path: root/drivers
2011-10-24Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: fix superpage support in pfn_to_dma_pte() intel-iommu: set iommu_superpage on VM domains to lowest common denominator intel-iommu: fix return value of iommu_unmap() API MAINTAINERS: Update VT-d entry for drivers/pci -> drivers/iommu move intel-iommu: Export a flag indicating that the IOMMU is used for iGFX. intel-iommu: Workaround IOTLB hang on Ironlake GPU intel-iommu: Fix AB-BA lockdep report
2011-10-24Merge branch 'for-linus' of http://people.redhat.com/agk/git/linux-dmLinus Torvalds
* 'for-linus' of http://people.redhat.com/agk/git/linux-dm: dm kcopyd: fix job_pool leak
2011-10-23dm kcopyd: fix job_pool leakAlasdair G Kergon
Fix memory leak introduced by commit a6e50b409d3f9e0833e69c3c9cca822e8fa4adbb (dm snapshot: skip reading origin when overwriting complete chunk). When allocating a set of jobs from kc->job_pool, job->master_job must be set (to point to itself) so that the mempool item gets freed when the master_job completes. master_job was introduced by commit c6ea41fbbe08f270a8edef99dc369faf809d1bd6 (dm kcopyd: preallocate sub jobs to avoid deadlock) Reported-by: Michael Leun <ml@newton.leun.net> Cc: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2011-10-23Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (w83627ehf) Fix negative 8-bit temperature values
2011-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: fib_rules: fix unresolved_rules counting r8169: fix wrong eee setting for rlt8111evl r8169: fix driver shutdown WoL regression. ehea: Change maintainer to me pptp: pptp_rcv_core() misses pskb_may_pull() call tproxy: copy transparent flag when creating a time wait pptp: fix skb leak in pptp_xmit() bonding: use local function pointer of bond->recv_probe in bond_handle_frame smsc911x: Add support for SMSC LAN89218 tg3: negate USE_PHYLIB flag check netconsole: enable netconsole can make net_device refcnt incorrent bluetooth: Properly clone LSM attributes to newly created child connections l2tp: fix a potential skb leak in l2tp_xmit_skb() bridge: fix hang on removal of bridge via netlink x25: Prevent skb overreads when checking call user data x25: Handle undersized/fragmented skbs x25: Validate incoming call user data lengths udplite: fast-path computation of checksum coverage IPVS netns shutdown/startup dead-lock netfilter: nf_conntrack: fix event flooding in GRE protocol tracker
2011-10-20hwmon: (w83627ehf) Fix negative 8-bit temperature valuesJean Delvare
Since 8-bit temperature values are now handled in 16-bit struct members, values have to be cast to s8 for negative temperatures to be properly handled. This is broken since kernel version 2.6.39 (commit bce26c58df86599c9570cee83eac58bdaae760e4.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Guenter Roeck <guenter.roeck@ericsson.com> Cc: stable@kernel.org # 2.6.39+ Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-10-19r8169: fix wrong eee setting for rlt8111evlhayeswang
Correct the wrong parameter for setting EEE for RTL8111E-VL. Signed-off-by: Hayes Wang <hayeswang@realtek.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19r8169: fix driver shutdown WoL regression.françois romieu
Due to commit 92fc43b4159b518f5baae57301f26d770b0834c9 ("r8169: modify the flow of the hw reset."), rtl8169_hw_reset stomps during driver shutdown on RxConfig bits which are needed for WOL on some versions of the hardware. As these bits were formerly set from the r81{0x, 68}_pll_power_down methods, factor them out for use in the driver shutdown (rtl_shutdown) handler. I favored __rtl8169_get_wol() -hardware state indication- over RTL_FEATURE_WOL as the latter has become a good candidate for removal. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com> Cc: Hayes <hayeswang@realtek.com> Tested-by: Marc Ballarin <ballarin.marc@gmx.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19Merge branch 'v4l_for_linus' of git://linuxtv.org/mchehab/for_linusLinus Torvalds
* 'v4l_for_linus' of git://linuxtv.org/mchehab/for_linus: [media] videodev: fix a NULL pointer dereference in v4l2_device_release()
2011-10-19[media] videodev: fix a NULL pointer dereference in v4l2_device_release()Antonio Ospite
The change in 8280b66 does not cover the case when v4l2_dev is already NULL, fix that. With a Kinect sensor, seen as an USB camera using GSPCA in this context, a NULL pointer dereference BUG can be triggered by just unplugging the device after the camera driver has been loaded. Signed-off-by: Antonio Ospite <ospite@studenti.unina.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-10-19intel-iommu: fix superpage support in pfn_to_dma_pte()Allen Kay
If target_level == 0, current code breaks out of the while-loop if SUPERPAGE bit is set. We should also break out if PTE is not present. If we don't do this, KVM calls to iommu_iova_to_phys() will cause pfn_to_dma_pte() to create mapping for 4KiB pages. Signed-off-by: Allen Kay <allen.m.kay@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-10-19intel-iommu: set iommu_superpage on VM domains to lowest common denominatorAllen Kay
set dmar->iommu_superpage field to the smallest common denominator of super page sizes supported by all active VT-d engines. Initialize this field in intel_iommu_domain_init() API so intel_iommu_map() API will be able to use iommu_superpage field to determine the appropriate super page size to use. Signed-off-by: Allen Kay <allen.m.kay@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-10-19intel-iommu: fix return value of iommu_unmap() APIAllen Kay
iommu_unmap() API expects IOMMU drivers to return the actual page order of the address being unmapped. Previous code was just returning page order passed in from the caller. This patch fixes this problem. Signed-off-by: Allen Kay <allen.m.kay@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-10-19drm/radeon/kms/atom: fix handling of FB scratch indicesAlex Deucher
FB scratch indices are dword indices, but we were treating them as byte indices. As such, we were getting the wrong FB scratch data for non-0 indices. Fix the indices and guard the indexing against indices larger than the scratch allocation. Fixes memory corruption on some boards if data was written past the end of the FB scratch array. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reported-by: Dave Airlie <airlied@redhat.com> Tested-by: Dave Airlie <airlied@redhat.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-19pptp: pptp_rcv_core() misses pskb_may_pull() callEric Dumazet
e1000e uses paged frags, so any layer incorrectly pulling bytes from skb can trigger a BUG in skb_pull() [951.142737] [<ffffffff813d2f36>] skb_pull+0x15/0x17 [951.142737] [<ffffffffa0286824>] pptp_rcv_core+0x126/0x19a [pptp] [951.152725] [<ffffffff813d17c4>] sk_receive_skb+0x69/0x105 [951.163558] [<ffffffffa0286993>] pptp_rcv+0xc8/0xdc [pptp] [951.165092] [<ffffffffa02800a3>] gre_rcv+0x62/0x75 [gre] [951.165092] [<ffffffff81410784>] ip_local_deliver_finish+0x150/0x1c1 [951.177599] [<ffffffff81410634>] ? ip_local_deliver_finish+0x0/0x1c1 [951.177599] [<ffffffff81410846>] NF_HOOK.clone.7+0x51/0x58 [951.177599] [<ffffffff81410996>] ip_local_deliver+0x51/0x55 [951.177599] [<ffffffff814105b9>] ip_rcv_finish+0x31a/0x33e [951.177599] [<ffffffff8141029f>] ? ip_rcv_finish+0x0/0x33e [951.204898] [<ffffffff81410846>] NF_HOOK.clone.7+0x51/0x58 [951.214651] [<ffffffff81410bb5>] ip_rcv+0x21b/0x246 pptp_rcv_core() is a nice example of a function assuming everything it needs is available in skb head. Reported-by: Bradley Peterson <despite@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19pptp: fix skb leak in pptp_xmit()Eric Dumazet
In case we cant transmit skb, we must free it Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Dmitry Kozlov <xeb@mail.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19bonding: use local function pointer of bond->recv_probe in bond_handle_frameMitsuo Hayasaka
The bond->recv_probe is called in bond_handle_frame() when a packet is received, but bond_close() sets it to NULL. So, a panic occurs when both functions work in parallel. Why this happen: After null pointer check of bond->recv_probe, an sk_buff is duplicated and bond->recv_probe is called in bond_handle_frame. So, a panic occurs when bond_close() is called between the check and call of bond->recv_probe. Patch: This patch uses a local function pointer of bond->recv_probe in bond_handle_frame(). So, it can avoid the null pointer dereference. Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Cc: Jay Vosburgh <fubar@us.ibm.com> Cc: Andy Gospodarek <andy@greyhouse.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: WANG Cong <xiyou.wangcong@gmail.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-19smsc911x: Add support for SMSC LAN89218Phil Edworthy
LAN89218 is register compatible with LAN911x. Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-18tg3: negate USE_PHYLIB flag checkJiri Pirko
USE_PHYLIB flag in tg3_remove_one() is being checked incorrectly. This results tg3_phy_fini->phy_disconnect is never called and when tg3 module is removed. In my case this resulted in panics in phy_state_machine calling function phydev->adjust_link. So correct this check. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-18netconsole: enable netconsole can make net_device refcnt incorrentGao feng
There is no check if netconsole is enabled current. so when exec echo 1 > enabled; the reference of net_device will increment always. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Acked-by: Flavio Leitner <fbl@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-18drm/radeon/kms/DCE4.1: fix Select_CrtcSource EncodeMode setting for DP ↵Alex Deucher
bridges (v2) Settings in this table reflect the physical panel/connector rather than the internal dig encoding. v2: fix typo for DRM_MODE_CONNECTOR_VGA case. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-18drm/radeon/kms/DCE4.1: ss is not supported on the internal ppllsAlex Deucher
It's handled via external clock. It should already be protected by the external ss flag, but add an explicit check just in case. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-18drm/radeon/kms/DCE4.1: fix dig encoder to transmitter mappingAlex Deucher
llano has fully routeable dig encoders similar to DCE3.2 while ontario has a hardcoded mapping similar to DCE4.0. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-18ttm: Fix error-path using an uninitialized valueThomas Hellstrom
Pointed out by Michel Daenzer. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-15Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (w83627ehf) Properly report thermal diode sensors
2011-10-14intel-iommu: Export a flag indicating that the IOMMU is used for iGFX.David Woodhouse
We really don't want this to work in the general case; device drivers *shouldn't* care whether they are behind an IOMMU or not. But the integrated graphics is a special case, because the IOMMU and the GTT are all kind of smashed into one and generally horrifically buggy, so it's reasonable for the graphics driver to want to know when the IOMMU is active for the graphics hardware. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-10-14intel-iommu: Workaround IOTLB hang on Ironlake GPUDavid Woodhouse
To work around a hardware issue, we have to submit IOTLB flushes while the graphics engine is idle. The graphics driver will (we hope) go to great lengths to ensure that it gets that right on the affected chipset(s)... so let's not screw it over by deferring the unmap and doing it later. That wouldn't be very helpful. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-10-14Merge branch 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6: gpio-pca953x: fix gpio_base gpio/omap: fix build error with certain OMAP1 configs
2011-10-13hwmon: (w83627ehf) Properly report thermal diode sensorsJean Delvare
The w83627ehf driver is improperly reporting thermal diode sensors as type 2, instead of 3. This caused "sensors" and possibly other monitoring tools to report these sensors as "transistor" instead of "thermal diode". Furthermore, diode subtype selection (CPU vs. external) is only supported by the original W83627EHF/EHG. All later models only support CPU diode type, and some (NCT6776F) don't even have the register in question so we should avoid reading from it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: stable@kernel.org Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
2011-10-13gpio-pca953x: fix gpio_baseHartmut Knaack
gpio_base was set to 0 if no system platform data or open firmware platform data was provided. This led to conflicts, if any other gpiochip with a gpiobase of 0 was instantiated already. Setting it to -1 will automatically use the first one available. Signed-off-by: Hartmut Knaack <knaack.h@gmx.de> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-13gpio/omap: fix build error with certain OMAP1 configsJanusz Krzysztofik
With commit f64ad1a0e21a, "gpio/omap: cleanup _set_gpio_wakeup(), remove ifdefs", access to build time conditionally omitted 'suspend_wakeup' member of the 'gpio_bank' structure has been placed unconditionally in function _set_gpio_wakeup(), which is always built. This resulted in the driver compilation broken for certain OMAP1, i.e., non-OMAP16xx, configurations. Really required or not in previously excluded cases, define this structure member unconditionally as a fix. Tested with a custom OMAP1510 only configuration. Signed-off-by: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Kevin Hilman <khilman@ti.com> Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-10-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: mscan: too much data copied to CAN frame due to 16 bit accesses gro: refetch inet6_protos[] after pulling ext headers bnx2x: fix cl_id allocation for non-eth clients for NPAR mode mlx4_en: fix endianness with blue frame support
2011-10-13ide: Fix file references in drivers/ide/Johann Felix Soden
Fix file references in drivers/ide/ There are a lot of file references to now moved or deleted files in the whole tree, especially in documentation and Kconfig files. This patch fixes the references in drivers/ide/. Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-10intel-iommu: Fix AB-BA lockdep reportRoland Dreier
When unbinding a device so that I could pass it through to a KVM VM, I got the lockdep report below. It looks like a legitimate lock ordering problem: - domain_context_mapping_one() takes iommu->lock and calls iommu_support_dev_iotlb(), which takes device_domain_lock (inside iommu->lock). - domain_remove_one_dev_info() starts by taking device_domain_lock then takes iommu->lock inside it (near the end of the function). So this is the classic AB-BA deadlock. It looks like a safe fix is to simply release device_domain_lock a bit earlier, since as far as I can tell, it doesn't protect any of the stuff accessed at the end of domain_remove_one_dev_info() anyway. BTW, the use of device_domain_lock looks a bit unsafe to me... it's at least not obvious to me why we aren't vulnerable to the race below: iommu_support_dev_iotlb() domain_remove_dev_info() lock device_domain_lock find info unlock device_domain_lock lock device_domain_lock find same info unlock device_domain_lock free_devinfo_mem(info) do stuff with info after it's free However I don't understand the locking here well enough to know if this is a real problem, let alone what the best fix is. Anyway here's the full lockdep output that prompted all of this: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.39.1+ #1 ------------------------------------------------------- bash/13954 is trying to acquire lock: (&(&iommu->lock)->rlock){......}, at: [<ffffffff812f6421>] domain_remove_one_dev_info+0x121/0x230 but task is already holding lock: (device_domain_lock){-.-...}, at: [<ffffffff812f6508>] domain_remove_one_dev_info+0x208/0x230 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (device_domain_lock){-.-...}: [<ffffffff8109ca9d>] lock_acquire+0x9d/0x130 [<ffffffff81571475>] _raw_spin_lock_irqsave+0x55/0xa0 [<ffffffff812f8350>] domain_context_mapping_one+0x600/0x750 [<ffffffff812f84df>] domain_context_mapping+0x3f/0x120 [<ffffffff812f9175>] iommu_prepare_identity_map+0x1c5/0x1e0 [<ffffffff81ccf1ca>] intel_iommu_init+0x88e/0xb5e [<ffffffff81cab204>] pci_iommu_init+0x16/0x41 [<ffffffff81002165>] do_one_initcall+0x45/0x190 [<ffffffff81ca3d3f>] kernel_init+0xe3/0x168 [<ffffffff8157ac24>] kernel_thread_helper+0x4/0x10 -> #0 (&(&iommu->lock)->rlock){......}: [<ffffffff8109bf3e>] __lock_acquire+0x195e/0x1e10 [<ffffffff8109ca9d>] lock_acquire+0x9d/0x130 [<ffffffff81571475>] _raw_spin_lock_irqsave+0x55/0xa0 [<ffffffff812f6421>] domain_remove_one_dev_info+0x121/0x230 [<ffffffff812f8b42>] device_notifier+0x72/0x90 [<ffffffff8157555c>] notifier_call_chain+0x8c/0xc0 [<ffffffff81089768>] __blocking_notifier_call_chain+0x78/0xb0 [<ffffffff810897b6>] blocking_notifier_call_chain+0x16/0x20 [<ffffffff81373a5c>] __device_release_driver+0xbc/0xe0 [<ffffffff81373ccf>] device_release_driver+0x2f/0x50 [<ffffffff81372ee3>] driver_unbind+0xa3/0xc0 [<ffffffff813724ac>] drv_attr_store+0x2c/0x30 [<ffffffff811e4506>] sysfs_write_file+0xe6/0x170 [<ffffffff8117569e>] vfs_write+0xce/0x190 [<ffffffff811759e4>] sys_write+0x54/0xa0 [<ffffffff81579a82>] system_call_fastpath+0x16/0x1b other info that might help us debug this: 6 locks held by bash/13954: #0: (&buffer->mutex){+.+.+.}, at: [<ffffffff811e4464>] sysfs_write_file+0x44/0x170 #1: (s_active#3){++++.+}, at: [<ffffffff811e44ed>] sysfs_write_file+0xcd/0x170 #2: (&__lockdep_no_validate__){+.+.+.}, at: [<ffffffff81372edb>] driver_unbind+0x9b/0xc0 #3: (&__lockdep_no_validate__){+.+.+.}, at: [<ffffffff81373cc7>] device_release_driver+0x27/0x50 #4: (&(&priv->bus_notifier)->rwsem){.+.+.+}, at: [<ffffffff8108974f>] __blocking_notifier_call_chain+0x5f/0xb0 #5: (device_domain_lock){-.-...}, at: [<ffffffff812f6508>] domain_remove_one_dev_info+0x208/0x230 stack backtrace: Pid: 13954, comm: bash Not tainted 2.6.39.1+ #1 Call Trace: [<ffffffff810993a7>] print_circular_bug+0xf7/0x100 [<ffffffff8109bf3e>] __lock_acquire+0x195e/0x1e10 [<ffffffff810972bd>] ? trace_hardirqs_off+0xd/0x10 [<ffffffff8109d57d>] ? trace_hardirqs_on_caller+0x13d/0x180 [<ffffffff8109ca9d>] lock_acquire+0x9d/0x130 [<ffffffff812f6421>] ? domain_remove_one_dev_info+0x121/0x230 [<ffffffff81571475>] _raw_spin_lock_irqsave+0x55/0xa0 [<ffffffff812f6421>] ? domain_remove_one_dev_info+0x121/0x230 [<ffffffff810972bd>] ? trace_hardirqs_off+0xd/0x10 [<ffffffff812f6421>] domain_remove_one_dev_info+0x121/0x230 [<ffffffff812f8b42>] device_notifier+0x72/0x90 [<ffffffff8157555c>] notifier_call_chain+0x8c/0xc0 [<ffffffff81089768>] __blocking_notifier_call_chain+0x78/0xb0 [<ffffffff810897b6>] blocking_notifier_call_chain+0x16/0x20 [<ffffffff81373a5c>] __device_release_driver+0xbc/0xe0 [<ffffffff81373ccf>] device_release_driver+0x2f/0x50 [<ffffffff81372ee3>] driver_unbind+0xa3/0xc0 [<ffffffff813724ac>] drv_attr_store+0x2c/0x30 [<ffffffff811e4506>] sysfs_write_file+0xe6/0x170 [<ffffffff8117569e>] vfs_write+0xce/0x190 [<ffffffff811759e4>] sys_write+0x54/0xa0 [<ffffffff81579a82>] system_call_fastpath+0x16/0x1b Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-10-10mscan: too much data copied to CAN frame due to 16 bit accessesWolfgang Grandegger
Due to the 16 bit access to mscan registers there's too much data copied to the zero initialized CAN frame when having an odd number of bytes to copy. This patch ensures that only the requested bytes are copied by using an 8 bit access for the remaining byte. Reported-by: Andre Naujoks <nautsch@gmail.com> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-10bnx2x: fix cl_id allocation for non-eth clients for NPAR modeDmitry Kravkov
There are some consolidations of NPAR configuration when FCoE and iSCSI L2 clients will get the same id, in this case FCoE ring will be non-functional. Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-10mlx4_en: fix endianness with blue frame supportThadeu Lima de Souza Cascardo
The doorbell register was being unconditionally swapped. In x86, that meant it was being swapped to BE and written to the descriptor and to memory, depending on the case of blue frame support or writing to doorbell register. On PPC, this meant it was being swapped to LE and then swapped back to BE while writing to the register. But in the blue frame case, it was being written as LE to the descriptor. The fix is not to swap doorbell unconditionally, write it to the register as BE and convert it to BE when writing it to the descriptor. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@linux.vnet.ibm.com> Reported-by: Richard Hendrickson <richhend@us.ibm.com> Cc: Eli Cohen <eli@dev.mellanox.co.il> Cc: Yevgeny Petrilin <yevgenyp@mellanox.co.il> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-10Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
* 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/radeon/kms: use hardcoded dig encoder to transmitter mapping for DCE4.1 drm/radeon/kms: fix dp_detect handling for DP bridge chips drm/radeon/kms: retry aux transactions if there are status flags
2011-10-10Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://git.linux-mips.org/pub/scm/upstream-linus: (29 commits) MIPS: Call oops_enter, oops_exit in die staging/octeon: Software should check the checksum of no tcp/udp packets MIPS: Octeon: Enable C0_UserLocal probing. MIPS: No branches in delay slots for huge pages in handle_tlbl MIPS: Don't clobber CP0_STATUS value for CONFIG_MIPS_MT_SMTC MIPS: Octeon: Select CONFIG_HOLES_IN_ZONE MIPS: PM: Use struct syscore_ops instead of sysdevs for PM (v2) MIPS: Compat: Use 32-bit wrapper for compat_sys_futex. MIPS: Do not use EXTRA_CFLAGS MIPS: Alchemy: DB1200: Disable cascade IRQ in handler SERIAL: Lantiq: Set timeout in uart_port MIPS: Lantiq: Fix setting the PCI bus speed on AR9 MIPS: Lantiq: Fix external interrupt sources MIPS: tlbex: Fix build error in R3000 code. MIPS: Alchemy: Include Au1100 in PM code. MIPS: Alchemy: Fix typo in MAC0 registration MIPS: MSP71xx: Fix build error. MIPS: Handle __put_user() sleeping. MIPS: Allow forced irq threading MIPS: i8259: Mark cascade interrupt non-threaded ...
2011-10-06Merge git://github.com/davem330/netLinus Torvalds
* git://github.com/davem330/net: net: fix typos in Documentation/networking/scaling.txt bridge: leave carrier on for empty bridge netfilter: Use proper rwlock init function tcp: properly update lost_cnt_hint during shifting tcp: properly handle md5sig_pool references macvlan/macvtap: Fix unicast between macvtap interfaces in bridge mode
2011-10-06Merge branch 'for-linus' of http://people.redhat.com/agk/git/linux-dmLinus Torvalds
* 'for-linus' of http://people.redhat.com/agk/git/linux-dm: dm crypt: always disable discard_zeroes_data dm: raid fix write_mostly arg validation dm table: avoid crash if integrity profile changes dm: flakey fix corrupt_bio_byte error path
2011-10-06Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: md: Avoid waking up a thread after it has been freed.
2011-10-06drm/radeon/kms: use hardcoded dig encoder to transmitter mapping for DCE4.1Alex Deucher
The encoders are supposedly fully routeable, but changing the mapping doesn't always seem to take. Using a hardcoded mapping is much more reliable. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=41366 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Tested-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-05Merge branch 'for-linus' of git://github.com/dtor/inputLinus Torvalds
* 'for-linus' of git://github.com/dtor/input: Input: wacom - revert "Cintiq 21UX2 does not have menu strips"
2011-10-05Merge git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6Linus Torvalds
* git://bedivere.hansenpartnership.com/git/scsi-rc-fixes-2.6: [SCSI] libsas: fix panic when single phy is disabled on a wide port [SCSI] qla2xxx: Fix crash in qla2x00_abort_all_cmds() on unload
2011-10-05drm/radeon/kms: fix dp_detect handling for DP bridge chipsAlex Deucher
The HPD pin is not reliable for detecting whether a monitor is connected or not. Skip HPD and just use DDC or load detection. Fixes phantom VGA connected bugs. [Michel: fixes phantom VGA bugs on his llano system.] Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Tested-by: Michel Dänzer <michel.daenzer@amd.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-05drm/radeon/kms: retry aux transactions if there are status flagsAlex Deucher
If there are error flags in the aux status, retry the transaction. This makes aux much more reliable, especially on llano systems. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Cc: stable@kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-10-04Input: wacom - revert "Cintiq 21UX2 does not have menu strips"Jason Gerecke
This reverts commit 71c86ce59791bcd67af937bbea719a508079d7c2. The 21UX2 does have touchstrips, but they are in a somewhat- hidden location. Signed-off-by: Jason Gerecke <killertofu@gmail.com> Acked-by: Ping Cheng <pinglinux@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2011-10-04macvlan/macvtap: Fix unicast between macvtap interfaces in bridge modeDavid Ward
Packets should always be forwarded to the lowerdev using dev_forward_skb. vlan->forward is for packets being forwarded directly to another macvlan/ macvtap device (used for multicast in bridge mode). Reported-and-tested-by: Shlomo Pongratz <shlomop@mellanox.com> Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-04Merge git://github.com/davem330/netLinus Torvalds
* git://github.com/davem330/net: pch_gbe: Fixed the issue on which a network freezes pch_gbe: Fixed the issue on which PC was frozen when link was downed. make PACKET_STATISTICS getsockopt report consistently between ring and non-ring net: xen-netback: correctly restart Tx after a VM restore/migrate bonding: properly stop queuing work when requested can bcm: fix incomplete tx_setup fix RDSRDMA: Fix cleanup of rds_iw_mr_pool net: Documentation: Fix type of variables ibmveth: Fix oops on request_irq failure ipv6: nullify ipv6_ac_list and ipv6_fl_list when creating new socket cxgb4: Fix EEH on IBM P7IOC can bcm: fix tx_setup off-by-one errors MAINTAINERS: tehuti: Alexander Indenbaum's address bounces dp83640: reduce driver noise ptp: fix L2 event message recognition
