path: root/drivers
2021-11-04Merge tag 'v4.4.291' into toradex_vf_4.4-nexttoradex_vf_4.4-nexttoradex_vf_4.4Max Krummenacher
This is the 4.4.291 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-11-02regmap: Fix possible double-free in regcache_rbtree_exit()Yang Yingliang
commit 55e6d8037805b3400096d621091dfbf713f97e83 upstream. In regcache_rbtree_insert_to_block(), when 'present' realloc failed, the 'blk' which is supposed to assign to 'rbnode->block' will be freed, so 'rbnode->block' points a freed memory, in the error handling path of regcache_rbtree_init(), 'rbnode->block' will be freed again in regcache_rbtree_exit(), KASAN will report double-free as follows: BUG: KASAN: double-free or invalid-free in kfree+0xce/0x390 Call Trace: slab_free_freelist_hook+0x10d/0x240 kfree+0xce/0x390 regcache_rbtree_exit+0x15d/0x1a0 regcache_rbtree_init+0x224/0x2c0 regcache_init+0x88d/0x1310 __regmap_init+0x3151/0x4a80 __devm_regmap_init+0x7d/0x100 madera_spi_probe+0x10f/0x333 [madera_spi] spi_probe+0x183/0x210 really_probe+0x285/0xc30 To fix this, moving up the assignment of rbnode->block to immediately after the reallocation has succeeded so that the data structure stays valid even if the second reallocation fails. Reported-by: Hulk Robot <hulkci@huawei.com> Fixes: 3f4ff561bc88b ("regmap: rbtree: Make cache_present bitmap per node") Signed-off-by: Yang Yingliang <yangyingliang@huawei.com> Link: https://lore.kernel.org/r/20211012023735.1632786-1-yangyingliang@huawei.com Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02net: lan78xx: fix division by zero in send pathJohan Hovold
commit db6c3c064f5d55fa9969f33eafca3cdbefbb3541 upstream. Add the missing endpoint max-packet sanity check to probe() to avoid division by zero in lan78xx_tx_bh() in case a malicious device has broken descriptors (or when doing descriptor fuzz testing). Note that USB core will reject URBs submitted for endpoints with zero wMaxPacketSize but that drivers doing packet-size calculations still need to handle this (cf. commit 2548288b4fb0 ("USB: Fix: Don't skip endpoint descriptors with maxpacket=0")). Fixes: 55d7de9de6c3 ("Microchip's LAN7800 family USB 2/3 to 10/100/1000 Ethernet device driver") Cc: stable@vger.kernel.org # 4.3 Cc: Woojung.Huh@microchip.com <Woojung.Huh@microchip.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02mmc: sdhci: Map more voltage level to SDHCI_POWER_330Shawn Guo
commit 4217d07b9fb328751f877d3bd9550122014860a2 upstream. On Thundercomm TurboX CM2290, the eMMC OCR reports vdd = 23 (3.5 ~ 3.6 V), which is being treated as an invalid value by sdhci_set_power_noreg(). And thus eMMC is totally broken on the platform. [ 1.436599] ------------[ cut here ]------------ [ 1.436606] mmc0: Invalid vdd 0x17 [ 1.436640] WARNING: CPU: 2 PID: 69 at drivers/mmc/host/sdhci.c:2048 sdhci_set_power_noreg+0x168/0x2b4 [ 1.436655] Modules linked in: [ 1.436662] CPU: 2 PID: 69 Comm: kworker/u8:1 Tainted: G W 5.15.0-rc1+ #137 [ 1.436669] Hardware name: Thundercomm TurboX CM2290 (DT) [ 1.436674] Workqueue: events_unbound async_run_entry_fn [ 1.436685] pstate: 60000005 (nZCv daif -PAN -UAO -TCO -DIT -SSBS BTYPE=--) [ 1.436692] pc : sdhci_set_power_noreg+0x168/0x2b4 [ 1.436698] lr : sdhci_set_power_noreg+0x168/0x2b4 [ 1.436703] sp : ffff800010803a60 [ 1.436705] x29: ffff800010803a60 x28: ffff6a9102465f00 x27: ffff6a9101720a70 [ 1.436715] x26: ffff6a91014de1c0 x25: ffff6a91014de010 x24: ffff6a91016af280 [ 1.436724] x23: ffffaf7b1b276640 x22: 0000000000000000 x21: ffff6a9101720000 [ 1.436733] x20: ffff6a9101720370 x19: ffff6a9101720580 x18: 0000000000000020 [ 1.436743] x17: 0000000000000000 x16: 0000000000000004 x15: ffffffffffffffff [ 1.436751] x14: 0000000000000000 x13: 00000000fffffffd x12: ffffaf7b1b84b0bc [ 1.436760] x11: ffffaf7b1b720d10 x10: 000000000000000a x9 : ffff800010803a60 [ 1.436769] x8 : 000000000000000a x7 : 000000000000000f x6 : 00000000fffff159 [ 1.436778] x5 : 0000000000000000 x4 : 0000000000000000 x3 : 00000000ffffffff [ 1.436787] x2 : 0000000000000000 x1 : 0000000000000000 x0 : ffff6a9101718d80 [ 1.436797] Call trace: [ 1.436800] sdhci_set_power_noreg+0x168/0x2b4 [ 1.436805] sdhci_set_ios+0xa0/0x7fc [ 1.436811] mmc_power_up.part.0+0xc4/0x164 [ 1.436818] mmc_start_host+0xa0/0xb0 [ 1.436824] mmc_add_host+0x60/0x90 [ 1.436830] __sdhci_add_host+0x174/0x330 [ 1.436836] sdhci_msm_probe+0x7c0/0x920 [ 1.436842] platform_probe+0x68/0xe0 [ 1.436850] really_probe.part.0+0x9c/0x31c [ 1.436857] __driver_probe_device+0x98/0x144 [ 1.436863] driver_probe_device+0xc8/0x15c [ 1.436869] __device_attach_driver+0xb4/0x120 [ 1.436875] bus_for_each_drv+0x78/0xd0 [ 1.436881] __device_attach_async_helper+0xac/0xd0 [ 1.436888] async_run_entry_fn+0x34/0x110 [ 1.436895] process_one_work+0x1d0/0x354 [ 1.436903] worker_thread+0x13c/0x470 [ 1.436910] kthread+0x150/0x160 [ 1.436915] ret_from_fork+0x10/0x20 [ 1.436923] ---[ end trace fcfac44cb045c3a8 ]--- Fix the issue by mapping MMC_VDD_35_36 (and MMC_VDD_34_35) to SDHCI_POWER_330 as well. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Cc: stable@vger.kernel.org Link: https://lore.kernel.org/r/20211004024935.15326-1-shawn.guo@linaro.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02mmc: dw_mmc: exynos: fix the finding clock sample valueJaehoon Chung
commit 697542bceae51f7620af333b065dd09d213629fb upstream. Even though there are candiates value if can't find best value, it's returned -EIO. It's not proper behavior. If there is not best value, use a first candiate value to work eMMC. Signed-off-by: Jaehoon Chung <jh80.chung@samsung.com> Tested-by: Marek Szyprowski <m.szyprowski@samsung.com> Tested-by: Christian Hewitt <christianshewitt@gmail.com> Cc: stable@vger.kernel.org Fixes: c537a1c5ff63 ("mmc: dw_mmc: exynos: add variable delay tuning sequence") Link: https://lore.kernel.org/r/20211022082106.1557-1-jh80.chung@samsung.com Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02mmc: vub300: fix control-message timeoutsJohan Hovold
commit 8c8171929116cc23f74743d99251eedadf62341a upstream. USB control-message timeouts are specified in milliseconds and should specifically not vary with CONFIG_HZ. Fixes: 88095e7b473a ("mmc: Add new VUB300 USB-to-SD/SDIO/MMC driver") Cc: stable@vger.kernel.org # 3.0 Signed-off-by: Johan Hovold <johan@kernel.org> Link: https://lore.kernel.org/r/20211025115608.5287-1-johan@kernel.org Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02Revert "net: mdiobus: Fix memory leak in __mdiobus_register"Pavel Skripkin
commit 10eff1f5788b6ffac212c254e2f3666219576889 upstream. This reverts commit ab609f25d19858513919369ff3d9a63c02cd9e2e. This patch is correct in the sense that we _should_ call device_put() in case of device_register() failure, but the problem in this code is more vast. We need to set bus->state to UNMDIOBUS_REGISTERED before calling device_register() to correctly release the device in mdiobus_free(). This patch prevents us from doing it, since in case of device_register() failure put_device() will be called 2 times and it will cause UAF or something else. Also, Reported-by: tag in revered commit was wrong, since syzbot reported different leak in same function. Link: https://lore.kernel.org/netdev/20210928092657.GI2048@kadam/ Acked-by: Yanfei Xu <yanfei.xu@windriver.com> Signed-off-by: Pavel Skripkin <paskripkin@gmail.com> Link: https://lore.kernel.org/r/f12fb1faa4eccf0f355788225335eb4309ff2599.1633024062.git.paskripkin@gmail.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02nfc: port100: fix using -ERRNO as command type maskKrzysztof Kozlowski
commit 2195f2062e4cc93870da8e71c318ef98a1c51cef upstream. During probing, the driver tries to get a list (mask) of supported command types in port100_get_command_type_mask() function. The value is u64 and 0 is treated as invalid mask (no commands supported). The function however returns also -ERRNO as u64 which will be interpret as valid command mask. Return 0 on every error case of port100_get_command_type_mask(), so the probing will stop. Cc: <stable@vger.kernel.org> Fixes: 0347a6ab300a ("NFC: port100: Commands mechanism implementation") Signed-off-by: Krzysztof Kozlowski <krzysztof.kozlowski@canonical.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02ata: sata_mv: Fix the error handling of mv_chip_id()Zheyu Ma
commit a0023bb9dd9bc439d44604eeec62426a990054cd upstream. mv_init_host() propagates the value returned by mv_chip_id() which in turn gets propagated by mv_pci_init_one() and hits local_pci_probe(). During the process of driver probing, the probe function should return < 0 for failure, otherwise, the kernel will treat value > 0 as success. Since this is a bug rather than a recoverable runtime error we should use dev_alert() instead of dev_err(). Signed-off-by: Zheyu Ma <zheyuma97@gmail.com> Signed-off-by: Damien Le Moal <damien.lemoal@opensource.wdc.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02usbnet: fix error return code in usbnet_probe()Wang Hai
commit 6f7c88691191e6c52ef2543d6f1da8d360b27a24 upstream. Return error code if usb_maxpacket() returns 0 in usbnet_probe() Fixes: 397430b50a36 ("usbnet: sanity check for maxpacket") Reported-by: Hulk Robot <hulkci@huawei.com> Signed-off-by: Wang Hai <wanghai38@huawei.com> Reviewed-by: Johan Hovold <johan@kernel.org> Link: https://lore.kernel.org/r/20211026124015.3025136-1-wanghai38@huawei.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-11-02usbnet: sanity check for maxpacketOliver Neukum
commit 397430b50a363d8b7bdda00522123f82df6adc5e upstream. maxpacket of 0 makes no sense and oopses as we need to divide by it. Give up. V2: fixed typo in log and stylistic issues Signed-off-by: Oliver Neukum <oneukum@suse.com> Reported-by: syzbot+76bb1d34ffa0adc03baa@syzkaller.appspotmail.com Reviewed-by: Johan Hovold <johan@kernel.org> Link: https://lore.kernel.org/r/20211021122944.21816-1-oneukum@suse.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27net: mdiobus: Fix memory leak in __mdiobus_registerYanfei Xu
commit ab609f25d19858513919369ff3d9a63c02cd9e2e upstream. Once device_register() failed, we should call put_device() to decrement reference count for cleanup. Or it will cause memory leak. BUG: memory leak unreferenced object 0xffff888114032e00 (size 256): comm "kworker/1:3", pid 2960, jiffies 4294943572 (age 15.920s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 08 2e 03 14 81 88 ff ff ................ 08 2e 03 14 81 88 ff ff 90 76 65 82 ff ff ff ff .........ve..... backtrace: [<ffffffff8265cfab>] kmalloc include/linux/slab.h:591 [inline] [<ffffffff8265cfab>] kzalloc include/linux/slab.h:721 [inline] [<ffffffff8265cfab>] device_private_init drivers/base/core.c:3203 [inline] [<ffffffff8265cfab>] device_add+0x89b/0xdf0 drivers/base/core.c:3253 [<ffffffff828dd643>] __mdiobus_register+0xc3/0x450 drivers/net/phy/mdio_bus.c:537 [<ffffffff828cb835>] __devm_mdiobus_register+0x75/0xf0 drivers/net/phy/mdio_devres.c:87 [<ffffffff82b92a00>] ax88772_init_mdio drivers/net/usb/asix_devices.c:676 [inline] [<ffffffff82b92a00>] ax88772_bind+0x330/0x480 drivers/net/usb/asix_devices.c:786 [<ffffffff82baa33f>] usbnet_probe+0x3ff/0xdf0 drivers/net/usb/usbnet.c:1745 [<ffffffff82c36e17>] usb_probe_interface+0x177/0x370 drivers/usb/core/driver.c:396 [<ffffffff82661d17>] call_driver_probe drivers/base/dd.c:517 [inline] [<ffffffff82661d17>] really_probe.part.0+0xe7/0x380 drivers/base/dd.c:596 [<ffffffff826620bc>] really_probe drivers/base/dd.c:558 [inline] [<ffffffff826620bc>] __driver_probe_device+0x10c/0x1e0 drivers/base/dd.c:751 [<ffffffff826621ba>] driver_probe_device+0x2a/0x120 drivers/base/dd.c:781 [<ffffffff82662a26>] __device_attach_driver+0xf6/0x140 drivers/base/dd.c:898 [<ffffffff8265eca7>] bus_for_each_drv+0xb7/0x100 drivers/base/bus.c:427 [<ffffffff826625a2>] __device_attach+0x122/0x260 drivers/base/dd.c:969 [<ffffffff82660916>] bus_probe_device+0xc6/0xe0 drivers/base/bus.c:487 [<ffffffff8265cd0b>] device_add+0x5fb/0xdf0 drivers/base/core.c:3359 [<ffffffff82c343b9>] usb_set_configuration+0x9d9/0xb90 drivers/usb/core/message.c:2170 [<ffffffff82c4473c>] usb_generic_driver_probe+0x8c/0xc0 drivers/usb/core/generic.c:238 BUG: memory leak unreferenced object 0xffff888116f06900 (size 32): comm "kworker/0:2", pid 2670, jiffies 4294944448 (age 7.160s) hex dump (first 32 bytes): 75 73 62 2d 30 30 31 3a 30 30 33 00 00 00 00 00 usb-001:003..... 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff81484516>] kstrdup+0x36/0x70 mm/util.c:60 [<ffffffff814845a3>] kstrdup_const+0x53/0x80 mm/util.c:83 [<ffffffff82296ba2>] kvasprintf_const+0xc2/0x110 lib/kasprintf.c:48 [<ffffffff82358d4b>] kobject_set_name_vargs+0x3b/0xe0 lib/kobject.c:289 [<ffffffff826575f3>] dev_set_name+0x63/0x90 drivers/base/core.c:3147 [<ffffffff828dd63b>] __mdiobus_register+0xbb/0x450 drivers/net/phy/mdio_bus.c:535 [<ffffffff828cb835>] __devm_mdiobus_register+0x75/0xf0 drivers/net/phy/mdio_devres.c:87 [<ffffffff82b92a00>] ax88772_init_mdio drivers/net/usb/asix_devices.c:676 [inline] [<ffffffff82b92a00>] ax88772_bind+0x330/0x480 drivers/net/usb/asix_devices.c:786 [<ffffffff82baa33f>] usbnet_probe+0x3ff/0xdf0 drivers/net/usb/usbnet.c:1745 [<ffffffff82c36e17>] usb_probe_interface+0x177/0x370 drivers/usb/core/driver.c:396 [<ffffffff82661d17>] call_driver_probe drivers/base/dd.c:517 [inline] [<ffffffff82661d17>] really_probe.part.0+0xe7/0x380 drivers/base/dd.c:596 [<ffffffff826620bc>] really_probe drivers/base/dd.c:558 [inline] [<ffffffff826620bc>] __driver_probe_device+0x10c/0x1e0 drivers/base/dd.c:751 [<ffffffff826621ba>] driver_probe_device+0x2a/0x120 drivers/base/dd.c:781 [<ffffffff82662a26>] __device_attach_driver+0xf6/0x140 drivers/base/dd.c:898 [<ffffffff8265eca7>] bus_for_each_drv+0xb7/0x100 drivers/base/bus.c:427 [<ffffffff826625a2>] __device_attach+0x122/0x260 drivers/base/dd.c:969 Reported-by: syzbot+398e7dc692ddbbb4cfec@syzkaller.appspotmail.com Signed-off-by: Yanfei Xu <yanfei.xu@windriver.com> Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27platform/x86: intel_scu_ipc: Update timeout value in commentPrashant Malani
[ Upstream commit a0c5814b9933f25ecb6de169483c5b88cf632bca ] The comment decribing the IPC timeout hadn't been updated when the actual timeout was changed from 3 to 5 seconds in commit a7d53dbbc70a ("platform/x86: intel_scu_ipc: Increase virtual timeout from 3 to 5 seconds") . Since the value is anyway updated to 10s now, take this opportunity to update the value in the comment too. Signed-off-by: Prashant Malani <pmalani@chromium.org> Cc: Benson Leung <bleung@chromium.org> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> Link: https://lore.kernel.org/r/20210928101932.2543937-4-pmalani@chromium.org Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-27isdn: mISDN: Fix sleeping function called from invalid contextZheyu Ma
[ Upstream commit 6510e80a0b81b5d814e3aea6297ba42f5e76f73c ] The driver can call card->isac.release() function from an atomic context. Fix this by calling this function after releasing the lock. The following log reveals it: [ 44.168226 ] BUG: sleeping function called from invalid context at kernel/workqueue.c:3018 [ 44.168941 ] in_atomic(): 1, irqs_disabled(): 1, non_block: 0, pid: 5475, name: modprobe [ 44.169574 ] INFO: lockdep is turned off. [ 44.169899 ] irq event stamp: 0 [ 44.170160 ] hardirqs last enabled at (0): [<0000000000000000>] 0x0 [ 44.170627 ] hardirqs last disabled at (0): [<ffffffff814209ed>] copy_process+0x132d/0x3e00 [ 44.171240 ] softirqs last enabled at (0): [<ffffffff81420a1a>] copy_process+0x135a/0x3e00 [ 44.171852 ] softirqs last disabled at (0): [<0000000000000000>] 0x0 [ 44.172318 ] Preemption disabled at: [ 44.172320 ] [<ffffffffa009b0a9>] nj_release+0x69/0x500 [netjet] [ 44.174441 ] Call Trace: [ 44.174630 ] dump_stack_lvl+0xa8/0xd1 [ 44.174912 ] dump_stack+0x15/0x17 [ 44.175166 ] ___might_sleep+0x3a2/0x510 [ 44.175459 ] ? nj_release+0x69/0x500 [netjet] [ 44.175791 ] __might_sleep+0x82/0xe0 [ 44.176063 ] ? start_flush_work+0x20/0x7b0 [ 44.176375 ] start_flush_work+0x33/0x7b0 [ 44.176672 ] ? trace_irq_enable_rcuidle+0x85/0x170 [ 44.177034 ] ? kasan_quarantine_put+0xaa/0x1f0 [ 44.177372 ] ? kasan_quarantine_put+0xaa/0x1f0 [ 44.177711 ] __flush_work+0x11a/0x1a0 [ 44.177991 ] ? flush_work+0x20/0x20 [ 44.178257 ] ? lock_release+0x13c/0x8f0 [ 44.178550 ] ? __kasan_check_write+0x14/0x20 [ 44.178872 ] ? do_raw_spin_lock+0x148/0x360 [ 44.179187 ] ? read_lock_is_recursive+0x20/0x20 [ 44.179530 ] ? __kasan_check_read+0x11/0x20 [ 44.179846 ] ? do_raw_spin_unlock+0x55/0x900 [ 44.180168 ] ? ____kasan_slab_free+0x116/0x140 [ 44.180505 ] ? _raw_spin_unlock_irqrestore+0x41/0x60 [ 44.180878 ] ? skb_queue_purge+0x1a3/0x1c0 [ 44.181189 ] ? kfree+0x13e/0x290 [ 44.181438 ] flush_work+0x17/0x20 [ 44.181695 ] mISDN_freedchannel+0xe8/0x100 [ 44.182006 ] isac_release+0x210/0x260 [mISDNipac] [ 44.182366 ] nj_release+0xf6/0x500 [netjet] [ 44.182685 ] nj_remove+0x48/0x70 [netjet] [ 44.182989 ] pci_device_remove+0xa9/0x250 Signed-off-by: Zheyu Ma <zheyuma97@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-27isdn: cpai: check ctr->cnr to avoid array index out of boundXiaolong Huang
commit 1f3e2e97c003f80c4b087092b225c8787ff91e4d upstream. The cmtp_add_connection() would add a cmtp session to a controller and run a kernel thread to process cmtp. __module_get(THIS_MODULE); session->task = kthread_run(cmtp_session, session, "kcmtpd_ctr_%d", session->num); During this process, the kernel thread would call detach_capi_ctr() to detach a register controller. if the controller was not attached yet, detach_capi_ctr() would trigger an array-index-out-bounds bug. [ 46.866069][ T6479] UBSAN: array-index-out-of-bounds in drivers/isdn/capi/kcapi.c:483:21 [ 46.867196][ T6479] index -1 is out of range for type 'capi_ctr *[32]' [ 46.867982][ T6479] CPU: 1 PID: 6479 Comm: kcmtpd_ctr_0 Not tainted 5.15.0-rc2+ #8 [ 46.869002][ T6479] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.14.0-2 04/01/2014 [ 46.870107][ T6479] Call Trace: [ 46.870473][ T6479] dump_stack_lvl+0x57/0x7d [ 46.870974][ T6479] ubsan_epilogue+0x5/0x40 [ 46.871458][ T6479] __ubsan_handle_out_of_bounds.cold+0x43/0x48 [ 46.872135][ T6479] detach_capi_ctr+0x64/0xc0 [ 46.872639][ T6479] cmtp_session+0x5c8/0x5d0 [ 46.873131][ T6479] ? __init_waitqueue_head+0x60/0x60 [ 46.873712][ T6479] ? cmtp_add_msgpart+0x120/0x120 [ 46.874256][ T6479] kthread+0x147/0x170 [ 46.874709][ T6479] ? set_kthread_struct+0x40/0x40 [ 46.875248][ T6479] ret_from_fork+0x1f/0x30 [ 46.875773][ T6479] Signed-off-by: Xiaolong Huang <butterflyhuangxx@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Link: https://lore.kernel.org/r/20211008065830.305057-1-butterflyhuangxx@gmail.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27can: peak_pci: peak_pci_remove(): fix UAFZheyu Ma
commit 949fe9b35570361bc6ee2652f89a0561b26eec98 upstream. When remove the module peek_pci, referencing 'chan' again after releasing 'dev' will cause UAF. Fix this by releasing 'dev' later. The following log reveals it: [ 35.961814 ] BUG: KASAN: use-after-free in peak_pci_remove+0x16f/0x270 [peak_pci] [ 35.963414 ] Read of size 8 at addr ffff888136998ee8 by task modprobe/5537 [ 35.965513 ] Call Trace: [ 35.965718 ] dump_stack_lvl+0xa8/0xd1 [ 35.966028 ] print_address_description+0x87/0x3b0 [ 35.966420 ] kasan_report+0x172/0x1c0 [ 35.966725 ] ? peak_pci_remove+0x16f/0x270 [peak_pci] [ 35.967137 ] ? trace_irq_enable_rcuidle+0x10/0x170 [ 35.967529 ] ? peak_pci_remove+0x16f/0x270 [peak_pci] [ 35.967945 ] __asan_report_load8_noabort+0x14/0x20 [ 35.968346 ] peak_pci_remove+0x16f/0x270 [peak_pci] [ 35.968752 ] pci_device_remove+0xa9/0x250 Fixes: e6d9c80b7ca1 ("can: peak_pci: add support of some new PEAK-System PCI cards") Link: https://lore.kernel.org/all/1634192913-15639-1-git-send-email-zheyuma97@gmail.com Cc: stable@vger.kernel.org Signed-off-by: Zheyu Ma <zheyuma97@gmail.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27can: peak_usb: pcan_usb_fd_decode_status(): fix back to ERROR_ACTIVE state ↵Stephane Grosjean
notification commit 3d031abc7e7249573148871180c28ecedb5e27df upstream. This corrects the lack of notification of a return to ERROR_ACTIVE state for USB - CANFD devices from PEAK-System. Fixes: 0a25e1f4f185 ("can: peak_usb: add support for PEAK new CANFD USB adapters") Link: https://lore.kernel.org/all/20210929142111.55757-1-s.grosjean@peak-system.com Cc: stable@vger.kernel.org Signed-off-by: Stephane Grosjean <s.grosjean@peak-system.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27can: rcar_can: fix suspend/resumeYoshihiro Shimoda
commit f7c05c3987dcfde9a4e8c2d533db013fabebca0d upstream. If the driver was not opened, rcar_can_suspend() should not call clk_disable() because the clock was not enabled. Fixes: fd1159318e55 ("can: add Renesas R-Car CAN driver") Link: https://lore.kernel.org/all/20210924075556.223685-1-yoshihiro.shimoda.uh@renesas.com Cc: stable@vger.kernel.org Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Tested-by: Ayumi Nakamichi <ayumi.nakamichi.kf@renesas.com> Reviewed-by: Ulrich Hecht <uli+renesas@fpond.eu> Tested-by: Biju Das <biju.das.jz@bp.renesas.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27r8152: select CRC32 and CRYPTO/CRYPTO_HASH/CRYPTO_SHA256Vegard Nossum
commit 9973a43012b6ad1720dbc4d5faf5302c28635b8c upstream. Fix the following build/link errors by adding a dependency on CRYPTO, CRYPTO_HASH, CRYPTO_SHA256 and CRC32: ld: drivers/net/usb/r8152.o: in function `rtl8152_fw_verify_checksum': r8152.c:(.text+0x2b2a): undefined reference to `crypto_alloc_shash' ld: r8152.c:(.text+0x2bed): undefined reference to `crypto_shash_digest' ld: r8152.c:(.text+0x2c50): undefined reference to `crypto_destroy_tfm' ld: drivers/net/usb/r8152.o: in function `_rtl8152_set_rx_mode': r8152.c:(.text+0xdcb0): undefined reference to `crc32_le' Fixes: 9370f2d05a2a1 ("r8152: support request_firmware for RTL8153") Fixes: ac718b69301c7 ("net/usb: new driver for RTL8152") Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27drm/msm: Fix null pointer dereference on pointer edpColin Ian King
commit 2133c4fc8e1348dcb752f267a143fe2254613b34 upstream. The initialization of pointer dev dereferences pointer edp before edp is null checked, so there is a potential null pointer deference issue. Fix this by only dereferencing edp after edp has been null checked. Addresses-Coverity: ("Dereference before null check") Fixes: ab5b0107ccf3 ("drm/msm: Initial add eDP support in msm drm driver (v5)") Signed-off-by: Colin Ian King <colin.king@canonical.com> Reviewed-by: Dmitry Baryshkov <dmitry.baryshkov@linaro.org> Link: https://lore.kernel.org/r/20210929121857.213922-1-colin.king@canonical.com Signed-off-by: Rob Clark <robdclark@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27pata_legacy: fix a couple uninitialized variable bugsDan Carpenter
commit 013923477cb311293df9079332cf8b806ed0e6f2 upstream. The last byte of "pad" is used without being initialized. Fixes: 55dba3120fbc ("libata: update ->data_xfer hook for ATAPI") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27ethernet: s2io: fix setting mac address during resumeArnd Bergmann
commit 40507e7aada8422c38aafa0c8a1a09e4623c712a upstream. After recent cleanups, gcc started warning about a suspicious memcpy() call during the s2io_io_resume() function: In function '__dev_addr_set', inlined from 'eth_hw_addr_set' at include/linux/etherdevice.h:318:2, inlined from 's2io_set_mac_addr' at drivers/net/ethernet/neterion/s2io.c:5205:2, inlined from 's2io_io_resume' at drivers/net/ethernet/neterion/s2io.c:8569:7: arch/x86/include/asm/string_32.h:182:25: error: '__builtin_memcpy' accessing 6 bytes at offsets 0 and 2 overlaps 4 bytes at offset 2 [-Werror=restrict] 182 | #define memcpy(t, f, n) __builtin_memcpy(t, f, n) | ^~~~~~~~~~~~~~~~~~~~~~~~~ include/linux/netdevice.h:4648:9: note: in expansion of macro 'memcpy' 4648 | memcpy(dev->dev_addr, addr, len); | ^~~~~~ What apparently happened is that an old cleanup changed the calling conventions for s2io_set_mac_addr() from taking an ethernet address as a character array to taking a struct sockaddr, but one of the callers was not changed at the same time. Change it to instead call the low-level do_s2io_prog_unicast() function that still takes the old argument type. Fixes: 2fd376884558 ("S2io: Added support set_mac_address driver entry point") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Link: https://lore.kernel.org/r/20211013143613.2049096-1-arnd@kernel.org Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27net: encx24j600: check error in devm_regmap_init_encx24j600Nanyong Sun
commit f03dca0c9e2297c84a018e306f8a9cd534ee4287 upstream. devm_regmap_init may return error which caused by like out of memory, this will results in null pointer dereference later when reading or writing register: general protection fault in encx24j600_spi_probe KASAN: null-ptr-deref in range [0x0000000000000090-0x0000000000000097] CPU: 0 PID: 286 Comm: spi-encx24j600- Not tainted 5.15.0-rc2-00142-g9978db750e31-dirty #11 9c53a778c1306b1b02359f3c2bbedc0222cba652 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.13.0-1ubuntu1.1 04/01/2014 RIP: 0010:regcache_cache_bypass drivers/base/regmap/regcache.c:540 Code: 54 41 89 f4 55 53 48 89 fb 48 83 ec 08 e8 26 94 a8 fe 48 8d bb a0 00 00 00 48 b8 00 00 00 00 00 fc ff df 48 89 fa 48 c1 ea 03 <80> 3c 02 00 0f 85 4a 03 00 00 4c 8d ab b0 00 00 00 48 8b ab a0 00 RSP: 0018:ffffc900010476b8 EFLAGS: 00010207 RAX: dffffc0000000000 RBX: fffffffffffffff4 RCX: 0000000000000000 RDX: 0000000000000012 RSI: ffff888002de0000 RDI: 0000000000000094 RBP: ffff888013c9a000 R08: 0000000000000000 R09: fffffbfff3f9cc6a R10: ffffc900010476e8 R11: fffffbfff3f9cc69 R12: 0000000000000001 R13: 000000000000000a R14: ffff888013c9af54 R15: ffff888013c9ad08 FS: 00007ffa984ab580(0000) GS:ffff88801fe00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 000055a6384136c8 CR3: 000000003bbe6003 CR4: 0000000000770ef0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400 PKRU: 55555554 Call Trace: encx24j600_spi_probe drivers/net/ethernet/microchip/encx24j600.c:459 spi_probe drivers/spi/spi.c:397 really_probe drivers/base/dd.c:517 __driver_probe_device drivers/base/dd.c:751 driver_probe_device drivers/base/dd.c:782 __device_attach_driver drivers/base/dd.c:899 bus_for_each_drv drivers/base/bus.c:427 __device_attach drivers/base/dd.c:971 bus_probe_device drivers/base/bus.c:487 device_add drivers/base/core.c:3364 __spi_add_device drivers/spi/spi.c:599 spi_add_device drivers/spi/spi.c:641 spi_new_device drivers/spi/spi.c:717 new_device_store+0x18c/0x1f1 [spi_stub 4e02719357f1ff33f5a43d00630982840568e85e] dev_attr_store drivers/base/core.c:2074 sysfs_kf_write fs/sysfs/file.c:139 kernfs_fop_write_iter fs/kernfs/file.c:300 new_sync_write fs/read_write.c:508 (discriminator 4) vfs_write fs/read_write.c:594 ksys_write fs/read_write.c:648 do_syscall_64 arch/x86/entry/common.c:50 entry_SYSCALL_64_after_hwframe arch/x86/entry/entry_64.S:113 Add error check in devm_regmap_init_encx24j600 to avoid this situation. Fixes: 04fbfce7a222 ("net: Microchip encx24j600 driver") Reported-by: Hulk Robot <hulkci@huawei.com> Signed-off-by: Nanyong Sun <sunnanyong@huawei.com> Link: https://lore.kernel.org/r/20211012125901.3623144-1-sunnanyong@huawei.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27net: korina: select CRC32Vegard Nossum
commit 427f974d9727ca681085ddcd0530c97ab5811ae0 upstream. Fix the following build/link error by adding a dependency on the CRC32 routines: ld: drivers/net/ethernet/korina.o: in function `korina_multicast_list': korina.c:(.text+0x1af): undefined reference to `crc32_le' Fixes: ef11291bcd5f9 ("Add support the Korina (IDT RC32434) Ethernet MAC") Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Acked-by: Florian fainelli <f.fainelli@gmail.com> Link: https://lore.kernel.org/r/20211012152509.21771-1-vegard.nossum@oracle.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27net: arc: select CRC32Vegard Nossum
commit e599ee234ad4fdfe241d937bbabd96e0d8f9d868 upstream. Fix the following build/link error by adding a dependency on the CRC32 routines: ld: drivers/net/ethernet/arc/emac_main.o: in function `arc_emac_set_rx_mode': emac_main.c:(.text+0xb11): undefined reference to `crc32_le' The crc32_le() call comes through the ether_crc_le() call in arc_emac_set_rx_mode(). [v2: moved the select to ARC_EMAC_CORE; the Makefile is a bit confusing, but the error comes from emac_main.o, which is part of the arc_emac module, which in turn is enabled by CONFIG_ARC_EMAC_CORE. Note that arc_emac is different from emac_arc...] Fixes: 775dd682e2b0ec ("arc_emac: implement promiscuous mode and multicast filtering") Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Link: https://lore.kernel.org/r/20211012093446.1575-1-vegard.nossum@oracle.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27iio: ssp_sensors: fix error code in ssp_print_mcu_debug()Dan Carpenter
commit 4170d3dd1467e9d78cb9af374b19357dc324b328 upstream. The ssp_print_mcu_debug() function should return negative error codes on error. Returning "length" is meaningless. This change does not affect runtime because the callers only care about zero/non-zero. Reported-by: Jonathan Cameron <jic23@kernel.org> Fixes: 50dd64d57eee ("iio: common: ssp_sensors: Add sensorhub driver") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Link: https://lore.kernel.org/r/20210914105333.GA11657@kili Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27iio: ssp_sensors: add more range checking in ssp_parse_dataframe()Dan Carpenter
commit 8167c9a375ccceed19048ad9d68cb2d02ed276e0 upstream. The "idx" is validated at the start of the loop but it gets incremented during the iteration so it needs to be checked again. Fixes: 50dd64d57eee ("iio: common: ssp_sensors: Add sensorhub driver") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Link: https://lore.kernel.org/r/20210909091336.GA26312@kili Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27iio: adc128s052: Fix the error handling path of 'adc128_probe()'Christophe JAILLET
commit bbcf40816b547b3c37af49168950491d20d81ce1 upstream. A successful 'regulator_enable()' call should be balanced by a corresponding 'regulator_disable()' call in the error handling path of the probe, as already done in the remove function. Update the error handling path accordingly. Fixes: 913b86468674 ("iio: adc: Add TI ADC128S052") Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Reviewed-by: Alexandru Ardelean <ardeleanalex@gmail.com> Link: https://lore.kernel.org/r/85189f1cfcf6f5f7b42d8730966f2a074b07b5f5.1629542160.git.christophe.jaillet@wanadoo.fr Cc: <Stable@vger.kernel.org> Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27nvmem: Fix shift-out-of-bound (UBSAN) with byte size cellsStephen Boyd
commit 5d388fa01fa6eb310ac023a363a6cb216d9d8fe9 upstream. If a cell has 'nbits' equal to a multiple of BITS_PER_BYTE the logic *p &= GENMASK((cell->nbits%BITS_PER_BYTE) - 1, 0); will become undefined behavior because nbits modulo BITS_PER_BYTE is 0, and we subtract one from that making a large number that is then shifted more than the number of bits that fit into an unsigned long. UBSAN reports this problem: UBSAN: shift-out-of-bounds in drivers/nvmem/core.c:1386:8 shift exponent 64 is too large for 64-bit type 'unsigned long' CPU: 6 PID: 7 Comm: kworker/u16:0 Not tainted 5.15.0-rc3+ #9 Hardware name: Google Lazor (rev3+) with KB Backlight (DT) Workqueue: events_unbound deferred_probe_work_func Call trace: dump_backtrace+0x0/0x170 show_stack+0x24/0x30 dump_stack_lvl+0x64/0x7c dump_stack+0x18/0x38 ubsan_epilogue+0x10/0x54 __ubsan_handle_shift_out_of_bounds+0x180/0x194 __nvmem_cell_read+0x1ec/0x21c nvmem_cell_read+0x58/0x94 nvmem_cell_read_variable_common+0x4c/0xb0 nvmem_cell_read_variable_le_u32+0x40/0x100 a6xx_gpu_init+0x170/0x2f4 adreno_bind+0x174/0x284 component_bind_all+0xf0/0x264 msm_drm_bind+0x1d8/0x7a0 try_to_bring_up_master+0x164/0x1ac __component_add+0xbc/0x13c component_add+0x20/0x2c dp_display_probe+0x340/0x384 platform_probe+0xc0/0x100 really_probe+0x110/0x304 __driver_probe_device+0xb8/0x120 driver_probe_device+0x4c/0xfc __device_attach_driver+0xb0/0x128 bus_for_each_drv+0x90/0xdc __device_attach+0xc8/0x174 device_initial_probe+0x20/0x2c bus_probe_device+0x40/0xa4 deferred_probe_work_func+0x7c/0xb8 process_one_work+0x128/0x21c process_scheduled_works+0x40/0x54 worker_thread+0x1ec/0x2a8 kthread+0x138/0x158 ret_from_fork+0x10/0x20 Fix it by making sure there are any bits to mask out. Fixes: 69aba7948cbe ("nvmem: Add a simple NVMEM framework for consumers") Cc: Douglas Anderson <dianders@chromium.org> Cc: stable@vger.kernel.org Signed-off-by: Stephen Boyd <swboyd@chromium.org> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Link: https://lore.kernel.org/r/20211013124511.18726-1-srinivas.kandagatla@linaro.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27USB: serial: option: add Telit LE910Cx composition 0x1204Daniele Palmas
commit f5a8a07edafed8bede17a95ef8940fe3a57a77d5 upstream. Add the following Telit LE910Cx composition: 0x1204: tty, adb, mbim, tty, tty, tty, tty Signed-off-by: Daniele Palmas <dnlplm@gmail.com> Link: https://lore.kernel.org/r/20211004105655.8515-1-dnlplm@gmail.com Cc: stable@vger.kernel.org Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27USB: serial: qcserial: add EM9191 QDL supportAleksander Morgado
commit 11c52d250b34a0862edc29db03fbec23b30db6da upstream. When the module boots into QDL download mode it exposes the 1199:90d2 ids, which can be mapped to the qcserial driver, and used to run firmware upgrades (e.g. with the qmi-firmware-update program). T: Bus=01 Lev=03 Prnt=08 Port=03 Cnt=01 Dev#= 10 Spd=480 MxCh= 0 D: Ver= 2.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1 P: Vendor=1199 ProdID=90d2 Rev=00.00 S: Manufacturer=Sierra Wireless, Incorporated S: Product=Sierra Wireless EM9191 S: SerialNumber=8W0382004102A109 C: #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=2mA I: If#=0x0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=10 Driver=qcserial Signed-off-by: Aleksander Morgado <aleksander@aleksander.es> Cc: stable@vger.kernel.org Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27Input: xpad - add support for another USB ID of Nacon GC-100Michael Cullen
commit 3378a07daa6cdd11e042797454c706d1c69f9ca6 upstream. The Nacon GX100XF is already mapped, but it seems there is a Nacon GC-100 (identified as NC5136Wht PCGC-100WHITE though I believe other colours exist) with a different USB ID when in XInput mode. Signed-off-by: Michael Cullen <michael@michaelcullen.name> Link: https://lore.kernel.org/r/20211015192051.5196-1-michael@michaelcullen.name Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27efi/cper: use stack buffer for error record decodingArd Biesheuvel
commit b3a72ca80351917cc23f9e24c35f3c3979d3c121 upstream. Joe reports that using a statically allocated buffer for converting CPER error records into human readable text is probably a bad idea. Even though we are not aware of any actual issues, a stack buffer is clearly a better choice here anyway, so let's move the buffer into the stack frames of the two functions that refer to it. Cc: <stable@vger.kernel.org> Reported-by: Joe Perches <joe@perches.com> Signed-off-by: Ard Biesheuvel <ardb@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27cb710: avoid NULL pointer subtractionArnd Bergmann
commit 42641042c10c757fe10cc09088cf3f436cec5007 upstream. clang-14 complains about an unusual way of converting a pointer to an integer: drivers/misc/cb710/sgbuf2.c:50:15: error: performing pointer subtraction with a null pointer has undefined behavior [-Werror,-Wnull-pointer-subtraction] return ((ptr - NULL) & 3) != 0; Replace this with a normal cast to uintptr_t. Fixes: 5f5bac8272be ("mmc: Driver for CB710/720 memory card reader (MMC part)") Cc: stable <stable@vger.kernel.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Link: https://lore.kernel.org/r/20210927121408.939246-1-arnd@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-27xhci: Enable trust tx length quirk for Fresco FL11 USB controllerNikolay Martynov
commit ea0f69d8211963c4b2cc1998b86779a500adb502 upstream. Tested on SD5200T TB3 dock which has Fresco Logic FL1100 USB 3.0 Host Controller. Before this patch streaming video from USB cam made mouse and keyboard connected to the same USB bus unusable. Also video was jerky. With this patch streaming video doesn't have any effect on other periferals and video is smooth. Cc: stable@vger.kernel.org Signed-off-by: Nikolay Martynov <mar.kolya@gmail.com> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Link: https://lore.kernel.org/r/20211008092547.3996295-6-mathias.nyman@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-17scsi: virtio_scsi: Fix spelling mistake "Unsupport" -> "Unsupported"Colin Ian King
[ Upstream commit cced4c0ec7c06f5230a2958907a409c849762293 ] There are a couple of spelling mistakes in pr_info and pr_err messages. Fix them. Link: https://lore.kernel.org/r/20210924230330.143785-1-colin.king@canonical.com Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-17scsi: ses: Fix unsigned comparison with less than zeroJiapeng Chong
[ Upstream commit dd689ed5aa905daf4ba4c99319a52aad6ea0a796 ] Fix the following coccicheck warning: ./drivers/scsi/ses.c:137:10-16: WARNING: Unsigned expression compared with zero: result > 0. Link: https://lore.kernel.org/r/1632477113-90378-1-git-send-email-jiapeng.chong@linux.alibaba.com Reported-by: Abaci Robot <abaci@linux.alibaba.com> Signed-off-by: Jiapeng Chong <jiapeng.chong@linux.alibaba.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-17HID: apple: Fix logical maximum and usage maximum of Magic Keyboard JISMizuho Mori
[ Upstream commit 67fd71ba16a37c663d139f5ba5296f344d80d072 ] Apple Magic Keyboard(JIS)'s Logical Maximum and Usage Maximum are wrong. Below is a report descriptor. 0x05, 0x01, /* Usage Page (Desktop), */ 0x09, 0x06, /* Usage (Keyboard), */ 0xA1, 0x01, /* Collection (Application), */ 0x85, 0x01, /* Report ID (1), */ 0x05, 0x07, /* Usage Page (Keyboard), */ 0x15, 0x00, /* Logical Minimum (0), */ 0x25, 0x01, /* Logical Maximum (1), */ 0x19, 0xE0, /* Usage Minimum (KB Leftcontrol), */ 0x29, 0xE7, /* Usage Maximum (KB Right GUI), */ 0x75, 0x01, /* Report Size (1), */ 0x95, 0x08, /* Report Count (8), */ 0x81, 0x02, /* Input (Variable), */ 0x95, 0x05, /* Report Count (5), */ 0x75, 0x01, /* Report Size (1), */ 0x05, 0x08, /* Usage Page (LED), */ 0x19, 0x01, /* Usage Minimum (01h), */ 0x29, 0x05, /* Usage Maximum (05h), */ 0x91, 0x02, /* Output (Variable), */ 0x95, 0x01, /* Report Count (1), */ 0x75, 0x03, /* Report Size (3), */ 0x91, 0x03, /* Output (Constant, Variable), */ 0x95, 0x08, /* Report Count (8), */ 0x75, 0x01, /* Report Size (1), */ 0x15, 0x00, /* Logical Minimum (0), */ 0x25, 0x01, /* Logical Maximum (1), */ here is a report descriptor which is parsed one in kernel. see sys/kernel/debug/hid/<dev>/rdesc 05 01 09 06 a1 01 85 01 05 07 15 00 25 01 19 e0 29 e7 75 01 95 08 81 02 95 05 75 01 05 08 19 01 29 05 91 02 95 01 75 03 91 03 95 08 75 01 15 00 25 01 06 00 ff 09 03 81 03 95 06 75 08 15 00 25 [65] 05 07 19 00 29 [65] 81 00 95 01 75 01 15 00 25 01 05 0c 09 b8 81 02 95 01 75 01 06 01 ff 09 03 81 02 95 01 75 06 81 03 06 02 ff 09 55 85 55 15 00 26 ff 00 75 08 95 40 b1 a2 c0 06 00 ff 09 14 a1 01 85 90 05 84 75 01 95 03 15 00 25 01 09 61 05 85 09 44 09 46 81 02 95 05 81 01 75 08 95 01 15 00 26 ff 00 09 65 81 02 c0 00 Position 64(Logical Maximum) and 70(Usage Maximum) are 101. Both should be 0xE7 to support JIS specific keys(ろ, Eisu, Kana, |) support. position 117 is also 101 but not related(it is Usage 65h). There are no difference of product id between JIS and ANSI. They are same 0x0267. Signed-off-by: Mizuho Mori <morimolymoly@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-17i40e: fix endless loop under rtnlJiri Benc
[ Upstream commit 857b6c6f665cca9828396d9743faf37fd09e9ac3 ] The loop in i40e_get_capabilities can never end. The problem is that although i40e_aq_discover_capabilities returns with an error if there's a firmware problem, the returned error is not checked. There is a check for pf->hw.aq.asq_last_status but that value is set to I40E_AQ_RC_OK on most firmware problems. When i40e_aq_discover_capabilities encounters a firmware problem, it will encounter the same problem on its next invocation. As the result, the loop becomes endless. We hit this with I40E_ERR_ADMIN_QUEUE_TIMEOUT but looking at the code, it can happen with a range of other firmware errors. I don't know what the correct behavior should be: whether the firmware should be retried a few times, or whether pf->hw.aq.asq_last_status should be always set to the encountered firmware error (but then it would be pointless and can be just replaced by the i40e_aq_discover_capabilities return value). However, the current behavior with an endless loop under the rtnl mutex(!) is unacceptable and Intel has not submitted a fix, although we explained the bug to them 7 months ago. This may not be the best possible fix but it's better than hanging the whole system on a firmware bug. Fixes: 56a62fc86895 ("i40e: init code and hardware support") Tested-by: Stefan Assmann <sassmann@redhat.com> Signed-off-by: Jiri Benc <jbenc@redhat.com> Reviewed-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Tested-by: Dave Switzer <david.switzer@intel.com> Signed-off-by: Tony Nguyen <anthony.l.nguyen@intel.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-17ptp_pch: Load module automatically if ID matchesAndy Shevchenko
[ Upstream commit 7cd8b1542a7ba0720c5a0a85ed414a122015228b ] The driver can't be loaded automatically because it misses module alias to be provided. Add corresponding MODULE_DEVICE_TABLE() call to the driver. Fixes: 863d08ece9bf ("supports eg20t ptp clock") Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-17phy: mdio: fix memory leakPavel Skripkin
[ Upstream commit ca6e11c337daf7925ff8a2aac8e84490a8691905 ] Syzbot reported memory leak in MDIO bus interface, the problem was in wrong state logic. MDIOBUS_ALLOCATED indicates 2 states: 1. Bus is only allocated 2. Bus allocated and __mdiobus_register() fails, but device_register() was called In case of device_register() has been called we should call put_device() to correctly free the memory allocated for this device, but mdiobus_free() calls just kfree(dev) in case of MDIOBUS_ALLOCATED state To avoid this behaviour we need to set bus->state to MDIOBUS_UNREGISTERED _before_ calling device_register(), because put_device() should be called even in case of device_register() failure. Link: https://lore.kernel.org/netdev/YVMRWNDZDUOvQjHL@shell.armlinux.org.uk/ Fixes: 46abc02175b3 ("phylib: give mdio buses a device tree presence") Reported-and-tested-by: syzbot+398e7dc692ddbbb4cfec@syzkaller.appspotmail.com Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Pavel Skripkin <paskripkin@gmail.com> Link: https://lore.kernel.org/r/eceae1429fbf8fa5c73dd2a0d39d525aa905074d.1633024062.git.paskripkin@gmail.com Signed-off-by: Jakub Kicinski <kuba@kernel.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-17USB: cdc-acm: fix break reportingJohan Hovold
commit 58fc1daa4d2e9789b9ffc880907c961ea7c062cc upstream. A recent change that started reporting break events forgot to push the event to the line discipline, which meant that a detected break would not be reported until further characters had been receive (the port could even have been closed and reopened in between). Fixes: 08dff274edda ("cdc-acm: fix BREAK rx code path adding necessary calls") Cc: stable@vger.kernel.org Acked-by: Oliver Neukum <oneukum@suse.com> Signed-off-by: Johan Hovold <johan@kernel.org> Link: https://lore.kernel.org/r/20210929090937.7410-3-johan@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-17USB: cdc-acm: fix racy tty buffer accessesJohan Hovold
commit 65a205e6113506e69a503b61d97efec43fc10fd7 upstream. A recent change that started reporting break events to the line discipline caused the tty-buffer insertions to no longer be serialised by inserting events also from the completion handler for the interrupt endpoint. Completion calls for distinct endpoints are not guaranteed to be serialised. For example, in case a host-controller driver uses bottom-half completion, the interrupt and bulk-in completion handlers can end up running in parallel on two CPUs (high-and low-prio tasklets, respectively) thereby breaking the tty layer's single producer assumption. Fix this by holding the read lock also when inserting characters from the bulk endpoint. Fixes: 08dff274edda ("cdc-acm: fix BREAK rx code path adding necessary calls") Cc: stable@vger.kernel.org Acked-by: Oliver Neukum <oneukum@suse.com> Signed-off-by: Johan Hovold <johan@kernel.org> Link: https://lore.kernel.org/r/20210929090937.7410-2-johan@kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-16Merge tag 'v4.4.288' into toradex_vf_4.4Max Krummenacher
This is the 4.4.288 stable release Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-10-09libata: Add ATA_HORKAGE_NO_NCQ_ON_ATI for Samsung 860 and 870 SSD.Kate Hsuan
commit 7a8526a5cd51cf5f070310c6c37dd7293334ac49 upstream. Many users are reporting that the Samsung 860 and 870 SSD are having various issues when combined with AMD/ATI (vendor ID 0x1002) SATA controllers and only completely disabling NCQ helps to avoid these issues. Always disabling NCQ for Samsung 860/870 SSDs regardless of the host SATA adapter vendor will cause I/O performance degradation with well behaved adapters. To limit the performance impact to ATI adapters, introduce the ATA_HORKAGE_NO_NCQ_ON_ATI flag to force disable NCQ only for these adapters. Also, two libata.force parameters (noncqati and ncqati) are introduced to disable and enable the NCQ for the system which equipped with ATI SATA adapter and Samsung 860 and 870 SSDs. The user can determine NCQ function to be enabled or disabled according to the demand. After verifying the chipset from the user reports, the issue appears on AMD/ATI SB7x0/SB8x0/SB9x0 SATA Controllers and does not appear on recent AMD SATA adapters. The vendor ID of ATI should be 0x1002. Therefore, ATA_HORKAGE_NO_NCQ_ON_AMD was modified to ATA_HORKAGE_NO_NCQ_ON_ATI. BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=201693 Signed-off-by: Kate Hsuan <hpa@redhat.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Link: https://lore.kernel.org/r/20210903094411.58749-1-hpa@redhat.com Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@kernel.dk> Cc: Krzysztof Olędzki <ole@ans.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-09scsi: sd: Free scsi_disk device via put_device()Ming Lei
[ Upstream commit 265dfe8ebbabae7959060bd1c3f75c2473b697ed ] After a device is initialized via device_initialize() it should be freed via put_device(). sd_probe() currently gets this wrong, fix it up. Link: https://lore.kernel.org/r/20210906090112.531442-1-ming.lei@redhat.com Reviewed-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Ming Lei <ming.lei@redhat.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-09xen-netback: correct success/error reporting for the SKB-with-fraglist caseJan Beulich
[ Upstream commit 3ede7f84c7c21f93c5eac611d60eba3f2c765e0f ] When re-entering the main loop of xenvif_tx_check_gop() a 2nd time, the special considerations for the head of the SKB no longer apply. Don't mistakenly report ERROR to the frontend for the first entry in the list, even if - from all I can tell - this shouldn't matter much as the overall transmit will need to be considered failed anyway. Signed-off-by: Jan Beulich <jbeulich@suse.com> Reviewed-by: Paul Durrant <paul@xen.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <sashal@kernel.org>
2021-10-06HID: usbhid: free raw_report buffers in usbhid_stopAnirudh Rayabharam
commit f7744fa16b96da57187dc8e5634152d3b63d72de upstream. Free the unsent raw_report buffers when the device is removed. Fixes a memory leak reported by syzbot at: https://syzkaller.appspot.com/bug?id=7b4fa7cb1a7c2d3342a2a8a6c53371c8c418ab47 Reported-by: syzbot+47b26cd837ececfc666d@syzkaller.appspotmail.com Tested-by: syzbot+47b26cd837ececfc666d@syzkaller.appspotmail.com Signed-off-by: Anirudh Rayabharam <mail@anirudhrb.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-06HID: betop: fix slab-out-of-bounds Write in betop_probeF.A.Sulaiman
commit 1e4ce418b1cb1a810256b5fb3fd33d22d1325993 upstream. Syzbot reported slab-out-of-bounds Write bug in hid-betopff driver. The problem is the driver assumes the device must have an input report but some malicious devices violate this assumption. So this patch checks hid_device's input is non empty before it's been used. Reported-by: syzbot+07efed3bc5a1407bd742@syzkaller.appspotmail.com Signed-off-by: F.A. SULAIMAN <asha.16@itfac.mrt.ac.lk> Reviewed-by: Pavel Skripkin <paskripkin@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2021-10-06EDAC/synopsys: Fix wrong value type assignment for edac_modeSai Krishna Potthuri
commit 5297cfa6bdf93e3889f78f9b482e2a595a376083 upstream. dimm->edac_mode contains values of type enum edac_type - not the corresponding capability flags. Fix that. Issue caught by Coverity check "enumerated type mixed with another type." [ bp: Rewrite commit message, add tags. ] Fixes: ae9b56e3996d ("EDAC, synps: Add EDAC support for zynq ddr ecc controller") Signed-off-by: Sai Krishna Potthuri <lakshmi.sai.krishna.potthuri@xilinx.com> Signed-off-by: Shubhrajyoti Datta <shubhrajyoti.datta@xilinx.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: <stable@vger.kernel.org> Link: https://lkml.kernel.org/r/20210818072315.15149-1-shubhrajyoti.datta@xilinx.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
