commit 4877c737283813bdb4bebfa3168c1585f6e3a8ca upstream.
In general the semantics of IPIs are that they are are expected to
continue functioning after dpm_suspend_noirq().
Specifically I have seen a deadlock between the callfunc IPI and the
stop machine used by xen's do_suspend() routine. If one CPU has already
called dpm_suspend_noirq() then there is a window where it can be sent
a callfunc IPI before all the other CPUs have entered stop_cpu().
If this happens then the first CPU ends up spinning in stop_cpu()
waiting for the other to rendezvous in state STOPMACHINE_PREPARE while
the other is spinning in csd_lock_wait().
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: xen-devel@lists.xensource.com
LKML-Reference: <1280398595-29708-4-git-send-email-ian.campbell@citrix.com>
commit 81cbb0b17796d81cbd92defe113cf2a7c7a21fbb upstream.
This patch corrects a problem where gen_nand driver assumed there can be only
one chip and ignored the pdata->chip.nr_chips value.
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
commit 6a8cfcfb0de881735df4031eb5cc99be3d0971e9 upstream.
* preset should be done before sending the reset command
* without this, I get the following error on an i.MX35 :
[ 0.900000] ------------[ cut here ]------------
[ 0.900000] WARNING: at kernel/irq/manage.c:290 __enable_irq+0x4c/0x88()
[ 0.900000] Unbalanced enable for IRQ 33
[ 0.900000] Modules linked in:
[ 0.900000] [<c002ffb8>] (unwind_backtrace+0x0/0xf0) from [<c02f7d0c>] (dump_stack+0x18/0x1c)
[ 0.900000] [<c02f7d0c>] (dump_stack+0x18/0x1c) from [<c0049a44>] (warn_slowpath_common+0x54/0x6c)
[ 0.900000] [<c0049a44>] (warn_slowpath_common+0x54/0x6c) from [<c0049b00>] (warn_slowpath_fmt+0x38/0x40)
[ 0.900000] [<c0049b00>] (warn_slowpath_fmt+0x38/0x40) from [<c008f65c>] (__enable_irq+0x4c/0x88)
[ 0.900000] [<c008f65c>] (__enable_irq+0x4c/0x88) from [<c008fca0>] (enable_irq+0x54/0x98)
[ 0.900000] [<c008fca0>] (enable_irq+0x54/0x98) from [<c021e618>] (wait_op_done+0x40/0x134)
[ 0.900000] [<c021e618>] (wait_op_done+0x40/0x134) from [<c021e808>] (send_cmd+0x30/0x38)
[ 0.900000] [<c021e808>] (send_cmd+0x30/0x38) from [<c021eb8c>] (mxc_nand_command+0x26c/0x328)
[ 0.900000] [<c021eb8c>] (mxc_nand_command+0x26c/0x328) from [<c021aa60>] (nand_scan_ident+0x188/0x6c0)
[ 0.900000] [<c021aa60>] (nand_scan_ident+0x188/0x6c0) from [<c001a9cc>] (mxcnd_probe+0x2b8/0x3d0)
[ 0.900000] [<c001a9cc>] (mxcnd_probe+0x2b8/0x3d0) from [<c01f9e88>] (platform_drv_probe+0x20/0x24)
[ 0.900000] [<c01f9e88>] (platform_drv_probe+0x20/0x24) from [<c01f8c38>] (driver_probe_device+0xb0/0x164)
[ 0.900000] [<c01f8c38>] (driver_probe_device+0xb0/0x164) from [<c01f8d54>] (__driver_attach+0x68/0x8c)
[ 0.900000] [<c01f8d54>] (__driver_attach+0x68/0x8c) from [<c01f8348>] (bus_for_each_dev+0x50/0x84)
[ 0.900000] [<c01f8348>] (bus_for_each_dev+0x50/0x84) from [<c01f8a9c>] (driver_attach+0x20/0x28)
[ 0.900000] [<c01f8a9c>] (driver_attach+0x20/0x28) from [<c01f7c00>] (bus_add_driver+0x144/0x2dc)
[ 0.900000] [<c01f7c00>] (bus_add_driver+0x144/0x2dc) from [<c01f906c>] (driver_register+0xb0/0x13c)
[ 0.900000] [<c01f906c>] (driver_register+0xb0/0x13c) from [<c01fa13c>] (platform_driver_register+0x4c/0x60)
[ 0.900000] [<c01fa13c>] (platform_driver_register+0x4c/0x60) from [<c01fa170>] (platform_driver_probe+0x20/0xa0)
[ 0.900000] [<c01fa170>] (platform_driver_probe+0x20/0xa0) from [<c001a708>] (mxc_nd_init+0x18/0x24)
[ 0.900000] [<c001a708>] (mxc_nd_init+0x18/0x24) from [<c002938c>] (do_one_initcall+0x64/0x1bc)
[ 0.900000] [<c002938c>] (do_one_initcall+0x64/0x1bc) from [<c00084c4>] (kernel_init+0xe8/0x1ac)
[ 0.900000] [<c00084c4>] (kernel_init+0xe8/0x1ac) from [<c002aee8>] (kernel_thread_exit+0x0/0x8)
[ 0.900000] ---[ end trace 8bf72ac6ba089a19 ]---
[ 1.140000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xda (Micron NAND 256MiB 3,3V 8-bit)
Signed-off-by: Eric Bénard <eric@eukrea.com>
commit 0a79f67445de50ca0a8dc1d34f3cc406d89c28b2 upstream.
Device class is ff(vend.) instead of e0(wlcon).
Output from command `usb-devices`:
T: Bus=01 Lev=03 Prnt=03 Port=00 Cnt=01 Dev#= 6 Spd=12 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=01 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=05ac ProdID=8215 Rev=01.82
S: Manufacturer=Apple Inc.
S: Product=Bluetooth USB Host Controller
S: SerialNumber=7C6D62936607
C: #Ifs= 4 Cfg#= 1 Atr=e0 MxPwr=0mA
I: If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=01 Driver=btusb
I: If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
I: If#= 3 Alt= 0 #EPs= 0 Cls=fe(app. ) Sub=01 Prot=00 Driver=(none)
Signed-off-by: Cyril Lacoux <clacoux@ifeelgood.org>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
commit b58af4066d240b18b43f202e07b9ec7461d90b17 upstream.
As David VomLehn points out, it was possible to receive an interrupt
before clearing the free-urb flag which could lead to the urb being
incorrectly marked as busy.
For the same reason, move tx_bytes accounting so that it will never be
negative.
Note that the free-flags set and clear operations do not need any
additional locking as they are manipulated while USB_SERIAL_WRITE_BUSY
is set.
Reported-by: David VomLehn <dvomlehn@cisco.com>
Tested-by: David VomLehn <dvomlehn@cisco.com>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit b3e670443b7fb8a2d29831b62b44a039c283e351 upstream.
This patch fixes a race condition in two utility routines
related to the removal/unlinking of urbs from an anchor.
If two threads are concurrently accessing the same anchor,
both could end up with the same urb - thinking they are
the exclusive owner.
Alan Stern pointed out a related issue in
usb_unlink_anchored_urbs:
"The URB isn't removed from the anchor until it completes
(as a by-product of completion, in fact), which might not
be for quite some time after the unlink call returns.
In the meantime, the subroutine will keep trying to unlink
it, over and over again."
Cc: Oliver Neukum <oneukum@suse.de>
Cc: Greg Kroah-Hartman <greg@kroah.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Christian Lamparter <chunkeey@googlemail.com>
commit e10e1bec8e6654de4591ef45ddd6a6d1e5b2591c upstream.
This patch fixes the warning below:
[30753.755998] ------------[ cut here ]------------
[30753.755998] WARNING: at /home/tom/git/linux-2.6/linux-2.6-next/arch/x86/include/asm/dma-mapping.h:155 hcd_buffer_free+0xb1/0xd4 [usbcore]()
[30753.755998] Hardware name: 6475EK2
[30753.755998] Modules linked in: uvcvideo ehci_hcd usbtest cdc_ether usbnet vfat fat usb_storage nfsd lockd nfs_acl auth_rpcgss exportfs mii tun videodev v4l1_compat v4l2_compat_ioctl32 fuse bridge stp llc sunrpc ipv6 cpufreq_ondemand acpi_cpufreq freq_table mperf kvm_intel kvm arc4 ecb ath5k usbhid mac80211 snd_hda_codec_conexant ch341 usbserial ath cfg80211 thinkpad_acpi snd_hda_intel pcspkr wmi hwmon yenta_socket iTCO_wdt iTCO_vendor_support i2c_i801 e1000e snd_hda_codec snd_hwdep snd_pcm snd_timer snd soundcore snd_page_alloc pata_acpi uhci_hcd ohci_hcd usbcore i915 drm_kms_helper drm i2c_algo_bit i2c_core video output [last unloaded: uvcvideo]
[30753.755998] Pid: 0, comm: swapper Tainted: G W 2.6.35-rc6-gkh-wl+ #49
[30753.755998] Call Trace:
[30753.755998] <IRQ> [<ffffffff8104478a>] warn_slowpath_common+0x80/0x98
[30753.755998] [<ffffffff810447b7>] warn_slowpath_null+0x15/0x17
[30753.755998] [<ffffffffa00ce02d>] hcd_buffer_free+0xb1/0xd4 [usbcore]
[30753.755998] [<ffffffffa00c1345>] usb_free_coherent+0x1c/0x1e [usbcore]
[30753.755998] [<ffffffffa00b13e4>] simple_free_urb+0x23/0x2f [usbtest]
[30753.755998] [<ffffffffa00b210b>] iso_callback+0xbb/0x10f [usbtest]
[30753.755998] [<ffffffffa00c7390>] usb_hcd_giveback_urb+0x8c/0xc0 [usbcore]
[30753.755998] [<ffffffffa0449b35>] ehci_urb_done+0x84/0x95 [ehci_hcd]
[30753.755998] [<ffffffffa044b5a5>] ehci_work+0x41a/0x7dd [ehci_hcd]
[30753.755998] [<ffffffffa044e298>] ehci_irq+0x33b/0x370 [ehci_hcd]
[30753.755998] [<ffffffff8100fb05>] ? sched_clock+0x9/0xd
[30753.755998] [<ffffffff8105e641>] ? sched_clock_local+0x1c/0x82
[30753.755998] [<ffffffff8105e76a>] ? sched_clock_cpu+0xc3/0xce
[30753.755998] [<ffffffff81067c7e>] ? trace_hardirqs_off+0xd/0xf
[30753.755998] [<ffffffff8105e7b8>] ? cpu_clock+0x43/0x5e
[30753.755998] [<ffffffffa00c6999>] usb_hcd_irq+0x45/0xa1 [usbcore]
[30753.755998] [<ffffffff81092e02>] handle_IRQ_event+0x20/0xa5
[30753.755998] [<ffffffff81094cea>] handle_fasteoi_irq+0x92/0xd2
[30753.755998] [<ffffffff8100c0ed>] handle_irq+0x1f/0x2a
[30753.755998] [<ffffffff8100b75d>] do_IRQ+0x57/0xbe
[30753.755998] [<ffffffff8136a693>] ret_from_intr+0x0/0x16
[30753.755998] <EOI> [<ffffffff81223baa>] ? acpi_idle_enter_bm+0x231/0x269
[30753.755998] [<ffffffff81223ba3>] ? acpi_idle_enter_bm+0x22a/0x269
[30753.755998] [<ffffffff812c4b6b>] cpuidle_idle_call+0x99/0xce
[30753.755998] [<ffffffff81008dd5>] cpu_idle+0x61/0xaa
[30753.755998] [<ffffffff8136374b>] start_secondary+0x1c2/0x1c6
[30753.755998] ---[ end trace 904cfaf7ab4cb1a2 ]---
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
commit 356c5a4834a74c621715f7a7f16ded914eecbd3c upstream.
Signed-off-by: Alessio Igor Bogani <abogani@texware.it>
commit b6180ef7c99574c3350bbffa2a3a9d675321543d upstream.
This patch is to add a US Interface, Inc. "Navigator" USB device.
Specifically, it's a HAM Radio USB sound modem that also
incorporates three pairs of unique FTDI serial ports. The standard
Linux FTDI serial driver will only recognize the first two serial
ports of an unknown FDTI derived device and this patch adds in
recognition to these specific new IDs.
Signed-off-by: David A. Ranch <dranch@trinnet.net>
commit 0372a754be9aa43e19fd86c9bc04796d43b55e38 upstream.
This patch adds the product IDs of Huawei's K3765 and K4505 mobile
broadband usb modems to option.c. It also adds a quirk to the option
probe function so that binding to the device's network interface(class
0xff) is avoided. This is necessary to allow another driver to bind to
that, and to avoid programs like wvdial opening a nonfunctioning tty
during modem discovery.
Signed-off-by: Andrew Bird <ajb@spheresystems.co.uk>
commit b972302b0a13aaddc9e90da2b4b52722e5d0e776 upstream.
The patch adds Huawei ETS 1220 product id into the list of supported
devices in 'option' usb serial driver.
Signed-off-by: Pavel Kazlou <p.i.kazlou@gmail.com>
commit afad19648f70c6493193e0a774bd754b7790b4a0 upstream.
I have added the ProductID=0xe729 VendorID=FTDI_VID=0x0403 which will
enable support for the Segway Robotic Mobility Platform (RMP200) in the
ftdi_sio kernel module. Currently, users of the Segway RMP200 must use
a RUN+="/sbin/modprobe -q ftdi-sio product=0xe729 vendor=0x0403 in a
udev rule to get the ftdi_sio module to handle the usb interface and
mount it on /dev/ttyXXX. This is not a good solution because some users
will have multiple USB to Serial converters which will use the ftdi_sio
module.
Signed-off-by: John Rogers <jgrogers@gmail.com>
commit 93362a875fc69881ae69299efaf19a55a1f57db0 upstream.
The Logitech Harmony 700 series needs an extra delay during
initialization. This patch adds a USB quirk which enables such a delay
and adds the device to the quirks list.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
commit 33d973ad88ceb83ed1449592b7574b5b5bb33ac6 upstream.
Enlarging the buffer size via the MON_IOCT_RING_SIZE ioctl causes
general protection faults. It appears the culprit is an incorrect
argument to mon_free_buff: instead of passing the size of the current
buffer being freed, the size of the new buffer is passed.
Use the correct size argument to mon_free_buff when changing the size of
the buffer.
Signed-off-by: Steven Robertson <steven@strobe.cc>
Acked-by: Pete Zaitcev <zaitcev@redhat.com>
commit ae68a83bdc1971cb02fefc7a686ba6d077065e71 upstream.
This patch (as1405) fixes a small bug in ehci-hcd's isochronous
scheduler. Not all EHCI controllers are PCI, and the code shouldn't
assume that they are. Instead, introduce a special flag for
controllers which need to delay iso scheduling for full-speed devices
beyond the scheduling threshold.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Sarah Sharp <sarah.a.sharp@linux.intel.com>
CC: David Brownell <david-b@pacbell.net>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 0936fb5e92a90476959447ad8ae5d780afbbd930 upstream.
DMA_ADDR and DMA_COUNT are 32-bit registers, not 16-bit.
Marking them as 16-bit in the table causes only the lower
16-bits to be dumped and this is misleading.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
Acked-by: Felipe Balbi <felipe.balbi@nokia.com>
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
commit 492c5d943d6a04b124ba3a719dc746dc36b14cfb upstream.
On SMP systems, the SMSC911x registers may be accessed by multiple CPUs
and this seems to put the chip in an inconsistent state. The patch adds
spinlocks to the smsc911x_reg_read, smsc911x_reg_write,
smsc911x_rx_readfifo and smsc911x_tx_writefifo functions.
commit 6710a5760355be8f2e51682f41b0d3fc76550309 upstream.
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
commit 85f4cc17a62c3ac9edeaf120cdae7261df458053 upstream.
commit 556ab45f9a775bfa4762bacc0a4afb5b44b067bc upstream.
On some platforms (MacPro3,1) the BIOS assigns the ioatdma device to the
incorrect iommu causing faults when the driver initializes. Add a quirk
to catch this misconfiguration and try falling back to untranslated
operation (which works in the MacPro3,1 case).
Assuming there are other platforms with misconfigured iommus teach the
ioatdma driver to treat initialization failures as non-fatal (just fail
the driver load and emit a warning instead of triggering a BUG_ON).
This can be classified as a boot regression since 2.6.32 on affected
platforms since the ioatdma module did not autoload prior to that
kernel.
Acked-by: David Woodhouse <David.Woodhouse@intel.com>
Reported-by: Chris Li <lkml@chrisli.org>
Tested-by: Chris Li <lkml@chrisli.org>
commit 2d0bb1c1f4524befe9f0fcf0d0cd3081a451223f upstream.
Based on patches from Sonny Rao and Milton Miller...
Combined the patches to fix up clean_tx_irq and clean_rx_irq.
The PowerPC architecture does not require loads to independent bytes
to be ordered without adding an explicit barrier.
In ixgbe_clean_rx_irq we load the status bit then load the packet data.
With packet split disabled if these loads go out of order we get a
stale packet, but we will notice the bad sequence numbers and drop it.
The problem occurs with packet split enabled where the TCP/IP header
and data are in different descriptors. If the reads go out of order
we may have data that doesn't match the TCP/IP header. Since we use
hardware checksumming this bad data is never verified and it makes it
all the way to the application.
This bug was found during stress testing and adding this barrier has
been shown to fix it. The bug can manifest as a data integrity issue
(bad payload data) or as a BUG in skb_pull().
This was a nasty bug to hunt down, if people agree with the fix I think
it's a candidate for stable.
Previously Submitted to e1000-devel only for ixgbe
http://marc.info/?l=e1000-devel&m=126593062701537&w=3
We've now seen this problem hit with other device drivers (e1000e mostly)
So I'm resubmitting with fixes for other Intel Device Drivers with
similar issues.
CC: Milton Miller <miltonm@bga.com>
CC: Anton Blanchard <anton@samba.org>
CC: Sonny Rao <sonnyrao@us.ibm.com>
commit 51e9ac77035a3dfcb6fc0a88a0d80b6f99b5edb1 upstream.
If the 'bio_split' path in raid10-read is used while
resync/recovery is happening it is possible to deadlock.
Fix this be elevating ->nr_waiting for the duration of both
parts of the split request.
This fixes a bug that has been present since 2.6.22
but has only started manifesting recently for unknown reasons.
It is suitable for and -stable since then.
Reported-by: Justin Bronder <jsbronder@gentoo.org>
Tested-by: Justin Bronder <jsbronder@gentoo.org>
Signed-off-by: NeilBrown <neilb@suse.de>
commit bb4f1e9d0e2ef93de8e36ca0f5f26625fcd70b7d upstream.
Move the deletion of sysfs attributes from reconfig_mutex to
open_mutex didn't really help as a process can try to take
open_mutex while holding reconfig_mutex, so the same deadlock can
happen, just requiring one more process to be involved in the chain.
I looks like I cannot easily use locking to wait for the sysfs
deletion to complete, so don't.
The only things that we cannot do while the deletions are still
pending is other things which can change the sysfs namespace: run,
takeover, stop. Each of these can fail with -EBUSY.
So set a flag while doing a sysfs deletion, and fail run, takeover,
stop if that flag is set.
This is suitable for 2.6.35.x
commit 147e0b6a639ac581ca3bf627bedc3f4a6d3eca66 upstream.
Commit b821eaa5 "md: remove ->changed and related code" moved
revalidate_disk() under open_mutex, and lockdep noticed.
[ INFO: possible circular locking dependency detected ]
2.6.32-mdadm-locking #1
mdadm/3640 is trying to acquire lock:
(&bdev->bd_mutex){+.+.+.}, at: [<ffffffff811acecb>] revalidate_disk+0x5b/0x90
but task is already holding lock:
(&mddev->open_mutex){+.+...}, at: [<ffffffffa055e07a>] do_md_stop+0x4a/0x4d0 [md_mod]
which lock already depends on the new lock.
It is suitable for 2.6.35.x
Reported-by: Przemyslaw Czarnowski <przemyslaw.hawrylewicz.czarnowski@intel.com>
commit 110712828365ccafcc61a7f4db44c31ed4cf8793 upstream.
ide_cd_error_cmd() can complete an erroneous request with leftover
buffers. Signal this with its return value so that the request is not
accessed after its completion in the irq handler and we oops.
Signed-off-by: Borislav Petkov <bp@alien8.de>
commit d9e1b6c45059ccfff647a120769ae86da78dfdc4 upstream.
After the commit that changed ipmi_si detecting sequence from SMBIOS/ACPI
to ACPI/SMBIOS,
| commit 754d453185275951d39792865927ec494fa1ebd8
| Author: Matthew Garrett <mjg@redhat.com>
| Date: Wed May 26 14:43:47 2010 -0700
| ipmi: change device discovery order
| The ipmi spec provides an ordering for si discovery. Change the driver to
| match, with the exception of preferring smbios to SPMI as HPs (at least)
| contain accurate information in the former but not the latter.
ipmi_si can not be initialized.
[ 138.799739] calling init_ipmi_devintf+0x0/0x109 @ 1
[ 138.805050] ipmi device interface
[ 138.818131] initcall init_ipmi_devintf+0x0/0x109 returned 0 after 12797 usecs
[ 138.822998] calling init_ipmi_si+0x0/0xa90 @ 1
[ 138.840276] IPMI System Interface driver.
[ 138.846137] ipmi_si: probing via ACPI
[ 138.849225] ipmi_si 00:09: [io 0x0ca2] regsize 1 spacing 1 irq 0
[ 138.864438] ipmi_si: Adding ACPI-specified kcs state machine
[ 138.870893] ipmi_si: probing via SMBIOS
[ 138.880945] ipmi_si: Adding SMBIOS-specified kcs state machineipmi_si: duplicate interface
[ 138.896511] ipmi_si: probing via SPMI
[ 138.899861] ipmi_si: Adding SPMI-specified kcs state machineipmi_si: duplicate interface
[ 138.917095] ipmi_si: Trying ACPI-specified kcs state machine at i/o address 0xca2, slave address 0x0, irq 0
[ 138.928658] ipmi_si: Interface detection failed
[ 138.953411] initcall init_ipmi_si+0x0/0xa90 returned 0 after 110847 usecs
in smbios has
DMI/SMBIOS
Handle 0x00C5, DMI type 38, 18 bytes
IPMI Device Information
Interface Type: KCS (Keyboard Control Style)
Specification Version: 2.0
I2C Slave Address: 0x00
NV Storage Device: Not Present
Base Address: 0x0000000000000CA2 (I/O)
Register Spacing: 32-bit Boundaries
in DSDT has
Device (BMC)
Name (_HID, EisaId ("IPI0001"))
Method (_STA, 0, NotSerialized)
If (LEqual (OSN, Zero))
Return (Zero)
Return (0x0F)
Name (_STR, Unicode ("IPMI_KCS"))
Name (_UID, Zero)
Name (_CRS, ResourceTemplate ()
IO (Decode16,
0x0CA2, // Range Minimum
0x0CA2, // Range Maximum
0x00, // Alignment
0x01, // Length
IO (Decode16,
0x0CA6, // Range Minimum
0x0CA6, // Range Maximum
0x00, // Alignment
0x01, // Length
Method (_IFT, 0, NotSerialized)
Return (One)
Method (_SRV, 0, NotSerialized)
Return (0x0200)
so the reg spacing should be 4 instead of 1.
Try to calculate regspacing for this kind of system.
Observed on a Sun Fire X4800. Other OSes work and pass certification.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Acked-by: Matthew Garrett <mjg@redhat.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Myron Stowe <myron.stowe@hp.com>
Cc: Corey Minyard <minyard@acm.org>
commit 8f1d2d2be73a98c21e68fe2a26f633892d4abdd1 upstream.
ieee80211_beacon_get can return NULL...
commit e95b743536937a72e1560c85696b425c5d1a1c18 upstream.
The TX tracing code copies with the wrong length,
which will typically copy too little data. Fix
this by using the correct length variable.
commit fa260c00c1aa5c657793a7221e40d2400df5afd8 upstream.
Fix a build failure "error: void value not ignored as it ought to be"
by removing an assignment of a void return value. The functionality of
the code is not changed.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Acked-by: Henrik Kretzschmar <henne@nachtwindheim.de>
commit bf9c1fca9ae9a79ed209e7ab2c10b3862f3f6f72 upstream.
Sorry, one more fix, this one depends on the other, so this is rather 2/2.
tty->driver_data is used all over the code, but never set. This
results in oopses like:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000130
IP: [<ffffffff814a0040>] mutex_lock+0x10/0x40
Pid: 2157, comm: modem-manager Not tainted 2.6.34.1-0.1-desktop #1 2768DR7/2768DR7
RIP: 0010:[<ffffffff814a0040>] [<ffffffff814a0040>] mutex_lock+0x10/0x40
RSP: 0018:ffff88007b16fa50 EFLAGS: 00010286
RAX: 0000000000000000 RBX: 0000000000000130 RCX: 0000000000000003
RDX: 0000000000000003 RSI: 0000000000000286 RDI: 0000000000000130
RBP: 0000000000001000 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000130
R13: 0000000000000001 R14: 0000000000000000 R15: ffff88007b16feb4
Call Trace:
[<ffffffffa077690d>] ntty_write_room+0x4d/0x90 [nozomi]
Set tty->driver_data to the computed port in .install to not recompute it in
every place where needed. Switch .open to use driver_data too.
Cc: Alan Cox <alan@linux.intel.com>
commit ee78bb95b7bea08b7774a02073ea2bb45611a9e1 upstream.
Currently ntty_install omits to increment tty count and we get the
following warnings:
Warning: dev (noz2) tty->count(0) != #fd's(1) in tty_open
So to fix that, add one tty->count++ there.
commit 1f6ea6e511e5ec730d8e88651da1b7b6e8fd1333 upstream.
We were seeing faults in the solos-pci receive tasklet when packets
arrived for a VCC which was currently being closed:
[18842.727906] EIP: [<e082f490>] br2684_push+0x19/0x234 [br2684] SS:ESP 0068:dfb89d14
[18845.090712] [<c13ecff3>] ? do_page_fault+0x0/0x2e1
[18845.120042] [<e082f490>] ? br2684_push+0x19/0x234 [br2684]
[18845.153530] [<e084fa13>] solos_bh+0x28b/0x7c8 [solos_pci]
[18845.186488] [<e084f711>] ? solos_irq+0x2d/0x51 [solos_pci]
[18845.219960] [<c100387b>] ? handle_irq+0x3b/0x48
[18845.247732] [<c10265cb>] ? irq_exit+0x34/0x57
[18845.274437] [<c1025720>] tasklet_action+0x42/0x69
[18845.303247] [<c102643f>] __do_softirq+0x8e/0x129
[18845.331540] [<c10264ff>] do_softirq+0x25/0x2a
[18845.358274] [<c102664c>] _local_bh_enable_ip+0x5e/0x6a
[18845.389677] [<c102666d>] local_bh_enable+0xb/0xe
[18845.417944] [<e08490a8>] ppp_unregister_channel+0x32/0xbb [ppp_generic]
[18845.458193] [<e08731ad>] pppox_unbind_sock+0x18/0x1f [pppox]
This patch uses an RCU-inspired approach to fix it. In the RX tasklet's
find_vcc() function we first refuse to use a VCC which already has the
ATM_VF_READY bit cleared. And in the VCC close function, we synchronise
with the tasklet to ensure that it can't still be using the VCC before
we continue and allow the VCC to be destroyed.
Tested-by: Nathan Williams <nathan@traverse.com.au>
commit 549e15611b4ac1de51ef0e0a79c2704f50a638a2 upstream.
MSI delivery from on-board ahci controller doesn't work on K8M800. At
this point, it's unclear whether the culprit is with the ahci
controller or the host bridge. Given the track record and considering
the rather minimal impact of MSI, disabling it seems reasonable.
Reported-by: Rainer Hurtado Navarro <publio.escipion.el.africano@gmail.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 3d2a531804d16cd8df6dbbb0429c6f143e756049 upstream.
There is no reason to run NVidia-specific quirks related to HT MSI
mappings with MSI disabled via pci=nomsi, so make
__nv_msi_ht_cap_quirk() return immediately in that case.
This allows at least one machine to boot 100% of the time with
pci=nomsi (it still doesn't boot reliably without that).
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=16443 .
commit e847003f00d5eca3e3b3a6a1199f82b51293faf6 upstream.
Signed-off-by: Lytochkin Boris <lytboris@gmail.com>
Tested-by: Lytochkin Boris <lytboris@gmail.com>
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
commit 54d2379c20d814ced657cbc2c4ead8d1f8389fa2 upstream.
LBDAF is not available nor necessary on 64BIT kernel. This patch
fixed the dependency for hv_blkvsc module on 64BIT kernel.
Thanks vrataj2 [vrataj2@comcast.net] for reporting this problem.
Reported-by: vrataj2 <vrataj2@comcast.net>
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
Signed-off-by: Hank Janssen <hjanssen@microsoft.com>
commit 060132ae42cce3f9d2fd34d9a17b98362b44b9f9 upstream.
This patch prevents the code from calling parport_release and
parport_unregister_device twice with the same arguments - and thus fixes an oops.
Rationale:
After the first call the parport is already released and the
handle isn't valid anymore and calling parport_release and
parport_unregister_device twice isn't a good idea.
Acked-by: Willy Tarreau <w@1wt.eu>
commit e928c077e5cdcd72ee762125b37232aec1ff49f3 upstream.
line6 uses snd_pcm*() functions, so it should select SND_PCM.
ERROR: "snd_pcm_period_elapsed" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_set_ops" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_lib_free_pages" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_lib_ioctl" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_lib_malloc_pages" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_hw_constraint_ratdens" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_format_physical_width" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_lib_preallocate_pages_for_all" [drivers/staging/line6/line6usb.ko] undefined!
ERROR: "snd_pcm_new" [drivers/staging/line6/line6usb.ko] undefined!
Cc: Markus Grabner <grabner@icg.tugraz.at>
commit 5d92fe3387d086fc2f10426fbdb6b86d6cce5a47 upstream.
Device missing from current tables.
Tested-by: Rod Huffaker <rod.huffaker@gmail.com>
commit 127c03cdbad9bd5af5d7f33bd31a1015a90cb77f upstream.
NR_IRQS may be as low as 16, causing a (harmless?) buffer overflow in
pcmcia_setup_isa_irq():
static u8 pcmcia_used_irq[NR_IRQS];
if ((try < 32) && pcmcia_used_irq[irq])
continue;
This is read-only, so if this address would be non-zero, it would just
mean we would not attempt an IRQ >= NR_IRQS -- which would fail anyway!
And as request_irq() fails for an irq >= NR_IRQS, the setting code path:
pcmcia_used_irq[irq]++;
is never reached as well.
Reported-by: Christoph Fritz <chf.fritz@googlemail.com>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Signed-off-by: Christoph Fritz <chf.fritz@googlemail.com>
commit 213373cf974fe69e78ec894b07f45ae2f5a3a078 upstream.
SIDPR window registers are shared across ports and as each access is
done in two steps, accesses to different ports under EH may race.
This primarily is caused by incorrect host locking in EH context and
should be fixed by defining locking requirements for each EH operation
which can be used during EH and enforcing them but for now work around
the problem by adding a dedicated SIDPR lock and grabbing it for each
SIDPR access.
Reported-by: Mark Knecht <markknecht@gmail.com>
Reported-by: Paul Check <paul@thechecks.ca>
commit a1efd14a99483a4fb9308902397ed86b69454c99 upstream.
Apparently i830 and i845 cannot handle any stride that is not a multiple
of 256, unlike their brethren which do support 64 byte aligned strides.
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Signed-off-by: Eric Anholt <eric@anholt.net>
commit cda4b7d3a5b1dcbc0d8e7bad52134347798e9047 upstream.
The docs warn that to position the cursor such that no part of it is
visible on the pipe is an undefined operation. Avoid such circumstances
upon changing the mode, or at any other time, by unsetting the cursor if
it moves out of bounds.
"For normal high resolution display modes, the cursor must have at least a
single pixel positioned over the active screen.” (p143, p148 of the hardware
registers docs).
Fixes:
Bug 24748 - [965G] Graphics crashes when resolution is changed with KMS
enabled
https://bugs.freedesktop.org/show_bug.cgi?id=24748
v2: Only update the cursor registers if they change.
v3: Fix the unsigned comparision of x,y against width,height.
v4: Always set CUR.BASE or else the cursor may become corrupt.
Reported-by: Christian Eggers <ceggers@gmx.de>
Cc: Christopher James Halse Rogers <chalserogers@gmail.com>
bandwidth code
commit e06b14ee91a2ddefc9a67443a6cd8ee0fa800115 upstream.
Logic was:
if (mode0 && mode1)
else if (mode0)
else
Should be:
if (mode0 && mode1)
else if (mode0)
else if (mode1)
Otherwise we may end up calculating the priority regs with
unitialized values.
Fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=16492
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
commit 812d046915f48236657f02c06d7dc47140e9ceda upstream.
Use of HDP_*_COHERENCY_FLUSH_CNTL can cause a hang in certain
situations. Add workaround.
commit e376573f7267390f4e1bdc552564b6fb913bce76 upstream.
This fixes a problem where on low VRAM cards we'd run out of space for validation.
[airlied: Tested on my M7, Thinkpad T42, compiz works with no problems.]
Signed-off-by: Michel Dänzer <daenzer@vmware.com>
commit a91c1be21704113b023919826c6d531da46656ef upstream.
we also need to clean up and free the cdev.
Reported-by: Jani Nikula <ext-jani.1.nikula@nokia.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit 9d1ac34ec3a67713308ae0883c3359c557f14d17 upstream.
In kernel Bugzilla #15825 (2 users), in a wireless mailing list thread
(http://lists.infradead.org/pipermail/b43-dev/2010-May/000124.html), and on a
netbook owned by John Linville
(http://marc.info/?l=linux-wireless&m=127230751408818&w=4), there are reports
of ssb failing to detect an SPROM at the normal location. After studying the
MMIO trace dump for the Broadcom wl driver, it was determined that the affected
boxes had a relocated SPROM.
This patch fixes all systems that have reported this problem.
commit d28232b461b8d54b09e59325dbac8b0913ce2049 upstream.
Fix possible double priv->mutex lock introduced by commit
a69b03e941abae00380fc6bc1877fb797a1b31e6
"iwlwifi: cancel scan watchdog in iwl_bg_abort_scan" .
We can not call cancel_delayed_work_sync(&priv->scan_check) with
priv->mutex locked because workqueue function iwl_bg_scan_check()
take that lock internally.
We do not need to synchronize when canceling priv->scan_check work.
We can avoid races (sending double abort command or send no
command at all) using STATUS_SCAN_ABORT bit. Moreover
current iwl_bg_scan_check() code seems to be broken, as
we should not send abort commands when currently aborting.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
commit 601e0cb165e65dc185b31fe7ebd2c0169ea47306 upstream.
On AR9285, the antenna switch configuration register uses more than just
16 bits. Because of an arbitrary mask applied to the EEPROM value that
stores this configuration, diversity was broken in some cases, leading
to a significant degradation in signal strength.
Fix this by changing the callback to return a 32 bit value and remove
the arbitrary mask.
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
