Add support for usb hotplug, this change will add the following:
vbus is left enabled.
Bug 796158
Change-Id: I3c3cfa0bf8858b3be2351fe753ceb2a0229ed15d
Reviewed-on: http://git-master/r/30686
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Tested-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Reviewed-by: Prashant Gaikwad <pgaikwad@nvidia.com>
sdhci instance used by wifi should be always on to support
wake on wireless functionlity. pm_notify will power off
controller on suspend/resume which is not desired for wifi
instance.
bug 818687
bug 780047
bug 798783
Change-Id: I572e9e1f275c306eadda85ca95234a427fad23ca
Reviewed-on: http://git-master/r/30864
Reviewed-by: Rakesh Kumar <krakesh@nvidia.com>
Tested-by: Rakesh Kumar <krakesh@nvidia.com>
The kernel now receives wait tracking data (similar to gathers and
relocs) and compares the current syncpt with the threshold value.
If it's old, it gets a kernel mapping and rewrites the method data
to use a kernel reserved syncpt that is always 0 (so trivially pops
when seen by the HW).
Bug 519650
Bug 785525
Bug 803452
Note: reset the author in this commit to fix a email addr problem
and since from the latest/last cherry pick there was a reworking
of the code to be compatible with different user space versions
it also seemed reasonable.
(cherry picked from commit 4069d8e67665624ad3dceb628e572980dd57acd0)
(cherry picked from commit 6e4336408588e348804a62e53386acc9abc06823)
(cherry picked from commit 87a9efe751716ca741caac72b9061fdfdcec540a)
Change-Id: I9c6076da2384f373d5f402bee4406b09b4ebc4ff
Reviewed-on: http://git-master/r/23159
Reviewed-on: http://git-master/r/30281
Tested-by: Chris Johnson <cwj@nvidia.com>
Reviewed-by: Ken Adams <kadams@nvidia.com>
Reviewed-by: Prajakta Gudadhe <pgudadhe@nvidia.com>
clip invalid windows to fix screen size, failure to do so causes display
errors that result in corrupted display and invalid video modes.
prints a warning only once, if this warning is present in the logs then
there is a misbehaving application.
Bug 821094
(cherry picked from commit e08f18eba00bd5d86cb7770f709417a1bd0ca14f)
Change-Id: Ie5cec5c805bfe2bd4c5f1e5b7e22d5f255ca2680
Reviewed-on: http://git-master/r/30587
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
sclk minimum rate is set to 40MHz which is less than required by usb.
set sclk rate to 80MHz when usb is connected and disable sclk when usb is
not connected so that sclk will get clocked at minimum rate.
Bug 819796
Reviewed-on: http://git-master/r/28766
(cherry picked from commit e705e6b448791ef938a0897755205cdde72fa361)
Change-Id: I180d044f788e153d0057355e22ed422f32552d5c
Reviewed-on: http://git-master/r/30818
Tested-by: Prashant Gaikwad <pgaikwad@nvidia.com>
The commit 4547be7 rewrites suspend and resume functions. According
to this rewrite, when a serial port is a printk console device and
can suspend(without set no_console_suspend flag), it will definitely
call set_termios function during its resume, but parameter termios
isn't initialized, this will pass an unpredictable config to the
serial port. If this serial port is not a userspace opened tty device
, a suspend and resume action will make this serial port unusable.
I.E. ttyS0 is a printk console device, ttyS1 or keyboard+display is
userspace tty device, a suspend/resume action will make ttyS0
unusable.
If a serial port is both a printk console device and an opened tty
device, this issue can be overcome because it will call set_termios
again with the correct parameter in the uart_change_speed function.
Refer to the deleted content of commit 4547be7, revert parts relate
to restore settings into parameter termios. It is safe because if
a serial port is a printk console only device, the only meaningful
field in termios is c_cflag and its old config is saved in
uport->cons->cflag, if this port is also an opened tty device,
it will clear uport->cons->cflag in the uart_open and the old config
is saved in tty->termios.
refer http://git.kernel.org/?p=linux/kernel/git/stable/linux-2.6.37.y.git;
a=commit;h=891b9dd10764352926e1e107756aa229dfa2c210
cherry-pick the changes from the kernel 2.6.37 commit id
:891b9dd10764352926e1e107756aa229dfa2c210
Cherry-picked http://git-master/r/#change,20302
Bug 819016
Change-Id: Ic7ce0a6d595c0e1f65285d7978db93be12158f0f
Reviewed-on: http://git-master/r/30680
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Do not handle requests further for displays that are not enabled
Bug 813310
Bug 813728
Reviewed-on: http://git-master/r/29515
(cherry picked from commit 22578f1d7065ea84855fdbcaf09a792e9f9d3856)
Change-Id: I1fa907e33f2d250fff64752c8f0e26de51f3655b
Reviewed-on: http://git-master/r/30672
Having the device resume and suspend when the cable is not present is
an overhead for the system. Hence removed resume and device function
calls when the cable is not present.
Bug 803280
Change-Id: I238474fb1f3629f78833d58a89ffcabff7754fbb
Reviewed-on: http://git-master/r/30500
Reviewed-by: Rakesh Bodla <rbodla@nvidia.com>
* set bsea sclk to ulong_max
* use unbounded work queues with 1 max_active
work item on each of them
* clear INTR_STATUS per operation
* free nvmap handle after using it
Bug 803932
Change-Id: I9e46d86891f0026504ca4ab2f0c6da5776bb9a73
Reviewed-on: http://git-master/r/30196
sclk is shared between usb and avp. usb sets it to 80MHz, hence set sclk rate
to max when avp is running.
Bug 819796
Reviewed-on: http://git-master/r/28765
(cherry picked from commit 44234ba7be2de25ef79b803747064ce54f6dc081)
Change-Id: Iea5c785da0aff69f61c82f7e67356d93ead1d994
Reviewed-on: http://git-master/r/30314
usbd clock is enabled during the probe and not disabled after the
functionality. Due to this clock reference count is non-zero and hence
usbd clock is not disabled during suspend. Fixed this by disabling
clock appropriately.
- Since clocks are now turned off during suspend clock
needs to be enabled during fsl_udc_resume.
Bug 793834
Reviewed-on: http://git-master/r/21652
(cherry picked from commit 8fa46a6da22e6def221435098de054e55c7d1196)
Reviewed-on: http://git-master/r/22999
(cherry picked from commit 7ca37264ae9f7358afea2622fa35b928391f8561)
Change-Id: I9f39696e04674e76fb088e9eee498153f981bac6
Reviewed-on: http://git-master/r/30075
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Delay of 4ms is needed after the SUSPEND bit in the PORTSC register is
programmed. The hardware would be set only after 4ms of delay.
Bug 812427
Change-Id: I5253928264112b429f78e6682e261a44820811db
Reviewed-on: http://git-master/r/27510
Reviewed-on: http://git-master/r/29974
* add bsea engine support for encryption and decryption
* add arbitration semaphore id for bsea
Bug 803932
Change-Id: I978b06a12265acecae99dbf13607e00ae74e87f7
Signed-off-by: Sanjay Singh Rawat <srawat@nvidia.com>
Reviewed-on: http://git-master/r/29672
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
apis added to program max8907c regulator to power down and up core supply rail
via the pwren signal on enter and exit deep sleep mode.
Bug 817378
Change-Id: I5af04db22b6c84fc4359c1a0cf209710ca144159
Reviewed-on: http://git-master/r/28434
arch/arm/mm/proc-v7.S
drivers/video/tegra/dc/dc.c
Change-Id: I40be0d615f14f1c01305388a706d257f624ba968
Resolve potential race between resume and reset
Fix wmb after return
Change-Id: I98ad1e713b9781d780bf93561496011bf62b86d1
Signed-off-by: Andrei Warkentin <andreiw@motorola.com>
Fix SSL3250A camera flash I2C errors.
Bug 778859
Change-Id: Ifaf800405bcfc080a66c500cb74fe87ca3074be9
Reviewed-on: http://git-master/r/28205
Bug 787628
Change-Id: I73c3b8f0b3e69f1c4bc13bdaea84b19b14eb73d1
Signed-off-by: Puneet Saxena <puneets@nvidia.com>
Reviewed-on: http://git-master/r/28003
Signed-off-by: Dmitry Shmidt <dimitrysh@google.com>
Change-Id: I903db54b76781cdb9231bb25d79635cb8f264087
To ensure an accurate read of the RTC registers during the required
multi-byte read operation, the PMU RTC is designed with the following
protection scheme
- A circuit detects a write/read and locks the RTC_COUNT4 value
by keeping the RTC in a suspended mode
- During the suspended mode, a secondary counter is used to
keep track of all counts that would have normally incremented the RTC
- After the read is complete, the value of the secondary counter is
added back to the RTC registers and thereby keeping the RTC accurate
- The backup counter allows for a 1ms RTC suspend mode duration
when the RTC prescaler is enabled.
i2c needs to generate a 2 msgs when reading.
- the address setup(write RTC_COUNT4 operation),
hence start locking the RTC_COUNT4
- the data transfer (read RTC_COUNT4 operation),release locking it.
this may allow the CPU to execute other portions of code
in between the two operation.
The fix is to start a PMU RTC access by reading the register prior to
the RTC_COUNT4 so that access of the RTC PMU registers will be guaranteed
to always occur within the 1ms time period.
- the address setup(write RTC_COUNT4-1 operation),
so there is no locking the RTC_COUNT4
starting locking the RTC_COUNT4 and release locking the RTC_COUNT4
in one operation, so it will be guaranteed within 1ms
Bug 811075
Change-Id: Ie07472a329f6a0eed11e6a039cd93307bb5276a0
Reviewed-on: http://git-master/r/27537
bug 811316
Change-Id: I4513f81719a60c8f214ee07082e58defb1cca0aa
Reviewed-on: http://git-master/r/26985
there was a cropping code which saves from out of FB.However,
the cropping code was wrong and cropping should be done from
usermode driver instead of kernel. a warning is added here
for easy debugging
Bug 792524
Change-Id: Id57243e36f903b14a093dad23a6111032890c01a
Reviewed-on: http://git-master/r/28055
Reviewed-by: Donghan Ryu <dryu@nvidia.com>
Tested-by: Donghan Ryu <dryu@nvidia.com>
PPP handles packet loss but does not work with out of order packets.
This change performs reordering of incoming data packets within a
sliding window of one second. Since sequence number is optional,
receiving a packet without it will drop all queued packets.
Currently the logic is triggered by incoming packets, so queued
packets have to wait till another packet is arrived. It is done for
simplicity since no additional locks or threads are required. For
reliable protocols, a retransmission will kick it. For unreliable
protocols, queued packets just seem like packet loss. Time-critical
protocols might be broken, but they never work with queueing anyway.
Signed-off-by: Chia-chi Yeh <chiachi@android.com>
Change-Id: I023482f230dc4f413647f47b3c7c36fd4c98b97d
Prevents HDMI detect worker from re-disabling DC during
suspend (after tegra_dc_suspend has disabled DC itself)/
Change-Id: I90016fb709934ab8fb5135443980898069f8071f
Signed-off-by: Erik Gilling <konkers@android.com>
When HDCP repeater has no device attached, DEVICE_COUNT reports back as 0.
HDCP driver should handle this case as a good case and continue downstream
authentication, other than fail it.
Change-Id: Ied2e46428c0247f14fbd96016cd4fdbf358f6587
Change-Id: Ibf21f94d93ef237de6ab379dc1aa2498df08cdbd
Bug: 783488
Change-Id: I0d70ec5bb0fd880b167e9ced0e002829abeccdbf
Reviewed-on: http://git-master/r/24969
Add AD5820 focuser driver for Whistler.
Bug 783488
Change-Id: I0d8a08e7df9f472ffc4edfe7bfa255357bff5126
Reviewed-on: http://git-master/r/26970
Register assignments were wrong for incoming overlay blend
parameters. DisplayManagerLite policy sets src combine mode
to premult to signal dst premult aplha blending. But the DC
expects premult set for the dst window for this mode.
Bug 796009
Change-Id: I5929bc4cd362ac60c7a9f14bb4ae83da04b857ab
Reviewed-on: http://git-master/r/26835
Change-Id: I30dfa03324eb5c4c344c62578eb808a150c80deb
use pixel clock to configure HDMI interface signaling properties.
These options are different depending on which SoC.
Bug 786961 Bug 795251
(cherry picked from commit a59e2483a9f85a72186f51c124709401af554eb3)
Change-Id: Ie5ef35fe03065d3e77831a0e1a2bbf8319d04125
Reviewed-on: http://git-master/r/27722
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Tested-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Jessica Liao <jeliao@nvidia.com>
-Removed unused sensor mode mode_1920x1088
-Added ov5650_write_reg_helper function to do write_reg()
according to camera_mode.
-ov5650_get_status function is removed as it is reading reg 2
value and there is not any definition of reg 2 in datasheet and
even user space is not using it's value at all.
-Added ov5650_set_power function to on/off camera sensors power
-Added ioctl OV5650_IOCTL_SET_CAMERA_MODE to set camera_mode
from user space.
-Added i2c driver for right ov5650.
Bug 809921
Change-Id: Ib3cf43d0a064c18c218d0850e849fff84e18e661
Reviewed-on: http://git-master/r/26857
Tested-by: Pritesh Raithatha <praithatha@nvidia.com>
Reviewed-by: George Bauernschmidt <georgeb@nvidia.com>
nvmap's debugfs had a bad format so it was
very difficult to read the outputs. this commit
fixes it and added total allocation size along
with it
Bug 813891
Change-Id: I6e3165b3ff917d9510d39f1e35b8e6b59c086592
Reviewed-on: http://git-master/r/27349
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
This kernel driver will replace the functionality that was
previously in the NVRM daemon root process and allow multiple
instances of OpenMAX to function and AVP resource tracking and
cleanup.
Bug 772210
Change-Id: Ia5eb559cde4644bae5fd8b23a1de57cd65f3fdd8
Reviewed-on: http://git-master/r/25115
Tested-by: Stephen Holmes <sholmes@nvidia.com>
Reviewed-by: Stephen Holmes <sholmes@nvidia.com>
- added the tegra dependent layer of the caif protocol.
- integrated with the open source rainbow caif.
- verified the functionality using latest rainbow RIL.
bug 785523
Change-Id: I75be8d2ef6e5562facf902a3f963f34d241bb6c3
Reviewed-on: http://git-master/r/23421
Specified OSC_SRC_SEL flag to force clock signal to be taken from
an externally generated source rather than be calculated internally.
This should raise the accuracy to within +/-2 seconds/24 hours.
Bug 811075
Bug 810537
Change-Id: I7b7c4e4d752fdc03b81239f362a1d6f7aa4d3b92
Reviewed-on: http://git-master/r/27222
Reviewed-by: Andre Sihera <asihera@nvidia.com>
Tested-by: Andre Sihera <asihera@nvidia.com>
Reviewed-by: David Schalig <dschalig@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
add sleep to let the clock stabilize before handling interrupt.
Bug 814888
Change-Id: I7983017f04ad8b84eb6def0f4f7c580292e6e374
Reviewed-on: http://git-master/r/27592
Change-Id: I016b27ad8ada8ec6214b1ed2b6096c294d2e81b8
If HDCP was turned off (either by unplug or suspend) the work funciton
would wait the full timeout 5 * l.75s before exiting. This
causes suspend to timeout and crash.
Change-Id: I8eb185452ad09e34f4573874e9766c0e1cec15de
drivers/video/tegra/fb.c
Change-Id: Id2c7cf76925c140073baf04244b839c723515254
Change-Id: I4305576b867fb062db791b0e18a8f0215bbc5705
Change-Id: I23f01da0a7dcd62594faa828676ffb7a4bc72d9f
Change-Id: Ic998e183e79faabc36d96720dcbae2640e8cf419
With check from!=to it remains on when device is resumes and usb cable state is
not changed. Always disable the usbd clock after work is done.
Bug 812197
Change-Id: Id0f4bfc6d4eb8f82e010de35594720fc82bd77c4
Reviewed-on: http://git-master/r/27147
Change-Id: I1f85b4ed49128a261b29bb7c3ffe8c5d511a44f9
