* acpi-general:
ACPI: Fix bug when ACPI reset register is implemented in system memory
* acpi-video:
ACPI / video: Change the default for video.use_native_backlight to 1
We have a number of front-end drivers for SDHCI_PLTFM, some of them
use 'select MMC_SDHCI_PLTFM', others use 'depends on'. This is
inconsistent and confusing, and in one case has also led to a
build error because of incomplete dependencies:
warning: (MMC_SDHCI_PXAV3 && MMC_SDHCI_PXAV2 && MMC_SDHCI_BCM_KONA) selects MMC_SDHCI_PLTFM which has unmet direct dependencies (MMC && MMC_SDHCI)
drivers/built-in.o: In function `sdhci_sirf_resume':
:(.text+0xaaacb4): undefined reference to `sdhci_resume_host'
drivers/built-in.o: In function `sdhci_sirf_suspend':
:(.text+0xaaacf8): undefined reference to `sdhci_suspend_host'
drivers/built-in.o: In function `sdhci_sirf_probe':
:(.text+0xaaaf44): undefined reference to `sdhci_add_host'
:(.text+0xaaaf50): undefined reference to `sdhci_remove_host'
This changes Kconfig to use 'depends on MMC_SDHCI_PLTFM' for all these
cases, to fix the build error and make the logic more logical.
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
The MMC host driver should not select the pmic driver, since that
may have other dependencies, notably i2c in this case. It's not
clear what the exact requirement of the driver is, but to preserve
the behavior, this patch changes the 'select' into 'depends on',
meaning you now have to turn on TPS65010 explicitly and then
MMC_OMAP.
Found during randconfig build testing.
Cc: linux-omap@vger.kernel.org
Cc: Jarkko Nikula <jarkko.nikula@bitmer.com>
gcc correctly points out that hw_state can be used uninitially
in the mvsd_setup_data() function. This rearranges the function
to ensure it always contains a proper value.
Cc: Nicolas Pitre <nico@fluxnic.net>
Cc: Chris Ball <chris@printf.net>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Cc: Jason Cooper <jason@lakedaemon.net>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: linux-mmc@vger.kernel.org
Acked-by: Nicolas Pitre <nico@linaro.org>
This avoids a build error due to the use of flush_dcache_page.
drivers/mmc/host/atmel-mci.c: In function 'atmci_read_data_pio':
drivers/mmc/host/atmel-mci.c:1870:5: error: implicit declaration of function 'flush_dcache_page' [-Werror=implicit-function-declaration]
flush_dcache_page(sg_page(sg));
Cc: Ludovic Desroches <ludovic.desroches@atmel.com>
Acked-by: Ludovic Desroches <ludovic.desroches@atmel.com>
The sdhci core was refactored recently and some of those
refactorings required changes in every sdhci platform driver.
Those updates happened around the same time as when the msm
driver was merged so the refactorings missed the msm driver.
Hook in the basic library functions so that we can boot apq8074
dragonboards again instead of crashing when we try to jump to
NULL function pointers.
Reported-by: Kevin Hilman <khilman@linaro.org>
Cc: Georgi Djakov <gdjakov@mm-sol.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Acked-by: Kumar Gala <galak@codeaurora.org>
Reviewed-by: Georgi Djakov <gdjakov@mm-sol.com>
Tested-by: Kevin Hilman <khilman@linaro.org>
Fix a number of wrong print formats.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski+renesas@gmail.com>
Commit dd34c37aa3e (gpio: of: Allow -gpio suffix for property names)
added parsing for both -gpio and -gpios suffix but also changed
the handling for deferred probe unintentionally. Because of the
looping the second name will now return -ENOENT instead of
-EPROBE_DEFER. Fix the issue by breaking out of the loop if
-EPROBE_DEFER is encountered.
Reviewed-by: Thierry Reding <treding@nvidia.com>
Backmerge of dcache.c changes from mainline. It's that, or complete
rebase...
fs/splice.c
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio updates from Rusty Russell:
"Main excitement is a virtio_scsi fix for alloc holding spinlock on the
abort path, which I refuse to CC stable since (1) I discovered it
myself, and (2) it's been there forever with no reports"
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
virtio_scsi: don't call virtqueue_add_sgs(... GFP_NOIO) holding spinlock.
virtio-rng: fixes for device registration/unregistration
virtio-rng: fix boot with virtio-rng device
virtio-rng: support multiple virtio-rng devices
virtio_ccw: introduce device_lost in virtio_ccw_device
virtio: virtio_break_device() to mark all virtqueues broken.
Pull vhost infrastructure updates from Michael S. Tsirkin:
"This reworks vhost core dropping unnecessary RCU uses in favor of VQ
mutexes which are used on fast path anyway. This fixes worst-case
latency for users which change the memory mappings a lot. Memory
allocation for vhost-net now supports fallback on vmalloc (same as for
vhost-scsi) this makes it possible to create the device on systems
where memory is very fragmented, with slightly lower performance"
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
vhost: move memory pointer to VQs
vhost: move acked_features to VQs
vhost: replace rcu with mutex
vhost-net: extend device allocation to vmalloc
Pull arch/tile changes from Chris Metcalf:
"These mostly just address smaller issues reported to me"
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch: tile: kernel: unaligned.c: Cleaning up uninitialized variables
drivers/tty/hvc/hvc_tile.c: use PTR_ERR_OR_ZERO
replace strict_strto* call with kstrto*
tile: Update comments for generic idle conversion
tile: cleanup the comment in init_pgprot
tile: use BOOTMEM_DEFAULT instead of magic number 0 for reserve_bootmem flags
Pull module updates from Rusty Russell:
"Most of this is cleaning up various driver sysfs permissions so we can
re-add the perm check (we unified the module param and sysfs checks,
but the module ones were stronger so we weakened them temporarily).
Param parsing gets documented, and also "--" now forces args to be
handed to init (and ignored by the kernel).
Module NX/RO protections get tightened: we now set them before calling
parse_args()"
* tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
module: set nx before marking module MODULE_STATE_COMING.
samples/kobject/: avoid world-writable sysfs files.
drivers/hid/hid-picolcd_fb: avoid world-writable sysfs files.
drivers/staging/speakup/: avoid world-writable sysfs files.
drivers/regulator/virtual: avoid world-writable sysfs files.
drivers/scsi/pm8001/pm8001_ctl.c: avoid world-writable sysfs files.
drivers/hid/hid-lg4ff.c: avoid world-writable sysfs files.
drivers/video/fbdev/sm501fb.c: avoid world-writable sysfs files.
drivers/mtd/devices/docg3.c: avoid world-writable sysfs files.
speakup: fix incorrect perms on speakup_acntsa.c
cpumask.h: silence warning with -Wsign-compare
Documentation: Update kernel-parameters.tx
param: hand arguments after -- straight to init
modpost: Fix resource leak in read_dump()
net/core/rtnetlink.c
net/core/skbuff.c
Both conflicts were very simple overlapping changes.
Signed-off-by: Shruti Kanetkar <Shruti@Freescale.com>
Print the device address, the register number and the PHY ID for
which the MDIO read operation failed
Need to gro_postpull_rcsum for GRO to work with checksum complete.
Signed-off-by: Tom Herbert <therbert@google.com>
Signed-off-by: Shahed Shaikh <shahed.shaikh@qlogic.com>
- Check interrupt mode at the start of qlcnic_set_channels().
- Do not validate ring count if they are not going to change.
Pre-allocate the physically contiguous DMA buffer used for
minidump collection at driver load time, rather than at
run time, to minimize allocation failures. Driver will allocate
the buffer at load time if PEX DMA support capability is indicated
by the adapter.
We recently change the kzalloc() to devm_kzalloc() so freeing "ctlr"
here could lead to a double free.
Fixes: e194312854ed ('drivers: net: davinci_cpdma: Convert kzalloc() to devm_kzalloc().')
There is a typo here so we return directly instead of unwinding.
Acked-by: Tom Lendacky <thomas.lendacky@amd.com>
adds the device managed APIs so that no need worry about
freeing the resources.
Signed-off-by: Varka Bhadram <varkab@cdac.in>
Fixes:ee45fd92c739
("sfc: Use TX PIO for sufficiently small packets")
The linux net driver uses memcpy_toio() in order to copy into
the PIO buffers.
Even on a 64bit machine this causes 32bit accesses to a write-
combined memory region.
There are hardware limitations that mean that only 64bit
naturally aligned accesses are safe in all cases.
Due to being write-combined memory region two 32bit accesses
may be coalesced to form a 64bit non 64bit aligned access.
Solution was to open-code the memory copy routines using pointers
and to only enable PIO for x86_64 machines.
Not tested on platforms other than x86_64 because this patch
disables the PIO feature on other platforms.
Compile-tested on x86 to ensure that works.
The WARN_ON_ONCE() code in the previous version of this patch
has been moved into the internal sfc debug driver as the
assertion was unnecessary in the upstream kernel code.
This bug fix applies to v3.13 and v3.14 stable branches.
Signed-off-by: Shradha Shah <sshah@solarflare.com>
commit e9ce7cb6b107 ("xen-netback: Factor queue-specific data into
queue struct") added a use of vzalloc/vfree to interface.c, but
removed the #include <linux/vmalloc.h> statement at the same time,
which causes this build error:
drivers/net/xen-netback/interface.c: In function 'xenvif_free':
drivers/net/xen-netback/interface.c:754:2: error: implicit declaration of function 'vfree' [-Werror=implicit-function-declaration]
vfree(vif->queues);
cc1: some warnings being treated as errors
Cc: Wei Liu <wei.liu2@citrix.com>
Cc: Andrew J. Bennieston <andrew.bennieston@citrix.com>
Acked-by: Wei Liu <wei.liu2@citrix.com>
Using phy_drivers_register/_unregister functions is proper way to
handle multiple PHY drivers registration. For Realtek PHY drivers
module, it fixes incomplete current error-handlings up and adds
missed unregistration for the RTL8201CP driver.
Signed-off-by: Jongsung Kim <neidhard.kim@lge.com>
This patch fixes an issue that we cannot use nfs rootfs correctly
on r8a7790 when the command below runs on a host PC.
$ sudo ping -f -l 8 $BOARD_IP_ADDR
Since the driver sets the RACT to 1 in the first while loop of
sh_eth_rx(), the controller accepts a next frame into the next RX
descriptor during the while loop. But, in the first while loop
doesn't allocate a next skb. So, this patch removes the RACT setting
in the first while loop of sh_eth_rx().
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
This patch fixes the packet "exceeded" condition in sh_eth_rx() when
RACT in an RX descriptor is not set and the "quota" is 0.
Otherwise, kernel panic happens because the "&n->poll_list" is deleted
twice in sh_eth_poll() which calls napi_complete() and net_rx_action().
Signed-off-by: Kouei Abe <kouei.abe.cp@renesas.com>
The SXGBE_CORE_L34_ADDCTL_REG define is cut and pasted twice so we can
delete the second instance.
The QLC_83XX_GET_LSO_CAPABILITY define is cut and pasted twice so we can
Acked-by: Sony Chacko <sony.chacko@qlogic.com>
The “affinity hint” mechanism is used by the user space
daemon, irqbalancer, to indicate a preferred CPU mask for irqs.
Irqbalancer can use this hint to balance the irqs between the
cpus indicated by the mask.
We wish the HCA to preferentially map the IRQs it uses to numa cores
close to it. To accomplish this, we use cpumask_set_cpu_local_first(), that
sets the affinity hint according the following policy:
First it maps IRQs to “close” numa cores. If these are exhausted, the
remaining IRQs are mapped to “far” numa cores.
Signed-off-by: Yuval Atias <yuvala@mellanox.com>
Signed-off-by: Amir Vadai <amirv@mellanox.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal management update from Zhang Rui:
"Specifics:
- fix a bug in Exynos thermal driver, which overwrites the hardware
trip point threshold when updating software trigger levels and
results in emergency shutdown. From: Tushar Behera.
- add thermal sensor support for Armada 375 and 38x SoCs. From
Ezequiel Garcia.
- add TMU (Thermal Management Unit) support for Exynos5260 and
Exynos5420 SoCs. From Naveen Krishna Chatradhi.
- add support for the additional digital temperature sensors in the
Intel SoCs like Bay Trail. From: Srinivas Pandruvada.
- a couple of cleanups and small fixes from Jingoo Han, Bartlomiej
Zolnierkiewicz, Geert Uytterhoeven, Jacob Pan, Paul Walmsley and
Lan,Tianyu"
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (21 commits)
thermal: spear: remove unnecessary OOM messages
thermal: exynos: remove unnecessary OOM messages
thermal: rcar: remove unnecessary OOM messages
thermal: armada: Support Armada 380 SoC
thermal: armada: Support Armada 375 SoC
thermal: armada: Allow to specify an 'inverted readout' sensor
thermal: armada: Pass the platform_device to init_sensor()
thermal: armada: Add generic infrastructure to handle the sensor
thermal: armada: Add infrastructure to support generic formulas
thermal: armada: Rename armada_thermal_ops struct
thermal/intel_powerclamp: add newer cpu ids
thermal: rcar: Use pm_runtime_put() i.s.o. pm_runtime_put_sync()
thermal: samsung: Only update available threshold limits
Thermal/int3403: Fix thermal hysteresis unit conversion
thermal: Intel SoC DTS thermal
thermal: samsung: Add TMU support for Exynos5260 SoCs
thermal: samsung: Add TMU support for Exynos5420 SoCs
thermal: samsung: change base_common to more meaningful base_second
thermal: samsung: replace inten_ bit fields with intclr_
thermal: offer Samsung thermal support only when ARCH_EXYNOS is defined
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm changes from Thierry Reding:
"The majority of these changes are cleanups and fixes across all
drivers. Redundant error messages are removed and more PWM
controllers set the .can_sleep flag to signal that they can't be used
in atomic context.
Support is added for the Broadcom Kona family of SoCs and the Intel
LPSS driver can now probe PCI devices in addition to ACPI devices.
Upon shutdown, the pwm-backlight driver will now power off the
backlight. It also uses the new descriptor-based GPIO API for more
concise GPIO handling.
A large chunk of these changes also converts platforms to use the
lookup mechanism rather than relying on the global number space to
reference PWM devices. This is largely in preparation for more
unification and cleanups in future patches. Eventually it will allow
the legacy PWM API to be removed"
* tag 'pwm/for-3.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (38 commits)
pwm: fsl-ftm: set pwm_chip can_sleep flag
pwm: ab8500: Fix wrong value shift for disable/enable PWM
pwm: samsung: do not set manual update bit in pwm_samsung_config
pwm: lp3943: Set pwm_chip can_sleep flag
pwm: atmel: set pwm_chip can_sleep flag
pwm: mxs: set pwm_chip can_sleep flag
pwm: tiehrpwm: inline accessor functions
pwm: tiehrpwm: don't build PM related functions when not needed
pwm-backlight: retrieve configured PWM period
leds: leds-pwm: retrieve configured PWM period
ARM: pxa: hx4700: use PWM_LOOKUP to initialize struct pwm_lookup
ARM: shmobile: armadillo: use PWM_LOOKUP to initialize struct pwm_lookup
ARM: OMAP3: Beagle: use PWM_LOOKUP to initialize struct pwm_lookup
pwm: modify PWM_LOOKUP to initialize all struct pwm_lookup members
ARM: pxa: hx4700: initialize all the struct pwm_lookup members
ARM: OMAP3: Beagle: initialize all the struct pwm_lookup members
pwm: renesas-tpu: remove unused struct tpu_pwm_platform_data
ARM: shmobile: armadillo: initialize all struct pwm_lookup members
pwm: add period and polarity to struct pwm_lookup
pwm: twl: Really disable twl6030 PWMs
DM thinp already checks whether the discard_granularity of the data
device is a factor of the thin-pool block size. But when using the
dm-thin-pool's discard passdown support, DM thinp was not selecting the
max of the underlying data device's discard_granularity and the
thin-pool's block size.
Update set_discard_limits() to set discard_granularity to the max of
these values. This enables blkdev_issue_discard() to properly align the
discards that are sent to the DM thin device on a full block boundary.
As such each discard will now cover an entire DM thin-pool block and the
block will be reclaimed.
Reported-by: Zdenek Kabelac <zkabelac@redhat.com>
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Cc: stable@vger.kernel.org
Split the single per bio-prison lock by using per bucket locking. Per
bucket locking benefits both dm-thin and dm-cache targets by reducing
bio-prison lock contention.
Signed-off-by: Heinz Mauelshagen <heinzm@redhat.com>
Signed-off-by: Joe Thornber <ejt@redhat.com>
* pci/msi:
PCI/MSI: Fix memory leak in free_msi_irqs()
* pci/iommu:
PCI: Add function 1 DMA alias quirk for HighPoint RocketRaid 642L
PCI: Add bridge DMA alias quirk for ITE bridge
* pci/cleanup:
PCI: Merge multi-line quoted strings
PCI: Whitespace cleanup
PCI: Move EXPORT_SYMBOL so it immediately follows function/variable
This patch updates vhost_scsi_get_tag() to accept the combined
expected data transfer length + T10 PI bytes as the value passed
into target_submit_cmd().
This is required now that target-core logic in commit 14ef9200
expects to subtract se_cmd->prot_length from se_cmd->data_length.
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
Cc: Sagi Grimberg <sagig@mellanox.com>
In various areas of the code, it is assumed that
se_cmd->data_length describes pure data. In case
that protection information exists over the wire
(protect bits is are on) the target core re-calculates
the data length from the CDB and the backed device
block size (instead of each transport peeking in the cdb).
Modify loopback device to include protection information
in the transferred data length (like other scsi transports).
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
Cc: stable@vger.kernel.org # 3.15+
In case protection information exists over the wire
iscsi header data length is required to include it.
Use protection information aware scsi helpers to set
the correct transfer length.
In order to avoid breakage, remove iser transfer length
checks for each task as they are not always true and
somewhat redundant anyway.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Acked-by: Mike Christie <michaelc@cs.wisc.edu>
This device uses function 1 as the PCIe requester ID.
This vendor has similar boards based on the same Marvell 88SE9235 chipset,
but this patch was only tested with the 642L.
Tested on ASUS Sabertooth 990FX (AMD).
Link: https://bugzilla.kernel.org/show_bug.cgi?id=42679
Signed-off-by: Jérôme Carretero <cJ-ko@zougloub.eu>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Alex Williamson <alex.williamson@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jkirsher/net-next
Jeff Kirsher says:
Intel Wired LAN Driver Updates 2014-06-11
This series contains updates to igb, i40e and i40evf.
Todd makes a change to igb to un-hide invariant returns by getting rid of
the E1000_SUCCESS define and converting those returns to return 0.
Jacob separates the hardware logic from the set function, so that we can
re-use it during a ptp_reset in igb. This enables the reset to return
functionality to the last know timestamp mode, rather than resetting the
value.
Ashish implements context flags for headwb and headwb_addr so that we
do not have to keep them always enabled.
Shannon updates the admin queue API for the new firmware, which adds
set_pf_content, nvm_config_read/write, replaces set_phy_reset with
set_phy_debug and removes nvm_read/write_reg_se. Cleans up the driver
to use the stored base_queue value since there is no need to read the
PCI register for the PF's base queue on every single transmit queue
enable and disable as we already have the value stored from reading
the capability features at startup.
Anjali changes the notion of source and destination for FD_SB in ethtool
to align i40e with other drivers. Adds flow director statistics to
the PF stats. Fixes a bug in ethtool for flow director drop packet
filter where the drop action comes down as a ring_cookie value, so allow
it as a special value that can be used to configure destination control.
Mitch fixes the i40evf to keep the driver from going down when it is
already in a down state. This prevents a CPU soft lock in napi_disable().
Also change the i40evf to check the admin queue error bits since the
firmware can indicate any admin queue error states to the driver via
some bits in the length registers.
Neerav separates out the DCB capability and enabled flags because currently
if the firmware reports DCB capability the driver enables
I40E_FLAG_DCB_ENABLED flag. When this flag is enabled the driver inserts
a tag when transmitting a packet from the port even if there are no DCB
traffic classes configured at the port. So by adding the additional flag,
I40E_FLAG_DCB_CAPABLE, that will be set when the DCB capability is present
and the existing enabled flag will only be set if there are more than one
Greg fixes the i40e driver to not automatically accept tagged packets by
default so that the system must request a VLAN tag packet filter to get
packets with that tag. Greg also converts i40e to use the in-kernel
ether_addr_copy() instead of mempcy().
Jesse removes the FTYPE field from the receive descriptor to match the
hardware implementation.
When an initiator sends an allocation length bigger than what its
command consumes, the target should only return the actual response data
and set the residual length to the unused part of the allocation length.
Add a helper function that command handlers (INQUIRY, READ CAPACITY,
etc) can use to do this correctly, and use this code to get the correct
residual for commands that don't use the full initiator allocation in the
handlers for READ CAPACITY, READ CAPACITY(16), INQUIRY, MODE SENSE and
REPORT LUNS.
This addresses a handful of failures as reported by Christophe with
the Windows Certification Kit:
http://permalink.gmane.org/gmane.linux.scsi.target.devel/6515
Signed-off-by: Roland Dreier <roland@purestorage.com>
Tested-by: Christophe Vu-Brugier <cvubrugier@yahoo.fr>
Cc: stable@vger.kernel.org # 3.10+
After relatively recent changes in the ACPI-based PCI hotplug
(ACPIPHP) code, the acpiphp_check_host_bridge() executed for PCI
host bridges via acpi_pci_root_scan_dependent() doesn't do anything
useful, because those bridges do not have hotplug contexts. That
happens by mistake, so fix it by making acpiphp_enumerate_slots()
add hotplug contexts to PCI host bridges too and modify
acpiphp_remove_slots() to drop those contexts for host bridges
as appropriate.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=76901
Fixes: 2d8b1d566a5f (ACPI / hotplug / PCI: Get rid of check_sub_bridges())
Reported-and-tested-by: Gavin Guo <gavin.guo@canonical.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: 3.15+ <stable@vger.kernel.org> # 3.15+
This patch extracts LBA + sectors for VERIFY, and adds a goto check_lba
to perform the end-of-device checking.
(Update patch to drop lba_check usage - nab)
Signed-off-by: Christophe Vu-Brugier <cvubrugier@yahoo.fr>
A similar check is performed at the end of sbc_parse_cdb() and is now
enforced if the SYNCHRONIZE CACHE command's backend supports
->execute_sync_cache().
(Add check_lba goto to avoid *_max_sectors checks - nab)
In case the transport is iser we should not include the
iscsi target info in the sendtargets text response pdu.
This causes sendtargets response to include the target
info twice.
Modify iscsit_build_sendtargets_response to filter
transport types that don't match.
Reported-by: Slava Shwartsman <valyushash@gmail.com>
Cc: stable@vger.kernel.org # 3.11+
In case the discovery session is carried over iser, we can't
access the assumed network portal since the default portal is
used. In this case we don't really need to allocate the fastreg
pool, just prepare to the text pdu that will follow.
Reported-by: Alex Tabachnik <alext@mellanox.com>
free_msi_irqs() is leaking memory, since list_for_each_entry(entry,
&dev->msi_list, list) {...} is never executed, because dev->msi_list is
made empty by the loop just above this one.
Fix it by relying on zero termination of attribute array like
populate_msi_sysfs() does.
Fixes: 1c51b50c2995 ("PCI/MSI: Export MSI mode using attributes, not kobjects")
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
CC: stable@vger.kernel.org # v3.14+
Bump versions.
Change-ID: Ic4a84354955061ca18321b1e97c9c30fe1563b5c
Signed-off-by: Catherine Sullivan <catherine.sullivan@intel.com>
No need to read the PCI register for the PF's base queue on every single Tx
queue enable and disable as we already have the value stored from reading
Change-ID: Ic02fb622757742f43cb8269369c3d972d4f66555
Signed-off-by: Shannon Nelson <shannon.nelson@intel.com>
