path: root/drivers
2012-02-03USB: cp210x: allow more baud rates above 1MbaudJohan Hovold
commit d1620ca9e7bb0030068c3b45b653defde8839dac upstream. Allow more baud rates to be set in [1M,2M] baud. Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: Preston Fick <preston.fick@silabs.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cp210x: initialise baud rate at openJohan Hovold
commit cdc32fd6f7b2b2580d7f1b74563f888e4dd9eb8a upstream. The newer cp2104 devices require the baud rate to be initialised after power on. Make sure it is set when port is opened. Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: Preston Fick <preston.fick@silabs.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cp210x: clean up, refactor and document speed handlingJohan Hovold
commit e5990874e511d5bbca23b3396419480cb2ca0ee7 upstream. Clean up and refactor speed handling. Document baud rate handling for CP210{1,2,4,5,10}. Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: Preston Fick <preston.fick@silabs.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cp210x: fix up set_termios variablesJohan Hovold
commit 34b76fcaee574017862ea3fa0efdcd77a9d0e57d upstream. [Based on a patch from Johan, mangled by gregkh to keep things in line] Fix up the variable usage in the set_termios call. Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: Preston Fick <preston.fick@silabs.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cp210x: do not map baud rates to B0Johan Hovold
commit be125d9c8d59560e7cc2d6e2b65c8fd233498ab7 upstream. We do not implement B0 hangup yet so map low baudrates to 300bps. Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: Preston Fick <preston.fick@silabs.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cp210x: fix CP2104 baudrate usagePreston Fick
commit 7f482fc88ac47662228d6b1f05759797c8936a30 upstream. This fix changes the way baudrates are set on the CP210x devices from Silicon Labs. The CP2101/2/3 will respond to both a GET/SET_BAUDDIV command, and GET/SET_BAUDRATE command, while CP2104 and higher devices only respond to GET/SET_BAUDRATE. The current cp210x.ko driver in kernel version 3.2.0 only implements the GET/SET_BAUDDIV command. This patch implements the two new codes for the GET/SET_BAUDRATE commands. Then there is a change in the way that the baudrate is assigned or retrieved. This is done according to the CP210x USB specification in AN571. This document can be found here: http://www.silabs.com/pages/DownloadDoc.aspx?FILEURL=Support%20Documents/TechnicalDocs/AN571.pdf&src=DocumentationWebPart Sections 5.3/5.4 describe the USB packets for the old baudrate method. Sections 5.5/5.6 describe the USB packets for the new method. This patch also implements the new request scheme, and eliminates the unnecessary baudrate calculations since it uses the "actual baudrate" method. This patch solves the problem reported for the CP2104 in bug 42586, and also keeps support for all other devices (CP2101/2/3). This patchfile is also attached to the bug report on bugzilla.kernel.org. This patch has been developed and test on the 3.2.0 mainline kernel version under Ubuntu 10.11. Signed-off-by: Preston Fick <preston.fick@silabs.com> [duplicate patch also sent by Johan - gregkh] Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cp210x: call generic open last in openJohan Hovold
commit 55b2afbb92ad92e9f6b0aa4354eb1c94589280c3 upstream. Make sure port is fully initialised before calling generic open. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: serial: CP210x: Added USB-ID for the Link Instruments MSO-19Renato Caldas
commit 791b7d7cf69de11275e4dccec2f538eec02cbff6 upstream. This device is a Oscilloscope/Logic Analizer/Pattern Generator/TDR, using a Silabs CP2103 USB to UART Bridge. Signed-off-by: Renato Caldas <rmsc@fe.up.pt> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03macvlan: fix a possible use after freeEric Dumazet
[ Upstream commit 4ec7ac1203bcf21f5e3d977c9818b1a56c9ef40d ] Commit bc416d9768 (macvlan: handle fragmented multicast frames) added a possible use after free in macvlan_handle_frame(), since ip_check_defrag() uses pskb_may_pull() : skb header can be reallocated. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ben Greear <greearb@candelatech.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03bonding: fix enslaving in alb mode when link downJiri Bohac
[ Upstream commit b924551bed09f61b64f21bffe241afc5526b091a ] bond_alb_init_slave() is called from bond_enslave() and sets the slave's MAC address. This is done differently for TLB and ALB modes. bond->alb_info.rlb_enabled is used to discriminate between the two modes but this flag may be uninitialized if the slave is being enslaved prior to calling bond_open() -> bond_alb_initialize() on the master. It turns out all the callers of alb_set_slave_mac_addr() pass bond->alb_info.rlb_enabled as the hw parameter. This patch cleans up the unnecessary parameter of alb_set_slave_mac_addr() and makes the function decide based on the bonding mode instead, which fixes the above problem. Reported-by: Narendra K <Narendra_K@Dell.com> Signed-off-by: Jiri Bohac <jbohac@suse.cz> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cdc-wdm: Avoid hanging on interface with no USB_CDC_DMM_TYPEBjørn Mork
commit 15699e6fafc3a90e5fdc2ef30555a04dee62286f upstream. The probe does not strictly require the USB_CDC_DMM_TYPE descriptor, which is a good thing as it makes the driver usable on non-conforming interfaces. A user could e.g. bind to it to a CDC ECM interface by using the new_id and bind sysfs files. But this would fail with a 0 buffer length due to the missing descriptor. Fix by defining a reasonable fallback size: The minimum device receive buffer size required by the CDC WMC standard, revision 1.1 Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cdc-wdm: better allocate a buffer that is at least as big as we tell ↵Bjørn Mork
the USB core commit 655e247daf52b202a6c2d0f8a06dd2051e756ce4 upstream. As it turns out, there was a mismatch between the allocated inbuf size (desc->bMaxPacketSize0, typically something like 64) and the length we specified in the URB (desc->wMaxCommand, typically something like 2048) Signed-off-by: Bjørn Mork <bjorn@mork.no> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cdc-wdm: call wake_up_all to allow driver to shutdown on device removalBjørn Mork
commit 62aaf24dc125d7c55c93e313d15611f152b030c7 upstream. wdm_disconnect() waits for the mutex held by wdm_read() before calling wake_up_all(). This causes a deadlock, preventing device removal to complete. Do the wake_up_all() before we start waiting for the locks. Signed-off-by: Bjørn Mork <bjorn@mork.no> Cc: Oliver Neukum <oliver@neukum.org> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03hwmon: (sht15) fix bad error codeVivien Didelot
commit 6edf3c30af01854c416f8654d3d5d2652470afd4 upstream. When no platform data was supplied, returned error code was 0. Signed-off-by: Vivien Didelot <vivien.didelot@savoirfairelinux.com> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03hwmon: (w83627ehf) Disable setting DC mode for pwm2, pwm3 on NCT6776FGuenter Roeck
commit ad77c3e1808f07fa70f707b1c92a683b7c7d3f85 upstream. NCT6776F only supports pwm mode for pwm2 and pwm3. Return error if an attempt is made to set those pwm channels to DC mode. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03hwmon: (f71805f) Fix clamping of temperature limitsJean Delvare
commit 86b2bbfdbd1fcc4a3aa62ccd3f245c40c5ad5b85 upstream. Properly clamp temperature limits set by the user. Without this fix, attempts to write temperature limits above the maximum supported by the chip (255 degrees Celsius) would arbitrarily and unexpectedly result in the limit being set to 0 degree Celsius. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03usb: musb: davinci: fix build breakageSekhar Nori
commit 006896fc612f11bf0624db7814a75d0d5410855f upstream. Commit 0020afb369859472a461ef4af6410732e929d402 (ARM: mach-davinci: remove mach/memory.h) removed mach/memory.h for DaVinci which broke DaVinci MUSB build. mach/memory.h is not actually needed in davinci.c, so remove it. While at it, also remove some more machine specific inclulde files which are not needed for build. Tested on DM644x EVM using USB card reader. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03xHCI: Cleanup isoc transfer ring when TD length mismatch foundAndiry Xu
commit cf840551a884360841bd3d3ce1ad0868ff0b759a upstream. When a TD length mismatch is found during isoc TRB enqueue, it directly returns -EINVAL. However, isoc transfer is partially enqueued at this time, and the ring should be cleared. This should be backported to kernels as old as 2.6.36, which contain the commit 522989a27c7badb608155b1f1dea3487ed431f74 "xhci: Fix failed enqueue in the middle of isoch TD." Signed-off-by: Andiry Xu <andiry.xu@amd.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03xhci: Fix USB 3.0 device restart on resume.Sarah Sharp
commit d0cd5d482b8a6dc92c6c69a5387baf72ea84f23a upstream. The xHCI hub port code gets passed a zero-based port number by the USB core. It then adds one to in order to find a device slot by port number and device speed by calling xhci_find_slot_id_by_port. That function clearly states it requires a one-based port number. The xHCI port status change event handler was using a zero-based port number that it got from find_faked_portnum_from_hw_portnum, not a one-based port number. This lead to the doorbells never being rung for a device after a resume, or worse, a different device with the same speed having its doorbell rung (which could lead to bad power management in the xHCI host controller). This patch should be backported to kernels as old as 2.6.39. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Acked-by: Andiry Xu <andiry.xu@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03drivers/usb/host/ehci-fsl.c: add missing iounmapJulia Lawall
commit 2492c6e6454ff3edb11e273b071a6ea80a199c71 upstream. Add missing iounmap in error handling code, in a case where the function already preforms iounmap on some other execution path. A simplified version of the semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression e; statement S,S1; int ret; @@ e = \(ioremap\|ioremap_nocache\)(...) ... when != iounmap(e) if (<+...e...+>) S ... when any when != iounmap(e) *if (...) { ... when != iounmap(e) return ...; } ... when any iounmap(e); // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03usb: gadget: storage: endian fixAndiry Xu
commit a85016390135d577c457876d0e905095600751de upstream. Fix some endian issues for storage gadgets. Signed-off-by: Andiry Xu <andiry.xu@amd.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03usb: gadget: langwell: don't call gadget's disconnect()Alexander Shishkin
commit 37fd37108449d574da11aa9055c5c8afb39ff226 upstream. UDC core will call disconnect() and unbind() for us upon the gadget removal, so we should not do it ourselves. Otherwise, a composite gadget will explode, for example. Others might too. This was introduced during conversion to new style gadget in 2c7f0989 (usb: gadget: langwell: convert to new style). Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Heikki Krogerus <heikki.krogerus@linux.intel.com> Cc: linux-usb@vger.kernel.org Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: usbsevseg: fix max lengthHarrison Metzger
commit 1097ccebe630170080c41df0edcf88e0626e9c75 upstream. This changes the max length for the usb seven segment delcom device to 8 from 6. Delcom has both 6 and 8 variants and having 8 works fine with devices which are only 6. Signed-off-by: Harrison Metzger <harrisonmetz@gmail.com> Signed-off-by: Stuart Pook <stuart@acm.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: Realtek cr: fix autopm scheduling while atomicStanislaw Gruszka
commit b3ef051db763b640d1ff724b616ffba940896b44 upstream. Resolves: https://bugzilla.redhat.com/show_bug.cgi?id=784345 Reported-by: Francis Moreau <francis.moro@gmail.com> Reported-and-tested-by: Christian D <chrisudeussen@gmail.com> Reported-and-tested-by: Jimmy Dorff <jdorff@phy.duke.edu> Reported-and-tested-by: collura@ieee.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03vmwgfx: Fix assignment in vmw_framebuffer_create_handleRyan Mallon
commit bf9c05d5b6d19b3e4c9fe21047694e94f48db89b upstream. The assignment of handle in vmw_framebuffer_create_handle doesn't actually do anything useful and is incorrectly assigning an integer value to a pointer argument. It appears that this is a typo and should be dereferencing handle rather than assigning to it directly. This fixes a bug where an undefined handle value is potentially returned to user-space. Signed-off-by: Ryan Mallon <rmallon@gmail.com> Reviewed-by: Jakob Bornecrantz<jakob@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03iwlwifi: fix PCI-E transport "inta" raceJohannes Berg
commit b49ba04a3a0382e7314d990707c21094c410425a upstream. When an interrupt comes in, we read the reason bits and collect them into "trans_pcie->inta". This happens with the spinlock held. However, there's a bug resetting this variable -- that happens after the spinlock has been released. This means that it is possible for interrupts to be missed if the reset happens after some other interrupt reasons were already added to the variable. I found this by code inspection, looking for a reason that we sometimes see random commands time out. It seems possible that this causes such behaviour, but I can't say for sure right now since it happens extremely infrequently on my test systems. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03jsm: Fixed EEH recovery errorLucas Kannebley Tavares
commit 26aa38cafae0dbef3b2fe75ea487c83313c36d45 upstream. There was an error on the jsm driver that would cause it to be unable to recover after a second error is detected. At the first error, the device recovers properly: [72521.485691] EEH: Detected PCI bus error on device 0003:02:00.0 [72521.485695] EEH: This PCI device has failed 1 times in the last hour: ... [72532.035693] ttyn3 at MMIO 0x0 (irq = 49) is a jsm [72532.105689] jsm: Port 3 added However, at the second error, it cascades until EEH disables the device: [72631.229549] Call Trace: ... [72641.725687] jsm: Port 3 added [72641.725695] EEH: Detected PCI bus error on device 0003:02:00.0 [72641.725698] EEH: This PCI device has failed 3 times in the last hour: It was caused because the PCI state was not being saved after the first restore. Therefore, at the second recovery the PCI state would not be restored. Signed-off-by: Lucas Kannebley Tavares <lucaskt@linux.vnet.ibm.com> Signed-off-by: Breno Leitao <brenohl@br.ibm.com> Acked-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03serial: amba-pl011: lock console writes against interruptsRabin Vincent
commit ef605fdb33883d687cff5ba75095a91b313b4966 upstream. Protect against pl011_console_write() and the interrupt for the console UART running concurrently on different CPUs. Otherwise the console_write could spin for a long time waiting for the UART to become not busy, while the other CPU continuously services UART interrupts and keeps the UART busy. The checks for sysrq and oops_in_progress are taken from 8250.c. Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Reviewed-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Reviewed-by: Bibek Basu <bibek.basu@stericsson.com> Reviewed-by: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03TTY: fix UV serial console regressionJiri Slaby
commit 0eee50af5b13e00b3fb7a5fe8480419a71b8235d upstream. Commit 74c2107759d (serial: Use block_til_ready helper) and its fixup 3f582b8c110 (serial: fix termios settings in open) introduced a regression on UV systems. The serial eventually freezes while being used. It's completely unpredictable and sometimes needs a heap of traffic to happen first. To reproduce this, yast installation was used as it turned out to be pretty reliable in reproducing. Especially during installation process where one doesn't have an SSH daemon running. And no monitor as the HW is completely headless. So this was fun to find. Given the machine doesn't boot on vanilla before 2.6.36 final. (And the commits above are older.) Unless there is some bad race in the code, the hardware seems to be pretty broken. Otherwise pure MSR read should not cause such a bug, or? So to prevent the bug, revert to the old behavior. I.e. read modem status only if we really have to -- for non-CLOCAL set serials. Non-CLOCAL works on this hardware OK, I tried. See? I don't. And document that shit. Signed-off-by: Jiri Slaby <jslaby@suse.cz> References: https://lkml.org/lkml/2011/12/6/573 References: https://bugzilla.novell.com/show_bug.cgi?id=718518 Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03usb: io_ti: Make edge_remove_sysfs_attrs the port_remove method.Eric W. Biederman
commit 6d443d8499e4e59ffb949759cdded32730f8d2f6 upstream. Calling edge_remove_sysfs_attrs from edge_disconnect is too late as the device has already been removed from sysfs. Do the simple and obvious thing and make edge_remove_sysfs_attrs the port_remove method. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Reported-by: Wolfgang Frisch <wfpub@roembden.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03usb: dwc3: ep0: tidy up Pending Request handlingFelipe Balbi
commit 68d8a781575d7be490f97eb2c403fb13b083da6a upstream. The way our code was written, we should never have a DWC3_EP_PENDING_REQUEST flag set out of a Data Phase and the code in __dwc3_gadget_ep0_queue() did not reflect that situation properly. Tidy up that case to avoid any possible mistakes when starting requests for IRQs which are long gone. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03qcaux: add more Pantech UML190 and UML290 portsDan Williams
commit 074cc73506f529f39fef32ad1c9e1d4cdd8acf6c upstream. More ports we now know how to talk to. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cdc-wdm: use two mutexes to allow simultaneous read and writeBjørn Mork
commit e8537bd2c4f325a4796da33564ddcef9489b7feb upstream. using a separate read and write mutex for locking is sufficient to make the driver accept simultaneous read and write. This improves useability a lot. Signed-off-by: Bjørn Mork <bjorn@mork.no> Cc: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: cdc-wdm: updating desc->length must be protected by spin_lockBjørn Mork
commit c428b70c1e115c5649707a602742e34130d19428 upstream. wdm_in_callback() will also touch this field, so we cannot change it without locking Signed-off-by: Bjørn Mork <bjorn@mork.no> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: ftdi_sio: Add more identifiersAlan Cox
commit 2353f806c97020d4c7709f15eebb49b591f7306d upstream. 0x04d8, 0x000a: Hornby Elite Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: serial: ftdi additional IDsPeter Naulls
commit fc216ec363f4d174932df90bbf35c77d0540e561 upstream. I tested this against 2.6.39 in the Ubuntu kernel, however I see the IDs are not in latest 3.2 git. This adds IDs for the FTDI controller in the Rainforest Automation Zigbee dongle. Signed-off-by: Peter Naulls <peter@chocky.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: ftdi_sio: add PID for TI XDS100v2 / BeagleBone A3Peter Korsgaard
commit 55f13aeae0346f0c89bfface91ad9a97653dc433 upstream. Port A for JTAG, port B for serial. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: ftdi_sio: fix initial baud rateJohan Hovold
commit 108e02b12921078a59dcacd048079ece48a4a983 upstream. Fix regression introduced by commit b1ffb4c851f1 ("USB: Fix Corruption issue in USB ftdi driver ftdi_sio.c") which caused the termios settings to no longer be initialised at open. Consequently it was no longer possible to set the port to the default speed of 9600 baud without first changing to another baud rate and back again. Reported-by: Roland Ramthun <mail@roland-ramthun.de> Signed-off-by: Johan Hovold <jhovold@gmail.com> Tested-by: Roland Ramthun <mail@roland-ramthun.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: ftdi_sio: fix TIOCSSERIAL baud_base handlingJohan Hovold
commit eb833a9e0972f60beb4ab8104ad7ef6bf30f02fc upstream. Return EINVAL if new baud_base does not match the current one. The baud_base is device specific and can not be changed. This restores the old (pre-2005) behaviour which was changed due to a misunderstanding regarding this fact (see https://lkml.org/lkml/2005/1/20/84). Reported-by: Torbjörn Lofterud <torbjorn@pi.nxs.se> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03USB: option: Add LG docomo L-02CKentaro Matsuyama
commit e423d7401fd0717cb56a6cf51dd8341cc3e800d2 upstream. Add vendor and product ID for USB 3G/LTE modem of docomo L-02C Signed-off-by: Kentaro Matsuyama <kentaro.matsuyama@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03mpt2sas: Removed redundant calling of _scsih_probe_devices() from _scsih_probenagalakshmi.nandigama@lsi.com
commit 2cb6fc8c014b9b00c4487a79b8f6ed0da4121f45 upstream. Removed redundant calling of _scsih_probe_devices() from _scsih_probe as it is getting called from _scsih_scan_finished. Also moved the function scsi_scan_host(shost) to get called after the volumes on warp drive are reported to the OS. Otherwise by the time the (ioc->hide_drives) flags is set, the volumes on warp drive are reported to the OS already. Also modified the initialization of reply queues only in case of driver load time in the function _base_make_ioc_operational(). Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03drm/i915: Re-enable gen7 RC6 and GPU turbo after resume.Eric Anholt
commit 04115a9dee110b52a8eaa556c574022fa3bf4704 upstream. Signed-off-by: Eric Anholt <eric@anholt.net> Reviewed-by: Keith Packard <keithp@keithp.com> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Kenneth Graunke <kenneth@whitecape.org> Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03drm/i915/sdvo: always set positive sync polarityPaulo Zanoni
commit ba68e086223a5f149f37bf8692c8cdbf1b0ba3ef upstream. This is a revert of 81a14b46846fea0741902e8d8dfcc6c6c78154c8. We already set the mode polarity using the SDVO commands with struct intel_sdvo_dtd. We have at least 3 bugs that get fixed with this patch. The documentation, despite not clear, can also be interpreted in a way that suggests this patch is needed. Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=15766 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=42174 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=43333 Reviewed-by: Eric Anholt <eric@anholt.net> Reviewed-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03drm/i915: paper over missed irq issues with force wake voodooDaniel Vetter
commit 4cd53c0c8b01fc05c3ad5b2acdad02e37d3c2f55 upstream. Two things seem to do the trick on my ivb machine here: - prevent the gt from powering down while waiting for seqno notification interrupts by grabbing the force_wake in get_irq (and dropping it in put_irq again). - ordering writes from the ring's CS by reading a CS register, ACTHD seems to work. Only the blt&bsd ring on ivb seem to be massively affected by this, but for paranoia do this dance also on the render ring and on snb (i.e. all gpus with forcewake). Tested with Eric's glCopyPixels loop which without this patch scores a missed irq every few seconds. This patch needs my forcewake rework to use a spinlock instead of dev->struct_mutex. After crawling through docs a lot I've found the following nugget: Internal doc "SNB GT PM Programming Guide", Section 4.3.1: "GT does not generate interrupts while in RC6 (by design)" So it looks like rc6 and irq generation are indeed related. v2: Improve the comment per Eugeni Dodonov's suggestion. v3: Add the documentation snipped. Also restrict the w/a to ivb only for -fixes, as suggested by Keith Packard. Cc: Eric Anholt <eric@anholt.net> Cc: Kenneth Graunke <kenneth@whitecape.org> Cc: Eugeni Dodonov <eugeni.dodonov@intel.com> Tested-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Reviewed-by: Eugeni Dodonov <eugeni.dodonov@intel.com> Signed-Off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03tpm_tis: add delay after aborting commandStefan Berger
commit a927b8131794ee449b7f6666e7ab61301949b20f upstream. This patch adds a delay after aborting a command. Some TPMs need this and will not process the subsequent command correctly otherwise. It's worth noting that a TPM randomly failing to process a command, maps to randomly failing suspend/resume operations. Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com> Signed-off-by: Rajiv Andrade <srajiv@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03brcmsmac: fix tx queue flush infinite loopStanislaw Gruszka
commit f96b08a7e6f69c0f0a576554df3df5b1b519c479 upstream. This patch workaround live deadlock problem caused by infinite loop in brcms_c_wait_for_tx_completion(). I do not consider the patch as the proper fix, which should fix the real reason of tx queue flush failure, but patch helps with system lockup. Reference: https://bugzilla.kernel.org/show_bug.cgi?id=42576 Reported-and-tested-by: Patrick <ragamuffin@datacomm.ch> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03drm: Fix authentication kernel crashThomas Hellstrom
commit 598781d71119827b454fd75d46f84755bca6f0c6 upstream. If the master tries to authenticate a client using drm_authmagic and that client has already closed its drm file descriptor, either wilfully or because it was terminated, the call to drm_authmagic will dereference a stale pointer into kmalloc'ed memory and corrupt it. Typically this results in a hard system hang. This patch fixes that problem by removing any authentication tokens (struct drm_magic_entry) open for a file descriptor when that file descriptor is closed. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03drm/radeon/kms: rework modeset sequence for DCE41 and DCE5Alex Deucher
commit 3a47824d85eeca122895646f027dc63480994199 upstream. dig transmitter control table only has ENABLE/DISABLE actions on DCE4.1/DCE5. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=44955 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03drm/radeon/kms: move panel mode setup into encoder mode setAlex Deucher
commit 386d4d751e8e0b4b693bb724f09aae064ee5297d upstream. Needs to happen earlier in the mode set. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-03drm/radeon/kms: Add an MSI quirk for Dell RS690Alex Deucher
commit 44517c44496062180a6376cc704b33129441ce60 upstream. Interrupts only work with MSIs. https://bugs.freedesktop.org/show_bug.cgi?id=37679 Reported-by: Dmitry Podgorny <pasis.uax@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
