[ Upstream commit 3c25a860d17b7378822f35d8c9141db9507e3beb ]
Commit fcb26ec5b18d ("broadcom: move all PHY_ID's to header")
updated broadcom_tbl to use PHY_IDs, but incorrectly replaced 0x0143bca0
with PHY_ID_BCM5482 (making a duplicate entry, and completely omitting
the original). Fix that.
Fixes: fcb26ec5b18d ("broadcom: move all PHY_ID's to header")
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
[ Upstream commit 68242a5a1e2edce39b069385cbafb82304eac0f1 ]
Thomas reports
4gsystems sells two total different LTE-surfsticks under the same name.
The newer version of XS Stick W100 is from "omega"
Under windows the driver switches to the same ID, and uses MI03\6 for
network and MI01\6 for modem.
echo "1c9e 9b01" > /sys/bus/usb/drivers/qmi_wwan/new_id
echo "1c9e 9b01" > /sys/bus/usb-serial/drivers/option1/new_id
T: Bus=01 Lev=01 Prnt=01 Port=03 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1c9e ProdID=9b01 Rev=02.32
S: Manufacturer=USB Modem
S: Product=USB Modem
S: SerialNumber=
C: #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
I: If#= 4 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
Now all important things are there:
wwp0s29f7u2i3 (net), ttyUSB2 (at), cdc-wdm0 (qmi), ttyUSB1 (at)
There is also ttyUSB0, but it is not usable, at least not for at.
The device works well with qmi and ModemManager-NetworkManager.
Reported-by: Thomas Schäfer <tschaefer@t-online.de>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit b2663a4f30e85ec606b806f5135413e6d5c78d1e ]
When the IP stack passes SKBs the sfc driver puts them in 2 different TX
queues (called partners), one for checksummed and one for not checksummed.
If the SKB has xmit_more set the driver will delay pushing the work to the
NIC.
When later it does decide to push the buffers this patch ensures it also
pushes the partner queue, if that also has any delayed work. Before this
fix the work in the partner queue would be left for a long time and cause
a netdev watchdog.
Fixes: 70b33fb ("sfc: add support for skb->xmit_more")
Reported-by: Jianlin Shi <jishi@redhat.com>
Signed-off-by: Martin Habets <mhabets@solarflare.com>
[ Upstream commit 0db65fcfcded76fe4f74e3ca9f4e2baf67b683ef ]
New device IDs shamelessly lifted from the vendor driver.
[ Upstream commit 48900cb6af4282fa0fb6ff4d72a81aa3dadb5c39 ]
virtio declares support for NETIF_F_FRAGLIST, but assumes
that there are at most MAX_SKB_FRAGS + 2 fragments which isn't
always true with a fraglist.
A longer fraglist in the skb will make the call to skb_to_sgvec overflow
the sg array, leading to memory corruption.
Drop NETIF_F_FRAGLIST so we only get what we can handle.
Cc: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit 70910791731b5956171e1bfcad707766b8e18fee ]
The lt4112 is a HP branded Huawei me906e modem. Like other Huawei
modems, it does not have a fixed interface to function mapping.
Instead it uses a Huawei specific scheme: functions are mapped by
subclass and protocol.
However, the HP vendor ID is used for modems from many different
manufacturers using different schemes, so we cannot apply a generic
vendor rule like we do for the Huawei vendor ID.
Replace the previous lt4112 entry pointing to an arbitrary interface
number with a device specific subclass + protocol match.
Reported-and-tested-by: Muri Nicanor <muri+libqmi@immerda.ch>
Tested-by: Martin Hauke <mardnh@gmx.de>
Fixes: bb2bdeb83fb1 ("qmi_wwan: Add support for HP lt4112 LTE/HSPA+ Gobi 4G Modem")
[ Upstream commit e6dbe1eb2db0d7a14991c06278dd3030c45fb825 ]
priv->hwts_*_en indicate if timestamping is enabled/disabled at run
time. But priv->dma_cap.time_stamp and priv->dma_cap.atime_stamp
indicates HW is support for PTPv1/PTPv2.
Signed-off-by: Phil Reid <preid@electromag.com.au>
Acked-by: Richard Cochran <richardcochran@gmail.com>
[ Upstream commit c02b05011fadf8e409e41910217ca689f2fc9d91 ]
When doing memcpy/memset of EQEs, we should use sizeof struct
mlx4_eqe as the base size and not caps.eqe_size which could be bigger.
If caps.eqe_size is bigger than the struct mlx4_eqe then we corrupt
data in the master context.
When using a 64 byte stride, the memcpy copied over 63 bytes to the
slave_eq structure. This resulted in copying over the entire eqe of
interest, including its ownership bit -- and also 31 bytes of garbage
into the next WQE in the slave EQ -- which did NOT include the ownership
bit (and therefore had no impact).
However, once the stride is increased to 128, we are overwriting the
ownership bits of *three* eqes in the slave_eq struct. This results
in an incorrect ownership bit for those eqes, which causes the eq to
seem to be full. The issue therefore surfaced only once 128-byte EQEs
started being used in SRIOV and (overarchitectures that have 128/256
byte cache-lines such as PPC) - e.g after commit 77507aa249ae
"net/mlx4_core: Enable CQE/EQE stride support".
Fixes: 08ff32352d6f ('mlx4: 64-byte CQE/EQE support')
Signed-off-by: Carol L Soto <clsoto@linux.vnet.ibm.com>
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
[ Upstream commit 1acea4f6ce1b1c0941438aca75dd2e5c6b09db60 ]
We can't rely on PPPOX_ZOMBIE to decide whether to clear po->pppoe_dev.
PPPOX_ZOMBIE can be set by pppoe_disc_rcv() even when po->pppoe_dev is
NULL. So we have no guarantee that (sk->sk_state & PPPOX_ZOMBIE) implies
(po->pppoe_dev != NULL).
Since we're releasing a PPPoE socket, we want to release the pppoe_dev
if it exists and reset sk_state to PPPOX_DEAD, no matter the previous
value of sk_state. So we can just check for po->pppoe_dev and avoid any
assumption on sk->sk_state.
Fixes: 2b018d57ff18 ("pppoe: drop PPPOX_ZOMBIEs in pppoe_release")
Signed-off-by: Guillaume Nault <g.nault@alphalink.fr>
[ Upstream commit f23d538bc24a83c16127c2eb82c9cf1adc2b5149 ]
We don't have fraglist support in TAP_FEATURES. This will lead
software segmentation of gro skb with frag list. Fixes by having
frag list support in TAP_FEATURES.
With this patch single session of netperf receiving were restored from
about 5Gb/s to about 12Gb/s on mlx4.
Fixes a567dd6252 ("macvtap: simplify usage of tap_features")
Cc: Vlad Yasevich <vyasevic@redhat.com>
[ Upstream commit e819cdb198319cccf4af4fc12ac4d796109d8c23 ]
These are signed values the come from the user, we put a cap on the
upper bounds but not on the lower bounds.
We use "karg.dataSgeOffset" to calculate "sz". We verify "sz" and
proceed as if that means that "karg.dataSgeOffset" is correct but this
fails to consider that the "sz" calculations can have integer overflows.
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
[ Upstream commit 81207880cef207cd89db863f9aa1d65f22b4f2a2 ]
Add a register patch for rev E and above that configures the location of
some write sequences to assist with the headphone enables.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit 63f2f417526fc54191f2b813f72dc1d5322bede8 ]
API compliance scanning with coccinelle flagged:
./drivers/media/usb/gspca/m5602/m5602_s5k83a.c:180:9-25:
WARNING: timeout (100) seems HZ dependent
Numeric constants passed to schedule_timeout() make the effective
timeout HZ dependent which makes little sense in a polling loop for
the cameras rotation state.
Fixed up by converting the constant to jiffies with msecs_to_jiffies()
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
[ Upstream commit 03b36e4dcf422a10da8b67bce2ed00b34ec58aac ]
Clipping size bit of VI6_WPFn _HSZCLIP and VI6_WPFn _VSZCLIP register are from
0 bit to 11 bit. But VI6_WPF_SZCLIP_SIZE_MASK is set to 0x1FFF, this will mask
until the reserve bits. This fixes size for VI6_WPF_SZCLIP_SIZE_MASK.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu.yj@renesas.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com>
[ Upstream commit 1aa7890324b497f96f07c20673fae58f26fabfe7 ]
FP bit of VI6_DPR_mod_ROUTE register is 6bit. But VI6_DPR_ROUTE_FP_MASK is set
to 0xFF, this will mask until the reserve bit.
This fixes size for VI6_DPR_ROUTE_FP_MASK.
[ Upstream commit 45008ee9295b3ae96d7413ab91871907a671ca82 ]
FXA bit of VI6_DPR_mod_ROUTE register starts from 16bit. But VI6_DPR_ROUTE_FXA_MASK
is set to become start from 8bit. This fixes shift size for VI6_DPR_ROUTE_FXA_MASK.
[ Upstream commit e2c84ccb0fbe5e524d15bb09c042a6ca634adaed ]
If remove_pending is non-zero, then the v4l2_lock is never unlocked.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
[ Upstream commit d3b367bc26ea2e07a83fe73f0ccbddd729cb1f9a ]
It uses bitrev8(), so it must ensure that lib/bitrev.o gets included in
vmlinux.
[ Upstream commit d79bdc7f004404204a6ac07785f8d6717070ecdb ]
If omap4_keypad_parse_dt() fails we returned the error code but we
missed releasing keypad_data.
Signed-off-by: Sudip Mukherjee <sudip@vectorindia.org>
[ Upstream commit 1a5e251996e1b602f2ddc9261ee9de0ca1875bfa ]
If parkbd_allocate_serio() fails to allocate memory we are releasing the
parport but we missed unregistering the device. As a result this device
with exclusive access to that parport remains registered. And no other
device will be able to use that parport even though this driver has
failed to load.
[ Upstream commit 66bc2f51ef7deabc8b8f3baa98ae64b65e5e973a ]
There are trackpoint devices that fail to respond to the PS2 command
PSMOUSE_CMD_GETID if immediately queried after the parent device is
deactivated. Add a small delay for the hardware to get in a sane state
before sending any PS2 commands.
One example of such a system is:
Lenovo ThinkPad X120e, model 30515QG
synaptics: Touchpad model: 1, fw: 8.0, id: 0x1e2b1, caps: 0xd001a3/0x940300/0x121c00, board id: 1811, fw id: 797391
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
[ Upstream commit c9b57724b38d4c1555ee49418be3d76801e3327c ]
Looks like 0x8882 needs the same quirk than 0x8883.
Given that both devices claim they are "TPV OpticalTouchScreen" rename
the 0x8883 to add its PID in the #define.
Reported-by: Blaine Lee <blaine.j.lee@medtronic.com>
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
[ Upstream commit a4a2c54560f2c57b88ba0283f141b44f594c2337 ]
This patch adds keyboard support for MacbookPro12,1 as WELLSPRING9
(0x0272, 0x0273, 0x0274). The touchpad is handled in a separate
bcm5974 patch, as usual.
Tested-by: John Horan <knasher@gmail.com>
Tested-by: Jochen Radmacher <jradmacher@gmx.de>
Tested-by: Yang Hongyang <burnef@gmail.com>
Tested-by: Yen-Chin, Lee <coldnew.tw@gmail.com>
Tested-by: George Hilios <ghilios@gmail.com>
Tested-by: Janez Urevc <janez@janezurevc.name>
Signed-off-by: Henrik Rydberg <rydberg@bitmath.org>
Acked-by: Jiri Kosina <jkosina@suse.com>
[ Upstream commit b431ba8803666e56c1d178a421b3cbc36e8d3d33 ]
After a few iterations of start/stop UVC camera streaming, the streaming
stops.
This patch adds 250us delay in the cppi channel abort path to let cppi
drain properly.
Using 50us delay seems to be too aggressive, some webcams are still
broken. 250us is the original value used in TI 3.2 kernel.
Signed-off-by: Bin Liu <b-liu@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
[ Upstream commit cb83df77f3ec151d68a1b6be957207e6fc7b7f50 ]
1. set AUTOREQ to NONE at the beginning of teardown;
2. add delay for dma pipeline to drain;
3. Do not set USB_TDOWN bit for RX teardown.
The CPPI hw has an issue that when tearing down a RX channel, if
another RX channel is receiving data, the CPPI will lockup.
To workaround the issue, do not set the CPPI TD bit. The steps before
this point ensures the CPPI channel will be torn down properly.
[ Upstream commit 8ae25a355b5969e12f3185e8cb8eb08b871c9084 ]
The scanner (here DS3508) always returns 64 bytes per urb buffer. The first
byte indicates the data length used in the current buffer. There even was
a comment describing this. But the comment also said that we'll send
everything in the buffer to the tty layer. That means sending the actual
barcode data and lots of trailing zeroes. This patch lets the driver only
send the real data.
Signed-off-by: Philipp Hachtmann <hachti@hachti.de>
Acked-by: Johan Hovold <johan@kernel.org>
[ Upstream commit bc24937943d9f71a1e32b5dc4e2f0ef8fcc07b64 ]
Add runtime pm operations for registers access to avoid system hang.
Signed-off-by: Li Jun <jun.li@freescale.com>
[ Upstream commit 05bfd70bcdd3cd12c061cb77b73a11ba6f87379d ]
If a 3270 terminal is disconnected and later reconnected again,
it gets an unsolicited device end. This is currently ignored and
you have to hit the clear key to get the screen redrawn.
Add an automatic full redraw of the screen for this case.
[ Upstream commit e6aabee05f41c9d18e0b92194819edd84f352ac9 ]
Handle this case to make sure boundary_size does not become
0 and trigger a BUG_ON later.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
[ Upstream commit f50420223071b6ff4b586308f5c27eec54694a81 ]
Recently we purchased the Rigol DS6104 and when I try to operate it from
my Linux pc, everything works well with the default usbtmc driver,
except when I want to download a big datachunk like a screenshot. This
bitmapfile has a size of 1152054 bytes but I receive a smaller file and
no new packets can be read.
When I took a look at the driver source, I found this "Rigol quirk" and
I added the id of the new DS series oscilloscopes to this list. I
compiled it and loaded the new driver and now everything seems to work
fine.
Signed-off-by: Teunis van Beelen <teuniz@gmail.com>
[ Upstream commit 7aa6ca4d39edf01f997b9e02cf6d2fdeb224f351 ]
Set the PCI_DEV_FLAGS_VPD_REF_F0 flag on all Intel Ethernet device
functions other than function 0, so that on multi-function devices, we will
always read VPD from function 0 instead of from the other functions.
[bhelgaas: changelog]
Signed-off-by: Mark Rustad <mark.d.rustad@intel.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: Alexander Duyck <alexander.h.duyck@redhat.com>
CC: stable@vger.kernel.org
[ Upstream commit 91a37c794cf2cf7ec1f9afc4cbf4a118df7e085e ]
commit 932c435caba8a2ce473a91753bad0173269ef334 upstream.
Add a dev_flags bit, PCI_DEV_FLAGS_VPD_REF_F0, to access VPD through
function 0 to provide VPD access on other functions. This is for hardware
devices that provide copies of the same VPD capability registers in
multiple functions. Because the kernel expects that each function has its
own registers, both the locking and the state tracking are affected by VPD
accesses to different functions.
On such devices for example, if a VPD write is performed on function 0,
*any* later attempt to read VPD from any other function of that device will
hang. This has to do with how the kernel tracks the expected value of the
F bit per function.
Concurrent accesses to different functions of the same device can not only
hang but also corrupt both read and write VPD data.
When hangs occur, typically the error message:
vpd r/w failed. This is likely a firmware bug on this device.
will be seen.
Never set this bit on function 0 or there will be an infinite recursion.
[ Upstream commit 51e537387990dc1f00752103f314fd135cb94bc6 ]
Per the PCI Power Management spec r1.2, sec 3.2.4, a device that advertises
No_Soft_Reset == 0 in the PMCSR register (reported by lspci as "NoSoftRst-")
should perform an internal reset when transitioning from D3hot to D0 via
software control. Configuration context is lost and the device requires a
full reinitialization sequence.
Unfortunately the definition of "internal reset", beyond the application of
the configuration context, is largely left to the interpretation of the
specific device. Some devices don't seem to perform an "internal reset"
even if they report No_Soft_Reset == 0.
We still need to honor the PCI specification and restore PCI config context
in the event that we do a PM reset, so we don't cache and modify the
PCI_PM_CTRL_NO_SOFT_RESET bit for the device, but for interfaces where the
intention is to reset the device, like pci_reset_function(), we need a
mechanism to flag that PM reset (a D3hot->D0 transition) doesn't perform
any significant "internal reset" of the device.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit 59c816c1f24df0204e01851431d3bab3eb76719c ]
This code in vhost_scsi_make_tpg() is confusing because we limit "tpgt"
to UINT_MAX but the data type of "tpg->tport_tpgt" and that is a u16.
I looked at the context and it turns out that in
vhost_scsi_set_endpoint(), "tpg->tport_tpgt" is used as an offset into
the vs_tpg[] array which has VHOST_SCSI_MAX_TARGET (256) elements so
anything higher than 255 then it is invalid. I have made that the limit
now.
In vhost_scsi_send_evt() we mask away values higher than 255, but now
that the limit has changed, we don't need the mask.
[ Upstream commit be32c0cf0462c36f482b5ddcff1d8371be1e183c ]
The Exar XR17V358 can also be combined with a XR17V354 chip to act as a
single 12 port chip. This works the same way as the combining two XR17V358
chips. But the reported device id then is 0x4358.
Signed-off-by: Soeren Grunewald <soeren.grunewald@desy.de>
[ Upstream commit 96a5d18bc1338786fecac73599f1681f59a59a8e ]
The Exar XR17V358 chip usually provides only 8 ports. But two chips can be
combined to act as a single 16 port chip. Therefor one chip is configured
as master the second as slave by connecting the mode pin to VCC (master)
or GND (slave).
Then the master chip is reporting a different device-id depending on
whether a slave is detected or not. The UARTs 8-15 are addressed from
0x2000-0x3fff. So the offset of 0x400 from UART to UART can be used to
address all 16 ports as before.
See: https://www.exar.com/common/content/document.ashx?id=1587 page 11
[ Upstream commit b8a9d66d043ffac116100775a469f05f5158c16f ]
After commit 566c09c53455 ("raid5: relieve lock contention in get_active_stripe()")
__find_stripe() is called under conf->hash_locks + hash.
But handle_stripe_clean_event() calls remove_hash() under
conf->device_lock.
Under some cirscumstances the hash chain can be circuited,
and we get an infinite loop with disabled interrupts and locked hash
lock in __find_stripe(). This leads to hard lockup on multiple CPUs
and following system crash.
I was able to reproduce this behavior on raid6 over 6 ssd disks.
The devices_handle_discard_safely option should be set to enable trim
support. The following script was used:
for i in `seq 1 32`; do
dd if=/dev/zero of=large$i bs=10M count=100 &
done
neilb: original was against a 3.x kernel. I forward-ported
to 4.3-rc. This verison is suitable for any kernel since
Commit: 59fc630b8b5f ("RAID5: batch adjacent full stripe write")
(v4.1+). I'll post a version for earlier kernels to stable.
Signed-off-by: Roman Gushchin <klamm@yandex-team.ru>
Fixes: 566c09c53455 ("raid5: relieve lock contention in get_active_stripe()")
Signed-off-by: NeilBrown <neilb@suse.com>
Cc: Shaohua Li <shli@kernel.org>
Cc: <stable@vger.kernel.org> # 3.13 - 4.2
[ Upstream commit 0ca81a2840f77855bbad1b9f172c545c4dc9e6a4 ]
ib_send_cm_sidr_rep could sometimes erase the node from the sidr
(depending on errors in the process). Since ib_send_cm_sidr_rep is
called both from cm_sidr_req_handler and cm_destroy_id, cm_id_priv
could be either erased from the rb_tree twice or not erased at all.
Fixing that by making sure it's erased only once before freeing
cm_id_priv.
Fixes: a977049dacde ('[PATCH] IB: Add the kernel CM implementation')
Signed-off-by: Doron Tsur <doront@mellanox.com>
Signed-off-by: Matan Barak <matanb@mellanox.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit 2280521719e81919283b82902ac24058f87dfc1b ]
When pci_pool_alloc fails in mvs_task_prep then task->lldd_task stays
NULL but it's later used in mvs_abort_task as slot which is passed
to mvs_slot_task_free causing NULL pointer dereference.
Just return from mvs_slot_task_free when passed with NULL slot.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=101891
Signed-off-by: Dāvis Mosāns <davispuh@gmail.com>
Reviewed-by: Tomas Henzl <thenzl@redhat.com>
Cc: stable@vger.kernel.org
[ Upstream commit d01552a76d71f9879af448e9142389ee9be6e95b ]
This reverts commit 7eb418851f3278de67126ea0c427641ab4792c57.
This commit is poorly justified, I can find not discusison in email,
and it clearly causes a problem.
If a device which is being recovered fails and is subsequently
re-added to an array, there could easily have been changes to the
array *before* the point where the recovery was up to. So the
recovery must start again from the beginning.
If a spare is being recovered and fails, then when it is re-added we
really should do a bitmap-based recovery up to the recovery-offset,
and then a full recovery from there. Before this reversion, we only
did the "full recovery from there" which is not corect. After this
reversion with will do a full recovery from the start, which is safer
but not ideal.
It will be left to a future patch to arrange the two different styles
of recovery.
Reported-and-tested-by: Nate Dailey <nate.dailey@stratus.com>
Cc: stable@vger.kernel.org (3.14+)
Fixes: 7eb418851f32 ("md: allow a partially recovered device to be hot-added to an array.")
[ Upstream commit 681ab4696062f5aa939c9e04d058732306a97176 ]
This was introduced with 9e882242c6193ae6f416f2d8d8db0d9126bd996b
which changed the return value of submit_bio_wait() to return != 0 on
error, but didn't update the caller accordingly.
Fixes: 9e882242c6 ("block: Add submit_bio_wait(), remove from md")
Cc: stable@vger.kernel.org (v3.10)
Reported-by: Bill Kuzeja <William.Kuzeja@stratus.com>
Signed-off-by: Jes Sorensen <Jes.Sorensen@redhat.com>
[ Upstream commit 203d27b0226a05202438ddb39ef0ef1acb14a759 ]
[ Upstream commit a54c8f0f2d7df525ff997e2afe71866a1a013064 ]
xen-blkfront will crash if the check to talk_to_blkback()
in blkback_changed()(XenbusStateInitWait) returns an error.
The driver data is freed and info is set to NULL. Later during
the close process via talk_to_blkback's call to xenbus_dev_fatal()
the null pointer is passed to and dereference in blkfront_closing.
Signed-off-by: Cathy Avery <cathy.avery@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
[ Upstream commit fd7cd061adcf5f7503515ba52b6a724642a839c8 ]
We received several reports of systems rebooting and powering on
after an attempted shutdown. Testing showed that setting
XHCI_SPURIOUS_WAKEUP quirk in addition to the XHCI_SPURIOUS_REBOOT
quirk allowed the system to shutdown as expected for LynxPoint-LP
xHCI controllers. Set the quirk back.
Note that the quirk was originally introduced for LynxPoint and
LynxPoint-LP just for this same reason. See:
commit 638298dc66ea ("xhci: Fix spurious wakeups after S5 on Haswell")
It was later limited to only concern HP machines as it caused
regression on some machines, see both bug and commit:
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=66171
commit 6962d914f317 ("xhci: Limit the spurious wakeup fix only to HP machines")
Later it was discovered that the powering on after shutdown
was limited to LynxPoint-LP (Haswell-ULT) and that some non-LP HP
machine suffered from spontaneous resume from S3 (which should
not be related to the SPURIOUS_WAKEUP quirk at all). An attempt
to fix this then removed the SPURIOUS_WAKEUP flag usage completely.
commit b45abacde3d5 ("xhci: no switching back on non-ULT Haswell")
Current understanding is that LynxPoint-LP (Haswell ULT) machines
need the SPURIOUS_WAKEUP quirk, otherwise they will restart, and
plain Lynxpoint (Haswell) machines may _not_ have the quirk
set otherwise they again will restart.
Signed-off-by: Laura Abbott <labbott@fedoraproject.org>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Oliver Neukum <oneukum@suse.com>
[Added more history to commit message -Mathias]
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
[ Upstream commit 3b4739b8951d650becbcd855d7d6f18ac98a9a85 ]
If a host fails to wake up a isochronous SuperSpeed device from U1/U2
in time for a isoch transfer it will generate a "No ping response error"
Host will then move to the next transfer descriptor.
Handle this case in the same way as missed service errors, tag the
current TD as skipped and handle it on the next transfer event.
[ Upstream commit 4dcb8b57df3593dcb20481d9d6cf79d1dc1534be ]
btree_split_beneath()'s error path had an outstanding FIXME that speaks
directly to the potential for _not_ cleaning up a previously allocated
bufio-backed block.
Fix this by releasing the previously allocated bufio block using
unlock_block().
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Joe Thornber <thornber@redhat.com>
[ Upstream commit 2871c69e025e8bc507651d5a9cf81a8a7da9d24b ]
Commit 4c7e309340ff ("dm btree remove: fix bug in redistribute3") wasn't
a complete fix for redistribute3().
The redistribute3 function takes 3 btree nodes and shares out the entries
evenly between them. If the three nodes in total contained
(MAX_ENTRIES * 3) - 1 entries between them then this was erroneously getting
rebalanced as (MAX_ENTRIES - 1) on the left and right, and (MAX_ENTRIES + 1) in
the center.
Fix this issue by being more careful about calculating the target number
of entries for the left and right nodes.
Unit tested in userspace using this program:
https://github.com/jthornber/redistribute3-test/blob/master/redistribute3_t.c
Signed-off-by: Joe Thornber <ejt@redhat.com>
[ Upstream commit bae818ee1577c27356093901a0ea48f672eda514 ]
rbd requires stable pages, as it performs a crc of the page data before
they are send to the OSDs.
But since kernel 3.9 (patch 1d1d1a767206fbe5d4c69493b7e6d2a8d08cc0a0
"mm: only enforce stable page writes if the backing device requires
it") it is not assumed anymore that block devices require stable pages.
This patch sets the necessary flag to get stable pages back for rbd.
In a ceph installation that provides multiple ext4 formatted rbd
devices "bad crc" messages appeared regularly (ca 1 message every 1-2
minutes on every OSD that provided the data for the rbd) in the
OSD-logs before this patch. After this patch this messages are pretty
much gone (only ca 1-2 / month / OSD).
Cc: stable@vger.kernel.org # 3.9+, needs backporting
Signed-off-by: Ronny Hegewald <Ronny.Hegewald@online.de>
[idryomov@gmail.com: require stable pages only in crc case, changelog]
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
[ Upstream commit b94e22805a2224061bb263a82b72e09544a5fbb3 ]
0° Kelvin is actually −273.15°C, not -272.15°C. Fix the temperature offset.
Also improve the comment explaining the calculation.
Reported-by: Janusz Użycki <j.uzycki@elpromaelectronics.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Stefan Wahren <stefan.wahren@i2se.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
[ Upstream commit 49abb26651167c892393cd9f2ad23df429645ed9 ]
Fixes a harmless error message caused by:
51a4726b04e880fdd9b4e0e58b13f70b0a68a7f5
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
