commit 93040ae5cc8dcc893eca4a4366dc8415af278edf upstream.
Fixed spelling error in a comment as pointed out by DaveM.
Also refactored existing code a bit to provide placeholders for another ASIC
Bug workaround that will be checked-in soon after this.
Signed-off-by: Somnath Kotur <somnath.kotur@emulex.com>
Cc: Jacek Luczak <difrost.kernel@gmail.com>
[ Upstream commit daf3ec688e057f6060fb9bb0819feac7a8bbf45c ]
TG3_PHY_AUXCTL_SMDSP_ENABLE/DISABLE macros do a blind write to the phy
auxiliary control register and overwrite the EXT_PKT_LEN (bit 14) resulting
in intermittent crc errors on jumbo frames with some link partners. Change
the code to do a read/modify/write.
Signed-off-by: Nithin Nayak Sujir <nsujir@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
[ Upstream commit 9c13cb8bb477a83b9a3c9e5a5478a4e21294a760 ]
When netconsole is enabled, logging messages generated during tg3_open
can result in a null pointer dereference for the uninitialized tg3
status block. Use the irq_sync flag to disable polling in the early
stages. irq_sync is cleared when the driver is enabling interrupts after
all initialization is completed.
[ Upstream commit b9149729ebdcfce63f853aa54a404c6a8f6ebbf3 ]
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Acked-by: Jan Beulich <JBeulich@suse.com>
[ Upstream commit 4cc7c1cb7b11b6f3515bd9075527576a1eecc4aa ]
[ Upstream commit 7d5145d8eb2b9791533ffe4dc003b129b9696c48 ]
Signed-off-by: Matthew Daley <mattjd@gmail.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Ian Campbell <ian.campbell@citrix.com>
[ Upstream commit 48856286b64e4b66ec62b94e504d0b29c1ade664 ]
A buggy or malicious frontend should not be able to confuse netback.
If we spot anything which is not as it should be then shutdown the
device and don't try to continue with the ring in a potentially
hostile state. Well behaved and non-hostile frontends will not be
penalised.
As well as making the existing checks for such errors fatal also add a
new check that ensures that there isn't an insane number of requests
on the ring (i.e. more than would fit in the ring). If the ring
contains garbage then previously is was possible to loop over this
insane number, getting an error each time and therefore not generating
any more pending requests and therefore not exiting the loop in
xen_netbk_tx_build_gops for an externded period.
Also turn various netdev_dbg calls which no precipitate a fatal error
into netdev_err, they are rate limited because the device is shutdown
afterwards.
This fixes at least one known DoS/softlockup of the backend domain.
[ Upstream commit ab54ee80aa7585f9666ff4dd665441d7ce41f1e8 ]
We have conflicting type qualifiers for "freg_t" in s390's ptrace.h and the
iphase atm device driver, which causes the compile error below.
Unfortunately the s390 typedef can't be renamed, since it's a user visible api,
nor can I change the include order in s390 code to avoid the conflict.
So simply rename the iphase typedef to a new name. Fixes this compile error:
In file included from drivers/atm/iphase.c:66:0:
drivers/atm/iphase.h:639:25: error: conflicting type qualifiers for 'freg_t'
In file included from next/arch/s390/include/asm/ptrace.h:9:0,
from next/arch/s390/include/asm/lowcore.h:12,
from next/arch/s390/include/asm/thread_info.h:30,
from include/linux/thread_info.h:54,
from include/linux/preempt.h:9,
from include/linux/spinlock.h:50,
from include/linux/seqlock.h:29,
from include/linux/time.h:5,
from include/linux/stat.h:18,
from include/linux/module.h:10,
from drivers/atm/iphase.c:43:
next/arch/s390/include/uapi/asm/ptrace.h:197:3: note: previous declaration of 'freg_t' was here
Acked-by: chas williams - CONTRACTOR <chas@cmf.nrl.navy.mil>
[ Upstream commit 559bcac35facfed49ab4f408e162971612dcfdf3 ]
1) rhine_tx() should use dev_kfree_skb() not dev_kfree_skb_irq()
2) rhine_slow_event_task's NAPI triggering logic is racey, it
should just hit the interrupt mask register. This is the
same as commit 7dbb491878a2c51d372a8890fa45a8ff80358af1
("r8169: avoid NAPI scheduling delay.") made to fix the same
problem in the r8169 driver. From Francois Romieu.
Reported-by: Jamie Gloudon <jamie.gloudon@gmail.com>
Tested-by: Jamie Gloudon <jamie.gloudon@gmail.com>
[ Upstream commit 794ed393b707f01858f5ebe2ae5eabaf89d00022 ]
Ben Greear reported crashes in ip_rcv_finish() on a stress
test involving many macvlans.
We tracked the bug to a dst use after free. ip_rcv_finish()
was calling dst->input() and got garbage for dst->input value.
It appears the bug is in loopback driver, lacking
a skb_dst_force() before calling netif_rx().
As a result, a non refcounted dst, normally protected by a
RCU read_lock section, was escaping this section and could
be freed before the packet being processed.
[<ffffffff813a3c4d>] loopback_xmit+0x64/0x83
[<ffffffff81477364>] dev_hard_start_xmit+0x26c/0x35e
[<ffffffff8147771a>] dev_queue_xmit+0x2c4/0x37c
[<ffffffff81477456>] ? dev_hard_start_xmit+0x35e/0x35e
[<ffffffff8148cfa6>] ? eth_header+0x28/0xb6
[<ffffffff81480f09>] neigh_resolve_output+0x176/0x1a7
[<ffffffff814ad835>] ip_finish_output2+0x297/0x30d
[<ffffffff814ad6d5>] ? ip_finish_output2+0x137/0x30d
[<ffffffff814ad90e>] ip_finish_output+0x63/0x68
[<ffffffff814ae412>] ip_output+0x61/0x67
[<ffffffff814ab904>] dst_output+0x17/0x1b
[<ffffffff814adb6d>] ip_local_out+0x1e/0x23
[<ffffffff814ae1c4>] ip_queue_xmit+0x315/0x353
[<ffffffff814adeaf>] ? ip_send_unicast_reply+0x2cc/0x2cc
[<ffffffff814c018f>] tcp_transmit_skb+0x7ca/0x80b
[<ffffffff814c3571>] tcp_connect+0x53c/0x587
[<ffffffff810c2f0c>] ? getnstimeofday+0x44/0x7d
[<ffffffff810c2f56>] ? ktime_get_real+0x11/0x3e
[<ffffffff814c6f9b>] tcp_v4_connect+0x3c2/0x431
[<ffffffff814d6913>] __inet_stream_connect+0x84/0x287
[<ffffffff814d6b38>] ? inet_stream_connect+0x22/0x49
[<ffffffff8108d695>] ? _local_bh_enable_ip+0x84/0x9f
[<ffffffff8108d6c8>] ? local_bh_enable+0xd/0x11
[<ffffffff8146763c>] ? lock_sock_nested+0x6e/0x79
[<ffffffff814d6b49>] inet_stream_connect+0x33/0x49
[<ffffffff814632c6>] sys_connect+0x75/0x98
This bug was introduced in linux-2.6.35, in commit
7fee226ad2397b (net: add a noref bit on skb dst)
skb_dst_force() is enforced in dev_queue_xmit() for devices having a
qdisc.
Reported-by: Ben Greear <greearb@candelatech.com>
Tested-by: Ben Greear <greearb@candelatech.com>
[ Upstream commit 5d0feaff230c0abfe4a112e6f09f096ed99e0b2d ]
This was introduced in commit 6dccd16 "r8169: merge with version
6.001.00 of Realtek's r8169 driver". I did not find the version
6.001.00 online, but in 6.002.00 or any later r8169 from Realtek
this hunk is no longer present.
Also commit 05af214 "r8169: fix Ethernet Hangup for RTL8110SC
rev d" claims to have fixed this issue otherwise.
The magic compare mask of 0xfffe000 is dubious as it masks
parts of the Reserved part, and parts of the VLAN tag. But this
does not make much sense as the VLAN tag parts are perfectly
valid there. In matter of fact this seems to be triggered with
any VLAN tagged packet as RxVlanTag bit is matched. I would
suspect 0xfffe0000 was intended to test reserved part only.
Finally, this hunk is evil as it can cause more packets to be
handled than what was NAPI quota causing net/core/dev.c:
net_rx_action(): WARN_ON_ONCE(work > weight) to trigger, and
mess up the NAPI state causing device to hang.
As result, any system using VLANs and having high receive
traffic (so that NAPI poll budget limits rtl_rx) would result
in device hang.
Signed-off-by: Timo Teräs <timo.teras@iki.fi>
Acked-by: Francois Romieu <romieu@fr.zoreil.com>
[ Upstream commit a05948f296ce103989b28a2606e47d2e287c3c89 ]
Christoph Paasch found netxen could trigger a BUG in its dismantle
phase, in netxen_release_tx_buffer(), using full size TSO packets.
cmd_buf->frag_count includes the skb->data part, so the loop must
start at index 1 instead of 0, or else we can make an out
of bound access to cmd_buff->frag_array[MAX_SKB_FRAGS + 2]
Christoph provided the fixes in netxen_map_tx_skb() function.
In case of a dma mapping error, its better to clear the dma fields
so that we don't try to unmap them again in netxen_release_tx_buffer()
Reported-by: Christoph Paasch <christoph.paasch@uclouvain.be>
Tested-by: Christoph Paasch <christoph.paasch@uclouvain.be>
Cc: Sony Chacko <sony.chacko@qlogic.com>
Cc: Rajesh Borundia <rajesh.borundia@qlogic.com>
Signed-off-by: Christoph Paasch <christoph.paasch@uclouvain.be>
[ Upstream commit d721a1752ba544df8d7d36959038b26bc92bdf80 ]
If subtracting 12 from l leaves zero we'd do a zero size allocation,
leading to an oops later when we try to set the NUL terminator.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Tilman Schmidt <tilman@imap.cc>
[ Upstream commit ca4c7b35f75492de7fbf5ee95be07481c348caee ]
The lines
if (mlx4_is_mfunc(dev)) {
nreq = 2;
} else {
which hard code the number of requested msi-x vectors under multi-function
mode to two can be removed completely, since the firmware sets num_eqs and
reserved_eqs appropriately Thus, the code line:
nreq = min_t(int, dev->caps.num_eqs - dev->caps.reserved_eqs, nreq);
is by itself sufficient and correct for all cases. Currently, for mfunc
mode num_eqs = 32 and reserved_eqs = 28, hence four vectors will be enabled.
This triples (one vector is used for the async events and commands EQ) the
horse power provided for processing of incoming packets on netdev RSS scheme,
IO initiators/targets commands processing flows, etc.
Reviewed-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Amir Vadai <amirv@mellanox.com>
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
[ Upstream commit 213815a1e6ae70b9648483b110bc5081795f99e8 ]
Commit 5b4c4d36860e "mlx4_en: Allow communication between functions on
same host" introduced a regression under which a bridge acting as vSwitch
whose uplink is an mlx4 Ethernet device become non-operative in native
(non sriov) mode. This happens since broadcast ARP requests sent by VMs
were loopback-ed by the HW and hence the bridge learned VM source MACs
on both the VM and the uplink ports.
The fix is to place the DMAC in the send WQE only under SRIOV/eSwitch
configuration or when the device is in selftest.
Reviewed-by: Or Gerlitz <ogerlitz@mellanox.com>
Signed-off-by: Yan Burman <yanb@mellanox.com>
[ Upstream commit d6fb3be544b46a7611a3373fcaa62b5b0be01888 ]
The xgmac driver assumes 1 frame per descriptor. If a frame larger than
the descriptor's buffer size is received, the frame will spill over into
the next descriptor. So check for received frames that span more than one
descriptor and discard them. This prevents a crash if we receive erroneous
large packets.
Cc: netdev@vger.kernel.org
commit e0094244e41c4d0c7ad69920681972fc45d8ce34 upstream.
It has been reported that running this driver on some Samsung laptops
with EFI can cause those machines to become bricked as detailed in the
following report,
https://bugs.launchpad.net/ubuntu-cdimage/+bug/1040557
There have also been reports of this driver causing Machine Check
Exceptions on recent EFI-enabled Samsung laptops,
https://bugzilla.kernel.org/show_bug.cgi?id=47121
So disable it if booting from EFI since this driver relies on
grovelling around in the BIOS memory map which isn't going to work.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Cc: Corentin Chary <corentincj@iksaif.net>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Steve Langasek <steve.langasek@canonical.com>
commit 83e68189745ad931c2afd45d8ee3303929233e7f upstream.
Originally 'efi_enabled' indicated whether a kernel was booted from
EFI firmware. Over time its semantics have changed, and it now
indicates whether or not we are booted on an EFI machine with
bit-native firmware, e.g. 64-bit kernel with 64-bit firmware.
The immediate motivation for this patch is the bug report at,
which details how running a platform driver on an EFI machine that is
designed to run under BIOS can cause the machine to become
bricked. Also, the following report,
details how running said driver can also cause Machine Check
Exceptions. Drivers need a new means of detecting whether they're
running on an EFI machine, as sadly the expression,
if (!efi_enabled)
hasn't been a sufficient condition for quite some time.
Users actually want to query 'efi_enabled' for different reasons -
what they really want access to is the list of available EFI
facilities.
For instance, the x86 reboot code needs to know whether it can invoke
the ResetSystem() function provided by the EFI runtime services, while
the ACPI OSL code wants to know whether the EFI config tables were
mapped successfully. There are also checks in some of the platform
driver code to simply see if they're running on an EFI machine (which
would make it a bad idea to do BIOS-y things).
This patch is a prereq for the samsung-laptop fix patch.
Cc: David Airlie <airlied@linux.ie>
Cc: Dave Jiang <dave.jiang@intel.com>
Cc: Olof Johansson <olof@lixom.net>
Cc: Peter Jones <pjones@redhat.com>
Cc: Konrad Rzeszutek Wilk <konrad@kernel.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
commit aded024a12b32fc1ed9a80639681daae2d07ec25 upstream.
Don't access uninitialized work-queue when removing device.
The work queue is initialized only if the device multi-queue.
So don't call cancel_work unless this is a multi-queue device.
This fixes the following panic:
Kernel panic - not syncing: BUG!
Call Trace:
62031b28: [<6026085d>] panic+0x16b/0x2d3
62031b30: [<6004ef5e>] flush_work+0x0/0x1d7
62031b60: [<602606f2>] panic+0x0/0x2d3
62031b68: [<600333b0>] memcpy+0x0/0x140
62031b80: [<6002d58a>] unblock_signals+0x0/0x84
62031ba0: [<602609c5>] printk+0x0/0xa0
62031bd8: [<60264e51>] __mutex_unlock_slowpath+0x13d/0x148
62031c10: [<6004ef5e>] flush_work+0x0/0x1d7
62031c18: [<60050234>] try_to_grab_pending+0x0/0x17e
62031c38: [<6004e984>] get_work_gcwq+0x71/0x8f
62031c48: [<60050539>] __cancel_work_timer+0x5b/0x115
62031c78: [<628acc85>] unplug_port+0x0/0x191 [virtio_console]
62031c98: [<6005061c>] cancel_work_sync+0x12/0x14
62031ca8: [<628ace96>] virtcons_remove+0x80/0x15c [virtio_console]
62031ce8: [<628191de>] virtio_dev_remove+0x1e/0x7e [virtio]
62031d08: [<601cf242>] __device_release_driver+0x75/0xe4
62031d28: [<601cf2dd>] device_release_driver+0x2c/0x40
62031d48: [<601ce0dd>] driver_unbind+0x7d/0xc6
62031d88: [<601cd5d9>] drv_attr_store+0x27/0x29
62031d98: [<60115f61>] sysfs_write_file+0x100/0x14d
62031df8: [<600b737d>] vfs_write+0xcb/0x184
62031e08: [<600b58b8>] filp_close+0x88/0x94
62031e38: [<600b7686>] sys_write+0x59/0x88
62031e88: [<6001ced1>] handle_syscall+0x5d/0x80
62031ea8: [<60030a74>] userspace+0x405/0x531
62031f08: [<600d32cc>] sys_dup+0x0/0x5e
62031f28: [<601b11d6>] strcpy+0x0/0x18
62031f38: [<600be46c>] do_execve+0x10/0x12
62031f48: [<600184c7>] run_init_process+0x43/0x45
62031fd8: [<60019a91>] new_thread_handler+0xba/0xbc
Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com>
commit a5ffbe0a1993a27072742ef7db6cf9839956fce9 upstream.
Kernel commits 41affd5 and 6539306 changed the locking in rtl_lps_leave()
from a spinlock to a mutex by doing the calls indirectly from a work queue
to reduce the time that interrupts were disabled. This change was fine for
most systems; however a scheduling while atomic bug was reported in
https://bugzilla.redhat.com/show_bug.cgi?id=903881. The backtrace indicates
that routine rtl_is_special(), which calls rtl_lps_leave() in three places
was entered in atomic context. These direct calls are replaced by putting a
request on the appropriate work queue.
Reported-and-tested-by: Nathaniel Doherty <ntdoherty@gmail.com>
Cc: Nathaniel Doherty <ntdoherty@gmail.com>
Cc: Stanislaw Gruszka <sgruszka@redhat.com>
commit 0a06ad8e3a1cb5311b7dbafde45410aa1bce9d40 upstream.
In routine _rtl_rx_pre_process(), skb_dequeue() is called to get an skb;
however, the wrong variable name is used in subsequent calls.
Reported-by: Guenter Roeck <linux@roeck-us.net>
commit 58b2939b4d5a030eaec469d29812ab8477ee7e76 upstream.
When the xHCI driver is not available, actively switch the ports to EHCI
mode since some BIOSes leave them in xHCI mode where they would
otherwise appear dead. This was discovered on a Dell Optiplex 7010,
but it's possible other systems could be affected.
This should be backported to kernels as old as 3.0, that contain the
commit 69e848c2090aebba5698a1620604c7dccb448684 "Intel xhci: Support
EHCI/xHCI port switching."
Signed-off-by: David Moore <david.moore@gmail.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 48c3375c5f69b1c2ef3d1051a0009cb9bce0ce24 upstream.
This patch (as1640) fixes a memory leak in xhci-hcd. The urb_priv
data structure isn't always deallocated in the handle_tx_event()
routine for non-control transfers. The patch adds a kfree() call so
that all paths end up freeing the memory properly.
This patch should be backported to kernels as old as 2.6.36, that
contain the commit 8e51adccd4c4b9ffcd509d7f2afce0a906139f75 "USB: xHCI:
Introduce urb_priv structure"
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-and-tested-by: Martin Mokrejs <mmokrejs@fold.natur.cuni.cz>
commit f18f8ed2a9adc41c2d9294b85b6af115829d2af1 upstream.
To calculate the TD size for a particular TRB in an isoc TD, we need
know the endpoint's max packet size. Isochronous endpoints also encode
the number of additional service opportunities in their wMaxPacketSize
field. The TD size calculation did not mask off those bits before using
the field. This resulted in incorrect TD size information for
isochronous TRBs when an URB frame buffer crossed a 64KB boundary.
For example:
- an isoc endpoint has 2 additional service opportunites and
a max packet size of 1020 bytes
- a frame transfer buffer contains 3060 bytes
- one frame buffer crosses a 64KB boundary, and must be split into
one 1276 byte TRB, and one 1784 byte TRB.
The TD size is is the number of packets that remain to be transferred
for a TD after processing all the max packet sized packets in the
current TRB and all previous TRBs.
For this TD, the number of packets to be transferred is (3060 / 1020),
or 3. The first TRB contains 1276 bytes, which means it contains one
full packet, and a 256 byte remainder. After processing all the max
packet-sized packets in the first TRB, the host will have 2 packets left
to transfer.
The old code would calculate the TD size for the first TRB as:
total packet count = DIV_ROUND_UP (TD length / endpoint wMaxPacketSize)
total packet count - (first TRB length / endpoint wMaxPacketSize)
The math should have been:
total packet count = DIV_ROUND_UP (3060 / 1020) = 3
3 - (1276 / 1020) = 2
Since the old code didn't mask off the additional service interval bits
from the wMaxPacketSize field, the math ended up as
total packet count = DIV_ROUND_UP (3060 / 5116) = 1
1 - (1276 / 5116) = 1
Fix this by masking off the number of additional service opportunities
in the wMaxPacketSize field.
This patch should be backported to stable kernels as old as 3.0, that
contain the commit 4da6e6f247a2601ab9f1e63424e4d944ed4124f3 "xhci 1.0:
Update TD size field format." It may not apply well to kernels older
than 3.2 because of commit 29cc88979a8818cd8c5019426e945aed118b400e
"USB: use usb_endpoint_maxp() instead of le16_to_cpu()".
commit 760973d2a74b93eb1697981f7448f0e62767cfc4 upstream.
An isochronous TD is comprised of one isochronous TRB chained to zero or
more normal TRBs. Only the isoc TRB has the TBC and TLBPC fields. The
normal TRBs must set those fields to zeroes. The code was setting the
TBC and TLBPC fields for both isoc and normal TRBs. Fix this.
This should be backported to stable kernels as old as 3.0, that contain
the commit b61d378f2da41c748aba6ca19d77e1e1c02bcea5 " xhci 1.0: Set
transfer burst last packet count field."
commit ba7b5c22d33136a5612ca5ef8d31564dcc501126 upstream.
Fix incorrect bit test that originally showed up in
4ee823b83bc9851743fab756c76b27d6a1e2472b "USB/xHCI: Support
device-initiated USB 3.0 resume."
Use '&' instead of '&&'.
This should be backported to kernels as old as 3.4.
Signed-off-by: Nickolai Zeldovich <nickolai@csail.mit.edu>
new switch command
commit 200e0d994d9d1919b28c87f1a5fb99a8e13b8a0f upstream.
1. Optimize the match rules with new macro for Huawei USB storage devices,
to avoid to load USB storage driver for the modem interface
with Huawei devices.
2. Add to support new switch command for new Huawei USB dongles.
Signed-off-by: fangxiaozhi <huananhu@huawei.com>
commit 07c7be3d87e5cdaf5f94c271c516456364ef286c upstream.
1. Define a new macro for USB storage match rules:
matching with Vendor ID and interface descriptors.
commit 54a3ac0c9e5b7213daa358ce74d154352657353a upstream.
Usb3.0 device defines function remote wakeup which is only for interface
recipient rather than device recipient. This is different with usb2.0 device's
remote wakeup feature which is defined for device recipient. According usb3.0
spec 9.4.5, the function remote wakeup can be modified by the SetFeature()
requests using the FUNCTION_SUSPEND feature selector. This patch is to use
correct way to disable usb3.0 device's function remote wakeup after suspend
error and resuming.
This should be backported to kernels as old as 3.4, that contain the
commit 623bef9e03a60adc623b09673297ca7a1cdfb367 "USB/xhci: Enable remote
wakeup for USB3 devices."
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
commit 3e619d04159be54b3daa0b7036b0ce9e067f4b5d upstream.
This patch (as1654) fixes a very old bug in ehci-hcd, connected with
scheduling of periodic split transfers. The calculations for
full/low-speed bus usage are all carried out after the correction for
bit-stuffing has been applied, but the values in the max_tt_usecs
array assume it hasn't been. The array should allow for allocation of
up to 90% of the bus capacity, which is 900 us, not 780 us.
The symptom caused by this bug is that any isochronous transfer to a
full-speed device with a maxpacket size larger than about 980 bytes is
always rejected with a -ENOSPC error.
commit ee74290b7853db9d5fd64db70e5c175241c59fba upstream.
This patch (as1652) fixes a long-standing bug in ehci-hcd. The driver
relies on status polls to know when to stop port-resume signalling.
It uses the root-hub status timer to schedule these status polls. But
when the driver for the root hub is resumed, the timer is rescheduled
to go off immediately -- before the port is ready. When this happens
the timer does not get re-enabled, which prevents the port resume from
finishing until some other event occurs.
The symptom is that when a new device is plugged in, it doesn't get
recognized or enumerated until lsusb is run or something else happens.
The solution is to re-enable the root-hub status timer after every
status poll while a port resume is in progress.
This bug hasn't surfaced before now because we never used to try to
suspend the root hub in the middle of a port resume (except by
coincidence).
Reported-and-tested-by: Norbert Preining <preining@logic.at>
Tested-by: Ming Lei <ming.lei@canonical.com>
commit 78796ae17eacedcdcaaeb03ba73d2e532a4c8f83 upstream.
Add VID and PID for Telit Gobi QDL device
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
commit d4fa681541aa7bf8570d03426dd7ba663a71c467 upstream.
New device with 3 serial interfaces:
If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend) Sub=ff Prot=ff
If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend) Sub=ff Prot=ff
If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend) Sub=ff Prot=ff
If#= 3 Alt= 0 #EPs= 2 Cls=08(stor) Sub=06 Prot=50
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 03eb466f276ceef9dcf023dc5474db02af68aad9 upstream.
Add PID and special handling for Telit LE920
commit c249f911406efcc7456cb4af79396726bf7b8c57 upstream.
Add PID/VID entries for ELV WS 300 PC II weather station
Signed-off-by: Sven Killig <sven@killig.de>
commit 0ba3b2ccc72b3df5c305d61f59d93ab0f0e87991 upstream.
Add support for Zolix Omni 1509 monochromator custom USB-RS232 converter.
Signed-off-by: Petr Kubánek <petr@kubanek.net>
commit 72fca4a4b32dc778b5b885c3498700e42b610d49 upstream.
Previously the alarm event was not propagated into the RTC subsystem.
By adding a call to rtc_update_irq, this fixes a timeout problem with
the hwclock utility.
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
Cc: Alessandro Zummo <a.zummo@towertech.it>
commit f2d68cf4daa4de97d400d94836b907e35228e54f upstream.
When kzalloc() failed in radeon_user_framebuffer_create(), need to
call object_unreference() to match the object_reference().
Signed-off-by: liu chuansheng <chuansheng.liu@intel.com>
Signed-off-by: xueminsu <xuemin.su@intel.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit fd5d93a0015ce1a7db881382022b2fcdfdc61760 upstream.
If the requested number of DWs on the ring is larger than
the size of the ring itself, return an error.
In testing with large VM updates, we've seen crashes when we
try and allocate more space on the ring than the total size
of the ring without checking.
This prevents the crash but for large VM updates or bo moves
of very large buffers, we will need to break the transaction
down into multiple batches. I have patches to use IBs for
the next kernel.
commit bb588820ef421c6098dca1fec29c3b347f1c8c19 upstream.
Force the crtc mem requests on/off immediately rather
than waiting for the double buffered updates to kick in.
Seems we miss the update in certain conditions. Also
handle the DCE6 case.
Signed-off-by: Christopher Staite <chris@yourdreamnet.co.uk>
commit 9200ee4941a6e5d1ec5df88982243686882dff3f upstream.
vbios says external TMDS while the board is actually
internal TMDS.
fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=60037
commit 674a16f2b4724880d07389abbb95abf320b924aa upstream.
Newer versions of mesa emit this.
commit ed39fadd6df01095378e499fac3674883f16b853 upstream.
Some chips seem to need a little delay after blacking out
the MC before the requests actually stop.
May fix:
https://bugs.freedesktop.org/show_bug.cgi?id=56139
https://bugs.freedesktop.org/show_bug.cgi?id=57567
This is to fix a regression that only affect the stable (not for the mainline)
that the stable commit fdf9d86 was incorrectly placed dev->dev_link_magic check
before the *dev assignment in target_fabric_port_link() due to fuzzy automatically
context adjustment during the back-porting.
Reported-by: Chris Boot <bootc@bootc.net>
Signed-off-by: CAI Qian <caiqian@redhat.com>
commit 9452618e7462181ed9755236803b6719298a13ce upstream.
DMAR support on g4x/gm45 integrated gpus seems to be totally busted.
So don't bother, but instead disable it by default to allow distros to
unconditionally enable DMAR support.
v2: Actually wire up the right quirk entry, spotted by Adam Jackson.
Note that according to intel marketing materials only g45 and gm45
support DMAR/VT-d. So we have reports for all relevant gen4 pci ids by
now. Still, keep all the other gen4 ids in the quirk table in case the
marketing stuff confused me again, which would not be the first time.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=51921
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=538163
Cc: Adam Jackson <ajax@redhat.com>
Cc: stable@vger.kernel.org
Acked-By: David Woodhouse <David.Woodhouse@intel.com>
Tested-by: stathis <stathis@npcglib.org>
Tested-by: Mihai Moldovan <ionic@ionic.de>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Mihai Moldovan <ionic@ionic.de>
commit 8024c4c0b1057d1cd811fc9c3f88f81de9729fcd upstream.
We're testing for ->show but calling ->store().
commit 1adb2e2b5f85023d17eb4f95386a57029df27c88 upstream.
When the next beacon is sent, the ath_buf from the previous run is reused.
If getting a new beacon from mac80211 fails, bf->bf_mpdu is not reset, yet
the skb is freed, leading to a double-free on the next beacon tx attempt,
resulting in a system crash.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
commit a3dc48e82bb146ef11cf75676c8410c1df29b0c4 upstream.
On AR9300 the rx FIFO needs to be empty during reset to ensure that no
further DMA activity is generated, otherwise it might lead to memory
corruption issues.
commit 0981c3b24ef664f5611008a6e6d0622fac6d892b upstream.
SKBs that are allocated in the HTC layer do not have callbacks
registered and hence ended up not being freed, Fix this by freeing
them properly in the TX completion routine.
Reported-by: Larry Finger <Larry.Finger@lwfinger.net>
Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com>
Tested-by: Larry Finger <Larry.Finger@lwfinger.net>
commit a1fe52801a992e590cdaee2fb47a94bac9b5da90 upstream.
On hardware reintialization reference count of
already existing timers would be increased again.
This leads to problems on module unloading.
Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com>
Reviewed-by: Hante Meuleman <meuleman@broadcom.com>
Reviewed-by: Arend van Spriel <arend@broadcom.com>
Signed-off-by: Piotr Haber <phaber@broadcom.com>
Signed-off-by: Arend van Spriel <arend@broadcom.com>
