Add support for the ad7091r 12 bit ADC to the ad7476 driver. Although the
ad7091r is not really related to any of the other devices supported by this
driver, luckily for us there are not so many ways (which are not totally insane)
how sampling a single channel ADC via SPI can be implemented and support for the
ad7091r can be added to the driver with just a few adjustments.
The ad7091r requires an external "conversion start" pulse to start a sample
conversion. After the conversion has finished the result can be read via SPI. We
depend on a IIO trigger to generate this signal, as a result only sampling in
buffered mode and not in manual mode is available.
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Some converters require an external signal to start the conversion. This patch
adds support to the bfintmr trigger driver to generate such a signal.
This patch hooks up the set_trigger_state callback for the blackfin timer
trigger driver and only enables the timer when a trigger consumer requests it to
be enabled. There really is no reason to keep the timer running and generate
interrupts if nobody is listening to them.
If the timer frequency has not been configured yet get_gptimer_period() will
return 0. Handle this case instead of blindly dividing by the returned value.
Use the iio_read_channel_processed function to read the sample value in the
proper unit instead of using iio_read_channel_raw and iio_read_channel_scale and
doing the unit conversion manually.
Add a function to read a processed value from a channel. The function will first
attempt to read the IIO_CHAN_INFO_PROCESSED attribute. If that fails it will
read the IIO_CHAN_INFO_RAW attribute and convert the result from a raw value to
a processed value.
The patch also introduces a function to convert raw value to a processed value
and exports it, in case a user needs or wants to do the conversion by itself.
This patch adds support for the AD5755, AD5755-1, AD5757, AD5735, AD5737 16 and
14 bit quad-channel DACs. The AD5757/AD5737 only have current outputs, but
for the AD5755/AD5757 each of the outputs can be configured to either be a
voltage or a current output. We only allow to configure this at device probe
time since usually this needs to match the external circuitry and should not be
changed on the fly.
A few trivial formatting changes on merge.
The datasheet name is defined in the IIO driver.
On the other hand, the adc_channel_label is configured in
the platform side.
If the datasheet name is not matched with any adc_channel_label,
the iio_channel_get() should be returned as error for preventing
invalid channel data access.
This can be handled either way.
(a) checking null data when using it : in the xxx_read_raw()
or
(b) error returns when the channel is requested : this patch
The IIO consumer can't use the channel with invalid channel spec.
Therefore case (b) is more reasonable.
Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com>
Use kzalloc() rather than kmalloc() for initializing the iio_channel structure.
This patch enables the iio_dev and iio_chan_spec are set to NULL.
This may prevent the page fault problem because the pointer of iio_chan_spec
is initialized as NULL.
The iio_chan_spec is updated only in case that the IIO map has
specific channel label.
When the map has no ADC channel label, then the value of iio_chan_spec
remains as invalid pointer.
To prevent this problem, the pointer should be initialized as NULL.
Currently IIO uses a decimal fixed point representations for real type numbers.
This patch introduces a new representation for rational type numbers. The number
will be expressed by specifying a numerator and denominator. For converting a
raw value to a processed value multiply it by the numerator and divide it by the
denominator.
The reasoning for introducing this new type is that for a lot of devices the
scale can be represented easily by a fractional number, but it is not possible
to represent it as fixed point number without rounding. E.g. for a simple DAC
the scale is often the reference voltage divided by the number of possible
values (Usually 2**n_bits - 1). Each driver currently implements the conversion
of this fraction to a fixed point number on its own.
Also when it comes to the in-kernel interface this allows to directly use the
fractional factors to convert a raw value to a processed value. This should on
one hand require less instructions and on the other hand increase the
precision.
This commit- 314be14bb renamed the _st_ functions to loose the bit
that was meant for staging version but forgot to change
the documentation which still have _st_ sprinkled in some of the
places.
Signed-off-by: anish kumar <anish198519851985@gmail.com>
The ad7276/ad7277/ad7278 are similar to the ad7476/ad7477/ad7478 but have the
same number of leading zeros as the ad7940. The ad7273/ad7274 have a extra pin
for VREF where as for the ad7276/ad7277/ad7278 VREF is taken from VDD, but
otherwise they are compatible to the ad7276/ad7277.
The AD7940 is a single channel 14 bit ADC similar to the ADCs already supported
by the ad7476 driver, but it does have a different shift factor.
The ad7910/ad7920 are software compatible to the ad7467/ad7466.
The ad7476 driver is a driver for simple single channel ADCs. The driver does
not export any experimental or custom ABI files nor do the static code check
tools report any issues, so move the driver out of staging.
After the recent cleanups the buffer support is just a single 23 line function.
This does not really justify a file on its own, so move it to the main driver
file. And with only one source file left the header file containing the device
state struct becomes superflousious so move the content of the header
file to the main driver source file as well.
Slightly rework the reference voltage handling for the ad7476 driver. Now the only
way to specify a external reference voltage is to use the regulator API,
previously it was possible to use either platform_data or the regulator API. The
new way is more consistent with what other drivers do.
Also do not ignore errors when requesting the regulator, since this will cope
very poorly with e.g. deferred probing.
The ad7476 driver has only support for 1 channel ADCs. So the upper limit for
the buffer size is the size of one sample plus the size of the timestamp.
Preallocate a buffer large enough to hold this to avoid having to allocate and
free a new buffer for each sample being captured.
Some of the parts supported by this driver are software compatible. The
difference between them is only in the operating voltage range. So we do not
need extra chip info entries for them.
The datasheet is a bit confusing about this. It says that a dataword has 4
leading zeros, but the first zero is already put on the bus when CS is pulled
low and the second zero is put on the bus on the first leading edge of SCLK, so
when the first bit is sampled on the first trailing edge it will sample what the
datasheet refers to as the second leading zero. Subsequently we only see 3
leading zeros in the 16 bit dataword and the result we get is shifted to the
left by one bit. Fix this by adjusting the channel shift by 1.
Signed-off-by: Jens Taprogge <jens.taprogge@taprogge.org>
Signed-off-by: Samuel Iglesias Gonsalvez <siglesias@igalia.com>
With the latest patches, the TODO file was outdated.
The RX FIFO has a size of 3 characters. Check if when we are picking the
oldest one, we have more to read.
Use tty_dev->dev's drdata to associate struct ipocal_channel to the
respective tty_struct.
Make use of dev_set_drvdata() and dev_get_drvdata() to store and obtain
a pointer to the ipoctal struct corresponding to a struct dev.
Previously we relied on a private list of devices.
tpci200_request_irq()
Now, all the interrupt related functions are next to each other.
Rename __tpci_request_irq() to tpci_enable_irq() and __tpci_free_irq()
to tpci_disable_irq(). Change their second argument, move them above
tpci200_interrupt(), and use tpci_disable_irq() in the latter
tpci200_interrupt()
Minor cleanup. No functional changes.
Previously the return value from tpci200_interrupt was not quite correct
if a slot had caused an interrupt but no handler was instellalled:
IRQ_NONE was returned. However in this case we react to the interrupt
by disabling the IPack device interrupt.
Basically there are two cases the code now distinguishes:
- The tpci200 has raised an interrupt. We handle it and return
IRQ_HANDLED.
- Our device did not raise an interrupt. We return IRQ_NONE.
Some of the device registers are accessed from both interrupt and
non-interrupt context. To ensure proper read-modify-write modification
of these registers we can not use the "global" tpci200 mutex. Instead
a spin-lock is used.
In tpci200_request_irq as well as tpci200_free_irq we set and unset the
pointer to struct slot_irq. This pointer is accessed in
tpci200_interrupt. To ensure that the pointer is not freed after it has
been fetched in tpci200_interrupt() it is now protected through RCU.
ipoctal_write_tty and ipoctal_write are merged.
Split the IRQ service routing in TX part and RX part.
This way interrupt handling becomes independent of the channel number.
Each tty's driver_data is now pointing to the channel it is talking to. struct
ipoctal_channel contains all the information the callbacks require to do their
work.
By moving everything channel related into a separate struct we will be
able to clean up a lot of code. In the end tty->driver_data will no
longer need to point to ipoctal but instead can point to the respective
channel.
This also removes a possible bug in the unhandles_ints part when
slots[i] is not set.
tpci200_{request,free}_irq.
Use the __tpci200_{set,clear}_mask routines to access control
register. Do not overwrite flags unrelated to interrupt handling.
Convert tpci200_set_clockrate and tpci200_interrupt.
gdm_usb.* coding style clean up.
Signed-off-by: Macpaul Lin <macpaul@gmail.com>
Cc: Paul Stewart <pstew@chromium.org>
Cc: Ben Chan <benchan@chromium.org>
Cc: Sage Ahn <syahn@gctsemi.com>
Add a sanity check for the video RAM size. It should fit into the
PCI window.
Signed-off-by: Aaro Koskinen <aaro.koskinen@iki.fi>
It's possible to select video mode that exceeds the available video
memory. This is potentially dangerous, fix by adding a check.
The patch fixes system hangs seen occasionally when playing random videos
with mplayer.
We don't need these to be world writable or group writable.
Cc: Daniel Cotey <puff65537@bansheeslibrary.com>
Remove useless kfree() and clean up code related to the removal.
The semantic patch that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
position p1,p2;
expression x;
if (x@p1 == NULL) { ... kfree@p2(x); ... return ...; }
@unchanged exists@
position r.p1,r.p2;
expression e <= r.x,x,e1;
iterator I;
statement S;
if (x@p1 == NULL) { ... when != I(x,...) S
when != e = e1
when != e += e1
when != e -= e1
when != ++e
when != --e
when != e++
when != e--
when != &e
@ok depends on unchanged exists@
position any r.p1;
position r.p2;
expression x;
... when != true x@p1 == NULL
kfree@p2(x);
@depends on !ok && unchanged@
position r.p2;
expression x;
*kfree@p2(x);
// </smpl>
Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com>
