path: root/drivers
2007-07-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/ehca: Support small QP queues IB/ehca: Make internal_create/destroy_qp() static IB/ehca: Move ehca2ib_return_code() out of line IB/ehca: Generate async event when SRQ limit reached IB/ehca: Support large page MRs IB/mlx4: Fix error path in create_qp_common() mlx4_core: Change command token on timeout IB/mthca: Change command token on timeout IB/ipath: Remove ipath_layer dead code IB/mlx4: Fix leaks in __mlx4_ib_modify_qp
2007-07-22Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (60 commits) [SCSI] libsas: make ATA functions selectable by a config option [SCSI] bsg: unexport sg v3 helper functions [SCSI] bsg: fix bsg_unregister_queue [SCSI] bsg: make class backlinks [SCSI] 3w-9xxx: add support for 9690SA [SCSI] bsg: fix bsg_register_queue error path [SCSI] ESP: Increase ESP_BUS_TIMEOUT to 275. [SCSI] libsas: fix scr_read/write users and update the libata documentation [SCSI] mpt fusion: update Kconfig help [SCSI] scsi_transport_sas: add destructor for bsg [SCSI] iscsi_tcp: buggered kmalloc() [SCSI] qla2xxx: Update version number to 8.02.00-k2. [SCSI] qla2xxx: Add ISP25XX support. [SCSI] qla2xxx: Use pci_try_set_mwi(). [SCSI] qla2xxx: Use PCI-X/PCI-Express read control interfaces. [SCSI] qla2xxx: Re-factor isp_operations to static structures. [SCSI] qla2xxx: Validate mid-layer 'underflow' during check-condition handling. [SCSI] qla2xxx: Correct setting of 'current' and 'supported' speeds during FDMI registration. [SCSI] qla2xxx: Generalize iIDMA support. [SCSI] qla2xxx: Generalize FW-Interface-2 support. ...
2007-07-22[SCSI] libsas: make ATA functions selectable by a config optionJames Bottomley
Not everyone wants libsas automatically to pull in libata. This patch makes the behaviour configurable, so you can build libsas with or without ATA support. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-22Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (60 commits) [ARM] 4524/1: S3C: Move register out of include/asm-arm/arch-s3c2410 [ARM] 4523/1: S3C: Remove FIFO_MAX from uncompression headers [ARM] 4522/1: S3C: split include/asm-arm/arch/memory.h [ARM] 4521/2: S3C: Reorganise VA mapping headers [ARM] 4520/1: S3C: Remove old VA values from static map [ARM] 4519/1: S3C: split S3C2400 values out of S3C24XX map.h [ARM] 4518/1: S3C: Rename watchdog configuration options [ARM] 4517/1: S3C: Fix debug macros for ARM926 output [ARM] 4516/1: S3C: Fix uncompressor serial output for ARM926 [ARM] 4515/1: S3C: Move uncompress code to plat-s3c [ARM] 4514/1: S3C: Rename DEBUG_S3C2410_PORT and DEBUG_S3C_UART [ARM] 4513/1: S3C: Rename CONFIG_S3C2410_LOWLEVEL_UART_PORT [ARM] 4512/1: S3C: rename the debug macros for per-cpu updates [ARM] 4511/1: S3C: updated LLSERIAL Kconfig defines for CPU support [ARM] 4510/1: S3C: split debug-macro support into plat-s3c [ARM] 4509/1: S3C: Create initial arch/arm/plat-s3c [ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3c [ARM] 4461/1: MXC platform and i.MX31ADS core support [ARM] 4507/1: pxa2xx clock_event_device [ARM] 4497/1: Only allow safe cache configurations on ARMv6 and later ...
2007-07-22Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-ledsLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-leds: leds: Convert from struct class_device to struct device leds: leds-gpio for ngw100 leds: Add warning printks in error paths leds: Fix trigger unregister_simple if register_simple fails leds: Use menuconfig objects II - LED leds: Teach leds-gpio to handle timer-unsafe GPIOs leds: Add generic GPIO LED driver
2007-07-22Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlightLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight: leds: cr_bllcd.c: build fix backlight: Convert from struct class_device to struct device backlight: Fix order of Kconfig entries
2007-07-22Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [POWERPC] Clean up duplicate includes in drivers/macintosh/ [POWERPC] Quiet section mismatch warning on pcibios_setup [POWERPC] init and exit markings for hvc_iseries [POWERPC] Quiet section mismatch in hvc_rtas.c [POWERPC] Constify of_platform_driver match_table [POWERPC] hvcs: Make some things static and const [POWERPC] Constify of_platform_driver name [POWERPC] MPIC protected sources [POWERPC] of_detach_node()'s device node argument cannot be const [POWERPC] Fix ARCH=ppc builds [POWERPC] mv64x60: Use mutex instead of semaphore [POWERPC] Allow smp_call_function_single() to current cpu [POWERPC] Allow exec faults on readable areas on classic 32-bit PowerPC [POWERPC] Fix future firmware feature fixups function failure [POWERPC] fix showing xmon help [POWERPC] Make xmon_write accept a const buffer [POWERPC] Fix misspelled "CONFIG_CHECK_CACHE_COHERENCY" Kconfig option. [POWERPC] cell: CONFIG_SPE_BASE is a typo
2007-07-22KVM: Require CONFIG_ANON_INODESAvi Kivity
Found by Sebastian Siewior and randconfig. Signed-off-by: Avi Kivity <avi@qumranet.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-22Merge branches 'at91', 'imx', 'iop', 'ixp', 'ks8695', 'misc', 'ns9xxx', ↵Russell King
'pxa' and 's3c' into devel
2007-07-22[ARM] 4508/1: S3C: Move items to include/asm-arm/plat-s3cBen Dooks
This patch moves items of the s3c24xx support into a new plat-s3c directory for items that use the s3c24xx support but are not directly s3c24xx compatible, such as the s3c2400 and s3c6400. git mv commands: git mv include/asm-arm/arch-s3c2410/iic.h include/asm-arm/plat-s3c/iic.h git mv include/asm-arm/arch-s3c2410/nand.h include/asm-arm/plat-s3c/nand.h git mv include/asm-arm/arch-s3c2410/regs-iic.h include/asm-arm/plat-s3c/regs-iic.h git mv include/asm-arm/arch-s3c2410/regs-nand.h include/asm-arm/plat-s3c/regs-nand.h git mv include/asm-arm/arch-s3c2410/regs-rtc.h include/asm-arm/plat-s3c/regs-rtc.h git mv include/asm-arm/arch-s3c2410/regs-serial.h include/asm-arm/plat-s3c/regs-serial.h git mv include/asm-arm/arch-s3c2410/regs-timer.h include/asm-arm/plat-s3c/regs-timer.h git mv include/asm-arm/arch-s3c2410/regs-watchdog.h include/asm-arm/plat-s3c/regs-watchdog.h Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-22[POWERPC] Clean up duplicate includes in drivers/macintosh/Jesper Juhl
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-22[POWERPC] init and exit markings for hvc_iseriesStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-22[POWERPC] Quiet section mismatch in hvc_rtas.cStephen Rothwell
WARNING: vmlinux.o(.text+0x2066f0): Section mismatch: reference to .init.text:.add_preferred_console (between '.hvc_rtas_console_init' and '.hvc_beat_put_chars') Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-22[POWERPC] hvcs: Make some things static and constStephen Rothwell
2007-07-22[POWERPC] Constify of_platform_driver nameStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-07-22leds: cr_bllcd.c: build fixAndrew Morton
Build fix for cr_bllcd.c Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-07-22Pull tables-in-sysfs into release branchLen Brown
2007-07-22Pull netlink into release branchLen Brown
2007-07-22ACPI: Populate /sys/firmware/acpi/tables/Zhang Rui
The file name is the signature, such as DSDT, and the contents are the binary table image. Some tables, such as the SSDT, can have multiple instances. If just one, the file is SSDT, but if 3 instances, for example, it will be SSDT1, SSDT2, SSDT3 All static tables (besides teh RSDP and RSDT themselves are exported. Dynamic tables, such as SSDT op-regions that are not declared in the RSDT, will be added in a subsequent patch. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22Pull osi into release branchLen Brown
2007-07-22Pull video into release branchLen Brown
2007-07-22Pull throttle into release branchLen Brown
2007-07-22Pull thinkpad into release branchLen Brown
2007-07-22Pull sony into release branchLen Brown
2007-07-22Pull misc into release branchLen Brown
Conflicts: Documentation/feature-removal-schedule.txt
2007-07-22Pull dock-bay into release branchLen Brown
2007-07-22Pull ec into release branchLen Brown
2007-07-22Pull sbs into release branchLen Brown
2007-07-22Pull battery into release branchLen Brown
2007-07-22Pull acpi-debug into release branchLen Brown
2007-07-22Pull acpica into release branchLen Brown
2007-07-22ACPI: create CONFIG_ACPI_DEBUG_FUNC_TRACEThomas Renninger
Split ACPI_DEBUG into function trace enabled and not enabled. Function trace is most of the ACPI_DEBUG costs, but is not much of use for kernel ACPI debugging. Size of kernel image increased on test compile: + 48k (Full ACPI_DEBUG) + 35k (ACPI_DEBUG with function trace compiled out) Performance without function trace is also much better. Also remove ACPI_LV_DEBUG_OBJECT from default debug level as a lot vendors let Store (value, debug) in their code and this might confuse users when it pops up in syslog. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22ACPI: export ACPI events via acpi_mc_group multicast groupZhang Rui
This is an incremental patch for the recent genetlink multicast changes. Now ACPI events are exported via generic netlink multicast group. Thanks for Johannes' help on developing this patch Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22ACPI: fix empty macros found by -WextraDave Jones
ACPI has a ton of macros which make a bunch of empty if's when configured in non-debug mode. [lenb: The code it complaines about is functionally correct, so this patch is just to make -Wextra happier] #define DBG() if(...) DBG(); next_c_statement which turns into if(...) ; next_c_statement Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22ACPI: drivers/acpi/pci_link.c: lower printk severityDan Aloni
Signed-off-by: Dan Aloni <da-x@monatomic.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22sony-laptop: Fix event reading in sony-laptopMattia Dongili
The rewritten event reading code from sonypi was absolutely wrong, this patche makes things functional for type2 and type1 models. Cc: Andrei Paskevich <andrei@capet.iut-fbleau.fr> Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22sony-laptop: Add Vaio FE to the special init sequenceMattia Dongili
The Vaio FE series uses the same sequence as Vaio C series Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22sony-laptop: Make the driver use MSC_SCAN and a setkeycode and getkeycode ↵Mattia Dongili
key table. The following is the only way I could think of to hide some events as per Dmitry suggestions while still using the default {set,get}keycode implementation. Make the driver use MSC_SCAN and a setkeycode and getkeycode key table. Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Richard Hughes <richard@hughsie.com> Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22sony-laptop: Invoke _INI for SNC devices that provide itMattia Dongili
2007-07-22sony-laptop: Add support for recent Vaios Fn keys (C series for now)Mattia Dongili
Recent Vaios (C, AR, N, FE) need some special initialization sequence to enable Fn keys interrupts through the Embedded Controller. Moreover Fn keys have to be decoded internally using ACPI methods to get the key code. Thus a new DMI table to add SNC init time callbacks and new mappings for model-specific key code to generic sony-laptop code have been added. Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-22sony-laptop: map wireless switch events to KEY_WLANMattia Dongili
2007-07-22sony-laptop: add new SNC handlersMattia Dongili
- lid state: GLID - indicator lamp: GILS/SILS - multimedia bass gain: GMGB/CMGB Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-21ACPI: thinkpad-acpi: add locking to brightness subdriverHenrique de Moraes Holschuh
The backlight class does all the locking needed for sysfs access, but offers no API to interface to that locking without an layer violation. Since we need to mutex-lock procfs access, implement in-driver locking for brightness. It will go away the day thinkpad-acpi procfs goes away, or the backlight class gives us a way to use its locks without a layer violation. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-21ACPI: thinkpad-acpi: bump up version to 0.15Henrique de Moraes Holschuh
Name it thinkpad-acpi version 0.15. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-21ACPI: thinkpad-acpi: make EC-based thermal readings non-experimentalHenrique de Moraes Holschuh
Reading the 16 thermal sensors directly from the EC has been stable for about one year, in all supported ThinkPad models. Remove its "experimental" label. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-21ACPI: thinkpad-acpi: make sure DSDT TMPx readings don't return +128Henrique de Moraes Holschuh
We get +128 instead of -128 from the DSDT TMPx methods, due to errors when converting a EC byte return that is a s8 to an ACPI handler return that is an int. Fix it once and for all, by clamping acceptable temperature readings from DSDT TMPx so that anything outside the [-127,+127] range is converted to TP_EC_THERMAL_TMP_NA (-128). Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Michael Olbrich <michael.olbrich@gmx.net> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-21ACPI: thinkpad-acpi: react to Lenovo ThinkPad differences in hot keyHenrique de Moraes Holschuh
Lenovo ThinkPads have a slightly different key map layout from IBM ThinkPads (fn+f2 and fn+f3 are swapped). Knowing which one we are dealing with, we can properly set a few more hot keys up by default. Also, export the correct vendor in the input device, as that information might be useful to userspace. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-21ACPI: thinkpad-acpi: allow use of CMOS NVRAM for brightness controlHenrique de Moraes Holschuh
It appears that Lenovo decided to break the EC brightness control interface in a weird way in their latest BIOSes. Fortunately, the old CMOS NVRAM interface works just fine in such BIOSes. Add a module parameter that allows the user to select which strategy to use for brightness control: EC, NVRAM, or both. By default, do both (which is the way thinkpad-acpi used to work until now) on IBM ThinkPads, and use NVRAM only on Lenovo ThinkPads. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-21ACPI: thinkpad-acpi: store ThinkPad model informationHenrique de Moraes Holschuh
Keep note of ThinkPad model, BIOS and EC firmware information, and log it on startup. Makes for far more readable code in places, too. This patch also adds Lenovo's PCI ID to the pci ids table. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-21ACPI: thinkpad_acpi: use bool for boolean parametersHenrique de Moraes Holschuh
Some of the module parameters are boolean in nature. Make it so in fact. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
