path: root/drivers
2007-12-10atmel_spi: reload RCR before TCRRini van Zetten
We have a wifi module connected to the spi bus and got sometimes FIFO overrun errors on the spi bus. After some investigation i found that the driver loads the TCR (transmit count) register before the RCR (receive count). When the transfer list is not empty the atmel_spi_next_message is called while tx and rx are enabled. As soon as the TCR is loaded, hardware starts transfer and causes a rx fifo overrun because the RCR is not loaded yet. Load the RCR before the TCR. After this patch the fifo overrun disapears at out setup. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Rini van Zetten <rini@arvoo.nl> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10esp_scsi: fix reset cleanup spinlock recursionMaciej W. Rozycki
The esp_reset_cleanup() function is called with the host lock held and invokes starget_for_each_device() which wants to take it too. Here is a fix along the lines of shost_for_each_device()/__shost_for_each_device() adding a __starget_for_each_device() counterpart which assumes the lock has already been taken. Eventually, I think the driver should get modified so that more work is done as a softirq rather than in the interrupt context, but for now it fixes a bug that causes the spinlock debugger to fire. While at it, it fixes a small number of cosmetic problems with starget_for_each_device() too. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10Fix NULL dereference in umem.cNeil Brown
Fix NULL dereference in umem.c Signed-off-by: Neil Brown <neilb@suse.de> Tested-by: Dave Chinner <dgc@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10drivers/serial/uartlite.c: Add missing of_node_putJulia Lawall
There should be an of_node_put when breaking out of a loop that iterates using for_each_compatible_node. This was detected and fixed using the following semantic patch. (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ identifier d; type T; expression e; iterator for_each_compatible_node; @@ T *d; ... for_each_compatible_node(d,...) {... when != of_node_put(d) when != e = d ( return d; | + of_node_put(d); ? return ...; ) ...} // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10spi_imx: fix typo in descriptionWill Newton
Signed-off-by: Will Newton <will.newton@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10spi_bfin5xx: fix typo in descriptionWill Newton
2007-12-10pxa2xx_spi: fix typo in descriptionWill Newton
2007-12-10pcmcia: fix kernel-doc commentsRandy Dunlap
Fix kernel-doc comments in drivers/pcmcia/: - ti113x.h does not contain kernel-doc, so don't use /** to begin a doc comment - yenta_socket.c: remove /** on non-kernel-doc comments; escape the ':' in an "http:" comment so that it won't be treated as a section heading; - cs.c: remove /** on non-kernel-doc comments & add function parameter info - ds.c: fix function parameter info Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10revert "dpt_i2o: convert to SCSI hotplug model"Andrew Morton
revert commit 55d9fcf57ba5ec427544fca7abc335cf3da78160 Author: Matthew Wilcox <matthew@wil.cx> Date: Mon Jul 30 15:19:18 2007 -0600 [SCSI] dpt_i2o: convert to SCSI hotplug model - Delete refereces to HOSTS_C - Switch to module_init/module_exit instead of detect/release - Don't pass around the host template and rename it to adpt_template - Switch from scsi_register/scsi_unregister to scsi_host_alloc, scsi_add_host, scsi_scan_host and scsi_host_put. Because it caused (for unknown reasons) Andres' all-data-reads-as-zeroes problem, reported at http://groups.google.com/group/fa.linux.kernel/msg/083a9acff0330234 Cc: Matthew Wilcox <matthew@wil.cx> Cc: "Salyzyn, Mark" <mark_salyzyn@adaptec.com> Cc: James Bottomley <James.Bottomley@SteelEye.com> Acked-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Anders Henke <anders.henke@1und1.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10aoe: properly initialise the request_queue's backing_dev_infoAndrew Morton
AOE forgot to initialise its queue's backing_dev_info, so kernels crash. (http://bugzilla.kernel.org/show_bug.cgi?id=9482) Fix that and consoldate aoeblk_gdalloc()'s error handling. Thanks be to Jon for reporting and testing. Cc: "Ed L. Cashin" <ecashin@coraid.com> Cc: <stable@kernel.org> Cc: "Jon Nelson" <jnelson@jamponi.net> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-10firewire: OHCI 1.0 Isochronous Receive supportJarod Wilson
Third rendition of FireWire OHCI 1.0 Isochronous Receive support, using a zer-copy method similar to OHCI 1.1 which puts the IR data payload directly into the userspace buffer. The zero-copy implementation eliminates the video artifacts, audio popping, and buffer underrun problems seen with version 1 of this patch, as well as fixing a regression in OHCI 1.1 support introduced by version 2 of this patch. Successfully tested in OHCI 1.1 mode on the following chipsets: - NEC uPD72847 (rev 01), OHCI 1.1 (PCI) - Ti XIO2200(A) (rev 01), OHCI 1.1 (PCIe) - Ti TSB41AB2 (rev 01), OHCI 1.1 (PCI on SB Audigy) - Apple UniNorth 2 (rev 81), OHCI 1.1 (PowerBook G4 onboard) Successfully tested in OHCI 1.0 mode on the following chipsets: - Agere FW323 (rev 06), OHCI 1.0 (Mac Mini onboard) - Agere FW323 (rev 06), OHCI 1.0 (PCI) - Via VT6306 (rev 46), OHCI 1.0 (PCI) - NEC OrangeLink (rev 01), OHCI 1.0 (PCI) - NEC uPD72847 (rev 01), OHCI 1.1 (PCI) - Ti XIO2200(A) (rev 01), OHCI 1.1 (PCIe) The bulk of testing was done in an x86_64 system, but was also successfully sanity-tested on other systems, including a PPC(32) PowerBook G4 and an i686 EPIA M10k. Crude benchmarking (watching top during capture) puts the cpu utilization during capture on the EPIA's 1GHz Via C3 processor around 13%, which is down from 30% with the v1 code. Some implementation details: To maintain the same userspace API as dual-buffer mode, we set up two descriptors for every incoming packet. The first is an INPUT_MORE descriptor, pointing to a buffer large enough to hold just the packet's iso headers, immediately followed by an INPUT_LAST descriptor, pointing to a chunk of the userspace buffer big enough for the packet's data payload. With this setup, each incoming packet fills in these two descriptors in a manner that very closely emulates dual-buffer receive, to the point where the bulk of the handle_ir_* code is now identical between the two (and probably primed for some restructuring to share code between them). The only caveat I have at the moment is that neither of my OHCI 1.0 Via VT6307-based FireWire controllers work particularly well with this code for reasons I have yet to figure out. Signed-off-by: Jarod Wilson <jwilson@redhat.com> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2007-12-10Revert "PCI: fix IDE legacy mode resources"Linus Torvalds
This reverts commit fd6e732186ab522c812ab19c2c5e5befb8ec8115, which helped up things on MIPS, but was wrong for everything else. As Ralf Baechle puts it: "It seems the whole MIPS resource managment is complicated enough (out of necessity) that only a few people actually grok it. Ioports being actually memory mapped on MIPS only makes the confusion worse, sigh." Requested-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-07Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: libata: kill spurious NCQ completion detection ahci: don't attach if ICH6 is in combined mode ata_piix: add Toshiba Tecra M4 to broken suspend list ahci: fix engine reset failed message
2007-12-07libata: kill spurious NCQ completion detectionTejun Heo
Spurious NCQ completion detection implemented in ahci was incorrect. On AHCI receving and processing FISes and raising interrupts are not interlocked and spurious interrupts are expected. For example, if an interrupt occurs while interrupt handler is running and the running interrupt handler handles the event the new IRQ indicated, after IRQ handler finishes, it will be executed again because IRQ pending bit is set by the new interrupt but there won't be anything to process. Please read the following message for more information. http://article.gmane.org/gmane.linux.ide/26012 This patch... * Removes all spurious IRQ whining from ahci. Spurious NCQ completion detection was completely wrong. Spurious D2H Register FIS taught us that some early drives send spurious D2H Register FIS with I bit set while NCQ commands are in progress but none of recent drives does that and even the ones which show such behavior can do NCQ fine. * Kills all NCQ blacklist entries which were added because of spurious NCQ completions. I tracked down each commit and verified all removed ones are actually added because of spurious completions. WD740ADFD-00NLR1 wasn't deleted but moved upward because the drive not only had spurious NCQ completions but also is slow on sequential data transfers if NCQ is enabled. Maxtor 7V300F0 was added by 0e3dbc01d53940fe10e5a5cfec15ede3e929c918 from Alan Cox. I can only find evidences that the drive only had troubles with spuruious completions by searching the mailing list. This entry needs to be verified and removed if it doesn't have other NCQ related problems. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ahci: don't attach if ICH6 is in combined modeTejun Heo
ICH6 R/Ms share PCI ID between piix and ahci modes and we've been allowing ahci to attach regardless of how BIOS configured it. However, enabling AHCI mode when the controller is in combined mode can result in unexpected behavior. Don't attach if the controller is in combined mode. Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Bill Nottingham <notting@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ata_piix: add Toshiba Tecra M4 to broken suspend listPeter Schwenke
Add Toshiba Tecra M4 to broken suspend list. This is from OSDL bugzilla bug 7780. Signed-off-by: Peter Schwenke <peter@bluetoad.com.au> Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ahci: fix engine reset failed messageTejun Heo
There isn't much point in reporting -EOPNOTSUPP as failure. Also the message was missing newline. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07S2io: Check for register initialization completion before accesing device ↵Sreenivasa Honnur
registers - Making sure register initialisation is complete before proceeding further. The driver must wait until initialization is complete before attempting to access any other device registers. Signed-off-by: Surjit Reang <surjit.reang@neterion.com> Signed-off-by: Sreenivasa Honnur <sreenivasa.honnur@neterion.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Update file headers copyright noticesBenjamin Herrenschmidt
This updates the copyright notices of the new EMAC driver to avoid confusion as who is to be blamed for new bugs. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Call dev_set_drvdata() before tah_reset()Valentine Barshak
The patch moves dev_set_drvdata(&ofdev->dev, dev) up before tah_reset(ofdev) is called to avoid a NULL pointer dereference, since tah_reset uses drvdata. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Fix typo reading TAH channel infoValentine Barshak
This patch fixes a typo in ibm_newemac/core.c (tah_port should be used instead of tah_ph) Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Correct opb_bus_freq valueValentine Barshak
The EMAC4_MR1_OBCI(freq) macro expects freg in MHz, while opb_bus_freq is kept in Hz. Correct this. Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Skip EMACs that are marked unused by the firmwareHugh Blemings
Depending on how the 44x processors are wired, some EMAC cells might not be useable (and not connected to a PHY). However, some device-trees may choose to still expose them (since their registers are present in the MMIO space) but with an "unused" property in them. Signed-off-by: Hugh Blemings <hugh@blemings.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Cleanup/fix support for STACR register variantsBenjamin Herrenschmidt
There are a few variants of the STACR register that affect more than just the "AXON" version of EMAC. Replace the current test of various chip models with tests for generic properties in the device-tree. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Cleanup/Fix RGMII MDIO support detectionBenjamin Herrenschmidt
More than just "AXON" version of EMAC RGMII supports MDIO, so replace the current test with a generic property in the device-tree that indicates such support. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Workaround reset timeout when no linkBenjamin Herrenschmidt
With some PHYs, when the link goes away, the EMAC reset fails due to the loss of the RX clock I believe. The old EMAC driver worked around that using some internal chip-specific clock force bits that are different on various 44x implementations. This is an attempt at doing it differently, by avoiding the reset when there is no link, but forcing loopback mode instead. It seems to work on my Taishan 440GX based board so far. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Fix ZMII refcounting bugBenjamin Herrenschmidt
When using ZMII for MDIO only (such as 440GX with RGMII for data and ZMII for MDIO), the ZMII code would fail to properly refcount, thus triggering a BUG_ON(). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Add ET1011c PHY supportStefan Roese
This adds support for the Agere ET1011c PHY as found on the AMCC Taishan board. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07ibm_newemac: Add BCM5248 and Marvell 88E1111 PHY supportStefan Roese
This patch adds BCM5248 and Marvell 88E1111 PHY support to NEW EMAC driver. These PHY chips are used on PowerPC 440EPx boards. The PHY code is based on the previous work by Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Valentine Barshak <vbarshak@ru.mvista.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07e100: cleanup unneeded mathAuke Kok
No need to convert to bytes and back - cleanup unneeded code. Adapted from fix from 'Roel Kluin <12o3l@tiscali.nl>' Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07e1000: fix memcpy in e1000_get_stringsRoel Kluin
drivers/net/e1000/e1000_ethtool.c:113: #define E1000_TEST_LEN sizeof(e1000_gstrings_test) / ETH_GSTRING_LEN drivers/net/e1000e/ethtool.c:106: #define E1000_TEST_LEN sizeof(e1000_gstrings_test) / ETH_GSTRING_LEN E1000_TEST_LEN*ETH_GSTRING_LEN will expand to sizeof(e1000_gstrings_test) / (ETH_GSTRING_LEN * ETH_GSTRING_LEN) A lack of parentheses around defines causes unexpected results due to operator precedences. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07make bnx2x select ZLIB_INFLATEEliezer Tamir
The bnx2x module depends on the zlib_inflate functions. The build will fail if ZLIB_INFLATE has not been selected manually or by building another module that automatically selects it. Modify BNX2X config option to 'select ZLIB_INFLATE' like BNX2 and others. This seems to fix it. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07cxgb3 - T3C support updateDivy Le Ray
Update GPIO mapping for T3C. Update xgmac for T3C support. Fix typo in mtu table. Signed-off-by: Divy Le Ray <divy@chelsio.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07bonding: Fix race at module unloadJay Vosburgh
Fixes a race condition in module unload. Without this change, workqueue events may fire while bonding data structures are partially freed but before bond_close() is invoked by unregister_netdevice(). Update version to 3.2.3. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07bonding: Add new layer2+3 hash for xor/802.3ad modesJay Vosburgh
Add new hash for balance-xor and 802.3ad modes. Originally submitted by "Glenn Griffin" <ggriffin.kernel@gmail.com>; modified by Jay Vosburgh to move setting of hash policy out of line, tweak the documentation update and add version update to 3.2.2. Glenn's original comment follows: Included is a patch for a new xmit_hash_policy for the bonding driver that selects slaves based on MAC and IP information. This is a middle ground between what currently exists in the layer2 only policy and the layer3+4 policy. This policy strives to be fully 802.3ad compliant by transmitting every packet of any particular flow over the same link. As documented the layer3+4 policy is not fully compliant for extreme cases such as ip fragmentation, so this policy is a nice compromise for environments that require full compliance but desire more than the layer2 only policy. Signed-off-by: "Glenn Griffin" <ggriffin.kernel@gmail.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07bonding: Fix time comparisonDavid Sterba
From: David Sterba <dsterba@suse.cz> Use macros for comparing jiffies. Jiffies' wrap caused missed events and hangs. Module reinsert was needed to make bonding work again. Signed-off-by: David Sterba <dsterba@suse.cz> Acked-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07bonding: Allow setting and querying xmit policy regardless of modeWagner Ferenc
From: Wagner Ferenc <wferi@niif.hu> For consistency with the behaviour of the arp_ip_target option, let /sys/class/net/bond0/bonding/xmit_hash_policy accept and report current policy even if the bonding mode in effect does not use it. Signed-off-by: Ferenc Wagner <wferi@niif.hu> Acked-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07bonding: Coding style: break line after the if conditionWagner Ferenc
From: Wagner Ferenc <wferi@niif.hu> Adhere to coding style: break line after the if condition Signed-off-by: Ferenc Wagner <wferi@niif.hu> Acked-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07bonding: Purely cosmetic: rename a local variableWagner Ferenc
From: Wagner Ferenc <wferi@niif.hu> Code for rendering multivalue sysfs files occurs three times in this module. Rename 'buffer' to 'buf' in the first, for the sake of consistency. Signed-off-by: Ferenc Wagner <wferi@niif.hu> Acked-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07bonding: Return nothing for not applicable valuesWagner Ferenc
From: Wagner Ferenc <wferi@niif.hu> The previous code returned '\n' (that is, a single empty line) from most files, with one exception (xmit_hash_policy), where it returned 'NA\n'. This patch consolidates each file to return nothing at all if not applicable, not even a '\n'. I find this behaviour more usual, more useful, more efficient and shorter to code from both sides. Signed-off-by: Ferenc Wagner <wferi@niif.hu> Acked-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07bonding: Remove trailing NULs from sysfs interface.Wagner Ferenc
From: Wagner Ferenc <wferi@niif.hu> Also remove trailing spaces from multivalued files. This fixes output like for example: $ od -c /sys/class/net/bond0/bonding/slaves 0000000 e t h - l e f t e t h - r i g 0000020 h t \n \0 0000025 It mostly entails deleting '+1'-s after sprintf() calls: the return value of sprintf is the number of characters printed, without the closing NUL, ie. exactly what the sysfs interface requires. The three multivalue cases are different, because they also have to swallow back a trailing space. Signed-off-by: Ferenc Wagner <wferi@niif.hu> Acked-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-12-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-x86: ACPI: move timer broadcast before busmaster disable clockevents: warn once when program_event() is called with negative expiry hrtimers: avoid overflow for large relative timeouts
2007-12-07Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [AF_RXRPC]: Add a missing goto [VLAN]: Lost rtnl_unlock() in vlan_ioctl() [SCTP]: Fix the bind_addr info during migration. [SCTP]: Add bind hash locking to the migrate code [IPV4]: Remove prototype of ip_rt_advice [IPv4]: Reply net unreachable ICMP message [IPv6] SNMP: Increment OutNoRoutes when connecting to unreachable network [BRIDGE]: Section fix. [NIU]: Fix link LED handling.
2007-12-07ACPI: move timer broadcast before busmaster disableThomas Gleixner
The timer broadcast code might access HPET, which should not be accessed after the busmaster disable. In acpi_idle_enter_simple() this change also prevents, that we modify the busmaster state without going actually idle. This might leave the ACPI bm state in a stale state, when we leave the function early in the need_resched() check. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
2007-12-07leds: Fix led trigger locking bugsRichard Purdie
Convert part of the led trigger core from rw spinlocks to rw semaphores. We're calling functions which can sleep from invalid contexts otherwise. Fixes bug #9264. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-12-07[NIU]: Fix link LED handling.Mirko Lindner
The LED in the current driver will not be controlled correctly. During a link change the carrier of the link is not available and the LED will never turn on. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-06Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI: suspend: old debugging hacks sneaked back Freezer: Fix JFFS2 garbage collector freezing issue (rev. 2) HWMON: coretemp, suspend fix Freezer: Fix APM emulation breakage Freezer: Fix s2disk resume from initrd
2007-12-06Pull apm-freeze-fix into release branchLen Brown
2007-12-06Pull suspend-2.6.24 into release branchLen Brown
2007-12-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: [PARISC] lba_pci: pci_claim_resources disabled expansion roms [PARISC] print more than one character at a time for pdc console [PARISC] Update parisc-linux MAINTAINERS entries [PARISC] timer interrupt should not be IRQ_DISABLED Revert "[PARISC] import necessary bits of libgcc.a"
