Pull scsi target fixes from Nicholas Bellinger:
"Apologies for the late pull request.
Here are the outstanding target-pending fixes for v4.1 code.
The series contains three patches from Sagi + Co that address a few
iser-target issues that have been uncovered during recent testing at
Mellanox.
Patch #1 has a v3.16+ stable tag, and #2-3 have v3.10+ stable tags"
* git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending:
iser-target: Fix possible use-after-free
iser-target: release stale iser connections
iser-target: Fix variable-length response error completion
Pull drm fixes from Dave Airlie:
"A smattering of fixes,
mgag200:
don't accept modes that aren't aligned properly as hw can't do it
i915:
two regression fixes
radeon:
one query to allow userspace fixes
one oops fixer for older hw with new options enabled"
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/radeon: don't probe MST on hw we don't support it on
drm/radeon: Add RADEON_INFO_VA_UNMAP_WORKING query
drm/mgag200: Reject non-character-cell-aligned mode widths
Revert "drm/i915: Don't skip request retirement if the active list is empty"
drm/i915: Always reset vma->ggtt_view.pages cache on unbinding
git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux
Pull clk fixes from Michael Turquette:
"Very late clk regression fixes for the ARM-based AT91 platform.
These went unnoticed by me until recently, hence the late pull
request"
* tag 'clk-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/clk/linux:
clk: at91: fix h32mx prototype inclusion in pmc header
clk: at91: trivial: typo in peripheral clock description
clk: at91: fix PERIPHERAL_MAX_SHIFT definition
clk: at91: pll: fix input range validity check
https://github.com/bbrezillon/linux-at91 into clk-fixes
Trivial fix that prevents to compile this pmc clock driver if h32mx clock is
present but smd clock isn't.
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Fixes: bcc5fd49a0fd ("clk: at91: add a driver for the h32mx clock")
Cc: <stable@vger.kernel.org> # 3.18+
Fix the PERIPHERAL_MAX_SHIFT definition (3 instead of 4) and adapt the
round_rate and set_rate logic accordingly.
Reported-by: "Wu, Songjun" <Songjun.Wu@atmel.com>
The PLL impose a certain input range to work correctly, but it appears that
this input range does not apply on the input clock (or parent clock) but
on the input clock after it has passed the PLL divisor.
Fix the implementation accordingly.
Cc: <stable@vger.kernel.org> # v3.14+
Reported-by: Jonas Andersson <jonas@microbit.se>
git://anongit.freedesktop.org/drm-intel into drm-fixes
one fix, one revert
* tag 'drm-intel-fixes-2015-06-18' of git://anongit.freedesktop.org/drm-intel:
If you do radeon.mst=1 on a gpu without mst hw, and then
plug some mst hw it will oops instead of falling back.
So check we have DCE5 at least before proceeding.
Signed-off-by: Christian König <christian.koenig@amd.com>
This tells userspace that it's safe to use the RADEON_VA_UNMAP operation
of the DRM_RADEON_GEM_VA ioctl.
Cc: stable@vger.kernel.org
(NOTE: Backporting this commit requires at least backports of commits
26d4d129b6042197b4cbc8341c0618f99231af2f,
48afbd70ac7b6aa62e8d452091023941d8085f8a and
c29c0876ec05d51a93508a39b90b92c29ba6423d as well, otherwise using
RADEON_VA_UNMAP runs into trouble)
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
Since when we start discussions about the usage Media Controller for
complex hardware, one thing become clear: the way it is, MC fails to
map anything different than capture/output/m2m video-only streaming.
The point is that MC has entities named as devnodes, but the only
devnode used (before the DVB patches) is MEDIA_ENT_T_DEVNODE_V4L.
Due to the way MC got implemented, however, this entity actually
doesn't represent the devnode, but the hardware I/O engine that
receives data via DMA.
By coincidence, such DMA is associated with the V4L device node
on webcam hardware, but this is not true even for other V4L2
devices. For example, on USB hardware, the DMA is done via the
USB controller. The data passes though a in-kernel filter that
strips off the URB headers. Other V4L2 devices like radio may not
even have DMA. When it have, the DMA is done via ALSA, and not
via the V4L devnode.
In other words, MC is broken as a whole, but tagging it as BROKEN
right now would do more harm than good.
So, instead, let's mark, for now, the DVB part as broken and
block all new changes to MC while we fix this mess, whith
we hopefully will do for the next Kernel version.
Requested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Pull crypto fixes from Herbert Xu:
"This fixes the following issues:
- Crash in caam hash due to uninitialised buffer lengths.
- Alignment issue in caam RNG that may lead to non-random output"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
crypto: caam - fix RNG buffer cache alignment
crypto: caam - improve initalization for context state saves
The hwrng output buffers (2) are cast inside of a a struct (caam_rng_ctx)
allocated in one DMA-tagged region. While the kernel's heap allocator
should place the overall struct on a cacheline aligned boundary, the 2
buffers contained within may not necessarily align. Consenquently, the ends
of unaligned buffers may not fully flush, and if so, stale data will be left
behind, resulting in small repeating patterns.
This fix aligns the buffers inside the struct.
Note that not all of the data inside caam_rng_ctx necessarily needs to be
DMA-tagged, only the buffers themselves require this. However, a fix would
incur the expense of error-handling bloat in the case of allocation failure.
Signed-off-by: Steve Cornelius <steve.cornelius@freescale.com>
Signed-off-by: Victoria Milhoan <vicki.milhoan@freescale.com>
Multiple function in asynchronous hashing use a saved-state block,
a.k.a. struct caam_hash_state, which holds a stash of information
between requests (init/update/final). Certain values in this state
block are loaded for processing using an inline-if, and when this
is done, the potential for uninitialized data can pose conflicts.
Therefore, this patch improves initialization of state data to
prevent false assignments using uninitialized data in the state block.
This patch addresses the following traceback, originating in
ahash_final_ctx(), although a problem like this could certainly
exhibit other symptoms:
kernel BUG at arch/arm/mm/dma-mapping.c:465!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = 80004000
[00000000] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT SMP
Modules linked in:
CPU: 0 Not tainted (3.0.15-01752-gdd441b9-dirty #40)
PC is at __bug+0x1c/0x28
LR is at __bug+0x18/0x28
pc : [<80043240>] lr : [<8004323c>] psr: 60000013
sp : e423fd98 ip : 60000013 fp : 0000001c
r10: e4191b84 r9 : 00000020 r8 : 00000009
r7 : 88005038 r6 : 00000001 r5 : 2d676572 r4 : e4191a60
r3 : 00000000 r2 : 00000001 r1 : 60000093 r0 : 00000033
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c53c7d Table: 1000404a DAC: 00000015
Process cryptomgr_test (pid: 1306, stack limit = 0xe423e2f0)
Stack: (0xe423fd98 to 0xe4240000)
fd80: 11807fd1 80048544
fda0: 88005000 e4191a00 e5178040 8039dda0 00000000 00000014 2d676572 e4191008
fdc0: 88005018 e4191a60 00100100 e4191a00 00000000 8039ce0c e423fea8 00000007
fde0: e4191a00 e4227000 e5178000 8039ce18 e419183c 80203808 80a94a44 00000006
fe00: 00000000 80207180 00000000 00000006 e423ff08 00000000 00000007 e5178000
fe20: e41918a4 80a949b4 8c4844e2 00000000 00000049 74227000 8c4844e2 00000e90
fe40: 0000000e 74227e90 ffff8c58 80ac29e0 e423fed4 8006a350 8c81625c e423ff5c
fe60: 00008576 e4002500 00000003 00030010 e4002500 00000003 e5180000 e4002500
fe80: e5178000 800e6d24 007fffff 00000000 00000010 e4001280 e4002500 60000013
fea0: 000000d0 804df078 00000000 00000000 00000000 00000000 00000000 00000000
fec0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
fee0: 00000000 00000000 e4227000 e4226000 e4753000 e4752000 e40a5000 e40a4000
ff00: e41e7000 e41e6000 00000000 00000000 00000000 e423ff14 e423ff14 00000000
ff20: 00000400 804f9080 e5178000 e4db0b40 00000000 e4db0b80 0000047c 00000400
ff40: 00000000 8020758c 00000400 ffffffff 0000008a 00000000 e4db0b40 80206e00
ff60: e4049dbc 00000000 00000000 00000003 e423ffa4 80062978 e41a8bfc 00000000
ff80: 00000000 e4049db4 00000013 e4049db0 00000013 00000000 00000000 00000000
ffa0: e4db0b40 e4db0b40 80204cbc 00000013 00000000 00000000 00000000 80204cfc
ffc0: e4049da0 80089544 80040a40 00000000 e4db0b40 00000000 00000000 00000000
ffe0: e423ffe0 e423ffe0 e4049da0 800894c4 80040a40 80040a40 00000000 00000000
[<80043240>] (__bug+0x1c/0x28) from [<80048544>] (___dma_single_dev_to_cpu+0x84)
[<80048544>] (___dma_single_dev_to_cpu+0x84/0x94) from [<8039dda0>] (ahash_fina)
[<8039dda0>] (ahash_final_ctx+0x180/0x428) from [<8039ce18>] (ahash_final+0xc/0)
[<8039ce18>] (ahash_final+0xc/0x10) from [<80203808>] (crypto_ahash_op+0x28/0xc)
[<80203808>] (crypto_ahash_op+0x28/0xc0) from [<80207180>] (test_hash+0x214/0x5)
[<80207180>] (test_hash+0x214/0x5b8) from [<8020758c>] (alg_test_hash+0x68/0x8c)
[<8020758c>] (alg_test_hash+0x68/0x8c) from [<80206e00>] (alg_test+0x7c/0x1b8)
[<80206e00>] (alg_test+0x7c/0x1b8) from [<80204cfc>] (cryptomgr_test+0x40/0x48)
[<80204cfc>] (cryptomgr_test+0x40/0x48) from [<80089544>] (kthread+0x80/0x88)
[<80089544>] (kthread+0x80/0x88) from [<80040a40>] (kernel_thread_exit+0x0/0x8)
Code: e59f0010 e1a01003 eb126a8d e3a03000 (e5833000)
---[ end trace d52a403a1d1eaa86 ]---
Turns out 1366x768 does not in fact work on this hardware.
Signed-off-by: Adam Jackson <ajax@redhat.com>
This reverts commit 0aedb1626566efd72b369c01992ee7413c82a0c5.
I messed things up while applying [1] to drm-intel-fixes. Rectify.
[1] http://mid.gmane.org/1432827156-9605-1-git-send-email-ville.syrjala@linux.intel.com
Fixes: 0aedb1626566 ("drm/i915: Don't skip request retirement if the active list is empty")
Acked-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
With the introduction of multiple views of an obj in the same vm, each
vma was taught to cache its copy of the pages (so that different views
could have different page arrangements). However, this missed decoupling
those vma->ggtt_view.pages when the vma released its reference on the
obj->pages. As we don't always free the vma, this leads to a possible
scenario (e.g. execbuffer interrupted by the shrinker) where the vma
points to a stale obj->pages, and explodes.
Fixes regression from commit fe14d5f4e5468c5b80a24f1a64abcbe116143670
Author: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Date: Wed Dec 10 17:27:58 2014 +0000
drm/i915: Infrastructure for supporting different GGTT views per object
Tvrtko says, if someone else will be confused how this can happen, key
is the reservation execbuffer path. That puts the VMA on the exec_list
which prevents i915_vma_unbind and i915_gem_vma_destroy from fully
destroying the VMA. So the VMA is left existing as an empty object in
the list - unbound and disassociated with the backing store. Kind of a
cached memory object. And then re-using it needs to clear the cached
pages pointer which is fixed above.
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1227892
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Michel Thierry <michel.thierry@intel.com>
Reviewed-by: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
[Jani: Added Tvrtko's explanation to commit message.]
Pull dmaengine fixes from Vinod Koul:
"Here are hopefully last set of fixes for 4.1. This time we have:
- fixing pause capability reporting on both dmaengine pause & resume
support by Krzysztof
- locking fix fir at_xdmac by Ludovic
- slave configuration fix for at_xdmac by Ludovic"
* 'fixes' of git://git.infradead.org/users/vkoul/slave-dma:
dmaengine: Fix choppy sound because of unimplemented resume
dmaengine: at_xdmac: rework slave configuration part
dmaengine: at_xdmac: lock fixes
Pull NTB fixes from Jon Mason:
"I apologize for the tardiness of this request. Here are a couple of
last minute NTB bug fixes for v4.1:
NTB bug fixes to address issues in unmapping the MW reg base and
vbase, and an uninitialized variable on Atom platforms"
* tag 'ntb-4.1' of git://github.com/jonmason/ntb:
ntb: initialize max_mw for Atom before using it
ntb: iounmap MW reg and vbase in error path
Pull more MIPS fixes from Ralf Baechle:
"Another round of 4.1 MIPS fixes, one fix to a MIPS-specific #if
condition in lib/mpi, one fix to the MIPS GIC irqchip driver and one
SSB fix.
Details:
- fix handling of clock in chipco SSB driver.
- fix two MIPS-specific #if conditions to correctly work for GCC 5.1.
- fix damage to R6 pgtable bits done by XPA support.
- fix possible crash due to unloading modules that contain statically
defined platform devices.
- fix disabling of the MSA ASE on context switch to also work
correctly when a new thread/process has the CPU for the very first
time.
This is part of linux-next and has been beaten to death on
Imagination's test farm.
While things are not looking too grim this pull request also means the
rate of fixes for 4.1 remains nearly constant so I'd not be unhappy if
you'd delay the release"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus:
MPI: MIPS: Fix compilation error with GCC 5.1
IRQCHIP: mips-gic: Don't nest calls to do_IRQ()
MIPS: MSA: bugfix - disable MSA correctly for new threads/processes.
MIPS: Loongson: Do not register 8250 platform device from module.
MIPS: Cobalt: Do not build MTD platform device registration code as module.
SSB: Fix handling of ssb_pmu_get_alp_clock()
MIPS: pgtable-bits: Fix XPA damage to R6 definitions.
Pull irqchip fix from Thomas Gleixner:
"A single fix for an off by one bug in the sunxi irqchip driver"
* 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip: sunxi-nmi: Fix off-by-one error in irq iterator
The GIC chained handlers use do_IRQ() to call the subhandlers. This
means that irq_enter() calls get nested, which leads to preempt count
looking like we're in nested interrupts, which in turn leads to all
system time being accounted as IRQ time in account_system_time().
Fix it by using generic_handle_irq(). Since these same functions are
used in some systems (if cpu_has_veic) from a low-level vectored
interrupt handler which does not go throught do_IRQ(), we need to do it
conditionally.
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
Reviewed-by: Andrew Bresticker <abrestic@chromium.org>
Cc: linux-mips@linux-mips.org
Cc: tglx@linutronix.de
Cc: jason@lakedaemon.net
Patchwork: https://patchwork.linux-mips.org/patch/10545/
Pull networking fixes from David Miller:
1) Fix uninitialized struct station_info in cfg80211_wireless_stats(),
from Johannes Berg.
2) Revert commit attempt to fix ipv6 protocol resubmission, it adds
regressions.
3) Endless loops can be created in bridge port lists, fix from Nikolay
Aleksandrov.
4) Don't WARN_ON() if sk->sk_forward_alloc is non-zero in
sk_clear_memalloc, it is a legal situation during swap deactivation.
Fix from Mel Gorman.
5) Fix order of disabling interrupts and unlocking NAPI in enic driver
to avoid a race. From Govindarajulu Varadarajan.
6) High and low register writes are swapped when programming the start
of periodic output in igb driver. From Richard Cochran.
7) Fix device rename handling in mpls stack, from Robert Shearman.
8) Do not trigger compaction synchronously when optimistically trying
to allocate an order 3 page in alloc_skb_with_frags() and
skb_page_frag_refill(). From Shaohua Li.
9) Authentication with COOKIE_ECHO is not handled properly in SCTP, fix
from Marcelo Ricardo Leitner.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net:
Doc: networking: Fix URL for wiki.wireshark.org in udplite.txt
sctp: allow authenticating DATA chunks that are bundled with COOKIE_ECHO
net: don't wait for order-3 page allocation
mpls: handle device renames for per-device sysctls
net: igb: fix the start time for periodic output signals
enic: fix memory leak in rq_clean
enic: check return value for stat dump
enic: unlock napi busy poll before unmasking intr
net, swap: Remove a warning and clarify why sk_mem_reclaim is required when deactivating swap
bridge: fix multicast router rlist endless loop
tipc: disconnect socket directly after probe failure
Revert "ipv6: Fix protocol resubmission"
cfg80211: wext: clear sinfo struct before calling driver
Pull block layer fixes from Jens Axboe:
"Remember about a week ago when I sent the last pull request for 4.1?
Well, I lied. Now, I don't want to shift the blame, but Dan, Ming,
and Richard made a liar out of me.
Here are three small patches that should go into 4.1. More
specifically, this pull request contains:
- A Kconfig dependency for the pmem block driver, so it can't be
selected if HAS_IOMEM isn't availble. From Richard Weinberger.
- A fix for genhd, making the ext_devt_lock softirq safe. This makes
lockdep happier, since we also end up grabbing this lock on release
off the softirq path. From Dan Williams.
- A blk-mq software queue release fix from Ming Lei.
Last two are headed to stable, first fixes an issue introduced in this
cycle"
* 'for-linus' of git://git.kernel.dk/linux-block:
block: pmem: Add dependency on HAS_IOMEM
block: fix ext_dev_lock lockdep report
blk-mq: free hctx->ctxs in queue's release handler
Pull three more md fixes from Neil Brown:
"Hasn't been a good cycle for md has it :-(
The main issue fixed here is a rare race which can result in two
reshape threads running at once, which doesn't end well.
Also a minor issue with a write to a sysfs file returning the wrong
value. Backports to 4.0-stable are indicated"
* tag 'md/4.1-rc7-fixes' of git://neil.brown.name/md:
md: make sure MD_RECOVERY_DONE is clear before starting recovery/resync
md: Close race when setting 'action' to 'idle'.
md: don't return 0 from array_state_store
Pull VT-d hardware workarounds from David Woodhouse:
"This contains a workaround for hardware issues which I *thought* were
never going to be seen on production hardware. I'm glad I checked
that before the 4.1 release...
Firstly, PASID support is so broken on existing chips that we're just
going to declare the old capability bit 28 as 'reserved' and change
the VT-d spec to move PASID support to another bit. So any existing
hardware doesn't support SVM; it only sets that (now) meaningless bit
28.
That patch *wasn't* imperative for 4.1 because we don't have PASID
support yet. But *even* the extended context tables are broken — if
you just enable the wider tables and use none of the new bits in them,
which is precisely what 4.1 does, you find that translations don't
work. It's this problem which I thought was caught in time to be
fixed before production, but wasn't.
To avoid triggering this issue, we now *only* enable the extended
context tables on hardware which also advertises "we have PASID
support and we actually tested it this time" with the new PASID
feature bit.
In addition, I've added an 'intel_iommu=ecs_off' command line
parameter to allow us to disable it manually if we need to"
* git://git.infradead.org/intel-iommu:
iommu/vt-d: Only enable extended context tables if PASID is supported
iommu/vt-d: Change PASID support to bit 40 of Extended Capability Register
Although the extended tables are theoretically a completely orthogonal
feature to PASID and anything else that *uses* the newly-available bits,
some of the early hardware has problems even when all we do is enable
them and use only the same bits that were in the old context tables.
For now, there's no motivation to support extended tables unless we're
going to use PASID support to do SVM. So just don't use them unless
PASID support is advertised too. Also add a command-line bailout just in
case later chips also have issues.
The equivalent problem for PASID support has already been fixed with the
upcoming VT-d spec update and commit bd00c606a ("iommu/vt-d: Change
PASID support to bit 40 of Extended Capability Register"), because the
problematic platforms use the old definition of the PASID-capable bit,
which is now marked as reserved and meaningless.
So with this change, we'll magically start using ECS again only when we
see the new hardware advertising "hey, we have PASID support and we
actually tested it this time" on bit 40.
The VT-d hardware architect has promised that we are not going to have
any reason to support ECS *without* PASID any time soon, and he'll make
sure he checks with us before changing that.
In the future, if hypothetical new features also use new bits in the
context tables and can be seen on implementations *without* PASID support,
we might need to add their feature bits to the ecs_enabled() macro.
MD_RECOVERY_DONE is normally cleared by md_check_recovery after a
resync etc finished. However it is possible for raid5_start_reshape
to race and start a reshape before MD_RECOVERY_DONE is cleared. This
can lean to multiple reshapes running at the same time, which isn't
good.
To make sure it is cleared before starting a reshape, and also clear
it when reaping a thread, just to be safe.
Signed-off-by: NeilBrown <neilb@suse.de>
Checking ->sync_thread without holding the mddev_lock()
isn't really safe, even after flushing the workqueue which
ensures md_start_sync() has been run.
While this code is waiting for the lock, md_check_recovery could reap
the thread itself, and then start another thread (e.g. recovery might
finish, then reshape starts). When this thread gets the lock
md_start_sync() hasn't run so it doesn't get reaped, but
MD_RECOVERY_RUNNING gets cleared. This allows two threads to start
which leads to confusion.
So don't both if MD_RECOVERY_RUNNING isn't set, but if it is do
the flush and the test and the reap all under the mddev_lock to
avoid any race with md_check_recovery.
Fixes: 6791875e2e53 ("md: make reconfig_mutex optional for writes to md sysfs files.")
Cc: stable@vger.kernel.org (v4.0+)
Returning zero from a 'store' function is bad.
The return value should be either len length of the string
or an error.
So use 'len' if 'err' is zero.
Cc: stable@vger.kernel (v4.0+)
Some drivers implement only pause operation (no resuming). Example is
pl330 where pause is needed for getting residuum. pl330 does not support
resume operation, transfer must be stopped after pause.
However for slaves this is exposed always as "pause and resume" which
introduces subtle errors on Odroid U3 board (Exynos4412 with pl330).
After adding pause function to pl330 driver the audio playback
(utilizing DMA) gets choppy after some time (approximately 24 hours).
Fix this by exposing "cmd_pause" if and only if pause and resume are
implemented.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reported-by: gabriel@unseen.is
Reported-by: Marek Szyprowski <m.szyprowski@samsung.com>
Fixes: 88987d2c7534 ("dmaengine: pl330: add DMA_PAUSE feature")
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
Fix for the regression Linus called out, and another for probing
dongles.
* tag 'drm-intel-fixes-2015-06-11' of git://anongit.freedesktop.org/drm-intel:
drm/i915: Fix DDC probe for passive adapters
drm/i915: Properly initialize SDVO analog connectors
into drm-fixes
Two regression reverts, and two fixes, one for a dpm boot freeze.
* 'drm-fixes-4.1' of git://people.freedesktop.org/~agd5f/linux:
drm/radeon: Make sure radeon_vm_bo_set_addr always unreserves the BO
Revert "drm/radeon: adjust pll when audio is not enabled"
Revert "drm/radeon: don't share plls if monitors differ in audio support"
drm/radeon: fix freeze for laptop with Turks/Thames GPU.
When programming the start of a periodic output, the code wrongly places
the seconds value into the "low" register and the nanoseconds into the
"high" register. Even though this is backwards, it slipped through my
testing, because the re-arming code in the interrupt service routine is
correct, and the signal does appear starting with the second edge.
This patch fixes the issue by programming the registers correctly.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
Reviewed-by: Jacob Keller <jacob.e.keller@intel.com>
Acked-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Not all architectures have io memory.
Fixes:
drivers/block/pmem.c: In function ‘pmem_alloc’:
drivers/block/pmem.c:146:2: error: implicit declaration of function ‘ioremap_nocache’ [-Werror=implicit-function-declaration]
pmem->virt_addr = ioremap_nocache(pmem->phys_addr, pmem->size);
drivers/block/pmem.c:146:18: warning: assignment makes pointer from integer without a cast [enabled by default]
drivers/block/pmem.c:182:2: error: implicit declaration of function ‘iounmap’ [-Werror=implicit-function-declaration]
iounmap(pmem->virt_addr);
Signed-off-by: Richard Weinberger <richard@nod.at>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
Some error paths didn't unreserve the BO. This resulted in a deadlock
down the road on the next attempt to reserve the (still reserved) BO.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=90873
Reviewed-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
This reverts commit 7fe04d6fa824ccea704535a597dc417c8687f990.
Fixes some systems at the expense of others. Need to properly
fix the pll divider selection.
bug:
https://bugzilla.kernel.org/show_bug.cgi?id=99651
This reverts commit a10f0df0615abb194968fc08147f3cdd70fd5aa5.
bug:
Laptop with Turks/Thames GPU will freeze if dpm is enabled. It seems
the SMC engine is relying on some state inside the CP engine. CP needs
to chew at least one packet for it to get in good state for dynamic
power management.
This patch simply disabled and re-enable DPM after the ring test which
is enough to avoid the freeze.
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
Commit ab760a0 (ntb: Adding split BAR support for Haswell platforms)
changed ntb_device's mw from a fixed-size array into a pointer that is
allocated based on limits.max_mw; however, on Atom platforms, max_mw
is not initialized until ntb_device_setup(), which happens after the
allocation.
Fill out max_mw in ntb_atom_detect() to match ntb_xeon_detect(); this
happens before the use of max_mw in the ndev->mw allocation.
Fixes a null pointer dereference on Atom platforms with ntb hardware.
v2: fix typo (mw_max should be max_mw)
Signed-off-by: Daniel Verkamp <daniel.verkamp@intel.com>
Acked-by: Dave Jiang <dave.jiang@intel.com>
Signed-off-by: Jon Mason <jdmason@kudzu.us>
When incoming packet qualifies for rx_copybreak, we copy the data to newly
allocated skb. We do not free/unmap the original buffer. At this point driver
assumes this buffer is unallocated. When enic_rq_alloc_buf() is called for
buffer allocation, it checks if buf->os_buf is NULL. If its not NULL that means
buffer can be re-used.
When vnic_rq_clean() is called for freeing all rq buffers, and if the
rx_copybreak reused buffer falls outside the used desc, we do not free the
buffer. The following trace is observer when dma-debug is enabled.
Fix is to walk through complete ring and clean if buffer is present.
[ 40.555386] ------------[ cut here ]------------
[ 40.555396] WARNING: CPU: 0 PID: 491 at lib/dma-debug.c:971 dma_debug_device_change+0x188/0x1f0()
[ 40.555400] pci 0000:06:00.0: DMA-API: device driver has pending DMA allocations while released from device [count=4]
One of leaked entries details: [device address=0x00000000ff4cc040] [size=9018 bytes] [mapped with DMA_FROM_DEVICE] [mapped as single]
[ 40.555402] Modules linked in: nfsv3 nfs_acl rpcsec_gss_krb5 auth_rpcgss oid_registry nfsv4 dns_resolver coretemp intel_rapl iosf_mbi x86_pkg_temp_thermal intel_powerclamp kvm_intel kvm crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel aes_x86_64 lrw joydev mousedev gf128mul hid_generic glue_helper mgag200 usbhid ttm hid drm_kms_helper drm ablk_helper syscopyarea sysfillrect sysimgblt i2c_algo_bit i2c_core iTCO_wdt cryptd mac_hid evdev pcspkr sb_edac edac_core tpm_tis iTCO_vendor_support ipmi_si wmi tpm ipmi_msghandler shpchp lpc_ich processor acpi_power_meter hwmon button ac sch_fq_codel nfs lockd grace sunrpc fscache sd_mod ehci_pci ehci_hcd megaraid_sas usbcore scsi_mod usb_common enic(-) crc32c_generic crc32c_intel btrfs xor raid6_pq ext4 crc16 mbcache jbd2
[ 40.555467] CPU: 0 PID: 491 Comm: rmmod Not tainted 4.1.0-rc7-ARCH-01305-gf59b71f #118
[ 40.555469] Hardware name: Cisco Systems Inc UCSB-B200-M4/UCSB-B200-M4, BIOS B200M4.2.2.2.23.061220140128 06/12/2014
[ 40.555471] 0000000000000000 00000000e2f8a5b7 ffff880275f8bc48 ffffffff8158d6f0
[ 40.555474] 0000000000000000 ffff880275f8bca0 ffff880275f8bc88 ffffffff8107b04a
[ 40.555477] ffff8802734e0000 0000000000000004 ffff8804763fb3c0 ffff88027600b650
[ 40.555480] Call Trace:
[ 40.555488] [<ffffffff8158d6f0>] dump_stack+0x4f/0x7b
[ 40.555492] [<ffffffff8107b04a>] warn_slowpath_common+0x8a/0xc0
[ 40.555494] [<ffffffff8107b0d5>] warn_slowpath_fmt+0x55/0x70
[ 40.555498] [<ffffffff812fa408>] dma_debug_device_change+0x188/0x1f0
[ 40.555503] [<ffffffff8109aaef>] notifier_call_chain+0x4f/0x80
[ 40.555506] [<ffffffff8109aecb>] __blocking_notifier_call_chain+0x4b/0x70
[ 40.555510] [<ffffffff8109af06>] blocking_notifier_call_chain+0x16/0x20
[ 40.555514] [<ffffffff813f8066>] __device_release_driver+0xf6/0x120
[ 40.555518] [<ffffffff813f8b08>] driver_detach+0xc8/0xd0
[ 40.555523] [<ffffffff813f7c59>] bus_remove_driver+0x59/0xe0
[ 40.555527] [<ffffffff813f93a0>] driver_unregister+0x30/0x70
[ 40.555534] [<ffffffff8131532d>] pci_unregister_driver+0x2d/0xa0
[ 40.555542] [<ffffffffa0200ec2>] enic_cleanup_module+0x10/0x14e [enic]
[ 40.555547] [<ffffffff8110158f>] SyS_delete_module+0x1cf/0x280
[ 40.555551] [<ffffffff811e284e>] ? ____fput+0xe/0x10
[ 40.555554] [<ffffffff810980ec>] ? task_work_run+0xbc/0xf0
[ 40.555558] [<ffffffff815930ee>] system_call_fastpath+0x12/0x71
[ 40.555561] ---[ end trace 4988cadc77c2b236 ]---
[ 40.555562] Mapped at:
[ 40.555563] [<ffffffff812fa865>] debug_dma_map_page+0x95/0x150
[ 40.555566] [<ffffffffa01f4a88>] enic_rq_alloc_buf+0x1b8/0x360 [enic]
[ 40.555570] [<ffffffffa01f7658>] enic_open+0xf8/0x820 [enic]
[ 40.555574] [<ffffffff8148d50e>] __dev_open+0xce/0x150
[ 40.555579] [<ffffffff8148d851>] __dev_change_flags+0xa1/0x170
Signed-off-by: Govindarajulu Varadarajan <_govind@gmx.com>
We do not check the return value of enic_dev_stats_dump(). If allocation
fails, we will hit NULL pointer reference.
Return only if memory allocation fails. For other failures, we return the
previously recorded values.
There is a small window between vnic_intr_unmask() and enic_poll_unlock_napi().
In this window if an irq occurs and napi is scheduled on different cpu, it tries
to acquire enic_poll_lock_napi() and hits the following WARN_ON message.
Fix is to unlock napi_poll before unmasking the interrupt.
[ 781.121746] ------------[ cut here ]------------
[ 781.121789] WARNING: CPU: 1 PID: 0 at drivers/net/ethernet/cisco/enic/vnic_rq.h:228 enic_poll_msix_rq+0x36a/0x3c0 [enic]()
[ 781.121834] Modules linked in: nfsv3 nfs_acl rpcsec_gss_krb5 auth_rpcgss oid_registry nfsv4 dns_resolver coretemp intel_rapl iosf_mbi x86_pkg_temp_thermal intel_powerclamp kvm_intel kvm crct10dif_pclmul crc32_pclmul ghash_clmulni_intel aesni_intel mgag200 ttm drm_kms_helper joydev aes_x86_64 lrw drm gf128mul mousedev glue_helper sb_edac ablk_helper iTCO_wdt iTCO_vendor_support evdev ipmi_si syscopyarea sysfillrect sysimgblt i2c_algo_bit i2c_core edac_core lpc_ich mac_hid cryptd pcspkr ipmi_msghandler shpchp tpm_tis acpi_power_meter tpm wmi processor hwmon button ac sch_fq_codel nfs lockd grace sunrpc fscache hid_generic usbhid hid ehci_pci ehci_hcd sd_mod megaraid_sas usbcore scsi_mod usb_common enic crc32c_generic crc32c_intel btrfs xor raid6_pq ext4 crc16 mbcache jbd2
[ 781.122176] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.1.0-rc6-ARCH-00040-gc46a024-dirty #106
[ 781.122210] Hardware name: Cisco Systems Inc UCSB-B200-M4/UCSB-B200-M4, BIOS B200M4.2.2.2.23.061220140128 06/12/2014
[ 781.122252] 0000000000000000 bddbbc9d655ec96e ffff880277e43da8 ffffffff81583fe8
[ 781.122286] 0000000000000000 0000000000000000 ffff880277e43de8 ffffffff8107acfa
[ 781.122319] ffff880272c01000 ffff880273f18000 ffff880273f1a100 0000000000000000
[ 781.122352] Call Trace:
[ 781.122364] <IRQ> [<ffffffff81583fe8>] dump_stack+0x4f/0x7b
[ 781.122399] [<ffffffff8107acfa>] warn_slowpath_common+0x8a/0xc0
[ 781.122425] [<ffffffff8107ae2a>] warn_slowpath_null+0x1a/0x20
[ 781.122455] [<ffffffffa01fa9ca>] enic_poll_msix_rq+0x36a/0x3c0 [enic]
[ 781.122487] [<ffffffff8148525a>] net_rx_action+0x22a/0x370
[ 781.122512] [<ffffffff8107ed3d>] __do_softirq+0xed/0x2d0
[ 781.122537] [<ffffffff8107f06e>] irq_exit+0x7e/0xa0
[ 781.122560] [<ffffffff8158c424>] do_IRQ+0x64/0x100
[ 781.122582] [<ffffffff8158a42e>] common_interrupt+0x6e/0x6e
[ 781.122605] <EOI> [<ffffffff810bd331>] ? cpu_startup_entry+0x121/0x480
[ 781.122638] [<ffffffff810bd2fc>] ? cpu_startup_entry+0xec/0x480
[ 781.122667] [<ffffffff810f2ed3>] ? clockevents_register_device+0x113/0x1f0
[ 781.122698] [<ffffffff81050ab6>] start_secondary+0x196/0x1e0
[ 781.122723] ---[ end trace cec2e9dd3af7b9db ]---
Merge misc fixes from Andrew Morton:
"The gcc-4.4.4 workaround has actually been merged into a KVM tree by
Paolo but it is stuck in linux-next and mainline needs it"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
arch/x86/kvm/mmu.c: work around gcc-4.4.4 bug
sched, numa: do not hint for NUMA balancing on VM_MIXEDMAP mappings
zsmalloc: fix a null pointer dereference in destroy_handle_cache()
mm: memcontrol: fix false-positive VM_BUG_ON() on -rt
checkpatch: fix "GLOBAL_INITIALISERS" test
zram: clear disk io accounting when reset zram device
memcg: do not call reclaim if !__GFP_WAIT
mm/memory_hotplug.c: set zone->wait_table to null after freeing it
Clear zram disk io accounting when resetting the zram device. Otherwise
the residual io accounting stat will affect the diskstat in the next
zram active cycle.
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
Acked-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Acked-by: Minchan Kim <minchan@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input layer fix from Dmitry Torokhov:
"A small tweak for the Synaptics PS/2 touchpad driver"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: synaptics - add min/max quirk for Lenovo S540
Dan Carpenter reported missing brackets which resulted in reading a
wrong crystalfreq value. I also noticed that the result of this
function is ignored.
Reported-By: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Signed-off-by: Michael Buesch <m@bues.ch>
Cc: davem@davemloft.net
Cc: netdev@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/10536/
Passive DP->DVI/HDMI dongles on DP++ ports show up to the system as HDMI
devices, as they do not have a sink device in them to respond to any AUX
traffic. When probing these dongles over the DDC, sometimes they will
NAK the first attempt even though the transaction is valid and they
support the DDC protocol. The retry loop inside of
drm_do_probe_ddc_edid() would normally catch this case and try the
transaction again, resulting in success.
That, however, was thwarted by the fix for [1]:
commit 9292f37e1f5c79400254dca46f83313488093825
Author: Eugeni Dodonov <eugeni.dodonov@intel.com>
Date: Thu Jan 5 09:34:28 2012 -0200
drm: give up on edid retries when i2c bus is not responding
This added code to exit immediately if the return code from the
i2c_transfer function was -ENXIO in order to reduce the amount of time
spent in waiting for unresponsive or disconnected devices. That was
possible because the underlying i2c bit banging algorithm had retries of
its own (which, of course, were part of the reason for the bug the
commit fixes).
Since its introduction in
commit f899fc64cda8569d0529452aafc0da31c042df2e
Author: Chris Wilson <chris@chris-wilson.co.uk>
Date: Tue Jul 20 15:44:45 2010 -0700
drm/i915: use GMBUS to manage i2c links
we've been flipping back and forth enabling the GMBUS transfers, but
we've settled since then. The GMBUS implementation does not do any
retries, however, bailing out of the drm_do_probe_ddc_edid() retry loop
on first encounter of -ENXIO. This, combined with Eugeni's commit, broke
the retry on -ENXIO.
Retry GMBUS once on -ENXIO on first message to mitigate the issues with
passive adapters.
This patch is based on the work, and commit message, by Todd Previte
<tprevite@gmail.com>.
[1] https://bugs.freedesktop.org/show_bug.cgi?id=41059
v2: Don't retry if using bit banging.
v3: Move retry within gmbux_xfer, retry only on first message.
v4: Initialize GMBUS0 on retry (Ville).
v5: Take index reads into account (Ville).
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=85924
Cc: Todd Previte <tprevite@gmail.com>
Tested-by: Oliver Grafe <oliver.grafe@ge.com> (v2)
Tested-by: Jim Bride <jim.bride@linux.intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
iser connection termination process happens in 2 stages:
- isert_wait_conn:
- resumes rdma disconnect
- wait for session commands
- wait for flush completions (post a marked wr to signal we are done)
- wait for logout completion
- queue work for connection cleanup (depends on disconnected/timewait
events)
- isert_free_conn
- last reference put on the connection
In case we are terminating during IOs, we might be posting send/recv
requests after we posted the last work request which might lead
to a use-after-free condition in isert_handle_wc.
After we posted the last wr in isert_wait_conn we are guaranteed that
no successful completions will follow (meaning no new work request posts
may happen) but other flush errors might still come. So before we
put the last reference on the connection, we repeat the process of
posting a marked work request (isert_wait4flush) in order to make sure all
pending completions were flushed.
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
Signed-off-by: Jenny Falkovich <jennyf@mellanox.com>
Cc: stable@vger.kernel.org # 3.10+
When receiving a new iser connect request we serialize
the pending requests by adding the newly created iser connection
to the np accept list and let the login thread process the connect
request one by one (np_accept_wait).
In case we received a disconnect request before the iser_conn
has begun processing (still linked in np_accept_list) we should
detach it from the list and clean it up and not have the login
thread process a stale connection. We do it only when the connection
state is not already terminating (initiator driven disconnect) as
this might lead us to access np_accept_mutex after the np was released
in live shutdown scenarios.
