commit 108cef3aa41669610e1836fe638812dd067d72de upstream.
It is critical that fetch_block() and handle_stripe_dirtying()
are consistent in their analysis of what needs to be loaded.
Otherwise raid5 can wait forever for a block that won't be loaded.
Currently when writing to a RAID5 that is resyncing, to a location
beyond the resync offset, handle_stripe_dirtying chooses a
reconstruct-write cycle, but fetch_block() assumes a
read-modify-write, and a lockup can happen.
So treat that case just like RAID6, just as we do in
handle_stripe_dirtying. RAID6 always does reconstruct-write.
This bug was introduced when the behaviour of handle_stripe_dirtying
was changed in 3.7, so the patch is suitable for any kernel since,
though it will need careful merging for some versions.
Cc: stable@vger.kernel.org (v3.7+)
Fixes: a7854487cd7128a30a7f4f5259de9f67d5efb95f
Reported-by: Henry Cai <henryplusplus@gmail.com>
Signed-off-by: NeilBrown <neilb@suse.de>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 3b9d35d744bb5139f9fed57f38c019bb8c7d351c upstream.
This was not noticed for many years. Affects operation if
md raid is used a backing device for DRBD.
CC: stable@kernel.org # v3.2+
Signed-off-by: Philipp Reisner <philipp.reisner@linbit.com>
Signed-off-by: Lars Ellenberg <lars.ellenberg@linbit.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit dbdd74763f1faf799fbb9ed30423182e92919378 upstream.
This reverts commit 2c3fc8d26dd09b9d7069687eead849ee81c78e46.
This commit broke on x86 PV because entries in the generic SWIOTLB are
indexed using (pseudo-)physical address not DMA address and these are
not the same in a x86 PV guest.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
commit 4aaa71873ddb9faf4b0c4826579e2f6d18ff9ab4 upstream.
DMA mapped IO should be unmapped on the error path in probe() and
unconditionally on remove().
Fixes: 62936009f35a ([libata] Add 460EX on-chip SATA driver, sata_dwc_460ex)
commit 8c38d28ba8da98f7102c31d35359b4dbe9d1f329 upstream.
EXYNOS4_MCT_L_MASK is defined as 0xffffff00, so applying this bitmask
produces a number outside the range 0x00 to 0xff, which always results
in execution of the default switch statement.
Obviously this is wrong and git history shows that the bitmask inversion
was incorrectly set during a refactoring of the MCT code.
Fix this by putting the inversion at the correct position again.
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
Reported-by: GP Orcullo <kinsamanka@gmail.com>
Reviewed-by: Doug Anderson <dianders@chromium.org>
Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
commit 9b1087aa5e86448fe6ad40a58964e35f3ba423d5 upstream.
When changing flags in the CAN drivers ctrlmode the provided new content has to
be checked whether the bits are allowed to be changed. The bits that are to be
changed are given as a bitfield in cm->mask. Therefore checking against
cm->flags is wrong as the content can hold any kind of values.
The iproute2 tool sets the bits in cm->mask and cm->flags depending on the
detected command line options. To be robust against bogus user space
applications additionally sanitize the provided flags with the provided mask.
Cc: Wolfgang Grandegger <wg@grandegger.com>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 38bdf45f4aa5cb6186d50a29e6cbbd9d486a1519 upstream.
On Armada XP, 375 and 38x the MBus window 13 has the remap capability,
like windows 0 to 7. However, the mvebu-mbus driver isn't currently
taking into account this special case, which means that when window 13
is actually used, the remap registers are left to 0, making the device
using this MBus window unavailable.
As a minimal fix for stable, don't use window 13. A full fix will
follow later.
Fixes: fddddb52a6c ("bus: introduce an Marvell EBU MBus driver")
Reviewed-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
commit 9b1cc9f251affdd27f29fe46d0989ba76c33faf6 upstream.
If a DM table is reloaded with an inactive table when the device is not
suspended (normal procedure for LVM2), then there will be two dm-bufio
objects that can diverge. This can lead to a situation where the
inactive table uses bufio to read metadata at the same time the active
table writes metadata -- resulting in the inactive table having stale
metadata buffers once it is promoted to the active table slot.
Fix this by using reference counting and a global list of cache metadata
objects to ensure there is only one metadata object per metadata device.
Signed-off-by: Joe Thornber <ejt@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 6cdb08172bc89f0a39e1643c5e7eab362692fd1b upstream.
Fixes a race condition in abort handling that was injected
when multiple interrupt support was added. When only a single
interrupt is present, the adapter guarantees it will send
responses for aborted commands prior to the response for the
abort command itself. With multiple interrupts, these responses
generally come back on different interrupts, so we need to
ensure the abort thread waits until the aborted command is
complete so we don't perform a double completion. This race
condition was being hit frequently in environments which
were triggering command timeouts, which was resulting in
a double completion causing a kernel oops.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Reviewed-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com>
Tested-by: Wendy Xiong <wenxiong@linux.vnet.ibm.com>
commit 226e5ae9e5f9108beb0bde4ac69f68fe6210fed9 upstream.
If CONFIG_DEBUG_MUTEXES is set, the mutex->owner field is only cleared
if the mutex debugging is enabled which introduces a race in our
mutex_is_locked_by() - i.e. we may inspect the old owner value before it
is acquired by the new task.
This is the root cause of this error:
# diff --git a/kernel/locking/mutex-debug.c b/kernel/locking/mutex-debug.c
# index 5cf6731..3ef3736 100644
# --- a/kernel/locking/mutex-debug.c
# +++ b/kernel/locking/mutex-debug.c
# @@ -80,13 +80,13 @@ void debug_mutex_unlock(struct mutex *lock)
# DEBUG_LOCKS_WARN_ON(lock->owner != current);
# DEBUG_LOCKS_WARN_ON(!lock->wait_list.prev && !lock->wait_list.next);
# - mutex_clear_owner(lock);
# * __mutex_slowpath_needs_to_unlock() is explicitly 0 for debug
# * mutexes so that we can do it here after we've verified state.
# + mutex_clear_owner(lock);
# atomic_set(&lock->count, 1);
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=87955
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit ce7514526742c0898b837d4395f515b79dfb5a12 upstream.
It is possible for ata_sff_flush_pio_task() to set ap->hsm_task_state to
HSM_ST_IDLE in between the time __ata_sff_port_intr() checks for HSM_ST_IDLE
and before it calls ata_sff_hsm_move() causing ata_sff_hsm_move() to BUG().
This problem is hard to reproduce making this patch hard to verify, but this
fix will prevent the race.
I have not been able to reproduce the problem, but here is a crash dump from
a 2.6.32 kernel.
On examining the ata port's state, its hsm_task_state field has a value of HSM_ST_IDLE:
crash> struct ata_port.hsm_task_state ffff881c1121c000
hsm_task_state = 0
Normally, this should not be possible as ata_sff_hsm_move() was called from ata_sff_host_intr(),
which checks hsm_task_state and won't call ata_sff_hsm_move() if it has a HSM_ST_IDLE value.
PID: 11053 TASK: ffff8816e846cae0 CPU: 0 COMMAND: "sshd"
#0 [ffff88008ba03960] machine_kexec at ffffffff81038f3b
#1 [ffff88008ba039c0] crash_kexec at ffffffff810c5d92
#2 [ffff88008ba03a90] oops_end at ffffffff8152b510
#3 [ffff88008ba03ac0] die at ffffffff81010e0b
#4 [ffff88008ba03af0] do_trap at ffffffff8152ad74
#5 [ffff88008ba03b50] do_invalid_op at ffffffff8100cf95
#6 [ffff88008ba03bf0] invalid_op at ffffffff8100bf9b
[exception RIP: ata_sff_hsm_move+317]
RIP: ffffffff813a77ad RSP: ffff88008ba03ca0 RFLAGS: 00010097
RAX: 0000000000000000 RBX: ffff881c1121dc60 RCX: 0000000000000000
RDX: ffff881c1121dd10 RSI: ffff881c1121dc60 RDI: ffff881c1121c000
RBP: ffff88008ba03d00 R8: 0000000000000000 R9: 000000000000002e
R10: 000000000001003f R11: 000000000000009b R12: ffff881c1121c000
R13: 0000000000000000 R14: 0000000000000050 R15: ffff881c1121dd78
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#7 [ffff88008ba03d08] ata_sff_host_intr at ffffffff813a7fbd
#8 [ffff88008ba03d38] ata_sff_interrupt at ffffffff813a821e
#9 [ffff88008ba03d78] handle_IRQ_event at ffffffff810e6ec0
commit db93facfb0ef542aa5d8079e47580b3e669a4d82 upstream.
This patch is to fix two deadlock cases.
Deadlock 1:
CPU #1
pinctrl_register-> pinctrl_get ->
create_pinctrl
(Holding lock pinctrl_maps_mutex)
-> get_pinctrl_dev_from_devname
(Trying to acquire lock pinctrldev_list_mutex)
CPU #0
pinctrl_unregister
(Holding lock pinctrldev_list_mutex)
-> pinctrl_put ->> pinctrl_free ->
pinctrl_dt_free_maps -> pinctrl_unregister_map
(Trying to acquire lock pinctrl_maps_mutex)
Simply to say
CPU#1 is holding lock A and trying to acquire lock B,
CPU#0 is holding lock B and trying to acquire lock A.
Deadlock 2:
CPU #3
create_pinctrl
CPU #2
pinctrl_unregister
(Holding lock pctldev->mutex)
CPU #0
tegra_gpio_request
-> pinctrl_get_device_gpio_range
(Trying to acquire lock pctldev->mutex)
Simply to say
CPU#3 is holding lock A and trying to acquire lock D,
CPU#2 is holding lock B and trying to acquire lock A,
CPU#0 is holding lock D and trying to acquire lock B.
Signed-off-by: Jim Lin <jilin@nvidia.com>
commit 0915e6feb38de8d3601819992a5bd050201a56fa upstream.
The gpio device attributes were never destroyed when the gpio was
unexported (or on export failures).
Use device_create_with_groups() to create the default device attributes
of the gpio class device. Note that this also fixes the
attribute-creation race with userspace for these attributes.
Remove contingent attributes in export error path and on unexport.
Fixes: d8f388d8dc8d ("gpio: sysfs interface")
Cc: stable <stable@vger.kernel.org> # v2.6.27+
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 121b6a79955a3a3fd7bbb9b8cb88d5b9dad6283d upstream.
The gpio-chip device attributes were never destroyed when the device was
removed.
Fix by using device_create_with_groups() to create the device attributes
of the chip class device.
Note that this also fixes the attribute-creation race with userspace.
commit e512d56c799517f33b301d81e9a5e0ebf30c2d1e upstream.
git commit 37f81fa1f63ad38e16125526bb2769ae0ea8d332
"n_tty: do O_ONLCR translation as a single write"
surfaced a bug in the 3215 device driver. In combination this
broke tab expansion for tty ouput.
The cause is an asymmetry in the behaviour of tty3215_ops->write
vs tty3215_ops->put_char. The put_char function scans for '\t'
but the write function does not.
As the driver has logic for the '\t' expansion remove XTABS
from c_oflag of the initial termios as well.
Reported-by: Stephen Powell <zlinuxman@wowway.com>
commit 26d766c60f4ea08cd14f0f3435a6db3d6cc2ae96 upstream.
The ccw_device_start in raw3215_start_io can fail. raw3215_try_io
does not check if the request could be started and removes any
pending timer. This can leave the system in a hanging state.
Check for pending request after raw3215_start_io and start a
timer if necessary.
commit 2836766a9d0bd02c66073f8dd44796e6cc23848d upstream.
Sleep in atomic context happened on Trats2 board after inserting or
removing SD card because mmc_gpio_get_cd() was called under spin lock.
Fix this by moving card detection earlier, before acquiring spin lock.
The mmc_gpio_get_cd() call does not have to be protected by spin lock
because it does not access any sdhci internal data.
The sdhci_do_get_cd() call access host flags (SDHCI_DEVICE_DEAD). After
moving it out side of spin lock it could theoretically race with driver
removal but still there is no actual protection against manual card
eject.
Dmesg after inserting SD card:
[ 41.663414] BUG: sleeping function called from invalid context at drivers/gpio/gpiolib.c:1511
[ 41.670469] in_atomic(): 1, irqs_disabled(): 128, pid: 30, name: kworker/u8:1
[ 41.677580] INFO: lockdep is turned off.
[ 41.681486] irq event stamp: 61972
[ 41.684872] hardirqs last enabled at (61971): [<c0490ee0>] _raw_spin_unlock_irq+0x24/0x5c
[ 41.693118] hardirqs last disabled at (61972): [<c04907ac>] _raw_spin_lock_irq+0x18/0x54
[ 41.701190] softirqs last enabled at (61648): [<c0026fd4>] __do_softirq+0x234/0x2c8
[ 41.708914] softirqs last disabled at (61631): [<c00273a0>] irq_exit+0xd0/0x114
[ 41.716206] Preemption disabled at:[< (null)>] (null)
[ 41.721500]
[ 41.722985] CPU: 3 PID: 30 Comm: kworker/u8:1 Tainted: G W 3.18.0-rc5-next-20141121 #883
[ 41.732111] Workqueue: kmmcd mmc_rescan
[ 41.735945] [<c0014d2c>] (unwind_backtrace) from [<c0011c80>] (show_stack+0x10/0x14)
[ 41.743661] [<c0011c80>] (show_stack) from [<c0489d14>] (dump_stack+0x70/0xbc)
[ 41.750867] [<c0489d14>] (dump_stack) from [<c0228b74>] (gpiod_get_raw_value_cansleep+0x18/0x30)
[ 41.759628] [<c0228b74>] (gpiod_get_raw_value_cansleep) from [<c03646e8>] (mmc_gpio_get_cd+0x38/0x58)
[ 41.768821] [<c03646e8>] (mmc_gpio_get_cd) from [<c036d378>] (sdhci_request+0x50/0x1a4)
[ 41.776808] [<c036d378>] (sdhci_request) from [<c0357934>] (mmc_start_request+0x138/0x268)
[ 41.785051] [<c0357934>] (mmc_start_request) from [<c0357cc8>] (mmc_wait_for_req+0x58/0x1a0)
[ 41.793469] [<c0357cc8>] (mmc_wait_for_req) from [<c0357e68>] (mmc_wait_for_cmd+0x58/0x78)
[ 41.801714] [<c0357e68>] (mmc_wait_for_cmd) from [<c0361c00>] (mmc_io_rw_direct_host+0x98/0x124)
[ 41.810480] [<c0361c00>] (mmc_io_rw_direct_host) from [<c03620f8>] (sdio_reset+0x2c/0x64)
[ 41.818641] [<c03620f8>] (sdio_reset) from [<c035a3d8>] (mmc_rescan+0x254/0x2e4)
[ 41.826028] [<c035a3d8>] (mmc_rescan) from [<c003a0e0>] (process_one_work+0x180/0x3f4)
[ 41.833920] [<c003a0e0>] (process_one_work) from [<c003a3bc>] (worker_thread+0x34/0x4b0)
[ 41.841991] [<c003a3bc>] (worker_thread) from [<c003fed8>] (kthread+0xe4/0x104)
[ 41.849285] [<c003fed8>] (kthread) from [<c000f268>] (ret_from_fork+0x14/0x2c)
[ 42.038276] mmc0: new high speed SDHC card at address 1234
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 94144a465dd0 ("mmc: sdhci: add get_cd() implementation")
Cc: <stable@vger.kernel.org>
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
commit 9333caeaeae4f831054e0e127a6ed3948b604d3e upstream.
When KBC is in active multiplexing mode the touchpad on this laptop does
not work.
Reported-by: Bilal Koc <koc.bilo@googlemail.com>
commit 148e9a711e034e06310a8c36b64957934ebe30f2 upstream.
On some laptops, keyboard needs to be reset in order to successfully detect
touchpad (e.g., some Gigabyte laptop models with Elantech touchpads).
Without resettin keyboard touchpad pretends to be completely dead.
Based on the original patch by Mateusz Jończyk this version has been
expanded to include DMI based detection & application of the fix
automatically on the affected models of laptops. This has been confirmed to
fix problem by three users already on three different models of laptops.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=81331
Signed-off-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Acked-by: Mateusz Jończyk <mat.jonczyk@o2.pl>
Tested-by: Srihari Vijayaraghavan <linux.bug.reporting@gmail.com>
Tested by: Zakariya Dehlawi <zdehlawi@gmail.com>
Tested-by: Guillaum Bouchard <guillaum.bouchard@gmail.com>
commit 5e7e6e0c9b47a45576c38b4a72d67927a5e049f7 upstream.
Recent Leaf firmware versions (>= 3.1.557) do not allow to send
commands for non-existing channels. If a command is sent for a
non-existing channel, the firmware crashes.
Reported-by: Christopher Storah <Christopher.Storah@invetech.com.au>
Signed-off-by: Olivier Sobrie <olivier@sobrie.be>
Signed-off-by: Ahmed S. Darwish <ahmed.darwish@valeo.com>
commit 889b77f7fd2bcc922493d73a4c51d8a851505815 upstream.
Flooding the Kvaser CAN to USB dongle with multiple reads and
writes in very high frequency (*), closing the CAN channel while
all the transmissions are on (#), opening the device again (@),
then sending a small number of packets would make the driver
enter an almost infinite loop of:
[15959.853988] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853990] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853991] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853993] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853994] kvaser_usb 4-3:1.0 can0: cannot find free context
[15959.853995] kvaser_usb 4-3:1.0 can0: cannot find free context
_dragging the whole system down_ in the process due to the
excessive logging output.
Initially, this has caused random panics in the kernel due to a
buggy error recovery path. That got fixed in an earlier commit.(%)
This patch aims at solving the root cause. -->
16 tx URBs and contexts are allocated per CAN channel per USB
device. Such URBs are protected by:
a) A simple atomic counter, up to a value of MAX_TX_URBS (16)
b) A flag in each URB context, stating if it's free
c) The fact that ndo_start_xmit calls are themselves protected
by the networking layers higher above
After grabbing one of the tx URBs, if the driver noticed that all
of them are now taken, it stops the netif transmission queue.
Such queue is worken up again only if an acknowedgment was received
from the firmware on one of our earlier-sent frames.
Meanwhile, upon channel close (#), the driver sends a CMD_STOP_CHIP
to the firmware, effectively closing all further communication. In
the high traffic case, the atomic counter remains at MAX_TX_URBS,
and all the URB contexts remain marked as active. While opening
the channel again (@), it cannot send any further frames since no
more free tx URB contexts are available.
Reset all tx URB contexts upon CAN channel close.
(*) 50 parallel instances of `cangen0 -g 0 -ix`
(#) `ifconfig can0 down`
(@) `ifconfig can0 up`
(%) "can: kvaser_usb: Don't free packets when tight on URBs"
commit b442723fcec445fb0ae1104888dd22cd285e0a91 upstream.
writes in high frequency caused seemingly-random panics in the
kernel.
On further inspection, it seems the driver erroneously freed the
to-be-transmitted packet upon getting tight on URBs and returning
NETDEV_TX_BUSY, leading to invalid memory writes and double frees
at a later point in time.
Note:
Finding no more URBs/transmit-contexts and returning NETDEV_TX_BUSY
is a driver bug in and out of itself: it means that our start/stop
queue flow control is broken.
This patch only fixes the (buggy) error handling code; the root
cause shall be fixed in a later commit.
Acked-by: Olivier Sobrie <olivier@sobrie.be>
commit b5122236bba8d7ef62153da5b55cc65d0944c61e upstream.
Fix null-pointer dereference during probe if the interface-status
completion handler is called before the individual ports have been set
up.
Fixes: f79b2d0fe81e ("USB: keyspan: fix NULL-pointer dereferences and
memory leaks")
Reported-by: Richard <richjunk@pacbell.net>
Tested-by: Richard <richjunk@pacbell.net>
commit 1ae78a4870989a354028cb17dabf819b595e70e3 upstream.
Added virtual com port VID/PID entries for CEL USB sticks and MeshWorks
devices.
Signed-off-by: David Peterson <david.peterson@cel.com>
commit 90441b4dbe90ba0c38111ea89fa093a8c9627801 upstream.
Fixing typo for MeshConnect IDs. The original PID (0x8875) is not in
production and is not needed. Instead it has been changed to the
official production PID (0x8857).
Signed-off-by: Preston Fick <pffick@gmail.com>
commit 39e60635a01520e8c8ed3946a28c2b98e6a46f79 upstream.
DWC3 gadget sets up a pool of 32 TRBs for each EP during initialization. This
means, the max TRBs that can be submitted for an EP is fixed to 32. Since the
request queue for an EP is a linked list, any number of requests can be queued
to it by the gadget layer. However, the dwc3 driver must not submit TRBs more
than the pool it has created for. This limit wasn't respected when SG was used
resulting in submitting more than the max TRBs, eventually leading to
non-transfer of the TRBs submitted over the max limit.
Root cause:
When SG is used, there are two loops iterating to prepare TRBs:
- Outer loop over the request_list
- Inner loop over the SG list
The code was missing break to get out of the outer loop.
Fixes: eeb720fb21d6 (usb: dwc3: gadget: add support for SG lists)
Signed-off-by: Amit Virdi <amit.virdi@st.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit ec512fb8e5611fed1df2895f90317ce6797d6b32 upstream.
When scatter gather (SG) is used, multiple TRBs are prepared from one DWC3
request (dwc3_request). So while preparing TRBs, the 'last' flag should be set
only when it is the last TRB being prepared from the last dwc3_request entry.
The current implementation uses list_is_last to check if the dwc3_request is the
last entry from the request_list. However, list_is_last returns false for the
last entry too. This is because, while preparing the first TRB from a request,
the function dwc3_prepare_one_trb modifies the request's next and prev pointers
while moving the URB to req_queued. Hence, list_is_last always returns false no
matter what.
The correct way is not to access the modified pointers of dwc3_request but to
use list_empty macro instead.
Fixes: e5ba5ec833aa (usb: dwc3: gadget: fix scatter gather implementation)
commit 56abcab833fafcfaeb2f5b25e0364c1dec45f53e upstream.
Commit 8dccddbc2368 ("OHCI: final fix for NVIDIA problems (I hope)")
introduced into 3.1.9 broke boot on e.g. Freescale P2020DS development
board. The code path that was previously specific to NVIDIA controllers
had then become taken for all chips.
However, the M5237 installed on the board wedges solid when accessing
its base+OHCI_FMINTERVAL register, making it impossible to boot any
kernel newer than 3.1.8 on this particular and apparently other similar
machines.
Don't readl() and writel() base+OHCI_FMINTERVAL on PCI ID 10b9:5237.
The patch is suitable for the -next tree as well as all maintained
kernels up to 3.2 inclusive.
Signed-off-by: Arseny Solokha <asolokha@kb.kras.ru>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 7b8792bbdffdff3abda704f89c6a45ea97afdc62 upstream.
of_get_named_gpiod_flags fails with -EPROBE_DEFER in cases
where the gpio chip is available and the GPIO translation fails.
This causes drivers to be re-probed erroneusly, and hides the
real problem(i.e. the GPIO number being out of range).
Signed-off-by: Hans Holmberg <hans.holmberg@intel.com>
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
commit 7c2e211f3c95b91912a92a8c6736343690042e2e upstream.
Current vfio-pci just supports normal pci device, so vfio_pci_probe() will
return if the pci device is not a normal device. While current code makes a
mistake. PCI_HEADER_TYPE is the offset in configuration space of the device
type, but we use this value to mask the type value.
This patch fixs this by do the check directly on the pci_dev->hdr_type.
Signed-off-by: Wei Yang <weiyang@linux.vnet.ibm.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
commit 2228d80dd05a4fc5a410fde847677b8fb3eb23d7 upstream.
We've got a bug report at disconnecting a Webcam, where the kernel
spews warnings like below:
WARNING: CPU: 0 PID: 8385 at ../fs/sysfs/group.c:219 sysfs_remove_group+0x87/0x90()
sysfs group c0b2350c not found for kobject 'event3'
CPU: 0 PID: 8385 Comm: queue2:src Not tainted 3.16.2-1.gdcee397-default #1
Hardware name: ASUSTeK Computer INC. A7N8X-E/A7N8X-E, BIOS ASUS A7N8X-E Deluxe ACPI BIOS Rev 1013 11/12/2004
c08d0705 ddc75cbc c0718c5b ddc75ccc c024b654 c08c6d44 ddc75ce8 000020c1
c08d0705 000000db c03d1ec7 c03d1ec7 00000009 00000000 c0b2350c d62c9064
ddc75cd4 c024b6a3 00000009 ddc75ccc c08c6d44 ddc75ce8 ddc75cfc c03d1ec7
Call Trace:
[<c0205ba6>] try_stack_unwind+0x156/0x170
[<c02046f3>] dump_trace+0x53/0x180
[<c0205c06>] show_trace_log_lvl+0x46/0x50
[<c0204871>] show_stack_log_lvl+0x51/0xe0
[<c0205c67>] show_stack+0x27/0x50
[<c0718c5b>] dump_stack+0x3e/0x4e
[<c024b654>] warn_slowpath_common+0x84/0xa0
[<c024b6a3>] warn_slowpath_fmt+0x33/0x40
[<c03d1ec7>] sysfs_remove_group+0x87/0x90
[<c05a2c54>] device_del+0x34/0x180
[<c05e3989>] evdev_disconnect+0x19/0x50
[<c05e06fa>] __input_unregister_device+0x9a/0x140
[<c05e0845>] input_unregister_device+0x45/0x80
[<f854b1d6>] uvc_delete+0x26/0x110 [uvcvideo]
[<f84d66f8>] v4l2_device_release+0x98/0xc0 [videodev]
[<c05a25bb>] device_release+0x2b/0x90
[<c04ad8bf>] kobject_cleanup+0x6f/0x1a0
[<f84d5453>] v4l2_release+0x43/0x70 [videodev]
[<c0372f31>] __fput+0xb1/0x1b0
[<c02650c1>] task_work_run+0x91/0xb0
[<c024d845>] do_exit+0x265/0x910
[<c024df64>] do_group_exit+0x34/0xa0
[<c025a76f>] get_signal_to_deliver+0x17f/0x590
[<c0201b6a>] do_signal+0x3a/0x960
[<c02024f7>] do_notify_resume+0x67/0x90
[<c071ebb5>] work_notifysig+0x30/0x3b
[<b7739e60>] 0xb7739e5f
---[ end trace b1e56095a485b631 ]---
The cause is that uvc_status_cleanup() is called after usb_put_*() in
uvc_delete(). usb_put_*() removes the sysfs parent and eventually
removes the children recursively, so the later device_del() can't find
its sysfs. The fix is simply rearrange the call orders in
uvc_delete() so that the child is removed before the parent.
Bugzilla: https://bugzilla.suse.com/show_bug.cgi?id=897736
Reported-and-tested-by: Martin Pluskal <mpluskal@suse.com>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit f85698cd296f08218a7750f321e94607da128600 upstream.
The mutex does not serialise anything in this case but avoids a lockdep
warning from the control framework.
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
commit 2279948735609d0d17d7384e776b674619f792ef upstream.
This patches fixes an ancient bug in the dvb_usb_af9005 driver, which
has been reported at least in the following threads:
https://lkml.org/lkml/2009/2/4/350
https://lkml.org/lkml/2014/9/18/558
If the driver is compiled in without any IR support (neither
DVB_USB_AF9005_REMOTE nor custom symbols), the symbol_request calls in
af9005_usb_module_init() return pointers != NULL although the IR
symbols are not available.
This leads to the following oops:
[ 8.529751] usbcore: registered new interface driver dvb_usb_af9005
[ 8.531584] BUG: unable to handle kernel paging request at 02e00000
[ 8.533385] IP: [<7d9d67c6>] af9005_usb_module_init+0x6b/0x9d
[ 8.535613] *pde = 00000000
[ 8.536416] Oops: 0000 [#1] PREEMPT PREEMPT DEBUG_PAGEALLOCDEBUG_PAGEALLOC
[ 8.537863] CPU: 0 PID: 1 Comm: swapper Not tainted 3.15.0-rc6-00151-ga5c075c #1
[ 8.539827] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140531_083030-gandalf 04/01/2014
[ 8.541519] task: 89c9a670 ti: 89c9c000 task.ti: 89c9c000
[ 8.541519] EIP: 0060:[<7d9d67c6>] EFLAGS: 00010206 CPU: 0
[ 8.541519] EIP is at af9005_usb_module_init+0x6b/0x9d
[ 8.541519] EAX: 02e00000 EBX: 00000000 ECX: 00000006 EDX: 00000000
[ 8.541519] ESI: 00000000 EDI: 7da33ec8 EBP: 89c9df30 ESP: 89c9df2c
[ 8.541519] DS: 007b ES: 007b FS: 0000 GS: 00e0 SS: 0068
[ 8.541519] CR0: 8005003b CR2: 02e00000 CR3: 05a54000 CR4: 00000690
[ 8.541519] Stack:
[ 8.541519] 7d9d675b 89c9df90 7d992a49 7d7d5914 89c9df4c 7be3a800 7d08c58c 8a4c3968
[ 8.541519] 89c9df80 7be3a966 00000192 00000006 00000006 7d7d3ff4 8a4c397a 00000200
[ 8.541519] 7d6b1280 8a4c3979 00000006 000009a6 7da32db8 b13eec81 00000006 000009a6
[ 8.541519] Call Trace:
[ 8.541519] [<7d9d675b>] ? ttusb2_driver_init+0x16/0x16
[ 8.541519] [<7d992a49>] do_one_initcall+0x77/0x106
[ 8.541519] [<7be3a800>] ? parameqn+0x2/0x35
[ 8.541519] [<7be3a966>] ? parse_args+0x113/0x25c
[ 8.541519] [<7d992bc2>] kernel_init_freeable+0xea/0x167
[ 8.541519] [<7cf01070>] kernel_init+0x8/0xb8
[ 8.541519] [<7cf27ec0>] ret_from_kernel_thread+0x20/0x30
[ 8.541519] [<7cf01068>] ? rest_init+0x10c/0x10c
[ 8.541519] Code: 08 c2 c7 05 44 ed f9 7d 00 00 e0 02 c7 05 40 ed f9 7d 00 00 e0 02 c7 05 3c ed f9 7d 00 00 e0 02 75 1f b8 00 00 e0 02 85 c0 74 16 <a1> 00 00 e0 02 c7 05 54 84 8e 7d 00 00 e0 02 a3 58 84 8e 7d eb
[ 8.541519] EIP: [<7d9d67c6>] af9005_usb_module_init+0x6b/0x9d SS:ESP 0068:89c9df2c
[ 8.541519] CR2: 0000000002e00000
[ 8.541519] ---[ end trace 768b6faf51370fc7 ]---
The prefered fix would be to convert the whole IR code to use the kernel IR
infrastructure (which wasn't available at the time this driver had been created).
Until anyone who still has this old hardware steps up an does the conversion,
fix it by not calling the symbol_request calls if the driver is compiled in
without the default IR symbols (CONFIG_DVB_USB_AF9005_REMOTE).
Due to the IR related pointers beeing NULL by default, IR support will then be disabled.
The downside of this solution is, that it will no longer be possible to
compile custom IR symbols (not using CONFIG_DVB_USB_AF9005_REMOTE) in.
Please note that this patch has NOT been tested with all possible cases.
I don't have the hardware and could only verify that it fixes the reported
bug.
Reported-by: Fengguag Wu <fengguang.wu@intel.com>
Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com>
Acked-by: Luca Olivetti <luca@ventoso.org>
commit bc47150ab93988714d1fab7bc82fe5f505a107ad upstream.
The PLL flags were not used correctly.
commit 92b004d1aa9f367c372511ca0330f58216b25703 upstream.
If the probe of an fb driver has been deferred due to missing
dependencies, and the probe is later ran when a module is loaded, the
fbdev framework will try to find a logo to use.
However, the logos are __initdata, and have already been freed. This
causes sometimes page faults, if the logo memory is not mapped,
sometimes other random crashes as the logo data is invalid, and
sometimes nothing, if the fbdev decides to reject the logo (e.g. the
random value depicting the logo's height is too big).
This patch adds a late_initcall function to mark the logos as freed. In
reality the logos are freed later, and fbdev probe may be ran between
this late_initcall and the freeing of the logos. In that case we will
miss drawing the logo, even if it would be possible.
Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
commit e86fb5e8ab95f10ec5f2e9430119d5d35020c951 upstream.
When ring buffer returns an error indicating retry, storvsc may not
return a proper error code to SCSI when bounce buffer is not used.
This has introduced I/O freeze on RAID running atop storvsc devices.
This patch fixes it by always returning a proper error code.
Signed-off-by: Long Li <longli@microsoft.com>
Reviewed-by: K. Y. Srinivasan <kys@microsoft.com>
commit 6bf6ca7515c1df06f5c03737537f5e0eb191e29e upstream.
This patch changes iscsit_do_tx_data() to fail on short writes
when kernel_sendmsg() returns a value different than requested
transfer length, returning -EPIPE and thus causing a connection
reset to occur.
This avoids a potential bug in the original code where a short
write would result in kernel_sendmsg() being called again with
the original iovec base + length.
In practice this has not been an issue because iscsit_do_tx_data()
is only used for transferring 48 byte headers + 4 byte digests,
along with seldom used control payloads from NOPIN + TEXT_RSP +
REJECT with less than 32k of data.
So following Al's audit of iovec consumers, go ahead and fail
the connection on short writes for now, and remove the bogus
logic ahead of his proper upstream fix.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
commit 6583659e0f92e38079a8dd081e0a1181a0f37747 upstream.
HP ZBook 15 laptop needs a non-standard mapping (x_inverted).
BugLink: http://bugzilla.opensuse.org/show_bug.cgi?id=905329
Signed-off-by: Dominique Leuenberger <dimstar@opensuse.org>
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
commit add284a3a2481e759d6bec35f6444c32c8ddc383 upstream.
In order to act as a full command barrier by itself, we need to tell the
pipecontrol to actually stall the command streamer while the flush runs.
We require the full command barrier before operations like
MI_SET_CONTEXT, which currently rely on a prior invalidate flush.
References: https://bugs.freedesktop.org/show_bug.cgi?id=83677
Cc: Simon Farnsworth <simon@farnz.org.uk>
Cc: Daniel Vetter <daniel@ffwll.ch>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
commit 148b83d0815a3778c8949e6a97cb798cbaa0efb3 upstream.
In the gen7 pipe control there is an extra bit to flush the media
caches, so let's set it during cache invalidation flushes.
v2: Rename to MEDIA_STATE_CLEAR to be more inline with spec.
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
commit 410cce2a6b82299b46ff316c6384e789ce275ecb upstream.
The check was already in place in the dp mode_valid check, but
radeon_dp_get_dp_link_clock() never returned the high clock
mode_valid was checking for because that function clipped the
clock based on the hw capabilities. Add an explicit check
in the mode_valid function.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=87172
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 5e5c21cac1001089007260c48b0c89ebaace0e71 upstream.
Check the that ring we are using for copies is functional
rather than the GFX ring. On newer asics we use the DMA
ring for bo moves.
Reviewed-by: Christian König <christian.koenig@amd.com>
commit 89669e7a7f96be3ee8d9a22a071d7c0d3b4428fc upstream.
The commit "vmwgfx: Rework fence event action" introduced a number of bugs
that are fixed with this commit:
a) A forgotten return stateemnt.
b) An if statement with identical branches.
Reported-by: Rob Clark <robdclark@gmail.com>
Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com>
Reviewed-by: Jakob Bornecrantz <jakob@vmware.com>
Reviewed-by: Sinclair Yeh <syeh@vmware.com>
[ Upstream commit 17e96834fd35997ca7cdfbf15413bcd5a36ad448 ]
Hardware always provides compliment of IP pseudo checksum. Stack expects
whole packet checksum without pseudo checksum if CHECKSUM_COMPLETE is set.
This causes checksum error in nf & ovs.
kernel: qg-19546f09-f2: hw csum failure
kernel: CPU: 9 PID: 0 Comm: swapper/9 Tainted: GF O-------------- 3.10.0-123.8.1.el7.x86_64 #1
kernel: Hardware name: Cisco Systems Inc UCSB-B200-M3/UCSB-B200-M3, BIOS B200M3.2.2.3.0.080820141339 08/08/2014
kernel: ffff881218f40000 df68243feb35e3a8 ffff881237a43ab8 ffffffff815e237b
kernel: ffff881237a43ad0 ffffffff814cd4ca ffff8829ec71eb00 ffff881237a43af0
kernel: ffffffff814c6232 0000000000000286 ffff8829ec71eb00 ffff881237a43b00
kernel: Call Trace:
kernel: <IRQ> [<ffffffff815e237b>] dump_stack+0x19/0x1b
kernel: [<ffffffff814cd4ca>] netdev_rx_csum_fault+0x3a/0x40
kernel: [<ffffffff814c6232>] __skb_checksum_complete_head+0x62/0x70
kernel: [<ffffffff814c6251>] __skb_checksum_complete+0x11/0x20
kernel: [<ffffffff8155a20c>] nf_ip_checksum+0xcc/0x100
kernel: [<ffffffffa049edc7>] icmp_error+0x1f7/0x35c [nf_conntrack_ipv4]
kernel: [<ffffffff814cf419>] ? netif_rx+0xb9/0x1d0
kernel: [<ffffffffa040eb7b>] ? internal_dev_recv+0xdb/0x130 [openvswitch]
kernel: [<ffffffffa04c8330>] nf_conntrack_in+0xf0/0xa80 [nf_conntrack]
kernel: [<ffffffff81509380>] ? inet_del_offload+0x40/0x40
kernel: [<ffffffffa049e302>] ipv4_conntrack_in+0x22/0x30 [nf_conntrack_ipv4]
kernel: [<ffffffff815005ca>] nf_iterate+0xaa/0xc0
kernel: [<ffffffff81500664>] nf_hook_slow+0x84/0x140
kernel: [<ffffffff81509dd4>] ip_rcv+0x344/0x380
Hardware verifies IP & tcp/udp header checksum but does not provide payload
checksum, use CHECKSUM_UNNECESSARY. Set it only if its valid IP tcp/udp packet.
Cc: Jiri Benc <jbenc@redhat.com>
Cc: Stefan Assmann <sassmann@redhat.com>
Reported-by: Sunil Choudhary <schoudha@redhat.com>
Signed-off-by: Govindarajulu Varadarajan <_govind@gmx.com>
Reviewed-by: Jiri Benc <jbenc@redhat.com>
[ Upstream commit 7a05dc64e2e4c611d89007b125b20c0d2a4d31a5 ]
Commit d75b1ade567f ("net: less interrupt masking in NAPI") uncovered
wrong alx_poll() behavior.
A NAPI poll() handler is supposed to return exactly the budget when/if
napi_complete() has not been called.
It is also supposed to return number of frames that were received, so
that netdev_budget can have a meaning.
Also, in case of TX pressure, we still have to dequeue received
packets : alx_clean_rx_irq() has to be called even if
alx_clean_tx_irq(alx) returns false, otherwise device is half duplex.
Fixes: d75b1ade567f ("net: less interrupt masking in NAPI")
Reported-by: Oded Gabbay <oded.gabbay@amd.com>
Bisected-by: Oded Gabbay <oded.gabbay@amd.com>
Tested-by: Oded Gabbay <oded.gabbay@amd.com>
[ Upstream commit 05b0aa579397b734f127af58e401a30784a1e315 ]
During driver load in tg3_init_one, if the driver detects DMA activity before
intializing the chip tg3_halt is called. As part of tg3_halt interrupts are
disabled using routine tg3_disable_ints. This routine was using mailbox value
which was not initialized (default value is 0). As a result driver was writing
0x00000001 to pci config space register 0, which is the vendor id / device id.
This driver bug was exposed because of the commit a7877b17a667 (PCI: Check only
the Vendor ID to identify Configuration Request Retry). Also this issue is only
seen in older generation chipsets like 5722 because config space write to offset
0 from driver is possible. The newer generation chips ignore writes to offset 0.
Also without commit a7877b17a667, for these older chips when a GRC reset is
issued the Bootcode would reprogram the vendor id/device id, which is the reason
this bug was masked earlier.
Fixed by initializing the interrupt mailbox registers before calling tg3_halt.
Please queue for -stable.
Reported-by: Nils Holland <nholland@tisys.org>
Reported-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Signed-off-by: Prashant Sreedharan <prashant@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
commit 1ff383a4c3eda8893ec61b02831826e1b1f46b41 upstream.
This patch adds waiting until transmit buffer and shifter will be empty
before clock disabling.
Without this fix it's possible to have clock disabled while data was
not transmited yet, which causes unproper state of TX line and problems
in following data transfers.
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
commit d908f8478a8d18e66c80a12adb27764920c1f1ca upstream.
If probe() fails not only the attributes need to be removed
but also the memory freed.
Reported-by: Ahmed Tamrawi <ahmedtamrawi@gmail.com>
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit 403dff4e2c94f275e24fd85f40b2732ffec268a1 upstream.
We need to check that we have both a valid data and control inteface for both
types of headers (union and not union.)
References: https://bugzilla.kernel.org/show_bug.cgi?id=83551
Reported-by: Simon Schubert <2+kernel@0x2c.org>
