commit 9aa5b0181bdf335f0b731d8502e128a862884bcd upstream.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=60772
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reported-by: Leho Kraav <leho@kraav.com>
commit 3b59d16c513da258ec8f6a0b4db85f257a0380d6 upstream.
Signed-off-by: David Cluytens <david.cluytens@gmail.com>
commit 711fbdfbf2bc4827214a650afe3f64767a1aba16 upstream.
This patch removes an erroneous check of CSIZE, which made it impossible to set
CS5.
Compiles clean, but couldn't test against hardware.
Signed-off-by: Colin Leitner <colin.leitner@gmail.com>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 78692cc3382e0603a47e1f2aaeffe0d99891994d upstream.
CS5.
commit a313249937820f8b1996133fc285efbd6aad2c5b upstream.
This patch fixes the CS5 setting on the PL2303 USB-to-serial devices. CS5 has a
value of 0 and the CSIZE setting has been skipped altogether by the enclosing
if. Tested on 3.11.6 and the scope shows the correct output after the fix has
been applied.
Tagged to be added to stable, because it fixes a user visible driver bug and is
simple enough to backport easily.
commit c2db409cbc8751ccc7e6d2cc2e41af0d12ea637f upstream.
This patch adds the PCU SMBus DeviceID for the Intel Avoton SOC.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
Reviewed-by: Jean Delvare <khali@linux-fr.org>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: "Ong, Boon Leong" <boon.leong.ong@intel.com>
commit 29e674dd5c8e781589f09c3ee139c80f6da274e4 upstream.
This patch adds the AHCI and RAID-mode SATA DeviceIDs for the Intel Avoton SOC.
Cc: Ong Boon Leong <boon.leong.ong@intel.com>
commit 77b12bc9cf7b10c7c1a04ca45272fbb4287902d0 upstream.
This patch adds the AHCI-mode SATA Device IDs for the Intel Lynx Point-LP PCH
Signed-off-by: James Ralston <james.d.ralston@intel.com>
commit dfaaed08ecc01bd513248ba7999daf50ce028352 upstream.
Moust (if not all) modern software, including X, uses /dev/eventX rather than
the legacy /dev/mouseX devices. It therefore makes sense for general-purpose
(distro) kernels to use MOUSEDV=m (or even n), so let's drop the EXPERT=y
requirement.
Signed-off-by: Tom Gundersen <teg@jklm.no>
commit bcd2623073e98f69f84720308db0b142c4da0bd6 upstream.
There is plenty of consumer hardware (e.g., mac books) that does not use AT
keyboards or PS/2 mice. It therefore makes sense for distro kernels to
build the related drivers as modules to avoid loading them on hardware that
does not need them. As such, these options should no longer be protected by
EXPERT.
Moreover, building these drivers as modules gets rid of the following ugly
error during boot:
[ 2.337745] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 3.439537] i8042: No controller found
commit 1aeef303b5d9e243c41d5b80f8bb059366514a10 upstream.
For MPC8572/MPC8536, the status of GPIOs defined as output
cannot be determined by reading GPDAT register, so the code
use shadow data register instead. But the code may give the
wrong status of GPIOs defined as input under some scenarios:
1. If some pins were configured as inputs and were asserted
high before booting the kernel, the shadow data has been
initialized with those pin values.
2. Some pins have been configured as output first and have
been set to the high value, then reconfigured as input.
The above cases will make the shadow data for those input
pins to be set to high. Then reading the pin status will
always return high even if the actual pin status is low.
The code should eliminate the effects of the shadow data to
the input pins, and the status of those pins should be
read directly from GPDAT.
Acked-by: Scott Wood <scottwood@freescale.com>
Acked-by: Anatolij Gustschin <agust@denx.de>
Signed-off-by: Liu Gang <Gang.Liu@freescale.com>
commit a0c20fb02592d372e744d1d739cda3e1b3defaae upstream.
After commit e9e4ea74f06635f2ffc1dffe5ef40c854faa0a90
"net: smc91x: dont't use SMC_outw for fixing up halfword-aligned data"
The Versatile SMSC LAN91C111 is crashing like this:
kernel BUG at /home/linus/linux/drivers/net/ethernet/smsc/smc91x.c:599!
Internal error: Oops - BUG: 0 [#1] ARM
Modules linked in:
CPU: 0 PID: 43 Comm: udhcpc Not tainted 3.13.0-rc1+ #24
task: c6ccfaa0 ti: c6cd0000 task.ti: c6cd0000
PC is at smc_hardware_send_pkt+0x198/0x22c
LR is at smc_hardware_send_pkt+0x24/0x22c
pc : [<c01be324>] lr : [<c01be1b0>] psr: 20000013
sp : c6cd1d08 ip : 00000001 fp : 00000000
r10: c02adb08 r9 : 00000000 r8 : c6ced802
r7 : c786fba0 r6 : 00000146 r5 : c8800000 r4 : c78d6000
r3 : 0000000f r2 : 00000146 r1 : 00000000 r0 : 00000031
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 0005317f Table: 06cf4000 DAC: 00000015
Process udhcpc (pid: 43, stack limit = 0xc6cd01c0)
Stack: (0xc6cd1d08 to 0xc6cd2000)
1d00: 00000010 c8800000 c78d6000 c786fba0 c78d6000 c01be868
1d20: c01be7a4 00004000 00000000 c786fba0 c6c12b80 c0208554 000004d0 c780fc60
1d40: 00000220 c01fb734 00000000 00000000 00000000 c6c9a440 c6c12b80 c78d6000
1d60: c786fba0 c6c9a440 00000000 c021d1d8 00000000 00000000 c6c12b80 c78d6000
1d80: c786fba0 00000001 c6c9a440 c02087f8 c6c9a4a0 00080008 00000000 00000000
1da0: c78d6000 c786fba0 c78d6000 00000138 00000000 00000000 00000000 00000000
1dc0: 00000000 c027ba74 00000138 00000138 00000001 00000010 c6cedc00 00000000
1de0: 00000008 c7404400 c6cd1eec c6cd1f14 c067a73c c065c0b8 00000000 c067a740
1e00: 01ffffff 002040d0 00000000 00000000 00000000 00000000 00000000 ffffffff
1e20: 43004400 00110022 c6cdef20 c027ae8c c6ccfaa0 be82d65c 00000014 be82d3cc
1e40: 00000000 00000000 00000000 c01f2870 00000000 00000000 00000000 c6cd1e88
1e60: c6ccfaa0 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1e80: 00000000 00000000 00000031 c7802310 c7802300 00000138 c7404400 c0771da0
1ea0: 00000000 c6cd1eec c7800340 00000138 be82d65c 00000014 be82d3cc c6cd1f08
1ec0: 00000014 00000000 c7404400 c7404400 00000138 c01f4628 c78d6000 00000000
1ee0: 00000000 be82d3cc 00000138 c6cd1f08 00000014 c6cd1ee4 00000001 00000000
1f00: 00000000 00000000 00080011 00000002 06000000 ffffffff 0000ffff 00000002
1f20: 06000000 ffffffff 0000ffff c00928c8 c065c520 c6cd1f58 00000003 c009299c
1f40: 00000003 c065c520 c7404400 00000000 c7404400 c01f2218 c78106b0 c7441cb0
1f60: 00000000 00000006 c06799fc 00000000 00000000 00000006 00000000 c01f3ee0
1f80: 00000000 00000000 be82d678 be82d65c 00000014 00000001 00000122 c00139c8
1fa0: c6cd0000 c0013840 be82d65c 00000014 00000006 be82d3cc 00000138 00000000
1fc0: be82d65c 00000014 00000001 00000122 00000000 00000000 00018cb1 00000000
1fe0: 00003801 be82d3a8 0003a0c7 b6e9af08 60000010 00000006 00000000 00000000
[<c01be324>] (smc_hardware_send_pkt+0x198/0x22c) from [<c01be868>] (smc_hard_start_xmit+0xc4/0x1e8)
[<c01be868>] (smc_hard_start_xmit+0xc4/0x1e8) from [<c0208554>] (dev_hard_start_xmit+0x460/0x4cc)
[<c0208554>] (dev_hard_start_xmit+0x460/0x4cc) from [<c021d1d8>] (sch_direct_xmit+0x94/0x18c)
[<c021d1d8>] (sch_direct_xmit+0x94/0x18c) from [<c02087f8>] (dev_queue_xmit+0x238/0x42c)
[<c02087f8>] (dev_queue_xmit+0x238/0x42c) from [<c027ba74>] (packet_sendmsg+0xbe8/0xd28)
[<c027ba74>] (packet_sendmsg+0xbe8/0xd28) from [<c01f2870>] (sock_sendmsg+0x84/0xa8)
[<c01f2870>] (sock_sendmsg+0x84/0xa8) from [<c01f4628>] (SyS_sendto+0xb8/0xdc)
[<c01f4628>] (SyS_sendto+0xb8/0xdc) from [<c0013840>] (ret_fast_syscall+0x0/0x2c)
Code: e3130002 1a000001 e3130001 0affffcd (e7f001f2)
---[ end trace 81104fe70e8da7fe ]---
Kernel panic - not syncing: Fatal exception in interrupt
This is because the macro operations in smc91x.h defined
for Versatile are missing SMC_outsw() as used in this
commit.
The Versatile needs and uses the same accessors as the other
platforms in the first if(...) clause, just switch it to using
that and we have one problem less to worry about.
This includes a hunk of a patch from Will Deacon fixin
the other 32bit platforms as well: Innokom, Ramses, PXA,
PCM027.
Checkpatch complains about spacing, but I have opted to
follow the style of this .h-file.
Cc: Nicolas Pitre <nico@fluxnic.net>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jonathan Cameron <jic23@cam.ac.uk>
commit 88bf6d62db4393fa03a58bada9d746312d5b496f upstream.
A return value of 1 is interpreted as an error. See pci_driver.
in local_pci_probe(). If you're wondering how this ever could
have worked, it's because it used to be the case that only return
values less than zero were interpreted as failure. But even in
the current kernel if the driver registers its various entry
points with the kernel, and then returns a value which is
interpreted as failure, those registrations aren't undone, so
the driver still mostly works. However, the driver's remove
function wouldn't be called on rmmod, and pci power management
functions wouldn't work. In the case of Smart Array, since it
has a battery backed cache (or else no cache) even if the driver
is not shut down properly as long as there is no outstanding
i/o, nothing too bad happens, which is why it took so long to
notice.
Requesting backport to stable because the change to pci-driver.c
which requires driver probe functions to return 0 occurred between
2.6.35 and 2.6.36 (the pci power management breakage) and again
between 3.7 and 3.8 (pci_dev->driver getting set to NULL in
local_pci_probe() preventing driver remove function from being
called on rmmod.)
Signed-off-by: Stephen M. Cameron <scameron@beardog.cce.hp.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 2e311fbabdc23b7eaec77313dc3b9a151a5407b5 upstream.
We inadvertantly discarded the scsi status for aborted commands.
For some commands (e.g. reads from tape drives) these can't be retried,
and if we discarded the scsi status, the scsi mid layer couldn't notice
anything was wrong and the error was not reported.
commit ae5fbae0ccd982dfca0ce363036ed92f5b13f150 upstream.
Since commit 110dd8f19df5 "[SCSI] libsas: fix scr_read/write users and
update the libata documentation" we have been passing pmp=1 and is_cmd=0
to ata_tf_to_fis(). Praveen reports that eSATA attached drives do not
discover correctly. His investigation found that the BIOS was passing
pmp=0 while Linux was passing pmp=1 and failing to discover the drives.
Update libsas to follow the libata example of pulling the pmp setting
from the ata_link and correct is_cmd to be 1 since all tf's submitted
through ->qc_issue are commands. Presumably libsas lldds do not care
about is_cmd as they have sideband mechanisms to perform link
management.
http://marc.info/?l=linux-scsi&m=138179681726990
[jejb: checkpatch fix]
Reported-by: Praveen Murali <pmurali@logicube.com>
Tested-by: Praveen Murali <pmurali@logicube.com>
commit a1470c7bf3a4676e62e4c0fb204e339399eb5c59 upstream.
Bug report from: wenxiong@linux.vnet.ibm.com
The issue is happened in dual controller configuration. We got the
sysfs warnings when rmmod the ipr module.
enclosure_unregister() in drivers/msic/enclosure.c, call device_unregister()
for each componment deivce, device_unregister() ->device_del()->kobject_del()
->sysfs_remove_dir(). In sysfs_remove_dir(), set kobj->sd = NULL.
For each componment device,
enclosure_component_release()->enclosure_remove_links()->sysfs_remove_link()
in which checking kobj->sd again, it has been set as NULL when doing
device_unregister. So we saw all these sysfs WARNING.
Tested-by: wenxiong@linux.vnet.ibm.com
commit fd7c092e711ebab55b2688d3859d95dfd0301f73 upstream.
Avoid returning a truncated table or status string instead of setting
the DM_BUFFER_FULL_FLAG when the last target of a table fills the
buffer.
When processing a table or status request, the function retrieve_status
calls ti->type->status. If ti->type->status returns non-zero,
retrieve_status assumes that the buffer overflowed and sets
DM_BUFFER_FULL_FLAG.
However, targets don't return non-zero values from their status method
on overflow. Most targets returns always zero.
If a buffer overflow happens in a target that is not the last in the
table, it gets noticed during the next iteration of the loop in
retrieve_status; but if a buffer overflow happens in the last target, it
goes unnoticed and erroneously truncated data is returned.
In the current code, the targets behave in the following way:
* dm-crypt returns -ENOMEM if there is not enough space to store the
key, but it returns 0 on all other overflows.
* dm-thin returns errors from the status method if a disk error happened.
This is incorrect because retrieve_status doesn't check the error
code, it assumes that all non-zero values mean buffer overflow.
* all the other targets always return 0.
This patch changes the ti->type->status function to return void (because
most targets don't use the return code). Overflow is detected in
retrieve_status: if the status method fills up the remaining space
completely, it is assumed that buffer overflow happened.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
commit f9423606ade08653dd8a43334f0a7fb45504c5cc upstream.
The BUG_ON in drivers/iommu/intel-iommu.c:785 can be triggered from userspace via
VFIO by calling the VFIO_IOMMU_MAP_DMA ioctl on a vfio device with any address
beyond the addressing capabilities of the IOMMU. The problem is that the ioctl code
calls iommu_iova_to_phys before it calls iommu_map. iommu_map handles the case that
it gets addresses beyond the addressing capabilities of its IOMMU.
intel_iommu_iova_to_phys does not.
This patch fixes iommu_iova_to_phys to return NULL for addresses beyond what the
IOMMU can handle. This in turn causes the ioctl call to fail in iommu_map and
(correctly) return EFAULT to the user with a helpful warning message in the kernel
log.
Signed-off-by: Julian Stecklina <jsteckli@os.inf.tu-dresden.de>
Acked-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Joerg Roedel <joro@8bytes.org>
commit 2ab68ec927310dc488f3403bb48f9e4ad00a9491 upstream.
kyro would copy u32s and specify sizeof(unsigned long) as the size to copy.
This would copy more data than intended and cause memory corruption and might
leak kernel memory.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit c8760069627ad3b0dbbea170f0c4c58b16e18d3d upstream.
Current MMC driver doesn't handle generic error (bit19 of device
status) in write sequence. As a result, write data gets lost when
generic error occurs. For example, a generic error when updating a
filesystem management information causes a loss of write data and
corrupts the filesystem. In the worst case, the system will never
boot.
This patch includes the following functionality:
1. To enable error checking for the response of CMD12 and CMD13
in write command sequence
2. To retry write sequence when a generic error occurs
Messages are added for v2 to show what occurs.
Signed-off-by: KOBAYASHI Yoshitake <yoshitake.kobayashi@toshiba.co.jp>
Signed-off-by: Chris Ball <cjb@laptop.org>
commit 1e87a2456b0227ca4ab881e19a11bb99d164e792 upstream.
A HID device could send a malicious output report that would cause the
picolcd HID driver to trigger a NULL dereference during attr file writing.
[jkosina@suse.cz: changed
report->maxfield < 1
to
report->maxfield != 1
as suggested by Bruno].
CVE-2013-2899
Cc: stable@kernel.org
Reviewed-by: Bruno Prémont <bonbons@linux-vserver.org>
Acked-by: Bruno Prémont <bonbons@linux-vserver.org>
[Kefeng: backported to stable 3.4: adjust filename]
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
[ Upstream commit b5de4a22f157ca345cdb3575207bf46402414bc1 ]
init_card() calls dev_get_by_name() to get a network deceive. But it
doesn't decrease network device reference count after the device is
used.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
[ Upstream commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c ]
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must
set msg_namelen to the proper size <= sizeof(struct sockaddr_storage)
to return msg_name to the user.
This prevents numerous uninitialized memory leaks we had in the
recvmsg handlers and makes it harder for new code to accidentally leak
uninitialized memory.
Optimize for the case recvfrom is called with NULL as address. We don't
need to copy the address at all, so set it to NULL before invoking the
recvmsg handler. We can do so, because all the recvmsg handlers must
cope with the case a plain read() is called on them. read() also sets
msg_name to NULL.
Also document these changes in include/linux/net.h as suggested by David
Miller.
Changes since RFC:
Set msg->msg_name = NULL if user specified a NULL in msg_name but had a
non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't
affect sendto as it would bail out earlier while trying to copy-in the
address. It also more naturally reflects the logic by the callers of
verify_iovec.
With this change in place I could remove "
if (!uaddr || msg_sys->msg_namelen == 0)
This change does not alter the user visible error logic as we ignore
msg_namelen as long as msg_name is NULL.
Also remove two unnecessary curly brackets in ___sys_recvmsg and change
comments to netdev style.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
[ Upstream commit 1ca1a4cf59ea343a1a70084fe7cc96f37f3cf5b1 ]
In af3e095a1fb4, Erik Jacobsen fixed one type of unaligned access
bug for ia64 by converting a 64-bit write to use put_unaligned().
Unfortunately, since gcc will convert a short memset() to a series
of appropriately-aligned stores, the problem is now visible again
on tilegx, where the memset that zeros out proc_event is converted
to three 64-bit stores, causing an unaligned access panic.
A better fix for the original problem is to ensure that proc_event
is aligned to 8 bytes here. We can do that relatively easily by
arranging to start the struct cn_msg aligned to 8 bytes and then
offset by 4 bytes. Doing so means that the immediately following
proc_event structure is then correctly aligned to 8 bytes.
The result is that the memset() stores are now aligned, and as an
added benefit, we can remove the put_unaligned() calls in the code.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
[ Upstream commit f9a23c84486ed350cce7bb1b2828abd1f6658796 ]
These strings come from a copy_from_user() and there is no way to be
sure they are NUL terminated.
[ Upstream commit b869ccfab1e324507fa3596e3e1308444fb68227 ]
This patch fixes two race conditions between bond_store_updelay/downdelay
and bond_store_miimon which could lead to division by zero as miimon can
be set to 0 while either updelay/downdelay are being set and thus miss the
zero check in the beginning, the zero div happens because updelay/downdelay
are stored as new_value / bond->params.miimon. Use rtnl to synchronize with
miimon setting.
Signed-off-by: Nikolay Aleksandrov <nikolay@redhat.com>
CC: Jay Vosburgh <fubar@us.ibm.com>
CC: Andy Gospodarek <andy@greyhouse.net>
CC: Veaceslav Falico <vfalico@redhat.com>
Acked-by: Veaceslav Falico <vfalico@redhat.com>
[ Upstream commit ec9f1d15db8185f63a2c3143dc1e90ba18541b08 ]
Currently the ARP monitoring is not supported with 802.3ad, and it's
prohibited to use it via the module params.
However we still can set it afterwards via sysfs, cause we only check for
*LB modes there.
To fix this - add a check for 802.3ad mode in bonding_store_arp_interval.
Signed-off-by: Veaceslav Falico <vfalico@redhat.com>
commit 43c831468b3d26dbe8f2e061ccaf1abaf9cc1b8b upstream.
Use case: people who use both Apple and PC keyboards regularly, and desire to
keep&use their PC muscle memory.
A particular use case: an Apple compact external keyboard connected to a PC
laptop. (This use case can't be covered well by X.org key remappings etc.)
Signed-off-by: Nanno Langstraat <langstr@gmail.com>
commit 7be63f20b00840a6f1c718dcee00855688d64acd upstream.
Add missing switch breaks.
Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net>
commit ac5b4b6bf0c84c48d7e2e3fce22e35b04282ba76 upstream.
Dynamic static allocation is evil, as Kernel stack is too low, and
ompilation complains about it on some archs:
drivers/staging/media/lirc/lirc_zilog.c:967:1: warning: 'read' uses dynamic stack allocation [enabled by default]
Instead, let's enforce a limit for the buffer to be 64. That should
be more than enough.
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com>
commit 78551277e4df57864b0b0e7f85c23ede2be2edb8 upstream.
This allows the module to be autoloaded in the common case.
In order to work on non-PnP systems the module should be compiled in or
loaded unconditionally at boot (c.f. modules-load.d(5)), as before.
commit 02e5f5c0a0f726e66e3d8506ea1691e344277969 upstream.
The various ->run routines of md personalities assume that the 'queue'
has been initialised by the blk_set_stacking_limits() call in
md_alloc().
However when the level is changed (by level_store()) the ->run routine
for the new level is called for an array which has already had the
stacking limits modified. This can result in incorrect final
settings.
So call blk_set_stacking_limits() before ->run in level_store().
A specific consequence of this bug is that it causes
discard_granularity to be set incorrectly when reshaping a RAID4 to a
RAID0.
This is suitable for any -stable kernel since 3.3 in which
blk_set_stacking_limits() was introduced.
Reported-and-tested-by: "Baldysiak, Pawel" <pawel.baldysiak@intel.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 97b6ff6be9da7675aab339334fda996d6c5077d9 upstream.
GPU with low amount of ram can fails at pinning new framebuffer before
unpinning old one. On such failure, retry with unpinning old one before
pinning new one allowing to work around the issue. This is somewhat
ugly but only affect those old GPU we care about.
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit d5693761b2b4ff530c8af8af9ec55b6eae76e617 upstream.
Typo in the register offset.
Noticed-by: Sylvain BERTRAND <sylware@legeek.net>
commit 9360bd1112d8874d21942e2ae74f5416b00a8db6 upstream.
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit b2ea8ef559b4d94190009f3651b5b3ab7c05afd3 upstream.
Apparently they need the same treatment as primary planes. This fixes
modesetting failures because of stuck cursors (!) on Thomas' i830M
machine.
I've figured while at it I'll also roll it out for the ivb 3 pipe
version of this function. I didn't do this for i845/i865 since Bspec
says the update mechanism works differently, and there's some
additional rules about what can be updated in which order.
Tested-by: Thomas Richter <thor@math.tu-berlin.de>
Cc: Thomas Richter <thor@math.tu-berlin.de>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 9a0599ddeae012a771bba5e23393fc52d8a59d89 upstream.
Fix the case where the ttm pointer may be NULL causing
a NULL pointer dereference.
Signed-off-by: Jakob Bornecrantz <jakob@vmware.com>
Signed-off-by: Thomas Hellström <thellstrom@vmware.com>
commit 8e3ffa471091c560deb6738ed9ab7445b7a5fd04 upstream.
Userspace uses the netdev devtype for stuff like device naming and type
detection. Be nice and set it. Remove the pointless #if/#endif around
SET_NETDEV_DEV too.
Signed-off-by: Dan Williams <dcbw@redhat.com>
commit e7cc5cf74544d97d7b69e2701595037474db1f96 upstream.
The pcie_portdrv .probe() method calls pci_enable_device() once, in
pcie_port_device_register(), but the .remove() method calls
pci_disable_device() twice, in pcie_port_device_remove() and in
pcie_portdrv_remove().
That causes a "disabling already-disabled device" warning when removing a
PCIe port device. This happens all the time when removing Thunderbolt
devices, but is also easy to reproduce with, e.g.,
"echo 0000:00:1c.3 > /sys/bus/pci/drivers/pcieport/unbind"
This patch removes the disable from pcie_portdrv_remove().
[bhelgaas: changelog, tag for stable]
Reported-by: David Bulkow <David.Bulkow@stratus.com>
Reported-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit d03b4aa77e1187b77dfe37d14a923547f00baa66 upstream.
While receiving a packet on SDIO interface, we allocate skb with
size multiple of SDIO block size. We need to resize this skb
after RX using packet length from RX header.
Signed-off-by: Avinash Patil <patila@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
commit f36afb3957353d2529cb2b00f78fdccd14fc5e9c upstream.
dm-mpath and dm-thin must process messages even if some device is
suspended, so we allocate argv buffer with GFP_NOIO. These messages have
a small fixed number of arguments.
On the other hand, dm-switch needs to process bulk data using messages
so excessive use of GFP_NOIO could cause trouble.
The patch also lowers the default number of arguments from 64 to 8, so
that there is smaller load on GFP_NOIO allocations.
Acked-by: Alasdair G Kergon <agk@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 2bf127a5cc372b9319afcbae10b090663b621c8b upstream.
RSSI value is provided on word3 not on word2.
Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl>
commit 6fb392b1a63ae36c31f62bc3fc8630b49d602b62 upstream.
Check user-defined length in snmp ioctl request and allow request
only if it fits into a qeth command buffer.
Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com>
Signed-off-by: Frank Blaschka <frank.blaschka@de.ibm.com>
Reviewed-by: Heiko Carstens <heicars2@linux.vnet.ibm.com>
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
commit 78dbfecb95be4635b995af3bd29fa10013409fcd upstream.
The routine that processes received frames was returning the RSSI value for the
signal strength; however, that value is available only for associated APs. As
a result, the strength was the absurd value of 10 dBm. As a result, scans
return incorrect values for the strength, which causes unwanted attempts to roam.
commit b4ade797668e33b4e8353c2701ce01d7084dfafa upstream.
This patch fixes https://bugzilla.kernel.org/show_bug.cgi?id=63881.
Reported-by: Matthieu Baerts <matttbe@gmail.com>
commit 3545f3d5f4af715c914394123ce7725a9cf0a1c4 upstream.
commit 9df682927c2e3a92f43803d6b52095992e3b2ab8 upstream.
This fixes resets on heavy TX data traffic.
Vendor driver
VT6656_Linux_src_v1.21.03_x86_11.04.zip
http://www.viaembedded.com/servlet/downloadSvl?id=1890&download_file_id=14704
This is GPL-licensed code.
original code
BBbVT3184Init
//2007-0725, RobertChang add, Enable Squelch detect reset option(SQ_RST_Opt), USB (register4, bit1)
CONTROLnsRequestIn(pDevice,
MESSAGE_TYPE_READ,
(WORD)0x600+4, // USB's Reg4's bit1
MESSAGE_REQUEST_MEM,
1,
(PBYTE) &byData);
byData = byData|2 ;
CONTROLnsRequestOut(pDevice,
MESSAGE_TYPE_WRITE,
1,
(PBYTE) &byData);
return TRUE;//ntStatus;
A back port patch is needed for kernels less than 3.10.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
commit ea5ec76d76da9279d12027c1828544c5ccbe7932 upstream.
If the permission check fails, we drop a reference to the blkif without
having taken it in the first place. The bug was introduced in commit
604c499cbbcc3d5fe5fb8d53306aa0fae1990109 (xen/blkback: Check device
permissions before allowing OP_DISCARD).
Cc: Jan Beulich <JBeulich@suse.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 7b3d2fb92067bcb29f0f085a9fa9fa64920a6646 upstream.
[1] The gpmi uses the nand_command_lp to issue the commands to NAND chips.
The gpmi issues a DMA operation with gpmi_cmd_ctrl when it handles
a NAND_CMD_NONE control command. So when we read a page(NAND_CMD_READ0)
from the NAND, we may send two DMA operations back-to-back.
If we do not serialize the two DMA operations, we will meet a bug when
1.1) we enable CONFIG_DMA_API_DEBUG, CONFIG_DMADEVICES_DEBUG,
and CONFIG_DEBUG_SG.
1.2) Use the following commands in an UART console and a SSH console:
cmd 1: while true;do dd if=/dev/mtd0 of=/dev/null;done
cmd 1: while true;do dd if=/dev/mmcblk0 of=/dev/null;done
The kernel log shows below:
kernel BUG at lib/scatterlist.c:28!
Unable to handle kernel NULL pointer dereference at virtual address 00000000
[<80044a0c>] (__bug+0x18/0x24) from [<80249b74>] (sg_next+0x48/0x4c)
[<80249b74>] (sg_next+0x48/0x4c) from [<80255398>] (debug_dma_unmap_sg+0x170/0x1a4)
[<80255398>] (debug_dma_unmap_sg+0x170/0x1a4) from [<8004af58>] (dma_unmap_sg+0x14/0x6c)
[<8004af58>] (dma_unmap_sg+0x14/0x6c) from [<8027e594>] (mxs_dma_tasklet+0x18/0x1c)
[<8027e594>] (mxs_dma_tasklet+0x18/0x1c) from [<8007d444>] (tasklet_action+0x114/0x164)
1.3) Assume the two DMA operations is X (first) and Y (second).
The root cause of the bug:
Assume process P issues DMA X, and sleep on the completion
@this->dma_done. X's tasklet callback is dma_irq_callback. It firstly
wake up the process sleeping on the completion @this->dma_done,
and then trid to unmap the scatterlist S. The waked process P will
issue Y in another ARM core. Y initializes S->sg_magic to zero
with sg_init_one(), while dma_irq_callback is unmapping S at the same
time.
See the diagram:
ARM core 0 | ARM core 1
(P issues DMA X, then sleep) --> |
(X's tasklet wakes P) --> |
| <-- (P begin to issue DMA Y)
(X's tasklet unmap the |
scatterlist S with dma_unmap_sg) --> | <-- (Y calls sg_init_one() to init
| scatterlist S)
[2] This patch serialize both the X and Y in the following way:
Unmap the DMA scatterlist S firstly, and wake up the process at the end
of the DMA callback, in such a way, Y will be executed after X.
After this patch:
| scatterlist S)
Signed-off-by: Huang Shijie <b32955@freescale.com>
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
commit 4355b70cf48363c50a9de450b01178c83aba8f6a upstream.
Some bright specification writers decided to write this in the ONFI spec
(from ONFI 3.0, Section 3.1):
"The number of blocks and number of pages per block is not required to
be a power of two. In the case where one of these values is not a
power of two, the corresponding address shall be rounded to an
integral number of bits such that it addresses a range up to the
subsequent power of two value. The host shall not access upper
addresses in a range that is shown as not supported."
This breaks every assumption MTD makes about NAND block/chip-size
dimensions -- they *must* be a power of two!
And of course, an enterprising manufacturer has made use of this lovely
freedom. Exhibit A: Micron MT29F32G08CBADAWP
"- Plane size: 2 planes x 1064 blocks per plane
- Device size: 32Gb: 2128 blockss [sic]"
This quickly hits a BUG() in nand_base.c, since the extra dimensions
overflow so we think it's a second chip (on my single-chip setup):
ONFI param page 0 valid
ONFI flash detected
NAND device: Manufacturer ID: 0x2c, Chip ID: 0x44 (Micron MT29F32G08CBADAWP), 4256MiB, page size: 8192, OOB size: 744
kernel BUG at drivers/mtd/nand/nand_base.c:203!
Internal error: Oops - BUG: 0 [#1] SMP ARM
[... trim ...]
[<c02cf3e4>] (nand_select_chip+0x18/0x2c) from [<c02d25c0>] (nand_do_read_ops+0x90/0x424)
[<c02d25c0>] (nand_do_read_ops+0x90/0x424) from [<c02d2dd8>] (nand_read+0x54/0x78)
[<c02d2dd8>] (nand_read+0x54/0x78) from [<c02ad2c8>] (mtd_read+0x84/0xbc)
[<c02ad2c8>] (mtd_read+0x84/0xbc) from [<c02d4b28>] (scan_read.clone.4+0x4c/0x64)
[<c02d4b28>] (scan_read.clone.4+0x4c/0x64) from [<c02d4c88>] (search_bbt+0x148/0x290)
[<c02d4c88>] (search_bbt+0x148/0x290) from [<c02d4ea4>] (nand_scan_bbt+0xd4/0x5c0)
[... trim ...]
---[ end trace 0c9363860d865ff2 ]---
So to fix this, just truncate these dimensions down to the greatest
power-of-2 dimension that is less than or equal to the specified
dimension.
