commit 668f9abbd4334e6c29fa8acd71635c4f9101caa7 upstream.
Commit bf6bddf1924e ("mm: introduce compaction and migration for
ballooned pages") introduces page_count(page) into memory compaction
which dereferences page->first_page if PageTail(page).
This results in a very rare NULL pointer dereference on the
aforementioned page_count(page). Indeed, anything that does
compound_head(), including page_count() is susceptible to racing with
prep_compound_page() and seeing a NULL or dangling page->first_page
pointer.
This patch uses Andrea's implementation of compound_trans_head() that
deals with such a race and makes it the default compound_head()
implementation. This includes a read memory barrier that ensures that
if PageTail(head) is true that we return a head page that is neither
NULL nor dangling. The patch then adds a store memory barrier to
prep_compound_page() to ensure page->first_page is set.
This is the safest way to ensure we see the head page that we are
expecting, PageTail(page) is already in the unlikely() path and the
memory barriers are unfortunately required.
Hugetlbfs is the exception, we don't enforce a store memory barrier
during init since no race is possible.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Holger Kiehl <Holger.Kiehl@dwd.de>
Cc: Christoph Lameter <cl@linux.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
commit e3a8786c10e75903f1269474e21fe8cb49c3a670 upstream.
Commit 5445eaf309ff ('mvneta: Try to fix mvneta when compiled as
module') fixed the mvneta driver to make it work properly when loaded
as a module in SGMII configuration, which was tested successful by the
author on the Armada XP OpenBlocks AX3, which uses SGMII.
However, it turns out that the Armada XP GP, which uses RGMII, is
affected by a similar problem: its SERDES configuration is lost when
mvneta is loaded as a module, because this configuration is set by the
bootloader, and then lost because the clock is gated by the clock
framework until the mvneta driver is loaded again and the clock is
re-enabled.
However, it turns out that for the RGMII case, setting the SERDES
configuration is not sufficient: the PCS enable bit in the
MVNETA_GMAC_CTRL_2 register must also be set, like in the SGMII
configuration.
Therefore, this commit reworks the SGMII/RGMII initialization: the
only difference between the two now is a different SERDES
configuration, all the rest is identical.
In detail, to achieve this, the commit:
* Renames MVNETA_SGMII_SERDES_CFG to MVNETA_SERDES_CFG because it is
not specific to SGMII, but also used on RGMII configurations.
* Adds a MVNETA_RGMII_SERDES_PROTO definition, that must be used as
the MVNETA_SERDES_CFG value in RGMII configurations.
* Removes the mvneta_gmac_rgmii_set() and mvneta_port_sgmii_config()
functions, and instead directly do the SGMII/RGMII configuration in
mvneta_port_up(), from where those functions where called. It is
worth mentioning that mvneta_gmac_rgmii_set() had an 'enable'
parameter that was always passed as '1', so it was pretty useless.
* Reworks the mvneta_port_up() function to set the MVNETA_SERDES_CFG
register to the appropriate value depending on the RGMII vs. SGMII
configuration. It also unconditionally set the PCS_ENABLE bit (was
already done for SGMII, but is now also needed for RGMII), and sets
the PORT_RGMII bit (which was already done for both SGMII and
RGMII).
This commit was successfully tested with mvneta compiled as a module,
on both the OpenBlocks AX3 (SGMII configuration) and the Armada XP GP
(RGMII configuration).
Reported-by: Steve McIntyre <steve@einval.com>
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
commit a79121d3b57e7ad61f0b5d23eae05214054f3ccd upstream.
Bit 3 of the MVNETA_GMAC_CTRL_2 is actually used to enable the PCS,
not the PSC: there was a typo in the name of the define, which this
commit fixes.
commit 8ee661b505613ef2747b350ca2871a31b3781bee upstream.
It apparently blows up on some machines. This functionally reverts
commit 828c79087cec61eaf4c76bb32c222fbe35ac3930
Author: Ben Widawsky <benjamin.widawsky@intel.com>
Date: Wed Oct 16 09:21:30 2013 -0700
drm/i915: Disable GGTT PTEs on GEN6+ suspend
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=64841
Reported-and-Tested-by: Brad Jackson <bjackson0971@gmail.com>
Cc: Takashi Iwai <tiwai@suse.de>
Cc: Paulo Zanoni <paulo.r.zanoni@intel.com>
Cc: Todd Previte <tprevite@gmail.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 5f12c5eca6e6b7aeb4b2028d579f614b4fe7a81f upstream.
Fixes a build break due to the undeclared use of irq_of_parse_and_map()
and of_iomap(). This build break was apparently introduced while the
driver was unbuildable due to the bug fixed by
62c19c9d29e65086e5ae76df371ed2e6b23f00cd ("i2c: Remove usage of
orphaned symbol OF_I2C"). When 62c19c was added in v3.14-rc7,
the driver was enabled again, breaking the powerpc mpc85xx_defconfig
and mpc85xx_smp_defconfig.
62c19c is marked for stable, so this should go there as well.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
commit 09ed3d5ba06137913960f9c9385f71fc384193ab upstream.
Xen balloon driver will update ballooned out pages' P2M entries to point
to scratch page for PV guests. In 24f69373e2 ("xen/balloon: don't alloc
page while non-preemptible", kmap_flush_unused was moved after updating
P2M table. In that case for 32 bit PV guest we might end up with
P2M X -----> S (S is mfn of balloon scratch page)
M2P Y -----> X (Y is mfn in persistent kmap entry)
kmap_flush_unused() iterates through all the PTEs in the kmap address
space, using pte_to_page() to obtain the page. If the p2m and the m2p
are inconsistent the incorrect page is returned. This will clear
page->address on the wrong page which may cause subsequent oopses if
that page is currently kmap'ed.
Move the flush back between get_page and __set_phys_to_machine to fix
this.
Signed-off-by: Wei Liu <wei.liu2@citrix.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
commit 6797b39e6f6f34c74177736e146406e894b9482b upstream.
The cypress PS/2 trackpad models supported by the cypress_ps2 driver
emulate BTN_RIGHT events in firmware based on the finger position, as part
of this no motion events are sent when the finger is in the button area.
The INPUT_PROP_BUTTONPAD property is there to indicate to userspace that
BTN_RIGHT events should be emulated in userspace, which is not necessary
in this case.
When INPUT_PROP_BUTTONPAD is advertised userspace will wait for a motion
event before propagating the button event higher up the stack, as it needs
current abs x + y data for its BTN_RIGHT emulation. Since in the
cypress_ps2 pads don't report motion events in the button area, this means
that clicks in the button area end up being ignored, so
INPUT_PROP_BUTTONPAD actually causes problems for these touchpads, and
removing it fixes:
https://bugs.freedesktop.org/show_bug.cgi?id=76341
Reported-by: Adam Williamson <awilliam@redhat.com>
Tested-by: Adam Williamson <awilliam@redhat.com>
Reviewed-by: Peter Hutterer <peter.hutterer@who-t.net>
commit 8a0435d958fb36d93b8df610124a0e91e5675c82 upstream.
This extends Benjamin Tissoires manual min/max quirk table with support for
the ThinkPad X240.
commit 421e08c41fda1f0c2ff6af81a67b491389b653a5 upstream.
The new Lenovo Haswell series (-40's) contains a new Synaptics touchpad.
However, these new Synaptics devices report bad axis ranges.
Under Windows, it is not a problem because the Windows driver uses RMI4
over SMBus to talk to the device. Under Linux, we are using the PS/2
fallback interface and it occurs the reported ranges are wrong.
Of course, it would be too easy to have only one range for the whole
series, each touchpad seems to be calibrated in a different way.
We can not use SMBus to get the actual range because I suspect the firmware
will switch into the SMBus mode and stop talking through PS/2 (this is the
case for hybrid HID over I2C / PS/2 Synaptics touchpads).
So as a temporary solution (until RMI4 land into upstream), start a new
list of quirks with the min/max manually set.
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit e4dbedc7eac7da9db363a36f2bd4366962eeefcc upstream.
We should not be using static variable mousedev_mix in methods that can be
called before that singleton gets assigned. While at it let's add open and
close methods to mousedev structure so that we do not need to test if we
are dealing with multiplexor or normal device and simply call appropriate
method directly.
This fixes: https://bugzilla.kernel.org/show_bug.cgi?id=71551
Reported-by: GiulioDP <depasquale.giulio@gmail.com>
Tested-by: GiulioDP <depasquale.giulio@gmail.com>
commit b5fd2a3e92ca5c8c1f3c20d31ac5daed3ec4d604 upstream.
Two tablets in this series support both pen and touch. One (Intuos S)
only supports pen. This patch also updates the driver to process wireless
devices that do not support touch interface.
Tested-by: Jason Gerecke <killertofu@gmail.com>
Acked-by: Chris Bagwell <chris@cnpbagwell.com>
Signed-off-by: Ping Cheng <pingc@wacom.com>
commit f5d2b7c28b67d627646b6a0142bc201a7b1516b0 upstream.
Documentation/fb/modedb.txt states that video=option should be
considered a global option. But video_setup and fb_get_options are not
coded that way. Instead its required to boot with video=driver:option to
set a given option in drvier. This is cumbersome because it requires to
know in advance which driver will be active for a given board/kernel.
The following patch implements the documented catchall for the fbdev
drivers. It is now possible to boot with video=XxY without the need to
know the active driver in advance. The specific case it tries to fix is
syslinux in the SUSE installer which offers a menu to set a display
resolution. Right now this just appends the vga= option the kernel. But
in addition to vga= it should be possible to pass a generic video=XxY
for all framebuffer/drm drivers. With this change forcing a certain
window size of VM displays is now much easier.
Today the video= option is stored in a global fb_mode_option. But
unfortunately only drm uses it.
Note: this change introduces a small memleak if video=option is actually
used because fb_mode_option is const. Most drivers use strsep to get to
individual options. This could be fixed in a followup patch which always
releases the option string in every caller of fb_get_options.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit d0ce7b8567ae76b8a6c0eb8361d121deb98c1b3f upstream.
Commit 8116188fdef594 ("nouveau/acpi: hook up to the MXM method for mux
switching.") broke the build on non-x86 architectures due to the new
dependency on MXM and MXM being an x86 platform driver.
It built previously since the vga switcheroo registration routines were
zereod out on !X86. The code was built in but unused.
This patch makes all of the DSM code depend on CONFIG_VGA_SWITCHEROO,
allowing it to build on non-x86 and shrinking the module size as well.
[rdunlap@infradead.org: fix build eror when VGA_SWITCHEROO is not enabled]
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
Cc: David Airlie <airlied@linux.ie>
commit 22e580d07f6529a395c129575127ea6d860aed3a upstream.
Corrected the MWAIT flag for C-State C6 on Intel Avoton/Rangeley processors.
Signed-off-by: Arne Bockholdt <linux-kernel@bockholdt.com>
Acked-by: Len Brown <len.brown@intel.com>
commit fab04b2208dd1d4121319f0096c5a5f4b70abc54 upstream.
Support the "Intel(R) Atom(TM) Processor C2000 Product Family",
formerly code-named Avoton. It is based on the next generation
Intel Atom processor architecture, formerly code-named Silvermont.
Signed-off-by: Len Brown <len.brown@intel.com>
commit afc659241258b40b683998ec801d25d276529f43 upstream.
This patch adds the SMBus Device IDs for the Intel Wildcat Point-LP PCH.
Signed-off-by: James Ralston <james.d.ralston@intel.com>
commit 2b6e0ca175fe4a20f21ba82b1e7ccc71029c4dd4 upstream.
In https://bugzilla.redhat.com/show_bug.cgi?id=994438 and
https://bugzilla.redhat.com/show_bug.cgi?id=970480 we
received different reports of e100 throwing the following
warning:
[<c06a0ba5>] ? pci_disable_device+0x85/0x90
[<c044a153>] warn_slowpath_fmt+0x33/0x40
[<c06a0ba5>] pci_disable_device+0x85/0x90
[<f7fdf7e0>] __e100_shutdown+0x80/0x120 [e100]
[<c0476ca5>] ? check_preempt_curr+0x65/0x90
[<f7fdf8d6>] e100_suspend+0x16/0x30 [e100]
[<c06a1ebb>] pci_legacy_suspend+0x2b/0xb0
[<c098fc0f>] ? wait_for_completion+0x1f/0xd0
[<c06a2d50>] ? pci_pm_poweroff+0xb0/0xb0
[<c06a2de4>] pci_pm_freeze+0x94/0xa0
[<c0767bb7>] dpm_run_callback+0x37/0x80
[<c076a204>] ? pm_wakeup_pending+0xc4/0x140
[<c0767f12>] __device_suspend+0xb2/0x1f0
[<c076806f>] async_suspend+0x1f/0x90
[<c04706e5>] async_run_entry_fn+0x35/0x140
[<c0478aef>] ? wake_up_process+0x1f/0x40
[<c0464495>] process_one_work+0x115/0x370
[<c0462645>] ? start_worker+0x25/0x30
[<c0464dc5>] ? manage_workers.isra.27+0x1a5/0x250
[<c0464f6e>] worker_thread+0xfe/0x330
[<c0464e70>] ? manage_workers.isra.27+0x250/0x250
[<c046a224>] kthread+0x94/0xa0
[<c0997f37>] ret_from_kernel_thread+0x1b/0x28
[<c046a190>] ? insert_kthread_work+0x30/0x30
This patch removes pci_disable_device() from __e100_shutdown().
pci_clear_master() is enough.
Signed-off-by: Michele Baldessari <michele@acksyn.org>
Tested-by: Mark Harig <idirectscm@aim.com>
Signed-off-by: Aaron Brown <aaron.f.brown@intel.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
commit 1aa9578c1a9450fb21501c4f549f5b1edb557e6d upstream.
Don Zickus <dzickus@redhat.com> writes:
Some co-workers of mine bought Samsung laptops that had mostly usb3 ports.
Those ports did not resume correctly (the driver would timeout communicating
and fail). This led to frustration as suspend/resume is a common use for
laptops.
Poking around, I applied the reset on resume quirk to this chipset and the
resume started working. Reloading the xhci_hcd module had been the temporary
workaround.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Reported-by: Don Zickus <dzickus@redhat.com>
Tested-by: Prarit Bhargava <prarit@redhat.com>
commit 1d0d6df02750b4a6f466768cbfbf860e24f4c8d4 upstream.
Old single touch Tablet PCs do not have touch_max set at
wacom_features. Since touch device at lease supports one
finger, assign touch_max to 1 when touch usage is defined
in its HID Descriptor and touch_max is not pre-defined.
Reviewed-by: Chris Bagwell <chris@cnpbagwell.com>
commit c15bdfd5b9831e4cab8cfc118243956e267dd30e upstream.
The current assumption in the elantech driver that hw version 3 touchpads
are never clickpads and hw version 4 touchpads are always clickpads is
wrong.
There are several bug reports for this, ie:
https://bugzilla.redhat.com/show_bug.cgi?id=1030802
http://superuser.com/questions/619582/right-elantech-touchpad-button-not-working-in-linux
I've spend a couple of hours wading through various bugzillas, launchpads
and forum posts to create a list of fw-versions and capabilities for
different laptop models to find a good method to differentiate between
clickpads and versions with separate hardware buttons.
Which shows that a device being a clickpad is reliable indicated by bit 12
being set in the fw_version. I've included the gathered list inside the
driver, so that we've this info at hand if we need to revisit this later.
Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit 66fda75f47dc583f1c187556e9a2c082dd64f8c6 upstream.
There are many places where ops->disable is called directly. Instead we
should use _regulator_do_disable() which also handles gpio regulators.
To be able to use the wrapper function from _regulator_force_disable(),
I moved the _notifier_call_chain() call from _regulator_do_disable() to
_regulator_disable(). This way, _regulator_force_disable() can use
different flags for _notifier_call_chain() without calling it twice.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit 608cfbe4abaf76e9d732efd7ed1cfa3998163d91 upstream.
The call to clamp_t() first truncates the variable signed 8 bit and as a
result, the actual clamp is a no-op.
Fixes: 0d78156eef1d ('p54: improve site survey')
commit d9317aea16ecec7694271ef11fb7791a0f0d9cc5 upstream.
As part of a workaround for a hardware erratum in the SFC9100 family
(SF bug 35388), the TX_DESC_UPD_DWORD register address is also used
for communicating with the event block, and only descriptor pointer
values < 2048 are valid.
If the TX DMA ring size is increased to 4096 descriptors (which the
firmware still allows) then we may write a descriptor pointer
value >= 2048, which has entirely different and undesirable effects!
Limit the TX DMA ring size correctly when this workaround is in
effect.
Fixes: 8127d661e77f ('sfc: Add support for Solarflare SFC9100 family')
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
Signed-off-by: Shradha Shah <sshah@solarflare.com>
commit e351bf25fa373a3de0be2141b962c5c3c27006a2 upstream.
It upsets static checkers when we don't check for allocation failure. I
moved the memset() of "tv" earlier so we don't use uninitialized data on
error.
Fixes: 1d212cf0c2d8 ('[media] cx18: struct i2c_client is too big for stack')
Acked-by: Andy Walls <awalls@md.metrocast.net>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
commit 324ed533bf0b23c309b805272c4ffcc5d51493a6 upstream.
We recently introduced some new error paths but the unlocks are missing.
Fixes: 0065a79a8698 ('[media] dw2102: Don't use dynamic static allocation')
commit 1cdbcc5db4e6d51ce9bb1313195167cada9aa6e9 upstream.
We recently introduced some new error paths which are missing their
unlocks.
Fixes: 64f7ef8afbf8 ('[media] cxusb: Don't use dynamic static allocation')
commit 33b7107f59a61236d94ecd6b45e20283cd5abcc8 upstream.
In commit 6892b41d9701283085b655c6086fb57a5d63fa47
Author: Lad, Prabhakar <prabhakar.csengg@gmail.com>
Date: Tue Jun 25 21:24:51 2013 +0530
net: davinci: emac: Convert to devm_* api
the call of request_irq is replaced by devm_request_irq and the call
of free_irq is removed. But since interrupts are requested in
emac_dev_open, doing ifconfig up/down on the board requests the
interrupts again each time, causing devm_request_irq to fail. The
interface is dead until the device is rebooted.
This patch reverts said commit partially: It changes the driver back
to use request_irq instead of devm_request_irq, puts free_irq back in
place, but keeps the remaining changes of the original patch.
Reported-by: Jon Ringle <jon@ringle.org>
Signed-off-by: Christian Riesch <christian.riesch@omicron.at>
Cc: Lad, Prabhakar <prabhakar.csengg@gmail.com>
commit 0f4706d2740f2a221cd502922b22e522009041d9 upstream.
We have reports of heavy screen corruption if we try to use the stolen
memory reserved by the BIOS whilst the DMA-Remapper is active. This
quirk may be only specific to a few machines or BIOSes, but first lets
apply the big hammer and always disable use of stolen memory when DMAR
is active.
v2 by Jani: Rebase on -fixes, only look at intel_iommu_gfx_mapped.
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=68535
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit 224aa3ed45c8735ae02bb2ecca002409fa6aa772 upstream.
Vybrids PIT register is monitonic decreasing. However, sched_clock
reading needs to be monitonic increasing. Use bitwise not to get
the complement of the clock register. This fixes the clock going
backward. Also, the clock now starts at 0 since we load the
register with the maximum value at start.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Cc: daniel.lezcano@linaro.org
Cc: linux@arm.linux.org.uk
Link: http://lkml.kernel.org/r/d25af915993aec1b486be653eb86f748ddef54fe.1394057313.git.stefan@agner.ch
commit 47587fc098451c2100dc1fb618855fc2e2d937af upstream.
I noticed that after hot unplugging a Logitech unifying receiver
(drivers/hid/hid-logitech-dj.c) the kernel would occasionally spew a
stack trace similar to this:
usb 1-1.1.2: USB disconnect, device number 7
WARNING: CPU: 0 PID: 2865 at fs/sysfs/group.c:216 device_del+0x40/0x1b0()
sysfs group ffffffff8187fa20 not found for kobject 'hidraw0'
CPU: 0 PID: 2865 Comm: upowerd Tainted: G W 3.14.0-rc4 #7
Hardware name: LENOVO 7783PN4/ , BIOS 9HKT43AUS 07/11/2011
0000000000000009 ffffffff814cd684 ffff880427ccfdf8 ffffffff810616e7
ffff88041ec61800 ffff880427ccfe48 ffff88041e444d80 ffff880426fab8e8
ffff880429359960 ffffffff8106174c ffffffff81714b98 0000000000000028
Call Trace:
[<ffffffff814cd684>] ? dump_stack+0x41/0x51
[<ffffffff810616e7>] ? warn_slowpath_common+0x77/0x90
[<ffffffff8106174c>] ? warn_slowpath_fmt+0x4c/0x50
[<ffffffff81374fd0>] ? device_del+0x40/0x1b0
[<ffffffff8137516f>] ? device_unregister+0x2f/0x50
[<ffffffff813751fa>] ? device_destroy+0x3a/0x40
[<ffffffffa03ca245>] ? drop_ref+0x55/0x120 [hid]
[<ffffffffa03ca3e6>] ? hidraw_release+0x96/0xb0 [hid]
[<ffffffff811929da>] ? __fput+0xca/0x210
[<ffffffff8107fe17>] ? task_work_run+0x97/0xd0
[<ffffffff810139a9>] ? do_notify_resume+0x69/0xa0
[<ffffffff814dbd22>] ? int_signal+0x12/0x17
---[ end trace 63f4a46f6566d737 ]---
During device removal hid_disconnect() is called via hid_hw_stop() to
stop the device and free all its resources, including the sysfs
files. The problem is that if a user space process, such as upowerd,
holds a reference to a hidraw file the corresponding sysfs files will
be kept around (drop_ref() does not call device_destroy() if the open
counter is not 0) and it will be usb_disconnect() who, by calling
device_del() for the USB device, will indirectly remove the sysfs
files of the hidraw device (sysfs_remove_dir() is recursive these
days). Because of this, by the time user space releases the last
reference to the hidraw file and drop_ref() tries to destroy the
device the sysfs files are already gone and the kernel will print
the warning above.
Fix this by calling device_destroy() at USB disconnect time.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
commit 114a55cf9dd1576e7ac56189832cd4d7dc56c218 upstream.
Re-arrange code slightly to ensure that device properties are configured
before calling auto-center command.
Reported-by: Michal MalĂ˝ <madcatxster@prifuk.cz>
Signed-off-by: Simon Wood <simon@mungewell.org>
commit ef0899410ff630b2e75306da49996dbbfa318165 upstream.
"elevator: Fix a race in elevator switching and md device initialization"
changed the semantics of elevator_init() in a way that now enforces to hold
the corresponding request queue's sysfs_lock when calling elevator_init()
to fix a race.
The patch did not convert the s390 dasd device driver which is the only
device driver which also calls elevator_init(). So add the missing locking.
Cc: Tomoki Sekiyama <tomoki.sekiyama@hds.com>
With upstream commit defd884845297fd5690594bfe89656b01f16d87e, 3.12
commit 2f82fa987df6b060241fc760eadf5dd02c51a979, we introduced a
warning:
drivers/infiniband/ulp/isert/ib_isert.c: In function 'isert_cq_rx_comp_err':
drivers/infiniband/ulp/isert/ib_isert.c:##L##: warning: unused variable 'ib_dev' [-Wunused-variable]
Remove ib_dev as it is unused.
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
Cc: Nicholas Bellinger <nab@linux-iscsi.org>
commit d746ca9561440685edb62614d1bcbbc27ff50e66 upstream.
The code to load a MAC address into a u64 for passing to the
hypervisor via a register is broken on little endian.
Create a helper function called ibmveth_encode_mac_addr
which does the right thing in both big and little endian.
We were storing the MAC address in a long in struct ibmveth_adapter.
It's never used so remove it - we don't need another place in the
driver where we create endian issues with MAC addresses.
Acked-by: Torsten Duwe <duwe@suse.de>
commit 1e9291996c4eedf79883f47ec635235e39d3d6cd upstream.
Since the statistics handler is asynchrous, it can very well
be that we will handle the statistics (hence the RSSI
fluctuation) when we already disassociated.
Don't WARN on this case.
This solves: https://bugzilla.redhat.com/show_bug.cgi?id=1071998
Cc: <stable@vger.kernel.org> [3.10+]
Fixes: 2b76ef13086f ("iwlwifi: mvm: implement reduced Tx power")
Reviewed-by: Johannes Berg <johannes.berg@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
commit 89935315f192abf7068d0044cefc84f162c3c81f upstream.
Before commit b355cee88e3b (ACPI / resources: ignore invalid ACPI
device resources), if acpi_dev_resource_memory()/acpi_dev_resource_io()
returns false, it means the the resource is not a memeory/IO resource.
But after commit b355cee88e3b, those functions return false if the
given memory/IO resource entry is invalid (the length of the resource
is zero).
This breaks pnpacpi_allocated_resource(), because it now recognizes
the invalid memory/io resources as resources of unknown type. Thus
users see confusing warning messages on machines with zero length
ACPI memory/IO resources.
Fix the problem by rearranging pnpacpi_allocated_resource() so that
it calls acpi_dev_resource_memory() for memory type and IO type
resources only, respectively.
Fixes: b355cee88e3b (ACPI / resources: ignore invalid ACPI device resources)
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Reported-and-tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Reported-and-tested-by: Julian Wollrath <jwollrath@web.de>
Reported-and-tested-by: Paul Bolle <pebolle@tiscali.nl>
[rjw: Changelog]
commit b12bb60d6c350b348a4e1460cd68f97ccae9822e upstream.
If the initialization of storvsc fails, the storvsc_device_destroy()
causes NULL pointer dereference.
storvsc_bus_scan()
scsi_scan_target()
__scsi_scan_target()
scsi_probe_and_add_lun(hostdata=NULL)
scsi_alloc_sdev(hostdata=NULL)
sdev->hostdata = hostdata
now the host allocation fails
__scsi_remove_device(sdev)
calls sdev->host->hostt->slave_destroy() ==
storvsc_device_destroy(sdev)
access of sdev->hostdata->request_mempool
Signed-off-by: Ales Novak <alnovak@suse.cz>
Signed-off-by: Thomas Abraham <tabraham@suse.com>
Reviewed-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: K. Y. Srinivasan <kys@microsoft.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit f324777ea88bab2522602671e46fc0851d7d5e35 upstream.
This fixes requesting of the MSI-X vectors for the base response queue.
The iteration in the for loop in qla24xx_enable_msix() was incorrect.
We should only iterate of the first two MSI-X vectors and not the total
number of MSI-X vectors that have given to the driver for this device
from pci_enable_msix() in this function.
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com>
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
commit b77ed25c9f8402e8b3e49e220edb4ef09ecfbb53 upstream.
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
commit c59053a23d586675c25d789a7494adfdc02fba57 upstream.
In the first place, the loop 'for' in the macro 'for_each_isci_host'
(drivers/scsi/isci/host.h:314) is incorrect, because it accesses
the 3rd element of 2 element array. After the 2nd iteration it executes
the instruction:
ihost = to_pci_info(pdev)->hosts[2]
(while the size of the 'hosts' array equals 2) and reads an
out of range element.
In the second place, this loop is incorrectly optimized by GCC v4.8
(see http://marc.info/?l=linux-kernel&m=138998871911336&w=2).
As a result, on platforms with two SCU controllers,
the loop is executed more times than it can be (for i=0,1 and 2).
It causes kernel panic during entering the S3 state
and the following oops after 'rmmod isci':
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8131360b>] __list_add+0x1b/0xc0
Oops: 0000 [#1] SMP
RIP: 0010:[<ffffffff8131360b>] [<ffffffff8131360b>] __list_add+0x1b/0xc0
Call Trace:
[<ffffffff81661b84>] __mutex_lock_slowpath+0x114/0x1b0
[<ffffffff81661c3f>] mutex_lock+0x1f/0x30
[<ffffffffa03e97cb>] sas_disable_events+0x1b/0x50 [libsas]
[<ffffffffa03e9818>] sas_unregister_ha+0x18/0x60 [libsas]
[<ffffffffa040316e>] isci_unregister+0x1e/0x40 [isci]
[<ffffffffa0403efd>] isci_pci_remove+0x5d/0x100 [isci]
[<ffffffff813391cb>] pci_device_remove+0x3b/0xb0
[<ffffffff813fbf7f>] __device_release_driver+0x7f/0xf0
[<ffffffff813fc8f8>] driver_detach+0xa8/0xb0
[<ffffffff813fbb8b>] bus_remove_driver+0x9b/0x120
[<ffffffff813fcf2c>] driver_unregister+0x2c/0x50
[<ffffffff813381f3>] pci_unregister_driver+0x23/0x80
[<ffffffffa04152f8>] isci_exit+0x10/0x1e [isci]
[<ffffffff810d199b>] SyS_delete_module+0x16b/0x2d0
[<ffffffff81012a21>] ? do_notify_resume+0x61/0xa0
[<ffffffff8166ce29>] system_call_fastpath+0x16/0x1b
The loop has been corrected.
This patch fixes kernel panic during entering the S3 state
and the above oops.
Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com>
Reviewed-by: Maciej Patelczyk <maciej.patelczyk@intel.com>
Tested-by: Lukasz Dorau <lukasz.dorau@intel.com>
commit ddfadd7736b677de2d4ca2cd5b4b655368c85a7a upstream.
Remove an erroneous BUG_ON() in the case of a hard reset timeout. The
reset timeout handler puts the port into the "awaiting link-up" state.
The timeout causes the device to be disconnected and we need to be in
the awaiting link-up state to re-connect the port. The BUG_ON() made
the incorrect assumption that resets never timeout and we always
complete the reset in the "resetting" state.
Testing this patch also uncovered that libata continues to attempt to
reset the port long after the driver has torn down the context. Once
the driver has committed to abandoning the link it must indicate to
libata that recovery ends by returning -ENODEV from
->lldd_I_T_nexus_reset().
Acked-by: Lukasz Dorau <lukasz.dorau@intel.com>
Reported-by: David Milburn <dmilburn@redhat.com>
Reported-by: Xun Ni <xun.ni@intel.com>
Tested-by: Xun Ni <xun.ni@intel.com>
commit d96e43e8fce28cf97df576a07af9d65657a41a6f upstream.
This patch adds the missing netif_napi_del() to the flexcan_remove() function.
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit f003698e23f6f56a791774f14d0ac35d04872490 upstream.
This patch moves the transceiver enable and disable into seperate functions,
where the NULL pointer check is hidden.
commit 9b00b300e7bce032c467c36ca47fe2a776887fc2 upstream.
In flexcan_chip_enable() and flexcan_chip_disable() fixed delays are used.
Experiments have shown that the transition from and to low power mode may take
several microseconds.
This patch adds a while loop which polls the Low Power Mode ACK bit (LPM_ACK)
that indicates a successfull mode change. If the function runs into a timeout a
error value is returned.
commit 7e9e148af01ef388efb6e2490805970be4622792 upstream.
If flexcan_chip_start() in flexcan_open() fails, the interrupt is not freed,
this patch adds the missing cleanup.
commit 5be93bdda64e85450598c6e97f79fb8f6acf30e0 upstream.
When shutting down the CAN interface (ifconfig canX down) during high CAN bus
loads, the CAN core might hang and freeze the whole CPU.
This patch fixes the shutdown sequence by first disabling the CAN core then
disabling all interrupts.
commit e893fba90c09f9b57fb97daae204ea9cc2c52fa5 upstream.
In order to avoid wasting cache space a partial block at the end of the
origin device is not cached. Unfortunately, the check for such a
partial block at the end of the origin device was flawed.
Fix accesses beyond the end of the origin device that occured due to
attempted promotion of an undetected partial block by:
- initializing the per bio data struct to allow cache_end_io to work properly
- recognizing access to the partial block at the end of the origin device
- avoiding out of bounds access to the discard bitset
Otherwise, users can experience errors like the following:
attempt to access beyond end of device
dm-5: rw=0, want=20971520, limit=20971456
device-mapper: cache: promotion failed; couldn't copy block
Signed-off-by: Heinz Mauelshagen <heinzm@redhat.com>
Acked-by: Joe Thornber <ejt@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 8b9d96666529a979acf4825391efcc7c8a3e9f12 upstream.
During demotion or promotion to a cache's >2TB fast device we must not
truncate the cache block's associated sector to 32bits. The 32bit
temporary result of from_cblock() caused a 32bit multiplication when
calculating the sector of the fast device in issue_copy_real().
Use an intermediate 64bit type to store the 32bit from_cblock() to allow
for proper 64bit multiplication.
Here is an example of how this bug manifests on an ext4 filesystem:
EXT4-fs error (device dm-0): ext4_mb_generate_buddy:756: group 17136, 32768 clusters in bitmap, 30688 in gd; block bitmap corrupt.
JBD2: Spotted dirty metadata buffer (dev = dm-0, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
commit cebc2de44d3bce53e46476e774126c298ca2c8a9 upstream.
This has been a relatively long-standing issue that wasn't nailed down
until Teng-Feng Yang's meticulous bug report to dm-devel on 3/7/2014,
see: http://www.redhat.com/archives/dm-devel/2014-March/msg00021.html
From that report:
"When decreasing the reference count of a metadata block with its
reference count equals 3, we will call dm_btree_remove() to remove
this enrty from the B+tree which keeps the reference count info in
metadata device.
The B+tree will try to rebalance the entry of the child nodes in each
node it traversed, and the rebalance process contains the following
steps.
(1) Finding the corresponding children in current node (shadow_current(s))
(2) Shadow the children block (issue BOP_INC)
(3) redistribute keys among children, and free children if necessary (issue BOP_DEC)
Since the update of a metadata block's reference count could be
recursive, we will stash these reference count update operations in
smm->uncommitted and then process them in a FILO fashion.
The problem is that step(3) could free the children which is created
in step(2), so the BOP_DEC issued in step(3) will be carried out
before the BOP_INC issued in step(2) since these BOPs will be
processed in FILO fashion. Once the BOP_DEC from step(3) tries to
decrease the reference count of newly shadow block, it will report
failure for its reference equals 0 before decreasing. It looks like we
can solve this issue by processing these BOPs in a FIFO fashion
instead of FILO."
Commit 5b564d80 ("dm space map: disallow decrementing a reference count
below zero") changed the code to report an error for this temporary
refcount decrement below zero. So what was previously a harmless
invalid refcount became a hard failure due to the new error path:
device-mapper: space map common: unable to decrement a reference count below 0
device-mapper: thin: 253:6: dm_thin_insert_block() failed: error = -22
device-mapper: thin: 253:6: switching pool to read-only mode
This bug is in dm persistent-data code that is common to the DM thin and
cache targets. So any users of those targets should apply this fix.
Fix this by applying recursive space map operations in FIFO order rather
than FILO.
Resolves: https://bugzilla.kernel.org/show_bug.cgi?id=68801
Reported-by: Apollon Oikonomopoulos <apoikos@debian.org>
Reported-by: edwillam1007@gmail.com
Reported-by: Teng-Feng Yang <shinrairis@gmail.com>
Signed-off-by: Joe Thornber <ejt@redhat.com>
commit 0a8d8c446b5429d15ff2d48f46e00d8a08552303 upstream.
Since commit d25f06ea466e "vmxnet3: fix netpoll race condition",
the vmxnet3 driver fails to build when CONFIG_PCI_MSI is disabled,
because it unconditionally references the vmxnet3_msix_rx()
function.
To fix this, use the same #ifdef in the caller that exists around
the function definition.
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Shreyas Bhatewara <sbhatewara@vmware.com>
Cc: "VMware, Inc." <pv-drivers@vmware.com>
