This reverts commit 584ec12265192bf49dfa270d517380f6723a6956, which
was commit ddfadd7736b677de2d4ca2cd5b4b655368c85a7a upstream. It
causes boot failure on 3.2 although no such problem occurs upstream.
Reported-by: Ondrej Zary <linux@rainbow-software.org>
Acked-by: Dan Williams <dan.j.williams@intel.com>
commit 22c73795b101597051924556dce019385a1e2fa0 upstream.
This patch reorders reported frequencies from the highest to the lowest,
just like in other frequency drivers.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
[bwh: Backported to 3.2: cpu_frequency_table::driver_data is called index]
commit d82b922a4acc1781d368aceac2f9da43b038cab2 upstream.
The powernow-k6 driver used to read the initial multiplier from the
powernow register. However, there is a problem with this:
* If there was a frequency transition before, the multiplier read from the
register corresponds to the current multiplier.
* If there was no frequency transition since reset, the field in the
register always reads as zero, regardless of the current multiplier that
is set using switches on the mainboard and that the CPU is running at.
The zero value corresponds to multiplier 4.5, so as a consequence, the
powernow-k6 driver always assumes multiplier 4.5.
For example, if we have 550MHz CPU with bus frequency 100MHz and
multiplier 5.5, the powernow-k6 driver thinks that the multiplier is 4.5
and bus frequency is 122MHz. The powernow-k6 driver then sets the
multiplier to 4.5, underclocking the CPU to 450MHz, but reports the
current frequency as 550MHz.
There is no reliable way how to read the initial multiplier. I modified
the driver so that it contains a table of known frequencies (based on
parameters of existing CPUs and some common overclocking schemes) and sets
the multiplier according to the frequency. If the frequency is unknown
(because of unusual overclocking or underclocking), the user must supply
the bus speed and maximum multiplier as module parameters.
This patch should be backported to all stable kernels. If it doesn't
apply cleanly, change it, or ask me to change it.
- Adjust context
- s/driver_data/index/]
commit e20e1d0ac02308e2211306fc67abcd0b2668fb8b upstream.
I found out that a system with k6-3+ processor is unstable during network
server load. The system locks up or the network card stops receiving. The
reason for the instability is the CPU frequency scaling.
During frequency transition the processor is in "EPM Stop Grant" state.
The documentation says that the processor doesn't respond to inquiry
requests in this state. Consequently, coherency of processor caches and
bus master devices is not maintained, causing the system instability.
This patch flushes the cache during frequency transition. It fixes the
instability.
Other minor changes:
* u64 invalue changed to unsigned long because the variable is 32-bit
* move the logic to set the multiplier to a separate function
powernow_k6_set_cpu_multiplier
* preserve lower 5 bits of the powernow port instead of 4 (the voltage
field has 5 bits)
* mask interrupts when reading the multiplier, so that the port is not
open during other activity (running other kernel code with the port open
shouldn't cause any misbehavior, but we should better be safe and keep
the port closed)
[bwh: Backported to 3.2: adjust context]
commit a94cdd1f4d30f12904ab528152731fb13a812a16 upstream.
In read_all_bytes, we do
unsigned char i;
bt->read_data[0] = BMC2HOST;
bt->read_count = bt->read_data[0];
for (i = 1; i <= bt->read_count; i++)
bt->read_data[i] = BMC2HOST;
If bt->read_data[0] == bt->read_count == 255, we loop infinitely in the
'for' loop. Make 'i' an 'int' instead of 'char' to get rid of the
overflow and finish the loop after 255 iterations every time.
Reported-and-debugged-by: Rui Hui Dian <rhdian@novell.com>
Cc: Tomas Cech <tcech@suse.cz>
Cc: Corey Minyard <minyard@acm.org>
Cc: <openipmi-developer@lists.sourceforge.net>
Signed-off-by: Corey Minyard <cminyard@mvista.com>
commit e4af376d04b0(drivers: hv: switch to use mb() instead of smp_mb()),
the adjustment mistakenly dropped the change in hv_ringbuffer_read,
so add it.
Signed-off-by: Qiang Huang <h.huangqiang@huawei.com>
commit 2c42be2dd4f6586728dba5c4e197afd5cfaded78 upstream.
ft_del_tpg checks tpg->tport is set before unlinking the tpg from the
tport when the tpg is being removed. Set this pointer in ft_tport_create,
or the unlinking won't happen in ft_del_tpg and tport->tpg will reference
a deleted object.
This patch sets tpg->tport in ft_tport_create, because that's what
ft_del_tpg checks, and is the only way to get back to the tport to
clear tport->tpg.
The bug was occuring when:
- lport created, tport (our per-lport, per-provider context) is
allocated.
tport->tpg = NULL
- tpg created
- a PRLI is received. ft_tport_create is called, tpg is found and
tport->tpg is set
- tpg removed. ft_tpg is freed in ft_del_tpg. Since tpg->tport was not
set, tport->tpg is not cleared and points at freed memory
- Future calls to ft_tport_create return tport via first conditional,
instead of searching for new tpg by calling ft_lport_find_tpg.
tport->tpg is still invalid, and will access freed memory.
see https://bugzilla.redhat.com/show_bug.cgi?id=1071340
Signed-off-by: Andy Grover <agrover@redhat.com>
commit 12cd43c6ed6da7bf7c5afbd74da6959cda6d056b upstream.
Register B43_MMIO_PSM_PHY_HDR is 16 bit one, so accessing it with 32b
functions isn't safe. On my machine it causes delayed (!) CPU exception:
Disabling lock debugging due to kernel taint
mce: [Hardware Error]: CPU 0: Machine Check Exception: 4 Bank 4: b200000000070f0f
mce: [Hardware Error]: TSC 164083803dc
mce: [Hardware Error]: PROCESSOR 2:20fc2 TIME 1396650505 SOCKET 0 APIC 0 microcode 0
mce: [Hardware Error]: Run the above through 'mcelog --ascii'
mce: [Hardware Error]: Machine check: Processor context corrupt
Kernel panic - not syncing: Fatal machine check on current CPU
Kernel Offset: 0x0 from 0xffffffff81000000 (relocation range: 0xffffffff80000000-0xffffffff9fffffff)
Signed-off-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Larry Finger <Larry.Finger@lwfinger.net>
commit d444edc679e7713412f243b792b1f964e5cff1e1 upstream.
This patch fixes a long-standing bug in iscsit_build_conn_drop_async_message()
where during ERL=2 connection recovery, a bogus conn_p pointer could
end up being used to send the ISCSI_OP_ASYNC_EVENT + DROPPING_CONNECTION
notifying the initiator that cmd->logout_cid has failed.
The bug was manifesting itself as an OOPs in iscsit_allocate_cmd() with
a bogus conn_p pointer in iscsit_build_conn_drop_async_message().
Reported-by: Arshad Hussain <arshad.hussain@calsoftinc.com>
Reported-by: santosh kulkarni <santosh.kulkarni@calsoftinc.com>
commit 16086279353cbfecbb3ead474072dced17b97ddc upstream.
This needs to be done to update some of the fields in
the connector structure used by the audio code.
Noticed by several users on irc.
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Christian König <christian.koenig@amd.com>
commit aa6de142c901cd2d90ef08db30ae87da214bedcc upstream.
Previously, the vmwgfx_fb driver would allow users to call FBIOSET_VINFO, but it would not adjust
the FINFO properly, resulting in distorted screen rendering. The patch corrects that behaviour.
See https://bugs.gentoo.org/show_bug.cgi?id=494794 for examples.
Signed-off-by: Christopher Friedt <chrisfriedt@gmail.com>
Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
commit 5bdb0f02add5994b0bc17494f4726925ca5d6ba1 upstream.
In case of error when writing to userspace, function ehca_create_cq()
does not set an error code before following its error path.
This patch sets the error code to -EFAULT when ib_copy_to_udata()
fails.
This was caught when using spatch (aka. coccinelle)
to rewrite call to ib_copy_{from,to}_udata().
Link: https://www.gitorious.org/opteya/coccib/source/75ebf2c1033c64c1d81df13e4ae44ee99c989eba:ib_copy_udata.cocci
Link: http://marc.info/?i=cover.1394485254.git.ydroneaud@opteya.com
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit 08e74c4b00c30c232d535ff368554959403d0432 upstream.
In case of error when writing to userspace, the function mthca_create_cq()
This patch sets the error code to -EFAULT when ib_copy_to_udata() fails.
commit fe76cd88e654124d1431bb662a0fc6e99ca811a5 upstream.
If unable to ensure_next_mapping() we must add the current bio, which
was removed from the @bios list via bio_list_pop, back to the
deferred_bios list before all the remaining @bios.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Joe Thornber <ejt@redhat.com>
commit e1f23f3dd817f53f622e486913ac662add46eeed upstream.
This is *not* bisected, but the likely regression is
commit c35614380d5c956bfda20eab2755b2f5a7d6f1e7
Author: Zhao Yakui <yakui.zhao@intel.com>
Date: Tue Nov 24 09:48:48 2009 +0800
drm/i915: Don't set up the TV port if it isn't in the BIOS table.
The commit does not check for all TV device types that might be present
in the VBT, disabling TV out for the missing ones. Add composite
S-video.
Reported-and-tested-by: Matthew Khouzam <matthew.khouzam@gmail.com>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=73362
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
[bwh: Backported to 3.2: s/old\.device_type/device_type/]
commit a585f87c863e4e1d496459d382b802bf5ebe3717 upstream.
The scenario here is that someone calls enable_irq_wake() from somewhere
in the code. This will result in the lockdep producing a backtrace as can
be seen below. In my case, this problem is triggered when using the wl1271
(TI WlCore) driver found in drivers/net/wireless/ti/ .
The problem cause is rather obvious from the backtrace, but let's outline
the dependency. enable_irq_wake() grabs the IRQ buslock in irq_set_irq_wake(),
which in turns calls mxs_gpio_set_wake_irq() . But mxs_gpio_set_wake_irq()
calls enable_irq_wake() again on the one-level-higher IRQ , thus it tries to
grab the IRQ buslock again in irq_set_irq_wake() . Because the spinlock in
irq_set_irq_wake()->irq_get_desc_buslock()->__irq_get_desc_lock() is not
marked as recursive, lockdep will spew the stuff below.
We know we can safely re-enter the lock, so use IRQ_GC_INIT_NESTED_LOCK to
fix the spew.
[ INFO: possible recursive locking detected ]
3.10.33-00012-gf06b763-dirty #61 Not tainted
kworker/0:1/18 is trying to acquire lock:
(&irq_desc_lock_class){-.-...}, at: [<c00685f0>] __irq_get_desc_lock+0x48/0x88
but task is already holding lock:
Possible unsafe locking scenario:
CPU0
lock(&irq_desc_lock_class);
*** DEADLOCK ***
May be due to missing lock nesting notation
3 locks held by kworker/0:1/18:
#0: (events){.+.+.+}, at: [<c0036308>] process_one_work+0x134/0x4a4
#1: ((&fw_work->work)){+.+.+.}, at: [<c0036308>] process_one_work+0x134/0x4a4
#2: (&irq_desc_lock_class){-.-...}, at: [<c00685f0>] __irq_get_desc_lock+0x48/0x88
stack backtrace:
CPU: 0 PID: 18 Comm: kworker/0:1 Not tainted 3.10.33-00012-gf06b763-dirty #61
Workqueue: events request_firmware_work_func
[<c0013eb4>] (unwind_backtrace+0x0/0xf0) from [<c0011c74>] (show_stack+0x10/0x14)
[<c0011c74>] (show_stack+0x10/0x14) from [<c005bb08>] (__lock_acquire+0x140c/0x1a64)
[<c005bb08>] (__lock_acquire+0x140c/0x1a64) from [<c005c6a8>] (lock_acquire+0x9c/0x104)
[<c005c6a8>] (lock_acquire+0x9c/0x104) from [<c051d5a4>] (_raw_spin_lock_irqsave+0x44/0x58)
[<c051d5a4>] (_raw_spin_lock_irqsave+0x44/0x58) from [<c00685f0>] (__irq_get_desc_lock+0x48/0x88)
[<c00685f0>] (__irq_get_desc_lock+0x48/0x88) from [<c0068e78>] (irq_set_irq_wake+0x20/0xf4)
[<c0068e78>] (irq_set_irq_wake+0x20/0xf4) from [<c027260c>] (mxs_gpio_set_wake_irq+0x1c/0x24)
[<c027260c>] (mxs_gpio_set_wake_irq+0x1c/0x24) from [<c0068cf4>] (set_irq_wake_real+0x30/0x44)
[<c0068cf4>] (set_irq_wake_real+0x30/0x44) from [<c0068ee4>] (irq_set_irq_wake+0x8c/0xf4)
[<c0068ee4>] (irq_set_irq_wake+0x8c/0xf4) from [<c0310748>] (wlcore_nvs_cb+0x10c/0x97c)
[<c0310748>] (wlcore_nvs_cb+0x10c/0x97c) from [<c02be5e8>] (request_firmware_work_func+0x38/0x58)
[<c02be5e8>] (request_firmware_work_func+0x38/0x58) from [<c0036394>] (process_one_work+0x1c0/0x4a4)
[<c0036394>] (process_one_work+0x1c0/0x4a4) from [<c0036a4c>] (worker_thread+0x138/0x394)
[<c0036a4c>] (worker_thread+0x138/0x394) from [<c003cb74>] (kthread+0xa4/0xb0)
[<c003cb74>] (kthread+0xa4/0xb0) from [<c000ee00>] (ret_from_fork+0x14/0x34)
wlcore: loaded
Acked-by: Shawn Guo <shawn.guo@linaro.org>
commit 159ce52a6b777fc82fa0b51c7440e25f9e4c6feb upstream.
During probe the driver allocates dummy I2C device for companion chip
with i2c_new_dummy() but it does not check the return value of this call.
In case of error (i2c_new_device(): memory allocation failure or I2C
address cannot be used) this function returns NULL which is later used
by regmap_init_i2c().
If i2c_new_dummy() fails for companion device, fail also the probe for
main MFD driver.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
- Adjust filename, context
- Add kfree() before return, as driver is not using managed allocations]
commit 96cf3dedc491d2f1f66cc26217f2b06b0c7b6797 upstream.
During probe the driver allocates dummy I2C devices for RTC and ADC
calls.
by i2c_unregister_device().
If i2c_new_dummy() fails for RTC or ADC devices, fail also the probe
for main MFD driver.
commit ed26f87b9f71693a1d1ee85f5e6209601505080f upstream.
During probe the driver allocates dummy I2C device for RTC with i2c_new_dummy() but it does not check the return value of this call.
If i2c_new_dummy() fails for RTC device, fail also the probe for
main MFD driver.
commit 97dc4ed3fa377ec91bb60ba98b70d645c2099384 upstream.
During probe the driver allocates dummy I2C devices for RTC, haptic and
MUIC with i2c_new_dummy() but it does not check the return value of this
calls.
If i2c_new_dummy() fails for RTC, haptic or MUIC devices, fail also the
probe for main MFD driver.
commit a6e6e660baa5c583022e3e48c85316bace027825 upstream.
It is currently not possible to select the SA1100 or Vexpress
drivers in the MFD subsystem, because the menu for the entire
subsystem ends before these options are presented.
Move the main menu closing and the endif for HAS_IOMEM to the
end of the file so these are selectable again.
commit 9d194d1025f463392feafa26ff8c2d8247f71be1 upstream.
In case of error while accessing to userspace memory, function
nes_create_qp() returns NULL instead of an error code wrapped through
ERR_PTR(). But NULL is not expected by ib_uverbs_create_qp(), as it
check for error with IS_ERR().
As page 0 is likely not mapped, it is going to trigger an Oops when
the kernel will try to dereference NULL pointer to access to struct
ib_qp's fields.
In some rare cases, page 0 could be mapped by userspace, which could
turn this bug to a vulnerability that could be exploited: the function
pointers in struct ib_device will be under userspace total control.
to rewrite calls to ib_copy_{from,to}_udata().
Link: https://www.gitorious.org/opteya/ib-hw-nes-create-qp-null
commit a2cb0eb8a64adb29a99fd864013de957028f36ae upstream.
Guard against a potential buffer overrun. The size to read from the
user is passed in, and due to the padding that needs to be taken into
account, as well as the place holder for the ICRC it is possible to
overflow the 32bit value which would cause more data to be copied from
user space than is allocated in the buffer.
Reported-by: Nico Golde <nico@ngolde.de>
Reported-by: Fabian Yamaguchi <fabs@goesec.de>
Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
commit 3b3e0efb5c72c4fc940af50b33626b8a78a907dc upstream.
qi->tqi_readyTime is written directly to registers that expect
microseconds as unit instead of TU.
When setting the CABQ ready time, cur_conf->beacon_interval is in TU, so
convert it to microseconds before passing it to ath9k_hw.
This should hopefully fix some Tx DMA issues with buffered multicast
frames in AP mode.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit 1f74ef0f2d7d692fcd615621e0e734c3e7771413 upstream.
When adding or removing 100G from a balloon:
BUG: soft lockup - CPU#0 stuck for 22s! [vballoon:367]
We have a wait_event_interruptible(), but the condition is always true
(more ballooning to do) so we don't ever sleep. We also have a
wait_event() for the host to ack, but that is also always true as QEMU
is synchronous for balloon operations.
Reported-by: Gopesh Kumar Chaudhary <gopchaud@in.ibm.com>
commit 82e5a649453a3cf23516277abb84273768a1592b upstream.
There is a flow in which we send the host command in SYNC
mode, but we don't take priv->mutex.
Fixes: https://bugzilla.redhat.com/show_bug.cgi?id=1046495
Reviewed-by: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
- mutex is priv->shrd->mutex]
commit abe5d64d1a74195a44cd14624f8178b9f48b7cc7 upstream.
This patch fixes the following sparse warning :
drivers/staging/serqt_usb2/serqt_usb2.c:727:40: warning: restricted __le16 degrades to integer
Signed-off-by: Himangi Saraogi <himangi774@gmail.com>
commit 2610decdd0b3808ba20471a999835cfee5275f98 upstream.
In commit f78bccd79ba3cd9d9664981b501d57bdb81ab8a4 entitled "rtlwifi:
rtl8192ce: Fix too long disable of IRQs", Olivier Langlois
<olivier@trillion01.com> fixed a problem caused by an extra long disabling
of interrupts. This patch makes the same fix for rtl8192se.
- Adjust context
- Drop change to an error path that we don't have]
commit d8eb6c653ef6b323d630de3c5685478469e248bc upstream.
commit 511f3c5 (usb: gadget: udc-core: fix a regression during gadget driver
unbinding) introduced a crash when DEBUG is enabled.
The debug trace in the atmel_usba_stop function made the assumption that the
driver pointer passed in parameter was not NULL, but since the commit above,
such assumption was no longer always true.
This commit now uses the driver pointer stored in udc which fixes this
issue.
[ balbi@ti.com : improved commit log a bit ]
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit b1e43f232698274871e1358c276d7b0242a7d607 upstream.
The UVC specification uses alternate setting selection to notify devices
of stream start/stop. This breaks when using bulk-based devices, as the
video streaming interface has a single alternate setting in that case,
making video stream start and video stream stop events to appear
identical to the device. Bulk-based devices are thus not well supported
by UVC.
The webcam built in the Asus Zenbook UX302LA ignores the set interface
request and will keep the video stream enabled when the driver tries to
stop it. If USB autosuspend is enabled the device will then be suspended
and will crash, requiring a cold reboot.
USB trace capture showed that Windows sends a CLEAR_FEATURE(HALT)
request to the bulk endpoint when stopping the stream instead of
selecting alternate setting 0. The camera then behaves correctly, and
thus seems to require that behaviour.
Replace selection of alternate setting 0 with clearing of the endpoint
halt feature at video stream stop for bulk-based devices. Let's refrain
from blaming Microsoft this time, as it's not clear whether this
Windows-specific but USB-compliant behaviour was specifically developed
to handle bulkd-based UVC devices, or if the camera just took advantage
of it.
Signed-off-by: Oleksij Rempel <linux@rempel-privat.de>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
[bwh: Backported to 3.2: adjust filename]
commit 723abd87f6e536f1353c8f64f621520bc29523a3 upstream.
The 'active' sysfs attribute should refer to the currently active tty
devices the console is running on, not the currently active console. The
console structure doesn't refer to any device in sysfs, only the tty the
console is running on has. So we need to print out the tty names in
'active', not the console names.
There is one special-case, which is tty0. If the console is directed to
it, we want 'tty0' to show up in the file, so user-space knows that the
messages get forwarded to the active VT. The ->device() callback would
resolve tty0, though. Hence, treat it special and don't call into the VT
layer to resolve it (plymouth is known to depend on it).
Cc: Lennart Poettering <lennart@poettering.net>
Cc: Kay Sievers <kay@vrfy.org>
Cc: Jiri Slaby <jslaby@suse.cz>
Signed-off-by: Werner Fink <werner@suse.de>
Signed-off-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
[bwh: Backported to 3.2: no TTY_DRIVER_UNNUMBERED_NODE case in tty_line_name()]
commit 61f0319193c44adbbada920162d880b1fdb3aeb3 upstream.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 06f9b6e59661cee510b04513b13ea7927727d758 upstream.
Around DWC USB3 2.30a release another bit has been added to the
Device-Specific Event (DEVT) Event Information (EvtInfo) bitfield.
Because of that, what used to be 8 bits long, has become 9 bits long.
Per dwc3 2.30a+ spec in the Device-Specific Event (DEVT), the field of
Event Information Bits(EvtInfo) uses [24:16] bits, and it has 9 bits
not 8 bits. And the following reserved field uses [31:25] bits not
[31:24] bits, and it has 7 bits.
So in dwc3_event_devt, the bit mask should be:
event_info [24:16] 9 bits
reserved31_25 [31:25] 7 bits
This patch makes sure that newer core releases will work fine with
Linux and that we will decode the event information properly on new
core releases.
[ balbi@ti.com : improve commit log a bit ]
Signed-off-by: Huang Rui <ray.huang@amd.com>
commit f76a1cbed18c86e2d192455f0daebb48458965f3 upstream.
Commit 3e6c6f630a5282df8f3393a59f10eb9c56536d23 ("Delay creation of
khcvd thread") moved the call of hvc_init from being a device_initcall
into hvc_alloc, and used a non-null hvc_driver as indication of whether
hvc_init had already been called.
The problem with this is that hvc_driver is only assigned a value
at the bottom of hvc_init, and so there is a window where multiple
hvc_alloc calls can be in progress at the same time and hence try
and call hvc_init multiple times. Previously the use of device_init
guaranteed that hvc_init was only called once.
This manifests itself as sporadic instances of two hvc_init calls
racing each other, and with the loser of the race getting -EBUSY
from tty_register_driver() and hence that virtual console fails:
Couldn't register hvc console driver
virtio-ports vport0p1: error -16 allocating hvc for port
Here we add an atomic_t to guarantee we'll never run hvc_init twice.
Fixes: 3e6c6f630a52 ("Delay creation of khcvd thread")
Reported-by: Jim Somerville <Jim.Somerville@windriver.com>
Tested-by: Jim Somerville <Jim.Somerville@windriver.com>
commit 6b0df6827bb6fcacb158dff29ad0a62d6418b534 upstream.
The functions for data copying copyarea_foreward_8bpp and
copyarea_backward_8bpp are buggy, they produce screen corruption.
This patch fixes the functions and moves the logic to one function
"copyarea_8bpp". For simplicity, the function only handles copying that
is aligned on 8 pixes. If we copy an unaligned area, generic function
cfb_copyarea is used.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit 43751a1b8ee2e70ce392bf31ef3133da324e68b3 upstream.
This patch fixes the hardware cursor on mach64 when font width is not a
multiple of 8 pixels.
If you load such a font, the cursor is expanded to the next 8-byte
boundary and a part of the next character after the cursor is not
visible.
For example, when you load a font with 12-pixel width, the cursor width
is 16 pixels and when the cursor is displayed, 4 pixels of the next
character are not visible.
The reason is this: atyfb_cursor is called with proper parameters to
load an image that is 12-pixel wide. However, the number is aligned on
the next 8-pixel boundary on the line
"unsigned int width = (cursor->image.width + 7) >> 3;" and the whole
function acts as it is was loading a 16-pixel image.
This patch fixes it so that the value written to the framebuffer is
padded with 0xaaaa (the transparent pattern) when the image size it not
a multiple of 8 pixels. The transparent pattern causes that the cursor
will not interfere with the next character.
commit c29dd8696dc5dbd50b3ac441b8a26751277ba520 upstream.
This patch fixes mach64 to use unaligned access to the font bitmap.
This fixes unaligned access warning on sparc64 when 14x8 font is loaded.
On x86(64), unaligned access is handled in hardware, so both functions
le32_to_cpup and get_unaligned_le32 perform the same operation.
On RISC machines, unaligned access is not handled in hardware, so we
better use get_unaligned_le32 to avoid the unaligned trap and warning.
commit 00a9d699bc85052d2d3ed56251cd928024ce06a3 upstream.
The function cfb_copyarea is buggy when the copy operation is not aligned on
long boundary (4 bytes on 32-bit machines, 8 bytes on 64-bit machines).
How to reproduce:
- use x86-64 machine
- use a framebuffer driver without acceleration (for example uvesafb)
- set the framebuffer to 8-bit depth
(for example fbset -a 1024x768-60 -depth 8)
- load a font with character width that is not a multiple of 8 pixels
note: the console-tools package cannot load a font that has
width different from 8 pixels. You need to install the packages
"kbd" and "console-terminus" and use the program "setfont" to
set font width (for example: setfont Uni2-Terminus20x10)
- move some text left and right on the bash command line and you get a
screen corruption
To expose more bugs, put this line to the end of uvesafb_init_info:
info->flags |= FBINFO_HWACCEL_COPYAREA | FBINFO_READS_FAST;
- Now framebuffer console will use cfb_copyarea for console scrolling.
You get a screen corruption when console is scrolled.
This patch is a rewrite of cfb_copyarea. It fixes the bugs, with this
patch, console scrolling in 8-bit depth with a font width that is not a
multiple of 8 pixels works fine.
The cfb_copyarea code was very buggy and it looks like it was written
and never tried with non-8-pixel font.
commit a772d4736641ec1b421ad965e13457c17379fc86 upstream.
When X11 is running and the user switches back to console, the card
modifies the content of registers M_MACCESS and M_PITCH in periodic
intervals.
This patch fixes it by restoring the content of these registers before
issuing any accelerator command.
commit 6b355b33a64fd6d8ead2b838ec16fb9b551f71e8 upstream.
Previous logic,
if (avail > 8) {
store slave;
return;
send data; clear;
The logic error is, if there isn't space send the buffer and clear,
but the slave wasn't added to the now empty buffer loosing that slave
id. It also should have been "if (avail >= 8)" because when it is 8,
there is space.
Instead, if there isn't space send and clear the buffer, then there is
always space for the slave id.
Signed-off-by: David Fries <David@Fries.net>
Acked-by: Evgeniy Polyakov <zbr@ioremap.net>
commit 0f540c3a7cfb91c9d7a19eb0c95c24c5de1197d5 upstream.
Since
commit ee1452d7458451a7508e0663553ce88d63958157
Author: Jani Nikula <jani.nikula@intel.com>
Date: Fri Sep 20 15:05:30 2013 +0300
drm/i915: assume all GM45 Acer laptops use inverted backlight PWM
failed and was later reverted in
commit be505f643925e257087247b996cd8ece787c12af
Author: Alexander van Heukelum <heukelum@fastmail.fm>
Date: Sat Dec 28 21:00:39 2013 +0100
Revert "drm/i915: assume all GM45 Acer laptops use inverted backlight PWM"
fix the individual broken machine instead.
Note to backporters:
http://patchwork.freedesktop.org/patch/17837/
is the patch you want for 3.13 and older.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=54171
Reference: http://mid.gmane.org/DUB115-W7628C7C710EA51AA110CD4A5000@phx.gbl
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
[danvet: Patch mangling for 3.14 plus adding the link to the original
for 3.13.]
commit ac4199e0f047546aa40172785e26c82b54bbe811 upstream.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=53881
Cc: Jani Nikula <jani.nikula@intel.com>
Tested-by: Jani Monoses <jani@ubuntu.com>
[ Upstream commit 7563487cbf865284dcd35e9ef5a95380da046737 ]
There are three buffer overflows addressed in this patch.
1) In isdnloop_fake_err() we add an 'E' to a 60 character string and
then copy it into a 60 character buffer. I have made the destination
buffer 64 characters and I'm changed the sprintf() to a snprintf().
2) In isdnloop_parse_cmd(), p points to a 6 characters into a 60
character buffer so we have 54 characters. The ->eazlist[] is 11
characters long. I have modified the code to return if the source
buffer is too long.
3) In isdnloop_command() the cbuf[] array was 60 characters long but the
max length of the string then can be up to 79 characters. I made the
cbuf array 80 characters long and changed the sprintf() to snprintf().
I also removed the temporary "dial" buffer and changed it to use "p"
directly.
Unfortunately, we pass the "cbuf" string from isdnloop_command() to
isdnloop_writecmd() which truncates anything over 60 characters to make
it fit in card->omsg[]. (It can accept values up to 255 characters so
long as there is a '\n' character every 60 characters). For now I have
just fixed the memory corruption bug and left the other problems in this
driver alone.
[ Upstream commit 77bc6bed7121936bb2e019a8c336075f4c8eef62 ]
Return -EINVAL unless all of user-given strings are correctly
NUL-terminated.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
[ Upstream commit 0576eddf24df716d8570ef8ca11452a9f98eaab2 ]
This patch removes a test in start_new_rx_buffer() that checks whether
a copy operation is less than MAX_BUFFER_OFFSET in length, since
MAX_BUFFER_OFFSET is defined to be PAGE_SIZE and the only caller of
start_new_rx_buffer() already limits copy operations to PAGE_SIZE or less.
Signed-off-by: Paul Durrant <paul.durrant@citrix.com>
Cc: Ian Campbell <ian.campbell@citrix.com>
Cc: Wei Liu <wei.liu2@citrix.com>
Cc: Sander Eikelenboom <linux@eikelenboom.it>
Reported-By: Sander Eikelenboom <linux@eikelenboom.it>
Tested-By: Sander Eikelenboom <linux@eikelenboom.it>
[ Upstream commit a39ee449f96a2cd44ce056d8a0a112211a9b1a1f ]
vhost fails to validate negative error code
from vhost_get_vq_desc causing
a crash: we are using -EFAULT which is 0xfffffff2
as vector size, which exceeds the allocated size.
The code in question was introduced in commit
8dd014adfea6f173c1ef6378f7e5e7924866c923
vhost-net: mergeable buffers support
CVE-2014-0055
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
[ Upstream commit d8316f3991d207fe32881a9ac20241be8fa2bad0 ]
When mergeable buffers are disabled, and the
incoming packet is too large for the rx buffer,
get_rx_bufs returns success.
This was intentional in order for make recvmsg
truncate the packet and then handle_rx would
detect err != sock_len and drop it.
Unfortunately we pass the original sock_len to
recvmsg - which means we use parts of iov not fully
validated.
Fix this up by detecting this overrun and doing packet drop
immediately.
CVE-2014-0077
commit d43ff4cd798911736fb39025ec8004284b1b0bc2 upstream.
The struct driver_info ax88178_info is assigned the function
asix_rx_fixup_common as it's rx_fixup callback. This means that
FLAG_MULTI_PACKET must be set as this function is cloning the
data and calling usbnet_skb_return. Not setting this flag leads
to usbnet_skb_return beeing called a second time from within
the rx_process function in the usbnet module.
Signed-off-by: Emil Goode <emilgoode@gmail.com>
Reported-by: Bjørn Mork <bjorn@mork.no>
commit 8b5b6f5413e97c3e8bafcdd67553d508f4f698cd upstream.
ASIX AX88772B started to pack data even more tightly. Packets and the ASIX packet
header may now cross URB boundaries. To handle this we have to introduce
some state between individual calls to asix_rx_fixup().
Signed-off-by: Lucas Stach <dev@lynxeye.de>
[ Emil: backported to 3.2:
- dropped changes to drivers/net/usb/ax88172a.c
- Introduced some static function declarations as the functions
are not used outside of asix.c (sparse is complaining about it) ]
commit a9e0aca4b37885b5599e52211f098bd7f565e749 upstream.
asix_rx_fixup() is complex, and does some unnecessary memory copies (at
least on x86 where NET_IP_ALIGN is 0)
Also, it tends to provide skbs with a big truesize (4096+256 with
MTU=1500) to upper stack, so incoming trafic consume a lot of memory and
I noticed early packet drops because we hit socket rcvbuf too fast.
Switch to a different strategy, using copybreak so that we provide nice
skbs to upper stack (including the NET_SKB_PAD to avoid future head
reallocations in some paths)
With this patch, I no longer see packets drops or tcp collapses on
various tcp workload with a AX88772 adapter.
Cc: Aurelien Jacobs <aurel@gnuage.org>
Cc: Trond Wuellner <trond@chromium.org>
Cc: Grant Grundler <grundler@chromium.org>
Cc: Paul Stewart <pstew@chromium.org>
Reviewed-by: Grant Grundler <grundler@chromium.org>
[ Emil: Backported to 3.2: fixed small conflict ]
