commit d25221525e0e2cfd70e4ec7216549c06609a8bd2 upstream.
Adjust the bulk message timeout to the other ones (1000ms). Otherwise the
following dmesg errors can be seen on a Raspberry Pi:
[ 31.492386] Failed to read 1-wire data from 0x81: err=-110.
[ 31.504168] 0x81: count=-110, status:
[ 31.613404] Failed to read 1-wire data from 0x81: err=-110.
[ 31.621915] 0x81: count=-110, status:
[ 43.260968] Failed to read 1-wire data from 0x81: err=-110.
[ 43.270998] 0x81: count=-110, status:
[ 43.379959] Failed to read 1-wire data from 0x81: err=-110.
[ 43.388854] 0x81: count=-110, status:
Signed-off-by: Alexander Stein <alexanders83@web.de>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
commit 5df848f37b1d20e5dd64bea16ba9f69ed321e11b upstream.
Return a negative error code on failure.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
commit c6b97bcf8e3ee6643a7f90a54d1ef3f9e12ec245 upstream.
edac_init() does not deallocate already allocated resources on failure
path.
Found by Linux Driver Verification project (linuxtesting.org).
[ Boris: The unwind path functions have __exit annotation but are being
used in an __init function, leading to section mismatches. Drop the
section annotation and make them normal functions. ]
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Link: http://lkml.kernel.org/r/1423203162-26368-1-git-send-email-khoroshilov@ispras.ru
commit 10640d34552ccd8fabe7b15b0c4e3a102247952d upstream.
If you pass an invalid string here then you probably deserve the memory
corruption, but it annoys static analysis tools so lets fix it.
commit d4b036648402bb4ef6d4a0df51375a2fb705b6cc upstream.
When a default page-size for given level should be mapped,
the level encoding must be 0 rather than 7. This fixes an
issue seen on IOMMUv2 hardware, where this encoding is
enforced.
Tested-by: Suravee Suthikulpanit <Suravee.Suthikulpanit@amd.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
commit b24b1b63a37d05d61601d643ef30f95dd2452048 upstream.
Now that fetch_pte returns the page-size of the pte, this
function can be optimized too.
commit 5d7c94c3f4f20964b217d64ee44a9a08320c315a upstream.
Now that fetch_pte returns the page-size of the pte, the
call in this function can also be optimized a little bit.
commit 71b390e9bec5121d25c45326ff0b0b96a143f9a8 upstream.
function can be optimized a lot.
commit 3039ca1b1c37e61cc9239dbb3903db55141ecabd upstream.
Extend the fetch_pte function to also return the page-size
that is mapped by the returned pte.
[ Upstream commit 31a418986a5852034d520a5bab546821ff1ccf3d ]
When we come to tear things down in netback_remove() and generate the
uevent it is possible that the xenstore directory has already been
removed (details below).
In such cases netback_uevent() won't be able to read the hotplug
script and will write a xenstore error node.
A recent change to the hypervisor exposed this race such that we now
sometimes lose it (where apparently we didn't ever before).
Instead read the hotplug script configuration during setup and use it
for the lifetime of the backend device.
The apparently more obvious fix of moving the transition to
state=Closed in netback_remove() to after the uevent does not work
because it is possible that we are already in state=Closed (in
reaction to the guest having disconnected as it shutdown). Being
already in Closed means the toolstack is at liberty to start tearing
down the xenstore directories. In principal it might be possible to
arrange to unregister the device sooner (e.g on transition to Closing)
such that xenstore would still be there but this state machine is
fragile and prone to anger...
A modern Xen system only relies on the hotplug uevent for driver
domains, when the backend is in the same domain as the toolstack it
will run the necessary setup/teardown directly in the correct sequence
wrt xenstore changes.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Acked-by: Wei Liu <wei.liu2@citrix.com>
[ Upstream commit 397a253af5031de4a4612210055935309af4472c ]
Currently, the calibration function that corrects the initial offsets
among multiple devices only works the first time. If the function is
called more than once, the calibration fails and bogus offsets will be
programmed into the devices.
In a well hidden spot, the device documentation tells that trigger indexes
0 and 1 are special in allowing the TRIG_IF_LATE flag to actually work.
This patch fixes the issue by using one of the special triggers during the
recalibration method.
Signed-off-by: Richard Cochran <richardcochran@gmail.com>
commit f11cc568758f23088c1f7a8369100c59e4c07bd6 upstream.
Avoid deprecated usage of EXTRA_CFLAGS by moving definition of DG_PART into dgnc_driver.h
Signed-off-by: Cass May <cass@cassm.net>
commit 97b0b6ca4c0f0f964d3c6918301ca45353ef8bc5 upstream.
If command line use EXTRA_CFLAGS (e.g. "EXTRA_CFLAGS=-mmedium-calls"
for arc architecture, with allmodconfig), it can not pass compiling,
the related error:
drivers/staging/rtl8188eu/core/rtw_ap.c:22:27: fatal error: osdep_service.h: No such file or directory
Signed-off-by: Chen Gang <gang.chen@asianux.com>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
"dgap_driver.h"
commit 6319c61aecc7acaf39a1dc0e81a8aac6a17499ee upstream.
Normally, the macros from command line are system specific macros (e.g
__linux, __KERNEL__ ...), and module own macros are usually defined in
their header files.
DG_NAME and DG_PART are driver 'dgap' owned macros which are used by
multiple files within driver, and need be defined in the driver main
header file.
So move DG_NAME and DG_PART to "dgap_driver.h", it not only can make
code clearer, but also can avoid compiling failure when EXTRA_CFLAGS
appended to make command line (e.g. "EXTRA_CFLAGS=-W").
commit 7c0411d2fabc2e2702c9871ffb603e251158b317 upstream.
We have that bug for years and some users report side effects when fixing it on older hardware.
So revert it for VM_CONTEXT0_PAGE_TABLE_END_ADDR, but keep it for VM 1-15.
Signed-off-by: Christian König <christian.koenig@amd.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 607d48063512707a414e346972e2210dc71ab491 upstream.
The mapping range is inclusive between starting and ending addresses.
commit b9a5e5e18fbf223502c0b2264c15024e393da928 upstream.
Since acpi_reserve_resources() is defined as a device_initcall(),
there's no guarantee that it will be executed in the right order
with respect to the rest of the ACPI initialization code. On some
systems this leads to breakage if, for example, the address range
that should be reserved for the ACPI fixed registers is given to
the PCI host bridge instead if the race is won by the wrong code
path.
Fix this by turning acpi_reserve_resources() into a void function
and calling it directly from within the ACPI initialization sequence.
Reported-and-tested-by: George McCollister <george.mccollister@gmail.com>
Link: http://marc.info/?t=143092384600002&r=1&w=2
commit 74856fbf441929918c49ff262ace9835048e4e6a upstream.
256 bytes per sector support has been broken since 2.6.X,
and no-one stepped up to fix this.
So disable support for it.
Signed-off-by: Mark Hounschell <dmarkh@cfl.rr.com>
Signed-off-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
commit 3c0213d17a09601e0c6c0ae0e27caf70d988290f upstream.
When the v3 hardware sees more than one finger, it uses the semi-mt
protocol to report the touches. However, it currently works when
num_fingers is 0, 1 or 2, but when it is 3 and above, it sends only 1
finger as if num_fingers was 1.
This confuses userspace which knows how to deal with extra fingers
when all the slots are used, but not when some are missing.
Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=90101
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 6e9eac2dcee5e19f125967dd2be3e36558c42fff upstream.
If any memory allocation in resize_stripes fails we will return
-ENOMEM, but in some cases we update conf->pool_size anyway.
This means that if we try again, the allocations will be assumed
to be larger than they are, and badness results.
So only update pool_size if there is no error.
This bug was introduced in 2.6.17 and the patch is suitable for
-stable.
Fixes: ad01c9e3752f ("[PATCH] md: Allow stripes to be expanded in preparation for expanding an array")
Signed-off-by: NeilBrown <neilb@suse.de>
Commit 178c2490b99f898efc06d1ad75cadc84f13021a6 ("thermal: step_wise:
cdev only needs update on a new target state") broke driver acerhdf.
That driver abused the step_wise thermal governor until the bang_bang
governor was available, and the optimization broke this usage model.
Kernels v3.12 to v3.18 are affected. In v3.19 the acerhdf driver was
switched to the bang_bang governor and that solved the problem.
For kernels v3.12 to v3.17, the bang_bang governor isn't available
yet so the easiest fix is to revert the optimization.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Reported-by: Dieter Jurzitza (https://bugzilla.opensuse.org/show_bug.cgi?id=925961)
Tested-by: Peter Feuerer <peter@piie.net>
Tested-by: Dieter Jurzitza
commit f230e8ffc03f17bd9d6b90ea890b8252a8cc1821 upstream.
This patch fixes an inverted return value of the gpio get_direction
function.
The wrong value causes the direction sysfs entry and GPIO debugfs file
to indicate incorrect GPIO direction settings. In some cases it also
prevents setting GPIO output values.
The problem is also present in all other stable kernel versions since
linux-3.12.
Reported-by: Jochen Henneberg <jh@henneberg-systemdesign.com>
Signed-off-by: Michael Brunner <michael.brunner@kontron.com>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
commit ea345c145ff23197eab34d0c4d0c8a93d7bea8c6 upstream.
Add the USB Id to link the D-Link DWA 130 USB Wifi adapter
to the rt2830 driver.
Signed-off-by: Scott Branden <sbranden@broadcom.com>
Signed-off-by: Pieter Truter <ptruter@broadcom.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
commit 09c5b4803a80a5451d950d6a539d2eb311dc0fb1 upstream.
When the LPM policy is set to ATA_LPM_MAX_POWER, the device might
generate a spurious PHY event that cuases errors on the link.
Ignore this event if it occured within 10s after the policy change.
The timeout was chosen observing that on a Dell XPS13 9333 these
spurious events can occur up to roughly 6s after the policy change.
Link: http://lkml.kernel.org/g/3352987.ugV1Ipy7Z5@xps13
Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com>
commit 8393b811f38acdf7fd8da2028708edad3e68ce1f upstream.
This is a preparation commit that will allow to add other criteria
according to which PHY events should be dropped.
commit 60c8f783a18feb95ad967c87e9660caf09fb4700 upstream.
clkdiv is declared as an u32 but it can be set to a negative value
causing a huge divisor value. Change its type to int to avoid this case.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 903124fe1aa284f61745a9dd4fbfa0184e569fff upstream.
memset() to 0 interfaces array before reusing
usb_configuration structure.
This commit fix bug:
ln -s functions/acm.1 configs/c.1
ln -s functions/acm.2 configs/c.1
ln -s functions/acm.3 configs/c.1
echo "UDC name" > UDC
echo "" > UDC
rm configs/c.1/acm.*
rmdir functions/*
mkdir functions/ecm.usb0
ln -s functions/ecm.usb0 configs/c.1
[ 82.220969] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 82.229009] pgd = c0004000
[ 82.231698] [00000000] *pgd=00000000
[ 82.235260] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
[ 82.240638] Modules linked in:
[ 82.243681] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.0.0-rc2 #39
[ 82.249926] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[ 82.256003] task: c07cd2f0 ti: c07c8000 task.ti: c07c8000
[ 82.261393] PC is at composite_setup+0xe3c/0x1674
[ 82.266073] LR is at composite_setup+0xf20/0x1674
[ 82.270760] pc : [<c03510d4>] lr : [<c03511b8>] psr: 600001d3
[ 82.270760] sp : c07c9df0 ip : c0806448 fp : ed8c9c9c
[ 82.282216] r10: 00000001 r9 : 00000000 r8 : edaae918
[ 82.287425] r7 : ed551cc0 r6 : 00007fff r5 : 00000000 r4 : ed799634
[ 82.293934] r3 : 00000003 r2 : 00010002 r1 : edaae918 r0 : 0000002e
[ 82.300446] Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
[ 82.307910] Control: 10c5387d Table: 6bc1804a DAC: 00000015
[ 82.313638] Process swapper/0 (pid: 0, stack limit = 0xc07c8210)
[ 82.319627] Stack: (0xc07c9df0 to 0xc07ca000)
[ 82.323969] 9de0: 00000000 c06e65f4 00000000 c07c9f68
[ 82.332130] 9e00: 00000067 c07c59ac 000003f7 edaae918 ed8c9c98 ed799690 eca2f140 200001d3
[ 82.340289] 9e20: ee79a2d8 c07c9e88 c07c5304 ffff55db 00010002 edaae810 edaae860 eda96d50
[ 82.348448] 9e40: 00000009 ee264510 00000007 c07ca444 edaae860 c0340890 c0827a40 ffff55e0
[ 82.356607] 9e60: c0827a40 eda96e40 ee264510 edaae810 00000000 edaae860 00000007 c07ca444
[ 82.364766] 9e80: edaae860 c0354170 c03407dc c033db4c edaae810 00000000 00000000 00000010
[ 82.372925] 9ea0: 00000032 c0341670 00000000 00000000 00000001 eda96e00 00000000 00000000
[ 82.381084] 9ec0: 00000000 00000032 c0803a23 ee1aa840 00000001 c005d54c 249e2450 00000000
[ 82.389244] 9ee0: 200001d3 ee1aa840 ee1aa8a0 ed84f4c0 00000000 c07c9f68 00000067 c07c59ac
[ 82.397403] 9f00: 00000000 c005d688 ee1aa840 ee1aa8a0 c07db4b4 c006009c 00000032 00000000
[ 82.405562] 9f20: 00000001 c005ce20 c07c59ac c005cf34 f002000c c07ca780 c07c9f68 00000057
[ 82.413722] 9f40: f0020000 413fc090 00000001 c00086b4 c000f804 60000053 ffffffff c07c9f9c
[ 82.421880] 9f60: c0803a20 c0011fc0 00000000 00000000 c07c9fb8 c001bee0 c07ca4f0 c057004c
[ 82.430040] 9f80: c07ca4fc c0803a20 c0803a20 413fc090 00000001 00000000 01000000 c07c9fb0
[ 82.438199] 9fa0: c000f800 c000f804 60000053 ffffffff 00000000 c0050e70 c0803bc0 c0783bd8
[ 82.446358] 9fc0: ffffffff ffffffff c0783664 00000000 00000000 c07b13e8 00000000 c0803e54
[ 82.454517] 9fe0: c07ca480 c07b13e4 c07ce40c 4000406a 00000000 40008074 00000000 00000000
[ 82.462689] [<c03510d4>] (composite_setup) from [<c0340890>] (s3c_hsotg_complete_setup+0xb4/0x418)
[ 82.471626] [<c0340890>] (s3c_hsotg_complete_setup) from [<c0354170>] (usb_gadget_giveback_request+0xc/0x10)
[ 82.481429] [<c0354170>] (usb_gadget_giveback_request) from [<c033db4c>] (s3c_hsotg_complete_request+0xcc/0x12c)
[ 82.491583] [<c033db4c>] (s3c_hsotg_complete_request) from [<c0341670>] (s3c_hsotg_irq+0x4fc/0x558)
[ 82.500614] [<c0341670>] (s3c_hsotg_irq) from [<c005d54c>] (handle_irq_event_percpu+0x50/0x150)
[ 82.509291] [<c005d54c>] (handle_irq_event_percpu) from [<c005d688>] (handle_irq_event+0x3c/0x5c)
[ 82.518145] [<c005d688>] (handle_irq_event) from [<c006009c>] (handle_fasteoi_irq+0xd4/0x18c)
[ 82.526650] [<c006009c>] (handle_fasteoi_irq) from [<c005ce20>] (generic_handle_irq+0x20/0x30)
[ 82.535242] [<c005ce20>] (generic_handle_irq) from [<c005cf34>] (__handle_domain_irq+0x6c/0xdc)
[ 82.543923] [<c005cf34>] (__handle_domain_irq) from [<c00086b4>] (gic_handle_irq+0x2c/0x6c)
[ 82.552256] [<c00086b4>] (gic_handle_irq) from [<c0011fc0>] (__irq_svc+0x40/0x74)
[ 82.559716] Exception stack(0xc07c9f68 to 0xc07c9fb0)
[ 82.564753] 9f60: 00000000 00000000 c07c9fb8 c001bee0 c07ca4f0 c057004c
[ 82.572913] 9f80: c07ca4fc c0803a20 c0803a20 413fc090 00000001 00000000 01000000 c07c9fb0
[ 82.581069] 9fa0: c000f800 c000f804 60000053 ffffffff
[ 82.586113] [<c0011fc0>] (__irq_svc) from [<c000f804>] (arch_cpu_idle+0x30/0x3c)
[ 82.593491] [<c000f804>] (arch_cpu_idle) from [<c0050e70>] (cpu_startup_entry+0x128/0x1a4)
[ 82.601740] [<c0050e70>] (cpu_startup_entry) from [<c0783bd8>] (start_kernel+0x350/0x3bc)
[ 82.609890] Code: 0a000002 e3530005 05975010 15975008 (e5953000)
[ 82.615965] ---[ end trace f57d5f599a5f1bfa ]---
Most of kernel code assume that interface array in
struct usb_configuration is NULL terminated.
When gadget is composed with configfs configuration
structure may be reused for different functions set.
This bug happens because purge_configs_funcs() sets
only next_interface_id to 0. Interface array still
contains pointers to already freed interfaces. If in
second try we add less interfaces than earlier we
may access unallocated memory when trying to get
interface descriptors.
Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 172115090f5e739660b97694618a2ba86457063a upstream.
Without this flag some versions of these enclosures do not work.
Reported-and-tested-by: Christian Schaller <cschalle@redhat.com>
commit c735ed74d83f8ecb45c4c4c95a16853c9c3c8157 upstream.
Added the USB serial console device ID for KCF Technologies PRN device
which has a USB port for its serial console.
Signed-off-by: Mark Edwards <sonofaforester@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 48ef23a4f686b1e4519d4193c20d26834ff810ff upstream.
This phone is already supported by the visor driver.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
commit 82ee3aeb9295c5fc37fd2ddf20f13ac2b40ec97d upstream.
Samsung has just released a portable USB3 SSD, coming in a very small
and nice form factor. It's USB ID is 04e8:8001, which unfortunately is
already used by the Palm Visor driver for the Samsung I330 phone cradle.
Having pl2303 or visor pick up this device ID results in conflicts with
the usb-storage driver, which handles the newly released portable USB3
SSD.
To work around this conflict, I've dug up a mailing list post [1] from a
long time ago, in which a user posts the full USB descriptor
information. The most specific value in this appears to be the interface
class, which has value 255 (0xff). Since usb-storage requires an
interface class of 0x8, I believe it's correct to disambiguate the two
devices by matching on 0xff inside visor.
[1] http://permalink.gmane.org/gmane.linux.usb.user/4264
commit 948fa13504f80b9765d2b753691ab94c83a10341 upstream.
If the xHCI host controller has died (ie, device removed) or suffered
other serious fatal error (STS_FATAL), then xhci_irq should handle this
condition with IRQ_HANDLED instead of -ESHUTDOWN.
Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 18cc2f4cbbaf825a4fedcf2d60fd388d291e0a38 upstream.
Our event ring consists of only one segment, and we risk filling
the event ring in case we get isoc transfers with short intervals
such as webcams that fill a TD every microframe (125us)
With 64 TRB segment size one usb camera could fill the event ring in 8ms.
A setup with several cameras and other devices can fill up the
event ring as it is shared between all devices.
This has occurred when uvcvideo queues 5 * 32TD URBs which then
get cancelled when the video mode changes. The cancelled URBs are returned
in the xhci interrupt context and blocks the interrupt handler from
handling the new events.
A full event ring will block xhci from scheduling traffic and affect all
devices conneted to the xhci, will see errors such as Missed Service
Intervals for isoc devices, and and Split transaction errors for LS/FS
interrupt devices.
Increasing the TRB_PER_SEGMENT will also increase the default endpoint ring
size, which is welcome as for most isoc transfer we had to dynamically
expand the endpoint ring anyway to be able to queue the 5 * 32TDs uvcvideo
queues.
The default size used to be 64 TRBs per segment
commit d104d0152a97fade389f47635b73a9ccc7295d0b upstream.
Isoc TDs usually consist of one TRB, sometimes two. When all goes well we
receive only one success event for a TD, and move the dequeue pointer to
the next TD.
This fails if the TD consists of two TRBs and we get a transfer error
on the first TRB, we will then see two events for that TD.
Fix this by making sure the event we get is for the last TRB in that TD
before moving the dequeue pointer to the next TD. This will resolve some
of the uvc and dvb issues with the
"ERROR Transfer event TRB DMA ptr not part of current TD" error message
commit 5a7125c64def3b21f8147eca8b54949a60963942 upstream.
See https://bugzilla.redhat.com/show_bug.cgi?id=1025672
We need to put() the reference to the scsi host that we got in
pscsi_configure_device(). In VIRTUAL_HOST mode it is associated with
the dev_virt, not the hba_virt.
Signed-off-by: Andy Grover <agrover@redhat.com>
commit 1b63bf617206ff35b93c57c67bbe067ac735a85a upstream.
The following error message is seen when loading the nct6775 driver
with DEBUG_LOCK_ALLOC enabled.
BUG: key ffff88040b2f0030 not in .data!
WARNING: CPU: 0 PID: 186 at kernel/locking/lockdep.c:2988
lockdep_init_map+0x469/0x630()
DEBUG_LOCKS_WARN_ON(1)
Caused by a missing call to sysfs_attr_init() when initializing
sysfs attributes.
Reported-by: Alexey Orishko <alexey.orishko@gmail.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
commit adba657533bdd255f7b78bc8a324091f46b294cd upstream.
When configured via device tree, the associated iio device needs to be
measuring voltage for the conversion to resistance to be correct.
Return -EINVAL if that is not the case.
Signed-off-by: Chris Lesiak <chris.lesiak@licor.com>
commit 77bb3dfdc0d554befad58fdefbc41be5bc3ed38a upstream.
A non-percpu VIRQ (e.g., VIRQ_CONSOLE) may be freed on a different
VCPU than it is bound to. This can result in a race between
handle_percpu_irq() and removing the action in __free_irq() because
handle_percpu_irq() does not take desc->lock. The interrupt handler
sees a NULL action and oopses.
Only use the percpu chip/handler for per-CPU VIRQs (like VIRQ_TIMER).
# cat /proc/interrupts | grep virq
40: 87246 0 xen-percpu-virq timer0
44: 0 0 xen-percpu-virq debug0
47: 0 20995 xen-percpu-virq timer1
51: 0 0 xen-percpu-virq debug1
69: 0 0 xen-dyn-virq xen-pcpu
74: 0 0 xen-dyn-virq mce
75: 29 0 xen-dyn-virq hvc_console
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 83a35114d0e4583e6b0ca39502e68b6a92e2910c upstream.
This bug has been there since day 1; addresses in the top guest physical
page weren't considered valid. You could map that page (the check in
check_gpte() is correct), but if a guest tried to put a pagetable there
we'd check that address manually when walking it, and kill the guest.
commit 414b7e3b9ce8b0577f613e656fdbc36b34b444dd upstream.
The USB mini-driver in rtlwifi, which is used by rtl8192cu, issues a call to
usb_control_msg() with a timeout value of 0. In some instances where the
interface is shutting down, this infinite wait results in a CPU deadlock. A
one second timeout fixes this problem without affecting any normal operations.
This bug is reported at https://bugzilla.novell.com/show_bug.cgi?id=927786.
Reported-by: Bernhard Wiedemann <bwiedemann@suse.com>
Tested-by: Bernhard Wiedemann <bwiedemann@suse.com>
Cc: Stable <stable@vger.kernel.org>
Cc: Bernhard Wiedemann <bwiedemann@suse.com>
Cc: Takashi Iwai<tiwai@suse.com>
commit 59c816c1f24df0204e01851431d3bab3eb76719c upstream.
This code in vhost_scsi_make_tpg() is confusing because we limit "tpgt"
to UINT_MAX but the data type of "tpg->tport_tpgt" and that is a u16.
I looked at the context and it turns out that in
vhost_scsi_set_endpoint(), "tpg->tport_tpgt" is used as an offset into
the vs_tpg[] array which has VHOST_SCSI_MAX_TARGET (256) elements so
anything higher than 255 then it is invalid. I have made that the limit
now.
In vhost_scsi_send_evt() we mask away values higher than 255, but now
that the limit has changed, we don't need the mask.
commit dc45708ca9988656d706940df5fd102672c5de92 upstream.
Set the SRB flags correctly when there is no data transfer. Without this
change some IHV drivers will fail valid commands such as TEST_UNIT_READY.
Cc: <stable@vger.kernel.org>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Reviewed-by: Long Li <longli@microsoft.com>
commit f89ce2706d8341c921b96e13a00b951a10eed308 upstream.
This patch adds temperature monitoring support for F15h M60h processor.
- Add new pci device id for the relevant processor
- The functionality of REG_REPORTED_TEMPERATURE is moved to
D0F0xBC_xD820_0CA4 [Reported Temperature Control]
- So, use this to get CUR_TEMP value
- Since we need an indirect register access, protect this with
a mutex lock
- Add Kconfig, Doc entries to indicate support for this processor.
Signed-off-by: Aravind Gopalakrishnan <aravind.gopalakrishnan@amd.com>
Acked-by: Borislav Petkov <bp@suse.de>
Acked-by: Clemens Ladisch <clemens@ladisch.de>
[Guenter Roeck: Declare new mutex and function static]
commit ec0159503ae74aeb834e78366bdf4b9663ca1129 upstream.
Adding new PCI ID to support AMD F16 M30h processor (Mullins).
While at it, modify Kconfig and Doc files to reflect the
support for newer processors
Note: PCI ID for this processor will make it into pci_ids.h
as part of this patch:
http://marc.info/?l=linux-kernel&m=139291362126057&w=2
which should be pulled into 3.15 when merge window opens
(It currently sits in 'for-next' branch of bp.git-
https://git.kernel.org/cgit/linux/kernel/git/bp/bp.git/log/?h=for-next)
Signed-off-by: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com>
commit 85a8885bd0e00569108aa7b5e26b89c752e3cd51 upstream.
Extend ECC decoding support for F16h M30h. Tested on F16h M30h with ECC
turned on using mce_amd_inj module and the patch works fine.
Link: http://lkml.kernel.org/r/1392913726-16961-1-git-send-email-Aravind.Gopalakrishnan@amd.com
Tested-by: Arindam Nath <Arindam.Nath@amd.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
commit 9493c2422cae272d6f1f567cbb424195defe4176 upstream.
Remove 2 redundant extern inline functions: qla8044_set_qsnt_ready() and
qla8044_need_reset_handler(). At present, within upstream next kernel
source code, they are only used within "drivers/scsi/qla2xxx/qla_nx2.c".
The related error and warnings (with allmodconfig under tile):
CC [M] drivers/scsi/qla2xxx/qla_nx2.o
drivers/scsi/qla2xxx/qla_nx2.c:1633:1: error: static declaration of 'qla8044_need_reset_handler' follows non-static declaration
qla8044_need_reset_handler(struct scsi_qla_host *vha)
In file included from drivers/scsi/qla2xxx/qla_def.h:3706:0,
from drivers/scsi/qla2xxx/qla_nx2.c:11:
drivers/scsi/qla2xxx/qla_gbl.h:756:20: note: previous declaration of 'qla8044_need_reset_handler' was here
extern inline void qla8044_need_reset_handler(struct scsi_qla_host *vha);
drivers/scsi/qla2xxx/qla_gbl.h:756:20: warning: inline function 'qla8044_need_reset_handler' declared but never defined
make[3]: *** [drivers/scsi/qla2xxx/qla_nx2.o] Error 1
make[2]: *** [drivers/scsi/qla2xxx] Error 2
make[1]: *** [drivers/scsi] Error 2
make: *** [drivers] Error 2
CC [M] drivers/scsi/qla2xxx/qla_tmpl.o
from drivers/scsi/qla2xxx/qla_tmpl.c:7:
drivers/scsi/qla2xxx/qla_gbl.h:755:20: warning: inline function 'qla8044_set_qsnt_ready' declared but never defined
extern inline void qla8044_set_qsnt_ready(struct scsi_qla_host *vha);
Signed-off-by: Chen Gang <gang.chen.5i5j@gmail.com>
Acked-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
commit 62ec95f86d2850b7ce6d73fb236a6fcf48411aea upstream.
rtllib_probe_req is defined as "static inline" in rtllib_softmac.c however it
is declared differently as "extern inline" in rtllib_softmac.h. Since it isn't
used outside of the scope of rtllib_softmac, it makes sense to remove the
incorrect declaration.
Signed-off-by: Behan Webster <behanw@converseincode.com>
Suggested-by: Arnd Bergmann <arnd@arndb.de>
commit 0c9f3a65c5eb7fe1fc611a22eb8a8b71ea865998 upstream.
The rtl8712 driver has an 'extern inline' function that contains an
'if', which causes lots of warnings with CONFIG_PROFILE_ALL_BRANCHES
overriding the definition of 'if':
drivers/staging/rtl8712/ieee80211.h:759:229: warning: '______f' is static but declared in inline function 'ieee80211_get_hdrlen' which is not static [enabled by default]
This changes the driver to use 'static inline' instead, which happens
to be the correct annotation anyway.
Cc: Florian Schilhabel <florian.c.schilhabel@googlemail.com>
commit 6d91857d4826b382b3fd4fad95f52713be646f96 upstream.
With compilers which follow the C99 standard (like modern versions of gcc and
clang), "extern inline" does the opposite thing from older versions of gcc
(emits code for an externally linkable version of the inline function).
"static inline" does the intended behavior in all cases instead.
Patch not upstream as this driver is deleted there.
Fix up some "extern inline" functions as they break the build when using
a "modern" complier (i.e. gcc5).
