Vybrid ADC peripheral includes a temperature sensor
which is connected to channel number 26. This patch
adds support for the sensor. The raw value is read
and the temperature calculated in milli degree Celsius,
which is returned using IIO_CHAN_INFO_PROCESSED option.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
This driver register pm_power_off with snvs power off function. If
your boards NOT use PMIC_ON_REQ to turn on/off external pmic, or use
other pin to do, please disable the driver in dts, otherwise, your
pm_power_off maybe overwrote by this driver.
Signed-off-by: Robin Gong <b38343@freescale.com>
Acked-By: Sebastian Reichel <sre@kernel.org>
Pull md bugfix from Neil Brown:
"One fix for md for 3.18.
This fixes a regression introduced in 3.13"
* tag 'md/3.18-fix' of git://neil.brown.name/md:
md: Always set RECOVERY_NEEDED when clearing RECOVERY_FROZEN
md_check_recovery will skip any recovery and also clear
MD_RECOVERY_NEEDED if MD_RECOVERY_FROZEN is set.
So when we clear _FROZEN, we must set _NEEDED and ensure that
md_check_recovery gets run.
Otherwise we could miss out on something that is needed.
In particular, this can make it impossible to remove a
failed device from an array is the 'recovery-needed' processing
didn't happen.
Suitable for stable kernels since 3.13.
Cc: stable@vger.kernel.org (3.13+)
Reported-and-tested-by: Joe Lawrence <joe.lawrence@stratus.com>
Fixes: 30b8feb730f9b9b3c5de02580897da03f59b6b16
Signed-off-by: NeilBrown <neilb@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi
Pull SCSI fixes from James Bottomley:
"This is a set of six fixes and a MAINTAINER update.
The fixes are two multipath (one in Test Unit Ready handling for the
path checkers and one in the section of code that sends a start unit
after failover; both of these were perturbed by the scsi-mq update), a
CD-ROM door locking fix that was likewise introduced by scsi-mq and
three driver fixes for a previous code update in cxgb4i, megaraid_sas
and bnx2fc"
* tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
bnx2fc: fix tgt spinlock locking
megaraid_sas: fix bug in handling return value of pci_enable_msix_range()
cxgb4i: send abort_rpl correctly
cxgbi: add maintainer for cxgb3i/cxgb4i
scsi: TUR path is down after adapter gets reset with multipath
scsi: call device handler for failed TUR command
scsi: only re-lock door after EH on devices that were reset
Pull power supply updates from Sebastian Reichel:
"Power supply and reset changes for the v3.18-rc:
- misc. charger-manager fixes
- year 2038 fix in ab8500_fg
- fix error handling of bq2415x_charger"
* tag 'for-v3.18-rc' of git://git.infradead.org/battery-2.6:
power: charger-manager: Fix accessing invalidated power supply after charger unbind
power: charger-manager: Fix accessing invalidated power supply after fuel gauge unbind
power: charger-manager: Avoid recursive thermal get_temp call
power_supply: Add no_thermal property to prevent recursive get_temp calls
power: bq2415x_charger: Fix memory leak on DTS parsing error
power: bq2415x_charger: Properly handle ENODEV from power_supply_get_by_phandle
power: ab8500_fg.c: use 64-bit time types
Pull drm gixes from Dave Airlie:
- exynos: infinite loop regressions fixed
- i915: one regression
- radeon: one race condition on monitor probing
- noveau: two regressions
- tegra: one vblank regression fix
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux:
drm/tegra: dc: Add missing call to drm_vblank_on()
drm/nouveau/nv50/disp: Fix modeset on G94
drm/gk20a/fb: fix setting of large page size bit
drm/radeon: add locking around atombios scratch space usage
drm/i915: Fix obj->map_and_fenceable across tiling changes
drm/exynos: fix possible infinite loop issue
drm/exynos: g2d: fix null pointer dereference
drm/exynos: resolve infinite loop issue on non multi-platform
drm/exynos: resolve infinite loop issue on multi-platform
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"Mostly small fixups to PS/2 tochpad drivers (ALPS, Elantech,
Synaptics) to better deal with specific hardware"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input:
Input: elantech - update the documentation
Input: elantech - provide a sysfs knob for crc_enabled
Input: elantech - report the middle button of the touchpad
Input: alps - ignore bad data on Dell Latitudes E6440 and E7440
Input: alps - allow up to 2 invalid packets without resetting device
Input: alps - ignore potential bare packets when device is out of sync
Input: elantech - fix crc_enabled for Fujitsu H730
Input: elantech - use elantech_report_trackpoint for hardware v4 too
Input: twl4030-pwrbutton - ensure a wakeup event is recorded.
Input: synaptics - add min/max quirk for Lenovo T440s
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform drivers fixlets from Darren Hart:
"Just two patches to remove hp_accel events from the keyboard bus
stream via an i8042 filter"
* tag 'platform-drivers-x86-v3.18-3' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86:
platform: hp_accel: Add SERIO_I8042 as a dependency since it now includes i8042.h/serio.h
platform: hp_accel: add a i8042 filter to remove HPQ6000 data from kb bus stream
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata fixes from Tejun Heo:
"The most notable is the revert of lock splitting optimization in ahci.
This also made the IRQ handling threaded even when there's only one
IRQ in use. The conversion missed IRFQ_SHARED leading to screaming
IRQs problem in some cases and the threaded IRQ handling showed
performance regression in some LKP test cases. The changes are
reverted for now. It'll probably be retried once threaded IRQ
handling is removed from ahci.
Other than that, there's one fix for ahci and several patches adding
device IDs"
* 'for-3.18-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata:
ahci: fix AHCI parameters not taken into account
ata: sata_rcar: Add r8a7793 device support
ahci: Add Device IDs for Intel Sunrise Point PCH
ahci: disable MSI instead of NCQ on Samsung pci-e SSDs on macbooks
Revert "AHCI: Optimize single IRQ interrupt processing"
Revert "AHCI: Do not acquire ata_host::lock from single IRQ handler"
ata: sata_rcar: Disable DIPM mode for r8a7790 ES1
Pull ACPI and power management fixes from Rafael Wysocki:
"These are three regression fixes, two recent (generic power domains,
suspend-to-idle) and one older (cpufreq), an ACPI blacklist entry for
one more machine having problems with Windows 8 compatibility, a minor
cpufreq driver fix (cpufreq-dt) and a fixup for new callback
definitions (generic power domains).
Specifics:
- Fix a crash in the suspend-to-idle code path introduced by a recent
commit that forgot to check a pointer against NULL before
dereferencing it (Dmitry Eremin-Solenikov).
- Fix a boot crash on Exynos5 introduced by a recent commit making
that platform use generic Device Tree bindings for power domains
which exposed a weakness in the generic power domains framework
leading to that crash (Ulf Hansson).
- Fix a crash during system resume on systems where cpufreq depends
on Operation Performance Points (OPP) for functionality, but
CONFIG_OPP is not set. This leads the cpufreq driver registration
to fail, but the resume code attempts to restore the pre-suspend
cpufreq configuration (which does not exist) nevertheless and
crashes. From Geert Uytterhoeven.
- Add a new ACPI blacklist entry for Dell Vostro 3546 that has
problems if it is reported as Windows 8 compatible to the BIOS
(Adam Lee).
- Fix swapped arguments in an error message in the cpufreq-dt driver
(Abhilash Kesavan).
- Fix up the prototypes of new callbacks in struct generic_pm_domain
to make them more useful. Users of those callbacks will be added
in 3.19 and it's better for them to be based on the correct struct
definition in mainline from the start. From Ulf Hansson and Kevin
Hilman"
* tag 'pm+acpi-3.18-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PM / Domains: Fix initial default state of the need_restore flag
PM / sleep: Fix entering suspend-to-IDLE if no freeze_oops is set
PM / Domains: Change prototype for the attach and detach callbacks
cpufreq: Avoid crash in resume on SMP without OPP
cpufreq: cpufreq-dt: Fix arguments in clock failure error message
ACPI / blacklist: blacklist Win8 OSI for Dell Vostro 3546
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394
Pull firewire fix from Stefan Richter:
"IEEE 1394 (FireWire) subsystem fix: The character device file
interface for raw 1394 I/O took uninitialized kernel stack as
substitute for missing ioctl() argument data. This could partially
show up in subsequent read() output"
* tag 'firewire-fix' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394:
firewire: cdev: prevent kernel stack leaking into ioctl arguments
* pm-domains:
* pm-sleep:
* pm-cpufreq:
* acpi-blacklist:
Found by the UC-KLEE tool: A user could supply less input to
firewire-cdev ioctls than write- or write/read-type ioctl handlers
expect. The handlers used data from uninitialized kernel stack then.
This could partially leak back to the user if the kernel subsequently
generated fw_cdev_event_'s (to be read from the firewire-cdev fd)
which notably would contain the _u64 closure field which many of the
ioctl argument structures contain.
The fact that the handlers would act on random garbage input is a
lesser issue since all handlers must check their input anyway.
The fix simply always null-initializes the entire ioctl argument buffer
regardless of the actual length of expected user input. That is, a
runtime overhead of memset(..., 40) is added to each firewirew-cdev
ioctl() call. [Comment from Clemens Ladisch: This part of the stack is
most likely to be already in the cache.]
Remarks:
- There was never any leak from kernel stack to the ioctl output
buffer itself. IOW, it was not possible to read kernel stack by a
read-type or write/read-type ioctl alone; the leak could at most
happen in combination with read()ing subsequent event data.
- The actual expected minimum user input of each ioctl from
include/uapi/linux/firewire-cdev.h is, in bytes:
[0x00] = 32, [0x05] = 4, [0x0a] = 16, [0x0f] = 20, [0x14] = 16,
[0x01] = 36, [0x06] = 20, [0x0b] = 4, [0x10] = 20, [0x15] = 20,
[0x02] = 20, [0x07] = 4, [0x0c] = 0, [0x11] = 0, [0x16] = 8,
[0x03] = 4, [0x08] = 24, [0x0d] = 20, [0x12] = 36, [0x17] = 12,
[0x04] = 20, [0x09] = 24, [0x0e] = 4, [0x13] = 40, [0x18] = 4.
Reported-by: David Ramos <daramos@stanford.edu>
Cc: <stable@vger.kernel.org>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Pull virtio bugfix from Michael S Tsirkin:
"This fixes a crash in virtio console multi-channel mode that got
introduced in -rc1"
* tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost:
virtio_console: move early VQ enablement
Pull networking fixes from David Miller:
1) sunhme driver lacks DMA mapping error checks, based upon a report by
Meelis Roos.
2) Fix memory leak in mvpp2 driver, from Sudip Mukherjee.
3) DMA memory allocation sizes are wrong in systemport ethernet driver,
fix from Florian Fainelli.
4) Fix use after free in mac80211 defragmentation code, from Johannes
Berg.
5) Some networking uapi headers missing from Kbuild file, from Stephen
Hemminger.
6) TUN driver gets csum_start offset wrong when VLAN accel is enabled,
and macvtap has a similar bug, from Herbert Xu.
7) Adjust several tunneling drivers to set dev->iflink after registry,
because registry sets that to -1 overwriting whatever we did. From
Steffen Klassert.
8) Geneve forgets to set inner tunneling type, causing GSO segmentation
to fail on some NICs. From Jesse Gross.
9) Fix several locking bugs in stmmac driver, from Fabrice Gasnier and
Giuseppe CAVALLARO.
10) Fix spurious timeouts with NewReno on low traffic connections, from
Marcelo Leitner.
11) Fix descriptor updates in enic driver, from Govindarajulu
Varadarajan.
12) PPP calls bpf_prog_create() with locks held, which isn't kosher.
Fix from Takashi Iwai.
13) Fix NULL deref in SCTP with malformed INIT packets, from Daniel
Borkmann.
14) psock_fanout selftest accesses past the end of the mmap ring, fix
from Shuah Khan.
15) Fix PTP timestamping for VLAN packets, from Richard Cochran.
16) netlink_unbind() calls in netlink pass wrong initial argument, from
Hiroaki SHIMODA.
17) vxlan socket reuse accidently reuses a socket when the address
family is different, so we have to explicitly check this, from
Marcelo Lietner.
18) Fix missing include in nft_reject_bridge.c breaking the build on ppc
and other architectures, from Guenter Roeck.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (75 commits)
vxlan: Do not reuse sockets for a different address family
smsc911x: power-up phydev before doing a software reset.
lib: rhashtable - Remove weird non-ASCII characters from comments
net/smsc911x: Fix delays in the PHY enable/disable routines
net/smsc911x: Fix rare soft reset timeout issue due to PHY power-down mode
netlink: Properly unbind in error conditions.
net: ptp: fix time stamp matching logic for VLAN packets.
cxgb4 : dcb open-lldp interop fixes
selftests/net: psock_fanout seg faults in sock_fanout_read_ring()
net: bcmgenet: apply MII configuration in bcmgenet_open()
net: bcmgenet: connect and disconnect from the PHY state machine
net: qualcomm: Fix dependency
ixgbe: phy: fix uninitialized status in ixgbe_setup_phy_link_tnx
net: phy: Correctly handle MII ioctl which changes autonegotiation.
ipv6: fix IPV6_PKTINFO with v4 mapped
net: sctp: fix memory leak in auth key management
net: sctp: fix NULL pointer dereference in af->from_addr_param on malformed packet
net: ppp: Don't call bpf_prog_create() in ppp_lock
net/mlx4_en: Advertize encapsulation offloads features only when VXLAN tunnel is set
cxgb4 : Fix bug in DCB app deletion
The detection of crc_enabled is known to fail for Fujitsu H730. A DMI
blacklist is added for that, but it can be expected that other laptops will
pop up with this.
Here a sysfs knob is provided to alter the behaviour of crc_enabled.
Writing 0 or 1 to it sets the variable to 0 or 1. Reading it will show the
crc_enabled variable (0 or 1).
Reported-by: Stefan Valouch <stefan@valouch.com>
Signed-off-by: Ulrik De Bie <ulrik.debie-os@e2big.org>
In the past, no elantech was known with 3 touchpad mouse buttons.
Fujitsu H730 is the first known elantech with a middle button. This commit
enables this middle button. For backwards compatibility, the Fujitsu is
detected via DMI, and only for this one 3 buttons will be announced.
Sometimes on Dell Latitude laptops psmouse/alps driver receive invalid ALPS
protocol V3 packets with bit7 set in last byte. More often it can be
reproduced on Dell Latitude E6440 or E7440 with closed lid and pushing
cover above touchpad.
If bit7 in last packet byte is set then it is not valid ALPS packet. I was
told that ALPS devices never send these packets. It is not know yet who
send those packets, it could be Dell EC, bug in BIOS and also bug in
touchpad firmware...
With this patch alps driver does not process those invalid packets, but
instead of reporting PSMOUSE_BAD_DATA, getting into out of sync state,
getting back in sync with the next byte and spam dmesg we return
PSMOUSE_FULL_PACKET. If driver is truly out of sync we'll fail the checks
on the next byte and report PSMOUSE_BAD_DATA then.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Tested-by: Pali Rohár <pali.rohar@gmail.com>
Merge misc fixes from Andrew Morton:
"15 fixes"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>:
MAINTAINERS: add IIO include files
kernel/panic.c: update comments for print_tainted
mem-hotplug: reset node present pages when hot-adding a new pgdat
mem-hotplug: reset node managed pages when hot-adding a new pgdat
mm/debug-pagealloc: correct freepage accounting and order resetting
fanotify: fix notification of groups with inode & mount marks
mm, compaction: prevent infinite loop in compact_zone
mm: alloc_contig_range: demote pages busy message from warn to info
mm/slab: fix unalignment problem on Malta with EVA due to slab merge
mm/page_alloc: restrict max order of merging on isolated pageblock
mm/page_alloc: move freepage counting logic to __free_one_page()
mm/page_alloc: add freepage on isolate pageblock to correct buddy list
mm/page_alloc: fix incorrect isolation behavior by rechecking migratetype
mm/compaction: skip the range until proper target pageblock is met
zram: avoid kunmap_atomic() of a NULL pointer
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid
Pull HID fixes from Jiri Kosina:
- fix for an oops in HID core upon repeated subdriver insertion/removal
under certain circumstances, by Benjamin Tissoires
- quirk for another Elan Touchscreen device, by Adel Gadllah
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid:
HID: core: cleanup .claimed field on disconnect
HID: usbhid: enable always-poll quirk for Elan Touchscreen 0103
zram could kunmap_atomic() a NULL pointer in a rare situation: a zram
page becomes a full-zeroed page after a partial write io. The current
code doesn't handle this case and performs kunmap_atomic() on a NULL
pointer, which panics the kernel.
This patch fixes this issue.
Signed-off-by: Weijie Yang <weijie.yang@samsung.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Nitin Gupta <ngupta@vflare.org>
Cc: Weijie Yang <weijie.yang.kh@gmail.com>
Acked-by: Jerome Marchand <jmarchan@redhat.com>
git://people.freedesktop.org/~tagr/linux into drm-fixes
drm/tegra: Fixes for v3.18-rc5
This is a single patch that fixes the VBLANK machinery after:
7ffd7a68511c drm: Always reject drm_vblank_get() after drm_vblank_off()
* tag 'drm/tegra/for-3.18-rc5' of git://people.freedesktop.org/~tagr/linux:
git://anongit.freedesktop.org/git/nouveau/linux-2.6 into drm-fixes
One modesetting, one gk20a fix.
* 'linux-3.18' of git://anongit.freedesktop.org/git/nouveau/linux-2.6:
git://anongit.freedesktop.org/drm-intel into drm-fixes
one regression fix.
* tag 'drm-intel-fixes-2014-11-13' of git://anongit.freedesktop.org/drm-intel:
Currently, we only match against local port number in order to reuse
socket. But if this new vxlan wants an IPv6 socket and a IPv4 one bound
to that port, vxlan will reuse an IPv4 socket as IPv6 and a panic will
follow. The following steps reproduce it:
# ip link add vxlan6 type vxlan id 42 group 229.10.10.10 \
srcport 5000 6000 dev eth0
# ip link add vxlan7 type vxlan id 43 group ff0e::110 \
# ip link set vxlan6 up
# ip link set vxlan7 up
<panic>
[ 4.187481] BUG: unable to handle kernel NULL pointer dereference at 0000000000000058
[ 4.188076] Call Trace:
[ 4.188085] [<ffffffff81667c4a>] ? ipv6_sock_mc_join+0x3a/0x630
[ 4.188098] [<ffffffffa05a6ad6>] vxlan_igmp_join+0x66/0xd0 [vxlan]
[ 4.188113] [<ffffffff810a3430>] process_one_work+0x220/0x710
[ 4.188125] [<ffffffff810a33c4>] ? process_one_work+0x1b4/0x710
[ 4.188138] [<ffffffff810a3a3b>] worker_thread+0x11b/0x3a0
[ 4.188149] [<ffffffff810a3920>] ? process_one_work+0x710/0x710
So address family must also match in order to reuse a socket.
Reported-by: Jean-Tsung Hsiao <jhsiao@redhat.com>
Signed-off-by: Marcelo Ricardo Leitner <mleitner@redhat.com>
With commit be9dad1f9f26604fb ("net: phy: suspend phydev when going
to HALTED"), the PHY device will be put in a low-power mode using
BMCR_PDOWN if the the interface is set down. The smsc911x driver does
a software_reset opening the device driver (ndo_open). In such case,
the PHY must be powered-up before access to any register and before
calling the software_reset function. Otherwise, as the PHY is powered
down the software reset fails and the interface can not be enabled
again.
This patch fixes this scenario that is easy to reproduce setting down
the network interface and setting up again.
$ ifconfig eth0 down
$ ifconfig eth0 up
ifconfig: SIOCSIFFLAGS: Input/output error
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Increased delay in the smsc911x_phy_disable_energy_detect (from 1ms to 2ms).
Dropped delays in the smsc911x_phy_enable_energy_detect (100ms and 1ms).
The patch affect SMSC LAN generation 4 chips with integrated PHY (LAN9221).
I saw problems with soft reset due to wrong udelay timings.
After I fixed udelay, I measured the time needed to bring integrated PHY
from power-down to operational mode (the time beetween clearing EDPWRDOWN
bit and soft reset complete event). I got 1ms (measured using ktime_get).
The value is equal to the current value (1ms) used in the
smsc911x_phy_disable_energy_detect. It is near the upper bound and in order
to avoid rare soft reset faults it is doubled (2ms).
I don't know official timing for bringing up integrated PHY as specs doesn't
clarify this (or may be I didn't found).
It looks safe to drop delays before and after setting EDPWRDOWN bit
(enable PHY power-down mode). I didn't saw any regressions with the patch.
The patch was reviewed by Steve Glendinning and Microchip Team.
Signed-off-by: Alexander Kochetkov <al.kochet@gmail.com>
Acked-by: Steve Glendinning <steve.glendinning@shawell.net>
It is possible that PHY could enter power-down mode (ENERGYON clear),
between ENERGYON bit check in smsc911x_phy_disable_energy_detect and SRST
bit set in smsc911x_soft_reset. This could happen, for example, if someone
disconnect ethernet cable between the checks. The PHY in a power-down mode
would prevent the MAC portion of chip to be software reseted.
Initially found by code review, confirmed later using test case.
This is low probability issue, and in order to reproduce it you have to
run the script:
while true; do
ifconfig eth0 down
ifconfig eth0 up || break
done
While the script is running you have to plug/unplug ethernet cable many
times (using gpio controlled ethernet switch, for example) until get:
[ 4516.477783] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4516.512207] smsc911x smsc911x.0: eth0: SMSC911x/921x identified at 0xce006000, IRQ: 336
[ 4516.524658] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 4516.559082] smsc911x smsc911x.0: eth0: SMSC911x/921x identified at 0xce006000, IRQ: 336
[ 4516.571990] ADDRCONF(NETDEV_UP): eth0: link is not ready
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm
Pull device mapper fixes from Mike Snitzer:
- stable fix for dm-thin that avoids normal IO racing with discard
- stable fix for a dm-cache related bug in dm-btree walking code that
results from using very large fast device (eg 4T) with a very small
cache blocksize (eg 32K) -- this is a very uncommon configuration
- a couple fixes for dm-raid (one for stable and the other addresses a
crash in 3.18-rc1 code)
- stable fix for dm-thinp that addresses a very rare dm-bufio bug
having to do with memory reclaimation (via shrinker) when using
dm-thinp ontop of loopback devices
- fix a leak in dm-stripe target constructor's error path
* tag 'dm-3.18-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm:
dm btree: fix a recursion depth bug in btree walking code
dm thin: grab a virtual cell before looking up the mapping
dm raid: fix inaccessible superblocks causing oops in configure_discard_support
dm raid: ensure superblock's size matches device's logical block size
dm bufio: change __GFP_IO to __GFP_FS in shrinker callbacks
dm stripe: fix potential for leak in stripe_ctr error path
When the CRTC is enabled, make sure the VBLANK machinery is enabled.
Failure to do so will cause drm_vblank_get() to not enable the VBLANK on
the CRTC and VBLANK-synchronized page-flips won't work.
While at it, get rid of the legacy drm_vblank_pre_modeset() and
drm_vblank_post_modeset() calls that are replaced by drm_vblank_on()
and drm_vblank_off().
Reported-by: Alexandre Courbot <acourbot@nvidia.com>
Tested-by: Alexandre Courbot <acourbot@nvidia.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Commit f5866db6 (virtio_console: enable VQs early) tried to make
sure that DRIVER_OK was set when virtio_console started using its
virtqueues. Doing this in add_port(), however, means that we try
to set DRIVER_OK again when when a port is dynamically added after
the probe function is done.
Let's move virtio_device_ready() to the probe function just before
trying to use the virtqueues instead. This is fine as nothing can
fail inbetween.
Reported-by: Thomas Graf <tgraf@suug.ch>
Reviewed-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Commit 1dce6264045cd23e9c07574ed0bb31c7dce9354f introduced a regression
spotted on several G94 (FDObz #85160). This device seems to expect the
vblank period to be set after setting scale instead of before.
V2: shove this in a separate function
This is a candidate bug-fix for 3.18
Signed-off-by: Roy Spliet <rspliet@eclipso.eu>
Tested-by: Zlatko Calusic <zcalusic@bitsync.net>
Tested-by: Michael Riesch <michael@riesch.at>
Tested-by: "poma" <pomidorabelisima@gmail.com>
Tested-by: Adam Williamson <adamw@happyassassin.net>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
Commit "ltc/gf100-: fix cbc issues on certain boards" moved the setting
of the large page size bit from bar/nvc0 to fb/nvc0. GK20A uses its own
FB device and the change was thus not applied to it - fix this.
Signed-off-by: Alexandre Courbot <acourbot@nvidia.com>
Pull kvm fixes from Paolo Bonzini:
"Two fixes --- one of them not exactly a one liner, but things are
calming down on the KVM front at last"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: x86: Fix uninitialized op->type for some immediate values
KVM: s390: virtio_ccw: remove unused variable
into drm-fixes
atom scratch register race fix.
* 'drm-fixes-3.18' of git://people.freedesktop.org/~agd5f/linux:
git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos into drm-fixes
Now exynos drm driver incurs infinite loop issue on multi-platform
reported by Matwey V.Korniliv like below,
http://comments.gmane.org/gmane.comp.video.dri.devel/117622
This issue is because non kms drivers enabled are probed before
a component master tries to bring up. This patch set resolves
the infinite loop issue and also includes fixups relevant to exynos
drm internal issues.
* 'exynos-drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/daeinki/drm-exynos:
Pull crypto fixes from Herbert Xu:
- stack corruption fix for pseries hwrng driver
- add missing DMA unmap in caam crypto driver
- fix NUMA crash in qat crypto driver
- fix buggy mapping of zero-length associated data in qat crypto driver
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
hwrng: pseries - port to new read API and fix stack corruption
crypto: caam - fix missing dma unmap on error path
crypto: qat - Enforce valid numa configuration
crypto: qat - Prevent dma mapping zero length assoc data
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging
Pull hwmon fixes from Guenter Roeck:
- fix PCI device ID in fam15h_power driver
- fix suspend/resume behavior in pwm-fan driver
- reduce logging noise created by ibmpowernv driver
* tag 'hwmon-for-linus-v3.18-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging:
hwmon: (fam15h_power) Fix NB device ID for F16h M30h
hwmon: (pwm-fan) Fix suspend/resume behavior
hwmon: (ibmpowernv) Quieten when probing finds no device
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal
Pull thermal driver fixes from Eduardo Valentin:
"This week we have few fixes:
- fix in IMX thermal driver to do the correct loading sequence with
CPUfreq
- fix in Exynos related to TMU_CONTROL offset in Exynos5260
- fix the unit conversion in int3403"
[ Still pulling from Eduardo as Rui Zhang is on a business trip and has
troubles with his machine ]
* 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal:
imx: thermal: imx_get_temp might be called before sensor clock is prepared
thermal: exynos: use correct offset for TMU_CONTROL register on Exynos5260
thermal: imx: correct driver load sequence for cpu cooling
Thermal/int3403: Fix thermal hysteresis unit conversion
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD fixes from Lee Jones:
- register offset fix for stmpe
- eradicate build warning when !PM in rtsx_pcr
- fix device ID collision when multiple boards are connected in
viperboard
- use correct Regmap handle - fixing unhanded IRQs in max77693
- unmask MUIC IRQs in max77693
- clear VBUS & CHG bits so board doesn't reboot instead of poweroff in
twl4030
* tag 'mfd-fixes-3.18' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd:
mfd: twl4030-power: Fix poweroff with PM configuration enabled
mfd: max77693: Fix always masked MUIC interrupts
mfd: max77693: Use proper regmap for handling MUIC interrupts
mfd: viperboard: Fix platform-device id collision
mfd: rtsx: Fix build warnings for !PM
mfd: stmpe: Fix STMPE24xx GPMR LSB
Pull drm fixes from Dave Airlie:
"Radeon and i915 fixes.
I probably should have sent these earlier, but nothing too urgent in
them:
- i915:
blackscreen and corruption fixes
- radeon:
oops, locking and stability"
drm/radeon: add missing crtc unlock when setting up the MC
drm/radeon: use gart for DMA IB tests
drm/radeon: make sure mode init is complete in bandwidth_update
drm/radeon: set correct CE ram size for CIK
drm/i915: safeguard against too high minimum brightness
drm/i915: vlv: fix gunit HW state corruption during S4 suspend
drm/i915: Disable caches for Global GTT.
Commit ae5c6c6d "ptp: Classify ptp over ip over vlan packets" changed the
code in two drivers that matches time stamps with PTP frames, with the goal
of allowing VLAN tagged PTP packets to receive hardware time stamps.
However, that commit failed to account for the VLAN header when parsing
IPv4 packets. This patch fixes those two drivers to correctly match VLAN
tagged IPv4/UDP PTP messages with their time stamps.
This patch should also be applied to v3.17.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
* In LLD_MANAGED mode, traffic classes were being returned in reverse order to
lldp agent.
* Priotype of strict is no longer the default returned.
* Change behaviour of getdcbx() based on discussions on lldp-devel
These were missed as there was no working fetch interface for open-lldp when
running in LLD_MANAGED mode till now.
Fixes: 76bcb31efc06 ("cxgb4 : Add DCBx support codebase and dcbnl_ops")
Signed-off-by: Anish Bhatt <anish@chelsio.com>
In case an interface has been brought down before entering S3, and then
brought up out of S3, all the initialization done during
bcmgenet_probe() by bcmgenet_mii_init() calling bcmgenet_mii_config() is
just lost since register contents are restored to their reset values.
Re-apply this configuration anytime we call bcmgenet_open() to make sure
our port multiplexer is properly configured to match the PHY interface.
Since we are now calling bcmgenet_mii_config() everytime bcmgenet_open()
is called, make sure we only print the message during initialization
time not to pollute the console.
Fixes: b6e978e50444 ("net: bcmgenet: add suspend/resume callbacks")
Fixes: 1c1008c793fa4 ("net: bcmgenet: add main driver file")
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
phy_disconnect() is the only way to guarantee that we are not going to
schedule more work on the PHY state machine workqueue for that
particular PHY device.
This fixes an issue where a network interface was suspended prior to a
system suspend/resume cycle and would then be resumed as part of
mdio_bus_resume(), since the GENET interface clocks would have been
disabled, this basically resulted in bus errors to appear since we are
invoking the GENET driver adjust_link() callback.
This patch removes the dependency of the VENDOR entry and fixes
the QCA7000 one.
Signed-off-by: Stefan Wahren <stefan.wahren@i2se.com>
While developing MST support I noticed I often got the wrong data
back from a transaction, in a racy fashion. I noticed the scratch
space wasn't locked against concurrent users.
Based on a patch by Alex, but I've made it a bit more obvious when
things are locked.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Status variable is never initialized, can carry an arbitrary value
on the stack and thus may let the function fail.
Fixes: e90dd2645664 ("ixgbe: Make return values more direct")
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Emil Tantilov <emil.s.tantilov@intel.com>
