commit c927b080c67e3e97193c81fc1d27f4251bf4e036 upstream.
In AES-ECB mode crypt is done with key only, so any use of IV
can cause kernel Oops. Use IV only in AES-CBC and AES-CTR.
Signed-off-by: Kamil Konieczny <k.konieczny@partner.samsung.com>
Reported-by: Anand Moon <linux.amoon@gmail.com>
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
Tested-by: Anand Moon <linux.amoon@gmail.com>
Cc: stable@vger.kernel.org # can be applied after commit 8f9702aad138
On linux-4.4 and linux-4.9 we get a warning about an array that is
never initialized when CONFIG_REGULATOR is disabled:
drivers/usb/phy/phy-msm-usb.c: In function 'msm_otg_probe':
drivers/usb/phy/phy-msm-usb.c:1911:14: error: 'regs[0].consumer' may be used uninitialized in this function [-Werror=maybe-uninitialized]
motg->vddcx = regs[0].consumer;
drivers/usb/phy/phy-msm-usb.c:1912:14: error: 'regs[1].consumer' may be used uninitialized in this function [-Werror=maybe-uninitialized]
motg->v3p3 = regs[1].consumer;
drivers/usb/phy/phy-msm-usb.c:1913:14: error: 'regs[2].consumer' may be used uninitialized in this function [-Werror=maybe-uninitialized]
motg->v1p8 = regs[2].consumer;
This adds a Kconfig dependency for it. In newer kernels, the driver no
longer exists, so this is only needed for stable kernels.
GCC correctly points out an uninitialized variable use when CONFIG_PCI is disabled.
drivers/idle/i7300_idle.c: In function 'i7300_idle_notifier':
include/asm-generic/bug.h:119:5: error: 'got_ctl' may be used uninitialized in this function [-Werror=maybe-uninitialized]
if (unlikely(__ret_warn_once && !__warned)) { \
drivers/idle/i7300_idle.c:415:5: note: 'got_ctl' was declared here
u8 got_ctl;
The driver no longer exists in later kernels, so this patch only appplies to
linux-4.9.y and earlier.
When CONFIG_MTD_CFI is disabled, we get a warning for this spi driver:
include/linux/mtd/cfi.h:76:2: #warning No CONFIG_MTD_CFI_Ix selected. No NOR chip support can work. [-Werror=cpp]
The problem here is a layering violation that was fixed in mainline kernels with
a larger rework in commit 054e532f8f90 ("spi: bcm-qspi: Remove hardcoded settings
and spi-nor.h dependency"). We can't really backport that to stable kernels, so
this just adds a Kconfig dependency to make it either build cleanly or force it
to be disabled.
commit fd94d53e55bd487368dfee9f1af24da78b2bb582 upstream.
Building i915 without backlight support results in a harmless warning
for intel_panel_set_backlight:
drivers/gpu/drm/i915/intel_panel.c:653:13: error: 'intel_panel_set_backlight' defined but not used [-Werror=unused-function]
This moves it into the CONFIG_BACKLIGHT_CLASS_DEVICE section that
its caller is in.
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Link: https://patchwork.freedesktop.org/patch/msgid/20171127151239.1813673-2-arnd@arndb.de
[arnd: manually rebased to 4.9]
commit dbed87a9d3a857a86f602775b5845f5f6d9652b5 upstream.
With CONFIG_RESET_CONTROLLER=n we see the following link error in the
meson gxbb clk driver:
drivers/built-in.o: In function 'gxbb_aoclkc_probe':
drivers/clk/meson/gxbb-aoclk.c:161: undefined reference to 'devm_reset_controller_register'
Fix this by selecting the reset controller subsystem.
Fixes: f8c11f79912d ("clk: meson: Add GXBB AO Clock and Reset controller driver")
Signed-off-by: Tobias Regnery <tobias.regnery@gmail.com>
Acked-by: Neil Armstrong <narmstrong@baylibre.com>
[narmstrong: Added fixes-by tag]
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
commit 27d807180ae0a9e50d90adf9b22573c21be904c2 upstream.
I noticed that this function uses a lot of kernel stack when the
"latent entropy" plugin is enabled:
drivers/isdn/hardware/eicon/message.c: In function 'sig_ind':
drivers/isdn/hardware/eicon/message.c:6113:1: error: the frame size of 1168 bytes is larger than 1152 bytes [-Werror=frame-larger-than=]
We currently don't warn about this, as we raise the warning limit
to 2048 bytes in mainline, but I'd like to lower that limit again
in the future, and this function can easily be changed to be more
efficient and avoid that warning, by making some of its local
variables 'const'.
commit 27430d19a91615245babaa9b216d0807636903a0 upstream.
tw5864_frameinterval_get() only initializes its output when it successfully
identifies the video standard in tw5864_input. We get a warning here because
gcc can't always track the state if initialized warnings across a WARN()
macro, and thinks it might get used incorrectly in tw5864_s_parm:
media/pci/tw5864/tw5864-video.c: In function 'tw5864_s_parm':
media/pci/tw5864/tw5864-video.c:816:38: error: 'time_base.numerator' may be used uninitialized in this function [-Werror=maybe-uninitialized]
media/pci/tw5864/tw5864-video.c:819:31: error: 'time_base.denominator' may be used uninitialized in this function [-Werror=maybe-uninitialized]
Using dev_warn() instead of WARN() avoids the __branch_check__() in
unlikely and lets the compiler see that the initialization is correct.
Acked-by: Andrey Utkin <andrey.utkin@corp.bluecherry.net>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit 190b23b4eb997767afad186bd8c96badceabf39e upstream.
In randconfig builds that select VIDEO_EM28XX_V4L2 and
MEDIA_SUBDRV_AUTOSELECT, but not MEDIA_CAMERA_SUPPORT, we get
a Kconfig warning:
warning: (VIDEO_EM28XX_V4L2) selects VIDEO_MT9V011 which has unmet direct dependencies (MEDIA_SUPPORT && I2C && VIDEO_V4L2 && MEDIA_CAMERA_SUPPORT)
This avoids the warning by making that 'select' conditional on
MEDIA_CAMERA_SUPPORT. Alternatively we could mark EM28XX as
'depends on MEDIA_CAMERA_SUPPORT', but it does not seem to
have any real dependency on that itself.
commit fa6317eedd6341f2144ed1097706d8c34f18b6e4 upstream.
If MEDIA_SUBDRV_AUTOSELECT and VIDEO_GO7007 are both set, we
automatically select VIDEO_OV7640, but that depends on MEDIA_CAMERA_SUPPORT,
so we get a Kconfig warning if that is disabled:
warning: (VIDEO_GO7007) selects VIDEO_OV7640 which has unmet direct dependencies (MEDIA_SUPPORT && I2C && VIDEO_V4L2 && MEDIA_CAMERA_SUPPORT)
This adds another dependency so we don't accidentally select
it when it is unavailable.
commit 3538aa6ecfb2dd727a40f9ebbbf25a0c2afe6226 upstream.
While testing with CONFIG_UBSAN, I got this warning:
drivers/media/i2c/tc358743.c: In function 'tc358743_probe':
drivers/media/i2c/tc358743.c:1930:1: error: the frame size of 2480 bytes is larger than 2048 bytes [-Werror=frame-larger-than=]
The problem is that the i2c_rd8/wr8/rd16/... functions in this driver pass
a pointer to a local variable into a common function, and each call to one
of them adds another variable plus redzone to the stack.
I also noticed that the way this is done is broken on big-endian machines,
as we copy the registers in CPU byte order.
To address both those problems, I'm adding two helper functions for reading
a register of up to 32 bits with correct endianess and change all other
functions to use that instead. Just to be sure we don't get the problem
back with changed optimizations in gcc, I'm also marking the new functions
as 'noinline', although my tests with gcc-7 don't require that.
commit ea4348c8462a20e8b1b6455a7145d2b86f8a49b6 upstream.
Older versions of gcc warn about the tca8418_irq_handler function
as they can't keep track of the variable assignment inside of the
loop when using the -Wmaybe-unintialized flag:
drivers/input/keyboard/tca8418_keypad.c: In function ‘tca8418_irq_handler’:
drivers/input/keyboard/tca8418_keypad.c:172:9: error: ‘reg’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
drivers/input/keyboard/tca8418_keypad.c:165:5: note: ‘reg’ was declared here
This is fixed in gcc-6, but it's possible to rearrange the code
in a way that avoids the warning on older compilers as well.
commit b74c0a9969f25217a5e5bbcac56a11bee16718d3 upstream.
gcc-4.9 notices that the validate_init() function returns unintialized
data when called with a zero 'nr_buffers' argument, when called with the
-Wmaybe-uninitialized flag:
drivers/gpu/drm/nouveau/nouveau_gem.c: In function ‘validate_init.isra.6’:
drivers/gpu/drm/nouveau/nouveau_gem.c:457:5: error: ‘ret’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
However, the only caller of this function always passes a nonzero
argument, and gcc-6 is clever enough to take this into account and
not warn about it any more.
Adding an explicit initialization to -EINVAL here is correct even if
the caller changed, and it avoids the warning on gcc-4.9 as well.
Reviewed-By: Karol Herbst <karolherbst@gmail.com>
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
commit d4c2269b3d5d06a8ea434b1841fbcaec336ed396 upstream.
drivers/block/rbd.c: In function ‘rbd_watch_cb’:
drivers/block/rbd.c:3690:5: error: ‘struct_v’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
drivers/block/rbd.c:3759:5: note: ‘struct_v’ was declared here
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
commit 7e1751001818209b214b8c3df0b3c91fae250ea2 upstream.
The rework of the exynos DRM clock handling introduced
warnings for configurations that have CONFIG_PM disabled:
drivers/gpu/drm/exynos/exynos_hdmi.c:736:13: error: 'hdmi_clk_disable_gates' defined but not used [-Werror=unused-function]
static void hdmi_clk_disable_gates(struct hdmi_context *hdata)
drivers/gpu/drm/exynos/exynos_hdmi.c:717:12: error: 'hdmi_clk_enable_gates' defined but not used [-Werror=unused-function]
static int hdmi_clk_enable_gates(struct hdmi_context *hdata)
The problem is that the PM functions themselves are inside of
an #ifdef, but some functions they call are not.
This patch removes the #ifdef and instead marks the PM functions
as __maybe_unused, which is a more reliable way to get it right.
Link: https://patchwork.kernel.org/patch/8436281/
Fixes: 9be7e9898444 ("drm/exynos/hdmi: clock code re-factoring")
Signed-off-by: Inki Dae <inki.dae@samsung.com>
commit 7fc1503c906f0fac62d3506a6e993e49fb996248 upstream.
On x86, the cw1200 driver produces a rather silly warning about the
possible use of the 'ret' variable without an initialization
presumably after being confused by the architecture specific definition
of WARN_ON:
drivers/net/wireless/st/cw1200/wsm.c: In function ‘wsm_handle_rx’:
drivers/net/wireless/st/cw1200/wsm.c:1457:9: error: ‘ret’ may be used uninitialized in this function [-Werror=maybe-uninitialized]
We have already checked that 'count' is larger than 0 here, so
we know that 'ret' is initialized. Changing the 'for' loop
into do/while also makes this clear to the compiler.
Suggested-by: David Laight <David.Laight@ACULAB.COM>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit 44a5b977128c0ffff0654392b40f4c2ce72a619b upstream.
gcc-7.0.1 now warns about a previously unnoticed access of uninitialized
struct members:
drivers/scsi/advansys.c: In function 'AscMsgOutSDTR':
drivers/scsi/advansys.c:3860:26: error: '*((void *)&sdtr_buf+5)' may be used uninitialized in this function [-Werror=maybe-uninitialized]
((ushort)s_buffer[i + 1] << 8) | s_buffer[i]);
drivers/scsi/advansys.c:3860:26: error: '*((void *)&sdtr_buf+7)' may be used uninitialized in this function [-Werror=maybe-uninitialized]
The code has existed in this exact form at least since v2.6.12, and the
warning seems correct. This uses named initializers to ensure we
initialize all members of the structure.
commit 067fdeb2f391bfa071f741a2b3eb74b8ff3785cd upstream.
Fix build warning that related to PAGE_SIZE. The maximum DMA
length has nothing to do with PAGE_SIZE, just use a fix number
for the definition.
drivers/dma/zx_dma.c: In function 'zx_dma_prep_memcpy':
drivers/dma/zx_dma.c:523:8: warning: division by zero [-Wdiv-by-zero]
drivers/dma/zx_dma.c: In function 'zx_dma_prep_slave_sg':
drivers/dma/zx_dma.c:567:11: warning: division by zero [-Wdiv-by-zero]
Signed-off-by: Jun Nie <jun.nie@linaro.org>
Tested-by: Shawn Guo <shawn.guo@linaro.org>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 68fd77cf8a4b045594231f07e5fc92e1a34c0a9e upstream.
We get a Kconfig warning when selecting this without also enabling
CONFIG_PCI:
warning: (X86_INTEL_LPSS && INTEL_SOC_DTS_IOSF_CORE
&& SND_SST_IPC_ACPI && MMC_SDHCI_ACPI && PUNIT_ATOM_DEBUG)
selects IOSF_MBI which has unmet direct dependencies (PCI)
This adds a new depedency.
Fixes: 3a2419f865a6 ("Thermal: Intel SoC: DTS thermal use common APIs")
Reviewed-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
commit b115bebc07f282067eccc06fd5aa3060ab1426da upstream.
When CONFIG_PM_SLEEP is disabled, we get a warning about unused functions:
drivers/gpio/gpio-xgene.c:155:12: warning: 'xgene_gpio_resume' defined but not used [-Wunused-function]
static int xgene_gpio_resume(struct device *dev)
drivers/gpio/gpio-xgene.c:142:12: warning: 'xgene_gpio_suspend' defined but not used [-Wunused-function]
static int xgene_gpio_suspend(struct device *dev)
The warnings are harmless and can be avoided by simplifying the code and marking
the functions as __maybe_unused.
commit f46e7cd36b5f2ce2bfb567e278a10ca717f85b84 upstream.
The advansys probe function tries to handle both ISA and PCI cases, each
hidden in an #ifdef when unused. This leads to a warning indicating that
when PCI is disabled we could be using uninitialized data:
drivers/scsi/advansys.c: In function advansys_board_found :
drivers/scsi/advansys.c:11036:5: error: ret may be used uninitialized in this function [-Werror=maybe-uninitialized]
drivers/scsi/advansys.c:10928:28: note: ret was declared here
drivers/scsi/advansys.c:11309:8: error: share_irq may be used uninitialized in this function [-Werror=maybe-uninitialized]
drivers/scsi/advansys.c:10928:6: note: share_irq was declared here
This cannot happen in practice because the hardware in question only
exists for PCI, but changing the code to just error out here is better
for consistency and avoids the warning.
Reviewed-by: Hannes Reinecke <hare@suse.com>
commit 484c7bbf2649831714da3a0fa30213977458e9b5 upstream.
When CONFIG_PROC_FS is disabled, we get warnings about unused variables
as remove_proc_entry() evaluates to an empty macro.
drivers/video/fbdev/via/viafbdev.c: In function 'viafb_remove_proc':
drivers/video/fbdev/via/viafbdev.c:1635:4: error: unused variable 'iga2_entry' [-Werror=unused-variable]
drivers/video/fbdev/via/viafbdev.c:1634:4: error: unused variable 'iga1_entry' [-Werror=unused-variable]
These are easy to avoid by using the pointer from the structure.
Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
commit c0bfc549e96231e0ead4424de6e4933fde819d70 upstream.
I ran into a build error when I disabled CONFIG_ACPI and tried to
compile this driver:
drivers/perf/xgene_pmu.c:1242:1: warning: data definition has no type or storage class
MODULE_DEVICE_TABLE(of, xgene_pmu_of_match);
drivers/perf/xgene_pmu.c:1242:1: error: type defaults to 'int' in declaration of 'MODULE_DEVICE_TABLE' [-Werror=implicit-int]
Include module.h for the MODULE_DEVICE_TABLE macro that's
implicitly included through ACPI.
Tested-by: Tai Nguyen <ttnguyen@apm.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit c8bd2ac3b4c6c84c4a7cdceaed626247db698ab2 upstream.
The function musb_run_resume_work is called only when CONFIG_PM is
enabled. So this function should not be defined when CONFIG_PM is
disabled. Otherwise the compiler issues a warning:
drivers/usb/musb/musb_core.c:2057:12: error: ‘musb_run_resume_work’ defined but
static int musb_run_resume_work(struct musb *musb)
Signed-off-by: Jérémy Lefaure <jeremy.lefaure@lse.epita.fr>
Signed-off-by: Bin Liu <b-liu@ti.com>
commit b4aca383f9afb5f84b05de272656e6d4a919d995 upstream.
Fix:
drivers/platform/x86/intel_mid_thermal.c:424:12: warning: ‘mid_thermal_resume’
static int mid_thermal_resume(struct device *dev)
drivers/platform/x86/intel_mid_thermal.c:436:12: warning: ‘mid_thermal_suspend’
static int mid_thermal_suspend(struct device *dev)
which I see during randbuilds here.
Cc: Darren Hart <dvhart@infradead.org>
Cc: platform-driver-x86@vger.kernel.org
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
commit fbc2a294f29e726787a0f5238b27137904f26b81 upstream.
The only usage of function intel_gpio_runtime_idle() is here (in the
same file):
static const struct dev_pm_ops intel_gpio_pm_ops = {
SET_RUNTIME_PM_OPS(NULL, NULL, intel_gpio_runtime_idle)
And when CONFIG_PM is not set, the macro SET_RUNTIME_PM_OPS expands to
nothing, causing the following compiler warning:
drivers/gpio/gpio-intel-mid.c:324:12: warning: ‘intel_gpio_runtime_idle’
static int intel_gpio_runtime_idle(struct device *dev)
Fix it by annotating the function with __maybe_unused.
Signed-off-by: Augusto Mecking Caringi <augustocaringi@gmail.com>
Acked-by: Andy Shevchenko <andy.shevchenko@gmail.com>
commit 42db500a551f97551a901e2258f84a60baf4edfc upstream.
Fix the following warnings:
drivers/pci/host/vmd.c:731:12: warning: ‘vmd_suspend’ defined but not used [-Wunused-function]
static int vmd_suspend(struct device *dev)
drivers/pci/host/vmd.c:739:12: warning: ‘vmd_resume’ defined but not used [-Wunused-function]
static int vmd_resume(struct device *dev)
Signed-off-by: Bjorn Helgaas <helgaas@kernel.org>
Reviewed-by: Keith Busch <keith.busch@intel.com>
commit fbdf0e28d061708cf18ba0f8e0db5360dc9a15b9 upstream.
I got a warning about broken code on ARM64 with 64K pages:
drivers/net/vmxnet3/vmxnet3_drv.c: In function 'vmxnet3_rq_init':
drivers/net/vmxnet3/vmxnet3_drv.c:1679:29: error: large integer implicitly truncated to unsigned type [-Werror=overflow]
rq->buf_info[0][i].len = PAGE_SIZE;
'len' here is a 16-bit integer, so this clearly won't work. I don't think
this driver is used much on anything other than x86, so there is no need
to fix this properly and we can work around it with a Kconfig dependency
to forbid known-broken configurations. qemu in theory supports it on
other architectures too, but presumably only for compatibility with x86
guests that also run on vmware.
CONFIG_PAGE_SIZE_64KB is used on hexagon, mips, sh and tile, the other
symbols are architecture-specific names for the same thing.
commit aa01338c018469274848a973bcbd287ef341937c upstream.
With CONFIG_RESET_CONTROLLER=n we get the following link error in the
sunxi-ng clk driver:
drivers/built-in.o: In function `sunxi_ccu_probe':
mux-core.c:(.text+0x12fe68): undefined reference to 'reset_controller_register'
mux-core.c:(.text+0x12fe68): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol 'reset_controller_register'
Fix this by adding the appropriate select statement.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit ac29fc66855b79c2960c63a4a66952d5b721d698 upstream.
The alternative intel_backlight_device_register() definition apparently
never got used, but I have now run into a case of i915 being compiled
without CONFIG_BACKLIGHT_CLASS_DEVICE, resulting in a number of
identical warnings:
drivers/gpu/drm/i915/intel_drv.h:1739:12: error: 'intel_backlight_device_register' defined but not used [-Werror=unused-function]
This marks the function as 'inline', which was surely the original
intention here.
Fixes: 1ebaa0b9c2d4 ("drm/i915: Move backlight registration to connector registration")
Link: https://patchwork.freedesktop.org/patch/msgid/20171127151239.1813673-1-arnd@arndb.de
(cherry picked from commit 2de2d0b063b08becb2c67a2c338c44e37bdcffee)
Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
commit 87a81dce53b1ea61acaeefa5191a0376a2d1d721 upstream.
Performing the hash of an empty file leads to a kernel Oops
[ 44.504600] Unable to handle kernel paging request for data at address 0x0000000c
[ 44.512819] Faulting instruction address: 0xc02d2be8
[ 44.524088] Oops: Kernel access of bad area, sig: 11 [#1]
[ 44.529171] BE PREEMPT CMPC885
[ 44.532232] CPU: 0 PID: 491 Comm: md5sum Not tainted 4.15.0-rc8-00211-g3a968610b6ea #81
[ 44.540814] NIP: c02d2be8 LR: c02d2984 CTR: 00000000
[ 44.545812] REGS: c6813c90 TRAP: 0300 Not tainted (4.15.0-rc8-00211-g3a968610b6ea)
[ 44.554223] MSR: 00009032 <EE,ME,IR,DR,RI> CR: 48222822 XER: 20000000
[ 44.560855] DAR: 0000000c DSISR: c0000000
[ 44.560855] GPR00: c02d28fc c6813d40 c6828000 c646fa40 00000001 00000001 00000001 00000000
[ 44.560855] GPR08: 0000004c 00000000 c000bfcc 00000000 28222822 100280d4 00000000 10020008
[ 44.560855] GPR16: 00000000 00000020 00000000 00000000 10024008 00000000 c646f9f0 c6179a10
[ 44.560855] GPR24: 00000000 00000001 c62f0018 c6179a10 00000000 c6367a30 c62f0000 c646f9c0
[ 44.598542] NIP [c02d2be8] ahash_process_req+0x448/0x700
[ 44.603751] LR [c02d2984] ahash_process_req+0x1e4/0x700
[ 44.608868] Call Trace:
[ 44.611329] [c6813d40] [c02d28fc] ahash_process_req+0x15c/0x700 (unreliable)
[ 44.618302] [c6813d90] [c02060c4] hash_recvmsg+0x11c/0x210
[ 44.623716] [c6813db0] [c0331354] ___sys_recvmsg+0x98/0x138
[ 44.629226] [c6813eb0] [c03332c0] __sys_recvmsg+0x40/0x84
[ 44.634562] [c6813f10] [c03336c0] SyS_socketcall+0xb8/0x1d4
[ 44.640073] [c6813f40] [c000d1ac] ret_from_syscall+0x0/0x38
[ 44.645530] Instruction dump:
[ 44.648465] 38c00001 7f63db78 4e800421 7c791b78 54690ffe 0f090000 80ff0190 2f870000
[ 44.656122] 40befe50 2f990001 409e0210 813f01bc <8129000c> b39e003a 7d29c214 913e003c
This patch fixes that Oops by checking if src is NULL.
Fixes: 6a1e8d14156d4 ("crypto: talitos - making mapping helpers more generic")
Cc: <stable@vger.kernel.org>
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
[ Upstream commit 6e266610eb6553cfb7e7eb5d11914bd01509c406 ]
The driver may sleep under a spinlock.
The function call path is:
rr_close (acquire the spinlock)
free_irq --> may sleep
To fix it, free_irq is moved to the place without holding the spinlock.
This bug is found by my static analysis tool(DSAC) and checked by my code review.
Signed-off-by: Jia-Ju Bai <baijiaju1990@163.com>
[ Upstream commit c4f9d9cb2c29ff04c6b4bb09b72802d8aedfc7cb ]
Add a respective dependency.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
[ Upstream commit 68a213d325c23d39f109f4c7c824b906a7d209de ]
This machine reports number of keyboard backlight led levels, instead of
value of the last led level index. Therefore max_brightness properly needs
to be subtracted by 1 to match led max_brightness API.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Reported-by: Gabriel M. Elder <gabriel@tekgnowsys.com>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196913
Signed-off-by: Darren Hart (VMware) <dvhart@infradead.org>
[ Upstream commit ded600ea9fb51a495d2fcd21e90351df876488e8 ]
If of_clk_get() fails, the clean-up of already initialized clocks should be
the same as when clk_prepare_enable() fails. Thus a clk_disable_unprepare()
for each clock should be called before the clk_put().
Found by Linux Driver Verification project (linuxtesting.org).
Fixes: 16adc674d0d6 ("usb: dwc3: ep0: fix setup_packet_pending initialization")
Signed-off-by: Andreas Platschek <andreas.platschek@opentech.at>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit 8722e095f5a44d0e409e45c5ddc2ee9cf589c777 ]
DWC3_DEPCMD_ENDTRANSFER has been witnessed to require around 600 iterations
before controller would become idle again after unplugging the USB cable
with AIO reads submitted.
Bump timeout from 500 iterations to 1000 so dwc3_stop_active_transfer does
not receive -ETIMEDOUT and does not WARN:
[ 81.326273] ------------[ cut here ]------------
[ 81.335341] WARNING: CPU: 0 PID: 1874 at drivers/usb/dwc3/gadget.c:2627 dwc3_stop_active_transfer.constprop.23+0x69/0xc0 [dwc3]
[ 81.347094] Modules linked in: usb_f_fs libcomposite configfs bnep btsdio bluetooth ecdh_generic brcmfmac brcmutil dwc3 intel_powerclamp coretemp ulpi kvm_intel udc_core kvm irqbypass crc32_pclmul crc32c_intel pcbc dwc3_pci aesni_intel aes_i586 crypto_simd cryptd ehci_pci ehci_hcd basincove_gpadc industrialio gpio_keys usbcore usb_common
[ 81.378142] CPU: 0 PID: 1874 Comm: irq/34-dwc3 Not tainted 4.14.0-edison+ #119
[ 81.385545] Hardware name: Intel Corporation Merrifield/BODEGA BAY, BIOS 542 2015.01.21:18.19.48
[ 81.394548] task: f5b1be00 task.stack: f420a000
[ 81.399219] EIP: dwc3_stop_active_transfer.constprop.23+0x69/0xc0 [dwc3]
[ 81.406086] EFLAGS: 00010086 CPU: 0
[ 81.409672] EAX: 0000001f EBX: f5729800 ECX: c132a2a2 EDX: 00000000
[ 81.416096] ESI: f4054014 EDI: f41cf400 EBP: f420be10 ESP: f420bdf4
[ 81.422521] DS: 007b ES: 007b FS: 00d8 GS: 0000 SS: 0068
[ 81.428061] CR0: 80050033 CR2: b7a3f000 CR3: 01d94000 CR4: 001006d0
[ 81.434483] Call Trace:
[ 81.437063] __dwc3_gadget_ep_disable+0xa3/0x2b0 [dwc3]
[ 81.442438] ? _raw_spin_lock_irqsave+0x32/0x40
[ 81.447135] dwc3_gadget_ep_disable+0xbf/0xe0 [dwc3]
[ 81.452269] usb_ep_disable+0x1c/0xd0 [udc_core]
[ 81.457048] ffs_func_eps_disable.isra.15+0x3b/0x90 [usb_f_fs]
[ 81.463070] ffs_func_set_alt+0x7d/0x310 [usb_f_fs]
[ 81.468132] ffs_func_disable+0x14/0x20 [usb_f_fs]
[ 81.473075] reset_config+0x5b/0x90 [libcomposite]
[ 81.478023] composite_disconnect+0x2b/0x50 [libcomposite]
[ 81.483685] dwc3_disconnect_gadget+0x39/0x50 [dwc3]
[ 81.488808] dwc3_gadget_disconnect_interrupt+0x21b/0x250 [dwc3]
[ 81.495014] dwc3_thread_interrupt+0x2a8/0xf70 [dwc3]
[ 81.500219] ? __schedule+0x78c/0x7e0
[ 81.504027] irq_thread_fn+0x18/0x30
[ 81.507715] ? irq_thread+0xb7/0x180
[ 81.511400] irq_thread+0x111/0x180
[ 81.515000] ? irq_finalize_oneshot+0xe0/0xe0
[ 81.519490] ? wake_threads_waitq+0x30/0x30
[ 81.523806] kthread+0x107/0x110
[ 81.527131] ? disable_percpu_irq+0x50/0x50
[ 81.531439] ? kthread_stop+0x150/0x150
[ 81.535397] ret_from_fork+0x19/0x24
[ 81.539136] Code: 89 d8 c7 45 ec 00 00 00 00 c7 45 f0 00 00 00 00 c7 45 f4 00 00 00 00 e8 56 ef ff ff 85 c0 74 12 50 68 b9 1c 14 f8 e8 64 0f f7 c8 <0f> ff 58 5a 8d 76 00 8b 83 98 00 00 00 c6 83 a0 00 00 00 00 83
[ 81.559295] ---[ end trace f3133eec81a473b8 ]---
Number of iterations measured on 4 consecutive unplugs:
[ 1088.799777] dwc3_send_gadget_ep_cmd(cmd=331016, params={0, 0, 0}) iterated 605 times
[ 1222.024986] dwc3_send_gadget_ep_cmd(cmd=331016, params={0, 0, 0}) iterated 580 times
[ 1317.590452] dwc3_send_gadget_ep_cmd(cmd=331016, params={0, 0, 0}) iterated 598 times
[ 1453.218314] dwc3_send_gadget_ep_cmd(cmd=331016, params={0, 0, 0}) iterated 594 times
Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com>
[ Upstream commit eb9436966fdc84cebdf222952a99898ab46d9bb0 ]
in error path of jz4740_dma_probe(), call clk_disable_unprepare() to clean
up.
Fixes: 25ce6c35fea0 MIPS: jz4740: Remove custom DMA API
Signed-off-by: Tobias Jordan <Tobias.Jordan@elektrobit.com>
[ Upstream commit 33cd3c07a976e11c3c4cc6b0b3db6760ad1590c5 ]
Fix the leak of the CRTC structure in the failure paths of
armada_drm_crtc_create().
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
[ Upstream commit c810daba0ab5226084a56893a789af427a801146 ]
mclk and hclk need to be disabled. Since pm_runtime_disable does
not disable the clocks, use pm_runtime_force_suspend instead.
Signed-off-by: Takuo Koguchi <takuo.koguchi.sw@hitachi.com>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
atc_prep_dma_interleaved
[ Upstream commit 62a277d43d47e74972de44d33bd3763e31992414 ]
_xt_ is being dereferenced before it is null checked, hence there is a
potential null pointer dereference.
Fix this by moving the pointer dereference after _xt_ has been null
checked.
This issue was detected with the help of Coccinelle.
Fixes: 4483320e241c ("dmaengine: Use Pointer xt after NULL check.")
Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com>
Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com>
[ Upstream commit 5c9afbda911ce20b3f2181d1e440a0222e1027dd ]
If the last test in 'ioat_dma_self_test()' fails, we must release all
the allocated resources and not just part of them.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Acked-by: Dave Jiang <dave.jiang@intel.com>
[ Upstream commit b6b5e8a691185606dfffff3198c89e3b4fd9d4f6 ]
This controller does not support EEE, but it may connect to a PHY
which supports EEE and advertises EEE by default, while its link
partner also advertises EEE. If this happens, the PHY enters low
power mode when the traffic rate is low and causes packet loss.
This patch disables EEE advertisement by default for any PHY that
gianfar connects to, to prevent the above unwanted outcome.
Signed-off-by: Shaohui Xie <Shaohui.Xie@nxp.com>
Tested-by: Yangbo Lu <Yangbo.lu@nxp.com>
Signed-off-by: Claudiu Manoil <claudiu.manoil@nxp.com>
Reviewed-by: Andrew Lunn <andrew@lunn.ch>
[ Upstream commit e46772a6946a7d1f3fbbc1415871851d6651f1d4 ]
If clk_set_rate() fails, we should disable clk before return.
Signed-off-by: Branislav Radocaj <branislav@radocaj.org>
[ Upstream commit 51ef7925e10688c57186d438e784532e063492e4 ]
When I run make W=1 on gcc (Debian 7.2.0-16) 7.2.0 I got an error for
the first run, all next ones are okay.
CC [M] drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.o
drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.c:2078: error: Cannot parse struct or union!
scripts/Makefile.build:310: recipe for target 'drivers/net/wireless/broadcom/brcm80211/brcmfmac/sdio.o' failed
Seems like something happened with W=1 and wrong kernel doc format.
As a quick fix remove dubious /** in the code.
Acked-by: Arend van Spriel <arend.vanspriel@broadcom.com>
[ Upstream commit 58117672943734715bbe7565ac9f062effa524f0 ]
According to LS1021A RM, the value of PAL can be set so that the start of the
IP header in the receive data buffer is aligned to a 32-bit boundary. Normally,
setting PAL = 2 provides minimal padding to ensure such alignment of the IP
header.
However every incoming packet's 8-byte time stamp will be inserted into the
packet data buffer as padding alignment bytes when hardware time stamping is
enabled.
So we set the padding 8+2 here to avoid the flooded alignment faults:
root@128:~# cat /proc/cpu/alignment
User: 0
System: 17539 (inet_gro_receive+0x114/0x2c0)
Skipped: 0
Half: 0
Word: 0
DWord: 0
Multi: 17539
User faults: 2 (fixup)
Also shown when exception report enablement
CPU: 0 PID: 161 Comm: irq/66-eth1_g0_ Not tainted 4.1.21-rt13-WR8.0.0.0_preempt-rt #16
Hardware name: Freescale LS1021A
[<8001b420>] (unwind_backtrace) from [<8001476c>] (show_stack+0x20/0x24)
[<8001476c>] (show_stack) from [<807cfb48>] (dump_stack+0x94/0xac)
[<807cfb48>] (dump_stack) from [<80025d70>] (do_alignment+0x720/0x958)
[<80025d70>] (do_alignment) from [<80009224>] (do_DataAbort+0x40/0xbc)
[<80009224>] (do_DataAbort) from [<80015398>] (__dabt_svc+0x38/0x60)
Exception stack(0x86ad1cc0 to 0x86ad1d08)
1cc0: f9b3e080 86b3d072 2d78d287 00000000 866816c0 86b3d05e 86e785d0 00000000
1ce0: 00000011 0000000e 80840ab0 86ad1d3c 86ad1d08 86ad1d08 806d7fc0 806d806c
1d00: 40070013 ffffffff
[<80015398>] (__dabt_svc) from [<806d806c>] (inet_gro_receive+0x114/0x2c0)
[<806d806c>] (inet_gro_receive) from [<80660eec>] (dev_gro_receive+0x21c/0x3c0)
[<80660eec>] (dev_gro_receive) from [<8066133c>] (napi_gro_receive+0x44/0x17c)
[<8066133c>] (napi_gro_receive) from [<804f0538>] (gfar_clean_rx_ring+0x39c/0x7d4)
[<804f0538>] (gfar_clean_rx_ring) from [<804f0bf4>] (gfar_poll_rx_sq+0x58/0xe0)
[<804f0bf4>] (gfar_poll_rx_sq) from [<80660b10>] (net_rx_action+0x27c/0x43c)
[<80660b10>] (net_rx_action) from [<80033638>] (do_current_softirqs+0x1e0/0x3dc)
[<80033638>] (do_current_softirqs) from [<800338c4>] (__local_bh_enable+0x90/0xa8)
[<800338c4>] (__local_bh_enable) from [<8008025c>] (irq_forced_thread_fn+0x70/0x84)
[<8008025c>] (irq_forced_thread_fn) from [<800805e8>] (irq_thread+0x16c/0x244)
[<800805e8>] (irq_thread) from [<8004e490>] (kthread+0xe8/0x104)
[<8004e490>] (kthread) from [<8000fda8>] (ret_from_fork+0x14/0x2c)
Signed-off-by: Zumeng Chen <zumeng.chen@gmail.com>
[ Upstream commit da340f921d3454f1521671c7a5a43ad3331fbe50 ]
Prevent that a prefix flag is set based on invalid configuration data.
The validity.verify_base flag should only be set for alias devices.
Usually the unit address type is either one of base, PAV alias or
HyperPAV alias. But in cases where the unit address type is not set or
any other value the validity.verify_base flag might be set as well.
This would lead to follow on errors.
Explicitly check for alias devices and set the validity flag only for
them.
Signed-off-by: Stefan Haberland <sth@linux.vnet.ibm.com>
Reviewed-by: Jan Hoeppner <hoeppner@linux.vnet.ibm.com>
[ Upstream commit a98a4ebc8c61d20f0150d6be66e0e65223a347af ]
Current codes don't use skb->mark to assign flowi4_mark, it would
make the policy route rule with fwmark doesn't work as expected.
Signed-off-by: Gao Feng <gfree.wind@vip.163.com>
[ Upstream commit 23a9cd2ad90543e9da3786878d2b2729c095439d ]
This patch limits the initial value for PSN to 24 bits as
spec requires.
Signed-off-by: Moni Shoua <monis@mellanox.com>
Signed-off-by: Mukesh Kacker <mukesh.kacker@oracle.com>
Signed-off-by: Daniel Jurgens <danielj@mellanox.com>
Reviewed-by: Parav Pandit <parav@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit a283cdc4d3670700182c820b59078387f9a01a30 ]
The ARP table entry indexes are aliased to 12bits
instead of the intended 16bits when uploaded to
the QP Context. This will present an issue when the
number of connections exceeds 4096 as ARP entries are
reused. Fix this by adjusting the mask to account for
the full 16bits.
Fixes: 4e9042e647ff ("i40iw: add hw and utils files")
Signed-off-by: Mustafa Ismail <mustafa.ismail@intel.com>
Signed-off-by: Shiraz Saleem <shiraz.saleem@intel.com>
[ Upstream commit 7c5c2c2d18d778e51fd8b899965097168306031c ]
To use pin PF4 as the RX signal of UART0, we have to write 0b011 into
the respective pin controller register.
Fix the wrong value we had in our table so far.
Fixes: 96851d391d02 ("drivers: pinctrl: add driver for Allwinner A64 SoC")
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Chen-Yu Tsai <wens@csie.org>
