commit 6abff5dc4d5a2c90e597137ce8987e7fd439259b upstream.
Add USB IDs for Motorola H24 HSPA USB module.
Signed-off-by: Krzysztof Hałasa <khalasa@piap.pl>
Acked-by: Oliver Neukum <oneukum@suse.de>
commit 130c5ce716c9bfd1c2a2ec840a746eb7ff9ce1e6 upstream.
This fixes the A->B/B->A locking dependency, see the warning below.
The function task_exit_notify() is called with (task_exit_notifier)
.rwsem set and then calls sync_buffer() which locks buffer_mutex. In
sync_start() the buffer_mutex was set to prevent notifier functions to
be started before sync_start() is finished. But when registering the
notifier, (task_exit_notifier).rwsem is locked too, but now in
different order than in sync_buffer(). In theory this causes a locking
dependency, what does not occur in practice since task_exit_notify()
is always called after the notifier is registered which means the lock
is already released.
However, after checking the notifier functions it turned out the
buffer_mutex in sync_start() is unnecessary. This is because
sync_buffer() may be called from the notifiers even if sync_start()
did not finish yet, the buffers are already allocated but empty. No
need to protect this with the mutex.
So we fix this theoretical locking dependency by removing buffer_mutex
in sync_start(). This is similar to the implementation before commit:
750d857 oprofile: fix crash when accessing freed task structs
which introduced the locking dependency.
Lockdep warning:
oprofiled/4447 is trying to acquire lock:
(buffer_mutex){+.+...}, at: [<ffffffffa0000e55>] sync_buffer+0x31/0x3ec [oprofile]
but task is already holding lock:
((task_exit_notifier).rwsem){++++..}, at: [<ffffffff81058026>] __blocking_notifier_call_chain+0x39/0x67
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #1 ((task_exit_notifier).rwsem){++++..}:
[<ffffffff8106557f>] lock_acquire+0xf8/0x11e
[<ffffffff81463a2b>] down_write+0x44/0x67
[<ffffffff810581c0>] blocking_notifier_chain_register+0x52/0x8b
[<ffffffff8105a6ac>] profile_event_register+0x2d/0x2f
[<ffffffffa00013c1>] sync_start+0x47/0xc6 [oprofile]
[<ffffffffa00001bb>] oprofile_setup+0x60/0xa5 [oprofile]
[<ffffffffa00014e3>] event_buffer_open+0x59/0x8c [oprofile]
[<ffffffff810cd3b9>] __dentry_open+0x1eb/0x308
[<ffffffff810cd59d>] nameidata_to_filp+0x60/0x67
[<ffffffff810daad6>] do_last+0x5be/0x6b2
[<ffffffff810dbc33>] path_openat+0xc7/0x360
[<ffffffff810dbfc5>] do_filp_open+0x3d/0x8c
[<ffffffff810ccfd2>] do_sys_open+0x110/0x1a9
[<ffffffff810cd09e>] sys_open+0x20/0x22
[<ffffffff8146ad4b>] system_call_fastpath+0x16/0x1b
-> #0 (buffer_mutex){+.+...}:
[<ffffffff81064dfb>] __lock_acquire+0x1085/0x1711
[<ffffffff814634f0>] mutex_lock_nested+0x63/0x309
[<ffffffffa0001226>] task_exit_notify+0x16/0x1a [oprofile]
[<ffffffff81467b96>] notifier_call_chain+0x37/0x63
[<ffffffff8105803d>] __blocking_notifier_call_chain+0x50/0x67
[<ffffffff81058068>] blocking_notifier_call_chain+0x14/0x16
[<ffffffff8105a718>] profile_task_exit+0x1a/0x1c
[<ffffffff81039e8f>] do_exit+0x2a/0x6fc
[<ffffffff8103a5e4>] do_group_exit+0x83/0xae
[<ffffffff8103a626>] sys_exit_group+0x17/0x1b
1 lock held by oprofiled/4447:
#0: ((task_exit_notifier).rwsem){++++..}, at: [<ffffffff81058026>] __blocking_notifier_call_chain+0x39/0x67
stack backtrace:
Pid: 4447, comm: oprofiled Not tainted 2.6.39-00007-gcf4d8d4 #10
Call Trace:
[<ffffffff81063193>] print_circular_bug+0xae/0xbc
[<ffffffffa0000e55>] ? sync_buffer+0x31/0x3ec [oprofile]
[<ffffffff81062627>] ? mark_lock+0x42f/0x552
[<ffffffff81058026>] ? __blocking_notifier_call_chain+0x39/0x67
[<ffffffff81465031>] ? retint_swapgs+0xe/0x13
Reported-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Cc: Carl Love <carll@us.ibm.com>
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit 6ac6519b93065625119a347be1cbcc1b89edb773 upstream.
After registering the task free notifier we possibly have tasks in our
dying_tasks list. Free them after unregistering the notifier in case
of an error.
commit 745718132c3c7cac98a622b610e239dcd5217f71 upstream.
When we tear down a device we try to flush all outstanding
commands in scsi_free_queue(). However the check in
scsi_request_fn() is imperfect as it only signals that
we _might start_ aborting commands, not that we've actually
aborted some.
So move the printk inside the scsi_kill_request function,
this will also give us a hint about which commands are aborted.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit 03b147083a2f9a2a3fbbd2505fa88ffa3c6ab194 upstream.
Stanse found a potential NULL dereference in scsi_kill_request.
Instead of triggering BUG() in 'if (unlikely(cmd == NULL))' branch,
the kernel will Oops earlier on cmd dereference.
Move the dereferences after the if.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit cec28a5428793b6bc64e56687fb239759d6da74e upstream.
Kingston DT 101 G2 replies a wrong tag while transporting, add an
unusal_devs entry to ignore the tag validation.
Signed-off-by: Qinglin Ye <yestyle@gmail.com>
commit ec0cd94d881ca89cc9fb61d00d0f4b2b52e605b3 upstream.
Tested with SIM5218EVB-KIT evaluation kit.
Signed-off-by: Veli-Pekka Peltola <veli-pekka.peltola@bluegiga.com>
commit 307369b0ca06b27b511b61714e335ddfccf19c4f upstream.
Signed-off-by: Marcin Kościelnicki <koriakin@0x04.net>
commit 8746c83d538cab273d335acb2be226d096f4a5af upstream.
qset->qh.link is an __le64 field and we should be using cpu_to_le64()
to fill it.
commit 6a9ce6b654e491981f6ef7e214cbd4f63e033848 upstream.
After sleeping on a wait queue, signal_pending(current) should be
checked (not before sleeping).
Acked-by: Alessandro Rubini <rubini@gnudd.com>
Signed-off-by: Federico Vaga <federico.vaga@gmail.com>
commit 3ffab428f40849ed5f21bcfd7285bdef7902f9ca upstream.
This fixes kernel oops when an USB DAQ device is plugged out while it's
communicating with the userspace software.
Signed-off-by: Bernd Porr <berndporr@f2s.com>
commit 438957f8d4a84daa7fa5be6978ad5897a2e9e5e5 upstream.
Interrupts must be disabled prior to calling usb_hcd_unlink_urb_from_ep.
If interrupts are not disabled, it can potentially lead to a deadlock.
The deadlock is readily reproduceable on a slower (ARM based) device
such as the TI Pandaboard.
Signed-off-by: Bart Westgeest <bart@elbrys.com>
commit 2d1618170eb493d18f66f2ac03775409a6fb97c6 upstream.
priv->work must not be synced while priv->mutex is locked, because
the mutex is taken in the work handler.
Move cancel_work_sync down to after the device shutdown code.
This is safe, because the work handler checks fw_state and bails out
early in case of a race.
Signed-off-by: Michael Buesch <m@bues.ch>
Acked-by: Christian Lamparter <chunkeey@googlemail.com>
commit 32d3a3922d617a5a685a5e2d24b20d0e88f192a9 upstream.
The tx_lock is not initialized properly. Add spin_lock_init().
commit 4cac2eb158c6da0c761689345c6cc5df788a6292 upstream.
Previously we claimed device ID 0x7450, regardless of the vendor, which is
clearly wrong. Now we'll claim that device ID only for AMD.
I suspect this was just a typo in the original code, but it's possible this
change will break shpchp on non-7450 AMD bridges. If so, we'll have to fix
them as we find them.
Reference: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=638863
Reported-by: Ralf Jung <ralfjung-e@gmx.de>
Cc: Joerg Roedel <joerg.roedel@amd.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit cc6bcf7d2ec2234e7b41770185e4dc826390185e upstream.
The wrong bits were put on the wire, fix that.
This fixes kernel bug #42562.
Signed-off-by: Sheng-Hui J. Chu <jeffchu@broadcom.com>
commit 0587102cf9f427c185bfdeb2cef41e13ee0264b1 upstream
Again basically cut and paste
Convert the main driver set to use the hooks for GICOUNT
Signed-off-by: Alan Cox <alan@linux.intel.com>
commit d281da7ff6f70efca0553c288bb883e8605b3862 upstream
Dan Rosenberg noted that various drivers return the struct with uncleared
fields. Instead of spending forever trying to stomp all the drivers that
get it wrong (and every new driver) do the job in one place.
This first patch adds the needed operations and hooks them up, including
the needed USB midlayer and serial core plumbing.
commit 0d145d7d4a241c321c832a810bb6edad18e2217b upstream.
The following patch contains additional affected webcam models, on top of the
patches commited to linux-next 2394d67e446bf616a0885167d5f0d397bdacfdfc
and 5b253d88cc6c65a23cefc457a5a4ef139913c5fc
Signed-off-by: sordna <sordna@gmail.com>
Cc: Oliver Neukum <oliver@neukum.org>
commit 60c71ca972a2dd3fd9d0165b405361c8ad48349b upstream.
We've had another report of the "chipmunk" sound on a Logitech C600 webcam.
This patch resolves the issue.
Signed-off-by: Josh Boyer <jwboyer@redhat.com>
commit 2f640bf4c94324aeaa1b6385c10aab8c5ad1e1cf upstream.
The 8020i protocol (also 8070i and QIC-157) uses 12-byte commands;
shorter commands must be padded. Simon Detheridge reports that his
3-TB USB disk drive claims to use the 8020i protocol (which is
normally meant for ATAPI devices like CD drives), and because of its
large size, the disk drive requires the use of 16-byte commands.
However the usb_stor_pad12_command() routine in usb-storage always
sets the command length to 12, making the drive impossible to use.
Since the SFF-8020i specification allows for 16-byte commands in
future extensions, we may as well accept them. This patch (as1490)
changes usb_stor_pad12_command() to leave commands larger than 12
bytes alone rather than truncating them.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Simon Detheridge <simon@widgit.com>
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
commit b1ffb4c851f185e9051ba837c16d9b84ef688d26 upstream.
Fix for ftdi_set_termios() glitching output
ftdi_set_termios() is constantly setting the baud rate, data bits and parity
unnecessarily on every call, . When called while characters are being
transmitted can cause the FTDI chip to corrupt the serial port bit stream
output by stalling the output half a bit during the output of a character.
Simple fix by skipping this setting if the baud rate/data bits/parity are
unchanged.
Signed-off-by: Andrew Worsley <amworsley@gmail.com>
commit 0c16595539b612fe948559433dda08ff96a8bdc7 upstream.
I get report from customer that his usb-serial
converter doesn't work well,it sometimes work,
but sometimes it doesn't.
The usb-serial converter's id:
vendor_id product_id
0x4348 0x5523
Then I search the usb-serial codes, and there are
two drivers announce support this device, pl2303
and ch341, commit 026dfaf1 cause it. Through many
times to test, ch341 works well with this device,
and pl2303 doesn't work quite often(it just work quite little).
ch341 works well with this device, so we doesn't
need pl2303 to support.I try to revert 026dfaf1 first,
but it failed. So I prepare this patch by hand to revert it.
Signed-off-by: Wang YanQing <Udknight@gmail.com>
commit 9bab0b7fbaceec47d32db51cd9e59c82fb071f5a upstream
This adds a mechanism to resume selected IRQs during syscore_resume
instead of dpm_resume_noirq.
Under Xen we need to resume IRQs associated with IPIs early enough
that the resched IPI is unmasked and we can therefore schedule
ourselves out of the stop_machine where the suspend/resume takes
place.
This issue was introduced by 676dc3cf5bc3 "xen: Use IRQF_FORCE_RESUME".
Back ported to 2.6.32 (which lacks syscore support) by calling the relavant
resume function directly from sysdev_resume).
v2: Fixed non-x86 build errors.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Jeremy Fitzhardinge <Jeremy.Fitzhardinge@citrix.com>
Cc: xen-devel <xen-devel@lists.xensource.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Link: http://lkml.kernel.org/r/1318713254.11016.52.camel@dagon.hellion.org.uk
commit 7dcd2499deab8f10011713c40bc2f309c9b65077 upstream
... and do the same for pread.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
commit ce9d419dbecc292cc3e06e8b1d6d123d3fa813a4 upstream.
Move the access control up from the fast paths, which are no longer
universally taken first, up into the caller. This then duplicates some
sanity checking along the slow paths, but is much simpler.
Tracked as CVE-2010-2962.
Reported-by: Kees Cook <kees@ubuntu.com>
commit 9a3f530f39f4490eaa18b02719fb74ce5f4d2d86 upstream.
When the number of failed devices exceeds the allowed number
we must abort any active parity operations (checks or updates) as they
are no longer meaningful, and can lead to a BUG_ON in
handle_parity_checks6.
This bug was introduce by commit 6c0069c0ae9659e3a91b68eaed06a5c6c37f45c8
in 2.6.29.
Reported-by: Manish Katiyar <mkatiyar@gmail.com>
Tested-by: Manish Katiyar <mkatiyar@gmail.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit bf5140817b2d65faac9b32fc9057a097044ac35b upstream.
On writes in MODE_RAW the mtd_oob_ops struct is not sufficiently
initialized which may cause nandwrite to fail. With this patch
it is possible to write raw nand/oob data without additional ECC
(either for testing or when some sectors need different oob layout
e.g. bootloader) like
nandwrite -n -r -o /dev/mtd0 <myfile>
Signed-off-by: Peter Wippich <pewi@gw-instruments.de>
Tested-by: Ricard Wanderlof <ricardw@axis.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit 3308511c93e6ad0d3c58984ecd6e5e57f96b12c8 upstream.
Make sure that SCSI device removal via scsi_remove_host() does finish
all pending SCSI commands. Currently that's not the case and hence
removal of a SCSI host during I/O can cause a deadlock. See also
"blkdev_issue_discard() hangs forever if underlying storage device is
removed" (http://bugzilla.kernel.org/show_bug.cgi?id=40472). See also
http://lkml.org/lkml/2011/8/27/6.
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
commit c68bf8eeaa57c852e74adcf597237be149eef830 upstream.
The call to complete() in st_scsi_execute_end() wakes up sleeping thread
in write_behind_check(), which frees the st_request, thus invalidating
the pointer to the associated bio structure, which is then passed to the
blk_rq_unmap_user(). Fix by storing pointer to bio structure into
temporary local variable.
This bug is present since at least linux-2.6.32.
Signed-off-by: Petr Uzel <petr.uzel@suse.cz>
Reported-by: Juergen Groß <juergen.gross@ts.fujitsu.com>
Acked-by: Kai Mäkisara <kai.makisara@kolumbus.fi>
This reverts commit 0f12a6ad9fa3a03f2bcee36c9cb704821e244c40.
It causes too many build errors and needs to be done properly.
Reported-by: Jiri Slaby <jslaby@suse.cz>
Reported-by: Christoph Biedl <linux-kernel.bfrz@manchmal.in-ulm.de>
Cc: Ian Campbell <ian.campbell@citrix.com>
commit ce7e9065958191e6b7ca49d7ed0e1099c486d198 upstream.
Here is a patch for a new PID (zeitcontrol-device mifare-reader FT232BL(like FT232BM but lead free)).
Signed-off-by: Artur Zimmer <artur128@3dzimmer.de>
commit 2f1def2695c223b2aa325e5e47d0d64200a45d23 upstream.
A new device ID pair is added for Sierra Wireless MC8305.
Signed-off-by: Florian Echtler <floe@butterbrot.org>
commit e0c87bd95e8dad455c23bc56513af8dcb1737e55 upstream.
Modify Ethernet addess macros to be compatible with BE/LE platforms
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Cc: Chul Kim <chul.kim@idt.com>
Cc: Kumar Gala <galak@kernel.crashing.org>
Cc: Matt Porter <mporter@kernel.crashing.org>
Cc: Li Yang <leoli@freescale.com>
commit 9fbdaeb4f4dd14a0caa9fc35c496d5440c251a3a upstream.
The newer Lenovo ThinkPads have HKEY HID of LEN0068 instead
of IBM0068. Added new HID so that thinkpad_acpi module will
auto load on these newer Lenovo ThinkPads.
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: stable@vger.kernel.org
Signed-off-by: Manoj Iyer <manoj.iyer@canonical.com>
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Commit 6d86a0ee (watchdog: mtx1-wdt: request gpio before using it) was
backported from upstream. The patch is using a gpiolib call which is only
available in kernel 2.6.34+. Fix build by using the "old" gpiolib API
instead.
Signed-off-by: Florian Fainelli <florian@openwrt.org>
This reverts commit 262e2d9d559334e09bc80516132ea99d82f97b8c.
Turns out this breaks the build, and as such, really isn't needed for
the 2.6.32-stable branch at all.
Reported-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Cc: Anand Gadiyar <gadiyar@ti.com>
Cc: Ajay Kumar Gupta <ajay.gupta@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
place.
commit 9bed77ee2fb46b74782d0d9d14b92e9d07f3df6e upstream.
This device is not using the proper demod IF. Instead of using the
IF macro, it is specifying a IF frequency. This doesn't work, as xc3028
needs to load an specific SCODE for the tuner. In this case, there's
no IF table for 5 MHz.
commit d59a7b1dbce8b972ec2dc9fcaaae0bfa23687423 upstream.
If the bus has been reset on resume, set the alternate setting to 0.
This should be the default value, but some devices crash or otherwise
misbehave if they don't receive a SET_INTERFACE request before any other
video control request.
Microdia's 0c45:6437 camera has been found to require this change or it
will stop sending video data after resume.
uvc_video.c]
Signed-off-by: Ming Lei <ming.lei@canonical.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit c84c14224bbca6ec60d5851fcc87be0e34df2f44 upstream.
The third parameter of module_param is supposed to be an octal value.
The missing leading "0" causes the following:
$ ls -l /sys/module/carminefb/parameters/
total 0
-rw-rwxr-- 1 root root 4096 Jul 8 08:55 fb_displays
-rw-rwxr-- 1 root root 4096 Jul 8 08:55 fb_mode
-rw-rwxr-- 1 root root 4096 Jul 8 08:55 fb_mode_str
After fixing the perm parameter, we get the expected:
total 0
-r--r--r-- 1 root root 4096 Jul 8 08:56 fb_displays
-r--r--r-- 1 root root 4096 Jul 8 08:56 fb_mode
-r--r--r-- 1 root root 4096 Jul 8 08:56 fb_mode_str
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Sebastian Siewior <bigeasy@linutronix.de>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
commit dbdf1afcaaabe83dea15a3cb9b9013e73ae3b1ad upstream.
Put sysfs attributes of ccwgroup devices in an attribute group to
ensure that these attributes are actually present when userspace
is notified via uevents.
Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com>
commit 273d23574f9dacd9c63c80e7d63639a669aad441 upstream.
For USB CONTROL transaction, when the data length is zero,
the IN package is needed to finish this transaction in status stage.
Signed-off-by: Jerry Huang <r66093@freescale.com>
commit 3687f641307eeff6f7fe31a88dc39db88e89238b upstream.
Some Stellaris evaluation kits have the JTAG/SWD FTDI chip onboard,
and some, like EK-LM3S9B90, come with a separate In-Circuit Debugger
Interface Board. The ICDI board can also be used stand-alone, for
other boards and chips than the kit it came with. The ICDI has both
old style 20-pin JTAG connector and new style JTAG/SWD 10-pin 1.27mm
pitch connector.
Tested with EK-LM3S9B90, where the BD-ICDI board is included.
Signed-off-by: Peter Stuge <peter@stuge.se>
commit 74bdf22b5c3858b06af46f19d05c23e76c40a3bb upstream.
Add PID 0xfc8a, 0xfc8b for device Sony Ericsson Urban
Signed-off-by: Hakan Kvist <hakan.kvist@sonyericsson.com>
Signed-off-by: Oskar Andero <oskar.andero@sonyericsson.com>
commit 598f0b703506da841d3459dc0c48506be14d1778 upstream.
Add vendor and product ID for the SMART USB to serial adapter. These
were meant to be used with their SMART Board whiteboards, but can be
re-purposed for other tasks. Tested and working (at at least 9600 bps).
Signed-off-by: Eric Benoit <eric@ecks.ca>
commit 2394d67e446bf616a0885167d5f0d397bdacfdfc upstream.
The new runtime PM code has shown that many webcams suffer
from a race condition that may crash them upon resume.
Runtime PM is especially prone to show the problem because
it retains power to the cameras at all times. However
system suspension may also crash the devices and retain
power to the devices.
The only way to solve this problem without races is in
usbcore with the RESET_RESUME quirk.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 65e52f41fa944cef2e6d4222b8c54f46cc575214 upstream.
here is the patch to support Owen SI-30 device.
This is a pulse counter controller.
http://www.owen.ru/en/catalog/93788515
usb-drivers output:
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 4 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=02(commc) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=03eb ProdID=0030 Rev=01.01
C: #Ifs= 2 Cfg#= 1 Atr=c0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=02 Prot=00 Driver=cdc_acm
I: If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_acm
This patch is installed on my home system which receives data from this
controller connected to cold water counter.
Signed-off-by: Denis Pershin <dyp@perchine.com>
commit aec01c5895051849ed842dc5b8794017a7751f28 upstream.
Alan Stern points out that after spin_unlock(&ps->lock) there is no
guarantee that ps->pid won't be freed. Since kill_pid_info_as_uid() is
called after the spin_unlock(), the pid passed to it must be pinned.
Reported-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Serge Hallyn <serge.hallyn@canonical.com>
commit e16da02fcdf1c5e824432f88abf42623dafdf191 upstream.
This patch solves two things:
1) Enables autosense emulation code to correctly
interpret descriptor format sense data, and
2) Fixes a bug whereby the autosense emulation
code would overwrite descriptor format sense data
with SENSE KEY HARDWARE ERROR in fixed format, to
incorrectly look like this:
Oct 21 14:11:07 localhost kernel: sd 7:0:0:0: [sdc] Sense Key : Recovered Error [current] [descriptor]
Oct 21 14:11:07 localhost kernel: Descriptor sense data with sense descriptors (in hex):
Oct 21 14:11:07 localhost kernel: 72 01 04 1d 00 00 00 0e 09 0c 00 00 00 00 00 00
Oct 21 14:11:07 localhost kernel: 00 4f 00 c2 00 50
Oct 21 14:11:07 localhost kernel: sd 7:0:0:0: [sdc] ASC=0x4 ASCQ=0x1d
Signed-off-by: Luben Tuikov <ltuikov@yahoo.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
