patch b64d70825abbf706bbe80be1b11b09514b71f45e in mainline.
The code in fb_ddc_read() is said to be based on the implementation of the
radeon driver:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=fc5891c8a3ba284f13994d7bc1f1bfa8283982de
However, comparing the old radeon driver code with the new fb_ddc code
reveals some differences. Most notably, the I2C bus lines are held at the
end of the function, while the original code was releasing them (as the
comment above correctly says.)
There are a few other differences, which appear to be responsible for read
failures on my system. While tracing low-level I2C code in i2c-algo-bit, I
noticed that the initial attempt to read the EDID always failed. It takes
one retry for the read to succeed. As we are about to remove this
automatic retry property from i2c-algo-bit, reading the EDID would really
fail.
As a summary, the I2C lines quirk which is supposedly needed to read EDID
on some older monitors is currently breaking the (first) read on all other
monitors (and might not even work with older ones - did anyone try since
October 2006?)
After applying the patch below, which makes the code in fb_ddc_read()
really similar to what the radeon driver used to have, the first EDID read
succeeds again.
On top of that, as it appears that this code has been broken for one year
now and nobody seems to have complained, I'm curious if it makes sense to
keep this quirk in place. It makes the code more complex and slower just
for the sake of monitors which I guess nobody uses anymore. Can't we just
get rid of it?
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Tested-by: Roger Leigh <rleigh@whinlatter.ukfsn.org>
Tested-by: Michael Buesch <mb@bu3sch.de>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
patch a7839e960675b549f06209d18283d5cee2ce9261 in mainline.
On some systems the number of resources(IO,MEM) returnedy by PNP device is
greater than the PNP constant, for example motherboard devices. It brings
that some resources can't be reserved and resource confilicts. This will
cause PCI resources are assigned wrongly in some systems, and cause hang.
This is a regression since we deleted ACPI motherboard driver and use PNP
system driver.
[akpm@linux-foundation.org: fix text and coding-style a bit]
Signed-off-by: Li Shaohua <shaohua.li@intel.com>
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Thomas Renninger <trenn@suse.de>
patch cb43c54ca05c01533c45e4d3abfe8f99b7acf624 in mainline.
The APM emulation is currently broken as a result of commit
831441862956fffa17b9801db37e6ea1650b0f69
"Freezer: make kernel threads nonfreezable by default"
that removed the PF_NOFREEZE annotations from apm_ioctl() without adding
the appropriate freezer hooks. Fix it and remove the unnecessary variable flags
from apm_ioctl().
Special thanks to Franck Bui-Huu <vagabon.xyz@gmail.com> for pointing out the
problem.
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Franck Bui-Huu <vagabon.xyz@gmail.com>
Cc: Nigel Cunningham <nigel@nigel.suspend2.net>
Signed-off-by: Len Brown <len.brown@intel.com>
patch 0f13864e5b24d9cbe18d125d41bfa4b726a82e40 in mainline.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=9416
Signed-off-by: Karsten Keil <kkeil@suse.de>
patch 8668a3c468ed55d19514117a5a959d91d3d03823 in mainline.
Resetting an SMP guest will force AP enter real mode (RESET) with
paging enabled in protected mode. While current enter_rmode() can
only handle mode switch from nonpaging mode to real mode which leads
to SMP reboot failure.
Fix by reloading the mmu context on entering real mode.
Signed-off-by: Yaozu (Eddie) Dong <eddie.dong@intel.com>
Signed-off-by: Qing He <qing.he@intel.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
patch 78f7826868da8e27d097802139a3fec39f47f3b8 in mainline.
When resetting from userspace, we need to handle the flags being cleared
even after we are in real mode.
patch 0967b7bf1c22b55777aba46ff616547feed0b141 in mainline.
If we defer updating rip until pio instructions are executed, we have a
problem with reset: a pio reset updates rip, and when the instruction
completes we skip the emulated instruction, pointing rip somewhere completely
unrelated.
Fix by updating rip when we see decode the instruction, not after emulation.
patch 404fb881b82cf0cf6981832f8d31a7484e4dee81 in mainline.
The clts code didn't use set_cr0 properly, so our lazy FPU
processing wasn't being done by the clts instruction at all.
(this isn't called on Intel as the hardware does the decode for us)
Signed-off-by: Amit Shah <amit.shah@qumranet.com>
This is not in mainline, as it was fixed differently in that tree.
first_cpu(cpus) returns the only CPU when NR_CPUS is 1 regardless of
the cpus mask. Therefore we avoid a kernel hang in
KVM_SET_MEMORY_REGION ioctl on uniprocessor by not entering the loop at
all.
Signed-off-by: Marko Kohtala <marko.kohtala@gmail.com>
patch 00b2ef475d4728ca53a2bc788c7978042907e354 in mainline.
emulator_write_std() is not implemented, and calling write_emulated should
work just as well in place of write_std.
Fixes emulator failures with the push r/m instruction.
patch cf5a94d1331b411b84414c13e43f578260942d6b in mainline.
'invd' can destroy host data, and 'wbinvd' allows the guest to induce
long (milliseconds) latencies.
Noted by Ben Serebrin.
patch 651a3e29b3d19418d7a8a9787906061f9be7cc5f in mainline.
Emulate the 'invd' instruction (opcode 0f 08).
and Mod = 3
patch 4e62417bf317504c0b85e0d7abd236f334f54eaf in mainline.
The patch belows changes the access type to register from memory for
instructions that are declared as SrcMem or DstMem, but have a
ModR/M byte with Mod = 3.
It fixes (at least) the lmsw and smsw instructions on an AMD64 CPU,
which are needed for FreeBSD.
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
patch a012e65aee48379a7a87eadafa74f878b61522b9 in mainline.
Implement emulation of instruction:
movnti m32/m64, r32/r64
opcode: 0x0f 0xc3
Needed to support Linux 2.6.16 as guest (used for mmio).
Signed-off-by: Sheng Yang <sheng.yang@intel.com>
patch 9e555930bd873d238f5f7b9d76d3bf31e6e3ce93 in mainline.
Fix a long boot delay in the forcedeth driver. During initialization, the
timeout for the handshake between mgmt unit and driver can be very long.
The patch reduces the timeout by eliminating a extra loop around the
timeout logic.
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=9308
Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com>
Cc: Alex Howells <astinus@gentoo.org>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
patch 490dde8990c55662596a4be71b5070bd7d382d4a in mainline.
This patch adds new device ids and features for mcp79 devices into the
forcedeth driver.
index 92ce2e3..f9ba0ac 100644
patch eafe1aa37e6ec2d56f14732b5240c4dd09f0613a in mainline.
Fix possible memory overrun issue in the isdn ioctl code. Found by ADLAB
<adlab@venustech.com.cn>
Cc: ADLAB <adlab@venustech.com.cn>
patch 1cb52658b4f5b10a9e91f8e1c21ca2bcc1b9a3ca in mainline.
A recent patch added software synchronization during EHCI startup,
so ports aren't switched away from the companion controllers after
resets have started. This patch adds a short delay letting hardware
finish that port switching before any new resets begin ... so both
ends of that hardware race window are closed.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Dave Miller <davem@davemloft.net>
Cc: Dely Sy <dely.l.sy@intel.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
patch 5cf1973a44bd298e3cfce6f6af8faa8c9d0a6d55 in mainline
to make HAL like the microtek driver's devices the parent must be
correctly set.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
changeset dac4ae0daa1be36ab015973ed9e9dc04a2684395 in mainline.
Input: ALPS - add support for model found in Dell Vostro 1400
Signed-off-by: William Pettersson <william.pettersson@gmail.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
commit 5d0360ee96a5ef953dbea45873c2a8c87e77d59b upstream.
We have seen ramdisk based install systems, where some pages of mapped
libraries and programs were suddendly zeroed under memory pressure. This
should not happen, as the ramdisk avoids freeing its pages by keeping
them dirty all the time.
It turns out that there is a case, where the VM makes a ramdisk page
clean, without telling the ramdisk driver. On memory pressure
shrink_zone runs and it starts to run shrink_active_list. There is a
check for buffer_heads_over_limit, and if true, pagevec_strip is called.
pagevec_strip calls try_to_release_page. If the mapping has no
releasepage callback, try_to_free_buffers is called. try_to_free_buffers
has now a special logic for some file systems to make a dirty page
clean, if all buffers are clean. Thats what happened in our test case.
The simplest solution is to provide a noop-releasepage callback for the
ramdisk driver. This avoids try_to_free_buffers for ramdisk pages.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Acked-by: Nick Piggin <npiggin@suse.de>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
[NET] random : secure_tcp_sequence_number should not assume CONFIG_KTIME_SCALAR
[ Upstream commit: 6dd10a62353a50b30b30e0c18653650975b29c71 ]
All 32 bits machines but i386 dont have CONFIG_KTIME_SCALAR. On these
machines, ktime.tv64 is more than 4 times the (correct) result given
by ktime_to_ns()
Again on these machines, using ktime_get_real().tv64 >> 6 give a
32bits rollover every 64 seconds, which is not wanted (less than the
120 s MSL)
Using ktime_to_ns() is the portable way to get nsecs from a ktime, and
have correct code.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
patch 29f5f2a19b055feabfcc6f92e1d40ec092c373ea in mainline.
Properly account for queue commands, this fixes a problem reported
by Holger Schurig when using the debugfs interface.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
patch 0b5316769774d1dc2fdd702e095f9e6992af269a in mainline.
ipw2200 makes extensive use of background scanning when unassociated or
down. Unfortunately, the firmware sends scan completed events many
times per second, which the driver pushes directly up to userspace.
This needlessly wakes up processes listening for wireless events many
times per second. Batch together scan completed events for
non-user-requested scans and send them up to userspace every 4 seconds.
Scan completed events resulting from an SIOCSIWSCAN call are pushed up
without delay.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Cc: Tobias Powalowski <t.powa@gmx.de>
patch d466a9190ff1ceddfee50686e61d63590fc820d9 in mainline.
Not surprisingly the Nikon D40X DSC needs the same quirks as the D40,
but it has a separate ID.
See http://bugs.gentoo.org/show_bug.cgi?id=191431
patch 16eb345f4d9189b59bae576ae63cba7ca77817b2 in mainline.
Upgrade the unusual_devs.h file to support the Nikon D200
Signed-off-by: Mike Pagano <mpagano-kernel@mpagano.com>
Signed-off-by: Phil Dibowitz <phil@ipom.com>
patch 2e21630ddc3fb717dc645356b75771c6a52dc627 in mainline.
Currently the Geode AES module fails to encrypt or decrypt if
the coherent bits are not set what is currently the case if the
encryption does not occur inplace. However, the encryption works
on my Geode machine _only_ if the coherent bits are always set.
Signed-off-by: Sebastian Siewior <sebastian@breakpoint.cc>
Acked-by: Jordan Crouse <jordan.crouse@amd.com>
patch 63f0edfc0b7f8058f9d3f9b572615ec97ae011ba in mainline.
ACPI: VIDEO: Adjust current level to closest available one.
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
patch 96af154710d44b574515431a0bb014888398a741 in mainline.
[libata] sata_sis: use correct S/G table size
sata_sis has the same restrictions as other SFF controllers, and so must
use LIBATA_MAX_PRD to denote that SCSI may only fill ATA_MAX_PRD/2
entries, due to our need to handle IOMMU merging.
patch aaa092a114696f4425cd57c4d7fa05110007e247 in mainline.
sata_sis: fix SCR read breakage
SCR read for controllers which uses PCI configuration space for SCR
access got broken while adding @val argument to SCR accessors. Fix
it.
Signed-off-by: Tejun Heo <htejun@gmail.com>
patch 348badf1e825323c419dd118f65783db0f7d2ec8 in mainline.
When a DMA device is unregistered, its reference count is decremented twice
for each channel: Once dma_class_dev_release() and once in
dma_chan_cleanup(). This may result in the DMA device driver's remove()
function completing before all channels have been cleaned up, causing lots
of use-after-free fun.
Fix it by incrementing the device's reference count twice for each
channel during registration.
[dan.j.williams@intel.com: kill unnecessary client refcounting]
Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Signed-off-by: Shannon Nelson <shannon.nelson@intel.com>
patch 6c55be8b962f1bdc592d579e81fc27b11ea53dfc in mainline.
<debug output from Joel's system>
handling stripe 7629696, state=0x14 cnt=1, pd_idx=2 ops=0:0:0
check 5: state 0x6 toread 0000000000000000 read 0000000000000000 write fffff800ffcffcc0 written 0000000000000000
check 4: state 0x6 toread 0000000000000000 read 0000000000000000 write fffff800fdd4e360 written 0000000000000000
check 3: state 0x1 toread 0000000000000000 read 0000000000000000 write 0000000000000000 written 0000000000000000
check 2: state 0x1 toread 0000000000000000 read 0000000000000000 write 0000000000000000 written 0000000000000000
check 1: state 0x6 toread 0000000000000000 read 0000000000000000 write fffff800ff517e40 written 0000000000000000
check 0: state 0x6 toread 0000000000000000 read 0000000000000000 write fffff800fd4cae60 written 0000000000000000
locked=4 uptodate=2 to_read=0 to_write=4 failed=0 failed_num=0
for sector 7629696, rmw=0 rcw=0
</debug>
These blocks were prepared to be written out, but were never handled in
ops_run_biodrain(), so they remain locked forever. The operations flags
are all clear which means handle_stripe() thinks nothing else needs to be
done.
This state suggests that the STRIPE_OP_PREXOR bit was sampled 'set' when it
should not have been. This patch cleans up cases where the code looks at
sh->ops.pending when it should be looking at the consistent stack-based
snapshot of the operations flags.
Report from Joel:
Resync done. Patch fix this bug.
Tested-by: Joel Bertrand <joel.bertrand@systella.fr>
Cc: <stable@kernel.org>
Cc: Neil Brown <neilb@suse.de>
patch df9d177aa28d50e64bae6fbd6b263833079e3571 in mainline.
Instruction pointer returned by profile_pc() can be a random value. This
break the assumption than we can safely set struct op_sample.eip field to a
magic value to signal to the per-cpu buffer reader side special event like
task switch ending up in a segfault in get_task_mm() when profile_pc()
return ~0UL. Fixed by sanitizing the sampled eip and reject/log invalid
eip.
Problem reported by Sami Farin, patch tested by him.
Signed-off-by: Philippe Elie <phil.el@wanadoo.fr>
Tested-by: Sami Farin <safari-kernel@safari.iki.fi>
patch 3cc2c17700c98b0af778566b0af6292b23b01430 in mainline.
The size passing to memset is wrong.
Signed-off-by Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
patch 0f2cbd38aa377e30df3b7602abed69464d1970aa in mainline.
The sysfs interface to DMI data takes care to not make the system
serial number and UUID world-readable, presumably due to privacy
concerns. For consistency, we should not let the eeprom driver
export these same strings to the world on Sony Vaio laptops.
Instead, only make them readable by root, as we already do for BIOS
passwords.
patch 8b925a3dd8a4d7451092cb9aa11da727ba69e0f0 in mainline.
Recent (i.e. 2005 and later) Sony Vaio laptops have names beginning
with VGN rather than PCG. Update the eeprom driver so that it
recognizes these.
Why this matters: the eeprom driver hides private data from the
EEPROMs it recognizes as Vaio EEPROMs (passwords, serial number...) so
if the driver fails to recognize a Vaio EEPROM as such, the private
data is exposed to the world.
patch be8a1f7cd4501c3b4b32543577a33aee6d2193ac in mainline.
Turns out we don't actually check the status to see if there was a
device out there to talk to, just if we had a timeout when doing so.
Add the proper check, so we don't falsly think there are devices
on the bus that are not there, etc.
commit 1dbc1fda5d8ca907f320b806005d4a447977d26a in mainline.
ACPI: suspend: Wrong order of GPE restore.
acpi_leave_sleep_state() should have correct list of wake and
runtime GPEs, which is available only after disable_wakeup_device()
is called.
[cebbert@redhat.com: backport to 2.6.23]
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
patch is 9c1c6a1ba786d58bd03e27ee49f89a5685e8e07b in mainline.
ACPI: sleep: Fix GPE suspend cleanup
Commit 9b039330808b83acac3597535da26f47ad1862ce removed
acpi_gpe_sleep_prepare(), the only function used at S5 transition
Add call to generic acpi_enable_wake_device().
Reference: https://bugzilla.novell.com/show_bug.cgi?id=299882
Differs from mainline, but the functionality is already there.
P5W-DH Deluxe has ICH7R which doesn't have PMP support but SIMG 4726
hardwired to the second port of AHCI controller at PCI device 1f.2.
The 4726 doesn't work as PMP but as a storage processor which can do
hardware RAID on downstream ports.
When no device is attached to the downstream port of the 4726, pseudo
ATA device for configuration appears. Unfortunately, ATA emulation on
the device is very lousy and causes long hang during boot.
This patch implements workaround for the board. If the mainboard is
P5W-DH Deluxe (matched using DMI), only hardreset is used on the
second port of AHCI controller @ 1f.2 and the hardreset doesn't depend
on receiving the first FIS and just proceed to IDENTIFY.
This workaround fixes bugzilla #8923.
http://bugzilla.kernel.org/show_bug.cgi?id=8923
Cc: Jeff Garzik <jeff@garzik.org>
Backport ATA_FLAG_NO_SRST and ATA_FLAG_ASSUME_ATA. These are
originally link flags (ATA_LFLAG_*) but link abstraction doesn't exist
on 2.6.23, so make it port flags.
This is for the following workaround for ASUS P5W DH Deluxe.
These new flags don't introduce any behavior change unless set and
nobody sets them yet.
patch e14cbfa630cd3ab2631ee21b718b290928f47868 in mainline.
Another one doing spurious NCQ completions. Blacklist it.
Cc: Luca Tettamanti <kronos.it@gmail.com>
Upstream as 7fc86860cf73e060ab8ed9763010dfe5b5389b1c
This code relied on the CPU and GPU address for the aperture being the same,
On some r5xx hardware I was playing with I noticed that this isn't always true.
This fixes issues seen on some r400 cards. (bugs.freedesktop.org 9957)
patch c43422053bea7a5ce09f18d0c50a606fe1a549f4 in mainline.
moxa, fix and optimise empty timer
don't wait and delete empty timer in empty timer function. Also fire next
empty timer at rounded jiffies to save power.
This fixes a lockup, because we wait for ourselves to finish forever.
(i.e. sync called from the timer itself).
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
patch ac6aec2f5683588361ab408cb3346b08c66bdfbe in mainline.
- register_device unconditionally (non-pci dependent) to have also isa
devices in /dev
- unregister devices on module removal
- don't set TTY_DRIVER_DYNAMIC_DEV twice (removed the one dependent on some
macro)
This is the substantial part of the patch and the previous point is for
not checking which devices to unregister and which not (simply register
and unregister all found no matter on which bus they are plugged).
Cc: Ferenc Wagner <wferi@niif.hu>
patch 0fec02c93f60fb44ba3a24a0d3e4a52521d34d3f in mainline.
avoid buffer overflow when returning sense data.
With current adapter firmware the driver is working but future firmware
updates may return sense data larger than 96 bytes, causing overflow on
scp->sense_buffer and a kernel crash.
This fix should be backported to earlier kernels.
Signed-off-by: HighPoint Linux Team <linux@highpoint-tech.com>
Signed-off-by: James Bottomley <James.Bottomley@steeleye.com>
patch 15d8061bf02aa299b2447f7a22fd18b4a503ea9d in mainline.
The cs5535 uses an incorrect construct to access the other drive of a pair,
causing it to access beyond an array boundary on the secondary interface.
This fixes it by using the new ide_get_paired_drive() helper instead.
Bart: patch description fixes
Cc: Andrew Morton <akpm@osdl.org>
Acked-by: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
patch a87a87ccdc541e0a0cc8c7d01a365be8d9153a7b in mainline.
The siimage uses an incorrect construct to access the other drive of a pair,
patch 0c824b51b338c808de650b440ba5f9f4a725f7fc in mainline.
The patch described by the following excerpt from ChangeLog-2.6.22 makes
it impossible to use UDMA on a Tyan S2707 motherboard (SvrWks CSB5):
commit 2d5eaa6dd744a641e75503232a01f52d0768884c
Author: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Date: Thu May 10 00:01:08 2007 +0200
ide: rework the code for selecting the best DMA transfer mode (v3)
This one-line patch against 2.6.23 fixes the problem.
Signed-off-by: Tony Battersby <tonyb@cybernetics.com>
patch 9713d9e650045f7f2afd81d58a068827be306993 in mainline.
This fix the same issue which was debbuged for the C4 controller for the B1
versions.
The capilib_ function modify or traverse a linked list without locking.
This patch extends the existing locking to the calls of these function to
prevent access to a list which is in the middle of a modification.
