commit 1d220334d6a8a711149234dc5f98d34ae02226b8 upstream.
The missing break statement causes wrong capacity calculation for
batteries that report energy.
Reported-by: d binderman <dcb314@hotmail.com>
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
commit c3b327d60bbba3f5ff8fd87d1efc0e95eb6c121b upstream.
All bits in the values read from registers to be used for the next
write were getting overwritten, avoid doing so to not mess with the
current configuration.
Signed-off-by: Guillem Jover <guillem@hadrons.org>
Cc: Riku Voipio <riku.voipio@iki.fi>
commit 96f3640894012be7dd15a384566bfdc18297bc6c upstream.
The spec notes that fan0 and fan1 control mode bits are located in bits
7-6 and 5-4 respectively, but the FAN_CTRL_MODE macro was making the
bits shift by 5 instead of by 4.
commit 904879748d7439a6dabdc6be9aad983e216b027d upstream.
The 5 GHz CTL indexes were not being read for all hardware
devices due to the masking out through the CTL_MODE_M mask
being one bit too short. Without this the calibrated regulatory
maximum values were not being picked up when devices operate
on 5 GHz in HT40 mode. The final output power used for Atheros
devices is the minimum between the calibrated CTL values and
what CRDA provides.
Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com>
commit 0827a9ff2bbcbb03c33f1a6eb283fe051059482c upstream.
If we can't read the firmware for a device from the disk, and yet the
device already has a valid firmware image in it, we don't want to
replace the firmware with something invalid. So check the version
number to be less than the current one to verify this is the correct
thing to do.
Reported-by: Chris Beauchamp <chris@chillibean.tv>
Tested-by: Chris Beauchamp <chris@chillibean.tv>
Cc: Alan Stern <stern@rowland.harvard.edu>
commit 0eee6a2b2a52e17066a572d30ad2805d3ebc7508 upstream.
I recently bought a i-gotU USB GPS, and whilst hunting around for linux
support discovered this post by you back in 2009:
http://kerneltrap.org/mailarchive/linux-usb/2009/3/12/5148644
>Try the navman driver instead. You can either add the device id to the
> driver and rebuild it, or do this before you plug the device in:
> modprobe navman
> echo -n "0x0df7 0x0900" > /sys/bus/usb-serial/drivers/navman/new_id
> and then plug your device in and see if that works.
I can confirm that the navman driver works with the right device IDs on
my i-gotU GT-600, which has the same device IDs. Attached is a patch
adding the IDs.
commit b9f0aee83335db1f3915f4e42a5e21b351740afd upstream.
non-critical issue, CVE-2010-2803
Userspace controls the amount of memory to be allocate, so it can
get the ioctl to allocate more memory than the kernel uses, and get
access to kernel stack. This can only be done for processes authenticated
to the X server for DRI access, and if the user has DRI access.
Fix is to just memset the data to 0 if the user doesn't copy into
it in the first place.
Reported-by: Kees Cook <kees@ubuntu.com>
commit 51e9ac77035a3dfcb6fc0a88a0d80b6f99b5edb1 upstream.
If the 'bio_split' path in raid10-read is used while
resync/recovery is happening it is possible to deadlock.
Fix this be elevating ->nr_waiting for the duration of both
parts of the split request.
This fixes a bug that has been present since 2.6.22
but has only started manifesting recently for unknown reasons.
It is suitable for and -stable since then.
Reported-by: Justin Bronder <jsbronder@gentoo.org>
Tested-by: Justin Bronder <jsbronder@gentoo.org>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 549e15611b4ac1de51ef0e0a79c2704f50a638a2 upstream.
MSI delivery from on-board ahci controller doesn't work on K8M800. At
this point, it's unclear whether the culprit is with the ahci
controller or the host bridge. Given the track record and considering
the rather minimal impact of MSI, disabling it seems reasonable.
Reported-by: Rainer Hurtado Navarro <publio.escipion.el.africano@gmail.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit a01c7800420d2c294ca403988488a635d4087a6d upstream.
In nvram_write, first of all, correctly handle the case where the file
pointer is already beyond the end; we should return EOF in that case.
Second, make the logic a bit more explicit so that gcc can statically
prove that the copy_from_user() is safe. Once the condition of the
beyond-end filepointer is eliminated, the copy is safe but gcc can't
prove it, causing build failures for i386 allyesconfig.
Third, eliminate the entirely superfluous variable "len", and just use
the passed-in variable "count" instead.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Wim Van Sebroeck <wim@iguana.be>
LKML-Reference: <tip-*@git.kernel.org>
Cc: Stephen Hemminger <shemminger@vyatta.com>
commit a91c1be21704113b023919826c6d531da46656ef upstream.
we also need to clean up and free the cdev.
Reported-by: Jani Nikula <ext-jani.1.nikula@nokia.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit 4b4fd27c0b5ec638a1f06ced9226fd95229dbbf0 upstream.
avoid potential stack overflow by correctly checking count parameter
Reported-by: Ilja <ilja@netric.org>
Signed-off-by: Helge Deller <deller@gmx.de>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
commit 5a29f7893fbe681f1334285be7e41e56f0de666c upstream.
I've hit an issue on my system when I've been using RealTek RTL8139D cards in
bonding interface in mode balancing-alb. When I enslave a card, the current
active slave (bond->curr_active_slave) is not set and the link is therefore
not functional.
# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.5.0 (November 4, 2008)
Bonding Mode: adaptive load balancing
Primary Slave: None
Currently Active Slave: None
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
Slave Interface: eth1
MII Status: up
Link Failure Count: 0
Permanent HW addr: 00:1f:1f:01:2f:22
The thing that gets it right is when I unplug the cable and then I put it back
into the NIC. Then the current active slave is set to eth1 and link is working
just fine. Here is dmesg log with bonding DEBUG messages turned on:
ADDRCONF(NETDEV_UP): bond0: link is not ready
event_dev: bond0, event: 1
IFF_MASTER
event_dev: bond0, event: 8
IFF_MASTER
bond_ioctl: master=bond0, cmd=35216
slave_dev=cac5d800:
slave_dev->name=eth1:
eth1: ! NETIF_F_VLAN_CHALLENGED
event_dev: eth1, event: 8
eth1: link up, 100Mbps, full-duplex, lpa 0xC5E1
event_dev: eth1, event: 1
IFF_SLAVE
Initial state of slave_dev is BOND_LINK_UP
bonding: bond0: enslaving eth1 as an active interface with an up link.
ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
event_dev: bond0, event: 4
IFF_MASTER
bond0: no IPv6 routers present
<<<<cable unplug>>>>
eth1: link down
event_dev: eth1, event: 4
IFF_SLAVE
bonding: bond0: link status definitely down for interface eth1, disabling it
IFF_MASTER
<<<<cable plug>>>>
IFF_SLAVE
bonding: bond0: link status definitely up for interface eth1.
bonding: bond0: making interface eth1 the new active one.
IFF_SLAVE
IFF_SLAVE
bonding: bond0: first active interface up!
IFF_MASTER
The current active slave is set by calling bond_select_active_slave() function
from bond_miimon_commit() function when the slave (eth1) link goes to state up.
I also tested this on other machine with Broadcom NetXtreme II BCM5708
1000Base-T NIC and there all works fine. The thing is that this adapter is down
and goes up after few seconds after it is enslaved.
This patch calls bond_select_active_slave() in bond_enslave() function for modes
alb and tlb and makes sure that the current active slave is set up properly even
when the slave state is already up. Tested on both systems, works fine.
Notice: The same problem can maybe also occrur in mode 8023AD but I'm unable to
test that.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Cc: Jean Delvare <jdelvare@suse.de>
commit 7a52b34b07122ff5f45258d47f260f8a525518f0 upstream.
Sumeet Lahorani <sumeet.lahorani@oracle.com> reported that the IPoIB
child entries are world-writable; however we don't want ordinary users
to be able to create and destroy child interfaces, so fix them to be
writable only by root.
Signed-off-by: Or Gerlitz <ogerlitz@voltaire.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
commit 6fd024893911dcb51b4a0aa71971db5ba38f7071 upstream.
The current initialisation code probes 'unsupported' AGP devices
simply by calling its own probe function. It does not lock these
devices or even check whether another driver is already bound to
them.
We must use the device core to manage this. So if the specific
device id table didn't match anything and agp_try_unsupported=1,
switch the device id table and call driver_attach() again.
commit 8a52da632ceb9d8b776494563df579e87b7b586b upstream.
The debugging code using the freed structure is moved before the kfree.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@free@
expression E;
position p;
kfree@p(E)
expression free.E, subE<=free.E, E1;
position free.p;
kfree@p(E)
subE = E1
* E
// </smpl>
commit d6a574ff6bfb842bdb98065da053881ff527be46 upstream.
Use an irq spinlock to hold off the IRQ handler until
enough early card init is complete such that the handler
can run without faulting.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
commit 38000a94a902e94ca8b5498f7871c6316de8957a upstream.
sky2_phy_reinit is called by the ethtool helpers sky2_set_settings,
sky2_nway_reset and sky2_set_pauseparam when netif_running.
However, at the end of sky2_phy_init GM_GP_CTRL has GM_GPCR_RX_ENA and
GM_GPCR_TX_ENA cleared. So, doing these commands causes the device to
stop working:
$ ethtool -r eth0
$ ethtool -A eth0 autoneg off
Fix this issue by enabling Rx/Tx after running sky2_phy_init in
sky2_phy_reinit.
Signed-off-by: Brandon Philips <bphilips@suse.de>
Tested-by: Brandon Philips <bphilips@suse.de>
Cc: stable@kernel.org
Tested-by: Mike McCormack <mikem@ring3k.org>
commit ed770f01360b392564650bf1553ce723fa46afec upstream.
If the call to phy_connect fails, we will return directly instead of freeing
the previously allocated struct net_device.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
commit d883b9f0977269d519469da72faec6a7f72cb489 upstream.
On hyper-threaded CPUs, each core appears twice in the CPU list. Skip
the second entry to avoid duplicate sensors.
Acked-by: Huaxu Wan <huaxu.wan@intel.com>
commit 3f4f09b4be35d38d6e2bf22c989443e65e70fc4c upstream.
Don't assume that CPU entry number and core ID always match. It
worked in the simple cases (single CPU, no HT) but fails on
multi-CPU systems.
commit a747c5abc329611220f16df0bb4cf0ca4a7fdf0c upstream.
If run_to_completion flag is set, it means that we are running in a
single-threaded mode, and thus no locks are held.
This fixes a deadlock when IPMI notifier is being called during panic.
Acked-by: Corey Minyard <minyard@acm.org>
commit e2218350465e7e0931676b4849b594c978437bce upstream.
When the user sets the block device to readwrite then the mddev should
follow suit. Otherwise, the BUG_ON in md_write_start() will be set to
trigger.
The reverse direction, setting mddev->ro to match a set readonly
request, can be ignored because the blkdev level readonly flag precludes
the need to have mddev->ro set correctly. Nevermind the fact that
setting mddev->ro to 1 may fail if the array is in use.
commit af3a2cd6b8a479345786e7fe5e199ad2f6240e56 upstream.
read_balance uses a "unsigned long" for a sector number which
will get truncated beyond 2TB.
This will cause read-balancing to be non-optimal, and can cause
data to be read from the 'wrong' branch during a resync. This has a
very small chance of returning wrong data.
Reported-by: Jordan Russell <jr-list-2010@quo.to>
commit 964147d5c86d63be79b442c30f3783d49860c078 upstream.
There is a very small race window when writing to a
RAID1 such that if a device is marked faulty at exactly the wrong
time, the write-in-progress will not be sent to the device,
but the bitmap (if present) will be updated to say that
the write was sent.
Then if the device turned out to still be usable as was re-added
to the array, the bitmap-based-resync would skip resyncing that
block, possibly leading to corruption. This would only be a problem
if no further writes were issued to that area of the device (i.e.
that bitmap chunk).
Suitable for any pending -stable kernel.
commit e7971c80a8e0299f91272ad8e8ac4167623e1862 upstream.
The SH SOHARD ARCNET cards are implemented using generic PLX Technology
PCI<->IOBus bridges. Subvendor and subdevice IDs were not specified,
causing the driver to attach to any such bridge and likely crash the
system by attempting to initialize an unrelated device.
Fix by specifying subvendor and subdevice according to the values found
in the PCI-ID Repository at http://pci-ids.ucw.cz/ .
Signed-off-by: Andreas Bombe <aeb@debian.org>
commit e7ecd435692ca9bde9d124be30b3a26e672ea6c2 upstream.
There are ATAPI devices which raise AN when hit by commands issued by
open(). This leads to infinite loop of AN -> MEDIA_CHANGE uevent ->
udev open() to check media -> AN.
Both ACS and SerialATA standards don't define in which case ATAPI
devices are supposed to raise or not raise AN. They both list media
insertion event as a possible use case for ATAPI ANs but there is no
clear description of what constitutes such events. As such, it seems
a bit too naive to export ANs directly to userland as MEDIA_CHANGE
events without further verification (which should behave similarly to
windows as it apparently is the only thing that some hardware vendors
are testing against).
This patch adds libata.atapi_an module parameter and disables ATAPI AN
by default for now.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Nick Bowler <nbowler@elliptictech.com>
Cc: David Zeuthen <david@fubar.dk>
commit 1c010ff8912cbc08d80e865aab9c32b6b00c527d upstream.
The functionality bit vector is always returned as a little-endian
32-bit number by the device, so it must be byte-swapped to the host
endianness.
On the other hand, the delay value is handled by the USB stack, so no
byte swapping is needed on our side.
This fixes bug #15105:
http://bugzilla.kernel.org/show_bug.cgi?id=15105
Reported-by: Jens Richter <jens@richter-stutensee.de>
Tested-by: Jens Richter <jens@richter-stutensee.de>
Cc: Till Harbaum <till@harbaum.org>
commit c074c39d62306efa5ba7c69c1a1531bc7333d252 upstream.
Experience has shown that the block buffer can only be used for SMBus
(not I2C) block transactions, even though the datasheet doesn't
mention this limitation.
Reported-by: Felix Rubinstein <felixru@gmail.com>
Cc: Oleg Ryjkov <oryjkov@gmail.com>
commit b0bcdd3cd0adb85a7686b396ba50493871b1135c upstream.
Different motherboards have different PNP declarations for
W83781D/W83782D chips. Some declare the whole range of I/O ports (8
ports), some declare only the useful ports (2 ports at offset 5) and
some declare fancy ranges, for example 4 ports at offset 4. To
properly handle all cases, request all ports individually for probing.
After we have determined that we really have a W83781D or W83782D
chip, the useful port range will be requested again, as a single
block.
I did not see a board which needs this yet, but I know of one for lm78
driver and I'd like to keep the logic of these two drivers in sync.
commit 534ead709235b967b659947c55d9130873a432c4 upstream.
libata currently doesn't retry if a command fails with AC_ERR_INVALID
assuming that retrying won't get it any further even if retried.
However, a failure may be classified as invalid through hardware
glitch (incorrect reading of the error register or firmware bug) and
there isn't whole lot to gain by not retrying as actually invalid
commands will be failed immediately. Also, commands serving FS IOs
are extremely unlikely to be invalid. Retry FS IOs even if it's
marked invalid.
Transient and incorrect invalid failure was seen while debugging
firmware related issue on Samsung n130 on bko#14314.
http://bugzilla.kernel.org/show_bug.cgi?id=14314
Reported-by: Johannes Stezenbach <js@sig21.net>
returning it via qc->result_tf.
commit a09bf4cd53b8ab000197ef81f15d50f29ecf973c upstream.
commit b1d4b390ea4bb480e65974ce522a04022608a8df upstream.
Some FSC hardware monitoring chips (Syleus at least) doesn't like
quick writes we typically use to probe for I2C chips. Use a regular
byte read instead for the address they live at (0x73). These are the
only known chips living at this address on PC systems.
For clarity, this fix should not be needed for kernels 2.6.30 and
later, as we started instantiating the hwmon devices explicitly based
on DMI data. Still, this fix is valuable in the following two cases:
* Support for recent FSC chips on older kernels. The DMI-based device
instantiation is more difficult to backport than the device support
itself.
* Case where the DMI-based device instantiation fails, whatever the
reason. We fall back to probing in that case, so it should work.
This fixes kernel bug #15634:
https://bugzilla.kernel.org/show_bug.cgi?id=15634
Acked-by: Hans de Goede <hdegoede@redhat.com>
commit fa7fe7af146a7b613e36a311eefbbfb5555325d1 upstream.
There is a typo here. We should be testing "*dentry" which was just
assigned instead of "dentry". This could result in dereferencing an
ERR_PTR inside either usbfs_mkdir() or usbfs_create().
This is a merge of two mainline commits, intended
for stable@kernel.org submission for 2.6.27 kernel.
commit f833bab87fca5c3ce13778421b1365845843b976
and
commit 918aae42aa9b611a3663b16ae849fdedc67c2292
Changelog of both:
Currently clockevents_notify() is called with interrupts enabled at
some places and interrupts disabled at some other places.
This results in a deadlock in this scenario.
cpu A holds clockevents_lock in clockevents_notify() with irqs enabled
cpu B waits for clockevents_lock in clockevents_notify() with irqs disabled
cpu C doing set_mtrr() which will try to rendezvous of all the cpus.
This will result in C and A come to the rendezvous point and waiting
for B. B is stuck forever waiting for the spinlock and thus not
reaching the rendezvous point.
Fix the clockevents code so that clockevents_lock is taken with
interrupts disabled and thus avoid the above deadlock.
Also call lapic_timer_propagate_broadcast() on the destination cpu so
that we avoid calling smp_call_function() in the clockevents notifier
chain.
This issue left us wondering if we need to change the MTRR rendezvous
logic to use stop machine logic (instead of smp_call_function) or add
a check in spinlock debug code to see if there are other spinlocks
which gets taken under both interrupts enabled/disabled conditions.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: "Brown Len" <len.brown@intel.com>
LKML-Reference: <1250544899.2709.210.camel@sbs-t61.sc.intel.com>
I got following warning on ia64 box:
In function 'acpi_processor_power_verify':
642: warning: passing argument 2 of 'smp_call_function_single' from
incompatible pointer type
This smp_call_function_single() was introduced by a commit
f833bab87fca5c3ce13778421b1365845843b976:
The problem is that the lapic_timer_propagate_broadcast() has 2 versions:
One is real code that modified in the above commit, and the other is NOP
code that used when !ARCH_APICTIMER_STOPS_ON_C3:
static void lapic_timer_propagate_broadcast(struct acpi_processor *pr) { }
So I got warning because of !ARCH_APICTIMER_STOPS_ON_C3.
We really want to do nothing here on !ARCH_APICTIMER_STOPS_ON_C3, so
modify lapic_timer_propagate_broadcast() of real version to use
smp_call_function_single() in it.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Signed-off-by: Thomas Renninger <trenn@suse.de>
commit b3dc1a212e5167984616445990c76056034f8eeb upstream.
It looks like this patch -
commit 7b2519afa1abd1b9f63aa1e90879307842422dae
Author: Yang, Bo <Bo.Yang@lsi.com>
Date: Tue Oct 6 14:52:20 2009 -0600
[SCSI] megaraid_sas: fix 64 bit sense pointer truncation
has caused a problem for 32bit programs with 64bit os -
http://bugzilla.kernel.org/show_bug.cgi?id=15001
fix by converting the user space 32bit pointer to a 64 bit one when
needed.
[jejb: fix up some 64 bit warnings]
Signed-off-by: Tomas Henzl <thenzl@redhat.com>
Cc: Bo Yang <Bo.Yang@lsi.com>
commit 6da8d866d0d39e9509ff826660f6a86a6757c966 upstream.
release_one_tty(tty) can be called when tty still has a reference
to pgrp/session. In this case we leak the pid.
Reported-by: Catalin Marinas <catalin.marinas@arm.com>
Reported-and-tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
commit 4d7a5644e4adfafe76c2bd8ee168e3f3b5dae3a8 upstream.
Add missing newline to dev_warn() message string. This is more of an issue
with older kernels that don't automatically add a newline if it was missing
from the end of the previous line.
Signed-off-by: Dean Nelson <dnelson@redhat.com>
commit 7152b592593b9d48b33f8997b1dfd6df9143f7ec upstream.
This patch (as1352) fixes a bug in the way isochronous input data is
returned to userspace for usbfs transfers. The entire buffer must be
copied, not just the first actual_length bytes, because the individual
packets will be discontiguous if any of them are short.
Reported-by: Markus Rechberger <mrechberger@gmail.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit e0188829cb724e7d12a2d4e343b368ff1d6e1471 upstream.
About 50% of shutdowns of b44 Ethernet adapter ends by kernel panic
with kernels compiled with stack-protector.
Checking b44_magic_pattern() return values, one call of
b44_magic_pattern() returns 127. It means, that set_bit(128, pmask)
was called on line 1509. It means that bit 0 of 17th byte of pmask was
overwritten. But pmask has only 16 bytes. Stack corruption happens.
It seems that set_bit() on line 1509 always writes one bit off.
The fix does not only solve the stack corruption, but also makes Wake
On LAN working on my onboard B44 on Asus A7V-333X mainboard.
It seems that this problem affects all kernel versions since commit
725ad800 ([PATCH] b44: add wol for old nic) on 2006-06-20.
Signed-off-by: Stanislav Brabec <sbrabec@suse.cz>
commit 19f48cb105b7fa18d0dcab435919a3a29b7a7c4c upstream.
this patch fixes a memory leak which occurs when an em28xx card with DVB
extension is unplugged or its DVB extension driver is unloaded. In
dvb_fini(), dev->dvb must be freed before being set to NULL, as is done
in dvb_init() in case of error.
Note that this bug is also present in the latest stable kernel release.
Signed-off-by: Francesco Lavra <francescolavra@interfree.it>
commit 41f8910040639eb106b1a5b5301aab79ecde4940 upstream.
Pointed out by Sean E. Millichamp.
Quote from Documentation/networking/bonding.txt:
"Note that when a bonding interface has no active links, the
driver will immediately reuse the first link that goes up, even if the
updelay parameter has been specified (the updelay is ignored in this
case). If there are slave interfaces waiting for the updelay timeout
to expire, the interface that first went into that state will be
immediately reused. This reduces down time of the network if the
value of updelay has been overestimated, and since this occurs only in
cases with no connectivity, there is no additional penalty for
ignoring the updelay."
This patch actually changes the behaviour in this way.
commit 6b4dbcd86a9d464057fcc7abe4d0574093071fcc upstream.
loff_t is a signed type. If userspace passes a negative ppos, the "count"
range check is weakened. "count"s bigger than HPEE_MAX_LENGTH will pass the check.
Also, if ppos is negative, the readb(eisa_eeprom_addr + *ppos) will poke in random
memory.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
commit 7dc482dfeeeefcfd000d4271c4626937406756d7 upstream.
Almost all r128's private ioctls require that the CCE state has
already been initialised. However, most do not test that this has
been done, and will proceed to dereference a null pointer. This may
result in a security vulnerability, since some ioctls are
unprivileged.
This adds a macro for the common initialisation test and changes all
ioctl implementations that require prior initialisation to use that
macro.
Also, r128_do_init_cce() does not test that the CCE state has not
been initialised already. Repeated initialisation may lead to a crash
or resource leak. This adds that test.
commit ef4638f955f2c4a667c8af20769d03f5ed3781ca upstream.
This patch (as1274) simplifies the counting of transaction-error
retries. Now we will count up from 0 to QH_XACTERR_MAX instead of
down from QH_XACTERR_MAX to 0.
The patch also fixes a small bug: qh->xacterr was not getting
initialized for interrupt endpoints.
Tested-by: Matthijs Kooijman <matthijs@stdin.nl>
Cc: Reinoud Koornstra <koornstra@hp.com>
commit ddeee0b2eec2a51b0712b04de4b39e7bec892a53 upstream.
I notice that the processcompl_compat() function seems to be leaking the
'struct async *as' in the error paths.
I think that the calling convention is fundamentally buggered. The
caller is the one that did the "reap_as()" to get the as thing, the
caller should be the one to free it too.
Freeing it in the caller also means that it very clearly always gets
freed, and avoids the need for any "free in the error case too".
From: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Marcus Meissner <meissner@suse.de>
commit d4a4683ca054ed9917dfc9e3ff0f7ecf74ad90d6 upstream.
We need to only copy the data received by the device to userspace, not
the whole kernel buffer, which can contain "stale" data.
Thanks to Marcus Meissner for pointing this out and testing the fix.
Reported-by: Marcus Meissner <meissner@suse.de>
Tested-by: Marcus Meissner <meissner@suse.de>
commit bca476139d2ded86be146dae09b06e22548b67f3 upstream.
When controlling an industrial radio modem it can be necessary to
manipulate the handshake lines in order to control the radio modem's
transmitter, from userspace.
The transmitter should not be turned off before all characters have been
transmitted. serial8250_tx_empty() was reporting that all characters were
transmitted before they actually were.
Discovered in parallel with more testing and analysis by Kees Schoenmakers
as follows:
I ran into an NetMos 9835 serial pci board which behaves a little
different than the standard. This type of expansion board is very common.
"Standard" 8250 compatible devices clear the 'UART_LST_TEMT" bit together
with the "UART_LSR_THRE" bit when writing data to the device.
The NetMos device does it slightly different
I believe that the TEMT bit is coupled to the shift register. The problem
is that after writing data to the device and very quickly after that one
does call serial8250_tx_empty, it returns the wrong information.
My patch makes the test more robust (and solves the problem) and it does
not affect the already correct devices.
Alan:
We may yet need to quirk this but now we know which chips we have a
way to do that should we find this breaks some other 8250 clone with
dodgy THRE.
Signed-off-by: Dick Hollenbeck <dick@softplc.com>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Cc: Kees Schoenmakers <k.schoenmakers@sigmae.nl>
In Linus' tree:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=c556752109794a5ff199b80a1673336b4df8433a
dev_dbg outputs dev_name, which is released with device_unregister. This bug
resulted in output like this:
i2c Xy2�0: adapter [SMBus I801 adapter at 1880] unregistered
The right output would be:
i2c i2c-0: adapter [SMBus I801 adapter at 1880] unregistered
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
commit 730c586ad5228c339949b2eb4e72b80ae167abc4 upstream.
While running 20 parallel instances of dd as follows:
#!/bin/bash
for i in `seq 1 20`; do
dd if=/dev/zero of=/export/hda3/dd_$i bs=1073741824 count=1 &
done
wait
on a 16G machine, we noticed that rather than just killing the processes,
the entire kernel went down. Stracing dd reveals that it first does an
mmap2, which makes 1GB worth of zero page mappings. Then it performs a
read on those pages from /dev/zero, and finally it performs a write.
The machine died during the reads. Looking at the code, it was noticed
that /dev/zero's read operation had been changed by
557ed1fa2620dc119adb86b34c614e152a629a80 ("remove ZERO_PAGE") from giving
zero page mappings to actually zeroing the page.
The zeroing of the pages causes physical pages to be allocated to the
process. But, when the process exhausts all the memory that it can, the
kernel cannot kill it, as it is still in the kernel mode allocating more
memory. Consequently, the kernel eventually crashes.
To fix this, I propose that when a fatal signal is pending during
/dev/zero read operation, we simply return and let the user process die.
Signed-off-by: Salman Qazi <sqazi@google.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
[ Modified error return and comment trivially. - Linus]
