commit 0ed013e28fe853244f4972cf18d8e2bd62eeb8fc upstream.
The MAC can drop short packets when the PHY detects noise on the line at
100Mbps due to a timing issue. Workaround the issue by increasing the PLL
counter so the PHY properly recognizes the synchronization pattern from the
MAC.
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
Cc: Leann Ogasawara <leann.ogasawara@canonical.com>
commit 3c4aa91f21f65b7b40bdfb015eacbcb8453ccae2 upstream.
Like e65cc194f7628ecaa02462f22f42fb09b50dcd49 this patch enables 64bit DMA
for the AHCI SATA controller of a board that has the SB600 southbridge. In
this case though we're enabling 64bit DMA for the Asus M3A motherboard. It
is a new enough board that all of the BIOS releases since the initial
release (0301 from 2007-10-22) work correctly with 64bit DMA enabled.
Signed-off-by: Mark Nelson <mdnelson8@gmail.com>
Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
commit cb7cf41961fe10773c491c75ae73539ad4bbed66 upstream.
The encoders are supposedly fully routeable, but changing the mapping
doesn't always seem to take. Using a hardcoded mapping is much more
reliable.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=41366
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Tested-by: Simon Farnsworth <simon.farnsworth@onelan.co.uk>
commit 4f332844cc87c5f99c5300f788abbe8a8c731390 upstream.
If there are error flags in the aux status, retry the transaction.
This makes aux much more reliable, especially on llano systems.
Reviewed-by: Michel Dänzer <michel.daenzer@amd.com>
commit d982dcdc4e64eb1881df44b0035a8268bf1ab067 upstream.
Fix clock rate setting in the mxs-mmc driver. Previously, if div2 was 0
then the value for TIMING_CLOCK_RATE would have been 255 instead of 0.
The limits for div1 (TIMING_CLOCK_DIVIDE) and div2 (TIMING_CLOCK_RATE+1)
were also not correctly defined.
Can easily be reproduced on mx23evk: default clock for high speed sdio
cards is 50 MHz. With a SSP_CLK of 28.8 MHz default), this resulted in
an actual clock rate of about 56 kHz. Tested on mx23evk.
Signed-off-by: Koen Beel <koen.beel@barco.com>
Reviewed-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: Chris Ball <cjb@laptop.org>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
commit 876fbba1db4a377f050a2bb49b474c7527b2995d upstream.
Commit a63a5cf (dm: improve block integrity support) introduced a
two-phase initialization of a DM device's integrity profile. This
patch avoids dereferencing a NULL 'template_disk' pointer in
blk_integrity_register() if there is an integrity profile mismatch in
dm_table_set_integrity().
This can occur if the integrity profiles for stacked devices in a DM
table are changed between the call to dm_table_prealloc_integrity() and
Reported-by: Zdenek Kabelac <zkabelac@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Signed-off-by: Alasdair G Kergon <agk@redhat.com>
commit 01f96c0a9922cd9919baf9d16febdf7016177a12 upstream.
Two related problems:
1/ some error paths call "md_unregister_thread(mddev->thread)"
without subsequently clearing ->thread. A subsequent call
to mddev_unlock will try to wake the thread, and crash.
2/ Most calls to md_wakeup_thread are protected against the thread
disappeared either by:
- holding the ->mutex
- having an active request, so something else must be keeping
the array active.
However mddev_unlock calls md_wakeup_thread after dropping the
mutex and without any certainty of an active request, so the
->thread could theoretically disappear.
So we need a spinlock to provide some protections.
So change md_unregister_thread to take a pointer to the thread
pointer, and ensure that it always does the required locking, and
clears the pointer properly.
Reported-by: "Moshe Melnikov" <moshe@zadarastorage.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit a73914c35b05d80f8ce78288e10056c91090b666 upstream.
When a wide port is being utilized to a target, if one disables only one
of the
phys, we get an OS crash:
BUG: unable to handle kernel NULL pointer dereference at
0000000000000238
IP: [<ffffffff814ca9b1>] mutex_lock+0x21/0x50
PGD 4103f5067 PUD 41dba9067 PMD 0
Oops: 0002 [#1] SMP
last sysfs file: /sys/bus/pci/slots/5/address
CPU 0
Modules linked in: pm8001(U) ses enclosure fuse nfsd exportfs autofs4
ipmi_devintf ipmi_si ipmi_msghandler nfs lockd fscache nfs_acl
auth_rpcgss 8021q fcoe libfcoe garp libfc scsi_transport_fc stp scsi_tgt
llc sunrpc cpufreq_ondemand acpi_cpufreq freq_table ipv6 sr_mod cdrom
dm_mirror dm_region_hash dm_log uinput sg i2c_i801 i2c_core iTCO_wdt
iTCO_vendor_support e1000e mlx4_ib ib_mad ib_core mlx4_en mlx4_core ext3
jbd mbcache sd_mod crc_t10dif usb_storage ata_generic pata_acpi ata_piix
libsas(U) scsi_transport_sas dm_mod [last unloaded: pm8001]
Pid: 5146, comm: scsi_wq_5 Not tainted
2.6.32-71.29.1.el6.lustre.7.x86_64 #1 Storage Server
RIP: 0010:[<ffffffff814ca9b1>] [<ffffffff814ca9b1>]
RSP: 0018:ffff8803e4e33d30 EFLAGS: 00010246
RAX: 0000000000000000 RBX: 0000000000000238 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffff8803e664c800 RDI: 0000000000000238
RBP: ffff8803e4e33d40 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000001 R12: 0000000000000000
R13: 0000000000000238 R14: ffff88041acb7200 R15: ffff88041c51ada0
FS: 0000000000000000(0000) GS:ffff880028200000(0000)
knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 0000000000000238 CR3: 0000000410143000 CR4: 00000000000006f0
Process scsi_wq_5 (pid: 5146, threadinfo ffff8803e4e32000, task
ffff8803e4e294a0)
Stack:
ffff8803e664c800 0000000000000000 ffff8803e4e33d70 ffffffffa001f06e
<0> ffff8803e4e33d60 ffff88041c51ada0 ffff88041acb7200 ffff88041bc0aa00
<0> ffff8803e4e33d90 ffffffffa0032b6c 0000000000000014 ffff88041acb7200
Call Trace:
[<ffffffffa001f06e>] sas_port_delete_phy+0x2e/0xa0 [scsi_transport_sas]
[<ffffffffa0032b6c>] sas_unregister_devs_sas_addr+0xac/0xe0 [libsas]
[<ffffffffa0034914>] sas_ex_revalidate_domain+0x204/0x330 [libsas]
[<ffffffffa00307f0>] ? sas_revalidate_domain+0x0/0x90 [libsas]
[<ffffffffa0030855>] sas_revalidate_domain+0x65/0x90 [libsas]
[<ffffffff8108c7d0>] worker_thread+0x170/0x2a0
[<ffffffff81091ea0>] ? autoremove_wake_function+0x0/0x40
[<ffffffff8108c660>] ? worker_thread+0x0/0x2a0
[<ffffffff81091b36>] kthread+0x96/0xa0
[<ffffffff810141ca>] child_rip+0xa/0x20
[<ffffffff81091aa0>] ? kthread+0x0/0xa0
[<ffffffff810141c0>] ? child_rip+0x0/0x20
Code: ff ff 85 c0 75 ed eb d6 66 90 55 48 89 e5 48 83 ec 10 48 89 1c 24
4c 89 64 24 08 0f 1f 44 00 00 48 89 fb e8 92 f4 ff ff 48 89 df <f0> ff
0f 79 05 e8 25 00 00 00 65 48 8b 04 25 08 cc 00 00 48 2d
RIP [<ffffffff814ca9b1>] mutex_lock+0x21/0x50
RSP <ffff8803e4e33d30>
The following patch is admittedly a band-aid, and does not solve the
root cause, but it still is a good candidate for hardening as a pointer
check before reference.
Signed-off-by: Mark Salyzyn <mark_salyzyn@us.xyratex.com>
Tested-by: Jack Wang <jack_wang@usish.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 9bfacd01dc9b7519e1e6da12b01963550b9d09a2 upstream.
I hit a crash in qla2x00_abort_all_cmds() if the qla2xxx module is
unloaded right after it is loaded. I debugged this down to the abort
handling improperly treating a command of type SRB_ADISC_CMD as if it
had a bsg_job to complete when that command actually uses the iocb_cmd
part of the union. (I guess to hit this one has to unload the module
while the async FC initialization is still in progress)
It seems we should only look for a bsg_job if type is SRB_ELS_CMD_RPT,
SRB_ELS_CMD_HST or SRB_CT_CMD, so switch the test to make that explicit.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Acked-by: Chad Dupuis <chad.dupuis@qlogic.com>
commit 77a861c405da75d81e9e6e32c50eb7f9777777e8 upstream.
The rt2x00 driver gets frequent occurrences of the following error message
when operating under load:
phy0 -> rt2x00queue_write_tx_frame: Error - Arrived at non-free entry in the
non-full queue 2.
This is caused by simultaneous attempts from mac80211 to send a frame via
rt2x00, which are not properly serialized inside rt2x00queue_write_tx_frame,
causing the second frame to fail sending with the above mentioned error
message.
Fix this by introducing a per-queue spinlock to serialize the TX operations
on that queue.
Reported-by: Andreas Hartmann <andihartmann@01019freenet.de>
Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com>
Acked-by: Helmut Schaa <helmut.schaa@googlemail.com>
Signed-off-by: Ivo van Doorn <IvDoorn@gmail.com>
Cc: Tim Gardner <tim.gardner@canonical.com>
commit 12d5180bd7e683a4ae80830b82ba67e7b7fac7b2 upstream.
Most asics just use the hw default value which requires
no explicit programming. For those that need a different
value, the vbios will program it properly. As such,
there's no need to program these registers explicitly
in the driver. Changing MC_SHARED_CHREMAP requires a reload
of all data in vram otherwise its contents will be scambled.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=40103
v2: drop now unused channel_remap functions.
commit 6375bda073724ead7df08746866b724b1799a295 upstream.
The previous code could potentially loop forever. Limit
the number of DP aux defer retries to 4 for native aux
transactions, same as i2c over aux transactions.
Noticed by: Brad Campbell <lists2009@fnarfbargle.com>
Cc: Brad Campbell <lists2009@fnarfbargle.com>
commit 109bc10d30f33e84f1d7289f0039e0c858ade82f upstream.
An incorrect ordering in the error checking code lead
to DP aux defer being skipped in the aux native write
path. Move the bytes transferred check (ret == 0)
below the defer check.
Tracked down by: Brad Campbell <brad@fnarfbargle.com>
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=41121
Cc: Brad Campbell <brad@fnarfbargle.com>
commit 5ba7ddf81634bfdf32d09261d2959e3f5b7c4263 upstream.
Only disable the pipe if the monitor is physically
disconnected. The previous logic also disabled the
pipe if the link was trained.
Fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=41248
commit b8aee294d89502469f2d80ae6afb93398d8227e0 upstream.
Fixes cursor disappearing prematurely when moving off a top/left edge which
is not located at the desktop top/left edge.
Signed-off-by: Michel Dänzer <michel.daenzer@amd.com>
Reviewed-by: Alex Deucher <alexander.deucher@amd.com>
commit 05faadcf59507e8eea57ffbeea9cbb14c9a2ab3d upstream.
Commit 2a7fade7e03 ("hwmon: lis3: Power on corrections") caused a
regression on HP laptops with 8bit chip. Writing CTRL2_BOOT_8B bit seems
clearing the BIOS setup, and no proper interrupt for DriveGuard will be
triggered any more.
Since the init code there is basically only for embedded devices, put a
pdata check so that the problematic initialization will be skipped for
hp_accel stuff.
Cc: Eric Piel <eric.piel@tremplin-utc.net>
Cc: Samu Onkalo <samu.p.onkalo@nokia.com>
Signed-off-by: Andrew Morton <akpm@google.com>
commit 2c8fc867602e385fd2abe76da0b6bda8ed907547 upstream.
Simon Kirby reported that on his RAID setup with idedisk underneath
the box OOMs after a couple of days of runtime. Running with
CONFIG_DEBUG_KMEMLEAK pointed to idedisk_prep_fn() which unconditionally
allocates an ide_cmd struct. However, ide_requeue_and_plug() can be
called more than once per request, either from the request issue or the
IRQ handler path and do blk_peek_request() ends up in idedisk_prep_fn()
repeatedly, allocating a struct ide_cmd everytime and "forgetting" the
previous pointer.
Make sure the code reuses the old allocated chunk.
Reported-and-tested-by: Simon Kirby <sim@hostway.ca>
Link: http://marc.info/?l=linux-kernel&m=131667641517919
Link: http://lkml.kernel.org/r/20110922072643.GA27232@hostway.ca
Signed-off-by: Borislav Petkov <bp@alien8.de>
commit d9ad77ebfd3a304306f9f18ff3f9e522da075e27 upstream.
This reverts commit 18b4fada275dd2b6dd9db904ddf70fe39e272222.
This code was correct, apologies to anyone who noticed things broke.
revert contents are different due to another commit in between.
commit a0babc80eb375aad69dab4687c3b44c47d42f241 upstream.
Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com>
Signed-off-by: Eilon Greenstein <eilong@broadcom.com>
commit f2eaeb58bf6995a979c413ea0cc73289533feacb upstream.
Use register name to initialize attention mask
commit 6c80c39d9a6986a566c30d797aae37bfb697eea3 upstream.
If iwl_scan_initiate() fails for any reason,
priv->scan_request and priv->scan_vif are left
dangling. This can lead to a crash later when
iwl_bg_scan_completed() tries to run a pending
scan request.
In practice, this seems to be very rare due to
the STATUS_SCANNING check earlier. That check,
however, is wrong -- it should allow a scan to
be queued when a reset/roc scan is going on.
When a normal scan is already going on, a new
one can't be issued by mac80211, so that code
can be removed completely. I introduced this
bug when adding off-channel support in commit
266af4c745952e9bebf687dd68af58df553cb59d.
Reported-by: Peng Yan <peng.yan@intel.com>
Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com>
commit 65d0f19e583e80e42b1c67c166bfc4dfdf6ab693 upstream.
iwlegacy version of fix:
commit effd4d9aece9184f526e6556786a94d335e38b71
Author: Johannes Berg <johannes.berg@intel.com>
Date: Thu Sep 15 11:46:52 2011 -0700
iwlagn: do not use interruptible waits
Since the dawn of its time, iwlwifi has used
interruptible waits to wait for synchronous
commands and firmware loading.
This leads to "interesting" bugs, because it
can't actually handle the interruptions; for
example when a command sending is interrupted
it will assume the command completed fully,
and then leave it pending, which leads to all
kinds of trouble when the command finishes
later.
Since there's no easy way to gracefully deal
with interruptions, fix the driver to not use
interruptible waits.
This at least fixes the error
iwlagn 0000:02:00.0: Error: Response NULL in 'REPLY_SCAN_ABORT_CMD'
I have seen in P2P testing, but it is likely
that there are other errors caused by this.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 831d85471e761e190c3c8979b37540d699ae5812 upstream.
Driver rtl8192cu assigns a new struct rtl_tcb_desc object, but fails to
clear it.
commit 2e2a41d6ca07d1b2aa67015c35fd80701c98e867 upstream.
commit 282cdb325aea4ebbc42ce753b47cc96145eb54bc
Date: Mon Sep 12 12:09:10 2011 -0700
iwlagn: fix command queue timeout
If the command queue is constantly busy,
which can happen in P2P, the hangcheck
timer will frequently find a command in
it and will eventually reset the device
because nothing sets the timestamp for
this queue when commands are processed.
Fix this by setting the timestamp when
a command completes.
iwlegacy does not support P2P, but this patch fix possible
unneeded hardware resets, hence is needed.
commit e9f9530bb697f53dd620df290102359a3325bb23 upstream.
During the endurance testing, rx frames are not getting DMAd from
MAC whereas pcu rx frame counters are getting updated properly.
As per systems team input updated the initval to fix rx dma stuck
issue.
Signed-off-by: Rajkumar Manoharan <rmanohar@qca.qualcomm.com>
commit 3538a001ea7db13fa1be2966b71f69d808acff01 upstream.
qla4xxx driver needs to be linked with libiscsi.o to fix
build errors. This happens when no other drivers that use
libiscsi.o are enabled.
ERROR: "iscsi_conn_stop" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_get_addr_param" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_session_teardown" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_host_alloc" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_start" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_send_pdu" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_session_get_param" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_get_param" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_set_param" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_session_failure" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_complete_pdu" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_session_setup" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_bind" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_conn_setup" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
ERROR: "iscsi_itt_to_task" [drivers/scsi/qla4xxx/qla4xxx.ko] undefined!
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
child.
commit 24926dadc41cc566e974022b0e66231b82c6375f upstream.
In an enclosure model where there are chaining expanders to a large body
of storage, it was discovered that libsas, responding to a broadcast
event change, would only revalidate the domain of first child expander
in the list.
The issue is that the pointer value to the discovered source device was
used to break out of the loop, rather than the content of the pointer.
This still remains non-compliant as the revalidate domain code is
supposed to loop through all child expanders, and not stop at the first
one it finds that reports a change count. However, the design of this
routine does not allow multiple device discoveries and that would be a
more complicated set of patches reserved for another day. We are fixing
the glaring bug rather than refactoring the code.
Signed-off-by: Mark Salyzyn <msalyzyn@us.xyratex.com>
commit d0efab26f89506387a1bde898556660e06d7eb15 upstream.
scsi reset on hardware with enabled MSI interrupts generates WARNING message
[11027.798722] aacraid: Host adapter abort request (0,0,0,0)
[11027.798814] aacraid: Host adapter reset request. SCSI hang ?
[11087.762237] aacraid: SCSI bus appears hung
[11135.082543] ------------[ cut here ]------------
[11135.082646] WARNING: at drivers/pci/msi.c:658 pci_enable_msi_block+0x251/0x290()
Signed-off-by: Vasily Averin <vvs@sw.ru>
Acked-by: Mark Salyzyn <mark_salyzyn@us.xyratex.com>
commit 96067723e46b0dd24ae7b934085ab4eff4d26a1b upstream.
Following reports on the list, it looks like the 3e-9xxx driver will leak dma
mappings every time we get a transient queueing error back from the card.
This is because it maps the sg list in the routine that sends the command, but
doesn't unmap again in the transient failure path (even though the command is
sent back to the block layer). Fix by unmapping before returning the status.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
Acked-by: Adam Radford <aradford@gmail.com>
commit e48f129c2f200dde8899f6ea5c6e7173674fc482 upstream.
This oops was reported recently:
d:mon> e
cpu 0xd: Vector: 300 (Data Access) at [c0000000fd4c7120]
pc: d00000000076f194: .t3_l2t_get+0x44/0x524 [cxgb3]
lr: d000000000b02108: .init_act_open+0x150/0x3d4 [cxgb3i]
sp: c0000000fd4c73a0
msr: 8000000000009032
dar: 0
dsisr: 40000000
current = 0xc0000000fd640d40
paca = 0xc00000000054ff80
pid = 5085, comm = iscsid
d:mon> t
[c0000000fd4c7450] d000000000b02108 .init_act_open+0x150/0x3d4 [cxgb3i]
[c0000000fd4c7500] d000000000e45378 .cxgbi_ep_connect+0x784/0x8e8 [libcxgbi]
[c0000000fd4c7650] d000000000db33f0 .iscsi_if_rx+0x71c/0xb18
[scsi_transport_iscsi2]
[c0000000fd4c7740] c000000000370c9c .netlink_data_ready+0x40/0xa4
[c0000000fd4c77c0] c00000000036f010 .netlink_sendskb+0x4c/0x9c
[c0000000fd4c7850] c000000000370c18 .netlink_sendmsg+0x358/0x39c
[c0000000fd4c7950] c00000000033be24 .sock_sendmsg+0x114/0x1b8
[c0000000fd4c7b50] c00000000033d208 .sys_sendmsg+0x218/0x2ac
[c0000000fd4c7d70] c00000000033f55c .sys_socketcall+0x228/0x27c
[c0000000fd4c7e30] c0000000000086a4 syscall_exit+0x0/0x40
commit caca9510ff4e5d842c0589110243d60927836222 upstream.
In commit a144c6a6c924 ("PM: Print a warning if firmware is requested
when tasks are frozen") we not only printed a warning if somebody tried
to load the firmware when tasks are frozen - we also failed the load.
But that check was done before the check for built-in firmware, and then
when we disallowed usermode helpers during bootup (commit 288d5abec831:
"Boot up with usermodehelper disabled"), that actually means that
built-in modules can no longer load their firmware even if the firmware
is built in too. Which used to work, and some people depended on it for
the R100 driver.
So move the test for usermodehelper_is_disabled() down, to after
checking the built-in firmware.
This should fix:
https://bugzilla.kernel.org/show_bug.cgi?id=40952
Reported-by: James Cloos <cloos@hjcloos.com>
Bisected-by: Elimar Riesebieter <riesebie@lxtec.de>
Cc: Michel Dänzer <michel@daenzer.net>
Cc: Rafael Wysocki <rjw@sisk.pl>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Cc: Lucas Villa Real <lucasvr@gobolinux.org>
commit cc41d586e8b4d76164fe7731c1c49be6cc5fc7e6 upstream.
Signed (negative) temperatures were not handled correctly.
Signed-off-by: Roland Stigge <stigge@antcom.de>
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com>
commit b5a95fe7ef464a67fab6ff870aa740739e788f90 upstream.
Do not set io_req->sc_cmd to NULL until bnx2fc_unmap_sg_list() is called to
enable it to unmap the DMA mappings.
Signed-off-by: Bhanu Prakash Gollapudi <bprakash@broadcom.com>
commit d36b3279e157641c345b12eddb3db78fb42da80f upstream.
Deleting NPIV port causes a kernel panic when the NPIV port is in the same zone
as the physical port and shares the same LUN. This happens due to the fact that
vport destroy and unsolicited ELS are scheduled to run on the same workqueue,
and vport destroy destroys the lport and the unsolicited ELS tries to access
the invalid lport. This patch fixes this issue by maintaining a list of valid
lports and verifying if the lport is valid or not before accessing it.
commit 7625eb2f2fff7bfae41d3119b472c20b48874895 upstream.
Based on earlier patch from Neil Horman <nhorman@tuxdriver.com>
If iSCSI is not supported on a bnx2 device, bnx2_cnic_probe() will
return NULL and the cnic device will not be visible to bnx2i. This
will prevent bnx2i from registering and then unregistering during
cnic_start() and cause the warning message:
bnx2 0003:01:00.1: eth1: Failed waiting for ULP up call to complete
Signed-off-by: Michael Chan <mchan@broadcom.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
commit db1d350fcb156b58f66a67680617077bcacfe6fc upstream.
During NETDEV_UP, we use symbol_get() to get the net driver's cnic
probe function. This sometimes doesn't work if NETDEV_UP happens
right after NETDEV_REGISTER and the net driver is still running module
init code. As a result, the cnic device may not be discovered. We
fix this by probing on all NETDEV events if the device's netif_running
state is up.
commit 11f23aa8ccd56786f0a6f04211cf59b3fab2ce08 upstream.
This reduces the likelihood of port re-use when re-loading the driver.
Signed-off-by: Eddie Wai <eddie.wai@broadcom.com>
commit 101c40c8cb0d10c30f423805f9f5b7a75956832d upstream.
During iSCSI connection terminations, if the target is also terminating
at about the same time, the firmware may not complete the driver's
request to close or reset the connection. This is fixed by handling
other events (instead of the expected completion event) as an indication
that the driver's request has been rejected.
commit 93736656138e6d2f39f19c1d68f9ef81cfc9dd66 upstream.
We need to keep looping until cnic_get_kcqes() returns 0. cnic_get_kcqes()
returns a maximum of 64 entries. If there are more entries in the queue
and we don't loop back, the remaining entries may not be serviced for a
long time.
commit fdfc61594e6de21c23f955818ef78bcab9bafe40 upstream.
DVOOutputControl checks the value of of bios scratch reg 3
on some tables and assumes the encoder is already enabled
if the DFP2_ACTIVE bit is set. Clear that bit so the table
sets the DDIA enable bit properly.
commit a7e6401e19aa54924ab11ee548afaad0a55ffdc6 upstream.
ehci_bios_handoff() is marked __devinit, `ehci_dmi_nohandoff_table' should be
marked __devinitconst, not __initconst. This fixes the following section
mismatch:
WARNING: vmlinux.o(.devinit.text+0x4f08): Section mismatch in reference from the function ehci_bios_handoff() to the variable .init.rodata:ehci_dmi_nohandoff_table
The function __devinit ehci_bios_handoff() references a variable __initconst ehci_dmi_nohandoff_table.
If ehci_dmi_nohandoff_table is only used by ehci_bios_handoff then annotate ehci_dmi_nohandoff_table with a matching annotation.
Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Signed-off-by: Arnaud Lacombe <lacombar@gmail.com>
commit 74dcd0ec735ba9c5bef254b2f6e53068cf3f9ff0 upstream.
Have libiscsi_tcp have upper layers allocate the LLD data
along with the iscsi_cls_conn struct, so it is refcounted.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
commit 2cab7a4c5ccf96e0954e767af490ba9aee2c9b6f upstream.
This patch adds an additional SATA RAID controller DeviceID for the Intel Panther Point PCH.
Signed-off-by: Seth Heasley <seth.heasley@intel.com>
commit 77cd72a53f6426f81b7f56a862402849ee903bda upstream.
Hardware only increments the put pointer on event types >= 4. Do not
increment the get pointer for event type 3.
Reported-by: Kapil Karkra <kapil.karkra@intel.com>
commit 39ea2c5b5ffaa344467da53e885cfa4ac0105050 upstream.
Instead of immediately completing any request that has a second
termination call made on it, wait for the TC done/abort HW event.
Signed-off-by: Jeff Skirvin <jeffrey.d.skirvin@intel.com>
commit 985af6f70dbb8a33b3af8a7c7df508d924650e37 upstream.
Need the following workaround in the driver for interoperability with
the older Intel SSD drives and any other SATA drive that may exhibit the
same behavior. This is a corner case where SCU speed is limited to
either 3G or 1.5G and the drive has a period of DC idle when it switches
speed during SATA speed negotiation. Workaround :change PHYTOV[31:24]
from 0x36 to 0x3B.
Signed-off-by: Marcin Tomczak <marcin.tomczak@intel.com>
commit 0a96e9754d6c4a2a31e50ee6c6e36ec13f80bc25 upstream.
PCI and SR-IOV Fixes
- Call pci_save_state after the pci_restore_state completes.
- After calling pci_enable_pcie_error_reporting() and checking the return
value for logging messages from rc, reset rc to 0 to it will not later be
interpreted for error.
- Read PCI config space SR-IOV capability to get the number of VFs supported.
- Check for the PF's supported number of VFs before invoking PCI enable sriov
API call and log error message that user requested number of VFs is beyond
the PF capability if such request is passed in.
- Added check for Physical function with Virtual Functions attached. If so,
first disable all the VFs before proceeding to device reset.
Signed-off-by: Alex Iannicelli <alex.iannicelli@emulex.com>
Signed-off-by: James Smart <james.smart@emulex.com>
commit 5248a7498e5f6f3d6d276080466946f82f0ea56a upstream.
Fabric and Target Discovery Fixes
- Clear FC_VPORT_NEEDS_INIT_VPI flag during completion of REG_VFI mailbox
command.
- Prevent SLI3 Code from unregistering the physical VPI.
- Add an else clause to the code that checks and sets
sp->cmn.request_multiple_Nport to clear the bit.
- Remove a redundant mbox free.
- Modified lpfc_sli4_async_fip_evt to pass in physical VPI toi
lpfc_find_vport_by_vpid function.
- Modified lpfc_find_vport_by_vpid to translate physical VPI to logical VPI
before comparing with vport VPI.
commit 7851fe2c7f294d0beccf4c3d6af52e8247b89f00 upstream.
Adapter Interface fixes and changes
- Modify the macro field from lpfc_init_vpi_vpi to lpfc_init_vfi_vpi
- Add the new CQE_CODE_RECEIVE_V1 CQE Code, add code in the driver to handle
the new Code the same as the CQE_CODE_RECEIVE code except that there are
two new checks for this code that will cause the driver to use the new V1
macros for rq_id and fcf_id.
- Fix a bug in lpfc_prep_seq() where the size out of the first CQE was
ONLY being used, even though multiple dmabufs make up the sequence,
each have their own CQE with potentially different sizes.
- Fix bug in lpfc_bsg_ct_unsol_event() where the ulpContext and ulpWord[3]
fields of the XMIT_SEQUENCE64_CX IOCB were being calculated incorrectly.
- Do physical to logical translation before indexing into the active
XRI array.
- Populate physical vpi in the iocb data structure.
- Put the current accumulated total in each IOCB in the chain as we are
walking thru then. The last IOCB in the chain should have the total
length of the sequence.
commit 88a2cfbb8bf3802ca5a90c7d1567a1e542e6ef0c upstream.
Miscellaneous Bug fixes and code cleanup
- Fix 16G link speed reporting by adding check for 16G check.
- Change the check and enforcement of MAILBOX_EXT_SIZE (2048B)
to the check and enforcement of BSG_MBOX_SIZE - sizeof(MAILBOX_t) (3840B).
- Instead of waiting for a fixed amount of time after performing firmware
reset, the driver shall wait for the Lancer SLIPORT_STATUS register for the
readiness of the firmware for bring up.
- Add logging to indicate when dynamic parameters are changed.
- Add revision and date to the firmware image format.
- Use revision instead of rev_name to check firmware image version.
- Update temporary offset after memcopy is complete for firmware update.
- Consolidated the use of the macros to get rid of duplicated register
offset definitions.
- Removed the unused second parameter in routine lpfc_bsg_diag_mode_enter()
- Enable debugfs when debugfs is enabled.
- Update function comments for lpfc_sli4_alloc_xri and lpfc_sli4_init_rpi_hdrs.
