This reverts commit 55fe10a686c3a8bce7bddc149e4ebb12f5a18c25 which is
commit 0443de5fbf224abf41f688d8487b0c307dc5a4b4 upstream.
This causes a build breakage on 3.0, so we shouldn't apply it to that
tree.
Reported-by: Jiri Slaby <jslaby@suse.cz>
Cc: Christoph Fritz <chf.fritz@googlemail.com>
Cc: Marc Kleine-Budde <mkl@pengutronix.de>
commit c6cc25fda58da8685ecef3f179adc7b99c8253b2 upstream.
The adp5520 unfortunately also clears the BL_EN bit when the nSTNDBY bit is
cleared. So we need to make sure to restore it during resume if it was set
before suspend.
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
commit 836dc2fe89c968c10cada87e0dfae6626f8f9da3 upstream.
PARTITION_SUPPORT needs to be set before doing the compare on version
number so the bit width test does not get invalid data. Before this
patch, a Sandisk iNAND eMMC card would detect 1-bit width although
the hardware supports 4-bit.
Only affects old emmc devices - pre 4.4 devices.
Reported-by: Elad Yi <elad.yi@gmail.com>
Signed-off-by: Philip Rakity <prakity@yahoo.com>
Signed-off-by: Chris Ball <cjb@laptop.org>
commit e005715efaf674660ae59af83b13822567e3a758 upstream.
There's a bug where rtc alarms are ignored after the rtc cmos suspends
but before the system finishes suspend. Since hpet emulation is
disabled and it still handles the interrupts, a wake event is never
registered which is done from the rtc layer.
This patch reverts commit d1b2efa83fbf ("rtc: disable hpet emulation on
suspend") which disabled hpet emulation. To fix the problem mentioned
in that commit, hpet_rtc_timer_init() is called directly on resume.
Signed-off-by: Derek Basehore <dbasehore@chromium.org>
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
commit 545d6e189a41c94c11f55045a771118eccc9d9eb upstream.
Found problem on system that firmware that could handle pci aer.
Firmware get error reporting after pci injecting error, before os boots.
But after os boots, firmware can not get report anymore, even pci=noaer
is passed.
Root cause: BIOS _OSC has problem with query bit checking.
It turns out that BIOS vendor is copying example code from ACPI Spec.
In ACPI Spec 5.0, page 290:
If (Not(And(CDW1,1))) // Query flag clear?
{ // Disable GPEs for features granted native control.
If (And(CTRL,0x01)) // Hot plug control granted?
Store(0,HPCE) // clear the hot plug SCI enable bit
Store(1,HPCS) // clear the hot plug SCI status bit
When Query flag is set, And(CDW1,1) will be 1, Not(1) will return 0xfffffffe.
So it will get into code path that should be for control set only.
BIOS acpi code should be changed to "If (LEqual(And(CDW1,1), 0)))"
Current kernel code is using _OSC query to notify firmware about support
from OS and then use _OSC to set control bits.
During query support, current code is using all possible controls.
So will execute code that should be only for control set stage.
That will have problem when pci=noaer or aer firmware_first is used.
As firmware have that control set for os aer already in query support stage,
but later will not os aer handling.
We should avoid passing all possible controls, just use osc_control_set
instead.
That should workaround BIOS bugs with affected systems on the field
as more bios vendors are copying sample code from ACPI spec.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
commit c39e8e4354ce4daf23336de5daa28a3b01f00aa6 upstream.
The TX_FIFO register is 10 bits wide. The lower 8 bits are the data to be
written, while the upper two bits are flags to indicate stop/start.
The driver apparently attempted to optimize write access, by only writing a
byte in those cases where the stop/start bits are zero. However, we have
seen cases where the lower byte is duplicated onto the upper byte by the
hardware, which causes inadvertent stop/starts.
This patch changes the write access to the transmit FIFO to always be 16 bits
wide.
Signed off by: Steven A. Falco <sfalco@harris.com>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit e6637d5427d2af9f3f33b95447bfc5347e5ccd85 upstream.
commit ae1287865f5361fa138d4d3b1b6277908b54eac9
Author: Dave Airlie <airlied@redhat.com>
Date: Thu Jan 24 16:12:41 2013 +1000
fbcon: don't lose the console font across generic->chip driver switch
uses a pointer in vc->vc_font.data to load font into the new driver.
However if the font is actually freed, we need to clear the data
so that we don't reload font from dangling pointer.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=892340
Signed-off-by: Mika Kuoppala <mika.kuoppala@intel.com>
commit b0b885657b6c8ef63a46bc9299b2a7715d19acde upstream.
We first tried to avoid updating atime/mtime entirely (commit
b0de59b5733d: "TTY: do not update atime/mtime on read/write"), and then
limited it to only update it occasionally (commit 37b7f3c76595: "TTY:
fix atime/mtime regression"), but it turns out that this was both
insufficient and overkill.
It was insufficient because we let people attach to the shared ptmx node
to see activity without even reading atime/mtime, and it was overkill
because the "only once a minute" means that you can't really tell an
idle person from an active one with 'w'.
So this tries to fix the problem properly. It marks the shared ptmx
node as un-notifiable, and it lowers the "only once a minute" to a few
seconds instead - still long enough that you can't time individual
keystrokes, but short enough that you can tell whether somebody is
active or not.
Reported-by: Simon Kirby <sim@hostway.ca>
Acked-by: Jiri Slaby <jslaby@suse.cz>
commit 5a65dcc04cda41f4122aacc37a5a348454645399 upstream.
The serial core uses device_find_child() but does not drop the reference to
the retrieved child after using it. This patch add the missing put_device().
What I have done to test this issue.
I used a machine with an AMBA PL011 serial driver. I tested the patch on
next-20120408 because the last branch [next-20120415] does not boot on this
board.
For test purpose, I added some pr_info() messages to print the refcount
after device_find_child() (lines: 1937,2009), and after put_device()
(lines: 1947, 2021).
Boot the machine *without* put_device(). Then:
echo reboot > /sys/power/disk
echo disk > /sys/power/state
[ 87.058575] uart_suspend_port:1937 refcount 4
[ 87.058582] uart_suspend_port:1947 refcount 4
[ 87.098083] uart_resume_port:2009refcount 5
[ 87.098088] uart_resume_port:2021 refcount 5
[ 103.055574] uart_suspend_port:1937 refcount 6
[ 103.055580] uart_suspend_port:1947 refcount 6
[ 103.095322] uart_resume_port:2009 refcount 7
[ 103.095327] uart_resume_port:2021 refcount 7
[ 252.459580] uart_suspend_port:1937 refcount 8
[ 252.459586] uart_suspend_port:1947 refcount 8
[ 252.499611] uart_resume_port:2009 refcount 9
[ 252.499616] uart_resume_port:2021 refcount 9
The refcount continuously increased.
Boot the machine *with* this patch. Then:
[ 159.333559] uart_suspend_port:1937 refcount 4
[ 159.333566] uart_suspend_port:1947 refcount 3
[ 159.372751] uart_resume_port:2009 refcount 4
[ 159.372755] uart_resume_port:2021 refcount 3
[ 185.713614] uart_suspend_port:1937 refcount 4
[ 185.713621] uart_suspend_port:1947 refcount 3
[ 185.752935] uart_resume_port:2009 refcount 4
[ 185.752940] uart_resume_port:2021 refcount 3
[ 207.458584] uart_suspend_port:1937 refcount 4
[ 207.458591] uart_suspend_port:1947 refcount 3
[ 207.498598] uart_resume_port:2009 refcount 4
[ 207.498605] uart_resume_port:2021 refcount 3
The refcount correctly handled.
Signed-off-by: Federico Vaga <federico.vaga@gmail.com>
commit 94c163663fc1dcfc067a5fb3cc1446b9469975ce upstream.
In case a machine supports memory hotplug all active memory increments
present at IPL time have been initialized with a "usecount" of 1.
This is wrong if the memory increment size is larger than the memory
section size of the memory hotplug code. If that is the case the
usecount must be initialized with the number of memory sections that
fit into one memory increment.
Otherwise it is possible to put a memory increment into standby state
even if there are still active sections.
Afterwards addressing exceptions might happen which cause the kernel
to panic.
However even worse, if a memory increment was put into standby state
and afterwards into active state again, it's contents would have been
zeroed, leading to memory corruption.
This was only an issue for machines that support standby memory and
have at least 256GB memory.
This is broken since commit fdb1bb15 "[S390] sclp/memory hotplug: fix
initial usecount of increments".
Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
commit 671b4b2ba9266cbcfe7210a704e9ea487dcaa988 upstream.
Many cards based on CY7C68300A/B/C use the USB ID 04b4:6830 but only the
B and C variants (EZ-USB AT2LP) support the ATA Command Block
functionality, according to the data sheets. The A variant (EZ-USB AT2)
locks up if ATACB is attempted, until a typical 30 seconds timeout runs
out and a USB reset is performed.
https://bugs.launchpad.net/bugs/428469
It seems that one way to spot a CY7C68300A (at least where the card
manufacturer left Cypress' EEPROM default vaules, against Cypress'
recommendations) is to look at the USB string descriptor indices.
A http://media.digikey.com/pdf/Data%20Sheets/Cypress%20PDFs/CY7C68300A.pdf
B http://www.farnell.com/datasheets/43456.pdf
C http://www.cypress.com/?rID=14189
Note that a CY7C68300B/C chip appears as CY7C68300A if it is running
in Backward Compatibility Mode, and if ATACB would be supported in this
case there is anyway no way to tell which chip it really is.
For 5 years my external USB drive has been locking up for half a minute
when plugged in and ata_id is run by udev, or anytime hdparm or similar
is run on it.
Finally looking at the /correct/ datasheet I think I found the reason. I
am aware the quirk in this patch is a bit hacky, but the hardware
manufacturers haven't made it easy for us.
Signed-off-by: Tormod Volden <debian.tormod@gmail.com>
commit 1361bf4b9f9ef45e628a5b89e0fd9bedfdcb7104 upstream.
When usbfs receives a ctrl-request from userspace it calls check_ctrlrecip,
which for a request with USB_RECIP_ENDPOINT tries to map this to an interface
to see if this interface is claimed, except for ctrl-requests with a type of
USB_TYPE_VENDOR.
When trying to use this device: http://www.akaipro.com/eiepro
redirected to a Windows vm running on qemu on top of Linux.
The windows driver makes a ctrl-req with USB_TYPE_CLASS and
USB_RECIP_ENDPOINT with index 0, and the mapping of the endpoint (0) to
the interface fails since ep 0 is the ctrl endpoint and thus never is
part of an interface.
This patch fixes this ctrl-req failing by skipping the checkintf call for
USB_RECIP_ENDPOINT ctrl-reqs on the ctrl endpoint.
Reported-by: Dave Stikkolorum <d.r.stikkolorum@hhs.nl>
Tested-by: Dave Stikkolorum <d.r.stikkolorum@hhs.nl>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 9f06d15f8db6946e41f73196a122b84a37938878 upstream.
The current ST Micro Connect Lite uses the FT4232H hi-speed quad USB
UART FTDI chip. It is also possible to drive STM reference targets
populated with an on-board JTAG debugger based on the FT2232H chip with
the same STMicroelectronics tools.
For this reason, the ST Micro Connect Lite PIDs should be
ST_STMCLT_2232_PID: 0x3746
ST_STMCLT_4232_PID: 0x3747
Signed-off-by: Adrian Thomasset <adrian.thomasset@st.com>
commit 58f8b6c4fa5a13cb2ddb400e26e9e65766d71e38 upstream.
This patch add a missing usb device id for the GDMBoost V1.x device
The patch is against 3.9-rc5
Signed-off-by: Stefani Seibold <stefani@seibold.net>
commit e7d3b6e22c871ba36d052ca99bc8ceca4d546a60 upstream.
Add the Apple 24" LED Cinema display to the supported devices.
Signed-off-by: Ben Jencks <ben@bjencks.net>
commit a2a2d6c7f93e160b52a4ad0164db1f43f743ae0f upstream.
Adding support for a Mediatek based device labelled as
D-Link Model: DWM-156, H/W Ver: A7
Also adding two other device IDs found in the Debian(!)
packages included on the embedded device driver CD.
This is a composite MBIM + serial ports + card reader device:
T: Bus=04 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 14 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2001 ProdID=7d01 Rev= 3.00
S: Manufacturer=D-Link,Inc
S: Product=D-Link DWM-156
C:* #Ifs= 7 Cfg#= 1 Atr=a0 MxPwr=500mA
A: FirstIf#= 0 IfCount= 2 Cls=02(comm.) Sub=0e Prot=00
I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=0e Prot=00 Driver=cdc_mbim
E: Ad=88(I) Atr=03(Int.) MxPS= 64 Ivl=125us
I: If#= 1 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
I:* If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=01 Driver=option
E: Ad=87(I) Atr=03(Int.) MxPS= 64 Ivl=500us
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 6 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit d19bf5cedfd7d53854a3bd699c98b467b139833b upstream.
This adds PID for Olivetti Olicard 145 in option.c
Signed-off-by: Filippo Turato <nnj7585@gmail.com>
[ Upstream commit b6a5a7b9a528a8b4c8bec940b607c5dd9102b8cc ]
While enslaving a new device and after IFF_BONDING flag is set, in case
of failure it is not stripped from the device's priv_flags while
cleaning up, which could lead to other problems.
Cleaning at err_close because the flag is set after dev_open().
v2: no change
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
[ Upstream commit 31d1670e73f4911fe401273a8f576edc9c2b5fea ]
The limit of 0x3c00 is taken from the windows driver.
Suggested-by: Huang, Xiong <xiong@qca.qualcomm.com>
Cc: Huang, Xiong <xiong@qca.qualcomm.com>
commit 37b7f3c76595e23257f61bd80b223de8658617ee upstream.
In commit b0de59b5733d ("TTY: do not update atime/mtime on read/write")
we removed timestamps from tty inodes to fix a security issue and waited
if something breaks. Well, 'w', the utility to find out logged users
and their inactivity time broke. It shows that users are inactive since
the time they logged in.
To revert to the old behaviour while still preventing attackers to
guess the password length, we update the timestamps in one-minute
intervals by this patch.
commit b0de59b5733d18b0d1974a060860a8b5c1b36a2e upstream.
On http://vladz.devzero.fr/013_ptmx-timing.php, we can see how to find
out length of a password using timestamps of /dev/ptmx. It is
documented in "Timing Analysis of Keystrokes and Timing Attacks on
SSH". To avoid that problem, do not update time when reading
from/writing to a TTY.
I am afraid of regressions as this is a behavior we have since 0.97
and apps may expect the time to be current, e.g. for monitoring
whether there was a change on the TTY. Now, there is no change. So
this would better have a lot of testing before it goes upstream.
References: CVE-2013-0160
commit 8558e4a26b00225efeb085725bc319f91201b239 upstream.
This is my example conversion of a few existing mmap users. The mtdchar
case is actually disabled right now (and stays disabled), but I did it
because it showed up on my "git grep", and I was familiar with the code
due to fixing an overflow problem in the code in commit 9c603e53d380
("mtdchar: fix offset overflow detection").
commit 2323036dfec8ce3ce6e1c86a49a31b039f3300d1 upstream.
This is my example conversion of a few existing mmap users. The HPET
case is simple, widely available, and easy to test (Clemens Ladisch sent
a trivial test-program for it).
Test-program-by: Clemens Ladisch <clemens@ladisch.de>
commit fc9bbca8f650e5f738af8806317c0a041a48ae4a upstream.
fb_mmap() case is a good example because it is a bit more complicated
than some: fb_mmap() mmaps one of two different memory areas depending
on the page offset of the mmap (but happily there is never any mixing of
the two, so the helper function still works).
commit 054430e773c9a1e26f38e30156eff02dedfffc17 upstream.
Okay so Alan's patch handled the case where there was no registered fbcon,
however the other path entered in set_con2fb_map pit.
In there we called fbcon_takeover, but we also took the console lock in a couple
of places. So push the console lock out to the callers of set_con2fb_map,
this means fbmem and switcheroo needed to take the lock around the fb notifier
entry points that lead to this.
This should fix the efifb regression seen by Maarten.
Tested-by: Maarten Lankhorst <maarten.lankhorst@canonical.com>
Tested-by: Lu Hua <huax.lu@intel.com>
commit 319e7bd96aca64a478f3aad40711c928405b8b77 upstream.
Since the firmware has been open sourced, the minor version has been
bumped to 1.4 and the API/ABI will stay compatible across further 1.x
releases.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
To get correct endianes on little endian cpus (like arm) while reading device
tree properties, this patch replaces of_get_property() with
of_property_read_u32(). While there use of_property_read_bool() for the
handling of the boolean "nxp,no-comparator-bypass" property.
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit f5cf8f07423b2677cebebcebc863af77223a4972 upstream.
This code was broken because it assumed that all MTD devices were map-based.
Disable it for now, until it can be fixed properly for the next merge window.
commit e2409d83434d77874b461b78af6a19cd6e6a1280 upstream.
It would cause no link after suspending or shutdowning when the
nic changes the speed to 10M and connects to a link partner which
forces the speed to 100M.
Check the link partner ability to determine which speed to set.
The link speed down code path is not factored in this kernel version.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
commit 9c603e53d380459fb62fec7cd085acb0b74ac18f upstream.
Sasha Levin has been running trinity in a KVM tools guest, and was able
to trigger the BUG_ON() at arch/x86/mm/pat.c:279 (verifying the range of
the memory type). The call trace showed that it was mtdchar_mmap() that
created an invalid remap_pfn_range().
The problem is that mtdchar_mmap() does various really odd and subtle
things with the vma page offset etc, and uses the wrong types (and the
wrong overflow) detection for it.
For example, the page offset may well be 32-bit on a 32-bit
architecture, but after shifting it up by PAGE_SHIFT, we need to use a
potentially 64-bit resource_size_t to correctly hold the full value.
Also, we need to check that the vma length plus offset doesn't overflow
before we check that it is smaller than the length of the mtdmap region.
This fixes things up and tries to make the code a bit easier to read.
Reported-and-tested-by: Sasha Levin <levinsasha928@gmail.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Acked-by: Artem Bityutskiy <dedekind1@gmail.com>
Cc: linux-mtd@lists.infradead.org
Cc: Ben Hutchings <ben@decadent.org.uk>
Cc: Brad Spengler <spender@grsecurity.net>
commit 30f359a6f9da65a66de8cadf959f0f4a0d498bba upstream.
This patch fixes a bug where a handful of informational / control CDBs
that should be allowed during ALUA access state Standby/Offline/Transition
where incorrectly returning CHECK_CONDITION + ASCQ_04H_ALUA_TG_PT_*.
This includes INQUIRY + REPORT_LUNS, which would end up preventing LUN
registration when LUN scanning occured during these ALUA access states.
Cc: Hannes Reinecke <hare@suse.de>
commit 83589b30f1e1dc9898986293c9336b8ce1705dec upstream.
BugLink: http://bugs.launchpad.net/bugs/1128840
It appears that when this register read fails it never recovers, so
I think there is no need to repeat the same error message ad infinitum.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Cc: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Gertjan van Wingerde <gwingerde@gmail.com>
Cc: Helmut Schaa <helmut.schaa@googlemail.com>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: linux-wireless@vger.kernel.org
Cc: users@rt2x00.serialmonkey.com
Cc: netdev@vger.kernel.org
Cc: stable@vger.kernel.org
revert commit b9f1f48ce20a1b923429c216669d03b5a900a8cf which is commit
084c7189acb3f969c855536166042e27f5dd703f upstream.
It shouldn't have been applied to the 3.0-stable tree.
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Cc: Marco Cesarano <marco@marvell.com>
Reported-by: Bing Zhao <bzhao@marvell.com>
commit da28d966f6aa942ae836d09729f76a1647932309 upstream.
The return code from the registration of the thermal class is used to
unallocate resources, but this failure isn't passed back to the caller of
thermal_init. Return this failure back to the caller.
This bug was introduced in changeset 4cb18728 which overwrote the return code
when the variable was re-used to catch the return code of the registration of
the genetlink thermal socket family.
Signed-off-by: Richard Guy Briggs <rbriggs@redhat.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Cc: Jonghwan Choi <jhbird.choi@samsung.com>
commit a32450e127fc6e5ca6d958ceb3cfea4d30a00846 upstream.
The Slimtype DVD A DS8A8SH drive locks up when max sector is smaller than
65535, and the blow backtrace is observed on locking up:
INFO: task flush-8:32:1130 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
flush-8:32 D ffffffff8180cf60 0 1130 2 0x00000000
ffff880273aef618 0000000000000046 0000000000000005 ffff880273aee000
ffff880273aee000 ffff880273aeffd8 ffff880273aee010 ffff880273aee000
ffff880273aeffd8 ffff880273aee000 ffff88026e842ea0 ffff880274a10000
Call Trace:
[<ffffffff8168fc2d>] schedule+0x5d/0x70
[<ffffffff8168fccc>] io_schedule+0x8c/0xd0
[<ffffffff81324461>] get_request+0x731/0x7d0
[<ffffffff8133dc60>] ? cfq_allow_merge+0x50/0x90
[<ffffffff81083aa0>] ? wake_up_bit+0x40/0x40
[<ffffffff81320443>] ? bio_attempt_back_merge+0x33/0x110
[<ffffffff813248ea>] blk_queue_bio+0x23a/0x3f0
[<ffffffff81322176>] generic_make_request+0xc6/0x120
[<ffffffff81322308>] submit_bio+0x138/0x160
[<ffffffff811d7596>] ? bio_alloc_bioset+0x96/0x120
[<ffffffff811d1f61>] submit_bh+0x1f1/0x220
[<ffffffff811d48b8>] __block_write_full_page+0x228/0x340
[<ffffffff811d3650>] ? attach_nobh_buffers+0xc0/0xc0
[<ffffffff811d8960>] ? I_BDEV+0x10/0x10
[<ffffffff811d4ab6>] block_write_full_page_endio+0xe6/0x100
[<ffffffff811d4ae5>] block_write_full_page+0x15/0x20
[<ffffffff811d9268>] blkdev_writepage+0x18/0x20
[<ffffffff81142527>] __writepage+0x17/0x40
[<ffffffff811438ba>] write_cache_pages+0x34a/0x4a0
[<ffffffff81142510>] ? set_page_dirty+0x70/0x70
[<ffffffff81143a61>] generic_writepages+0x51/0x80
[<ffffffff81143ab0>] do_writepages+0x20/0x50
[<ffffffff811c9ed6>] __writeback_single_inode+0xa6/0x2b0
[<ffffffff811ca861>] writeback_sb_inodes+0x311/0x4d0
[<ffffffff811caaa6>] __writeback_inodes_wb+0x86/0xd0
[<ffffffff811cad43>] wb_writeback+0x1a3/0x330
[<ffffffff816916cf>] ? _raw_spin_lock_irqsave+0x3f/0x50
[<ffffffff811b8362>] ? get_nr_inodes+0x52/0x70
[<ffffffff811cb0ac>] wb_do_writeback+0x1dc/0x260
[<ffffffff8168dd34>] ? schedule_timeout+0x204/0x240
[<ffffffff811cb232>] bdi_writeback_thread+0x102/0x2b0
[<ffffffff811cb130>] ? wb_do_writeback+0x260/0x260
[<ffffffff81083550>] kthread+0xc0/0xd0
[<ffffffff81083490>] ? kthread_worker_fn+0x1b0/0x1b0
[<ffffffff8169a3ec>] ret_from_fork+0x7c/0xb0
The above trace was triggered by
"dd if=/dev/zero of=/dev/sr0 bs=2048 count=32768"
It was previously working by accident, since another bug introduced
by 4dce8ba94c7 (libata: Use 'bool' return value for ata_id_XXX) caused
all drives to use maxsect=65535.
Signed-off-by: Shan Hai <shan.hai@windriver.com>
[ Upstream commit fcd99434fb5c137274d2e15dd2a6a7455f0f29ff ]
Now that netdev_rx_handler_unregister contains synchronize_net(), we need
to call it outside of bond->lock, cause it might sleep. Also, remove the
already unneded synchronize_net().
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
[ Upstream commit 4c51e53689569398d656e631c17308d9b8e84650 ]
This patch enables RX of jumbo frames for LAN7500.
Previously the driver would transmit jumbo frames succesfully but
would drop received jumbo frames (incrementing the interface errors
count).
With this patch applied the device can succesfully receive jumbo
frames up to MTU 9000 (9014 bytes on the wire including ethernet
header).
Signed-off-by: Steve Glendinning <steve.glendinning@shawell.net>
[ Upstream commit 76a0e68129d7d24eb995a6871ab47081bbfa0acc ]
skb->ip_summed should be CHECKSUM_UNNECESSARY when the driver reports that
checksums were correct and CHECKSUM_NONE in any other case. They're
currently placed vice versa, which breaks the forwarding scenario. Fix it
by placing them as described above.
[ Upstream commit 14bc435ea54cb888409efb54fc6b76c13ef530e9 ]
According to the Datasheet (page 52):
15-12 Reserved
11-0 RXBC Receive Byte Count
This field indicates the present received frame byte size.
The code has a bug:
rxh = ks8851_rdreg32(ks, KS_RXFHSR);
rxstat = rxh & 0xffff;
rxlen = rxh >> 16; // BUG!!! 0xFFF mask should be applied
Signed-off-by: Max Nekludov <Max.Nekludov@us.elster.com>
[ Upstream commit 188ab1b105c96656f6bcfb49d0d8bb1b1936b632 ]
Usage of pci-msi results in corrupted dma packet transfers to the host.
Reported-by: rebelyouth <rebelyouth.hacklab@gmail.com>
Tested-by: Christian Sünkenberg <christian.suenkenberg@student.kit.edu>
restarting tx queue
To restart tx queue use netif_wake_queue() intead of netif_start_queue()
so that net schedule will restart transmission immediately which will
increase network performance while doing huge data transfers.
Reported-by: Dan Franke <dan.franke@schneider-electric.com>
Suggested-by: Sriramakrishnan A G <srk@ti.com>
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
[ Upstream commit 91c5746425aed8f7188a351f1224a26aa232e4b3 ]
Some network drivers use a non default hard_header_len
Transmitted skb should take into account dev->hard_header_len, or risk
crashes or expensive reallocations.
In the case of aoe, lets reserve MAX_HEADER bytes.
David reported a crash in defxx driver, solved by this patch.
Reported-by: David Oostdyk <daveo@ll.mit.edu>
Tested-by: David Oostdyk <daveo@ll.mit.edu>
Cc: Ed Cashin <ecashin@coraid.com>
[ Upstream commit 74f9f42c1c1650e74fb464f76644c9041f996851 ]
The sky2 driver sets the Rx Upper Threshold for Pause Packet generation to a
wrong value which leads to only 2kB of RAM remaining space. This can lead to
Rx overflow errors even with activated flow-control.
Fix: We should increase the value to 8192/8
Signed-off-by: Mirko Lindner <mlindner@marvell.com>
Acked-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit 9cfe8b156c21cf340b3a10ecb3022fbbc1c39185 ]
The sky2 driver doesn't count the Receive Overflows because the MAC
interrupt for this event is not set in the MAC's interrupt mask.
The MAC's interrupt mask is set only for Transmit FIFO Underruns.
Fix: The correct setting should be (GM_IS_TX_FF_UR | GM_IS_RX_FF_OR)
Otherwise the Receive Overflow event will not generate any interrupt.
The Receive Overflow interrupt is handled correctly
commit e971318bbed610e28bb3fde9d548e6aaf0a6b02e upstream.
Some firmware exhibits a bug where the same VariableName and
VendorGuid values are returned on multiple invocations of
GetNextVariableName(). See,
https://bugzilla.kernel.org/show_bug.cgi?id=47631
As a consequence of such a bug, Andre reports hitting the following
WARN_ON() in the sysfs code after updating the BIOS on his, "Gigabyte
Technology Co., Ltd. To be filled by O.E.M./Z77X-UD3H, BIOS F19e
11/21/2012)" machine,
[ 0.581554] EFI Variables Facility v0.08 2004-May-17
[ 0.584914] ------------[ cut here ]------------
[ 0.585639] WARNING: at /home/andre/linux/fs/sysfs/dir.c:536 sysfs_add_one+0xd4/0x100()
[ 0.586381] Hardware name: To be filled by O.E.M.
[ 0.587123] sysfs: cannot create duplicate filename '/firmware/efi/vars/SbAslBufferPtrVar-01f33c25-764d-43ea-aeea-6b5a41f3f3e8'
[ 0.588694] Modules linked in:
[ 0.589484] Pid: 1, comm: swapper/0 Not tainted 3.8.0+ #7
[ 0.590280] Call Trace:
[ 0.591066] [<ffffffff81208954>] ? sysfs_add_one+0xd4/0x100
[ 0.591861] [<ffffffff810587bf>] warn_slowpath_common+0x7f/0xc0
[ 0.592650] [<ffffffff810588bc>] warn_slowpath_fmt+0x4c/0x50
[ 0.593429] [<ffffffff8134dd85>] ? strlcat+0x65/0x80
[ 0.594203] [<ffffffff81208954>] sysfs_add_one+0xd4/0x100
[ 0.594979] [<ffffffff81208b78>] create_dir+0x78/0xd0
[ 0.595753] [<ffffffff81208ec6>] sysfs_create_dir+0x86/0xe0
[ 0.596532] [<ffffffff81347e4c>] kobject_add_internal+0x9c/0x220
[ 0.597310] [<ffffffff81348307>] kobject_init_and_add+0x67/0x90
[ 0.598083] [<ffffffff81584a71>] ? efivar_create_sysfs_entry+0x61/0x1c0
[ 0.598859] [<ffffffff81584b2b>] efivar_create_sysfs_entry+0x11b/0x1c0
[ 0.599631] [<ffffffff8158517e>] register_efivars+0xde/0x420
[ 0.600395] [<ffffffff81d430a7>] ? edd_init+0x2f5/0x2f5
[ 0.601150] [<ffffffff81d4315f>] efivars_init+0xb8/0x104
[ 0.601903] [<ffffffff8100215a>] do_one_initcall+0x12a/0x180
[ 0.602659] [<ffffffff81d05d80>] kernel_init_freeable+0x13e/0x1c6
[ 0.603418] [<ffffffff81d05586>] ? loglevel+0x31/0x31
[ 0.604183] [<ffffffff816a6530>] ? rest_init+0x80/0x80
[ 0.604936] [<ffffffff816a653e>] kernel_init+0xe/0xf0
[ 0.605681] [<ffffffff816ce7ec>] ret_from_fork+0x7c/0xb0
[ 0.606414] [<ffffffff816a6530>] ? rest_init+0x80/0x80
[ 0.607143] ---[ end trace 1609741ab737eb29 ]---
There's not much we can do to work around and keep traversing the
variable list once we hit this firmware bug. Our only solution is to
terminate the loop because, as Lingzhu reports, some machines get
stuck when they encounter duplicate names,
> I had an IBM System x3100 M4 and x3850 X5 on which kernel would
> get stuck in infinite loop creating duplicate sysfs files because,
> for some reason, there are several duplicate boot entries in nvram
> getting GetNextVariableName into a circle of iteration (with
> period > 2).
Also disable the workqueue, as efivar_update_sysfs_entries() uses
GetNextVariableName() to figure out which variables have been created
since the last iteration. That algorithm isn't going to work if
GetNextVariableName() returns duplicates. Note that we don't disable
EFI variable creation completely on the affected machines, it's just
that any pstore dump-* files won't appear in sysfs until the next
boot.
[Backported for 3.0-stable. Removed code related to pstore
workqueue but pulled in helper function variable_is_present
from a93bc0c; Moved the definition of __efivars to the top
for being referenced in variable_is_present.]
Reported-by: Andre Heider <a.heider@gmail.com>
Reported-by: Lingzhu Xiang <lxiang@redhat.com>
Tested-by: Lingzhu Xiang <lxiang@redhat.com>
Cc: Seiji Aguchi <seiji.aguchi@hds.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Signed-off-by: Lingzhu Xiang <lxiang@redhat.com>
Reviewed-by: CAI Qian <caiqian@redhat.com>
commit ec50bd32f1672d38ddce10fb1841cbfda89cfe9a upstream.
It's not wise to assume VariableNameSize represents the length of
VariableName, as not all firmware updates VariableNameSize in the same
way (some don't update it at all if EFI_SUCCESS is returned). There
are even implementations out there that update VariableNameSize with
values that are both larger than the string returned in VariableName
and smaller than the buffer passed to GetNextVariableName(), which
resulted in the following bug report from Michael Schroeder,
> On HP z220 system (firmware version 1.54), some EFI variables are
> incorrectly named :
> ls -d /sys/firmware/efi/vars/*8be4d* | grep -v -- -8be returns
> /sys/firmware/efi/vars/dbxDefault-pport8be4df61-93ca-11d2-aa0d-00e098032b8c
> /sys/firmware/efi/vars/KEKDefault-pport8be4df61-93ca-11d2-aa0d-00e098032b8c
> /sys/firmware/efi/vars/SecureBoot-pport8be4df61-93ca-11d2-aa0d-00e098032b8c
> /sys/firmware/efi/vars/SetupMode-Information8be4df61-93ca-11d2-aa0d-00e098032b8c
The issue here is that because we blindly use VariableNameSize without
verifying its value, we can potentially read garbage values from the
buffer containing VariableName if VariableNameSize is larger than the
length of VariableName.
Since VariableName is a string, we can calculate its size by searching
for the terminating NULL character.
[Backported for 3.8-stable. Removed workqueue code added in
a93bc0c 3.9-rc1.]
Reported-by: Frederic Crozat <fcrozat@suse.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Josh Boyer <jwboyer@redhat.com>
Cc: Michael Schroeder <mls@suse.com>
Cc: Lee, Chun-Yi <jlee@suse.com>
Cc: Lingzhu Xiang <lxiang@redhat.com>
commit 4a35f83b2b7c6aae3fc0d1c4554fdc99dc33ad07 upstream.
Restore crtc->fb to the old framebuffer if queue_flip fails.
While at it, kill the pointless intel_fb temp variable.
v2: Update crtc->fb before queue_flip and restore it back
after a failure.
[Backported for 3.0-stable. Adjusted context. Please
cherry-pick commit 7317c75e66fce0c9f82fbe6f72f7e5256b315422
upstream before this patch as it provides necessary context
and fixes a panic.]
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Reported-and-Tested-by: Mika Kuoppala <mika.kuoppala@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 7317c75e66fce0c9f82fbe6f72f7e5256b315422 upstream.
This fixes a race where we may try to finish a page flip and decrement
the refcount even if our vblank_get failed and we ended up with a
spurious flip pending interrupt.
Fixes https://bugs.freedesktop.org/show_bug.cgi?id=34211.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Keith Packard <keithp@keithp.com>
commit c1681bf8a7b1b98edee8b862a42c19c4e53205fd upstream.
struct block_device lifecycle is defined by its inode (see fs/block_dev.c) -
block_device allocated first time we access /dev/loopXX and deallocated on
bdev_destroy_inode. When we create the device "losetup /dev/loopXX afile"
we want that block_device stay alive until we destroy the loop device
with "losetup -d".
But because we do not hold /dev/loopXX inode its counter goes 0, and
inode/bdev can be destroyed at any moment. Usually it happens at memory
pressure or when user drops inode cache (like in the test below). When later in
loop_clr_fd() we want to use bdev we have use-after-free error with following
stack:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000280
bd_set_size+0x10/0xa0
loop_clr_fd+0x1f8/0x420 [loop]
lo_ioctl+0x200/0x7e0 [loop]
lo_compat_ioctl+0x47/0xe0 [loop]
compat_blkdev_ioctl+0x341/0x1290
do_filp_open+0x42/0xa0
compat_sys_ioctl+0xc1/0xf20
do_sys_open+0x16e/0x1d0
sysenter_dispatch+0x7/0x1a
To prevent use-after-free we need to grab the device in loop_set_fd()
and put it later in loop_clr_fd().
The issue is reprodusible on current Linus head and v3.3. Here is the test:
dd if=/dev/zero of=loop.file bs=1M count=1
while [ true ]; do
losetup /dev/loop0 loop.file
echo 2 > /proc/sys/vm/drop_caches
losetup -d /dev/loop0
done
[ Doing bdgrab/bput in loop_set_fd/loop_clr_fd is safe, because every
time we call loop_set_fd() we check that loop_device->lo_state is
Lo_unbound and set it to Lo_bound If somebody will try to set_fd again
it will get EBUSY. And if we try to loop_clr_fd() on unbound loop
device we'll get ENXIO.
loop_set_fd/loop_clr_fd (and any other loop ioctl) is called under
loop_device->lo_ctl_mutex. ]
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
commit b92946e2919134ebe2a4083e4302236295ea2a73 upstream.
There're several reasons that the vectors need to be validated:
- Return error when caller provides vectors whose num is greater than UIO_MAXIOV.
- Linearize part of skb when userspace provides vectors grater than MAX_SKB_FRAGS.
- Return error when userspace provides vectors whose total length may exceed
- MAX_SKB_FRAGS * PAGE_SIZE.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Benjamin Poirier <bpoirier@suse.de> [patch reduced to
the 3rd reason only for 3.0]
