new 'unreg' parameter to determine when the release
is occuring from an implicit unregister, vs. explicit RELEASE.
It also adds special handling in core_scsi3_free_pr_reg_from_nacl()
to release the left-over pr_res_holder, now that pr_reg is deleted
from pr_reg_list within __core_scsi3_complete_pro_release().
commit d16ca7c5198fd668db10d2c7b048ed3359c12c54 upstream.
This patch fixes the usage of R_HOLDER bit for an All Registrants
reservation in READ_FULL_STATUS, where only the registration who
issued RESERVE was being reported as having an active reservation.
It changes core_scsi3_pri_read_full_status() to check ahead of the
list walk of active registrations to see if All Registrants is active,
and if so set R_HOLDER bit and scope/type fields for all active
registrations.
commit 215a8fe4198f607f34ecdbc9969dae783d8b5a61 upstream.
This patch fixes a NULL pointer dereference OOPs with pSCSI backends
within target_core_stat.c code. The bug is caused by a configfs attr
read if no pscsi_dev_virt->pdv_sd has been configured.
Reported-by: Olaf Hering <olaf@aepfle.de>
commit f068fbc82e7696d67b1bb8189306865bedf368b6 upstream.
This patch fixes a iser specific logout bug where early complete()
of conn->conn_logout_comp in iscsit_close_connection() was causing
isert_wait4logout() to complete too soon, triggering a use after
free NULL pointer dereference of iscsi_conn memory.
The complete() was originally added for traditional iscsi-target
when a ISCSI_LOGOUT_OP failed in iscsi_target_rx_opcode(), but given
iser-target does not wait in logout failure, this special case needs
to be avoided.
Reported-by: Sagi Grimberg <sagig@mellanox.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Slava Shwartsman <valyushash@gmail.com>
commit 5f7da044f8bc1cfb21c962edf34bd5699a76e7ae upstream.
This patch fixes a NULL pointer dereference triggered by a late
target_configure_device() -> alloc_workqueue() failure that results
in target_free_device() being called with DF_CONFIGURED already set,
which subsequently OOPses in destroy_workqueue() code.
Currently this only happens at modprobe target_core_mod time when
core_dev_setup_virtual_lun0() -> target_configure_device() fails,
and the explicit target_free_device() gets called.
To address this bug originally introduced by commit 0fd97ccf45, go
ahead and move DF_CONFIGURED to end of target_configure_device()
code to handle this special failure case.
Reported-by: Claudio Fleiner <cmf@daterainc.com>
Cc: Claudio Fleiner <cmf@daterainc.com>
commit 7544e597343e2166daba3f32e4708533aa53c233 upstream.
This patch fixes a se_cmd->cmd_kref leak buf when se_sess->sess_tearing_down
is true within target_get_sess_cmd() submission path code.
This se_cmd reference leak can occur during active session shutdown when
ack_kref=1 is passed by target_submit_cmd_[map_sgls,tmr]() callers.
commit 6302ce4d80aa82b3fdb5c5cd68e7268037091b47 upstream.
This crash was reported:
[ 366.947370] sd 3:0:1:0: [sdb] Spinning up disk....
[ 368.804046] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 368.804072] IP: [<ffffffff81358457>] __mutex_lock_common.isra.7+0x9c/0x15b
[ 368.804098] PGD 0
[ 368.804114] Oops: 0002 [#1] SMP
[ 368.804143] CPU 1
[ 368.804151] Modules linked in: sg netconsole s3g(PO) uinput joydev hid_multitouch usbhid hid snd_hda_codec_via cpufreq_userspace cpufreq_powersave cpufreq_stats uhci_hcd cpufreq_conservative snd_hda_intel snd_hda_codec snd_hwdep snd_pcm sdhci_pci snd_page_alloc sdhci snd_timer snd psmouse evdev serio_raw pcspkr soundcore xhci_hcd shpchp s3g_drm(O) mvsas mmc_core ahci libahci drm i2c_core acpi_cpufreq mperf video processor button thermal_sys dm_dmirror exfat_fs exfat_core dm_zcache dm_mod padlock_aes aes_generic padlock_sha iscsi_target_mod target_core_mod configfs sswipe libsas libata scsi_transport_sas picdev via_cputemp hwmon_vid fuse parport_pc ppdev lp parport autofs4 ext4 crc16 mbcache jbd2 sd_mod crc_t10dif usb_storage scsi_mod ehci_hcd usbcore usb_common
[ 368.804749]
[ 368.804764] Pid: 392, comm: kworker/u:3 Tainted: P W O 3.4.87-logicube-ng.22 #1 To be filled by O.E.M. To be filled by O.E.M./EPIA-M920
[ 368.804802] RIP: 0010:[<ffffffff81358457>] [<ffffffff81358457>] __mutex_lock_common.isra.7+0x9c/0x15b
[ 368.804827] RSP: 0018:ffff880117001cc0 EFLAGS: 00010246
[ 368.804842] RAX: 0000000000000000 RBX: ffff8801185030d0 RCX: ffff88008edcb420
[ 368.804857] RDX: 0000000000000000 RSI: 0000000000000002 RDI: ffff8801185030d4
[ 368.804873] RBP: ffff8801181531c0 R08: 0000000000000020 R09: 00000000fffffffe
[ 368.804885] R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801185030d4
[ 368.804899] R13: 0000000000000002 R14: ffff880117001fd8 R15: ffff8801185030d8
[ 368.804916] FS: 0000000000000000(0000) GS:ffff88011fc80000(0000) knlGS:0000000000000000
[ 368.804931] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 368.804946] CR2: 0000000000000000 CR3: 000000000160b000 CR4: 00000000000006e0
[ 368.804962] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 368.804978] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 368.804995] Process kworker/u:3 (pid: 392, threadinfo ffff880117000000, task ffff8801181531c0)
[ 368.805009] Stack:
[ 368.805017] ffff8801185030d8 0000000000000000 ffffffff8161ddf0 ffffffff81056f7c
[ 368.805062] 000000000000b503 ffff8801185030d0 ffff880118503000 0000000000000000
[ 368.805100] ffff8801185030d0 ffff8801188b8000 ffff88008edcb420 ffffffff813583ac
[ 368.805135] Call Trace:
[ 368.805153] [<ffffffff81056f7c>] ? up+0xb/0x33
[ 368.805168] [<ffffffff813583ac>] ? mutex_lock+0x16/0x25
[ 368.805194] [<ffffffffa018c414>] ? smp_execute_task+0x4e/0x222 [libsas]
[ 368.805217] [<ffffffffa018ce1c>] ? sas_find_bcast_dev+0x3c/0x15d [libsas]
[ 368.805240] [<ffffffffa018ce4f>] ? sas_find_bcast_dev+0x6f/0x15d [libsas]
[ 368.805264] [<ffffffffa018e989>] ? sas_ex_revalidate_domain+0x37/0x2ec [libsas]
[ 368.805280] [<ffffffff81355a2a>] ? printk+0x43/0x48
[ 368.805296] [<ffffffff81359a65>] ? _raw_spin_unlock_irqrestore+0xc/0xd
[ 368.805318] [<ffffffffa018b767>] ? sas_revalidate_domain+0x85/0xb6 [libsas]
[ 368.805336] [<ffffffff8104e5d9>] ? process_one_work+0x151/0x27c
[ 368.805351] [<ffffffff8104f6cd>] ? worker_thread+0xbb/0x152
[ 368.805366] [<ffffffff8104f612>] ? manage_workers.isra.29+0x163/0x163
[ 368.805382] [<ffffffff81052c4e>] ? kthread+0x79/0x81
[ 368.805399] [<ffffffff8135fea4>] ? kernel_thread_helper+0x4/0x10
[ 368.805416] [<ffffffff81052bd5>] ? kthread_flush_work_fn+0x9/0x9
[ 368.805431] [<ffffffff8135fea0>] ? gs_change+0x13/0x13
[ 368.805442] Code: 83 7d 30 63 7e 04 f3 90 eb ab 4c 8d 63 04 4c 8d 7b 08 4c 89 e7 e8 fa 15 00 00 48 8b 43 10 4c 89 3c 24 48 89 63 10 48 89 44 24 08 <48> 89 20 83 c8 ff 48 89 6c 24 10 87 03 ff c8 74 35 4d 89 ee 41
[ 368.805851] RIP [<ffffffff81358457>] __mutex_lock_common.isra.7+0x9c/0x15b
[ 368.805877] RSP <ffff880117001cc0>
[ 368.805886] CR2: 0000000000000000
[ 368.805899] ---[ end trace b720682065d8f4cc ]---
It's directly caused by 89d3cf6 [SCSI] libsas: add mutex for SMP task
execution, but shows a deeper cause: expander functions expect to be able to
cast to and treat domain devices as expanders. The correct fix is to only do
expander discover when we know we've got an expander device to avoid wrongly
casting a non-expander device.
Reported-by: Praveen Murali <pmurali@logicube.com>
Tested-by: Praveen Murali <pmurali@logicube.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit af6fc858a35b90e89ea7a7ee58e66628c55c776b upstream.
Otherwise the guest can abuse that control to cause e.g. PCIe
Unsupported Request responses by disabling memory and/or I/O decoding
and subsequently causing (CPU side) accesses to the respective address
ranges, which (depending on system configuration) may be fatal to the
host.
Note that to alter any of the bits collected together as
PCI_COMMAND_GUEST permissive mode is now required to be enabled
globally or on the specific device.
This is CVE-2015-2150 / XSA-120.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 85e40b0539b24518c8bdf63e2605c8522377d00f upstream.
Using the pvops kernel a NULL pointer dereference was detected on a
large machine (144 processors) when booting as dom0 in
evtchn_fifo_unmask() during assignment of a pirq.
The event channel in question was the first to need a new entry in
event_array[] in events_fifo.c. Unfortunately xen_irq_info_pirq_setup()
is called with evtchn being 0 for a new pirq and the real event channel
number is assigned to the pirq only during __startup_pirq().
It is mandatory to call xen_evtchn_port_setup() after assigning the
event channel number to the pirq to make sure all memory needed for the
event channel is allocated.
Signed-off-by: Juergen Gross <jgross@suse.com>
commit 3458390b9f0ba784481d23134798faee27b5f16f upstream.
To take down the MOB and GMR memory types, the driver may have to issue
fence objects and thus make sure that the fence manager is taken down
after those memory types.
Reorder device init accordingly.
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Sinclair Yeh <syeh@vmware.com>
commit 29d62ec5f87fbeec8413e2215ddad12e7f972e4c upstream.
Normally _regulator_do_enable() isn't called on an already-enabled
rdev. That's because the main caller, _regulator_enable() always
calls _regulator_is_enabled() and only calls _regulator_do_enable() if
the rdev was not already enabled.
However, there is one caller of _regulator_do_enable() that doesn't
check: regulator_suspend_finish(). While we might want to make
regulator_suspend_finish() behave more like _regulator_enable(), it's
probably also a good idea to make _regulator_do_enable() robust if it
is called on an already enabled rdev.
At the moment, _regulator_do_enable() is _not_ robust for already
enabled rdevs if we're using an ena_pin. Each time
_regulator_do_enable() is called for an rdev using an ena_pin the
reference count of the ena_pin is incremented even if the rdev was
already enabled. This is not as intended because the ena_pin is for
something else: for keeping track of how many active rdevs there are
sharing the same ena_pin.
Here's how the reference counting works here:
* Each time _regulator_enable() is called we increment
rdev->use_count, so _regulator_enable() calls need to be balanced
with _regulator_disable() calls.
* There is no explicit reference counting in _regulator_do_enable()
which is normally just a warapper around rdev->desc->ops->enable()
with code for supporting delays. It's not expected that the
"ops->enable()" call do reference counting.
* Since regulator_ena_gpio_ctrl() does have reference counting
(handling the sharing of the pin amongst multiple rdevs), we
shouldn't call it if the current rdev is already enabled.
Note that as part of this we cleanup (remove) the initting of
ena_gpio_state in regulator_register(). In _regulator_do_enable(),
_regulator_do_disable() and _regulator_is_enabled() is is clear that
ena_gpio_state should be the state of whether this particular rdev has
requested the GPIO be enabled. regulator_register() was initting it
as the actual state of the pin.
Fixes: 967cfb18c0e3 ("regulator: core: manage enable GPIO list")
Signed-off-by: Doug Anderson <dianders@chromium.org>
commit 0548bf4f5ad6fc3bd93c4940fa48078b34609682 upstream.
The _regulator_do_enable() call ought to be a no-op when called on an
already-enabled regulator. However, as an optimization
_regulator_enable() doesn't call _regulator_do_enable() on an already
enabled regulator. That means we never test the case of calling
_regulator_do_enable() during normal usage and there may be hidden
bugs or warnings. We have seen warnings issued by the tps65090 driver
and bugs when using the GPIO enable pin.
Let's match the same optimization that _regulator_enable() in
regulator_suspend_finish(). That may speed up suspend/resume and also
avoids exposing hidden bugs.
[Use much clearer commit message from Doug Anderson]
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
commit da293700568ed3d96fcf062ac15d7d7c41377f11 upstream.
EEH recovery for bnx2x based adapters is not reliable on all Power
systems using the default hot reset, which can result in an
unrecoverable EEH error. Forcing the use of fundamental reset
during EEH recovery fixes this.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
commit 8dad0386b97c4bd6edd56752ca7f2e735fe5beb4 upstream.
The NDDB register holds the data that are needed by the read and write
commands.
However, during a read PIO access, the datasheet specifies that after each 32
bytes read in that register, when BCH is enabled, we have to make sure that the
RDDREQ bit is set in the NDSR register.
This fixes an issue that was seen on the Armada 385, and presumably other mvebu
SoCs, when a read on a newly erased page would end up in the driver reporting a
timeout from the NAND.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Reviewed-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Ezequiel Garcia <ezequiel.garcia@free-electrons.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit cd6fa8d2ca53cac3226fdcffcf763be390abae32 upstream.
Commit fd316941c ("spi/pl022: disable port when unused") introduced a race,
which leads to possible driver lock up (easily reproducible on SMP).
The problem happens in giveback() function where the completion of the transfer
is signalled to SPI subsystem and then the HW SPI controller is disabled. Another
transfer might be setup in between, which brings driver in locked-up state.
Exact event sequence on SMP:
core0 core1
=> pump_transfers()
/* message->state == STATE_DONE */
=> giveback()
=> spi_finalize_current_message()
=> pl022_unprepare_transfer_hardware()
=> pl022_transfer_one_message
=> flush()
=> do_interrupt_dma_transfer()
=> set_up_next_transfer()
/* Enable SSP, turn on interrupts */
writew((readw(SSP_CR1(pl022->virtbase)) |
SSP_CR1_MASK_SSE), SSP_CR1(pl022->virtbase));
=> pl022_interrupt_handler()
=> readwriter()
/* disable the SPI/SSP operation */
=> writew((readw(SSP_CR1(pl022->virtbase)) &
(~SSP_CR1_MASK_SSE)), SSP_CR1(pl022->virtbase));
Lockup! SPI controller is disabled and the data will never be received. Whole
SPI subsystem is waiting for transfer ACK and blocked.
So, only signal transfer completion after disabling the controller.
Fixes: fd316941c (spi/pl022: disable port when unused)
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com>
commit 76e1d14b316d6f501ebc001e7a5d86b24ce5b615 upstream.
Additionally to the current DMA transfer the PDC allows to set up a next DMA
transfer. This is useful for larger SPI transfers.
The driver currently waits for ENDRX as end of the transfer. But ENDRX is set
when the current DMA transfer is done (RCR = 0), i.e. it doesn't include the
next DMA transfer.
Thus a subsequent SPI transfer could be started although there is currently a
transfer in progress. This can cause invalid accesses to the SPI slave devices
and to SPI transfer errors.
This issue has been observed on a hardware with a M25P128 SPI NOR flash.
So instead of ENDRX we should wait for RXBUFF. This flag is set if there is
no more DMA transfer in progress (RCR = RNCR = 0).
Signed-off-by: Torsten Fleischer <torfl6749@gmail.com>
commit 62dfd912ab3b5405b6fe72d0135c37e9648071f1 upstream.
Problem: When IMA and VTPM are both enabled in kernel config,
kernel hangs during bootup on LE OS.
Why?: IMA calls tpm_pcr_read() which results in tpm_ibmvtpm_send
and tpm_ibmtpm_recv getting called. A trace showed that
tpm_ibmtpm_recv was hanging.
Resolution: tpm_ibmtpm_recv was hanging because tpm_ibmvtpm_send
was sending CRQ message that probably did not make much sense
to phype because of Endianness. The fix below sends correctly
converted CRQ for LE. This was not caught before because it
seems IMA is not enabled by default in kernel config and
IMA exercises this particular code path in vtpm.
Tested with IMA and VTPM enabled in kernel config and VTPM
enabled on both a BE OS and a LE OS ppc64 lpar. This exercised
CRQ and TPM command code paths in vtpm.
Patch is against Peter's tpmdd tree on github which included
Vicky's previous vtpm le patches.
Signed-off-by: Joy Latten <jmlatten@linux.vnet.ibm.com>
Reviewed-by: Ashley Lai <ashley@ahsleylai.com>
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
commit 969439016d2cf61fef53a973d7e6d2061c3793b1 upstream.
When accessing CAN network interfaces with AF_PACKET sockets e.g. by dhclient
this can lead to a skb_under_panic due to missing skb initialisations.
Add the missing initialisations at the CAN skbuff creation times on driver
level (rx path) and in the network layer (tx path).
Reported-by: Austin Schuh <austin@peloton-tech.com>
Reported-by: Daniel Steer <daniel.steer@mclaren.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit f2e0ea861117bda073d1d7ffbd3120c07c0d5d34 upstream.
I'm still receiving reports to my email address, so let's point this
at the linux-serial mailing list instead.
commit eeb8a7e8bb123e84daeef84f5a2eab99ad2839a2 upstream.
when multiport is off, virtio console invokes config access from irq
context, config access is blocking on s390.
Fix this up by scheduling work from config irq - similar to what we do
for multiport configs.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reviewed-by: Amit Shah <amit.shah@redhat.com>
commit 4f6e24ed9de8634d6471ef86b382cba6d4e57ca8 upstream.
when multiport is off, we don't initialize config work,
but we then cancel uninitialized control_work on freeze.
commit a17d4996e051e78d164989b894608cf37cd5110b upstream.
Just keep it working, seems to fix some PLL problems.
Bug: https://bugs.freedesktop.org/show_bug.cgi?id=73378
Signed-off-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 77ae5f4b48a0445426c9c1ef7c0f28b717e35d55 upstream.
Need to double the viewport height.
commit 54acf107e4e66d1f4a697e08a7f60dba9fcf07c3 upstream.
To make sure the writes go through the pci bridge.
bug:
https://bugzilla.kernel.org/show_bug.cgi?id=90741
commit 0586915ec10d0ae60de5cd3381ad25a704760402 upstream.
bug:
commit cffefd9bb31cd35ab745d3b49005d10616d25bdc upstream.
bug:
commit 9d1393f23d5656cdd5f368efd60694d4aeed81d3 upstream.
bug:
commit f957063fee6392bb9365370db6db74dc0b2dce0a upstream.
bug:
commit c320bb5f6dc0cb88a811cbaf839303e0a3916a92 upstream.
bug:
commit a28b2a47edcd0cb7c051b445f71a426000394606 upstream.
Passing zeroed drm_radeon_cs struct to DRM_IOCTL_RADEON_CS produces the
following oops.
Fix by always calling INIT_LIST_HEAD() to avoid the crash in list_sort().
#include <stdint.h>
#include <fcntl.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <drm/radeon_drm.h>
static const struct drm_radeon_cs cs;
int main(int argc, char **argv)
return ioctl(open(argv[1], O_RDWR), DRM_IOCTL_RADEON_CS, &cs);
[ttrantal@test2 ~]$ ./main /dev/dri/card0
[ 46.904650] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 46.905022] IP: [<ffffffff814d6df2>] list_sort+0x42/0x240
[ 46.905022] PGD 68f29067 PUD 688b5067 PMD 0
[ 46.905022] Oops: 0002 [#1] SMP
[ 46.905022] CPU: 0 PID: 2413 Comm: main Not tainted 4.0.0-rc1+ #58
[ 46.905022] Hardware name: Hewlett-Packard HP Compaq dc5750 Small Form Factor/0A64h, BIOS 786E3 v02.10 01/25/2007
[ 46.905022] task: ffff880058e2bcc0 ti: ffff880058e64000 task.ti: ffff880058e64000
[ 46.905022] RIP: 0010:[<ffffffff814d6df2>] [<ffffffff814d6df2>] list_sort+0x42/0x240
[ 46.905022] RSP: 0018:ffff880058e67998 EFLAGS: 00010246
[ 46.905022] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[ 46.905022] RDX: ffffffff81644410 RSI: ffff880058e67b40 RDI: ffff880058e67a58
[ 46.905022] RBP: ffff880058e67a88 R08: 0000000000000000 R09: 0000000000000000
[ 46.905022] R10: ffff880058e2bcc0 R11: ffffffff828e6ca0 R12: ffffffff81644410
[ 46.905022] R13: ffff8800694b8018 R14: 0000000000000000 R15: ffff880058e679b0
[ 46.905022] FS: 00007fdc65a65700(0000) GS:ffff88006d600000(0000) knlGS:0000000000000000
[ 46.905022] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 46.905022] CR2: 0000000000000000 CR3: 0000000058dd9000 CR4: 00000000000006f0
[ 46.905022] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 46.905022] DR3: 0000000000000000 DR6: 00000000ffff4ff0 DR7: 0000000000000400
[ 46.905022] Stack:
[ 46.905022] ffff880058e67b40 ffff880058e2bcc0 ffff880058e67a78 0000000000000000
[ 46.905022] 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 46.905022] Call Trace:
[ 46.905022] [<ffffffff81644a65>] radeon_cs_parser_fini+0x195/0x220
[ 46.905022] [<ffffffff81645069>] radeon_cs_ioctl+0xa9/0x960
[ 46.905022] [<ffffffff815e1f7c>] drm_ioctl+0x19c/0x640
[ 46.905022] [<ffffffff810f8fdd>] ? trace_hardirqs_on_caller+0xfd/0x1c0
[ 46.905022] [<ffffffff810f90ad>] ? trace_hardirqs_on+0xd/0x10
[ 46.905022] [<ffffffff8160c066>] radeon_drm_ioctl+0x46/0x80
[ 46.905022] [<ffffffff81211868>] do_vfs_ioctl+0x318/0x570
[ 46.905022] [<ffffffff81462ef6>] ? selinux_file_ioctl+0x56/0x110
[ 46.905022] [<ffffffff81211b41>] SyS_ioctl+0x81/0xa0
[ 46.905022] [<ffffffff81dc6312>] system_call_fastpath+0x12/0x17
[ 46.905022] Code: 48 89 b5 10 ff ff ff 0f 84 03 01 00 00 4c 8d bd 28 ff ff
ff 31 c0 48 89 fb b9 15 00 00 00 49 89 d4 4c 89 ff f3 48 ab 48 8b 46 08 <48> c7
00 00 00 00 00 48 8b 0e 48 85 c9 0f 84 7d 00 00 00 c7 85
[ 46.905022] RIP [<ffffffff814d6df2>] list_sort+0x42/0x240
[ 46.905022] RSP <ffff880058e67998>
[ 47.149253] ---[ end trace 09576b4e8b2c20b8 ]---
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
[ Upstream commit 8d006e0105978619fb472e150c88b0d49337fe2b ]
This reverts commit 11ad714b98f6d9ca0067568442afe3e70eb94845 because
it breaks cx82310_eth.
The custom USB_DEVICE_CLASS macro matches
bDeviceClass, bDeviceSubClass and bDeviceProtocol
but the common USB_DEVICE_AND_INTERFACE_INFO matches
bInterfaceClass, bInterfaceSubClass and bInterfaceProtocol instead, which are
not specified.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Commit e7f3db14eacaf1993a70b1517582603dfdf34988 (89bb35e200bee745c539a96666e0792301ca40f1 upstream) was backported incorrectly by me, so fix it up, as the driver is now broken.
Sorry about that.
Reported-by: Kristina Martšenko <kristina.martsenko@gmail.com>
Cc: Jonathan Cameron <jic23@kernel.org>
