commit e555190d82c0f58e825e3cbd9e6ebe2e7ac713bd upstream.
When a raid1 array is configured to support write-behind
on some devices, it normally only reads from other devices.
If all devices are write-behind (because the rest have failed)
it is possible for a read request to be serviced before a
behind-write request, which would appear as data corruption.
So when forced to read from a WriteMostly device, wait for any
write-behind to complete, and don't start any more behind-writes.
Signed-off-by: NeilBrown <neilb@suse.de>
commit daa142d1773dd3a986f02a8a4da929608d24daaa upstream.
If a command times out resulting in EH getting invoked, we wait for the
aborted commands to come back after sending the abort. Shorten
the amount of time we wait for these responses, to ensure we don't
get stuck in EH for several minutes.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit f5832fa2f8dc39adcf3ae348d2d6383163235e79 upstream.
Commands which are completed by the VIOS are placed on a CRQ
in kernel memory for the ibmvfc driver to process. Each CRQ
entry is 16 bytes. The ibmvfc driver reads the first 8 bytes
to check if the entry is valid, then reads the next 8 bytes to get
the handle, which is a pointer the completed command. This fixes
an issue seen on Power 7 where the processor reordered the
loads from memory, resulting in processing command completion
with a stale handle. This could result in command timeouts,
and also early completion of commands.
commit 534ef056db8a8fb6b9d50188d88ed5d1fbc66673 upstream.
When removing several devices aic79xx will occasionally Oops
in ahd_handle_nonpkt_busfree during rescan. Looking at the
code I found that we're indeed not checking if the scb in
question is NULL. So check for it before accessing it.
Signed-off-by: Hannes Reinecke <hare@suse.de>
commit 02246c41171097ceab3246f6dc251ac89de6004b upstream.
Update mtime when writing to backing filesystem using the address space
operations write_begin and write_end.
Signed-off-by: Nikanth Karthikesan <knikanth@suse.de>
commit 455c0d71d46e86b0b7ff2c9dcfc19bc162302ee9 upstream.
Earlier, Ingo Molnar posted a patch to make it so that the kernel would avoid
reading _PPC on his broken T60. Unfortunately, it seems that with Thomas
Renninger's patch last July to eliminate _PPC evaluations when the processor
driver loads, the kernel never actually reads _PPC at all! This is problematic
if you happen to boot your non-T60 computer in a state where the BIOS _wants_
_PPC to be something other than zero.
So, put the _PPC evaluation back into acpi_processor_get_performance_info if
ignore_ppc isn't 1.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Acked-by: Jeff Mahoney <jeffm@suse.com>
commit 3c5d92a0cfb5103c0d5ab74d4ae6373d3af38148 upstream.
Allow the architecture to request a normal jiffy tick when the system
goes idle and tick_nohz_stop_sched_tick is called . On s390 the hook is
used to prevent the system going fully idle if there has been an
interrupt other than a clock comparator interrupt since the last wakeup.
On s390 the HiperSockets response time for 1 connection ping-pong goes
down from 42 to 34 microseconds. The CPU cost decreases by 27%.
LKML-Reference: <20090929122533.402715150@de.ibm.com>
Acked-by: John Jolly <jjolly@suse.de>
commit f458823b864c6def488f951a79986fa205aba4f1 upstream.
Presence detection of a digital monitor seems not to be reliable using
the HTPLG bit.
Dave Müller <dave.mueller@gmx.ch>
commit 4877c737283813bdb4bebfa3168c1585f6e3a8ca upstream.
In general the semantics of IPIs are that they are are expected to
continue functioning after dpm_suspend_noirq().
Specifically I have seen a deadlock between the callfunc IPI and the
stop machine used by xen's do_suspend() routine. If one CPU has already
called dpm_suspend_noirq() then there is a window where it can be sent
a callfunc IPI before all the other CPUs have entered stop_cpu().
If this happens then the first CPU ends up spinning in stop_cpu()
waiting for the other to rendezvous in state STOPMACHINE_PREPARE while
the other is spinning in csd_lock_wait().
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: xen-devel@lists.xensource.com
LKML-Reference: <1280398595-29708-4-git-send-email-ian.campbell@citrix.com>
commit 592970675c9522bde588b945388c7995c8b51328 upstream.
Use newly introduced netif_notify_peers() method to ensure a gratuitous ARP is
generated after a migration.
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: netdev@vger.kernel.org
commit 0a79f67445de50ca0a8dc1d34f3cc406d89c28b2 upstream.
Device class is ff(vend.) instead of e0(wlcon).
Output from command `usb-devices`:
T: Bus=01 Lev=03 Prnt=03 Port=00 Cnt=01 Dev#= 6 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=05ac ProdID=8215 Rev=01.82
S: Manufacturer=Apple Inc.
S: Product=Bluetooth USB Host Controller
S: SerialNumber=7C6D62936607
C: #Ifs= 4 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 3 Alt= 0 #EPs= 0 Cls=fe(app. ) Sub=01 Prot=00 Driver=(none)
Signed-off-by: Cyril Lacoux <clacoux@ifeelgood.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit a4967de6cbb260ad0f6612a1d2035e119ef1578f upstream.
We're adjusting horizontal timings only here, moving vsync was just a
slavish translation of a typo in the X server.
Signed-off-by: Adam Jackson <ajax@redhat.com>
commit b3e670443b7fb8a2d29831b62b44a039c283e351 upstream.
This patch fixes a race condition in two utility routines
related to the removal/unlinking of urbs from an anchor.
If two threads are concurrently accessing the same anchor,
both could end up with the same urb - thinking they are
the exclusive owner.
Alan Stern pointed out a related issue in
usb_unlink_anchored_urbs:
"The URB isn't removed from the anchor until it completes
(as a by-product of completion, in fact), which might not
be for quite some time after the unlink call returns.
In the meantime, the subroutine will keep trying to unlink
it, over and over again."
Cc: Oliver Neukum <oneukum@suse.de>
Cc: Greg Kroah-Hartman <greg@kroah.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit e10e1bec8e6654de4591ef45ddd6a6d1e5b2591c upstream.
This patch fixes the warning below:
[30753.755998] ------------[ cut here ]------------
[30753.755998] WARNING: at /home/tom/git/linux-2.6/linux-2.6-next/arch/x86/include/asm/dma-mapping.h:155 hcd_buffer_free+0xb1/0xd4 [usbcore]()
[30753.755998] Hardware name: 6475EK2
[30753.755998] Modules linked in: uvcvideo ehci_hcd usbtest cdc_ether usbnet vfat fat usb_storage nfsd lockd nfs_acl auth_rpcgss exportfs mii tun videodev v4l1_compat v4l2_compat_ioctl32 fuse bridge stp llc sunrpc ipv6 cpufreq_ondemand acpi_cpufreq freq_table mperf kvm_intel kvm arc4 ecb ath5k usbhid mac80211 snd_hda_codec_conexant ch341 usbserial ath cfg80211 thinkpad_acpi snd_hda_intel pcspkr wmi hwmon yenta_socket iTCO_wdt iTCO_vendor_support i2c_i801 e1000e snd_hda_codec snd_hwdep snd_pcm snd_timer snd soundcore snd_page_alloc pata_acpi uhci_hcd ohci_hcd usbcore i915 drm_kms_helper drm i2c_algo_bit i2c_core video output [last unloaded: uvcvideo]
[30753.755998] Pid: 0, comm: swapper Tainted: G W 2.6.35-rc6-gkh-wl+ #49
[30753.755998] Call Trace:
[30753.755998] <IRQ> [<ffffffff8104478a>] warn_slowpath_common+0x80/0x98
[30753.755998] [<ffffffff810447b7>] warn_slowpath_null+0x15/0x17
[30753.755998] [<ffffffffa00ce02d>] hcd_buffer_free+0xb1/0xd4 [usbcore]
[30753.755998] [<ffffffffa00c1345>] usb_free_coherent+0x1c/0x1e [usbcore]
[30753.755998] [<ffffffffa00b13e4>] simple_free_urb+0x23/0x2f [usbtest]
[30753.755998] [<ffffffffa00b210b>] iso_callback+0xbb/0x10f [usbtest]
[30753.755998] [<ffffffffa00c7390>] usb_hcd_giveback_urb+0x8c/0xc0 [usbcore]
[30753.755998] [<ffffffffa0449b35>] ehci_urb_done+0x84/0x95 [ehci_hcd]
[30753.755998] [<ffffffffa044b5a5>] ehci_work+0x41a/0x7dd [ehci_hcd]
[30753.755998] [<ffffffffa044e298>] ehci_irq+0x33b/0x370 [ehci_hcd]
[30753.755998] [<ffffffff8100fb05>] ? sched_clock+0x9/0xd
[30753.755998] [<ffffffff8105e641>] ? sched_clock_local+0x1c/0x82
[30753.755998] [<ffffffff8105e76a>] ? sched_clock_cpu+0xc3/0xce
[30753.755998] [<ffffffff81067c7e>] ? trace_hardirqs_off+0xd/0xf
[30753.755998] [<ffffffff8105e7b8>] ? cpu_clock+0x43/0x5e
[30753.755998] [<ffffffffa00c6999>] usb_hcd_irq+0x45/0xa1 [usbcore]
[30753.755998] [<ffffffff81092e02>] handle_IRQ_event+0x20/0xa5
[30753.755998] [<ffffffff81094cea>] handle_fasteoi_irq+0x92/0xd2
[30753.755998] [<ffffffff8100c0ed>] handle_irq+0x1f/0x2a
[30753.755998] [<ffffffff8100b75d>] do_IRQ+0x57/0xbe
[30753.755998] [<ffffffff8136a693>] ret_from_intr+0x0/0x16
[30753.755998] <EOI> [<ffffffff81223baa>] ? acpi_idle_enter_bm+0x231/0x269
[30753.755998] [<ffffffff81223ba3>] ? acpi_idle_enter_bm+0x22a/0x269
[30753.755998] [<ffffffff812c4b6b>] cpuidle_idle_call+0x99/0xce
[30753.755998] [<ffffffff81008dd5>] cpu_idle+0x61/0xaa
[30753.755998] [<ffffffff8136374b>] start_secondary+0x1c2/0x1c6
[30753.755998] ---[ end trace 904cfaf7ab4cb1a2 ]---
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
commit 356c5a4834a74c621715f7a7f16ded914eecbd3c upstream.
Signed-off-by: Alessio Igor Bogani <abogani@texware.it>
commit b6180ef7c99574c3350bbffa2a3a9d675321543d upstream.
This patch is to add a US Interface, Inc. "Navigator" USB device.
Specifically, it's a HAM Radio USB sound modem that also
incorporates three pairs of unique FTDI serial ports. The standard
Linux FTDI serial driver will only recognize the first two serial
ports of an unknown FDTI derived device and this patch adds in
recognition to these specific new IDs.
Signed-off-by: David A. Ranch <dranch@trinnet.net>
commit 0372a754be9aa43e19fd86c9bc04796d43b55e38 upstream.
This patch adds the product IDs of Huawei's K3765 and K4505 mobile
broadband usb modems to option.c. It also adds a quirk to the option
probe function so that binding to the device's network interface(class
0xff) is avoided. This is necessary to allow another driver to bind to
that, and to avoid programs like wvdial opening a nonfunctioning tty
during modem discovery.
Signed-off-by: Andrew Bird <ajb@spheresystems.co.uk>
commit b972302b0a13aaddc9e90da2b4b52722e5d0e776 upstream.
The patch adds Huawei ETS 1220 product id into the list of supported
devices in 'option' usb serial driver.
Signed-off-by: Pavel Kazlou <p.i.kazlou@gmail.com>
commit afad19648f70c6493193e0a774bd754b7790b4a0 upstream.
I have added the ProductID=0xe729 VendorID=FTDI_VID=0x0403 which will
enable support for the Segway Robotic Mobility Platform (RMP200) in the
ftdi_sio kernel module. Currently, users of the Segway RMP200 must use
a RUN+="/sbin/modprobe -q ftdi-sio product=0xe729 vendor=0x0403 in a
udev rule to get the ftdi_sio module to handle the usb interface and
mount it on /dev/ttyXXX. This is not a good solution because some users
will have multiple USB to Serial converters which will use the ftdi_sio
module.
Signed-off-by: John Rogers <jgrogers@gmail.com>
commit 93362a875fc69881ae69299efaf19a55a1f57db0 upstream.
The Logitech Harmony 700 series needs an extra delay during
initialization. This patch adds a USB quirk which enables such a delay
and adds the device to the quirks list.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
commit 33d973ad88ceb83ed1449592b7574b5b5bb33ac6 upstream.
Enlarging the buffer size via the MON_IOCT_RING_SIZE ioctl causes
general protection faults. It appears the culprit is an incorrect
argument to mon_free_buff: instead of passing the size of the current
buffer being freed, the size of the new buffer is passed.
Use the correct size argument to mon_free_buff when changing the size of
the buffer.
Signed-off-by: Steven Robertson <steven@strobe.cc>
Acked-by: Pete Zaitcev <zaitcev@redhat.com>
commit 492c5d943d6a04b124ba3a719dc746dc36b14cfb upstream.
On SMP systems, the SMSC911x registers may be accessed by multiple CPUs
and this seems to put the chip in an inconsistent state. The patch adds
spinlocks to the smsc911x_reg_read, smsc911x_reg_write,
smsc911x_rx_readfifo and smsc911x_tx_writefifo functions.
commit 51e9ac77035a3dfcb6fc0a88a0d80b6f99b5edb1 upstream.
If the 'bio_split' path in raid10-read is used while
resync/recovery is happening it is possible to deadlock.
Fix this be elevating ->nr_waiting for the duration of both
parts of the split request.
This fixes a bug that has been present since 2.6.22
but has only started manifesting recently for unknown reasons.
It is suitable for and -stable since then.
Reported-by: Justin Bronder <jsbronder@gentoo.org>
Tested-by: Justin Bronder <jsbronder@gentoo.org>
commit 110712828365ccafcc61a7f4db44c31ed4cf8793 upstream.
ide_cd_error_cmd() can complete an erroneous request with leftover
buffers. Signal this with its return value so that the request is not
accessed after its completion in the irq handler and we oops.
Signed-off-by: Borislav Petkov <bp@alien8.de>
commit fa260c00c1aa5c657793a7221e40d2400df5afd8 upstream.
Fix a build failure "error: void value not ignored as it ought to be"
by removing an assignment of a void return value. The functionality of
the code is not changed.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Acked-by: Henrik Kretzschmar <henne@nachtwindheim.de>
commit 1f6ea6e511e5ec730d8e88651da1b7b6e8fd1333 upstream.
We were seeing faults in the solos-pci receive tasklet when packets
arrived for a VCC which was currently being closed:
[18842.727906] EIP: [<e082f490>] br2684_push+0x19/0x234 [br2684] SS:ESP 0068:dfb89d14
[18845.090712] [<c13ecff3>] ? do_page_fault+0x0/0x2e1
[18845.120042] [<e082f490>] ? br2684_push+0x19/0x234 [br2684]
[18845.153530] [<e084fa13>] solos_bh+0x28b/0x7c8 [solos_pci]
[18845.186488] [<e084f711>] ? solos_irq+0x2d/0x51 [solos_pci]
[18845.219960] [<c100387b>] ? handle_irq+0x3b/0x48
[18845.247732] [<c10265cb>] ? irq_exit+0x34/0x57
[18845.274437] [<c1025720>] tasklet_action+0x42/0x69
[18845.303247] [<c102643f>] __do_softirq+0x8e/0x129
[18845.331540] [<c10264ff>] do_softirq+0x25/0x2a
[18845.358274] [<c102664c>] _local_bh_enable_ip+0x5e/0x6a
[18845.389677] [<c102666d>] local_bh_enable+0xb/0xe
[18845.417944] [<e08490a8>] ppp_unregister_channel+0x32/0xbb [ppp_generic]
[18845.458193] [<e08731ad>] pppox_unbind_sock+0x18/0x1f [pppox]
This patch uses an RCU-inspired approach to fix it. In the RX tasklet's
find_vcc() function we first refuse to use a VCC which already has the
ATM_VF_READY bit cleared. And in the VCC close function, we synchronise
with the tasklet to ensure that it can't still be using the VCC before
we continue and allow the VCC to be destroyed.
Tested-by: Nathan Williams <nathan@traverse.com.au>
commit 549e15611b4ac1de51ef0e0a79c2704f50a638a2 upstream.
MSI delivery from on-board ahci controller doesn't work on K8M800. At
this point, it's unclear whether the culprit is with the ahci
controller or the host bridge. Given the track record and considering
the rather minimal impact of MSI, disabling it seems reasonable.
Reported-by: Rainer Hurtado Navarro <publio.escipion.el.africano@gmail.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 3d2a531804d16cd8df6dbbb0429c6f143e756049 upstream.
There is no reason to run NVidia-specific quirks related to HT MSI
mappings with MSI disabled via pci=nomsi, so make
__nv_msi_ht_cap_quirk() return immediately in that case.
This allows at least one machine to boot 100% of the time with
pci=nomsi (it still doesn't boot reliably without that).
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16443 .
commit 060132ae42cce3f9d2fd34d9a17b98362b44b9f9 upstream.
This patch prevents the code from calling parport_release and
parport_unregister_device twice with the same arguments - and thus fixes an oops.
Rationale:
After the first call the parport is already released and the
handle isn't valid anymore and calling parport_release and
parport_unregister_device twice isn't a good idea.
Acked-by: Willy Tarreau <w@1wt.eu>
commit e928c077e5cdcd72ee762125b37232aec1ff49f3 upstream.
line6 uses snd_pcm*() functions, so it should select SND_PCM.
ERROR: "snd_pcm_period_elapsed" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_set_ops" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_lib_free_pages" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_lib_ioctl" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_lib_malloc_pages" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_hw_constraint_ratdens" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_format_physical_width" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_lib_preallocate_pages_for_all" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_new" [drivers/staging/line6/line6usb.ko] undefined!
Cc: Markus Grabner <grabner@icg.tugraz.at>
commit a01c7800420d2c294ca403988488a635d4087a6d upstream.
In nvram_write, first of all, correctly handle the case where the file
pointer is already beyond the end; we should return EOF in that case.
Second, make the logic a bit more explicit so that gcc can statically
prove that the copy_from_user() is safe. Once the condition of the
beyond-end filepointer is eliminated, the copy is safe but gcc can't
prove it, causing build failures for i386 allyesconfig.
Third, eliminate the entirely superfluous variable "len", and just use
the passed-in variable "count" instead.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Wim Van Sebroeck <wim@iguana.be>
LKML-Reference: <tip-*@git.kernel.org>
Cc: Stephen Hemminger <shemminger@vyatta.com>
commit 213373cf974fe69e78ec894b07f45ae2f5a3a078 upstream.
SIDPR window registers are shared across ports and as each access is
done in two steps, accesses to different ports under EH may race.
This primarily is caused by incorrect host locking in EH context and
should be fixed by defining locking requirements for each EH operation
which can be used during EH and enforcing them but for now work around
the problem by adding a dedicated SIDPR lock and grabbing it for each
SIDPR access.
Reported-by: Mark Knecht <markknecht@gmail.com>
Reported-by: Paul Check <paul@thechecks.ca>
commit 9d1ac34ec3a67713308ae0883c3359c557f14d17 upstream.
In kernel Bugzilla #15825 (2 users), in a wireless mailing list thread
(http://lists.infradead.org/pipermail/b43-dev/2010-May/000124.html), and on a
netbook owned by John Linville
(http://marc.info/?l=linux-wireless&m=127230751408818&w=4), there are reports
of ssb failing to detect an SPROM at the normal location. After studying the
MMIO trace dump for the Broadcom wl driver, it was determined that the affected
boxes had a relocated SPROM.
This patch fixes all systems that have reported this problem.
Cc: Ben Hutchings <ben@decadent.org.uk>
commit da1fdb02d9200ff28b6f3a380d21930335fe5429 upstream.
Ethernet driver b44 does register ssb by it's pcihost_wrapper
and doesn't set ssb_chipcommon. A check on this value
introduced with commit d53cdbb94a52a920d5420ed64d986c3523a56743
and ea2db495f92ad2cf3301623e60cb95b4062bc484 triggers:
BUG: unable to handle kernel NULL pointer dereference at 00000010
IP: [<c1266c36>] ssb_is_sprom_available+0x16/0x30
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
Cc: Larry Finger <Larry.Finger@lwfinger.net>
commit ea2db495f92ad2cf3301623e60cb95b4062bc484 upstream.
Our offset handling becomes even a little more hackish now. For some reason I
do not understand all offsets as inrelative. It assumes base offset is 0x1000
but it will work for now as we make offsets relative anyway by removing base
0x1000. Should be cleaner however.
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
commit d53cdbb94a52a920d5420ed64d986c3523a56743 upstream.
Attempting to read registers that don't exist on the SSB bus can cause
hangs on some boxes. At least some b43 devices are 'in the wild' that
don't have SPROMs at all. When the SSB bus support loads, it attempts
to read these (non-existant) SPROMs and causes hard hangs on the box --
no console output, etc.
This patch adds some intelligence to determine whether or not the SPROM
is present before attempting to read it. This avoids those hard hangs
on those devices with no SPROM attached to their SSB bus. The
SSB-attached devices (e.g. b43, et al.) won't work, but at least the box
will survive to test further patches. :-)
Cc: Michael Buesch <mb@bu3sch.de>
Turns out this isn't the best way to resolve this issue. The
individual patches will be applied instead.
commit 6363ee6f496eb7e3b3f78dc105e522c7b496089b upstream.
On some laptops there is no HDMI/DP. But the xrandr still reports
several disconnected HDMI/display ports. In such case the user will be
confused.
>DVI1 disconnected (normal left inverted right x axis y axis)
>DP1 disconnected (normal left inverted right x axis y axis)
>DVI2 disconnected (normal left inverted right x axis y axis)
>DP2 disconnected (normal left inverted right x axis y axis)
>DP3 disconnected (normal left inverted right x axis y axis)
This patch set is to use the child device parsed in VBT to decide whether
the HDMI/DP/LVDS/TV should be initialized.
Parse the child device from VBT.
The device class type is also added for LFP, TV, HDMI, DP output.
https://bugs.freedesktop.org/show_bug.cgi?id=22785
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Reviewed-by: Adam Jackson <ajax@redhat.com>
Signed-off-by: Eric Anholt <eric@anholt.net>
Acked-by: Takashi Iwai <tiwai@suse.de>
Combined patches from 2.6.33 for fixing LVDS detection.
7cf4f69d3f4511f443473954456cb91d5514756d
drm/i915: Don't set up the LVDS if it isn't in the BIOS device table.
38b3037ee47fbd65a36bc7c39f60a900fbbe3b8e
drm/i915: Fix LVDS presence check
6e36595a2131e7ed5ee2674be54b2713ba7f0490
drm/i915: Declare the new VBT parsing functions as static
11ba159288f1bfc1a475c994e598f5fe423fde9d
drm/i915: Don't check for lid presence when detecting LVDS
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Adam Jackson <ajax@redhat.com>
Cc: Eric Anholt <eric@anholt.net>
commit a91c1be21704113b023919826c6d531da46656ef upstream.
we also need to clean up and free the cdev.
Reported-by: Jani Nikula <ext-jani.1.nikula@nokia.com>
commit d28232b461b8d54b09e59325dbac8b0913ce2049 upstream.
Fix possible double priv->mutex lock introduced by commit
a69b03e941abae00380fc6bc1877fb797a1b31e6
"iwlwifi: cancel scan watchdog in iwl_bg_abort_scan" .
We can not call cancel_delayed_work_sync(&priv->scan_check) with
priv->mutex locked because workqueue function iwl_bg_scan_check()
take that lock internally.
We do not need to synchronize when canceling priv->scan_check work.
We can avoid races (sending double abort command or send no
command at all) using STATUS_SCAN_ABORT bit. Moreover
current iwl_bg_scan_check() code seems to be broken, as
we should not send abort commands when currently aborting.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 4cee78614cfa046a26c4fbf313d5bbacb3ad8efc upstream.
When an aggregation session is being cleaned up, while the tx status
for some frames is being processed, the TID is flushed and its buffers
are sent out.
Unfortunately that left the pending un-acked frames unprocessed, thus
leaking buffers. Fix this by reordering the code so that those frames
are processed first, before the TID is flushed.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit f860d526eb2939a1c37128900b5af2b6f3ff7f20 upstream.
When issuing a reset, the TSF value is lost in the hardware because of
the 913x specific cold reset. As with some AR9280 cards, the TSF needs
to be preserved in software here.
Additionally, there's an issue that frequently prevents a successful
TSF write directly after the chip reset. In this case, repeating the
TSF write after the initval-writes usually works.
This patch detects failed TSF writes and recovers from them, taking
into account the delay caused by the initval writes.
Reported-by: Björn Smedman <bjorn.smedman@venatech.se>
commit 03b4776c408d2f4bf3a5d204e223724d154716d1 upstream.
PDADC values were only generated for values surrounding the target
index, however not for the target index itself, leading to a minor
error in the generated curve.
commit 4c85ab11ca56da1aa59b58c80cc6a356515cc645 upstream.
https://bugzilla.kernel.org/show_bug.cgi?id=16476
Acked-by: Luis R. Rodriguez <lrodriguez@atheros.com>
commit ff847ac2d3e90edd94674c28bade25ae1e6a2e49 upstream.
The MAC-PHY interconnect on 82577/82578 uses a power management feature
(called K1) which must be disabled when in 1Gbps due to a hardware issue on
these parts. The #define bit setting used to enable/disable K1 is
incorrect and can cause PHY register accesses to stop working altogether
until the next device reset. This patch sets the register correctly.
This issue is present in kernels since 2.6.32.
Signed-off-by: Bruce Allan <bruce.w.allan@intel.com>
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
commit 36f2407fe52c55566221f8c68c8fb808abffd2f5 upstream.
Should e1000_test_msi() fail to see an msi interrupt, it attempts to
fallback to legacy INTx interrupts. But an error in the code may prevent
this from happening correctly.
Before calling e1000_test_msi_interrupt(), e1000_test_msi() disables SERR
by clearing the SERR bit from the just read PCI_COMMAND bits as it writes
them back out.
Upon return from calling e1000_test_msi_interrupt(), it re-enables SERR
by writing out the version of PCI_COMMAND it had previously read.
The problem with this is that e1000_test_msi_interrupt() calls
pci_disable_msi(), which eventually ends up in pci_intx(). And because
pci_intx() was called with enable set to 1, the INTX_DISABLE bit gets
cleared from PCI_COMMAND, which is what we want. But when we get back to
e1000_test_msi(), the INTX_DISABLE bit gets inadvertently re-set because
of the attempt by e1000_test_msi() to re-enable SERR.
The solution is to have e1000_test_msi() re-read the PCI_COMMAND bits as
part of its attempt to re-enable SERR.
During debugging/testing of this issue I found that not all the systems
I ran on had the SERR bit set to begin with. And on some of the systems
the same could be said for the INTX_DISABLE bit. Needless to say these
latter systems didn't have a problem falling back to legacy INTx
interrupts with the code as is.
Signed-off-by: Dean Nelson <dnelson@redhat.com>
Tested-by: Emil Tantilov <emil.s.tantilov@intel.com>
commit bc57117856cf1e581135810b37d3b75f9d1749f5 upstream.
Exit early when setting scrub rate on unknown/unsupported families.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Acked-by: Doug Thompson <dougthompson@xmission.com>
commit 9975a5f22a4fcc8d08035c65439900a983f891ad upstream.
The correct check is to verify whether in high range we're below 4GB
and not to extract the DctSelBaseAddr again. See "2.8.5 Routing DRAM
Requests" in the F10h BKDG.
commit 4b4fd27c0b5ec638a1f06ced9226fd95229dbbf0 upstream.
avoid potential stack overflow by correctly checking count parameter
Reported-by: Ilja <ilja@netric.org>
Signed-off-by: Helge Deller <deller@gmx.de>
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
