path: root/drivers
2014-02-10video:uvesafb: Fix oops that uvesafb try to execute NX-protected pageWang YanQing
commit b78f29ca0516266431688c5eb42d39ce42ec039a upstream. This patch fix the oops below that catched in my machine [ 81.560602] uvesafb: NVIDIA Corporation, GT216 Board - 0696a290, Chip Rev , OEM: NVIDIA, VBE v3.0 [ 81.609384] uvesafb: protected mode interface info at c000:d350 [ 81.609388] uvesafb: pmi: set display start = c00cd3b3, set palette = c00cd40e [ 81.609390] uvesafb: pmi: ports = 3b4 3b5 3ba 3c0 3c1 3c4 3c5 3c6 3c7 3c8 3c9 3cc 3ce 3cf 3d0 3d1 3d2 3d3 3d4 3d5 3da [ 81.614558] uvesafb: VBIOS/hardware doesn't support DDC transfers [ 81.614562] uvesafb: no monitor limits have been set, default refresh rate will be used [ 81.614994] uvesafb: scrolling: ypan using protected mode interface, yres_virtual=4915 [ 81.744147] kernel tried to execute NX-protected page - exploit attempt? (uid: 0) [ 81.744153] BUG: unable to handle kernel paging request at c00cd3b3 [ 81.744159] IP: [<c00cd3b3>] 0xc00cd3b2 [ 81.744167] *pdpt = 00000000016d6001 *pde = 0000000001c7b067 *pte = 80000000000cd163 [ 81.744171] Oops: 0011 [#1] SMP [ 81.744174] Modules linked in: uvesafb(+) cfbcopyarea cfbimgblt cfbfillrect [ 81.744178] [ 81.744181] Pid: 3497, comm: modprobe Not tainted 3.3.0-rc4NX+ #71 Acer Aspire 4741 /Aspire 4741 [ 81.744185] EIP: 0060:[<c00cd3b3>] EFLAGS: 00010246 CPU: 0 [ 81.744187] EIP is at 0xc00cd3b3 [ 81.744189] EAX: 00004f07 EBX: 00000000 ECX: 00000000 EDX: 00000000 [ 81.744191] ESI: f763f000 EDI: f763f6e8 EBP: f57f3a0c ESP: f57f3a00 [ 81.744192] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 [ 81.744195] Process modprobe (pid: 3497, ti=f57f2000 task=f748c600 task.ti=f57f2000) [ 81.744196] Stack: [ 81.744197] f82512c5 f759341c 00000000 f57f3a30 c124a9bc 00000001 00000001 000001e0 [ 81.744202] f8251280 f763f000 f7593400 00000000 f57f3a40 c12598dd f5c0c000 00000000 [ 81.744206] f57f3b10 c1255efe c125a21a 00000006 f763f09c 00000000 c1c6cb60 f7593400 [ 81.744210] Call Trace: [ 81.744215] [<f82512c5>] ? uvesafb_pan_display+0x45/0x60 [uvesafb] [ 81.744222] [<c124a9bc>] fb_pan_display+0x10c/0x160 [ 81.744226] [<f8251280>] ? uvesafb_vbe_find_mode+0x180/0x180 [uvesafb] [ 81.744230] [<c12598dd>] bit_update_start+0x1d/0x50 [ 81.744232] [<c1255efe>] fbcon_switch+0x39e/0x550 [ 81.744235] [<c125a21a>] ? bit_cursor+0x4ea/0x560 [ 81.744240] [<c129b6cb>] redraw_screen+0x12b/0x220 [ 81.744245] [<c128843b>] ? tty_do_resize+0x3b/0xc0 [ 81.744247] [<c129ef42>] vc_do_resize+0x3d2/0x3e0 [ 81.744250] [<c129efb4>] vc_resize+0x14/0x20 [ 81.744253] [<c12586bd>] fbcon_init+0x29d/0x500 [ 81.744255] [<c12984c4>] ? set_inverse_trans_unicode+0xe4/0x110 [ 81.744258] [<c129b378>] visual_init+0xb8/0x150 [ 81.744261] [<c129c16c>] bind_con_driver+0x16c/0x360 [ 81.744264] [<c129b47e>] ? register_con_driver+0x6e/0x190 [ 81.744267] [<c129c3a1>] take_over_console+0x41/0x50 [ 81.744269] [<c1257b7a>] fbcon_takeover+0x6a/0xd0 [ 81.744272] [<c12594b8>] fbcon_event_notify+0x758/0x790 [ 81.744277] [<c10929e2>] notifier_call_chain+0x42/0xb0 [ 81.744280] [<c1092d30>] __blocking_notifier_call_chain+0x60/0x90 [ 81.744283] [<c1092d7a>] blocking_notifier_call_chain+0x1a/0x20 [ 81.744285] [<c124a5a1>] fb_notifier_call_chain+0x11/0x20 [ 81.744288] [<c124b759>] register_framebuffer+0x1d9/0x2b0 [ 81.744293] [<c1061c73>] ? ioremap_wc+0x33/0x40 [ 81.744298] [<f82537c6>] uvesafb_probe+0xaba/0xc40 [uvesafb] [ 81.744302] [<c12bb81f>] platform_drv_probe+0xf/0x20 [ 81.744306] [<c12ba558>] driver_probe_device+0x68/0x170 [ 81.744309] [<c12ba731>] __device_attach+0x41/0x50 [ 81.744313] [<c12b9088>] bus_for_each_drv+0x48/0x70 [ 81.744316] [<c12ba7f3>] device_attach+0x83/0xa0 [ 81.744319] [<c12ba6f0>] ? __driver_attach+0x90/0x90 [ 81.744321] [<c12b991f>] bus_probe_device+0x6f/0x90 [ 81.744324] [<c12b8a45>] device_add+0x5e5/0x680 [ 81.744329] [<c122a1a3>] ? kvasprintf+0x43/0x60 [ 81.744332] [<c121e6e4>] ? kobject_set_name_vargs+0x64/0x70 [ 81.744335] [<c121e6e4>] ? kobject_set_name_vargs+0x64/0x70 [ 81.744339] [<c12bbe9f>] platform_device_add+0xff/0x1b0 [ 81.744343] [<f8252906>] uvesafb_init+0x50/0x9b [uvesafb] [ 81.744346] [<c100111f>] do_one_initcall+0x2f/0x170 [ 81.744350] [<f82528b6>] ? uvesafb_is_valid_mode+0x66/0x66 [uvesafb] [ 81.744355] [<c10c6994>] sys_init_module+0xf4/0x1410 [ 81.744359] [<c1157fc0>] ? vfsmount_lock_local_unlock_cpu+0x30/0x30 [ 81.744363] [<c144cb10>] sysenter_do_call+0x12/0x36 [ 81.744365] Code: f5 00 00 00 32 f6 66 8b da 66 d1 e3 66 ba d4 03 8a e3 b0 1c 66 ef b0 1e 66 ef 8a e7 b0 1d 66 ef b0 1f 66 ef e8 fa 00 00 00 61 c3 <60> e8 c8 00 00 00 66 8b f3 66 8b da 66 ba d4 03 b0 0c 8a e5 66 [ 81.744388] EIP: [<c00cd3b3>] 0xc00cd3b3 SS:ESP 0068:f57f3a00 [ 81.744391] CR2: 00000000c00cd3b3 [ 81.744393] ---[ end trace 18b2c87c925b54d6 ]--- Signed-off-by: Wang YanQing <udknight@gmail.com> Cc: Michal Januszewski <spock@gentoo.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10PCI: Add quirk for still enabled interrupts on Intel Sandy Bridge GPUsThomas Jarosch
commit cdb1f35dc7de42802527140a3613871c394548e1 upstream. commit f67fd55fa96f7d7295b43ffbc4a97d8f55e473aa upstream. Some BIOS implementations leave the Intel GPU interrupts enabled, even though no one is handling them (f.e. i915 driver is never loaded). Additionally the interrupt destination is not set up properly and the interrupt ends up -somewhere-. These spurious interrupts are "sticky" and the kernel disables the (shared) interrupt line after 100.000+ generated interrupts. Fix it by disabling the still enabled interrupts. This resolves crashes often seen on monitor unplug. Tested on the following boards: - Intel DH61CR: Affected - Intel DH67BL: Affected - Intel S1200KP server board: Affected - Asus P8H61-M LE: Affected, but system does not crash. Probably the IRQ ends up somewhere unnoticed. According to reports on the net, the Intel DH61WW board is also affected. Many thanks to Jesse Barnes from Intel for helping with the register configuration and to Intel in general for providing public hardware documentation. Signed-off-by: Thomas Jarosch <thomas.jarosch@intra2net.com> Tested-by: Charlie Suffin <charlie.suffin@stratus.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10fix eh wakeup (scsi_schedule_eh vs scsi_restart_operations)Dan Williams
commit 57fc2e335fd3c2f898ee73570dc81426c28dc7b4 upstream. Rapid ata hotplug on a libsas controller results in cases where libsas is waiting indefinitely on eh to perform an ata probe. A race exists between scsi_schedule_eh() and scsi_restart_operations() in the case when scsi_restart_operations() issues i/o to other devices in the sas domain. When this happens the host state transitions from SHOST_RECOVERY (set by scsi_schedule_eh) back to SHOST_RUNNING and ->host_busy is non-zero so we put the eh thread to sleep even though ->host_eh_scheduled is active. Before putting the error handler to sleep we need to check if the host_state needs to return to SHOST_RECOVERY for another trip through eh. Since i/o that is released by scsi_restart_operations has been blocked for at least one eh cycle, this implementation allows those i/o's to run before another eh cycle starts to discourage hung task timeouts. Reported-by: Tom Jackson <thomas.p.jackson@intel.com> Tested-by: Tom Jackson <thomas.p.jackson@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10SCSI: libsas: fix sas_discover_devices return code handlingDan Williams
commit e69e5d3d25d6b58543f782a515baeda064e2b601 upstream. commit b17caa174a7e1fd2e17b26e210d4ee91c4c28b37 upstream. commit 198439e4 [SCSI] libsas: do not set res = 0 in sas_ex_discover_dev() commit 19252de6 [SCSI] libsas: fix wide port hotplug issues The above commits seem to have confused the return value of sas_ex_discover_dev which is non-zero on failure and sas_ex_join_wide_port which just indicates short circuiting discovery on already established ports. The result is random discovery failures depending on configuration. Calls to sas_ex_join_wide_port are the source of the trouble as its return value is errantly assigned to 'res'. Convert it to bool and stop returning its result up the stack. Tested-by: Dan Melnic <dan.melnic@amd.com> Reported-by: Dan Melnic <dan.melnic@amd.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Reviewed-by: Jack Wang <jack_wang@usish.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Willy Tarreau <w@1wt.eu> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10libsas: continue revalidationDan Williams
commit 26f2f199ff150d8876b2641c41e60d1c92d2fb81 upstream. Continue running revalidation until no more broadcast devices are discovered. Fixes cases where re-discovery completes too early in a domain with multiple expanders with pending re-discovery events. Servicing BCNs can get backed up behind error recovery. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10Avoid dangling pointer in scsi_requeue_command()Bart Van Assche
commit 940f5d47e2f2e1fa00443921a0abf4822335b54d upstream. When we call scsi_unprep_request() the command associated with the request gets destroyed and therefore drops its reference on the device. If this was the only reference, the device may get released and we end up with a NULL pointer deref when we call blk_requeue_request. Reported-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Bart Van Assche <bvanassche@acm.org> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Reviewed-by: Tejun Heo <tj@kernel.org> [jejb: enhance commend and add commit log for stable] Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10pcdp: use early_ioremap/early_iounmap to access pcdp tableGreg Pearson
commit 6c4088ac3a4d82779903433bcd5f048c58fb1aca upstream. efi_setup_pcdp_console() is called during boot to parse the HCDP/PCDP EFI system table and setup an early console for printk output. The routine uses ioremap/iounmap to setup access to the HCDP/PCDP table information. The call to ioremap is happening early in the boot process which leads to a panic on x86_64 systems: panic+0x01ca do_exit+0x043c oops_end+0x00a7 no_context+0x0119 __bad_area_nosemaphore+0x0138 bad_area_nosemaphore+0x000e do_page_fault+0x0321 page_fault+0x0020 reserve_memtype+0x02a1 __ioremap_caller+0x0123 ioremap_nocache+0x0012 efi_setup_pcdp_console+0x002b setup_arch+0x03a9 start_kernel+0x00d4 x86_64_start_reservations+0x012c x86_64_start_kernel+0x00fe This replaces the calls to ioremap/iounmap in efi_setup_pcdp_console() with calls to early_ioremap/early_iounmap which can be called during early boot. This patch was tested on an x86_64 prototype system which uses the HCDP/PCDP table for early console setup. Signed-off-by: Greg Pearson <greg.pearson@hp.com> Acked-by: Khalid Aziz <khalid.aziz@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10mtd: cafe_nand: fix an & vs | mistakeDan Carpenter
commit 48f8b641297df49021093763a3271119a84990a2 upstream. The intent here was clearly to set result to true if the 0x40000000 flag was set. But instead there was a | vs & typo and we always set result to true. Artem: check the spec at wiki.laptop.org/images/5/5c/88ALP01_Datasheet_July_2007.pdf and this fix looks correct. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10usbdevfs: Correct amount of data copied to user in processcompl_compatHans de Goede
commit 2102e06a5f2e414694921f23591f072a5ba7db9f upstream. iso data buffers may have holes in them if some packets were short, so for iso urbs we should always copy the entire buffer, just like the regular processcompl does. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: serial: fix race between probe and openJohan Hovold
commit a65a6f14dc24a90bde3f5d0073ba2364476200bf upstream. Fix race between probe and open by making sure that the disconnected flag is not cleared until all ports have been registered. A call to tty_open while probe is running may get a reference to the serial structure in serial_install before its ports have been registered. This may lead to usb_serial_core calling driver open before port is fully initialised. With ftdi_sio this result in the following NULL-pointer dereference as the private data has not been initialised at open: [ 199.698286] IP: [<f811a089>] ftdi_open+0x59/0xe0 [ftdi_sio] [ 199.698297] *pde = 00000000 [ 199.698303] Oops: 0000 [#1] PREEMPT SMP [ 199.698313] Modules linked in: ftdi_sio usbserial [ 199.698323] [ 199.698327] Pid: 1146, comm: ftdi_open Not tainted 3.2.11 #70 Dell Inc. Vostro 1520/0T816J [ 199.698339] EIP: 0060:[<f811a089>] EFLAGS: 00010286 CPU: 0 [ 199.698344] EIP is at ftdi_open+0x59/0xe0 [ftdi_sio] [ 199.698348] EAX: 0000003e EBX: f5067000 ECX: 00000000 EDX: 80000600 [ 199.698352] ESI: f48d8800 EDI: 00000001 EBP: f515dd54 ESP: f515dcfc [ 199.698356] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 [ 199.698361] Process ftdi_open (pid: 1146, ti=f515c000 task=f481e040 task.ti=f515c000) [ 199.698364] Stack: [ 199.698368] f811a9fe f811a9e0 f811b3ef 00000000 00000000 00001388 00000000 f4a86800 [ 199.698387] 00000002 00000000 f806e68e 00000000 f532765c f481e040 00000246 22222222 [ 199.698479] 22222222 22222222 22222222 f5067004 f5327600 f5327638 f515dd74 f806e6ab [ 199.698496] Call Trace: [ 199.698504] [<f806e68e>] ? serial_activate+0x2e/0x70 [usbserial] [ 199.698511] [<f806e6ab>] serial_activate+0x4b/0x70 [usbserial] [ 199.698521] [<c126380c>] tty_port_open+0x7c/0xd0 [ 199.698527] [<f806e660>] ? serial_set_termios+0xa0/0xa0 [usbserial] [ 199.698534] [<f806e76f>] serial_open+0x2f/0x70 [usbserial] [ 199.698540] [<c125d07c>] tty_open+0x20c/0x510 [ 199.698546] [<c10e9eb7>] chrdev_open+0xe7/0x230 [ 199.698553] [<c10e48f2>] __dentry_open+0x1f2/0x390 [ 199.698559] [<c144bfec>] ? _raw_spin_unlock+0x2c/0x50 [ 199.698565] [<c10e4b76>] nameidata_to_filp+0x66/0x80 [ 199.698570] [<c10e9dd0>] ? cdev_put+0x20/0x20 [ 199.698576] [<c10f3e08>] do_last+0x198/0x730 [ 199.698581] [<c10f4440>] path_openat+0xa0/0x350 [ 199.698587] [<c10f47d5>] do_filp_open+0x35/0x80 [ 199.698593] [<c144bfec>] ? _raw_spin_unlock+0x2c/0x50 [ 199.698599] [<c10ff110>] ? alloc_fd+0xc0/0x100 [ 199.698605] [<c10f0b72>] ? getname_flags+0x72/0x120 [ 199.698611] [<c10e4450>] do_sys_open+0xf0/0x1c0 [ 199.698617] [<c11fcc08>] ? trace_hardirqs_on_thunk+0xc/0x10 [ 199.698623] [<c10e458e>] sys_open+0x2e/0x40 [ 199.698628] [<c144c990>] sysenter_do_call+0x12/0x36 [ 199.698632] Code: 85 89 00 00 00 8b 16 8b 4d c0 c1 e2 08 c7 44 24 14 88 13 00 00 81 ca 00 00 00 80 c7 44 24 10 00 00 00 00 c7 44 24 0c 00 00 00 00 <0f> b7 41 78 31 c9 89 44 24 08 c7 44 24 04 00 00 00 00 c7 04 24 [ 199.698884] EIP: [<f811a089>] ftdi_open+0x59/0xe0 [ftdi_sio] SS:ESP 0068:f515dcfc [ 199.698893] CR2: 0000000000000078 [ 199.698925] ---[ end trace 77c43ec023940cff ]--- Reported-and-tested-by: Ken Huang <csuhgw@gmail.com> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: cdc-wdm: fix lockup on error in wdm_readBjørn Mork
commit b086b6b10d9f182cd8d2f0dcfd7fd11edba93fc9 upstream. Clear the WDM_READ flag on empty reads to avoid running forever in an infinite tight loop, causing lockups: Jul 1 21:58:11 nemi kernel: [ 3658.898647] qmi_wwan 2-1:1.2: Unexpected error -71 Jul 1 21:58:36 nemi kernel: [ 3684.072021] BUG: soft lockup - CPU#0 stuck for 23s! [qmi.pl:12235] Jul 1 21:58:36 nemi kernel: [ 3684.072212] CPU 0 Jul 1 21:58:36 nemi kernel: [ 3684.072355] Jul 1 21:58:36 nemi kernel: [ 3684.072367] Pid: 12235, comm: qmi.pl Tainted: P O 3.5.0-rc2+ #13 LENOVO 2776LEG/2776LEG Jul 1 21:58:36 nemi kernel: [ 3684.072383] RIP: 0010:[<ffffffffa0635008>] [<ffffffffa0635008>] spin_unlock_irq+0x8/0xc [cdc_wdm] Jul 1 21:58:36 nemi kernel: [ 3684.072388] RSP: 0018:ffff88022dca1e70 EFLAGS: 00000282 Jul 1 21:58:36 nemi kernel: [ 3684.072393] RAX: ffff88022fc3f650 RBX: ffffffff811c56f7 RCX: 00000001000ce8c1 Jul 1 21:58:36 nemi kernel: [ 3684.072398] RDX: 0000000000000010 RSI: 000000000267d810 RDI: ffff88022fc3f650 Jul 1 21:58:36 nemi kernel: [ 3684.072403] RBP: ffff88022dca1eb0 R08: ffffffffa063578e R09: 0000000000000000 Jul 1 21:58:36 nemi kernel: [ 3684.072407] R10: 0000000000000008 R11: 0000000000000246 R12: 0000000000000002 Jul 1 21:58:36 nemi kernel: [ 3684.072412] R13: 0000000000000246 R14: ffffffff00000002 R15: ffff8802281d8c88 Jul 1 21:58:36 nemi kernel: [ 3684.072418] FS: 00007f666a260700(0000) GS:ffff88023bc00000(0000) knlGS:0000000000000000 Jul 1 21:58:36 nemi kernel: [ 3684.072423] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 Jul 1 21:58:36 nemi kernel: [ 3684.072428] CR2: 000000000270d9d8 CR3: 000000022e865000 CR4: 00000000000007f0 Jul 1 21:58:36 nemi kernel: [ 3684.072433] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 Jul 1 21:58:36 nemi kernel: [ 3684.072438] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Jul 1 21:58:36 nemi kernel: [ 3684.072444] Process qmi.pl (pid: 12235, threadinfo ffff88022dca0000, task ffff88022ff76380) Jul 1 21:58:36 nemi kernel: [ 3684.072448] Stack: Jul 1 21:58:36 nemi kernel: [ 3684.072458] ffffffffa063592e 0000000100020000 ffff88022fc3f650 ffff88022fc3f6a8 Jul 1 21:58:36 nemi kernel: [ 3684.072466] 0000000000000200 0000000100000000 000000000267d810 0000000000000000 Jul 1 21:58:36 nemi kernel: [ 3684.072475] 0000000000000000 ffff880212cfb6d0 0000000000000200 ffff880212cfb6c0 Jul 1 21:58:36 nemi kernel: [ 3684.072479] Call Trace: Jul 1 21:58:36 nemi kernel: [ 3684.072489] [<ffffffffa063592e>] ? wdm_read+0x1a0/0x263 [cdc_wdm] Jul 1 21:58:36 nemi kernel: [ 3684.072500] [<ffffffff8110adb7>] ? vfs_read+0xa1/0xfb Jul 1 21:58:36 nemi kernel: [ 3684.072509] [<ffffffff81040589>] ? alarm_setitimer+0x35/0x64 Jul 1 21:58:36 nemi kernel: [ 3684.072517] [<ffffffff8110aec7>] ? sys_read+0x45/0x6e Jul 1 21:58:36 nemi kernel: [ 3684.072525] [<ffffffff813725f9>] ? system_call_fastpath+0x16/0x1b Jul 1 21:58:36 nemi kernel: [ 3684.072557] Code: <66> 66 90 c3 83 ff ed 89 f8 74 16 7f 06 83 ff a1 75 0a c3 83 ff f4 The WDM_READ flag is normally cleared by wdm_int_callback before resubmitting the read urb, and set by wdm_in_callback when this urb returns with data or an error. But a crashing device may cause both a read error and cancelling all urbs. Make sure that the flag is cleared by wdm_read if the buffer is empty. We don't clear the flag on errors, as there may be pending data in the buffer which should be processed. The flag will instead be cleared on the next wdm_read call. Signed-off-by: Bjørn Mork <bjorn@mork.no> Acked-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: kaweth.c: use GFP_ATOMIC under spin_lockDan Carpenter
commit e4c7f259c5be99dcfc3d98f913590663b0305bf8 upstream. The problem is that we call this with a spin lock held. The call tree is: kaweth_start_xmit() holds kaweth->device_lock. -> kaweth_async_set_rx_mode() -> kaweth_control() -> kaweth_internal_control_msg() The kaweth_internal_control_msg() function is only called from kaweth_control() which used GFP_ATOMIC for its allocations. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: echi-dbgp: increase the controller wait time to come out of halt.Colin Ian King
commit f96a4216e85050c0a9d41a41ecb0ae9d8e39b509 upstream. The default 10 microsecond delay for the controller to come out of halt in dbgp_ehci_startup is too short, so increase it to 1 millisecond. This is based on emperical testing on various USB debug ports on modern machines such as a Lenovo X220i and an Ivybridge development platform that needed to wait ~450-950 microseconds. Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10usb: serial: mos7840: Fixup mos7840_chars_in_buffer()Mark Ferrell
commit 5c263b92f828af6a8cf54041db45ceae5af8f2ab upstream. * Use the buffer content length as opposed to the total buffer size. This can be a real problem when using the mos7840 as a usb serial-console as all kernel output is truncated during boot. Signed-off-by: Mark Ferrell <mferrell@uplogix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: CDC ACM: Fix NULL pointer dereferenceSven Schnelle
commit 99f347caa4568cb803862730b3b1f1942639523f upstream. If a device specifies zero endpoints in its interface descriptor, the kernel oopses in acm_probe(). Even though that's clearly an invalid descriptor, we should test wether we have all endpoints. This is especially bad as this oops can be triggered by just plugging a USB device in. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: serial: ftdi_sio: Handle the old_termios == 0 case e.g. uart_resume_port()Andrew Worsley
commit c515598e0f5769916c31c00392cc2bfe6af74e55 upstream. Handle null old_termios in ftdi_set_termios() calls from uart_resume_port(). Signed-off-by: Andrew Worsley <amworsley@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: cdc-wdm: fix buffer overflowOliver Neukum
commit c0f5ecee4e741667b2493c742b60b6218d40b3aa upstream. The buffer for responses must not overflow. If this would happen, set a flag, drop the data and return an error after user space has read all remaining data. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> [PG: minor adjustment since RESET from 880442027569 isn't in .34] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: io_ti: Fix NULL dereference in chase_port()Wolfgang Frisch
commit 1ee0a224bc9aad1de496c795f96bc6ba2c394811 upstream. The tty is NULL when the port is hanging up. chase_port() needs to check for this. This patch is intended for stable series. The behavior was observed and tested in Linux 3.2 and 3.7.1. Johan Hovold submitted a more elaborate patch for the mainline kernel. [ 56.277883] usb 1-1: edge_bulk_in_callback - nonzero read bulk status received: -84 [ 56.278811] usb 1-1: USB disconnect, device number 3 [ 56.278856] usb 1-1: edge_bulk_in_callback - stopping read! [ 56.279562] BUG: unable to handle kernel NULL pointer dereference at 00000000000001c8 [ 56.280536] IP: [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35 [ 56.281212] PGD 1dc1b067 PUD 1e0f7067 PMD 0 [ 56.282085] Oops: 0002 [#1] SMP [ 56.282744] Modules linked in: [ 56.283512] CPU 1 [ 56.283512] Pid: 25, comm: khubd Not tainted 3.7.1 #1 innotek GmbH VirtualBox/VirtualBox [ 56.283512] RIP: 0010:[<ffffffff8144e62a>] [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35 [ 56.283512] RSP: 0018:ffff88001fa99ab0 EFLAGS: 00010046 [ 56.283512] RAX: 0000000000000046 RBX: 00000000000001c8 RCX: 0000000000640064 [ 56.283512] RDX: 0000000000010000 RSI: ffff88001fa99b20 RDI: 00000000000001c8 [ 56.283512] RBP: ffff88001fa99b20 R08: 0000000000000000 R09: 0000000000000000 [ 56.283512] R10: 0000000000000000 R11: ffffffff812fcb4c R12: ffff88001ddf53c0 [ 56.283512] R13: 0000000000000000 R14: 00000000000001c8 R15: ffff88001e19b9f4 [ 56.283512] FS: 0000000000000000(0000) GS:ffff88001fd00000(0000) knlGS:0000000000000000 [ 56.283512] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 56.283512] CR2: 00000000000001c8 CR3: 000000001dc51000 CR4: 00000000000006e0 [ 56.283512] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 56.283512] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 56.283512] Process khubd (pid: 25, threadinfo ffff88001fa98000, task ffff88001fa94f80) [ 56.283512] Stack: [ 56.283512] 0000000000000046 00000000000001c8 ffffffff810578ec ffffffff812fcb4c [ 56.283512] ffff88001e19b980 0000000000002710 ffffffff812ffe81 0000000000000001 [ 56.283512] ffff88001fa94f80 0000000000000202 ffffffff00000001 0000000000000296 [ 56.283512] Call Trace: [ 56.283512] [<ffffffff810578ec>] ? add_wait_queue+0x12/0x3c [ 56.283512] [<ffffffff812fcb4c>] ? usb_serial_port_work+0x28/0x28 [ 56.283512] [<ffffffff812ffe81>] ? chase_port+0x84/0x2d6 [ 56.283512] [<ffffffff81063f27>] ? try_to_wake_up+0x199/0x199 [ 56.283512] [<ffffffff81263a5c>] ? tty_ldisc_hangup+0x222/0x298 [ 56.283512] [<ffffffff81300171>] ? edge_close+0x64/0x129 [ 56.283512] [<ffffffff810612f7>] ? __wake_up+0x35/0x46 [ 56.283512] [<ffffffff8106135b>] ? should_resched+0x5/0x23 [ 56.283512] [<ffffffff81264916>] ? tty_port_shutdown+0x39/0x44 [ 56.283512] [<ffffffff812fcb4c>] ? usb_serial_port_work+0x28/0x28 [ 56.283512] [<ffffffff8125d38c>] ? __tty_hangup+0x307/0x351 [ 56.283512] [<ffffffff812e6ddc>] ? usb_hcd_flush_endpoint+0xde/0xed [ 56.283512] [<ffffffff8144e625>] ? _raw_spin_lock_irqsave+0x14/0x35 [ 56.283512] [<ffffffff812fd361>] ? usb_serial_disconnect+0x57/0xc2 [ 56.283512] [<ffffffff812ea99b>] ? usb_unbind_interface+0x5c/0x131 [ 56.283512] [<ffffffff8128d738>] ? __device_release_driver+0x7f/0xd5 [ 56.283512] [<ffffffff8128d9cd>] ? device_release_driver+0x1a/0x25 [ 56.283512] [<ffffffff8128d393>] ? bus_remove_device+0xd2/0xe7 [ 56.283512] [<ffffffff8128b7a3>] ? device_del+0x119/0x167 [ 56.283512] [<ffffffff812e8d9d>] ? usb_disable_device+0x6a/0x180 [ 56.283512] [<ffffffff812e2ae0>] ? usb_disconnect+0x81/0xe6 [ 56.283512] [<ffffffff812e4435>] ? hub_thread+0x577/0xe82 [ 56.283512] [<ffffffff8144daa7>] ? __schedule+0x490/0x4be [ 56.283512] [<ffffffff8105798f>] ? abort_exclusive_wait+0x79/0x79 [ 56.283512] [<ffffffff812e3ebe>] ? usb_remote_wakeup+0x2f/0x2f [ 56.283512] [<ffffffff812e3ebe>] ? usb_remote_wakeup+0x2f/0x2f [ 56.283512] [<ffffffff810570b4>] ? kthread+0x81/0x89 [ 56.283512] [<ffffffff81057033>] ? __kthread_parkme+0x5c/0x5c [ 56.283512] [<ffffffff8145387c>] ? ret_from_fork+0x7c/0xb0 [ 56.283512] [<ffffffff81057033>] ? __kthread_parkme+0x5c/0x5c [ 56.283512] Code: 8b 7c 24 08 e8 17 0b c3 ff 48 8b 04 24 48 83 c4 10 c3 53 48 89 fb 41 50 e8 e0 0a c3 ff 48 89 04 24 e8 e7 0a c3 ff ba 00 00 01 00 <f0> 0f c1 13 48 8b 04 24 89 d1 c1 ea 10 66 39 d1 74 07 f3 90 66 [ 56.283512] RIP [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35 [ 56.283512] RSP <ffff88001fa99ab0> [ 56.283512] CR2: 00000000000001c8 [ 56.283512] ---[ end trace 49714df27e1679ce ]--- Signed-off-by: Wolfgang Frisch <wfpub@roembden.net> Cc: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: garmin_gps: fix memory leak on disconnectJohan Hovold
commit 618aa1068df29c37a58045fe940f9106664153fd upstream. Remove bogus disconnect test introduced by 95bef012e ("USB: more serial drivers writing after disconnect") which prevented queued data from being freed on disconnect. The possible IO it was supposed to prevent is long gone. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: mos7840: fix port-device leak in error pathJohan Hovold
commit 3eb55cc4ed88eee3b5230f66abcdbd2a91639eda upstream. The driver set the usb-serial port pointers to NULL on errors in attach, effectively preventing usb-serial core from decrementing the port ref counters and releasing the port devices and associated data. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: mos7840: fix urb leak at releaseJohan Hovold
commit 65a4cdbb170e4ec1a7fa0e94936d47e24a17b0e8 upstream. Make sure control urb is freed at release. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: serial: Fix memory leak in sierra_release()Lennart Sorensen
commit f7bc5051667b74c3861f79eed98c60d5c3b883f7 upstream. I found a memory leak in sierra_release() (well sierra_probe() I guess) that looses 8 bytes each time the driver releases a device. Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Acked-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: whiteheat: fix memory leak in error pathJohan Hovold
commit c129197c99550d356cf5f69b046994dd53cd1b9d upstream. Make sure command buffer is deallocated in case of errors during attach. Cc: <support@connecttech.com> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10USB: EHCI: go back to using the system clock for QH unlinksAlan Stern
commit 004c19682884d4f40000ce1ded53f4a1d0b18206 upstream. This patch (as1477) fixes a problem affecting a few types of EHCI controller. Contrary to what one might expect, these controllers automatically stop their internal frame counter when no ports are enabled. Since ehci-hcd currently relies on the frame counter for determining when it should unlink QHs from the async schedule, those controllers run into trouble: The frame counter stops and the QHs never get unlinked. Some systems have also experienced other problems traced back to commit b963801164618e25fbdc0cd452ce49c3628b46c8 (USB: ehci-hcd unlink speedups), which made the original switch from using the system clock to using the frame counter. It never became clear what the reason was for these problems, but evidently it is related to use of the frame counter. To fix all these problems, this patch more or less reverts that commit and goes back to using the system clock. But this can't be done cleanly because other changes have since been made to the scan_async() subroutine. One of these changes involved the tricky logic that tries to avoid rescanning QHs that have already been seen when the scanning loop is restarted, which happens whenever an URB is given back. Switching back to clock-based unlinks would make this logic even more complicated. Therefore the new code doesn't rescan the entire async list whenever a giveback occurs. Instead it rescans only the current QH and continues on from there. This requires the use of a separate pointer to keep track of the next QH to scan, since the current QH may be unlinked while the scanning is in progress. That new pointer must be global, so that it can be adjusted forward whenever the _next_ QH gets unlinked. (uhci-hcd uses this same trick.) Simplification of the scanning loop removes a level of indentation, which accounts for the size of the patch. The amount of code changed is relatively small, and it isn't exactly a reversion of the b963801164 commit. This fixes Bugzilla #32432. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Matej Kenda <matejken@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10xhci: Don't write zeroed pointers to xHC registers.Sarah Sharp
commit 159e1fcc9a60fc7daba23ee8fcdb99799de3fe84 upstream. When xhci_mem_cleanup() is called, we can't be sure if the xHC is actually halted. We can ask the xHC to halt by writing to the RUN bit in the command register, but that might timeout due to a HW hang. If the host controller is still running, we should not write zeroed values to the event ring dequeue pointers or base tables, the DCBAA pointers, or the command ring pointers. Eric Fu reports his VIA VL800 host accesses the event ring pointers after a failed register restore on resume from suspend. The hypothesis is that the host never actually halted before the register write to change the event ring pointer to zero. Remove all writes of zeroed values to pointer registers in xhci_mem_cleanup(). Instead, make all callers of the function reset the host controller first, which will reset those registers to zero. xhci_mem_init() is the only caller that doesn't first halt and reset the host controller before calling xhci_mem_cleanup(). This should be backported to kernels as old as 2.6.32. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Tested-by: Elric Fu <elricfu1@gmail.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10xHCI: Correct the #define XHCI_LEGACY_DISABLE_SMIAlex He
commit 95018a53f7653e791bba1f54c8d75d9cb700d1bd upstream. Re-define XHCI_LEGACY_DISABLE_SMI and used it in right way. All SMI enable bits will be cleared to zero and flag bits 29:31 are also cleared to zero. Other bits should be presvered as Table 146. This patch should be backported to kernels as old as 2.6.31. Signed-off-by: Alex He <alex.he@amd.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10xhci: Reset reserved command ring TRBs on cleanup.Sarah Sharp
commit 33b2831ac870d50cc8e01c317b07fb1e69c13fe1 upstream. When the xHCI driver needs to clean up memory (perhaps due to a failed register restore on resume from S3 or resume from S4), it needs to reset the number of reserved TRBs on the command ring to zero. Otherwise, several resume cycles (about 30) with a UAS device attached will continually increment the number of reserved TRBs, until all command submissions fail because there isn't enough room on the command ring. This patch should be backported to kernels as old as 2.6.32, that contain the commit 913a8a344ffcaf0b4a586d6662a2c66a7106557d "USB: xhci: Change how xHCI commands are handled." Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10xhci: Increase reset timeout for Renesas 720201 host.Sarah Sharp
commit 22ceac191211cf6688b1bf6ecd93c8b6bf80ed9b upstream. The NEC/Renesas 720201 xHCI host controller does not complete its reset within 250 milliseconds. In fact, it takes about 9 seconds to reset the host controller, and 1 second for the host to be ready for doorbell rings. Extend the reset and CNR polling timeout to 10 seconds each. This patch should be backported to kernels as old as 2.6.31, that contain the commit 66d4eadd8d067269ea8fead1a50fe87c2979a80d "USB: xhci: BIOS handoff and HW initialization." Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Reported-by: Edwin Klein Mentink <e.kleinmentink@zonnet.nl> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10xhci: Make handover code more robustMatthew Garrett
commit e955a1cd086de4d165ae0f4c7be7289d84b63bdc upstream. My test platform (Intel DX79SI) boots reliably under BIOS, but frequently crashes when booting via UEFI. I finally tracked this down to the xhci handoff code. It seems that reads from the device occasionally just return 0xff, resulting in xhci_find_next_cap_offset generating a value that's larger than the resource region. We then oops when attempting to read the value. Sanity checking that value lets us avoid the crash. I've no idea what's causing the underlying problem, and xhci still doesn't actually *work* even with this, but the machine at least boots which will probably make further debugging easier. This should be backported to kernels as old as 2.6.31, that contain the commit 66d4eadd8d067269ea8fead1a50fe87c2979a80d "USB: xhci: BIOS handoff and HW initialization." Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10Bluetooth: hci_ldisc: fix NULL-pointer dereference on tty_closeJohan Hovold
commit 33b69bf80a3704d45341928e4ff68b6ebd470686 upstream. Do not close protocol driver until device has been unregistered. This fixes a race between tty_close and hci_dev_open which can result in a NULL-pointer dereference. The line discipline closes the protocol driver while we may still have hci_dev_open sleeping on the req_lock mutex resulting in a NULL-pointer dereference when lock is acquired and hci_init_req called. Bug is 100% reproducible using hciattach and a disconnected serial port: 0. # hciattach -n ttyO1 any noflow 1. hci_dev_open called from hci_power_on grabs req lock 2. hci_init_req executes but device fails to initialise (times out eventually) 3. hci_dev_open is called from hci_sock_ioctl and sleeps on req lock 4. hci_uart_tty_close detaches protocol driver and cancels init req 5. hci_dev_open (1) releases req lock 6. hci_dev_open (3) grabs req lock, calls hci_init_req, which triggers oops when request is prepared in hci_uart_send_frame [ 137.201263] Unable to handle kernel NULL pointer dereference at virtual address 00000028 [ 137.209838] pgd = c0004000 [ 137.212677] [00000028] *pgd=00000000 [ 137.216430] Internal error: Oops: 17 [#1] [ 137.220642] Modules linked in: [ 137.223846] CPU: 0 Tainted: G W (3.3.0-rc6-dirty #406) [ 137.230529] PC is at __lock_acquire+0x5c/0x1ab0 [ 137.235290] LR is at lock_acquire+0x9c/0x128 [ 137.239776] pc : [<c0071490>] lr : [<c00733f8>] psr: 20000093 [ 137.239776] sp : cf869dd8 ip : c0529554 fp : c051c730 [ 137.251800] r10: 00000000 r9 : cf8673c0 r8 : 00000080 [ 137.257293] r7 : 00000028 r6 : 00000002 r5 : 00000000 r4 : c053fd70 [ 137.264129] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : 00000001 [ 137.270965] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel [ 137.278717] Control: 10c5387d Table: 8f0f4019 DAC: 00000015 [ 137.284729] Process kworker/u:1 (pid: 7, stack limit = 0xcf8682e8) [ 137.291229] Stack: (0xcf869dd8 to 0xcf86a000) [ 137.295776] 9dc0: c0529554 00000000 [ 137.304351] 9de0: cf8673c0 cf868000 d03ea1ef cf868000 000001ef 00000470 00000000 00000002 [ 137.312927] 9e00: cf8673c0 00000001 c051c730 c00716ec 0000000c 00000440 c0529554 00000001 [ 137.321533] 9e20: c051c730 cf868000 d03ea1f3 00000000 c053b978 00000000 00000028 cf868000 [ 137.330078] 9e40: 00000000 00000000 00000002 00000000 00000000 c00733f8 00000002 00000080 [ 137.338684] 9e60: 00000000 c02a1d50 00000000 00000001 60000013 c0969a1c 60000093 c053b96c [ 137.347259] 9e80: 00000002 00000018 20000013 c02a1d50 cf0ac000 00000000 00000002 cf868000 [ 137.355834] 9ea0: 00000089 c0374130 00000002 00000000 c02a1d50 cf0ac000 0000000c cf0fc540 [ 137.364410] 9ec0: 00000018 c02a1d50 cf0fc540 00000000 cf0fc540 c0282238 c028220c cf178d80 [ 137.372985] 9ee0: 127525d8 c02821cc 9a1fa451 c032727c 9a1fa451 127525d8 cf0fc540 cf0ac4ec [ 137.381561] 9f00: cf0ac000 cf0fc540 cf0ac584 c03285f4 c0328580 cf0ac4ec cf85c740 c05510cc [ 137.390136] 9f20: ce825400 c004c914 00000002 00000000 c004c884 ce8254f5 cf869f48 00000000 [ 137.398712] 9f40: c0328580 ce825415 c0a7f914 c061af64 00000000 c048cf3c cf8673c0 cf85c740 [ 137.407287] 9f60: c05510cc c051a66c c05510ec c05510c4 cf85c750 cf868000 00000089 c004d6ac [ 137.415863] 9f80: 00000000 c0073d14 00000001 cf853ed8 cf85c740 c004d558 00000013 00000000 [ 137.424438] 9fa0: 00000000 00000000 00000000 c00516b0 00000000 00000000 cf85c740 00000000 [ 137.433013] 9fc0: 00000001 dead4ead ffffffff ffffffff c0551674 00000000 00000000 c0450aa4 [ 137.441589] 9fe0: cf869fe0 cf869fe0 cf853ed8 c005162c c0013b30 c0013b30 00ffff00 00ffff00 [ 137.450164] [<c0071490>] (__lock_acquire+0x5c/0x1ab0) from [<c00733f8>] (lock_acquire+0x9c/0x128) [ 137.459503] [<c00733f8>] (lock_acquire+0x9c/0x128) from [<c0374130>] (_raw_spin_lock_irqsave+0x44/0x58) [ 137.469360] [<c0374130>] (_raw_spin_lock_irqsave+0x44/0x58) from [<c02a1d50>] (skb_queue_tail+0x18/0x48) [ 137.479339] [<c02a1d50>] (skb_queue_tail+0x18/0x48) from [<c0282238>] (h4_enqueue+0x2c/0x34) [ 137.488189] [<c0282238>] (h4_enqueue+0x2c/0x34) from [<c02821cc>] (hci_uart_send_frame+0x34/0x68) [ 137.497497] [<c02821cc>] (hci_uart_send_frame+0x34/0x68) from [<c032727c>] (hci_send_frame+0x50/0x88) [ 137.507171] [<c032727c>] (hci_send_frame+0x50/0x88) from [<c03285f4>] (hci_cmd_work+0x74/0xd4) [ 137.516204] [<c03285f4>] (hci_cmd_work+0x74/0xd4) from [<c004c914>] (process_one_work+0x1a0/0x4ec) [ 137.525604] [<c004c914>] (process_one_work+0x1a0/0x4ec) from [<c004d6ac>] (worker_thread+0x154/0x344) [ 137.535278] [<c004d6ac>] (worker_thread+0x154/0x344) from [<c00516b0>] (kthread+0x84/0x90) [ 137.543975] [<c00516b0>] (kthread+0x84/0x90) from [<c0013b30>] (kernel_thread_exit+0x0/0x8) [ 137.552734] Code: e59f4e5c e5941000 e3510000 0a000031 (e5971000) [ 137.559234] ---[ end trace 1b75b31a2719ed1e ]--- Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10Bluetooth: add NULL pointer check in HCIJun Nie
commit d9319560b86839506c2011346b1f2e61438a3c73 upstream. If we fail to find a hci device pointer in hci_uart, don't try to deref the NULL one we do have. Signed-off-by: Jun Nie <njun@marvell.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10IPoIB: Fix use-after-free of multicast objectPatrick McHardy
commit bea1e22df494a729978e7f2c54f7bda328f74bc3 upstream. Fix a crash in ipoib_mcast_join_task(). (with help from Or Gerlitz) Commit c8c2afe360b7 ("IPoIB: Use rtnl lock/unlock when changing device flags") added a call to rtnl_lock() in ipoib_mcast_join_task(), which is run from the ipoib_workqueue, and hence the workqueue can't be flushed from the context of ipoib_stop(). In the current code, ipoib_stop() (which doesn't flush the workqueue) calls ipoib_mcast_dev_flush(), which goes and deletes all the multicast entries. This takes place without any synchronization with a possible running instance of ipoib_mcast_join_task() for the same ipoib device, leading to a crash due to NULL pointer dereference. Fix this by making sure that the workqueue is flushed before ipoib_mcast_dev_flush() is called. To make that possible, we move the RTNL-lock wrapped code to ipoib_mcast_join_finish(). Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10bnx2i: Fixed NULL ptr deference for 1G bnx2 Linux iSCSI offloadEddie Wai
commit d6532207116307eb7ecbfa7b9e02c53230096a50 upstream. This patch fixes the following kernel panic invoked by uninitialized fields in the chip initialization for the 1G bnx2 iSCSI offload. One of the bits in the chip initialization is being used by the latest firmware to control overflow packets. When this control bit gets enabled erroneously, it would ultimately result in a bad packet placement which would cause the bnx2 driver to dereference a NULL ptr in the placement handler. This can happen under certain stress I/O environment under the Linux iSCSI offload operation. This change only affects Broadcom's 5709 chipset. Unable to handle kernel NULL pointer dereference at 0000000000000008 RIP: [<ffffffff881f0e7d>] :bnx2:bnx2_poll_work+0xd0d/0x13c5 Pid: 0, comm: swapper Tainted: G ---- 2.6.18-333.el5debug #2 RIP: 0010:[<ffffffff881f0e7d>] [<ffffffff881f0e7d>] :bnx2:bnx2_poll_work+0xd0d/0x13c5 RSP: 0018:ffff8101b575bd50 EFLAGS: 00010216 RAX: 0000000000000005 RBX: ffff81007c5fb180 RCX: 0000000000000000 RDX: 0000000000000ffc RSI: 00000000817e8000 RDI: 0000000000000220 RBP: ffff81015bbd7ec0 R08: ffff8100817e9000 R09: 0000000000000000 R10: ffff81007c5fb180 R11: 00000000000000c8 R12: 000000007a25a010 R13: 0000000000000000 R14: 0000000000000005 R15: ffff810159f80558 FS: 0000000000000000(0000) GS:ffff8101afebc240(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: 0000000000000008 CR3: 0000000000201000 CR4: 00000000000006a0 Process swapper (pid: 0, threadinfo ffff8101b5754000, task ffff8101afebd820) Stack: 000000000000000b ffff810159f80000 0000000000000040 ffff810159f80520 ffff810159f80500 00cf00cf8008e84b ffffc200100939e0 ffff810009035b20 0000502900000000 000000be00000001 ffff8100817e7810 00d08101b575bea8 Call Trace: <IRQ> [<ffffffff8008e0d0>] show_schedstat+0x1c2/0x25b [<ffffffff881f1886>] :bnx2:bnx2_poll+0xf6/0x231 [<ffffffff8000c9b9>] net_rx_action+0xac/0x1b1 [<ffffffff800125a0>] __do_softirq+0x89/0x133 [<ffffffff8005e30c>] call_softirq+0x1c/0x28 [<ffffffff8006d5de>] do_softirq+0x2c/0x7d [<ffffffff8006d46e>] do_IRQ+0xee/0xf7 [<ffffffff8005d625>] ret_from_intr+0x0/0xa <EOI> [<ffffffff801a5780>] acpi_processor_idle_simple+0x1c5/0x341 [<ffffffff801a573d>] acpi_processor_idle_simple+0x182/0x341 [<ffffffff801a55bb>] acpi_processor_idle_simple+0x0/0x341 [<ffffffff80049560>] cpu_idle+0x95/0xb8 [<ffffffff80078b1c>] start_secondary+0x479/0x488 Signed-off-by: Eddie Wai <eddie.wai@broadcom.com> Reviewed-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10fix crash in scsi_dispatch_cmd()James Bottomley
commit bfe159a51203c15d23cb3158fffdc25ec4b4dda1 upstream. USB surprise removal of sr is triggering an oops in scsi_dispatch_command(). What seems to be happening is that USB is hanging on to a queue reference until the last close of the upper device, so the crash is caused by surprise remove of a mounted CD followed by attempted unmount. The problem is that USB doesn't issue its final commands as part of the SCSI teardown path, but on last close when the block queue is long gone. The long term fix is probably to make sr do the teardown in the same way as sd (so remove all the lower bits on ejection, but keep the upper disk alive until last close of user space). However, the current oops can be simply fixed by not allowing any commands to be sent to a dead queue. Signed-off-by: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10fix Null pointer dereference on disk errorXiaotian Feng
commit 26cd4d65deba587f3cf2329b6869ce02bcbe68ec upstream. Following oops were observed when disk error happened: [ 4272.896937] sd 0:0:0:0: [sda] Unhandled error code [ 4272.896939] sd 0:0:0:0: [sda] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK [ 4272.896942] sd 0:0:0:0: [sda] CDB: Read(10): 28 00 00 5a de a7 00 00 08 00 [ 4272.896951] end_request: I/O error, dev sda, sector 5955239 [ 4291.574947] BUG: unable to handle kernel NULL pointer dereference at (null) [ 4291.658305] IP: [] ahci_activity_show+0x1/0x40 [ 4291.730090] PGD 76dbbc067 PUD 6c4fba067 PMD 0 [ 4291.783408] Oops: 0000 [#1] SMP [ 4291.822100] last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/sw_activity [ 4291.934235] CPU 9 [ 4291.958301] Pid: 27942, comm: hwinfo ...... ata_scsi_find_dev could return NULL, so ata_scsi_activity_{show,store} should check if atadev is NULL. Signed-off-by: Xiaotian Feng <dannyfeng@tencent.com> Cc: James Bottomley <JBottomley@Parallels.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10w1: fix oops when w1_search is called from netlink connectorMarcin Jurkowski
commit 9d1817cab2f030f6af360e961cc69bb1da8ad765 upstream. On Sat, Mar 02, 2013 at 10:45:10AM +0100, Sven Geggus wrote: > This is the bad commit I found doing git bisect: > 04f482faf50535229a5a5c8d629cf963899f857c is the first bad commit > commit 04f482faf50535229a5a5c8d629cf963899f857c > Author: Patrick McHardy <kaber@trash.net> > Date: Mon Mar 28 08:39:36 2011 +0000 Good job. I was too lazy to bisect for bad commit;) Reading the code I found problematic kthread_should_stop call from netlink connector which causes the oops. After applying a patch, I've been testing owfs+w1 setup for nearly two days and it seems to work very reliable (no hangs, no memleaks etc). More detailed description and possible fix is given below: Function w1_search can be called from either kthread or netlink callback. While the former works fine, the latter causes oops due to kthread_should_stop invocation. This patch adds a check if w1_search is serving netlink command, skipping kthread_should_stop invocation if so. Signed-off-by: Marcin Jurkowski <marcin1j@gmail.com> Acked-by: Evgeniy Polyakov <zbr@ioremap.net> Cc: Josh Boyer <jwboyer@gmail.com> Tested-by: Sven Geggus <lists@fuchsschwanzdomain.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10drivers/char/ipmi: memcpy, need additional 2 bytes to avoid memory overflowChen Gang
commit a5f2b3d6a738e7d4180012fe7b541172f8c8dcea upstream. When calling memcpy, read_data and write_data need additional 2 bytes. write_data: for checking: "if (size > IPMI_MAX_MSG_LENGTH)" for operating: "memcpy(bt->write_data + 3, data + 1, size - 1)" read_data: for checking: "if (msg_len < 3 || msg_len > IPMI_MAX_MSG_LENGTH)" for operating: "memcpy(data + 2, bt->read_data + 4, msg_len - 2)" Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10serial: 8250, increase PASS_LIMITJiri Slaby
commit e7328ae1848966181a7ac47e8ae6cddbd2cf55f3 upstream. With virtual machines like qemu, it's pretty common to see "too much work for irq4" messages nowadays. This happens when a bunch of output is printed on the emulated serial console. This is caused by too low PASS_LIMIT. When ISR loops more than the limit, it spits the message. I've been using a kernel with doubled the limit and I couldn't see no problems. Maybe it's time to get rid of the message now? Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> [PG: drivers/tty/serial/8250.c ---> drivers/serial/8250.c in 2.6.34] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10ACPI / cpuidle: Fix NULL pointer issues when cpuidle is disabledKonrad Rzeszutek Wilk
commit b88a634a903d9670aa5f2f785aa890628ce0dece upstream. If cpuidle is disabled, that means that: per_cpu(acpi_cpuidle_device, pr->id) is set to NULL as the acpi_processor_power_init ends up failing at retval = cpuidle_register_driver(&acpi_idle_driver) (in acpi_processor_power_init) and never sets the per_cpu idle device. So when acpi_processor_hotplug on CPU online notification tries to reference said device it crashes: cpu 3 spinlock event irq 62 BUG: unable to handle kernel NULL pointer dereference at 0000000000000004 IP: [<ffffffff81381013>] acpi_processor_setup_cpuidle_cx+0x3f/0x105 PGD a259b067 PUD ab38b067 PMD 0 Oops: 0002 [#1] SMP odules linked in: dm_multipath dm_mod xen_evtchn iscsi_boot_sysfs iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi libcrc32c crc32c nouveau mxm_wmi wmi radeon ttm sg sr_mod sd_mod cdrom ata_generic ata_piix libata crc32c_intel scsi_mod atl1c i915 fbcon tileblit font bitblit softcursor drm_kms_helper video xen_blkfront xen_netfront fb_sys_fops sysimgblt sysfillrect syscopyarea xenfs xen_privcmd mperf CPU 1 Pid: 3047, comm: bash Not tainted 3.8.0-rc3upstream-00250-g165c029 #1 MSI MS-7680/H61M-P23 (MS-7680) RIP: e030:[<ffffffff81381013>] [<ffffffff81381013>] acpi_processor_setup_cpuidle_cx+0x3f/0x105 RSP: e02b:ffff88001742dca8 EFLAGS: 00010202 RAX: 0000000000010be9 RBX: ffff8800a0a61800 RCX: ffff880105380000 RDX: 0000000000000003 RSI: 0000000000000200 RDI: ffff8800a0a61800 RBP: ffff88001742dce8 R08: ffffffff81812360 R09: 0000000000000200 R10: aaaaaaaaaaaaaaaa R11: 0000000000000001 R12: ffff8800a0a61800 R13: 00000000ffffff01 R14: 0000000000000000 R15: ffffffff81a907a0 FS: 00007fd6942f7700(0000) GS:ffff880105280000(0000) knlGS:0000000000000000 CS: e033 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000004 CR3: 00000000a6773000 CR4: 0000000000042660 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process bash (pid: 3047, threadinfo ffff88001742c000, task ffff880017944000) Stack: 0000000000000150 ffff880100f59e00 ffff88001742dcd8 ffff8800a0a61800 0000000000000000 00000000ffffff01 0000000000000000 ffffffff81a907a0 ffff88001742dd18 ffffffff813815b1 ffff88001742dd08 ffffffff810ae336 Call Trace: [<ffffffff813815b1>] acpi_processor_hotplug+0x7c/0x9f [<ffffffff810ae336>] ? schedule_delayed_work_on+0x16/0x20 [<ffffffff8137ee8f>] acpi_cpu_soft_notify+0x90/0xca [<ffffffff8166023d>] notifier_call_chain+0x4d/0x70 [<ffffffff810bc369>] __raw_notifier_call_chain+0x9/0x10 [<ffffffff81094a4b>] __cpu_notify+0x1b/0x30 [<ffffffff81652cf7>] _cpu_up+0x103/0x14b [<ffffffff81652e18>] cpu_up+0xd9/0xec [<ffffffff8164a254>] store_online+0x94/0xd0 [<ffffffff814122fb>] dev_attr_store+0x1b/0x20 [<ffffffff81216404>] sysfs_write_file+0xf4/0x170 This patch fixes it. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10Prevent interface errors with Seagate FreeAgent GoFlexDaniel J Blueman
commit c531077f40abc9f2129c4c83a30b3f8d6ce1c0e7 upstream. When using my Seagate FreeAgent GoFlex eSATAp external disk enclosure, interface errors are always seen until 1.5Gbps is negotiated [1]. This occurs using any disk in the enclosure, and when the disk is connected directly with a generic passive eSATAp cable, we see stable 3Gbps operation as expected. Blacklist 3Gbps mode to avoid dataloss and the ~30s delay bus reset and renegotiation incurs. Signed-off-by: Daniel J Blueman <daniel@quora.org> Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10Driver core: treat unregistered bus_types as having no devicesBjorn Helgaas
commit 4fa3e78be7e985ca814ce2aa0c09cbee404efcf7 upstream. A bus_type has a list of devices (klist_devices), but the list and the subsys_private structure that contains it are not initialized until the bus_type is registered with bus_register(). The panic/reboot path has fixups that look up devices in pci_bus_type. If we panic before registering pci_bus_type, the bus_type exists but the list does not, so mach_reboot_fixups() trips over a null pointer and panics again: mach_reboot_fixups pci_get_device .. bus_find_device(&pci_bus_type, ...) bus->p is NULL Joonsoo reported a problem when panicking before PCI was initialized. I think this patch should be sufficient to replace the patch he posted here: https://lkml.org/lkml/2012/12/28/75 ("[PATCH] x86, reboot: skip reboot_fixups in early boot phase") Reported-by: Joonsoo Kim <js1304@gmail.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10tg3: Avoid null pointer dereference in tg3_interrupt in netconsole modeNithin Nayak Sujir
commit 9c13cb8bb477a83b9a3c9e5a5478a4e21294a760 upstream. When netconsole is enabled, logging messages generated during tg3_open can result in a null pointer dereference for the uninitialized tg3 status block. Use the irq_sync flag to disable polling in the early stages. irq_sync is cleared when the driver is enabling interrupts after all initialization is completed. Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com> Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net> [PG: drivers/net/ethernet/broadcom/tg3.c --> drivers/net/tg3.c in .34] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10b43legacy: Fix crash on unload when firmware not availableLarry Finger
commit 2d838bb608e2d1f6cb4280e76748cb812dc822e7 upstream. When b43legacy is loaded without the firmware being available, a following unload generates a kernel NULL pointer dereference BUG as follows: [ 214.330789] BUG: unable to handle kernel NULL pointer dereference at 0000004c [ 214.330997] IP: [<c104c395>] drain_workqueue+0x15/0x170 [ 214.331179] *pde = 00000000 [ 214.331311] Oops: 0000 [#1] SMP [ 214.331471] Modules linked in: b43legacy(-) ssb pcmcia mac80211 cfg80211 af_packet mperf arc4 ppdev sr_mod cdrom sg shpchp yenta_socket pcmcia_rsrc pci_hotplug pcmcia_core battery parport_pc parport floppy container ac button edd autofs4 ohci_hcd ehci_hcd usbcore usb_common thermal processor scsi_dh_rdac scsi_dh_hp_sw scsi_dh_emc scsi_dh_alua scsi_dh fan thermal_sys hwmon ata_generic pata_ali libata [last unloaded: cfg80211] [ 214.333421] Pid: 3639, comm: modprobe Not tainted 3.6.0-rc6-wl+ #163 Source Technology VIC 9921/ALI Based Notebook [ 214.333580] EIP: 0060:[<c104c395>] EFLAGS: 00010246 CPU: 0 [ 214.333687] EIP is at drain_workqueue+0x15/0x170 [ 214.333788] EAX: c162ac40 EBX: cdfb8360 ECX: 0000002a EDX: 00002a2a [ 214.333890] ESI: 00000000 EDI: 00000000 EBP: cd767e7c ESP: cd767e5c [ 214.333957] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 [ 214.333957] CR0: 8005003b CR2: 0000004c CR3: 0c96a000 CR4: 00000090 [ 214.333957] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 [ 214.333957] DR6: ffff0ff0 DR7: 00000400 [ 214.333957] Process modprobe (pid: 3639, ti=cd766000 task=cf802e90 task.ti=cd766000) [ 214.333957] Stack: [ 214.333957] 00000292 cd767e74 c12c5e09 00000296 00000296 cdfb8360 cdfb9220 00000000 [ 214.333957] cd767e90 c104c4fd cdfb8360 cdfb9220 cd682800 cd767ea4 d0c10184 cd682800 [ 214.333957] cd767ea4 cba31064 cd767eb8 d0867908 cba31064 d087e09c cd96f034 cd767ec4 [ 214.333957] Call Trace: [ 214.333957] [<c12c5e09>] ? skb_dequeue+0x49/0x60 [ 214.333957] [<c104c4fd>] destroy_workqueue+0xd/0x150 [ 214.333957] [<d0c10184>] ieee80211_unregister_hw+0xc4/0x100 [mac80211] [ 214.333957] [<d0867908>] b43legacy_remove+0x78/0x80 [b43legacy] [ 214.333957] [<d083654d>] ssb_device_remove+0x1d/0x30 [ssb] [ 214.333957] [<c126f15a>] __device_release_driver+0x5a/0xb0 [ 214.333957] [<c126fb07>] driver_detach+0x87/0x90 [ 214.333957] [<c126ef4c>] bus_remove_driver+0x6c/0xe0 [ 214.333957] [<c1270120>] driver_unregister+0x40/0x70 [ 214.333957] [<d083686b>] ssb_driver_unregister+0xb/0x10 [ssb] [ 214.333957] [<d087c488>] b43legacy_exit+0xd/0xf [b43legacy] [ 214.333957] [<c1089dde>] sys_delete_module+0x14e/0x2b0 [ 214.333957] [<c110a4a7>] ? vfs_write+0xf7/0x150 [ 214.333957] [<c1240050>] ? tty_write_lock+0x50/0x50 [ 214.333957] [<c110a6f8>] ? sys_write+0x38/0x70 [ 214.333957] [<c1397c55>] syscall_call+0x7/0xb [ 214.333957] Code: bc 27 00 00 00 00 a1 74 61 56 c1 55 89 e5 e8 a3 fc ff ff 5d c3 90 55 89 e5 57 56 89 c6 53 b8 40 ac 62 c1 83 ec 14 e8 bb b7 34 00 <8b> 46 4c 8d 50 01 85 c0 89 56 4c 75 03 83 0e 40 80 05 40 ac 62 [ 214.333957] EIP: [<c104c395>] drain_workqueue+0x15/0x170 SS:ESP 0068:cd767e5c [ 214.333957] CR2: 000000000000004c [ 214.341110] ---[ end trace c7e90ec026d875a6 ]---Index: wireless-testing/drivers/net/wireless/b43legacy/main.c The problem is fixed by making certain that the ucode pointer is not NULL before deregistering the driver in mac80211. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10tun: Fix formatting.David S. Miller
commit 8bbb181308bc348e02bfdbebdedd4e4ec9d452ce upstream. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10net/tun: fix ioctl() based info leaksMathias Krause
commit a117dacde0288f3ec60b6e5bcedae8fa37ee0dfc upstream. The tun module leaks up to 36 bytes of memory by not fully initializing a structure located on the stack that gets copied to user memory by the TUNGETIFF and SIOCGIFHWADDR ioctl()s. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10isdnloop: fix and simplify isdnloop_init()Wu Fengguang
commit 77f00f6324cb97cf1df6f9c4aaeea6ada23abdb2 upstream. Fix a buffer overflow bug by removing the revision and printk. [ 22.016214] isdnloop-ISDN-driver Rev 1.11.6.7 [ 22.097508] isdnloop: (loop0) virtual card added [ 22.174400] Kernel panic - not syncing: stack-protector: Kernel stack is corrupted in: ffffffff83244972 [ 22.174400] [ 22.436157] Pid: 1, comm: swapper Not tainted 3.5.0-bisect-00018-gfa8bbb1-dirty #129 [ 22.624071] Call Trace: [ 22.720558] [<ffffffff832448c3>] ? CallcNew+0x56/0x56 [ 22.815248] [<ffffffff8222b623>] panic+0x110/0x329 [ 22.914330] [<ffffffff83244972>] ? isdnloop_init+0xaf/0xb1 [ 23.014800] [<ffffffff832448c3>] ? CallcNew+0x56/0x56 [ 23.090763] [<ffffffff8108e24b>] __stack_chk_fail+0x2b/0x30 [ 23.185748] [<ffffffff83244972>] isdnloop_init+0xaf/0xb1 Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10HID: LG: validate HID output report detailsKees Cook
commit 0fb6bd06e06792469acc15bbe427361b56ada528 upstream. A HID device could send a malicious output report that would cause the lg, lg3, and lg4 HID drivers to write beyond the output report allocation during an event, causing a heap overflow: [ 325.245240] usb 1-1: New USB device found, idVendor=046d, idProduct=c287 ... [ 414.518960] BUG kmalloc-4096 (Not tainted): Redzone overwritten Additionally, while lg2 did correctly validate the report details, it was cleaned up and shortened. CVE-2013-2893 Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> [PG: drop hid-lg4ff.c chunk; file not present in 2.6.34 baseline.] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10HID: zeroplus: validate output report detailsKees Cook
commit 78214e81a1bf43740ce89bb5efda78eac2f8ef83 upstream. The zeroplus HID driver was not checking the size of allocated values in fields it used. A HID device could send a malicious output report that would cause the driver to write beyond the output report allocation during initialization, causing a heap overflow: [ 1442.728680] usb 1-1: New USB device found, idVendor=0c12, idProduct=0005 ... [ 1466.243173] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten CVE-2013-2889 Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10HID: provide a helper for validating hid reportsKees Cook
commit 331415ff16a12147d57d5c953f3a961b7ede348b upstream. Many drivers need to validate the characteristics of their HID report during initialization to avoid misusing the reports. This adds a common helper to perform validation of the report exisitng, the field existing, and the expected number of values within the field. Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> [PG: in 2.6.34 it is err_hid(), original baseline had hid_err().] Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2014-02-10HID: pantherlord: validate output report detailsKees Cook
commit 412f30105ec6735224535791eed5cdc02888ecb4 upstream. A HID device could send a malicious output report that would cause the pantherlord HID driver to write beyond the output report allocation during initialization, causing a heap overflow: [ 310.939483] usb 1-1: New USB device found, idVendor=0e8f, idProduct=0003 ... [ 315.980774] BUG kmalloc-192 (Tainted: G W ): Redzone overwritten CVE-2013-2892 Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
