commit 5eb0d6eb3fac3daa60d9190eed9fa41cf809c756 upstream.
aic5_irq_domain_xlate() and aic_irq_domain_xlate() take the generic chip
lock without disabling interrupts, which can lead to a deadlock if an
interrupt occurs while the lock is held in one of these functions.
Replace irq_gc_{lock,unlock}() calls by
irq_gc_{lock_irqsave,unlock_irqrestore}() ones to prevent this bug from
happening.
Fixes: b1479ebb7720 ("irqchip: atmel-aic: Add atmel AIC/AIC5 drivers")
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Link: http://lkml.kernel.org/r/1473775109-4192-2-git-send-email-boris.brezillon@free-electrons.com
commit 47a66e45d7a7613322549c2475ea9d809baaf514 upstream.
Similar to struct drm_update_draw, struct drm_mode_fb_cmd2 has an
unaligned 64 bit field (modifier). This get packed differently between
32 bit and 64 bit modes on architectures that can handle unaligned 64
bit access (X86 and IA64). Other architectures pack the structs the
same and don't need the compat wrapper. Use the same condition for
drm_mode_fb_cmd2 as we use for drm_update_draw.
Note that only the modifier will be packed differently between compat
and non-compat versions.
Reviewed-by: Rob Clark <robdclark@gmail.com>
Signed-off-by: Kristian H. Kristensen <hoegsberg@chromium.org>
[seanpaul added not at bottom of commit msg re: modifier]
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Link: http://patchwork.freedesktop.org/patch/msgid/1473801645-116011-1-git-send-email-hoegsberg@chromium.org
commit d31ed3f05763644840c654a384eaefa94c097ba2 upstream.
The code is applying the same scaling for the X and Y components,
thus making the scaling feature only functional when both components
have the same scaling factor.
Do the s/_w/_h/ replacement where appropriate to fix vertical scaling.
Signed-off-by: Jan Leupold <leupold@rsi-elektrotechnik.de>
Fixes: 1a396789f65a2 ("drm: add Atmel HLCDC Display Controller support")
commit 00affcac69c7aae6c2cfcbc71f724e1c16d0b445 upstream.
gcc warns about the 'found' variable possibly being used uninitialized:
drivers/soc/qcom/spm.c: In function 'spm_dev_probe':
drivers/soc/qcom/spm.c:305:5: error: 'found' may be used uninitialized in this function [-Werror=maybe-uninitialized]
However, the code is correct because we know that there is
always at least one online CPU. This initializes the 'found'
variable to zero before the loop so the compiler knows
it does not have to warn about it.
commit 32844138e31347fc0f61d3bf2d7b9c4583f189e3 upstream.
resource_size_t may be defined as 32 or 64 bit depending on configuration,
so it cannot be printed using the normal format strings, as gcc correctly
warns:
pinctrl-at91-pio4.c: In function 'atmel_pinctrl_probe':
pinctrl-at91-pio4.c:1003:41: warning: format '%u' expects argument of type 'unsigned int', but argument 5 has type 'resource_size_t {aka long long unsigned int}' [-Wformat=]
dev_dbg(dev, "bank %i: hwirq=%u\n", i, res->start);
This changes the format string to use the special "%pr" format
string that prints a resource, and changes the arguments so we
the resource structure directly.
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
commit 260b31643691e8a58683a4ccc3bdf7abfd86f54a upstream.
The dw_mmc driver stores the physical address of the MMIO registers
in a pointer, which requires the use of type casts, and is actually
broken if anyone ever has this device on a 32-bit SoC in registers
above 4GB. Gcc warns about this possibility when the driver is built
with ARM LPAE enabled:
mmc/host/dw_mmc.c: In function 'dw_mci_edmac_start_dma':
mmc/host/dw_mmc.c:702:17: warning: cast from pointer to integer of different size
cfg.dst_addr = (dma_addr_t)(host->phy_regs + fifo_offset);
mmc/host/dw_mmc-pltfm.c: In function 'dw_mci_pltfm_register':
mmc/host/dw_mmc-pltfm.c:63:19: warning: cast to pointer from integer of different size
host->phy_regs = (void *)(regs->start);
This changes the code to use resource_size_t, which gets rid of the
warning, the bug and the useless casts.
Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 44eb0cb9620c6a53ec8e7073262e2af8079b727f upstream.
VMA offsets are 64 bits. Plane surface offsets are in ggtt and
the hardware register to set this is thus 32 bits. Be explicit
about these and convert carefully to from vma to final size.
This will make sparse happy by not creating 32bit pointers out
of 64bit vma offsets.
Cc: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1446204375-29831-1-git-send-email-mika.kuoppala@intel.com
Reviewed-by: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
commit 166c5a6ef765653848161e6f4af81c05e4b3ecf6 upstream.
In commit e45708976aea ("drm/dp-helper: Move the legacy helpers to
gma500") the legacy i2c helpers were moved to the only remaining user of
them, the gma500 driver. Together with that move, i2c_dp_aux_add_bus()
was marked deprecated and started warning about its remaining use.
It's now been a year and a half of annoying warning, and apparently
nobody cares enough about gma500 to try to move it along to the more
modern models.
Get rid of the warning - if even the gma500 people don't care enough,
then they should certainly not spam other innocent developers with a
warning that might hide other, much more real issues.
Cc: Daniel Vetter <daniel.vetter@intel.com>
Cc: Alan Cox <alan@linux.intel.com>
commit 7711aaf08ad3fc4d0e937eec1de0a63620444ce7 upstream.
A station pointer can be passed to the driver on tx, before it has been
marked as associated. Since ath9k_sta_state was initializing the entry
too late, it resulted in some spurious crashes.
Fixes: df3c6eb34da5 ("ath9k: Use sta_state() callback")
Signed-off-by: Felix Fietkau <nbd@nbd.name>
Signed-off-by: Kalle Valo <kvalo@qca.qualcomm.com>
commit 47a7b0d8888c04c9746812820b6e60553cc77bbc upstream.
The md-cluster is compiled as module by default,
if it is compiled by built-in way, then we can't
make md-cluster works.
[64782.630008] md/raid1:md127: active with 2 out of 2 mirrors
[64782.630528] md-cluster module not found.
[64782.630530] md127: Could not setup cluster service (-2)
Fixes: edb39c9 ("Introduce md_cluster_operations to handle cluster functions")
Reported-by: Marc Smith <marc.smith@mcc.edu>
Reviewed-by: NeilBrown <neilb@suse.com>
Signed-off-by: Guoqing Jiang <gqjiang@suse.com>
Signed-off-by: Shaohua Li <shli@fb.com>
commit bcf42aa60c2832510b9be0f30c090bfd35bb172d upstream.
The stop endpoint command has its own 5 second timeout timer.
If the timeout function is triggered between USB3 and USB2 host
removal it will try to call usb_hc_died(xhci_to_hcd(xhci)->primary_hcd)
the ->primary_hcd will be set to NULL at USB3 hcd removal.
Fix this by first checking if the PCI host is being removed, and
also by using only xhci_to_hcd() as it will always return the primary
hcd.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 486095fae3a8a6b1ae07c51844699d9bd5cfbebc upstream.
PG8, PG9 is said to be the CTS/RTS pins for UART1 according to the A23/33
datasheets. However, the function is wrongly named "uart2" in the pinctrl
driver. This patch fixes this by modifying them to be named "uart1".
Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit a32ac2912f97d7ea9b67eb67bb4aa30b9156a88e upstream.
A previous patch attempted to fix the pinmuxes for mfio 84 - 89, but it
omitted a change to pistachio_pin_group pistachio_groups, which results
in incorrect pll_lock signals being routed.
Apply the correct mux settings throughout the driver.
fixes: cefc03e5995e ("pinctrl: Add Pistachio SoC pin control driver")
fixes: e9adb336d0bf ("pinctrl: pistachio: fix mfio84-89 function description and pinmux.")
Signed-off-by: James Hartley <james.hartley@imgtec.com>
Reviewed-by: Sifan Naeem <Sifan.Naeem@imgtec.com>
commit 4e870e948fbabf62b78e8410f04c67703e7c816b upstream.
When dm-crypt processes writes, it allocates a new bio in
crypt_alloc_buffer(). The bio is allocated from a bio set and it can
have at most BIO_MAX_PAGES vector entries, however the incoming bio can be
larger (e.g. if it was allocated by bcache). If the incoming bio is
larger, bio_alloc_bioset() fails and an error is returned.
To avoid the error, we test for a too large bio in the function
crypt_map() and use dm_accept_partial_bio() to split the bio.
dm_accept_partial_bio() trims the current bio to the desired size and
asks DM core to send another bio with the rest of the data.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit a5d60783df61fbb67b7596b8a0f6b4b2e05251d5 upstream.
Move log_one_block()'s atomic_inc(&lc->io_blocks) before bio_alloc() to
fix a bug that the target hangs if bio_alloc() fails. The error path
does put_io_block(lc), so atomic_inc(&lc->io_blocks) must occur before
invoking the error path to avoid underflow of lc->io_blocks.
Reviewed-by: Josef Bacik <jbacik@fb.com>
commit 91e630d9ae6de6f740ef7c8176736eb55366833e upstream.
The kthread_run() function returns either a valid task_struct or
ERR_PTR() value, check for NULL is invalid. This change fixes potential
for oops, e.g. in OOM situation.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
commit b928466b2169e061822daad48ecf55b005445547 upstream.
The code setting XP watchpoint comparator and mask registers should, in
order to be fully compliant with specification, zero one or more most
significant bits of each field. In both L cases it means zeroing bit 63.
The bitmask doing this was wrong, though, zeroing bit 60 instead.
Fortunately, due to a lucky coincidence, this turned out to be fairly
innocent with the existing hardware.
Fixed now.
Signed-off-by: Pawel Moll <pawel.moll@arm.com>
commit b7c1beb278e8e3dc664ed3df3fc786db126120a9 upstream.
Fuzzing the CCN perf driver revealed a small but definitely dangerous
mistake in the event setup code. When a cycle counter is requested, the
driver should not reconfigure the events bus at all, otherwise it will
corrupt (in most but the simplest cases) its configuration and may end
up accessing XP array out of its bounds and corrupting control
registers.
Reported-by: Mark Rutland <mark.rutland@arm.com>
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Tested-by: Mark Rutland <mark.rutland@arm.com>
commit 4e486cba285ff06a1f28f0fc2991dde1482d1dcf upstream.
The "Miscellaneous Node" fell through cracks of node initialisation,
as its ID is shared with HN-I.
This patch treats MN as a special case (which it is), adding separate
validation check for it and pre-defining the node ID in relevant events
descriptions. That way one can simply run:
# perf stat -a -e ccn/mn_ecbarrier/ <workload>
Additionally, direction in the MN pseudo-events XP watchpoint
definitions is corrected to be "TX" (1) as they are defined from the
crosspoint point of view (thus barriers are transmitted from XP to MN).
commit 1423661fed2c40d6d71b5e2e3aa390f85157f9d5 upstream.
The ethtool_ops .get_regs function attempts to read the nonexistent
register NIC_QSET_SQ_0_7_CNM_CHG, which produces a "bus error" type
OOPs.
Fix by not attempting to read, and removing the definition of,
NIC_QSET_SQ_0_7_CNM_CHG. A zero is written into the register dump to
keep the layout unchanged.
Signed-off-by: David Daney <david.daney@cavium.com>
commit 08c5cd37480f59ea39682f4585d92269be6b1424 upstream.
Some full-speed mceusb infrared transceivers contain invalid endpoint
descriptors for their interrupt endpoints, with bInterval set to 0.
In the past they have worked out okay with the mceusb driver, because
the driver sets the bInterval field in the descriptor to 1,
overwriting whatever value may have been there before. However, this
approach was never sanctioned by the USB core, and in fact it does not
work with xHCI controllers, because they use the bInterval value that
was present when the configuration was installed.
Currently usbcore uses 32 ms as the default interval if the value in
the endpoint descriptor is invalid. It turns out that these IR
transceivers don't work properly unless the interval is set to 10 ms
or below. To work around this mceusb problem, this patch changes the
endpoint-descriptor parsing routine, making the default interval value
be 10 ms rather than 32 ms.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Wade Berrier <wberrier@gmail.com>
commit 6f3c4fb6d05e63c9c6d8968302491c3a5457be61 upstream.
Problems with the signal integrity of the high speed USB data lines or
noise on reference ground lines can cause the i.MX6 USB controller to
violate USB specs and exhibit unexpected behavior.
It was observed that USBi_UI interrupts were triggered first and when
isr_setup_status_phase was called, ci->status was NULL, which lead to a
NULL pointer dereference kernel panic.
This patch fixes the kernel panic, emits a warning once and returns
-EPIPE to halt the device and let the host get stalled.
It also adds a comment to point people, who are experiencing this issue,
to their USB hardware design.
Signed-off-by: Clemens Gruber <clemens.gruber@pqgruber.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
commit 519d8bd4b5d3d82c413eac5bb42b106bb4b9ec15 upstream.
The previous driver is possible to stop the transfer wrongly.
For example:
1) An interrupt happens, but not BRDY interruption.
2) Read INTSTS0. And than state->intsts0 is not set to BRDY.
3) BRDY is set to 1 here.
4) Read BRDYSTS.
5) Clear the BRDYSTS. And then. the BRDY is cleared wrongly.
Remarks:
- The INTSTS0.BRDY is read only.
- If any bits of BRDYSTS are set to 1, the BRDY is set to 1.
- If BRDYSTS is 0, the BRDY is set to 0.
So, this patch adds condition to avoid such situation. (And about
NRDYSTS, this is not used for now. But, avoiding any side effects,
this patch doesn't touch it.)
Fixes: d5c6a1e024dd ("usb: renesas_usbhs: fixup interrupt status clear method")
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit f190fd92458da3e869b4e2c6289e2c617490ae53 upstream.
This patch adds support for Infineon flashloader 0x8087/0x0801.
The flashloader is used in Telit LE940B modem family with Telit
flashing application.
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit c8d192428f52f244130b84650ad616df09f2b1e1 upstream.
Added devices ids for acces i/o products quad and octal serial cards
that make use of existing Pericom PI7C9X7954 and PI7C9X7958
configurations .
Signed-off-by: Jimi Damon <jdamon@accesio.com>
commit 47b34d2ef266e2c283b514d65c8963c2ccd42474 upstream.
Since the commit c1a67b48f6a5 ("serial: 8250_pci: replace switch-case by
formula for Intel MID"), the 8250 driver crashes in the byt_set_termios()
function with a divide error. This is caused by the fact that a baud rate of 0
(B0) is not handled properly. Fix it by falling back to B9600 in this case.
Reported-by: "Mendez Salinas, Fernando" <fernando.mendez.salinas@intel.com>
Fixes: c1a67b48f6a5 ("serial: 8250_pci: replace switch-case by formula for Intel MID")
commit 5dba4b14bafe801083d01e1f400816df7e5a8f2e upstream.
A recent fix to iio_buffer_read_first_n_outer removed ret from being set by
a return from wait_event_interruptible and also added a continue in a loop
which causes the variable ret to not be set when it reaches the end of the
loop. Fix this by initializing ret to zero.
Also remove extraneous white space at the end of the loop.
Fixes: fcf68f3c0bb2a5 ("fix sched WARNING "do not call blocking ops when !TASK_RUNNING")
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 171c0091837c81ed5c949fec6966bb5afff2d1cf upstream.
7985e7c100 ("iio: Introduce a new fractional value type") introduced a
new IIO_VAL_FRACTIONAL value type meant to represent rational type numbers
expressed by a numerator and denominator combination.
Formating of IIO_VAL_FRACTIONAL values relies upon do_div() usage. This
fails handling negative values properly since parameters are reevaluated
as unsigned values.
Fix this by using div_s64_rem() instead. Computed integer part will carry
properly signed value. Formatted fractional part will always be positive.
Fixes: 7985e7c100 ("iio: Introduce a new fractional value type")
Signed-off-by: Gregor Boirie <gregor.boirie@parrot.com>
Reviewed-by: Lars-Peter Clausen <lars@metafoo.de>
commit 307fe9dd11ae44d4f8881ee449a7cbac36e1f5de upstream.
All the scaling of the KXSD9 involves multiplication with a
fraction number < 1.
However the scaling value returned from IIO_INFO_SCALE was
unpredictable as only the micros of the value was assigned, and
not the integer part, resulting in scaling like this:
$cat in_accel_scale
-1057462640.011978
Fix this by assigning zero to the integer part.
Tested-by: Jonathan Cameron <jic23@kernel.org>
commit 36afb176d3c9580651d7f410ed7f000ec48b5137 upstream.
According to IIO ABI definition, IIO_PRESSURE data output unit is
kilopascal:
http://lxr.free-electrons.com/source/Documentation/ABI/testing/sysfs-bus-iio
This patch fix output unit of HID pressure sensor IIO driver from pascal to
kilopascal to follow IIO ABI definition.
Signed-off-by: Kweh, Hock Leong <hock.leong.kweh@intel.com>
Reviewed-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
commit 1c500840934a138bd6b13556c210516e9301fbee upstream.
In at least one known setup, the chip comes up in a state where reading
the chip ID returns garbage unless it's been reset, due to noise on the
wires during system boot.
All supported chips have the same reset method, and based on the
datasheets they all need 1.3 or 1.8ms to recover after reset. So, do
the conservative thing here and always reset the chip.
commit c2ab447454d498e709d9011c0f2d2945ee321f9b upstream.
The driver always assumes that an input device has been created when
reading channel 3. This causes a kernel panic when dereferencing
st->ts_input.
The change was introduced in
commit 84882b060301 ("iio: adc: at91_adc: Add support for touchscreens
without TSMR"). Earlier versions only entered that part of the if-else
statement if only the following flags are set:
AT91_ADC_IER_XRDY | AT91_ADC_IER_YRDY | AT91_ADC_IER_PRDY
Signed-off-by: Anders Darander <anders@chargestorm.se>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
commit 7d3cc21dab5313a02f2f3ca8164529b828a030d1 upstream.
The data buffer for captured mode for the ad799x driver is allocated in the
update_scan_mode() callback. This callback is not set in the iio_info
struct for the ad7791/ad7995/ad7999, which means that the data buffer is
not allocated when a captured transfer is started. As a result the driver
crashes when the first sample is received. To fix this properly set the
Fixes: d8dca33027c1 ("staging:iio:ad799x: Preallocate sample buffer")
commit 7175cce1c3f1d8c8840d2004f78f96a3904249b5 upstream.
Now that open delay and sample delay for each channel is configurable
via DT, the default IDLE_TIMEOUT value is not enough as this is
calculated based on hardcoded macros. This results in driver returning
EBUSY sometimes. Fix this by increasing the timeout
value based on maximum value possible to open delay and sample delays
for each channel.
Fixes: 5dc11e810676e ("iio: adc: ti_am335x_adc: make sample delay, open delay, averaging DT parameters")
Signed-off-by: Vignesh R <vigneshr@ti.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
commit 90c43ec6997a892448f1f86180a515f59cafd8a3 upstream.
It is possible that two or more ADC channels can be simultaneously
requested for raw samples, in which case there can be race in access to
FIFO data resulting in loss of samples.
If am335x_tsc_se_set_once() is called again from tiadc_read_raw(), when
ADC is still acquired to sample one of the channels, the second process
might be put into uninterruptible sleep state. Fix these issues, by
protecting FIFO access and channel configurations with a mutex. Since
tiadc_read_raw() might take anywhere between few microseconds to few
milliseconds to finish execution (depending on averaging and delay
values supplied via DT), its better to use mutex instead of spinlock.
Fixes: 7ca6740cd1cd4 ("mfd: input: iio: ti_amm335x: Rework TSC/ADC synchronization")
commit 543852af8e5902aee8f7c72c89e1513663e0f696 upstream.
SARADC controller needs to be reset before programming it, otherwise
it will not function properly.
Signed-off-by: Caesar Wang <wxt@rock-chips.com>
Cc: Jonathan Cameron <jic23@kernel.org>
Cc: Heiko Stuebner <heiko@sntech.de>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: linux-iio@vger.kernel.org
Cc: linux-rockchip@lists.infradead.org
Tested-by: Guenter Roeck <linux@roeck-us.net>
commit f8adf645db03345af2d9a8b6095b02327ea50885 upstream.
Use the iio_pollfunc_store_time parameter during triggered buffer
set-up to get valid timestamps.
Signed-off-by: Alison Schofield <amsfield22@gmail.com>
Cc: Daniel Baluta <daniel.baluta@gmail.com>
commit 7ac61a062f3147dc23e3f12b9dfe7c4dd35f9cb8 upstream.
Any readings from the raw interface of the KXSD9 driver will
return an empty string, because it does not return
IIO_VAL_INT but rather some random value from the accelerometer
to the caller.
commit d1e09f304a1d9651c5059ebfeb696dc2effc9b32 upstream.
Fixes an oops that might happen if uverbs_close races with
remove_one.
Both contexts may run ib_uverbs_cleanup_ucontext, it depends
on the flow.
Currently, there is no protection for a case that remove_one
didn't make the cleanup it runs to its end, the underlying
ib_device was freed then uverbs_close will call
ib_uverbs_cleanup_ucontext and OOPs.
Above might happen if uverbs_close deleted the file from the list
then remove_one didn't find it and runs to its end.
Fixes to protect against that case by a new cleanup lock so that
ib_uverbs_cleanup_ucontext will be called always before that
remove_one is ended.
Fixes: 35d4a0b63dc0 ("IB/uverbs: Fix race between ib_uverbs_open and remove_one")
Reported-by: Devesh Sharma <devesh.sharma@broadcom.com>
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Yishai Hadas <yishaih@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 299f6230bc6d0ccd5f95bb0fb865d80a9c7d5ccc upstream.
v4.8-rc3 commit 99f3c90d0d ("dm flakey: error READ bios during the
down_interval") overlooked the 'drop_writes' feature, which is meant to
allow reads to be issued rather than errored, during the down_interval.
Fixes: 99f3c90d0d ("dm flakey: error READ bios during the down_interval")
Reported-by: Qu Wenruo <quwenruo@cn.fujitsu.com>
commit 16c6d048d7b74249a4387700887e8adb13028866 upstream.
The bio is not returned if the data page cannot be allocated.
Signed-off-by: Wenwei Tao <ww.tao0320@gmail.com>
Signed-off-by: Matias Bjørling <m@bjorling.me>
Signed-off-by: Jens Axboe <axboe@fb.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
function
commit b53e7d000d9e6e9fd2c6eb6b82d2783c67fd599e upstream.
The bootloader (U-boot) sometimes uses this timer for various delays.
It uses it as a ongoing counter, and does comparisons on the current
counter value. The timer counter is never stopped.
In some cases when the user interacts with the bootloader, or lets
it idle for some time before loading Linux, the timer may expire,
and an interrupt will be pending. This results in an unexpected
interrupt when the timer interrupt is enabled by the kernel, at
which point the event_handler isn't set yet. This results in a NULL
pointer dereference exception, panic, and no way to reboot.
Clear any pending interrupts after we stop the timer in the probe
function to avoid this.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit 8a092e682f20f193f2070dba2ea1904e95814126 upstream.
Bypass support was added in commit d38018f2019c ("regulator: anatop: Add
bypass support to digital LDOs"). A check for valid voltage selectors was
added in commit da0607c8df5c ("regulator: anatop: Fail on invalid voltage
selector") but it also discards all regulators that are in bypass mode. Add
check for the bypass setting. Errors below were seen on a Variscite mx6
board.
anatop_regulator 20c8000.anatop:regulator-vddcore@140: Failed to read a valid default voltage selector.
anatop_regulator: probe of 20c8000.anatop:regulator-vddcore@140 failed with error -22
anatop_regulator 20c8000.anatop:regulator-vddsoc@140: Failed to read a valid default voltage selector.
anatop_regulator: probe of 20c8000.anatop:regulator-vddsoc@140 failed with error -22
Fixes: da0607c8df5c ("regulator: anatop: Fail on invalid voltage selector")
Signed-off-by: Mika Båtsman <mbatsman@mvista.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit 48a61e1e2af8020f11a2b8f8dc878144477623c6 upstream.
Add proper error path (for disabling runtime PM) when registering of
hwrng fails.
Fixes: b329669ea0b5 ("hwrng: exynos - Add support for Exynos random number generator")
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
commit e43e94c1eda76dabd686ddf6f7825f54d747b310 upstream.
Currently, the userspace governor only updates frequency on GOV_LIMITS
if policy->cur falls outside policy->{min/max}. However, it is also
necessary to update current frequency on GOV_LIMITS to match the user
requested value if it can be achieved within the new policy->{max/min}.
This was previously the behaviour in the governor until commit d1922f0
("cpufreq: Simplify userspace governor") which incorrectly assumed that
policy->cur == user requested frequency via scaling_setspeed. This won't
be true if the user requested frequency falls outside policy->{min/max}.
Ex: a temporary thermal cap throttled the user requested frequency.
Fix this by storing the user requested frequency in a seperate variable.
The governor will then try to achieve this request on every GOV_LIMITS
change.
Fixes: d1922f02562f (cpufreq: Simplify userspace governor)
Signed-off-by: Sai Gurrappadi <sgurrappadi@nvidia.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
commit a87eeb900dbb9f8202f96604d56e47e67c936b9d upstream.
Commit 655ee63cf371 ("scsi constants: command, sense key + additional
sense string") added a "Completed" sense string with key 0xF to
snstext[], but failed to updated the upper bounds check of the sense key
in scsi_sense_key_string().
Fixes: 655ee63cf371 ("[SCSI] scsi constants: command, sense key + additional sense strings")
Signed-off-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
commit 8b18e2359aff2ab810aba84cebffc9da07fef78f upstream.
For algorithms that implement IV generators before the crypto ops,
the IV needed for decryption is initially located in req->src
scatterlist, not in req->iv.
Avoid copying the IV into req->iv by modifying the (givdecrypt)
descriptors to load it directly from req->src.
aead_givdecrypt() is no longer needed and goes away.
Fixes: 479bcc7c5b9e ("crypto: caam - Convert authenc to new AEAD interface")
Signed-off-by: Horia Geantă <horia.geanta@nxp.com>
commit a77ec83a57890240c546df00ca5df1cdeedb1cc3 upstream.
The address of the iovec &vq->iov[out] is not guaranteed to contain the scsi
command's response iovec throughout the lifetime of the command. Rather, it
is more likely to contain an iovec from an immediately following command
after looping back around to vhost_get_vq_desc(). Pass along the iovec
entirely instead.
Fixes: 79c14141a487 ("vhost/scsi: Convert completion path to use copy_to_iter")
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit acc9cf8c66c66b2cbbdb4a375537edee72be64df upstream.
This patch fixes a cachedev registration-time allocation deadlock.
This can deadlock on boot if your initrd auto-registeres bcache devices:
Allocator thread:
[ 720.727614] INFO: task bcache_allocato:3833 blocked for more than 120 seconds.
[ 720.732361] [<ffffffff816eeac7>] schedule+0x37/0x90
[ 720.732963] [<ffffffffa05192b8>] bch_bucket_alloc+0x188/0x360 [bcache]
[ 720.733538] [<ffffffff810e6950>] ? prepare_to_wait_event+0xf0/0xf0
[ 720.734137] [<ffffffffa05302bd>] bch_prio_write+0x19d/0x340 [bcache]
[ 720.734715] [<ffffffffa05190bf>] bch_allocator_thread+0x3ff/0x470 [bcache]
[ 720.735311] [<ffffffff816ee41c>] ? __schedule+0x2dc/0x950
[ 720.735884] [<ffffffffa0518cc0>] ? invalidate_buckets+0x980/0x980 [bcache]
Registration thread:
[ 720.710403] INFO: task bash:3531 blocked for more than 120 seconds.
[ 720.715226] [<ffffffff816eeac7>] schedule+0x37/0x90
[ 720.715805] [<ffffffffa05235cd>] __bch_btree_map_nodes+0x12d/0x150 [bcache]
[ 720.716409] [<ffffffffa0522d30>] ? bch_btree_insert_check_key+0x1c0/0x1c0 [bcache]
[ 720.717008] [<ffffffffa05236e4>] bch_btree_insert+0xf4/0x170 [bcache]
[ 720.717586] [<ffffffff810e6950>] ? prepare_to_wait_event+0xf0/0xf0
[ 720.718191] [<ffffffffa0527d9a>] bch_journal_replay+0x14a/0x290 [bcache]
[ 720.718766] [<ffffffff810cc90d>] ? ttwu_do_activate.constprop.94+0x5d/0x70
[ 720.719369] [<ffffffff810cf684>] ? try_to_wake_up+0x1d4/0x350
[ 720.719968] [<ffffffffa05317d0>] run_cache_set+0x580/0x8e0 [bcache]
[ 720.720553] [<ffffffffa053302e>] register_bcache+0xe2e/0x13b0 [bcache]
[ 720.721153] [<ffffffff81354cef>] kobj_attr_store+0xf/0x20
[ 720.721730] [<ffffffff812a2dad>] sysfs_kf_write+0x3d/0x50
[ 720.722327] [<ffffffff812a225a>] kernfs_fop_write+0x12a/0x180
[ 720.722904] [<ffffffff81225177>] __vfs_write+0x37/0x110
[ 720.723503] [<ffffffff81228048>] ? __sb_start_write+0x58/0x110
[ 720.724100] [<ffffffff812cedb3>] ? security_file_permission+0x23/0xa0
[ 720.724675] [<ffffffff812258a9>] vfs_write+0xa9/0x1b0
[ 720.725275] [<ffffffff8102479c>] ? do_audit_syscall_entry+0x6c/0x70
[ 720.725849] [<ffffffff81226755>] SyS_write+0x55/0xd0
[ 720.726451] [<ffffffff8106a390>] ? do_page_fault+0x30/0x80
[ 720.727045] [<ffffffff816f2cae>] system_call_fastpath+0x12/0x71
The fifo code in upstream bcache can't use the last element in the buffer,
which was the cause of the bug: if you asked for a power of two size,
it'd give you a fifo that could hold one less than what you asked for
rather than allocating a buffer twice as big.
Signed-off-by: Kent Overstreet <kent.overstreet@gmail.com>
Tested-by: Eric Wheeler <bcache@linux.ewheeler.net>
commit 57b8f112cfe6622ddddb8c2641206bb5fa8a112d upstream.
