(submitted upstream as 19a8f59ab8ceee751ea720085098355d53f727d6)
perhaps bonghits could turn on my bus-mastering because the drm
certainly never bothered doing it before.
Signed-off-by: Dave Airlie <airlied@linux.ie>
patch 7d640c4a5b36c4733460065db1554da924044511 in mainline.
This reverts commit 109f0e93b6b728f03c1eb4af02bc25d71b646c59.
The original patch breaks BIOS updates on all Dell machines. The path to
the firmware file for the dell_rbu driver changes, which breaks all of
the userspace tools which rely on it.
Note that this patch re-introduces a problem with i2c name collision
that was previously fixed by this patch.
Signed-off-by: Michael E Brown <michael_e_brown@dell.com>
(not in mainline, as it is not applicable.)
We must reject new incompatible firmware early to avoid
running into strange transmission failures.
The current development tree supports newer firmware revisions.
These revisions cause strange failures on the stable 2.6.24 kernel.
Add a check to avoid confusing users a lot.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
patch 8dd0100ce9511e52614ecd0a6587c13ce5769c8b in mainline.
This fixes four resource leakages.
In any error path we must deallocate the DMA frame slots we
previously allocated by request_slot().
This is done by storing the ring pointers before doing any ring
allocation and restoring the old pointers in case of an error.
This patch by Michael Buesch has been ported to b43legacy.
Cc: Michael Buesch <mb@bu3sch.de>
Signed-off-by: Stefano Brivio <stefano.brivio@polimi.it>
patch 9eca9a8e81928685b4de00ecef83a7c13c340fc9 in mainline.
We must drop any packets we are not able to encrypt.
We must not send them unencrypted or with an all-zero-key (which
basically is the same as unencrypted, from a security point of view).
This might only trigger shortly after resume before mac80211 reassociated
and reconfigured the keys.
It is safe to drop these packets, as the association they belong to
is not guaranteed anymore anyway.
This is a security fix in the sense that it prevents information leakage.
patch ada50731c0346bf900dc387edd3a6961297bf2d3 in mainline.
This patch makes suspend/resume work with the b43legacy driver.
We must not overwrite the MAC addresses in the init function, as this
would also overwrite the MAC on resume. With an all-zero MAC the device
firmware is not able to ACK any received packets anymore.
Fix this by moving the initializion stuff that must be done on init but
not on resume to the start function.
Also zero out filter_flags to make sure we don't have some flags
from a previous instance for a tiny timeframe until mac80211 reconfigures
them.
patch 0cd67d48b519c3d8d89d238fab1cf68a5289638a in mainline.
Fix the crash reported below, which seems to happen on bcm4306 rev. 2 devices
only while using PIO:
Oops: 0000 [#1] PREEMPT
Modules linked in: b43(F) rfkill(F) led_class(F) input_polldev(F) arc4 b43legacy mac80211 cfg80211 i915 drm snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device ohci1394 ieee1394 ssb pcmcia snd_intel8x0m ehci_hcd uhci_hcd evdev
Pid: 0, comm: swapper Tainted: GF (2.6.24st3 #2)
EIP: 0060:[<f90f667b>] EFLAGS: 00010002 CPU: 0
EIP is at b43legacy_pio_handle_txstatus+0xbb/0x210 [b43legacy]
EAX: 0000049b EBX: f11f8044 ECX: 00000001 EDX: 00000000
ESI: f1ff8000 EDI: 00000000 EBP: f11f8040 ESP: c04f4ef4
DS: 007b ES: 007b FS: 0000 GS: 0000 SS: 0068
Process swapper (pid: 0, ti=c04f4000 task=c0488300 task.ti=c04b8000)
Stack: f90f2788 c05009f0 c0500900 000010f7 f1053823 c04f4f24 dfb8e800 00000003
f1368000 00000007 00000296 f90f1975 00001000 010c0800 01000000 00000007
f90f6391 f11f8000 00000082 c04f4f4a 00000000 00004fd0 10f70000 8c061000
Call Trace:
[<f90f2788>] b43legacy_debugfs_log_txstat+0x48/0xb0 [b43legacy]
[<f90f1975>] b43legacy_handle_hwtxstatus+0x75/0x80 [b43legacy]
[<f90f6391>] b43legacy_pio_rx+0x201/0x280 [b43legacy]
[<f90e4fa3>] b43legacy_interrupt_tasklet+0x2e3/0x870 [b43legacy]
[<c0123567>] tasklet_action+0x27/0x60
[<c01237b4>] __do_softirq+0x54/0xb0
[<c010686b>] do_softirq+0x7b/0xe0
[<c01457c0>] handle_level_irq+0x0/0x110
[<c0123758>] irq_exit+0x38/0x40
[<c0106953>] do_IRQ+0x83/0xd0
[<c011812f>] __update_rq_clock+0x4f/0x180
[<c0104b4f>] common_interrupt+0x23/0x28
[<c011007b>] wakeup_code+0x7b/0xde
[<c02b1039>] acpi_processor_idle+0x24a/0x3c9
[<c01025c7>] cpu_idle+0x47/0x80
[<c04b9ad5>] start_kernel+0x205/0x290
[<c04b9360>] unknown_bootoption+0x0/0x1f0
Code: 0f 00 00 81 fb ff 00 00 00 0f 87 36 01 00 00 8d 04 db 85 ff 8d 6c c6 40 8d 5d 04 0f 85 ef 00 00 00 fe 4e 0e 0f b7 46 0c 8b 53 04 <8b> 4a 50 29 c8 83 e8 52 66 89 46 0c 8b 54 24 14 80 7a 0b 00 74
EIP: [<f90f667b>] b43legacy_pio_handle_txstatus+0xbb/0x210 [b43legacy] SS:ESP 0068:c04f4ef4
Kernel panic - not syncing: Fatal exception in interrupt
patch 09552ccd8277e6382097e93a40f7311a09449367 in mainline
patch 7be1bb6b798d506693d2d8668e801951996b5a4a in mainline.
This patch makes suspend/resume work with the b43 driver.
them.
patch 82637e808478087ce861129745fa60cc37e7929d in mainline
This patch disables config mode access after clearing PCI settings.
Without this change WOL won't work on some BIOS's
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
patch a7bffe722c996679b4fb2103ecaf673ec2b9b4a7 in mainline.
If the sky2 deadman timer forces a recovery, the multicast hash
list is lost. Move the call to sky2_set_multicast to the end
of sky2_up() so all paths that bring device up will restore multicast.
These minor changes sync the latest ACPI blacklist into 2.6.24.
The main benefit of this patch is to make any future
changes easier to apply. The immediate benefit is one less
dmesg line on Acer systems.
Signed-off-by: Len Brown <len.brown@intel.com>
This patch works around a problem in the fakephp driver when a process
writing "0" to a "power" sysfs file to fake removal of a PCI device ends
up deadlocking itself in the sysfs code.
The patch was recently accepted into Linus' tree after the 2.6.24 release:
http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=5c796ae7a7ebe56967ed9b9963d7c16d733635ff
Signed-off-by: Ian Abbott <abbotti@mev.co.uk>
patch 2b91213064bd882c3adf35f028c6d12fab3269ec in mainline.
This patch is a critical fix for MCP77 and MCP79 devices. The feature
flags were missing the define for correct mac address
(DEV_HAS_CORRECT_MACADDR).
Signed-off-by: Ayaz Abdulla <aabdulla@nvidia.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
The device setup did miss to initialize the num_interrupt_out field, thus
failing to successfully complete the probe function.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
Cc: Alan Cox <alan@redhat.com>
Some crazy devices in the wild have a vendor id of 0x0000. If we try to
add a module alias with this id, we just can't do it due to a check in
the file2alias.c file. Change the test to verify that both the vendor
and product ids are 0x0000 to show a real "blank" module alias.
Note, the module-init-tools package also needs to be changed to properly
generate the depmod tables.
Cc: Janusz <janumix@poczta.fm>
Cc: Jon Masters <jcm@redhat.com>
usbtest did not swap the received status information when checking for
a non-zero value and failed to discover halted endpoints on big endian
systems.
Signed-off-by: Jan Andersson <jan@gaisler.com>
Acked-by: David Brownell <david-b@pacbell.net>
Add "FIX_CAPACITY" entry for HP Photosmart r707 Camera in "Disk" mode.
Camera will wedge when /lib/udev/vol_id attempts to access the last sector,
EIO gets reported to dmesg, and block device is marked "offline" (it is).
Reproduced vol_id behavior with:
"dd if=/dev/sda of=/dev/null skip=60800 count=1"
Signed-off-by: Grant Grundler <grundler@parisc-linux.org>
Signed-off-by: Phil Dibowitz <phil@ipom.com>
I've got a Dell wireless 5520 card with a different USB ID - specifically, 8136
instead of 8137. Attached a small patch to add support, and the output of an
'ati3'.
If we could get this in, that'd be sweet. ;) Thanks!
nc@knight:~/tmp/linux-2.6.24-rc8/drivers/usb/serial$ lsusb | grep 8136
Bus 001 Device 005: ID 413c:8136 Dell Computer Corp.
nc@knight:~/tmp/linux-source-2.6.23/drivers/usb/serial$ cu -l ttyUSB0 -s 115200
Connected.
ati3
Manufacturer: Novatel Wireless Incorporated
Model: Expedite EU860D MiniCard
Revision: 10.10.04.01-01 [2007-04-11 14:07:19]
IMEI: 011186000228043
+GCAP: +CGSM,+DS,+ES
this function will run in the context of the scsi error handler thread.
It must use GFP_NOIO instead of GFP_KERNEL to avoid a possible
deadlock.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Added support for the Elster Unicom III Optical Probe.
The device ID has already been added to the usb.ids file.
Signed-off-by: Ed Beroset <beroset@mindspring.com>
pl2303: add support for RATOC REX-USB60F
This patch adds support for RATOC REX-USB60F Serial Adapters,
which is widely used in Japan recently.
Signed-off-by: Akira Tsukamoto <akirat@rd.scei.sony.co.jp>
Remove entry for Huawei E620 UMTS/HSDPA card (ID: 12d1:1001) in pl2303 driver
Option driver is use instead
Signed-off-by: Daniel Kozák <kozzi11@gmail.com>
Sierra Wireless
Added support for Onda H600/Zte MF330 GPRS/UMTS/HSDPA datacard
Signed-off-by: Bruno Redondi <bruno.redondi@altarisoluzione.com>
little patches only to add vendor/device id of ATK_16IC CCD cam for
astronomy.
I work with a group of people on a free home automation tool called
FHEM. Some of the users own more than one USB-serial device by ELV. The
ftdi_sio driver has most of the ELV devices disabled by default and
needs to be re-enabled every time you get a new kernel. Additionally a
new device (EM 1010 PC - enegry monitor) is missing in the list.
Currently our users have to follow the instructions we provide at
http://www.koeniglich.de/fhem/linux.html ... However, to some users it
is too complicated to compile their own kernel module.
We are aware that you can specify one additional device using the
vendor/product option of the module. But lot's of users own more than
one device.
Signed-off-by: Peter Stark <peter.stark@t-online.de>
The following improvements were made:
- Added new product support: MC5725, AC 880 U, MP 3G (UMTS & CDMA)
Signed-off-by: Kevin Lloyd <linux@sierrawireless.com>
This simply adds the "YC Cable" as a vendor and its pl2303-based
USB<->Serial adapter as a product. This particular adapter is sold by
Radio Shack. I've done limited testing on a few different systems with
no issues.
Adds the appropriate vendor and device IDs for the AirCard 881U to
sierra.c. (This device is often rebadged by AT&T as the USBConnect 881).
Signed-off-by: Jessica L Blank <j@twu.net>
add support for:
4348:5523 WinChipHead USB->RS 232 adapter with Prolifec PL 2303 chipset
[ mingo@elte.hu: merged it and nursed it upstream ]
Six new device IDs for CP2101 driver.
Signed-off-by: Craig Shelley <craig@microtron.org.uk>
For fsl_usb2_udc driver, ep0 also has a descriptor. Current code is
misleading and contains a logical mistake. Here is the patch to fix it.
http://bugzilla.kernel.org/show_bug.cgi?id=9595
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
If we get a data URB back from the hardware after we have put the tty to
bed we go kaboom. Fortunately all we need to do is process the URB
without trying to ram its contents down the throat of an ex-tty.
Signed-off-by: Alan Cox <alan@redhat.com>
Drivers that register a ->fault handler, but do not range-check the
offset argument, must set VM_DONTEXPAND in the vm_flags in order to
prevent an expanding mremap from overflowing the resource.
I've audited the tree and attempted to fix these problems (usually by
adding VM_DONTEXPAND where it is not obvious).
Signed-off-by: Nick Piggin <npiggin@suse.de>
[PATCH] DVB: cx23885: add missing subsystem ID for Hauppauge HVR1800 Retail
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Before transmission of the last word in PIO RX_ONLY mode rx+tx mode
is enabled:
/* prevent last RX_ONLY read from triggering
* more word i/o: switch to rx+tx
if (c == 0 && tx == NULL)
mcspi_write_cs_reg(spi,
OMAP2_MCSPI_CHCONF0, l);
But because c is decremented after the test, c will never be zero and
rx+tx will not be enabled. This breaks RX_ONLY mode PIO transfers.
Fix it by decrementing c in the beginning of the various I/O loops.
Signed-off-by: Kalle Valo <kalle.valo@nokia.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6:
Revert "ACPI: Fan: Drop force_power_state acpi_device option"
ACPI: EC: "DEBUG" needs to be defined earlier
ACPI: EC: add leading zeros to debug messages
ACPI: EC: fix dmesg spam regression
ACPI: DMI blacklist to reduce console warnings on OSI(Linux) systems.
ACPI: Add ThinkPad R61, ThinkPad T61 to OSI(Linux) white-list
ACPI: make _OSI(Linux) console messages smarter
ACPI: Delete Intel Customer Reference Board (CRB) from OSI(Linux) DMI list
ACPI: on OSI(Linux), print needed DMI rather than requesting dmidecode output
ACPI: create acpi_dmi_dump()
DMI: create dmi_get_slot()
DMI: move dmi_available declaration to linux/dmi.h
ACPI: processor: Fix null pointer dereference in throttling
This reverts commit 93ad7c07ad487b036add8760dabcc35666a550ef.
http://bugzilla.kernel.org/show_bug.cgi?id=9798
The "DEBUG" symbol needs to be defined before #including <linux/kernel.h> to
get the pr_debug() working.
Signed-off-by: Márton Németh <nm127@freemail.hu>
Add leading zeros to pr_debug() calls. For example if x=0x0a, the format
"0x%2x" will result the string "0x a", the format "0x%2.2x" will result "0x0a".
Return OBF_1 optimization workaround
http://bugzilla.kernel.org/show_bug.cgi?id=8459
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6:
[SPARC]: Constify function pointer tables.
[SPARC64]: Fix section error in sparcspkr
[SPARC64]: Fix of section mismatch warnings.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
sis190: scheduling while atomic error
sis190: mdio operation failure is not correctly detected
sis190: remove duplicate INIT_WORK
sis190: add cmos ram access code for the SiS19x/968 chipset pair
[INET]: Fix truesize setting in ip_append_data
[NETNS]: Re-export init_net via EXPORT_SYMBOL.
iwlwifi: fix possible read attempt on ucode that is not available
[IPV4]: Add missing skb->truesize increment in ip_append_page().
[TULIP] DMFE: Fix SROM parsing regression.
[BLUETOOTH]: Move children of connection device to NULL before connection down.
This DMI blacklist reduces the console messages
on systems which have a BIOS that invokes OSI(Linux).
As the DMI blacklist already knows about these systems,
the request for DMI info itself is disabled.
Further, if OSI(Linux) has already been determined
to have no beneift, we disable the console message
requesting acpi_osi=Linux test results.
acpi_osi=Linux helps sound on these systems.
