commit 926317de33998c112c5510301868ea9aa34097e2 upstream.
This patch addresses a bug where a local EXTENDED_COPY WRITE or READ
backend I/O request would always return SAM_STAT_CHECK_CONDITION,
even if underlying xcopy_pt_cmd->se_cmd generated a different
SCSI status code.
ESX host environments expect to hit SAM_STAT_RESERVATION_CONFLICT
for certain scenarios, and SAM_STAT_CHECK_CONDITION results in
non-retriable status for these cases.
Tested on v4.1.y with ESX v5.5u2+ with local IBLOCK backend copy.
Reported-by: Nixon Vincent <nixon.vincent@calsoftinc.com>
Tested-by: Nixon Vincent <nixon.vincent@calsoftinc.com>
Cc: Nixon Vincent <nixon.vincent@calsoftinc.com>
Tested-by: Dinesh Israni <ddi@datera.io>
Signed-off-by: Dinesh Israni <ddi@datera.io>
Cc: Dinesh Israni <ddi@datera.io>
commit 449a137846c84829a328757cd21fd9ca65c08519 upstream.
This patch addresses a bug where EXTENDED_COPY across multiple LUNs
results in a CHECK_CONDITION when the source + destination are not
located on the same physical node.
ESX Host environments expect sense COPY_ABORTED w/ COPY TARGET DEVICE
NOT REACHABLE to be returned when this occurs, in order to signal
fallback to local copy method.
As described in section 6.3.3 of spc4r22:
"If it is not possible to complete processing of a segment because the
copy manager is unable to establish communications with a copy target
device, because the copy target device does not respond to INQUIRY,
or because the data returned in response to INQUIRY indicates
an unsupported logical unit, then the EXTENDED COPY command shall be
terminated with CHECK CONDITION status, with the sense key set to
COPY ABORTED, and the additional sense code set to COPY TARGET DEVICE
NOT REACHABLE."
Tested on v4.1.y with ESX v5.5u2+ with BlockCopy across multiple nodes.
commit 527268df31e57cf2b6d417198717c6d6afdb1e3e upstream.
This patch fixes a regression in >= v4.1.y code where the original
SCF_ACK_KREF assignment in target_get_sess_cmd() was dropped upstream
in commit 054922bb, but the series for addressing TMR ABORT_TASK +
LUN_RESET with fabric session reinstatement in commit febe562c20 still
depends on this code in transport_cmd_finish_abort().
The regression manifests itself as a se_cmd->cmd_kref +1 leak, where
ABORT_TASK + LUN_RESET can hang indefinately for a specific I_T session
for drivers using SCF_ACK_KREF, resulting in hung kthreads.
This patch has been verified with v4.1.y code.
Reported-by: Vaibhav Tandon <vst@datera.io>
Tested-by: Vaibhav Tandon <vst@datera.io>
Cc: Vaibhav Tandon <vst@datera.io>
commit 4f48aa7a11bfed9502a7c85a5b68cd40ea827f73 upstream.
Accesses of the rtsx sdmmc's parent device, which is the rtsx usb device,
must be done when it's runtime resumed. Currently this isn't case when
changing the led, so let's fix this by adding a pm_runtime_get_sync() and
a pm_runtime_put() around those operations.
Reported-by: Ritesh Raj Sarraf <rrs@researchut.com>
Tested-by: Ritesh Raj Sarraf <rrs@researchut.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 31cf742f515c275d22843c4c756e048d2b6d716c upstream.
The rtsx_usb_sdmmc driver may bail out in its ->set_ios() callback when no
SD card is inserted. This is wrong, as it could cause the device to remain
runtime resumed when it's unused. Fix this behaviour.
commit 3f2d26643595973e835e8356ea90c7c15cb1b0f1 upstream.
Commit f68381a70bb2 (mmc: block: fix packed command header endianness)
correctly fixed endianness handling of packed_cmd_hdr in
mmc_blk_packed_hdr_wrq_prep.
But now, sparse complains about incorrect types:
drivers/mmc/card/block.c:1613:27: sparse: incorrect type in assignment (different base types)
drivers/mmc/card/block.c:1613:27: expected unsigned int [unsigned] [usertype] <noident>
drivers/mmc/card/block.c:1613:27: got restricted __le32 [usertype] <noident>
So annotate cmd_hdr properly using __le32 to make everyone happy.
Fixes: f68381a70bb2 (mmc: block: fix packed command header endianness)
commit 9158cb29e7c2f10dd325eb1589f0fe745a271257 upstream.
Accesses to the rtsx usb device, which is the parent of the rtsx memstick
device, must not be done unless it's runtime resumed. This is currently not
the case and it could trigger various errors.
Fix this by properly deal with runtime PM in this regards. This means
making sure the device is runtime resumed, when serving requests via the
->request() callback or changing settings via the ->set_param() callbacks.
Cc: Ritesh Raj Sarraf <rrs@researchut.com>
commit 796aa46adf1d90eab36ae06a42e6d3f10b28a75c upstream.
Therefore when the rtsx_usb_ms driver polls for inserted memstick cards,
let's add pm_runtime_get|put*() to make sure accesses is done when the
rtsx usb device is runtime resumed.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
commit c09f12186d6b03b798832d95289af76495990192 upstream.
Commit 209851649dc4 "acpi: nfit: Add support for hot-add" added
support for _FIT notifications, but it neglected to verify the
notification event code matches the one in the ACPI spec for
"NFIT Update". Currently there is only one code in the spec, but
once additional codes are added, older kernels (without this fix)
will misbehave by assuming all event notifications are for an
NFIT Update.
Fixes: 209851649dc4 ("acpi: nfit: Add support for hot-add")
Cc: <stable@vger.kernel.org>
Cc: <linux-acpi@vger.kernel.org>
Cc: Dan Williams <dan.j.williams@intel.com>
Reported-by: Linda Knippers <linda.knippers@hpe.com>
Signed-off-by: Vishal Verma <vishal.l.verma@intel.com>
commit 6e5224224faa50ec4c8949dcefadf895e565f0d1 upstream.
The VF administrative mac addresses (stored in the PF driver) are
initialized to zero when the PF driver starts up.
These addresses may be modified in the PF driver through ndo calls
initiated by iproute2 or libvirt.
While we allow the PF/host to change the VF admin mac address from zero
to a valid unicast mac, we do not allow restoring the VF admin mac to
zero. We currently only allow changing this mac to a different unicast mac.
This leads to problems when libvirt scripts are used to deal with
VF mac addresses, and libvirt attempts to revoke the mac so this
host will not use it anymore.
Fix this by allowing resetting a VF administrative MAC back to zero.
Fixes: 8f7ba3ca12f6 ('net/mlx4: Add set VF mac address support')
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Reported-by: Moshe Levi <moshele@mellanox.com>
Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com>
commit 1e6bb1a3540fec3ef112b9a89dda88e684c3ff59 upstream.
Not all adapters have FC-NPIV configured. If bnx2fc is used with such an
adapter, driver would read irrelevant data from the the nvram and log
"FC-NPIV table with bad length..." In system logs.
Simply accept that reading '0' as the feature offset in nvram indicates
the feature isn't there and return.
Reported-by: Andrew Patterson <andrew.patterson@hpe.com>
Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com>
commit 64ce60cab24603ac0fcd59c9fbc3be78f4c4d229 upstream.
The SA controller spins down RAID drive spares.
A REGNEWD event causes an inquiry to be sent to all physical
drives. This causes the SA controller to spin up the spare.
The controller suspends all I/O to a logical volume until
the spare is spun up. The spin-up can take over 50 seconds.
This can result in one or both of the following:
- SML sends down aborts and resets to the logical volume
and can cause the logical volume to be off-lined.
- a negative impact on the logical volume's I/O performance
each time a REGNEWD is triggered.
Reviewed-by: Scott Teel <scott.teel@microsemi.com>
Reviewed-by: Kevin Barnett <kevin.barnett@microsemi.com>
Signed-off-by: Don Brace <don.brace@microsemi.com>
commit 6b7e9cde49691e04314342b7dce90c67ad567fcc upstream.
For historic reasons, io_opt is in bytes and max_sectors in block layer
sectors. This interface inconsistency is error prone and should be
fixed. But for 4.4--4.7 let's make the unit difference explicit via a
wrapper function.
Fixes: d0eb20a863ba ("sd: Optimal I/O size is in bytes, not sectors")
Reported-by: Fam Zheng <famz@redhat.com>
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
Tested-by: Andrew Patterson <andrew.patterson@hpe.com>
commit d102eb5c1ac5e6743b1c6d145c06a25d98ad1375 upstream.
The timeout loop terminates when the loop count is zero, but the decrement
of the count variable is post check. So count is -1 when we check for the
timeout and therefor the error message is supressed.
Change it to predecrement, so the error message is emitted.
[ tglx: Massaged changelog ]
Fixes: a2c225101234 ("irqchip: gic-v3: Refactor gic_enable_redist to support both enabling and disabling")
Acked-by: Sudeep Holla <sudeep.holla@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: kernel-janitors@vger.kernel.org
Cc: Jason Cooper <jason@lakedaemon.net>
Link: http://lkml.kernel.org/r/20161014072534.GA15168@mwanda
commit bcd8f2e94808fcddf6ef3af5f060a36820dcc432 upstream.
This patch fixes one use-after-free report[1] by KASAN.
In __scsi_scan_target(), when a type 31 device is probed,
SCSI_SCAN_TARGET_PRESENT is returned and the target will be scanned
again.
Inside the following scsi_report_lun_scan(), one new scsi_device
instance is allocated, and scsi_probe_and_add_lun() is called again to
probe the target and still see type 31 device, finally
__scsi_remove_device() is called to remove & free the device at the end
of scsi_probe_and_add_lun(), so cause use-after-free in
scsi_report_lun_scan().
And the following SCSI log can be observed:
scsi 0:0:2:0: scsi scan: INQUIRY pass 1 length 36
scsi 0:0:2:0: scsi scan: INQUIRY successful with code 0x0
scsi 0:0:2:0: scsi scan: peripheral device type of 31, no device added
scsi 0:0:2:0: scsi scan: Sending REPORT LUNS to (try 0)
scsi 0:0:2:0: scsi scan: REPORT LUNS successful (try 0) result 0x0
scsi 0:0:2:0: scsi scan: REPORT LUN scan
BUG: KASAN: use-after-free in __scsi_scan_target+0xbf8/0xe40 at addr ffff88007b44a104
This patch fixes the issue by moving the putting reference at
the end of scsi_report_lun_scan().
[1] KASAN report
[ 3.274597] PM: Adding info for serio:serio1
[ 3.275127] BUG: KASAN: use-after-free in __scsi_scan_target+0xd87/0xdf0 at addr ffff880254d8c304
[ 3.275653] Read of size 4 by task kworker/u10:0/27
[ 3.275903] CPU: 3 PID: 27 Comm: kworker/u10:0 Not tainted 4.8.0 #2121
[ 3.276258] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014
[ 3.276797] Workqueue: events_unbound async_run_entry_fn
[ 3.277083] ffff880254d8c380 ffff880259a37870 ffffffff94bbc6c1 ffff880078402d80
[ 3.277532] ffff880254d8bb80 ffff880259a37898 ffffffff9459fec1 ffff880259a37930
[ 3.277989] ffff880254d8bb80 ffff880078402d80 ffff880259a37920 ffffffff945a0165
[ 3.278436] Call Trace:
[ 3.278528] [<ffffffff94bbc6c1>] dump_stack+0x65/0x84
[ 3.278797] [<ffffffff9459fec1>] kasan_object_err+0x21/0x70
[ 3.279063] device: 'psaux': device_add
[ 3.279616] [<ffffffff945a0165>] kasan_report_error+0x205/0x500
[ 3.279651] PM: Adding info for No Bus:psaux
[ 3.280202] [<ffffffff944ecd22>] ? kfree_const+0x22/0x30
[ 3.280486] [<ffffffff94bc2dc9>] ? kobject_release+0x119/0x370
[ 3.280805] [<ffffffff945a0543>] __asan_report_load4_noabort+0x43/0x50
[ 3.281170] [<ffffffff9507e1f7>] ? __scsi_scan_target+0xd87/0xdf0
[ 3.281506] [<ffffffff9507e1f7>] __scsi_scan_target+0xd87/0xdf0
[ 3.281848] [<ffffffff9507d470>] ? scsi_add_device+0x30/0x30
[ 3.282156] [<ffffffff94f7f660>] ? pm_runtime_autosuspend_expiration+0x60/0x60
[ 3.282570] [<ffffffff956ddb07>] ? _raw_spin_lock+0x17/0x40
[ 3.282880] [<ffffffff9507e505>] scsi_scan_channel+0x105/0x160
[ 3.283200] [<ffffffff9507e8a2>] scsi_scan_host_selected+0x212/0x2f0
[ 3.283563] [<ffffffff9507eb3c>] do_scsi_scan_host+0x1bc/0x250
[ 3.283882] [<ffffffff9507efc1>] do_scan_async+0x41/0x450
[ 3.284173] [<ffffffff941c1fee>] async_run_entry_fn+0xfe/0x610
[ 3.284492] [<ffffffff941a8954>] ? pwq_dec_nr_in_flight+0x124/0x2a0
[ 3.284876] [<ffffffff941d1770>] ? preempt_count_add+0x130/0x160
[ 3.285207] [<ffffffff941a9a84>] process_one_work+0x544/0x12d0
[ 3.285526] [<ffffffff941aa8e9>] worker_thread+0xd9/0x12f0
[ 3.285844] [<ffffffff941aa810>] ? process_one_work+0x12d0/0x12d0
[ 3.286182] [<ffffffff941bb365>] kthread+0x1c5/0x260
[ 3.286443] [<ffffffff940855cd>] ? __switch_to+0x88d/0x1430
[ 3.286745] [<ffffffff941bb1a0>] ? kthread_worker_fn+0x5a0/0x5a0
[ 3.287085] [<ffffffff956dde9f>] ret_from_fork+0x1f/0x40
[ 3.287368] [<ffffffff941bb1a0>] ? kthread_worker_fn+0x5a0/0x5a0
[ 3.287697] Object at ffff880254d8bb80, in cache kmalloc-2048 size: 2048
[ 3.288064] Allocated:
[ 3.288147] PID = 27
[ 3.288218] [<ffffffff940b27ab>] save_stack_trace+0x2b/0x50
[ 3.288531] [<ffffffff9459f246>] save_stack+0x46/0xd0
[ 3.288806] [<ffffffff9459f4bd>] kasan_kmalloc+0xad/0xe0
[ 3.289098] [<ffffffff9459c07e>] __kmalloc+0x13e/0x250
[ 3.289378] [<ffffffff95078e5a>] scsi_alloc_sdev+0xea/0xcf0
[ 3.289701] [<ffffffff9507de76>] __scsi_scan_target+0xa06/0xdf0
[ 3.290034] [<ffffffff9507e505>] scsi_scan_channel+0x105/0x160
[ 3.290362] [<ffffffff9507e8a2>] scsi_scan_host_selected+0x212/0x2f0
[ 3.290724] [<ffffffff9507eb3c>] do_scsi_scan_host+0x1bc/0x250
[ 3.291055] [<ffffffff9507efc1>] do_scan_async+0x41/0x450
[ 3.291354] [<ffffffff941c1fee>] async_run_entry_fn+0xfe/0x610
[ 3.291695] [<ffffffff941a9a84>] process_one_work+0x544/0x12d0
[ 3.292022] [<ffffffff941aa8e9>] worker_thread+0xd9/0x12f0
[ 3.292325] [<ffffffff941bb365>] kthread+0x1c5/0x260
[ 3.292594] [<ffffffff956dde9f>] ret_from_fork+0x1f/0x40
[ 3.292886] Freed:
[ 3.292945] PID = 27
[ 3.293016] [<ffffffff940b27ab>] save_stack_trace+0x2b/0x50
[ 3.293327] [<ffffffff9459f246>] save_stack+0x46/0xd0
[ 3.293600] [<ffffffff9459fa61>] kasan_slab_free+0x71/0xb0
[ 3.293916] [<ffffffff9459bac2>] kfree+0xa2/0x1f0
[ 3.294168] [<ffffffff9508158a>] scsi_device_dev_release_usercontext+0x50a/0x730
[ 3.294598] [<ffffffff941ace9a>] execute_in_process_context+0xda/0x130
[ 3.294974] [<ffffffff9508107c>] scsi_device_dev_release+0x1c/0x20
[ 3.295322] [<ffffffff94f566f6>] device_release+0x76/0x1e0
[ 3.295626] [<ffffffff94bc2db7>] kobject_release+0x107/0x370
[ 3.295942] [<ffffffff94bc29ce>] kobject_put+0x4e/0xa0
[ 3.296222] [<ffffffff94f56e17>] put_device+0x17/0x20
[ 3.296497] [<ffffffff9505201c>] scsi_device_put+0x7c/0xa0
[ 3.296801] [<ffffffff9507e1bc>] __scsi_scan_target+0xd4c/0xdf0
[ 3.297132] [<ffffffff9507e505>] scsi_scan_channel+0x105/0x160
[ 3.297458] [<ffffffff9507e8a2>] scsi_scan_host_selected+0x212/0x2f0
[ 3.297829] [<ffffffff9507eb3c>] do_scsi_scan_host+0x1bc/0x250
[ 3.298156] [<ffffffff9507efc1>] do_scan_async+0x41/0x450
[ 3.298453] [<ffffffff941c1fee>] async_run_entry_fn+0xfe/0x610
[ 3.298777] [<ffffffff941a9a84>] process_one_work+0x544/0x12d0
[ 3.299105] [<ffffffff941aa8e9>] worker_thread+0xd9/0x12f0
[ 3.299408] [<ffffffff941bb365>] kthread+0x1c5/0x260
[ 3.299676] [<ffffffff956dde9f>] ret_from_fork+0x1f/0x40
[ 3.299967] Memory state around the buggy address:
[ 3.300209] ffff880254d8c200: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 3.300608] ffff880254d8c280: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 3.300986] >ffff880254d8c300: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
[ 3.301408] ^
[ 3.301550] ffff880254d8c380: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 3.301987] ffff880254d8c400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 3.302396]
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
commit 62837b3c1a95535d1a287c9c8c6563bbd8d37033 upstream.
Another Lifebook machine that needs the same quirk as other similar
models to make the driver working.
Also let's reorder elantech_dmi_force_crc_enabled list so LIfebook enries
are in alphabetical order.
Reported-by: William Linna <william.linna@gmail.com>
Tested-by: William Linna <william.linna@gmail.com>
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit f9a703a54d16ba2470391c4b12236ee56591d50c upstream.
Just like Fujitsu CELSIUS H730, the H760 also has an Elantech touchpad with
the same quirks. Without this patch, the touchpad is useless out-of-the-box
as the mouse pointer won't move.
This patch makes the driver aware of both the crc_enabled=1 requirement and
the middle button, making the touchpad fully functional out-of-the-box.
Signed-off-by: Matti Kurkela <Matti.Kurkela@iki.fi>
commit 930e19248e9b61da36c967687ca79c4d5f977919 upstream.
On suspend/resume cycle, selftest is executed to reset i8042 controller.
But when this is done in Asus devices, subsequent calls to detect/init
functions to elantech driver fails. Skipping selftest fixes this problem.
An easier step to reproduce this problem is adding i8042.reset=1 as a
kernel parameter. On Asus laptops, it'll make the system to start with the
touchpad already stuck, since psmouse_probe forcibly calls the selftest
function.
This patch was inspired by John Hiesey's change[1], but, since this problem
affects a lot of models of Asus, let's avoid running selftests on them.
All models affected by this problem:
A455LD
K401LB
K501LB
K501LX
R409L
V502LX
X302LA
X450LCP
X450LD
X455LAB
X455LDB
X455LF
Z450LA
[1]: https://marc.info/?l=linux-input&m=144312209020616&w=2
Fixes: "ETPS/2 Elantech Touchpad dies after resume from suspend"
(https://bugzilla.kernel.org/show_bug.cgi?id=107971)
Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
commit 24b923f073ac37eb744f56a2c7f77107b8219ab2 upstream.
This device uses GPIOs: 28 to switch between analog and
digital modes: on digital mode, it should be set to 1.
The code that sets it on analog mode is OK, but it misses
the logic that sets it on digital mode.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
commit 1871d718a9db649b70f0929d2778dc01bc49b286 upstream.
The cx231xx_set_agc_analog_digital_mux_select() callers
expect it to return 0 or an error. Returning a positive value
makes the first attempt to switch between analog/digital to fail.
commit 505a0ea706fc1db4381baa6c6bd2e596e730a55e upstream.
With the current settings, only one channel locks properly.
That's likely because, when this driver was written, Brazil
were still using experimental transmissions.
Change it to reproduce the settings used by the newer drivers.
That makes it lock on other channels.
Tested with both PixelView SBTVD Hybrid (cx231xx-based) and
C3Tech Digital Duo HDTV/SDTV (em28xx-based) devices.
commit dafb65fb98d85d8e78405e82c83e81975e5d5480 upstream.
On this frontend, it takes a while to start output normal
TS data. That only happens on state S9. On S8, the TS output
is enabled, but it is not reliable enough.
However, the zigzag loop is too fast to let it sync.
As, on practical tests, the zigzag software loop doesn't
seem to be helping, but just slowing down the tuning, let's
switch to hardware algorithm, as the tuners used on such
devices are capable of work with frequency drifts without
any help from software.
commit d50b3f43db739f03fcf8c0a00664b3d2fed0496e upstream.
When using efifb with a 16-bit (5:6:5) visual, fbcon's text is rendered
in the wrong colors - e.g. text gray (#aaaaaa) is rendered as green
(#50bc50) and neighboring pixels have slightly different values
(such as #50bc78).
The reason is that fbcon loads its 16 color palette through
efifb_setcolreg(), which in turn calculates a 32-bit value to write
into memory for each palette index.
Until now, this code could only handle 8-bit visuals and didn't mask
overlapping values when ORing them.
With this patch, fbcon displays the correct colors when a qemu VM is
booted in 16-bit mode (in GRUB: "set gfxpayload=800x600x16").
Fixes: 7c83172b98e5 ("x86_64 EFI boot support: EFI frame buffer driver") # v2.6.24+
Signed-off-by: Max Staudt <mstaudt@suse.de>
Acked-By: Peter Jones <pjones@redhat.com>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit e7cb08e894a0b876443ef8fdb0706575dc00a5d2 upstream.
We accidentally overwrite the original saved value of "flags" so that we
can't re-enable IRQs at the end of the function. Presumably this
function is mostly called with IRQs disabled or it would be obvious in
testing.
Fixes: aceeffbb59bb ("zfcp: trace full payload of all SAN records (req,resp,iels)")
Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com>
commit aceeffbb59bb91404a0bda32a542d7ebf878433a upstream.
This was lost with commit 2c55b750a884b86dea8b4cc5f15e1484cc47a25c
("[SCSI] zfcp: Redesign of the debug tracing for SAN records.")
but is necessary for problem determination, e.g. to see the
currently active zone set during automatic port scan.
For the large GPN_FT response (4 pages), save space by not dumping
any empty residual entries.
Fixes: 2c55b750a884 ("[SCSI] zfcp: Redesign of the debug tracing for SAN records.")
Reviewed-by: Alexey Ishchuk <aishchuk@linux.vnet.ibm.com>
Reviewed-by: Benjamin Block <bblock@linux.vnet.ibm.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
commit 94db3725f049ead24c96226df4a4fb375b880a77 upstream.
started to add FC_CT_HDR_LEN which made zfcp dump random data
out of bounds for RSPN GS responses because u.rspn.rsp
is the largest and last field in the union of struct zfcp_fc_req.
Other request/response types only happened to stay within bounds
due to the padding of the union or
due to the trace capping of u.gspn.rsp to ZFCP_DBF_SAN_MAX_PAYLOAD.
Timestamp : ...
Area : SAN
Subarea : 00
Level : 1
Exception : -
CPU id : ..
Caller : ...
Record id : 2
Tag : fsscth2
Request id : 0x...
Destination ID : 0x00fffffc
Payload short : 01000000 fc020000 80020000 00000000
xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx <===
00000000 00000000 00000000 00000000
Payload length : 32 <===
struct zfcp_fc_req {
[0] struct zfcp_fsf_ct_els ct_els;
[56] struct scatterlist sg_req;
[96] struct scatterlist sg_rsp;
union {
struct {req; rsp;} adisc; SIZE: 28+28= 56
struct {req; rsp;} gid_pn; SIZE: 24+20= 44
struct {rspsg; req;} gpn_ft; SIZE: 40*4+20=180
struct {req; rsp;} gspn; SIZE: 20+273= 293
struct {req; rsp;} rspn; SIZE: 277+16= 293
[136] } u;
commit 771bf03537ddfa4a4dde62ef9dfbc82e4f77ab20 upstream.
With commit 2c55b750a884b86dea8b4cc5f15e1484cc47a25c
we lost the N_Port-ID where an ELS response comes from.
With commit 7c7dc196814b9e1d5cc254dc579a5fa78ae524f7
("[SCSI] zfcp: Simplify handling of ct and els requests")
we lost the N_Port-ID where a CT response comes from.
It's especially useful if the request SAN trace record
with D_ID was already lost due to trace buffer wrap.
GS uses an open WKA port handle and ELS just a D_ID, and
only for ELS we could get D_ID from QTCB bottom via zfcp_fsf_req.
To cover both cases, add a new field to zfcp_fsf_ct_els
and fill it in on request to use in SAN response trace.
Strictly speaking the D_ID on SAN response is the FC frame's S_ID.
We don't need a field for the other end which is always us.
Fixes: 7c7dc196814b ("[SCSI] zfcp: Simplify handling of ct and els requests")
commit 7c964ffe586bc0c3d9febe9bf97a2e4b2866e5b7 upstream.
This information was lost with
commit a54ca0f62f953898b05549391ac2a8a4dad6482b
("[SCSI] zfcp: Redesign of the debug tracing for HBA records.")
but is required to debug e.g. invalid handle situations.
Fixes: a54ca0f62f95 ("[SCSI] zfcp: Redesign of the debug tracing for HBA records.")
commit d27a7cb91960cf1fdd11b10071e601828cbf4b1f upstream.
Since commit a54ca0f62f953898b05549391ac2a8a4dad6482b
HBA records no longer contain WWPN, D_ID, or LUN
to reduce duplicate information which is already in REC records.
In contrast to "regular" target ports, we don't use recovery to open
WKA ports such as directory/nameserver, so we don't get REC records.
Therefore, introduce pseudo REC running records without any
actual recovery action but including D_ID of WKA port on open/close.
commit 0102a30a6ff60f4bb4c07358ca3b1f92254a6c25 upstream.
bring back
commit d21e9daa63e009ce5b87bbcaa6d11ce48e07bbbe
("[SCSI] zfcp: Dont use 0 to indicate invalid LUN in rec trace")
which was lost with
commit ae0904f60fab7cb20c48d32eefdd735e478b91fb
("[SCSI] zfcp: Redesign of the debug tracing for recovery actions.")
Fixes: ae0904f60fab ("[SCSI] zfcp: Redesign of the debug tracing for recovery actions.")
commit 35f040df97fa0e94c7851c054ec71533c88b4b81 upstream.
While retaining the actual filtering according to trace level,
the following commits started to write such filtered records
with a hardcoded record level of 1 instead of the actual record level:
commit 250a1352b95e1db3216e5c5d4f4365bea5122f4a
("[SCSI] zfcp: Redesign of the debug tracing for SCSI records.")
Now we can distinguish written records again for offline level filtering.
Fixes: 250a1352b95e ("[SCSI] zfcp: Redesign of the debug tracing for SCSI records.")
commit 4eeaa4f3f1d6c47b69f70e222297a4df4743363e upstream.
On a successful end of reopen port forced,
zfcp_erp_strategy_followup_success() re-uses the port erp_action
and the subsequent zfcp_erp_action_cleanup() now
sees ZFCP_ERP_SUCCEEDED with
erp_action->action==ZFCP_ERP_ACTION_REOPEN_PORT
instead of ZFCP_ERP_ACTION_REOPEN_PORT_FORCED
but must not perform zfcp_scsi_schedule_rport_register().
We can detect this because the fresh port reopen erp_action
is in its very first step ZFCP_ERP_STEP_UNINITIALIZED.
Otherwise this opens a time window with unblocked rport
(until the followup port reopen recovery would block it again).
If a scsi_cmnd timeout occurs during this time window
fc_timed_out() cannot work as desired and such command
would indeed time out and trigger scsi_eh. This prevents
a clean and timely path failover.
This should not happen if the path issue can be recovered
on FC transport layer such as path issues involving RSCNs.
Also, unnecessary and repeated DID_IMM_RETRY for pending and
undesired new requests occur because internally zfcp still
has its zfcp_port blocked.
As follow-on errors with scsi_eh, it can cause,
in the worst case, permanently lost paths due to one of:
sd <scsidev>: [<scsidisk>] Medium access timeout failure. Offlining disk!
sd <scsidev>: Device offlined - not ready after error recovery
For fix validation and to aid future debugging with other recoveries
we now also trace (un)blocking of rports.
Fixes: 5767620c383a ("[SCSI] zfcp: Do not unblock rport from REOPEN_PORT_FORCED")
Fixes: a2fa0aede07c ("[SCSI] zfcp: Block FC transport rports early on errors")
Fixes: 5f852be9e11d ("[SCSI] zfcp: Fix deadlock between zfcp ERP and SCSI")
Fixes: 338151e06608 ("[SCSI] zfcp: make use of fc_remote_port_delete when target port is unavailable")
Fixes: 3859f6a248cb ("[PATCH] zfcp: add rports to enable scsi_add_device to work again")
commit 70369f8e15b220f50a16348c79a61d3f7054813c upstream.
In the hardware data router case, introduced with kernel 3.2
commit 86a9668a8d29 ("[SCSI] zfcp: support for hardware data router")
the ELS/GS request&response length needs to be initialized
as in the chained SBAL case.
Otherwise, the FCP channel rejects ELS requests with
FSF_REQUEST_SIZE_TOO_LARGE.
Such ELS requests can be issued by user space through BSG / HBA API,
or zfcp itself uses ADISC ELS for remote port link test on RSCN.
The latter can cause a short path outage due to
unnecessary remote target port recovery because the always
failing ADISC cannot detect extremely short path interruptions
beyond the local FCP channel.
Below example is decoded with zfcpdbf from s390-tools:
Timestamp : ...
Area : SAN
Subarea : 00
Level : 1
Exception : -
CPU id : ..
Caller : zfcp_dbf_san_req+0408
Record id : 1
Tag : fssels1
Request id : 0x<reqid>
Destination ID : 0x00<target d_id>
Payload info : 52000000 00000000 <our wwpn > [ADISC]
<our wwnn > 00<s_id> 00000000
Timestamp : ...
Area : HBA
Subarea : 00
Level : 1
Exception : -
CPU id : ..
Caller : zfcp_dbf_hba_fsf_res+0740
Record id : 1
Tag : fs_ferr
Request status : 0x00000010
FSF cmnd : 0x0000000b [FSF_QTCB_SEND_ELS]
FSF sequence no: 0x...
FSF issued : ...
FSF stat : 0x00000061 [FSF_REQUEST_SIZE_TOO_LARGE]
FSF stat qual : 00000000 00000000 00000000 00000000
Prot stat : 0x00000100
Prot stat qual : 00000000 00000000 00000000 00000000
Fixes: 86a9668a8d29 ("[SCSI] zfcp: support for hardware data router")
commit bd77befa5bcff8c51613de271913639edf85fbc2 upstream.
For an NPIV-enabled FCP device, zfcp can erroneously show
"NPort (fabric via point-to-point)" instead of "NPIV VPORT"
for the port_type sysfs attribute of the corresponding
fc_host.
s390-tools that can be affected are dbginfo.sh and ziomon.
zfcp_fsf_exchange_config_evaluate() ignores
fsf_qtcb_bottom_config.connection_features indicating NPIV
and only sets fc_host_port_type to FC_PORTTYPE_NPORT if
fsf_qtcb_bottom_config.fc_topology is FSF_TOPO_FABRIC.
Only the independent zfcp_fsf_exchange_port_evaluate()
evaluates connection_features to overwrite fc_host_port_type
to FC_PORTTYPE_NPIV in case of NPIV.
Code was introduced with upstream kernel 2.6.30
commit 0282985da5923fa6365adcc1a1586ae0c13c1617
("[SCSI] zfcp: Report fc_host_port_type as NPIV").
This works during FCP device recovery (such as set online)
because it performs FSF_QTCB_EXCHANGE_CONFIG_DATA followed by
FSF_QTCB_EXCHANGE_PORT_DATA in sequence.
However, the zfcp-specific scsi host sysfs attributes
"requests", "megabytes", or "seconds_active" trigger only
zfcp_fsf_exchange_config_evaluate() resetting fc_host
port_type to FC_PORTTYPE_NPORT despite NPIV.
The zfcp-specific scsi host sysfs attribute "utilization"
triggers only zfcp_fsf_exchange_port_evaluate() correcting
the fc_host port_type again in case of NPIV.
Evaluate fsf_qtcb_bottom_config.connection_features
in zfcp_fsf_exchange_config_evaluate() where it belongs to.
Fixes: 0282985da592 ("[SCSI] zfcp: Report fc_host_port_type as NPIV")
commit 2365418879e9abf12ea9def7f9f3caf0dfa7ffb0 upstream.
When Fastmap is used we can face here an -EBADMSG
since Fastmap cannot know about unmaps.
If the erasure was interrupted the PEB may show ECC
errors and UBI would go to ro-mode as it assumes
that the PEB was check during attach time, which is
not the case with Fastmap.
Fixes: dbb7d2a88d ("UBI: Add fastmap core")
Signed-off-by: Richard Weinberger <richard@nod.at>
commit f659b10087daaf4ce0087c3f6aec16746be9628f upstream.
As the documentation for kthread_stop() says, "if threadfn() may call
do_exit() itself, the caller must ensure task_struct can't go away".
dm-crypt does not ensure this and therefore crashes when crypt_dtr()
calls kthread_stop(). The crash is trivially reproducible by adding a
delay before the call to kthread_stop() and just opening and closing a
dm-crypt device.
general protection fault: 0000 [#1] PREEMPT SMP
CPU: 0 PID: 533 Comm: cryptsetup Not tainted 4.8.0-rc7+ #7
task: ffff88003bd0df40 task.stack: ffff8800375b4000
RIP: 0010: kthread_stop+0x52/0x300
Call Trace:
crypt_dtr+0x77/0x120
dm_table_destroy+0x6f/0x120
__dm_destroy+0x130/0x250
dm_destroy+0x13/0x20
dev_remove+0xe6/0x120
? dev_suspend+0x250/0x250
ctl_ioctl+0x1fc/0x530
? __lock_acquire+0x24f/0x1b10
dm_ctl_ioctl+0x13/0x20
do_vfs_ioctl+0x91/0x6a0
? ____fput+0xe/0x10
? entry_SYSCALL_64_fastpath+0x5/0xbd
? trace_hardirqs_on_caller+0x151/0x1e0
SyS_ioctl+0x41/0x70
entry_SYSCALL_64_fastpath+0x1f/0xbd
This problem was introduced by bcbd94ff481e ("dm crypt: fix a possible
hang due to race condition on exit").
Looking at the description of that patch (excerpted below), it seems
like the problem it addresses can be solved by just using
set_current_state instead of __set_current_state, since we obviously
need the memory barrier.
| dm crypt: fix a possible hang due to race condition on exit
| A kernel thread executes __set_current_state(TASK_INTERRUPTIBLE),
| __add_wait_queue, spin_unlock_irq and then tests kthread_should_stop().
| It is possible that the processor reorders memory accesses so that
| kthread_should_stop() is executed before __set_current_state(). If
| such reordering happens, there is a possible race on thread
| termination: [...]
So this patch just reverts the aforementioned patch and changes the
__set_current_state(TASK_INTERRUPTIBLE) to set_current_state(...). This
fixes the crash and should also fix the potential hang.
Fixes: bcbd94ff481e ("dm crypt: fix a possible hang due to race condition on exit")
Cc: Mikulas Patocka <mpatocka@redhat.com>
Signed-off-by: Rabin Vincent <rabinv@axis.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit f10e06b744074824fb8ec7066bc03ecc90918f5b upstream.
If pg_init_retries is set and a request is queued against a multipath
device with all underlying block device request_queues in the "dying"
state then an infinite loop is triggered because activate_path() never
succeeds and hence never calls pg_init_done().
This change avoids that device removal triggers an infinite loop by
failing the activate_path() which causes the "dying" path to be failed.
Reported-by: Bart Van Assche <bart.vanassche@sandisk.com>
commit 8dc23658b7aaa8b6b0609c81c8ad75e98b612801 upstream.
dm_resume() will return success (0) rather than -EINVAL if
!dm_suspended_md() upon retry within dm_resume().
Reset the error code at the start of dm_resume()'s retry loop.
Also, remove a useless assignment at the end of dm_resume().
Fixes: ffcc393641 ("dm: enhance internal suspend and resume interface")
Signed-off-by: Minfei Huang <mnghuan@gmail.com>
commit 3b785fbcf81c3533772c52b717f77293099498d3 upstream.
This avoids that new requests are queued while __dm_destroy() is in
progress.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
commit f9f4872df6e1801572949f8a370c886122d4b6da upstream.
This is a requirement that MSR MSR_PM_ENABLE must be set to 0x01 before
reading MSR_HWP_CAPABILITIES on a given CPU. If cpufreq init() is
scheduled on a CPU which is not same as policy->cpu or migrates to a
different CPU before calling msr read for MSR_HWP_CAPABILITIES, it
is possible that MSR_PM_ENABLE was not to set to 0x01 on that CPU.
This will cause GP fault. So like other places in this path
rdmsrl_on_cpu should be used instead of rdmsrl.
Moreover the scope of MSR_HWP_CAPABILITIES is on per thread basis, so it
should be read from the same CPU, for which MSR MSR_HWP_REQUEST is
getting set.
dmesg dump or warning:
[ 22.014488] WARNING: CPU: 139 PID: 1 at arch/x86/mm/extable.c:50 ex_handler_rdmsr_unsafe+0x68/0x70
[ 22.014492] unchecked MSR access error: RDMSR from 0x771
[ 22.014493] Modules linked in:
[ 22.014507] CPU: 139 PID: 1 Comm: swapper/0 Not tainted 4.7.5+ #1
[ 22.014516] Call Trace:
[ 22.014542] [<ffffffff813d7dd1>] dump_stack+0x63/0x82
[ 22.014558] [<ffffffff8107bc8b>] __warn+0xcb/0xf0
[ 22.014561] [<ffffffff8107bcff>] warn_slowpath_fmt+0x4f/0x60
[ 22.014563] [<ffffffff810676f8>] ex_handler_rdmsr_unsafe+0x68/0x70
[ 22.014564] [<ffffffff810677d9>] fixup_exception+0x39/0x50
[ 22.014604] [<ffffffff8102e400>] do_general_protection+0x80/0x150
[ 22.014610] [<ffffffff817f9ec8>] general_protection+0x28/0x30
[ 22.014635] [<ffffffff81687940>] ? get_target_pstate_use_performance+0xb0/0xb0
[ 22.014642] [<ffffffff810600c7>] ? native_read_msr+0x7/0x40
[ 22.014657] [<ffffffff81688123>] intel_pstate_hwp_set+0x23/0x130
[ 22.014660] [<ffffffff81688406>] intel_pstate_set_policy+0x1b6/0x340
[ 22.014662] [<ffffffff816829bb>] cpufreq_set_policy+0xeb/0x2c0
[ 22.014664] [<ffffffff81682f39>] cpufreq_init_policy+0x79/0xe0
[ 22.014666] [<ffffffff81682cb0>] ? cpufreq_update_policy+0x120/0x120
[ 22.014669] [<ffffffff816833a6>] cpufreq_online+0x406/0x820
[ 22.014671] [<ffffffff8168381f>] cpufreq_add_dev+0x5f/0x90
[ 22.014717] [<ffffffff81530ac8>] subsys_interface_register+0xb8/0x100
[ 22.014719] [<ffffffff816821bc>] cpufreq_register_driver+0x14c/0x210
[ 22.014749] [<ffffffff81fe1d90>] intel_pstate_init+0x39d/0x4d5
[ 22.014751] [<ffffffff81fe13f2>] ? cpufreq_gov_dbs_init+0x12/0x12
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
commit e330b9a6bb35dc7097a4f02cb1ae7b6f96df92af upstream.
of_irq_get[_byname]() return 0 iff irq_create_of_mapping() call fails.
Returning both error code and 0 on failure is a sign of a misdesigned API,
it makes the failure check unnecessarily complex and error prone. We should
rely on the platform IRQ resource in this case, not return 0, especially
as 0 can be a valid IRQ resource too...
Fixes: aff008ad813c ("platform_get_irq: Revert to platform_get_resource if of_irq_get fails")
Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com>
commit 8e2e03179923479ca0c0b6fdc7c93ecf89bce7a8 upstream.
Similar to the AR93xx and the AR94xx series, the AR95xx also have the same
quirk for the Bus Reset. It will lead to instant system reset if the
device is assigned via VFIO to a KVM VM. I've been able reproduce this
behavior with a MikroTik R11e-2HnD.
Fixes: c3e59ee4e766 ("PCI: Mark Atheros AR93xx to avoid bus reset")
Signed-off-by: Maik Broemme <mbroemme@libmpq.org>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit 02265cd60335a2c1417abae4192611e1fc05a6e5 upstream.
Potentially overflowing expression 1000000 * data->timeout_clks with
type unsigned int is evaluated using 32-bit arithmetic, and then used
in a context that expects an expression of type unsigned long long.
To avoid overflow, cast 1000000U to type unsigned long long.
Special thanks to Coverity.
Fixes: 7f05538af71c ("mmc: sdhci: fix data timeout (part 2)")
Signed-off-by: Haibo Chen <haibo.chen@nxp.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
commit 0ed50abb2d8fc81570b53af25621dad560cd49b3 upstream.
CMD23 aka SET_BLOCK_COUNT was introduced with MMC v3.1.
Older versions of the specification allowed to terminate
multi-block transfers only with CMD12.
The patch fixes the following problem:
mmc0: new MMC card at address 0001
mmcblk0: mmc0:0001 SDMB-16 15.3 MiB
mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
blk_update_request: I/O error, dev mmcblk0, sector 0
Buffer I/O error on dev mmcblk0, logical block 0, async page read
mmcblk0: unable to read partition table
Signed-off-by: Daniel Glöckner <dg@emlix.com>
commit 0c9d3491530773858ff9d705ec2a9c382f449230 upstream.
Some RTL8821AE devices sold in Great Britain have the country code of
0x25 encoded in their EEPROM. This value is not tested in the routine
that establishes the regulatory info for the chip. The fix is to set
this code to have the same capabilities as the EU countries. In addition,
the channels allowed for COUNTRY_CODE_ETSI were more properly suited
for China and Israel, not the EU. This problem has also been fixed.
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
commit d8846023aed1293e54d33499558fc2aa2b2f393f upstream.
Initialize the GPU clock muxes to sane inputs. Until now they have
not been changed from their default values, which means that both
GPU3D shader and GPU2D core were fed by clock inputs whose rates
exceed the maximium allowed frequency of the cores by as much as
200MHz.
This fixes a severe GPU stability issue on i.MX6DL.
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Acked-by: Shawn Guo <shawnguo@kernel.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
commit 8f9165c981fed187bb483de84caf9adf835aefda upstream.
http://www.ti.com/lit/pdf/SWCZ010:
DCDC o/p voltage can go higher than programmed value
Impact:
VDDI, VDD2, and VIO output programmed voltage level can go higher than
expected or crash, when coming out of PFM to PWM mode or using DVFS.
Description:
When DCDC CLK SYNC bits are 11/01:
* VIO 3-MHz oscillator is the source clock of the digital core and input
clock of VDD1 and VDD2
* Turn-on of VDD1 and VDD2 HSD PFETis synchronized or at a constant
phase shift
* Current pulled though VCC1+VCC2 is Iload(VDD1) + Iload(VDD2)
* The 3 HSD PFET will be turned-on at the same time, causing the highest
possible switching noise on the application. This noise level depends
on the layout, the VBAT level, and the load current. The noise level
increases with improper layout.
When DCDC CLK SYNC bits are 00:
* VIO 3-MHz oscillator is the source clock of digital core
* VDD1 and VDD2 are running on their own 3-MHz oscillator
* Current pulled though VCC1+VCC2 average of Iload(VDD1) + Iload(VDD2)
* The switching noise of the 3 SMPS will be randomly spread over time,
causing lower overall switching noise.
Workaround:
Set DCDCCTRL_REG[1:0]= 00.
Signed-off-by: Jan Remmet <j.remmet@phytec.de>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit ac182e8abc6f93c1c4cc12f042af64c9d7be0d1e upstream.
Add device ids for Intel Kabypoint PCH (Kabylake)
Signed-off-by: Alexander Usyskin <alexander.usyskin@intel.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
commit d71cf15b865bdd45925f7b094d169aaabd705145 upstream.
From the beginning of the gpio-mpc8xxx.c, the "handle_level_irq"
has being used to handle GPIO interrupts in the PowerPC/Layerscape
platforms. But actually, almost all PowerPC/Layerscape platforms
assert an interrupt request upon either a high-to-low change or
any change on the state of the signal.
So the "handle_level_irq" is not reasonable for PowerPC/Layerscape
GPIO interrupt, it should be "handle_edge_irq". Otherwise the system
may lost some interrupts from the PIN's state changes.
Signed-off-by: Liu Gang <Gang.Liu@nxp.com>
commit 80da44c29d997e28c4442825f35f4ac339813877 upstream.
This patch changes the p8_ghash driver to use ghash-generic as a fixed
fallback implementation. This allows the correct value of descsize to be
defined directly in its shash_alg structure and avoids problems with
incorrect buffer sizes when its state is exported or imported.
Reported-by: Jan Stancek <jstancek@redhat.com>
Fixes: cc333cd68dfa ("crypto: vmx - Adding GHASH routines for VMX module")
Signed-off-by: Marcelo Cerri <marcelo.cerri@canonical.com>
