commit e5c86679d5e864947a52fb31e45a425dea3e7fa9 upstream.
Linux IRQ #0 is reserved for error reporting and may not be used.
Increase NR_IRQS for one additional slot and increase
irq_domain_add_legacy parameter first_irq value to 1, so that linux
IRQ #0 is not associated with hardware IRQ #0 in legacy IRQ domains.
Introduce macro XTENSA_PIC_LINUX_IRQ for static translation of xtensa
PIC hardware IRQ # to linux IRQ #. Use this macro in XTFPGA platform
data definitions.
This fixes inability to use hardware IRQ #0 in configurations that don't
use device tree and allows for non-identity mapping between linux IRQ #
and hardware IRQ #.
Signed-off-by: Max Filippov <jcmvbkbc@gmail.com>
[ Upstream commit de9bf29dd6e4a8a874cb92f8901aed50a9d0b1d3 ]
Stop the tx when the napi is disabled to prevent napi_schedule() is
called.
Signed-off-by: Hayes Wang <hayeswang@realtek.com>
[ Upstream commit 2c561b2b728ca4013e76d6439bde2c137503745e ]
The rtl8152_post_reset() should sumbit rx urb and interrupt transfer,
otherwise the rx wouldn't work and the linking change couldn't be
detected.
[ Upstream commit 248b213ad908b88db15941202ef7cb7eb137c1a0 ]
Re-schedule napi after napi_complete() for tx, if it is necessay.
In r8152_poll(), if the tx is completed after tx_bottom() and before
napi_complete(), the scheduling of napi would be lost. Then, no
one handles the next tx until the next napi_schedule() is called.
[ Upstream commit a47b70ea86bdeb3091341f5ae3ef580f1a1ad822 ]
"swiotlb buffer is full" errors occur after repeated initialisation of a
device - f.e. suspend/resume or ip link set up/down. This is because memory
mapped using dma_map_single() in ravb_ring_format() and ravb_start_xmit()
is not released. Resolve this problem by unmapping descriptors when
freeing rings.
Fixes: c156633f1353 ("Renesas Ethernet AVB driver proper")
Signed-off-by: Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
[simon: reworked]
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
[ Upstream commit 6c971c09f38704513c426ba6515f22fb3d6c87d5 ]
The original ast driver will access some BMC configuration through P2A bridge
that can be disabled since AST2300 and after.
It will cause system hanged if P2A bridge is disabled.
Here is the update to fix it.
Signed-off-by: Y.C. Chen <yc_chen@aspeedtech.com>
[ Upstream commit cae9ff036eea577856d5b12860b4c79c5e71db4a ]
As it turns out, on cards that actually have CRTCs on them we're already
calling drm_kms_helper_poll_enable(drm_dev) from
nouveau_display_resume() before we call it in
nouveau_pmops_runtime_resume(). This leads us to accidentally trying to
enable polling twice, which results in a potential deadlock between the
RPM locks and drm_dev->mode_config.mutex if we end up trying to enable
polling the second time while output_poll_execute is running and holding
the mode_config lock. As such, make sure we only enable polling in
nouveau_pmops_runtime_resume() if we need to.
This fixes hangs observed on the ThinkPad W541
Signed-off-by: Lyude <lyude@redhat.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Kilian Singer <kilian.singer@quantumtechnology.info>
Cc: Lukas Wunner <lukas@wunner.de>
Cc: David Airlie <airlied@redhat.com>
[ Upstream commit 83b5d1e3d3013dbf90645a5d07179d018c8243fa ]
Signed-off-by: Helge Deller <deller@gmx.de>
[ Upstream commit d1156b489fa734d1af763d6a07b1637c01bb0aed ]
init_ring(), refill_rx_ring() and start_tx() don't check
if mapping dma memory succeed.
The patch adds the checks and failure handling.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
[ Upstream commit e82d02580af45663fad6d3596e4344c606e81e10 ]
This should be a typo.
Signed-off-by: Jisheng Zhang <jszhang@marvell.com>
[ Upstream commit 4af0e5bb95ee3ba5ea4bd7dbb94e1648a5279cc9 ]
In spite of switching to paged allocation of Rx buffers, the driver still
called dma_unmap_single() in the Rx queues tear-down path.
The DMA region unmapping code in free_skb_rx_queue() basically predates
the introduction of paged allocation to the driver. While being refactored,
it apparently hasn't reflected the change in the DMA API usage by its
counterpart gfar_new_page().
As a result, setting an interface to the DOWN state now yields the following:
# ip link set eth2 down
fsl-gianfar ffe24000.ethernet: DMA-API: device driver frees DMA memory with wrong function [device address=0x000000001ecd0000] [size=40]
WARNING: CPU: 1 PID: 189 at lib/dma-debug.c:1123 check_unmap+0x8e0/0xa28
CPU: 1 PID: 189 Comm: ip Tainted: G O 4.9.5 #1
task: dee73400 task.stack: dede2000
NIP: c02101e8 LR: c02101e8 CTR: c0260d74
REGS: dede3bb0 TRAP: 0700 Tainted: G O (4.9.5)
MSR: 00021000 <CE,ME> CR: 28002222 XER: 00000000
GPR00: c02101e8 dede3c60 dee73400 000000b6 dfbd033c dfbd36c4 1f622000 dede2000
GPR08: 00000007 c05b1634 1f622000 00000000 22002484 100a9904 00000000 00000000
GPR16: 00000000 db4c849c 00000002 db4c8480 00000001 df142240 db4c84bc 00000000
GPR24: c0706148 c0700000 00029000 c07552e8 c07323b4 dede3cb8 c07605e0 db535540
NIP [c02101e8] check_unmap+0x8e0/0xa28
LR [c02101e8] check_unmap+0x8e0/0xa28
Call Trace:
[dede3c60] [c02101e8] check_unmap+0x8e0/0xa28 (unreliable)
[dede3cb0] [c02103b8] debug_dma_unmap_page+0x88/0x9c
[dede3d30] [c02dffbc] free_skb_resources+0x2c4/0x404
[dede3d80] [c02e39b4] gfar_close+0x24/0xc8
[dede3da0] [c0361550] __dev_close_many+0xa0/0xf8
[dede3dd0] [c03616f0] __dev_close+0x2c/0x4c
[dede3df0] [c036b1b8] __dev_change_flags+0xa0/0x174
[dede3e10] [c036b2ac] dev_change_flags+0x20/0x60
[dede3e30] [c03e130c] devinet_ioctl+0x540/0x824
[dede3e90] [c0347dcc] sock_ioctl+0x134/0x298
[dede3eb0] [c0111814] do_vfs_ioctl+0xac/0x854
[dede3f20] [c0111ffc] SyS_ioctl+0x40/0x74
[dede3f40] [c000f290] ret_from_syscall+0x0/0x3c
--- interrupt: c01 at 0xff45da0
LR = 0xff45cd0
Instruction dump:
811d001c 7c66482e 813d0020 9061000c 807f000c 5463103a 7cc6182e 3c60c052
386309ac 90c10008 4cc63182 4826b845 <0fe00000> 4bfffa60 3c80c052 388402c4
---[ end trace 695ae6d7ac1d0c47 ]---
Mapped at:
[<c02e22a8>] gfar_alloc_rx_buffs+0x178/0x248
[<c02e3ef0>] startup_gfar+0x368/0x570
[<c036aeb4>] __dev_open+0xdc/0x150
[<c036b1b8>] __dev_change_flags+0xa0/0x174
[<c036b2ac>] dev_change_flags+0x20/0x60
Even though the issue was discovered in 4.9 kernel, the code in question
is identical in the current net and net-next trees.
Fixes: 75354148ce69 ("gianfar: Add paged allocation and Rx S/G")
Signed-off-by: Arseny Solokha <asolokha@kb.kras.ru>
Acked-by: Claudiu Manoil <claudiu.manoil@nxp.com>
[ Upstream commit d585df1c5ccf995fcee910705ad7a9cdd11d4152 ]
Some Hypervisors detach VFs from VMs by instantly causing an FLR event
to be generated for a VF.
In the mlx4 case, this will cause that VF's comm channel to be disabled
before the VM has an opportunity to invoke the VF device's "shutdown"
method.
The result is that the VF driver on the VM will experience a command
timeout during the shutdown process when the Hypervisor does not deliver
a command-completion event to the VM.
To avoid FW command timeouts on the VM when the driver's shutdown method
is invoked, we detect the absence of the VF's comm channel at the very
start of the shutdown process. If the comm-channel has already been
disabled, we cause all FW commands during the device shutdown process to
immediately return success (and thus avoid all command timeouts).
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Tariq Toukan <tariqt@mellanox.com>
[ Upstream commit 96692b097ba76d0c637ae8af47b29c73da33c9d0 ]
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
[ Upstream commit c966b6279f610a24ac1d42dcbe30e10fa61220b2 ]
[ Upstream commit a9306a63631493afc75893a4ac405d4e1cbae6aa ]
The might_sleep_if() assertions in __pm_runtime_idle(),
__pm_runtime_suspend() and __pm_runtime_resume() may generate
false-positive warnings in some situations. For example, that
happens if a nested pm_runtime_get_sync()/pm_runtime_put() pair
is executed with disabled interrupts within an outer
pm_runtime_get_sync()/pm_runtime_put() section for the same device.
[Generally, pm_runtime_get_sync() may sleep, so it should not be
called with disabled interrupts, but in this particular case the
previous pm_runtime_get_sync() guarantees that the device will not
be suspended, so the inner pm_runtime_get_sync() will return
immediately after incrementing the device's usage counter.]
That started to happen in the i915 driver in 4.10-rc, leading to
the following splat:
BUG: sleeping function called from invalid context at drivers/base/power/runtime.c:1032
in_atomic(): 1, irqs_disabled(): 0, pid: 1500, name: Xorg
1 lock held by Xorg/1500:
#0: (&dev->struct_mutex){+.+.+.}, at:
[<ffffffffa0680c13>] i915_mutex_lock_interruptible+0x43/0x140 [i915]
CPU: 0 PID: 1500 Comm: Xorg Not tainted
Call Trace:
dump_stack+0x85/0xc2
___might_sleep+0x196/0x260
__might_sleep+0x53/0xb0
__pm_runtime_resume+0x7a/0x90
intel_runtime_pm_get+0x25/0x90 [i915]
aliasing_gtt_bind_vma+0xaa/0xf0 [i915]
i915_vma_bind+0xaf/0x1e0 [i915]
i915_gem_execbuffer_relocate_entry+0x513/0x6f0 [i915]
i915_gem_execbuffer_relocate_vma.isra.34+0x188/0x250 [i915]
? trace_hardirqs_on+0xd/0x10
? i915_gem_execbuffer_reserve_vma.isra.31+0x152/0x1f0 [i915]
? i915_gem_execbuffer_reserve.isra.32+0x372/0x3a0 [i915]
i915_gem_do_execbuffer.isra.38+0xa70/0x1a40 [i915]
? __might_fault+0x4e/0xb0
i915_gem_execbuffer2+0xc5/0x260 [i915]
drm_ioctl+0x206/0x450 [drm]
? i915_gem_execbuffer+0x340/0x340 [i915]
? __fget+0x5/0x200
do_vfs_ioctl+0x91/0x6f0
? __fget+0x111/0x200
? __fget+0x5/0x200
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x23/0xc6
even though the code triggering it is correct.
Unfortunately, the might_sleep_if() assertions in question are
too coarse-grained to cover such cases correctly, so make them
a bit less sensitive in order to avoid the false-positives.
Reported-and-tested-by: Sedat Dilek <sedat.dilek@gmail.com>
[ Upstream commit f43128c75202f29ee71aa83e6c320a911137c189 ]
Since '701dc207bf55 ("i2c: piix4: Avoid race conditions with IMC")' we
are using the SMBSLVCNT register at offset 0x8. We need to request it.
Fixes: 701dc207bf55 ("i2c: piix4: Avoid race conditions with IMC")
Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com>
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
[ Upstream commit 5a70348e1187c5bf1cbd0ec51843f36befed1c2d ]
If a context is configured as dualstack ("IPv4v6"), the modem indicates
the context activation with a slightly different indication message.
The dual-stack indication omits the link_type (IPv4/v6) and adds
additional address fields.
IPv6 LSIs are identical to IPv4 LSIs, but have a different link type.
Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
Reviewed-by: Bjørn Mork <bjorn@mork.no>
[ Upstream commit 764895d3039e903dac3a70f219949efe43d036a0 ]
When the context is deactivated, the link_type is set to 0xff, which
triggers a warning message, and results in a wrong link status, as
the LSI is ignored.
[ Upstream commit b85ea006b6bebb692628f11882af41c3e12e1e09 ]
This patch fixes the device being used to DMA map skb->data.
Erroneous device assignment causes the crash when SMMU is enabled.
This happens during TX since buffer gets DMA mapped with device
correspondign to net_device and gets unmapped using the device
related to DSAF.
Signed-off-by: Kejian Yan <yankejian@huawei.com>
Reviewed-by: Yisen Zhuang <yisen.zhuang@huawei.com>
Signed-off-by: Salil Mehta <salil.mehta@huawei.com>
[ Upstream commit 7ba1b689038726d34e3244c1ac9e2e18c2ea4787 ]
If a USB-to-serial adapter is unplugged, the driver re-initializes, with
dev->hard_header_len and dev->addr_len set to zero, instead of the correct
values. If then a packet is sent through the half-dead interface, the
kernel will panic due to running out of headroom in the skb when pushing
for the AX.25 headers resulting in this panic:
[<c0595468>] (skb_panic) from [<c0401f70>] (skb_push+0x4c/0x50)
[<c0401f70>] (skb_push) from [<bf0bdad4>] (ax25_hard_header+0x34/0xf4 [ax25])
[<bf0bdad4>] (ax25_hard_header [ax25]) from [<bf0d05d4>] (ax_header+0x38/0x40 [mkiss])
[<bf0d05d4>] (ax_header [mkiss]) from [<c041b584>] (neigh_compat_output+0x8c/0xd8)
[<c041b584>] (neigh_compat_output) from [<c043e7a8>] (ip_finish_output+0x2a0/0x914)
[<c043e7a8>] (ip_finish_output) from [<c043f948>] (ip_output+0xd8/0xf0)
[<c043f948>] (ip_output) from [<c043f04c>] (ip_local_out_sk+0x44/0x48)
This patch makes mkiss behave like the 6pack driver. 6pack does not
panic. In 6pack.c sp_setup() (same function name here) the values for
dev->hard_header_len and dev->addr_len are set to the same values as in
my mkiss patch.
[ralf@linux-mips.org: Massages original submission to conform to the usual
standards for patch submissions.]
Signed-off-by: Thomas Osterried <thomas@osterried.de>
[ Upstream commit cd224553641848dd17800fe559e4ff5d208553e8 ]
xilinx_emaclite looks at the received data to try to determine the
Ethernet packet length but does not properly clamp it if
proto_type == ETH_P_IP or 1500 < proto_type <= 1518, causing a buffer
overflow and a panic via skb_panic() as the length exceeds the allocated
skb size.
Fix those cases.
Also add an additional unconditional check with WARN_ON() at the end.
Signed-off-by: Anssi Hannula <anssi.hannula@bitwise.fi>
Fixes: bb81b2ddfa19 ("net: add Xilinx emac lite device driver")
[ Upstream commit acf138f1b00bdd1b7cd9894562ed0c2a1670888e ]
The xilinx_emaclite uses __raw_writel and __raw_readl for register
accesses. Those functions do not imply any kind of memory barriers and
they may be reordered.
The driver does not seem to take that into account, though, and the
driver does not satisfy the ordering requirements of the hardware.
For clear examples, see xemaclite_mdio_write() and xemaclite_mdio_read()
which try to set MDIO address before initiating the transaction.
I'm seeing system freezes with the driver with GCC 5.4 and current
Linux kernels on Zynq-7000 SoC immediately when trying to use the
interface.
In commit 123c1407af87 ("net: emaclite: Do not use microblaze and ppc
IO functions") the driver was switched from non-generic
in_be32/out_be32 (memory barriers, big endian) to
__raw_readl/__raw_writel (no memory barriers, native endian), so
apparently the device follows system endianness and the driver was
originally written with the assumption of memory barriers.
Rather than try to hunt for each case of missing barrier, just switch
the driver to use iowrite32/ioread32/iowrite32be/ioread32be depending
on endianness instead.
Tested on little-endian Zynq-7000 ARM SoC FPGA.
Fixes: 123c1407af87 ("net: emaclite: Do not use microblaze and ppc IO
functions")
commit baabd567f87be05330faa5140f72a91960e7405a upstream.
The driver attempts to alter memory that is mapped to PCI device.
This is because tx_fwinfo_8190pci points to skb->data
Move the pci_map_single to when completed buffer is ready to be mapped with
psdec is empty to drop on mapping error.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
commit 1feb40067cf04ae48d65f728d62ca255c9449178 upstream.
The handling of IB_RDMA_WRITE_ONLY_WITH_IMMEDIATE will leak a memory
reference when a buffer cannot be allocated for returning the immediate
data.
The issue is that the rkey validation has already occurred and the RNR
nak fails to release the reference that was fruitlessly gotten. The
the peer will send the identical single packet request when its RNR
timer pops.
The fix is to release the held reference prior to the rnr nak exit.
This is the only sequence the requires both rkey validation and the
buffer allocation on the same packet.
Cc: Stable <stable@vger.kernel.org> # 4.7+
Tested-by: Tadeusz Struk <tadeusz.struk@intel.com>
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 3c9101766b502a0163d1d437fada5801cf616be2 upstream.
This patch fixes an issue that kernel panic happens when DMA is enabled
and we press enter key while the kernel booting on the serial console.
* An interrupt may occur after sci_request_irq().
* DMA transfer area is initialized by setup_timer() in sci_request_dma()
and used in interrupt.
If an interrupt occurred between sci_request_irq() and setup_timer() in
sci_request_dma(), DMA transfer area has not been initialized yet.
So, this patch changes the order of sci_request_irq() and
sci_request_dma().
Fixes: 73a19e4c0301 ("serial: sh-sci: Add DMA support.")
Signed-off-by: Takatoshi Akiyama <takatoshi.akiyama.kj@ps.hitachi-solutions.com>
[Shimoda changes the commit log]
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: Jiri Slaby <jslaby@suse.cz>
commit e9036d0662360cd4c79578565ce422ed5872f301 upstream.
When the tty lock is interrupted on attempted re-open, 2 tty krefs
are still held. Drop extra kref before returning failure from
tty_lock_interruptible(), and drop lookup kref before returning
failure from tty_open().
Fixes: 0bfd464d3fdd ("tty: Wait interruptibly for tty lock on reopen")
Signed-off-by: Peter Hurley <peter@hurleysoftware.com>
commit 32829da54d9368103a2f03269a5120aa9ee4d5da upstream.
A recent fix to /dev/mem prevents mappings from wrapping around the end
of physical address space. However, the check was written in a way that
also prevents a mapping reaching just up to the end of physical address
space, which may be a valid use case (especially on 32-bit systems).
This patch fixes it by checking the last mapped address (instead of the
first address behind that) for overflow.
Fixes: b299cde245 ("drivers: char: mem: Check for address space wraparound with mmap()")
Reported-by: Nico Huber <nico.h@gmx.de>
Signed-off-by: Julius Werner <jwerner@chromium.org>
commit b4e382ca7586a63b6c1e5221ce0863ff867c2df6 upstream.
Reusing the list_head for both is a bad idea. Callback execution is done
with the lock dropped so that alarms can be rescheduled from the callback,
which means that with some unfortunate timing, lists can get corrupted.
The execution list should not require its own locking, the single function
that uses it can only be called from a single context.
commit 07678eca2cf9c9a18584e546c2b2a0d0c9a3150c upstream.
When vmw_gb_surface_define_ioctl() is called with an existing buffer,
we end up returning an uninitialized variable in the backup_handle.
The fix is to first initialize backup_handle to 0 just to be sure, and
second, when a user-provided buffer is found, we will use the
req->buffer_handle as the backup_handle.
Reported-by: Murray McAllister <murray.mcallister@insomniasec.com>
Signed-off-by: Sinclair Yeh <syeh@vmware.com>
Reviewed-by: Deepak Rawat <drawat@vmware.com>
commit ee9c4e681ec4f58e42a83cb0c22a0289ade1aacf upstream.
The 'req->mip_levels' parameter in vmw_gb_surface_define_ioctl() is
a user-controlled 'uint32_t' value which is used as a loop count limit.
This can lead to a kernel lockup and DoS. Add check for 'req->mip_levels'.
References:
https://bugzilla.redhat.com/show_bug.cgi?id=1437431
Signed-off-by: Vladis Dronov <vdronov@redhat.com>
Reviewed-by: Sinclair Yeh <syeh@vmware.com>
commit f0c62e9878024300319ba2438adc7b06c6b9c448 upstream.
If vmalloc() fails then we need to a bit of cleanup before returning.
Fixes: fb1d9738ca05 ("drm/vmwgfx: Add DRM driver for VMware Virtual GPU")
commit ddff7ed45edce4a4c92949d3c61cd25d229c4a14 upstream.
When pci_enable_device() or pci_enable_device_mem() fail in
qla2x00_probe_one() we bail out but do a call to
pci_disable_device(). This causes the dev_WARN_ON() in
pci_disable_device() to trigger, as the device wasn't enabled
previously.
So instead of taking the 'probe_out' error path we can directly return
*iff* one of the pci_enable_device() calls fails.
Additionally rename the 'probe_out' goto label's name to the more
descriptive 'disable_device'.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
Fixes: e315cd28b9ef ("[SCSI] qla2xxx: Code changes for qla data structure refactoring")
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Giridhar Malavali <giridhar.malavali@cavium.com>
commit cec422c11caeeccae709e9942058b6b644ce434c upstream.
Fix error path if we can't copy user structure on CXL_IOCTL_START_WORK
ioctl. We shouldn't unlock the context status mutex as it was not
locked (yet).
Fixes: 0712dc7e73e5 ("cxl: Fix issues when unmapping contexts")
Signed-off-by: Frederic Barrat <fbarrat@linux.vnet.ibm.com>
Reviewed-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com>
Reviewed-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com>
commit 47eb0c8b4d9eb6368941c6a9bb443f00847a46d7 upstream.
The Lifebook E546 and E557 touchpad were also not functioning and
worked after running:
echo "1" > /sys/devices/platform/i8042/serio2/crc_enabled
Add them to the list of machines that need this workaround.
Signed-off-by: Ulrik De Bie <ulrik.debie-os@e2big.org>
Reviewed-by: Arjan Opmeer <arjan@opmeer.net>
commit 43523eba79bda8f5b4c27f8ffe20ea078d20113a upstream.
Without this, polling on the dma-buf (and presumably other devices
synchronizing against our rendering) would return immediately, even
while the BO was busy.
Signed-off-by: Eric Anholt <eric@anholt.net>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Rob Clark <robdclark@gmail.com>
Cc: linux-arm-msm@vger.kernel.org
Cc: freedreno@lists.freedesktop.org
Reviewed-by: Rob Clark <robdclark@gmail.com>
Signed-off-by: Rob Clark <robdclark@gmail.com>
commit 4ff83daa0200affe1894bd33d17bac404e3d78d4 upstream.
During v4.3 when the overflow/underflow check was relaxed by
commit c72c525022:
commit c72c5250224d475614a00c1d7e54a67f77cd3410
Author: Roland Dreier <roland@purestorage.com>
Date: Wed Jul 22 15:08:18 2015 -0700
target: allow underflow/overflow for PR OUT etc. commands
to allow underflow/overflow for Windows compliance + FCP, a
consequence was to allow control CDBs to process overflow
data for iscsi-target with immediate data as well.
As per Roland's original change, continue to allow underflow
cases for control CDBs to make Windows compliance + FCP happy,
but until overflow for control CDBs is supported tree-wide,
explicitly reject all control WRITEs with overflow following
pre v4.3.y logic.
Reported-by: Bart Van Assche <bart.vanassche@sandisk.com>
Cc: Roland Dreier <roland@purestorage.com>
commit 6c77003677d5f1ce15f26d24360cb66c0bc07bb3 upstream.
For a driver that does not set the CPUFREQ_STICKY flag, if all of the
->init() calls fail, cpufreq_register_driver() should return an error.
This will prevent the driver from loading.
Fixes: ce1bcfe94db8 (cpufreq: check cpufreq_policy_list instead of scanning policies for all CPUs)
Signed-off-by: David Arcari <darcari@redhat.com>
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
commit b1132deac01c2332d234fa821a70022796b79182 upstream.
get_random_long() reads from the get_random_int_hash array using an
unsigned long pointer. For this code to be guaranteed correct on all
architectures, the array must be aligned to an unsigned long boundary.
Signed-off-by: Eric Biggers <ebiggers3@gmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit ec9ee4acd97c0039a61c0ae4f12705767ae62153 upstream.
Commit d07e22597d1d ("mm: mmap: add new /proc tunable for mmap_base
ASLR") added the ability to choose from a range of values to use for
entropy count in generating the random offset to the mmap_base address.
The maximum value on this range was set to 32 bits for 64-bit x86
systems, but this value could be increased further, requiring more than
the 32 bits of randomness provided by get_random_int(), as is already
possible for arm64. Add a new function: get_random_long() which more
naturally fits with the mmap usage of get_random_int() but operates
exactly the same as get_random_int().
Also, fix the shifting constant in mmap_rnd() to be an unsigned long so
that values greater than 31 bits generate an appropriate mask without
overflow. This is especially important on x86, as its shift instruction
uses a 5-bit mask for the shift operand, which meant that any value for
mmap_rnd_bits over 31 acts as a no-op and effectively disables mmap_base
randomization.
Finally, replace calls to get_random_int() with get_random_long() where
appropriate.
This patch (of 2):
Add get_random_long().
Signed-off-by: Daniel Cashman <dcashman@android.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Nick Kralevich <nnk@google.com>
Cc: Jeff Vander Stoep <jeffv@google.com>
Cc: Mark Salyzyn <salyzyn@android.com>
commit 275292d3a3d62670b1b13484707b74e5239b4bb0 upstream.
AS3935 interrupt mask has been incorrect so valid lightning events
would never trigger an buffer event. Also noise interrupt should be
BIT(0).
Fixes: 24ddb0e4bba4 ("iio: Add AS3935 lightning sensor support")
Signed-off-by: Matt Ranostay <matt.ranostay@konsulko.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 7cc3bff4efe6164a0c8163331c8aa55454799f42 upstream.
The register mapping for the IIO driver for the Liteon Light and Proximity
sensor LTR501 interrupt mode is interchanged (ALS/PS).
There is a register called INTERRUPT register (address 0x8F)
Bit 0 represents PS measurement trigger.
Bit 1 represents ALS measurement trigger.
This two bit fields are interchanged within the driver.
see datasheet page 24:
http://optoelectronics.liteon.com/upload/download/DS86-2012-0006/S_110_LTR-501ALS-01_PrelimDS_ver1%5B1%5D.pdf
Signed-off-by: Franziska Naepelt <franziska.naepelt@idt.com>
Fixes: 7ac702b3144b6 ("iio: ltr501: Add interrupt support")
Acked-by: Peter Meerwald-Stadler <pmeerw@pmeerw.net>
commit 0a33252e060e97ed3fbdcec9517672f1e91aaef3 upstream.
lov_getstripe() calls set_fs(KERNEL_DS) so that it can handle a struct
lov_user_md pointer from user- or kernel-space. This changes the
behavior of copy_from_user() on SPARC and may result in a misaligned
access exception which in turn oopses the kernel. In fact the
relevant argument to lov_getstripe() is never called with a
kernel-space pointer and so changing the address limits is unnecessary
and so we remove the calls to save, set, and restore the address
limits.
Signed-off-by: John L. Hammond <john.hammond@intel.com>
Reviewed-on: http://review.whamcloud.com/6150
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-3221
Reviewed-by: Andreas Dilger <andreas.dilger@intel.com>
Reviewed-by: Li Wei <wei.g.li@intel.com>
Signed-off-by: Oleg Drokin <green@linuxhacker.ru>
commit 0340ff83cd4475261e7474033a381bc125b45244 upstream.
ci_role BUGs when the role is >= CI_ROLE_END.
Signed-off-by: Michael Thalmeier <michael.thalmeier@hale.at>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
commit aa1f058d7d9244423b8c5a75b9484b1115df7f02 upstream.
Fix below NULL pointer dereference. we set ci->roles[CI_ROLE_GADGET]
too early in ci_hdrc_gadget_init(), if udc_start() fails due to some
reason, the ci->roles[CI_ROLE_GADGET] check in ci_hdrc_gadget_destroy
can't protect us.
We fix this issue by only setting ci->roles[CI_ROLE_GADGET] if
udc_start() succeed.
[ 1.398550] Unable to handle kernel NULL pointer dereference at
virtual address 00000000
[ 1.448600] PC is at dma_pool_free+0xb8/0xf0
[ 1.453012] LR is at dma_pool_free+0x28/0xf0
[ 2.113369] [<ffffff80081817d8>] dma_pool_free+0xb8/0xf0
[ 2.118857] [<ffffff800841209c>] destroy_eps+0x4c/0x68
[ 2.124165] [<ffffff8008413770>] ci_hdrc_gadget_destroy+0x28/0x50
[ 2.130461] [<ffffff800840fa30>] ci_hdrc_probe+0x588/0x7e8
[ 2.136129] [<ffffff8008380fb8>] platform_drv_probe+0x50/0xb8
[ 2.142066] [<ffffff800837f494>] driver_probe_device+0x1fc/0x2a8
[ 2.148270] [<ffffff800837f68c>] __device_attach_driver+0x9c/0xf8
[ 2.154563] [<ffffff800837d570>] bus_for_each_drv+0x58/0x98
[ 2.160317] [<ffffff800837f174>] __device_attach+0xc4/0x138
[ 2.166072] [<ffffff800837f738>] device_initial_probe+0x10/0x18
[ 2.172185] [<ffffff800837e58c>] bus_probe_device+0x94/0xa0
[ 2.177940] [<ffffff800837c560>] device_add+0x3f0/0x560
[ 2.183337] [<ffffff8008380d20>] platform_device_add+0x180/0x240
[ 2.189541] [<ffffff800840f0e8>] ci_hdrc_add_device+0x440/0x4f8
[ 2.195654] [<ffffff8008414194>] ci_hdrc_usb2_probe+0x13c/0x2d8
[ 2.201769] [<ffffff8008380fb8>] platform_drv_probe+0x50/0xb8
[ 2.207705] [<ffffff800837f494>] driver_probe_device+0x1fc/0x2a8
[ 2.213910] [<ffffff800837f5ec>] __driver_attach+0xac/0xb0
[ 2.219575] [<ffffff800837d4b0>] bus_for_each_dev+0x60/0xa0
[ 2.225329] [<ffffff800837ec80>] driver_attach+0x20/0x28
[ 2.230816] [<ffffff800837e880>] bus_add_driver+0x1d0/0x238
[ 2.236571] [<ffffff800837fdb0>] driver_register+0x60/0xf8
[ 2.242237] [<ffffff8008380ef4>] __platform_driver_register+0x44/0x50
[ 2.248891] [<ffffff80086fd440>] ci_hdrc_usb2_driver_init+0x18/0x20
[ 2.255365] [<ffffff8008082950>] do_one_initcall+0x38/0x128
[ 2.261121] [<ffffff80086e0d00>] kernel_init_freeable+0x1ac/0x250
[ 2.267414] [<ffffff800852f0b8>] kernel_init+0x10/0x100
[ 2.272810] [<ffffff8008082680>] ret_from_fork+0x10/0x50
Fixes: 3f124d233e97 ("usb: chipidea: add role init and destroy APIs")
commit dc9217b69dd6089dcfeb86ed4b3c671504326087 upstream.
f_mass_storage has a memorry barrier issue with the sleep and wake
functions that can cause a deadlock. This results in intermittent hangs
during MSC file transfer. The host will reset the device after receiving
no response to resume the transfer. This issue is seen when dwc3 is
processing 2 transfer-in-progress events at the same time, invoking
completion handlers for CSW and CBW. Also this issue occurs depending on
the system timing and latency.
To increase the chance to hit this issue, you can force dwc3 driver to
wait and process those 2 events at once by adding a small delay (~100us)
in dwc3_check_event_buf() whenever the request is for CSW and read the
event count again. Avoid debugging with printk and ftrace as extra
delays and memory barrier will mask this issue.
Scenario which can lead to failure:
1) The main thread sleeps and waits for the next command in
get_next_command().
2) bulk_in_complete() wakes up main thread for CSW.
3) bulk_out_complete() tries to wake up the running main thread for CBW.
4) thread_wakeup_needed is not loaded with correct value in
sleep_thread().
5) Main thread goes to sleep again.
The pattern is shown below. Note the 2 critical variables.
* common->thread_wakeup_needed
* bh->state
CPU 0 (sleep_thread) CPU 1 (wakeup_thread)
bh->state = BH_STATE_FULL;
smp_wmb();
thread_wakeup_needed = 0; thread_wakeup_needed = 1;
smp_rmb();
if (bh->state != BH_STATE_FULL)
sleep again ...
As pointed out by Alan Stern, this is an R-pattern issue. The issue can
be seen when there are two wakeups in quick succession. The
thread_wakeup_needed can be overwritten in sleep_thread, and the read of
the bh->state maybe reordered before the write to thread_wakeup_needed.
This patch applies full memory barrier smp_mb() in both sleep_thread()
and wakeup_thread() to ensure the order which the thread_wakeup_needed
and bh->state are written and loaded.
However, a better solution in the future would be to use wait_queue
method that takes care of managing memory barrier between waker and
waiter.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Thinh Nguyen <thinhn@synopsys.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit 269ebce4531b8edc4224259a02143181a1c1d77c upstream.
IS_ERR_VALUE() in commit 87557efc27f6a50140fb20df06a917f368ce3c66
("xen-netfront: do not cast grant table reference to signed short") would
not return true for error code unless we cast ref first to type int.
Signed-off-by: Dongli Zhang <dongli.zhang@oracle.com>
Cc: Blake Cooper <blake.cooper@braintreepayments.com>
commit 87557efc27f6a50140fb20df06a917f368ce3c66 upstream.
While grant reference is of type uint32_t, xen-netfront erroneously casts
it to signed short in BUG_ON().
This would lead to the xen domU panic during boot-up or migration when it
is attached with lots of paravirtual devices.
commit 753c09b5652bb4fe53e2db648002ec64b32b8827 upstream.
Commit 5995a68 "xen/privcmd: Add support for Linux 64KB page granularity" did
not go far enough to support 64KB in mmap_batch_fn.
The variable 'nr' is the number of 4KB chunk to map. However, when Linux
is using 64KB page granularity the array of pages (vma->vm_private_data)
contain one page per 64KB. Fix it by incrementing st->index correctly.
Furthermore, st->va is not correctly incremented as PAGE_SIZE !=
XEN_PAGE_SIZE.
Fixes: 5995a68 ("xen/privcmd: Add support for Linux 64KB page granularity")
Reported-by: Feng Kan <fkan@apm.com>
Signed-off-by: Julien Grall <julien.grall@arm.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
commit 0037ae47812b1f431cc602100d1d51f37d77b61e upstream.
The current buffer is being reset to zero on device_free_chan_resources()
but not on device_terminate_all(). It could happen that HW is restarted and
expects BASE0 to be used, but the driver is not synchronized and will start
from BASE1. One solution is to reset the buffer explicitly in
m2p_hw_setup().
Signed-off-by: Alexander Sverdlin <alexander.sverdlin@gmail.com>
Signed-off-by: Vinod Koul <vinod.koul@intel.com>
commit 9a445bbb1607d9f14556a532453dd86d1b7e381e upstream.
This patch fixes the register definition of AE (Address Error flag) bit.
Fixes: 0c1c8ff32fa2 ("dmaengine: usb-dmac: Add Renesas USB DMA Controller (USB-DMAC) driver")
Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com>
[Shimoda: add Fixes and Cc tags in the commit log]
Reviewed-by: Geert Uytterhoeven <geert+renesas@glider.be>
