path: root/drivers
2016-10-31mpt3sas: Don't spam logs if logging level is 0Johannes Thumshirn
commit 0d667f72b2a20bbac72bec0ab11467fc70bb0f1f upstream. In _scsih_io_done() we test if the ioc->logging_level does _not_ have the MPT_DEBUG_REPLY bit set and if it hasn't we print the debug messages. This unfortunately is the wrong way around. Note, the actual bug is older than af0094115 but this commit removed the CONFIG_SCSI_MPT3SAS_LOGGING Kconfig option which hid the bug. Fixes: af0094115 'mpt2sas, mpt3sas: Remove SCSI_MPTXSAS_LOGGING entry from Kconfig' Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de> Acked-by: Chaitra P B <chaitra.basappa@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31clk: divider: Fix clk_divider_round_rate() to use clk_readl()Geert Uytterhoeven
commit 2cf9a57811bddb6fa6b0f8d7376da164d5534813 upstream. clk-divider uses clk_readl()/clk_writel() everywhere, except in clk_divider_round_rate(), where plain readl() is used. Change this to clk_readl(), as it makes a difference on powerpc. Fixes: e6d5e7d90be92cee ("clk-divider: Fix READ_ONLY when divider > 1") Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31clk: qoriq: fix a register offset errorTang Yuantian
commit 8964193f6bfda5c4cf14eedb7e94892c1f1c34f0 upstream. The offset of Core Cluster clock control/status register on cluster group V3 version is different from others, and should be plus 0x70000. Signed-off-by: Tang Yuantian <yuantian.tang@nxp.com> Reviewed-by: Scott Wood <oss@buserror.net> Fixes: 9e19ca2f627e ("clk: qoriq: Add ls2080a support.") Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31s390/con3270: fix insufficient space paddingSascha Silbe
commit 6cd997db911f28f2510b771691270c52b63ed2e6 upstream. con3270 contains an optimisation that reduces the amount of data to be transmitted to the 3270 terminal by putting a Repeat to Address (RA) order into the data stream. The RA order itself takes up space, so con3270 only uses it if there's enough space left in the line buffer. Otherwise it just pads out the line manually. For lines that were _just_ short enough that the RA order still fit in the line buffer, the line was instead padded with an insufficient amount of spaces. This was caused by examining the size of the allocated line buffer rather than the length of the string to be displayed. For con3270_cline_end(), we just compare against the line length. For con3270_update_string() however that isn't available anymore, so we check whether the Repeat to Address order is present. Fixes: f51320a5 ("[PATCH] s390: new 3270 driver.") (tglx/history.git) Tested-by: Jing Liu <liujbjl@linux.vnet.ibm.com> Tested-by: Yang Chen <bjcyang@linux.vnet.ibm.com> Signed-off-by: Sascha Silbe <silbe@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31s390/con3270: fix use of uninitialised dataSascha Silbe
commit c14f2aac7aa147861793eed9f41f91dd530f0be1 upstream. con3270 contains an optimisation that reduces the amount of data to be transmitted to the 3270 terminal by putting a Repeat to Address (RA) order into the data stream. The RA order itself takes up space, so con3270 only uses it if there's enough space left in the line buffer. Otherwise it just pads out the line manually. For lines too long to include the RA order, one byte was left uninitialised. This was caused by an off-by-one bug in the loop that pads out the line. Since the buffer is allocated from a common pool, the single byte left uninitialised contained some previous buffer content. Usually this was just a space or some character (which can result in clutter but is otherwise harmless). Sometimes, however, it was a Repeat to Address order, messing up the entire screen layout and causing the display to send the entire buffer content on every keystroke. Fixes: f51320a5 ("[PATCH] s390: new 3270 driver.") (tglx/history.git) Reported-by: Liu Jing <liujbjl@linux.vnet.ibm.com> Tested-by: Jing Liu <liujbjl@linux.vnet.ibm.com> Tested-by: Yang Chen <bjcyang@linux.vnet.ibm.com> Signed-off-by: Sascha Silbe <silbe@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31s390/cio: fix accidental interrupt enabling during resumeSebastian Ott
commit d53c51f26145657aa7c55fa396f93677e613548d upstream. Since commit 9f3d6d7 chsc_get_channel_measurement_chars is called with interrupts disabled during resume from hibernate. Since this function used spin_unlock_irq, interrupts have been enabled accidentally. Fix this by using the irqsave variant. Since we can't guarantee the IRQ-enablement state for all (future/ external) callers, change the locking in related functions to prevent similar bugs in the future. Fixes: 9f3d6d7 ("s390/cio: update measurement characteristics") Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Reviewed-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31dmaengine: ipu: remove bogus NO_IRQ referenceArnd Bergmann
commit 86c7e6836479c4045a9a81ed5ea76c51d719f9c1 upstream. A workaround for a warning introduced a use of the NO_IRQ macro that should have been gone for a long time. It is clear from the code that the value cannot actually be used, but apparently there was a configuration at some point that caused a warning, so instead of just reverting that patch, this rearranges the code in a way that the warning cannot reappear. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 6ef41cf6f721 ("dmaengine :ipu: change ipu_irq_handler() to remove compile warning") Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31power: bq24257: Fix use of uninitialized pointer bq->chargerGeorges Savoundararadj
commit 0610735928ee47870e083d5901caa371089216f1 upstream. bq->charger is initialized in bq24257_power_supply_init. Therefore, bq24257_power_supply_init should be called before the registration of the IRQ handler bq24257_irq_handler_thread that calls power_supply_changed(bq->charger). Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Cc: Aurelien Chanot <chanot.a@gmail.com> Cc: Andreas Dannenberg <dannenberg@ti.com> Cc: Sebastian Reichel <sre@kernel.org> Cc: David Woodhouse <dwmw2@infradead.org> Fixes: 2219a935963e ("power_supply: Add TI BQ24257 charger driver") Signed-off-by: Sebastian Reichel <sre@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31staging: r8188eu: Fix scheduling while atomic splatLarry Finger
commit 1335a9516d3d52f157ad87456efdd8dc9ae1747b upstream. Commit fadbe0cd5292851608e2e01b91d9295fa287b9fe ("staging: rtl8188eu: Remove rtw_zmalloc(), wrapper for kzalloc()") changed all allocation calls to be GFP_KERNEL even though the original wrapper was testing to determine if the caller was in atomic mode. Most of the mistakes were corrected with commit 33dc85c3c667209c930b2dac5ccbc2a365e06b7a ("staging: r8188eu: Fix scheduling while atomic error introduced in commit fadbe0cd"); however, two kzalloc calls were missed as the call only happens when the driver is shutting down. Fixes: fadbe0cd5292851608e2e01b91d9295fa287b9fe ("staging: rtl8188eu: Remove rtw_zmalloc(), wrapper for kzalloc()") Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: navin patidar <navin.patidar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31hwrng: omap - Only fail if pm_runtime_get_sync returns < 0Dave Gerlach
commit ad8529fde9e3601180a839867a8ab041109aebb5 upstream. Currently omap-rng checks the return value of pm_runtime_get_sync and reports failure if anything is returned, however it should be checking if ret < 0 as pm_runtime_get_sync return 0 on success but also can return 1 if the device was already active which is not a failure case. Only values < 0 are actual failures. Fixes: 61dc0a446e5d ("hwrng: omap - Fix assumption that runtime_get_sync will always succeed") Signed-off-by: Dave Gerlach <d-gerlach@ti.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31mwifiex: correct aid value during tdls setupXinming Hu
commit b64db1b252e9974a43a51ba083fa7d03e4716167 upstream. AID gets updated during TDLS setup, but modified value isn't reflected in "priv->assoc_rsp_buf". This causes TDLS setup failure. The problem is fixed here. Fixes: 4aff53ef18e4a4 ("mwifiex: parsing aid while receiving..") Signed-off-by: Xinming Hu <huxm@marvell.com> Signed-off-by: Amitkumar Karwar <akarwar@marvell.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31spi: spi-fsl-dspi: Drop extra spi_master_put in device remove functionWei Yongjun
commit 6999aeabbb703a81a204cb6f9f8f151759a99ac4 upstream. The call sequence spi_alloc_master/spi_register_master/spi_unregister_master is complete; it reduces the device reference count to zero, which and results in device memory being freed. The subsequent call to spi_master_put is unnecessary and results in an access to free memory. Drop it. Fixes: 9298bc727385 ("spi: spi-fsl-dspi: Remove spi-bitbang") Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31ARM: clk-imx35: fix name for ckil clkUwe Kleine-König
commit fcff03813a7c612873303037cef5ba0329850c35 upstream. This fixes [ 0.000000] i.MX clk 82: register failed with -17 because the name is duplicated. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Fixes: 3713e3f5e927 ("clk: imx35: define two clocks for rtc") Acked-by: Shawn Guo <shawnguo@kernel.org> Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31uio: fix dmem_region_start computationJan Viktorin
commit 4d31a2588ae37a5d0f61f4d956454e9504846aeb upstream. The variable i contains a total number of resources (including IORESOURCE_IRQ). However, we want the dmem_region_start to point after the last resource of type IORESOURCE_MEM. The original behaviour leads (very likely) to skipping several UIO mapping regions and makes them useless. Fix this by computing dmem_region_start from the uiomem which points to the last used UIO mapping. Fixes: 0a0c3b5a24bd ("Add new uio device for dynamic memory allocation") Signed-off-by: Jan Viktorin <viktorin@rehivetech.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31brcmfmac: avoid potential stack overflow in brcmf_cfg80211_start_ap()Arend Van Spriel
commit ded89912156b1a47d940a0c954c43afbabd0c42c upstream. User-space can choose to omit NL80211_ATTR_SSID and only provide raw IE TLV data. When doing so it can provide SSID IE with length exceeding the allowed size. The driver further processes this IE copying it into a local variable without checking the length. Hence stack can be corrupted and used as exploit. Reported-by: Daxing Guo <freener.gdx@gmail.com> Reviewed-by: Hante Meuleman <hante.meuleman@broadcom.com> Reviewed-by: Pieter-Paul Giesberts <pieter-paul.giesberts@broadcom.com> Reviewed-by: Franky Lin <franky.lin@broadcom.com> Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/i915: Unalias obj->phys_handle and obj->userptrChris Wilson
commit ca5732c53bf66ad755284786897e0dd10330de87 upstream. We use obj->phys_handle to choose the pread/pwrite path, but as obj->phys_handle is a union with obj->userptr, we then mistakenly use the phys_handle path for userptr objects within pread/pwrite. Testcase: igt/gem_userptr_blits/forbidden-operations Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97519 Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20161003124516.12388-2-chris@chris-wilson.co.uk (cherry picked from commit 5f12b80a0b42da253691ca03828033014bb786eb) Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/i915: Account for TSEG size when determining 865G stolen baseVille Syrjälä
commit d721b02fd00bf133580f431b82ef37f3b746dfb2 upstream. Looks like the TSEG lives just above TOUD, stolen comes after TSEG. The spec seems somewhat self-contradictory in places, in the ESMRAMC register desctription it says: TSEG Size: 10=(TOUD + 512 KB) to TOUD 11 =(TOUD + 1 MB) to TOUD so that agrees with TSEG being at TOUD. But the example given elsehwere in the spec says: TOUD equals 62.5 MB = 03E7FFFFh TSEG selected as 512 KB in size, Graphics local memory selected as 1 MB in size General System RAM available in system = 62.5 MB General system RAM range00000000h to 03E7FFFFh TSEG address range03F80000h to 03FFFFFFh TSEG pre-allocated from03F80000h to 03FFFFFFh Graphics local memory pre-allocated from03E80000h to 03F7FFFFh so here we have TSEG above stolen. Real world evidence agrees with the TOUD->TSEG->stolen order however, so let's fix up the code to account for the TSEG size. Cc: Taketo Kabe <fdporg@vega.pgw.jp> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: x86@kernel.org Fixes: 0ad98c74e093 ("drm/i915: Determine the stolen memory base address on gen2") Fixes: a4dff76924fe ("x86/gpu: Add Intel graphics stolen memory quirk for gen2 platforms") Reported-by: Taketo Kabe <fdporg@vega.pgw.jp> Tested-by: Taketo Kabe <fdporg@vega.pgw.jp> Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=96473 Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1470653919-27251-1-git-send-email-ville.syrjala@linux.intel.com Link: http://download.intel.com/design/chipsets/datashts/25251405.pdf Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31Revert "drm/i915: Check live status before reading edid"David Weinehall
commit 23f889bdf6ee5cfff012d8b09f6bec920c691696 upstream. This reverts commit 237ed86c693d8a8e4db476976aeb30df4deac74b. Our current implementation of live status check (repeat 9 times with 10ms delays between each attempt as a workaround for buggy displays) imposes a rather serious penalty, time wise, on intel_hdmi_detect(). Since we we already skip live status checks on platforms before gen 7, and since we seem to have coped quite well before the live status check was introduced for newer platforms too, the previous behaviour is probably preferable, at least unless someone can point to a use-case that the live status check improves (apart from "Bspec says so".) Signed-off-by: David Weinehall <david.weinehall@linux.intel.com> Fixes: 237ed86c693d ("drm/i915: Check live status before reading edid") Fixes: f8d03ea0053b ("drm/i915: increase the tries for HDMI hotplug live status checking") Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=97139 Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=94014 Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Jani Nikula <jani.nikula@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20160817124748.31208-1-david.weinehall@linux.intel.com Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/i915/gen9: fix the WaWmMemoryReadLatency implementationPaulo Zanoni
commit 4e4d3814a9bb4d71cd3ff0701d8d7041edefd8f0 upstream. Bspec says: "The mailbox response data may not account for memory read latency. If the mailbox response data for level 0 is 0us, add 2 microseconds to the result for each valid level." This means we should only do the +2 in case wm[0] == 0, not always. So split the sanitizing implementation from the WA implementation and fix the WA implementation. v2: Add Fixes tag (Maarten). Fixes: 367294be7c25 ("drm/i915/gen9: Add 2us read latency to WM level") Cc: Vandana Kannan <vandana.kannan@intel.com> Reviewed-by: Maarten Lankhorst <maarten.lankhorst@linux.intel.com> Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1474578035-424-5-git-send-email-paulo.r.zanoni@intel.com (cherry picked from commit 0727e40a48a1d08cf54ce2c01e120864b92e59bf) Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31xenbus: don't look up transaction IDs for ordinary writesJan Beulich
commit 9a035a40f7f3f6708b79224b86c5777a3334f7ea upstream. This should really only be done for XS_TRANSACTION_END messages, or else at least some of the xenstore-* tools don't work anymore. Fixes: 0beef634b8 ("xenbus: don't BUG() on user mode induced condition") Reported-by: Richard Schütz <rschuetz@uni-koblenz.de> Signed-off-by: Jan Beulich <jbeulich@suse.com> Tested-by: Richard Schütz <rschuetz@uni-koblenz.de> Signed-off-by: David Vrabel <david.vrabel@citrix.com> Cc: "M. Vefa Bicakci" <m.v.b@runbox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/vmwgfx: Limit the user-space command buffer sizeThomas Hellstrom
commit 51ab70bed997f64f091a639dbe22b629725a7faf upstream. With older hardware versions, the user could specify arbitrarily large command buffer sizes, causing a vmalloc / vmap space exhaustion. Signed-off-by: Thomas Hellstrom <thellstrom@vmware.com> Reviewed-by: Brian Paul <brianp@vmware.com> Reviewed-by: Sinclair Yeh <syeh@vmware.com> Signed-off-by: Sinclair Yeh <syeh@vmware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/radeon: change vblank_time's calculation method to reduce computational ↵Alex Deucher
error. commit 02cfb5fccb0f9f968f0e208d89d9769aa16267bc upstream. Ported from Rex's amdgpu change. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/radeon/si/dpm: fix phase shedding setupAlex Deucher
commit 427920292b00474d978d632bc03a8e4e50029af3 upstream. Used the wrong index to setup the phase shedding mask. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/radeon: narrow asic_init for virtualizationAlex Deucher
commit 884031f0aacf57dad1575f96714efc80de9b19cc upstream. Only needed on CIK+ due to the way pci reset is handled by the GPU. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/amdgpu: change vblank_time's calculation method to reduce computational ↵Rex Zhu
error. commit dc8184aa8621ee8048652496884d9f40d4bb407f upstream. Signed-off-by: Rex Zhu <Rex.Zhu@amd.com> Reviewed-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/amdgpu/dce11: add missing drm_mode_config_cleanup callGrazvydas Ignotas
commit 140c94da3c3338c0ff4cc127cf9bec87905ca83c upstream. All other amdgpu/dce_v* files have this call, it's only mysteriously missing from dce_v11_0.c since the file was added and causes leaks. Fixes: aaa36a976bbb ("drm/amdgpu: Add initial VI support") Signed-off-by: Grazvydas Ignotas <notasas@gmail.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/amdgpu/dce11: disable hpd on local panelsAlex Deucher
commit 3a9d993ee9809c217f4322623a9b78c8d17fdd1f upstream. Otherwise we can get a hotplug interrupt storm when we turn the panel off if hpd interrupts were enabled by the bios. bug: https://bugs.freedesktop.org/show_bug.cgi?id=97471 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/amdgpu/dce8: disable hpd on local panelsAlex Deucher
commit 324082586cc5918e3230f0b2f326656c653201eb upstream. Otherwise we can get a hotplug interrupt storm when we turn the panel off if hpd interrupts were enabled by the bios. bug: https://bugs.freedesktop.org/show_bug.cgi?id=97471 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/amdgpu/dce10: disable hpd on local panelsAlex Deucher
commit e96ec90f496603c48e0945f8bdeb4cdf3088cbba upstream. Otherwise we can get a hotplug interrupt storm when we turn the panel off if hpd interrupts were enabled by the bios. bug: https://bugs.freedesktop.org/show_bug.cgi?id=97471 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/amdgpu: fix IB alignment for UVDAlex Deucher
commit c4795ca642b8bd76b5b6ffba41ba909543273d43 upstream. According to the hw team, it should be 16, not 8. Cc: Peter Fang <peter.fang@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31drm/prime: Pass the right module owner through to dma_buf_export()Chris Wilson
commit 56a76c0123d6cb034975901c80fce2627338ef9e upstream. dma_buf_export() adds a reference to the owning module to the dmabuf (to prevent the driver from being unloaded whilst a third party still refers to the dmabuf). However, drm_gem_prime_export() was passing its own THIS_MODULE (i.e. drm.ko) rather than the driver. Extract the right owner from the device->fops instead. v2: Use C99 initializers to zero out unset elements of dma_buf_export_info v3: Extract the right module from dev->fops. Testcase: igt/vgem_basic/unload Reported-by: Petri Latvala <petri.latvala@intel.com> Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Petri Latvala <petri.latvala@intel.com> Cc: Christian König <christian.koenig@amd.com> Tested-by: Petri Latvala <petri.latvala@intel.com> Reviewed-by: Petri Latvala <petri.latvala@intel.com> Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/20161005122145.1507-1-chris@chris-wilson.co.uk Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28target: Don't override EXTENDED_COPY xcopy_pt_cmd SCSI status codeDinesh Israni
commit 926317de33998c112c5510301868ea9aa34097e2 upstream. This patch addresses a bug where a local EXTENDED_COPY WRITE or READ backend I/O request would always return SAM_STAT_CHECK_CONDITION, even if underlying xcopy_pt_cmd->se_cmd generated a different SCSI status code. ESX host environments expect to hit SAM_STAT_RESERVATION_CONFLICT for certain scenarios, and SAM_STAT_CHECK_CONDITION results in non-retriable status for these cases. Tested on v4.1.y with ESX v5.5u2+ with local IBLOCK backend copy. Reported-by: Nixon Vincent <nixon.vincent@calsoftinc.com> Tested-by: Nixon Vincent <nixon.vincent@calsoftinc.com> Cc: Nixon Vincent <nixon.vincent@calsoftinc.com> Tested-by: Dinesh Israni <ddi@datera.io> Signed-off-by: Dinesh Israni <ddi@datera.io> Cc: Dinesh Israni <ddi@datera.io> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28target: Make EXTENDED_COPY 0xe4 failure return COPY TARGET DEVICE NOT REACHABLENicholas Bellinger
commit 449a137846c84829a328757cd21fd9ca65c08519 upstream. This patch addresses a bug where EXTENDED_COPY across multiple LUNs results in a CHECK_CONDITION when the source + destination are not located on the same physical node. ESX Host environments expect sense COPY_ABORTED w/ COPY TARGET DEVICE NOT REACHABLE to be returned when this occurs, in order to signal fallback to local copy method. As described in section 6.3.3 of spc4r22: "If it is not possible to complete processing of a segment because the copy manager is unable to establish communications with a copy target device, because the copy target device does not respond to INQUIRY, or because the data returned in response to INQUIRY indicates an unsupported logical unit, then the EXTENDED COPY command shall be terminated with CHECK CONDITION status, with the sense key set to COPY ABORTED, and the additional sense code set to COPY TARGET DEVICE NOT REACHABLE." Tested on v4.1.y with ESX v5.5u2+ with BlockCopy across multiple nodes. Reported-by: Nixon Vincent <nixon.vincent@calsoftinc.com> Tested-by: Nixon Vincent <nixon.vincent@calsoftinc.com> Cc: Nixon Vincent <nixon.vincent@calsoftinc.com> Tested-by: Dinesh Israni <ddi@datera.io> Signed-off-by: Dinesh Israni <ddi@datera.io> Cc: Dinesh Israni <ddi@datera.io> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28target: Re-add missing SCF_ACK_KREF assignment in v4.1.yNicholas Bellinger
commit 527268df31e57cf2b6d417198717c6d6afdb1e3e upstream. This patch fixes a regression in >= v4.1.y code where the original SCF_ACK_KREF assignment in target_get_sess_cmd() was dropped upstream in commit 054922bb, but the series for addressing TMR ABORT_TASK + LUN_RESET with fabric session reinstatement in commit febe562c20 still depends on this code in transport_cmd_finish_abort(). The regression manifests itself as a se_cmd->cmd_kref +1 leak, where ABORT_TASK + LUN_RESET can hang indefinately for a specific I_T session for drivers using SCF_ACK_KREF, resulting in hung kthreads. This patch has been verified with v4.1.y code. Reported-by: Vaibhav Tandon <vst@datera.io> Tested-by: Vaibhav Tandon <vst@datera.io> Cc: Vaibhav Tandon <vst@datera.io> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28mmc: rtsx_usb_sdmmc: Handle runtime PM while changing the ledUlf Hansson
commit 4f48aa7a11bfed9502a7c85a5b68cd40ea827f73 upstream. Accesses of the rtsx sdmmc's parent device, which is the rtsx usb device, must be done when it's runtime resumed. Currently this isn't case when changing the led, so let's fix this by adding a pm_runtime_get_sync() and a pm_runtime_put() around those operations. Reported-by: Ritesh Raj Sarraf <rrs@researchut.com> Tested-by: Ritesh Raj Sarraf <rrs@researchut.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28mmc: rtsx_usb_sdmmc: Avoid keeping the device runtime resumed when unusedUlf Hansson
commit 31cf742f515c275d22843c4c756e048d2b6d716c upstream. The rtsx_usb_sdmmc driver may bail out in its ->set_ios() callback when no SD card is inserted. This is wrong, as it could cause the device to remain runtime resumed when it's unused. Fix this behaviour. Tested-by: Ritesh Raj Sarraf <rrs@researchut.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28mmc: core: Annotate cmd_hdr as __le32Jiri Slaby
commit 3f2d26643595973e835e8356ea90c7c15cb1b0f1 upstream. Commit f68381a70bb2 (mmc: block: fix packed command header endianness) correctly fixed endianness handling of packed_cmd_hdr in mmc_blk_packed_hdr_wrq_prep. But now, sparse complains about incorrect types: drivers/mmc/card/block.c:1613:27: sparse: incorrect type in assignment (different base types) drivers/mmc/card/block.c:1613:27: expected unsigned int [unsigned] [usertype] <noident> drivers/mmc/card/block.c:1613:27: got restricted __le32 [usertype] <noident> ... So annotate cmd_hdr properly using __le32 to make everyone happy. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Fixes: f68381a70bb2 (mmc: block: fix packed command header endianness) Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28memstick: rtsx_usb_ms: Manage runtime PM when accessing the deviceUlf Hansson
commit 9158cb29e7c2f10dd325eb1589f0fe745a271257 upstream. Accesses to the rtsx usb device, which is the parent of the rtsx memstick device, must not be done unless it's runtime resumed. This is currently not the case and it could trigger various errors. Fix this by properly deal with runtime PM in this regards. This means making sure the device is runtime resumed, when serving requests via the ->request() callback or changing settings via the ->set_param() callbacks. Cc: Ritesh Raj Sarraf <rrs@researchut.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28memstick: rtsx_usb_ms: Runtime resume the device when polling for cardsAlan Stern
commit 796aa46adf1d90eab36ae06a42e6d3f10b28a75c upstream. Accesses to the rtsx usb device, which is the parent of the rtsx memstick device, must not be done unless it's runtime resumed. Therefore when the rtsx_usb_ms driver polls for inserted memstick cards, let's add pm_runtime_get|put*() to make sure accesses is done when the rtsx usb device is runtime resumed. Reported-by: Ritesh Raj Sarraf <rrs@researchut.com> Tested-by: Ritesh Raj Sarraf <rrs@researchut.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28acpi, nfit: check for the correct event code in notificationsVishal Verma
commit c09f12186d6b03b798832d95289af76495990192 upstream. Commit 209851649dc4 "acpi: nfit: Add support for hot-add" added support for _FIT notifications, but it neglected to verify the notification event code matches the one in the ACPI spec for "NFIT Update". Currently there is only one code in the spec, but once additional codes are added, older kernels (without this fix) will misbehave by assuming all event notifications are for an NFIT Update. Fixes: 209851649dc4 ("acpi: nfit: Add support for hot-add") Cc: <stable@vger.kernel.org> Cc: <linux-acpi@vger.kernel.org> Cc: Dan Williams <dan.j.williams@intel.com> Reported-by: Linda Knippers <linda.knippers@hpe.com> Signed-off-by: Vishal Verma <vishal.l.verma@intel.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28net/mlx4_core: Allow resetting VF admin mac to zeroJack Morgenstein
commit 6e5224224faa50ec4c8949dcefadf895e565f0d1 upstream. The VF administrative mac addresses (stored in the PF driver) are initialized to zero when the PF driver starts up. These addresses may be modified in the PF driver through ndo calls initiated by iproute2 or libvirt. While we allow the PF/host to change the VF admin mac address from zero to a valid unicast mac, we do not allow restoring the VF admin mac to zero. We currently only allow changing this mac to a different unicast mac. This leads to problems when libvirt scripts are used to deal with VF mac addresses, and libvirt attempts to revoke the mac so this host will not use it anymore. Fix this by allowing resetting a VF administrative MAC back to zero. Fixes: 8f7ba3ca12f6 ('net/mlx4: Add set VF mac address support') Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Reported-by: Moshe Levi <moshele@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28bnx2x: Prevent false warning for lack of FC NPIVYuval Mintz
commit 1e6bb1a3540fec3ef112b9a89dda88e684c3ff59 upstream. Not all adapters have FC-NPIV configured. If bnx2fc is used with such an adapter, driver would read irrelevant data from the the nvram and log "FC-NPIV table with bad length..." In system logs. Simply accept that reading '0' as the feature offset in nvram indicates the feature isn't there and return. Reported-by: Andrew Patterson <andrew.patterson@hpe.com> Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28hpsa: correct skipping masked peripheralsDon Brace
commit 64ce60cab24603ac0fcd59c9fbc3be78f4c4d229 upstream. The SA controller spins down RAID drive spares. A REGNEWD event causes an inquiry to be sent to all physical drives. This causes the SA controller to spin up the spare. The controller suspends all I/O to a logical volume until the spare is spun up. The spin-up can take over 50 seconds. This can result in one or both of the following: - SML sends down aborts and resets to the logical volume and can cause the logical volume to be off-lined. - a negative impact on the logical volume's I/O performance each time a REGNEWD is triggered. Reviewed-by: Scott Teel <scott.teel@microsemi.com> Reviewed-by: Kevin Barnett <kevin.barnett@microsemi.com> Signed-off-by: Don Brace <don.brace@microsemi.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28sd: Fix rw_max for devices that report an optimal xfer sizeMartin K. Petersen
commit 6b7e9cde49691e04314342b7dce90c67ad567fcc upstream. For historic reasons, io_opt is in bytes and max_sectors in block layer sectors. This interface inconsistency is error prone and should be fixed. But for 4.4--4.7 let's make the unit difference explicit via a wrapper function. Fixes: d0eb20a863ba ("sd: Optimal I/O size is in bytes, not sectors") Reported-by: Fam Zheng <famz@redhat.com> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Tested-by: Andrew Patterson <andrew.patterson@hpe.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Juerg Haefliger <juerg.haefliger@hpe.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28irqchip/gicv3: Handle loop timeout properDan Carpenter
commit d102eb5c1ac5e6743b1c6d145c06a25d98ad1375 upstream. The timeout loop terminates when the loop count is zero, but the decrement of the count variable is post check. So count is -1 when we check for the timeout and therefor the error message is supressed. Change it to predecrement, so the error message is emitted. [ tglx: Massaged changelog ] Fixes: a2c225101234 ("irqchip: gic-v3: Refactor gic_enable_redist to support both enabling and disabling") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Sudeep Holla <sudeep.holla@arm.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: kernel-janitors@vger.kernel.org Cc: Jason Cooper <jason@lakedaemon.net> Link: http://lkml.kernel.org/r/20161014072534.GA15168@mwanda Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28scsi: Fix use-after-freeMing Lei
commit bcd8f2e94808fcddf6ef3af5f060a36820dcc432 upstream. This patch fixes one use-after-free report[1] by KASAN. In __scsi_scan_target(), when a type 31 device is probed, SCSI_SCAN_TARGET_PRESENT is returned and the target will be scanned again. Inside the following scsi_report_lun_scan(), one new scsi_device instance is allocated, and scsi_probe_and_add_lun() is called again to probe the target and still see type 31 device, finally __scsi_remove_device() is called to remove & free the device at the end of scsi_probe_and_add_lun(), so cause use-after-free in scsi_report_lun_scan(). And the following SCSI log can be observed: scsi 0:0:2:0: scsi scan: INQUIRY pass 1 length 36 scsi 0:0:2:0: scsi scan: INQUIRY successful with code 0x0 scsi 0:0:2:0: scsi scan: peripheral device type of 31, no device added scsi 0:0:2:0: scsi scan: Sending REPORT LUNS to (try 0) scsi 0:0:2:0: scsi scan: REPORT LUNS successful (try 0) result 0x0 scsi 0:0:2:0: scsi scan: REPORT LUN scan scsi 0:0:2:0: scsi scan: INQUIRY pass 1 length 36 scsi 0:0:2:0: scsi scan: INQUIRY successful with code 0x0 scsi 0:0:2:0: scsi scan: peripheral device type of 31, no device added BUG: KASAN: use-after-free in __scsi_scan_target+0xbf8/0xe40 at addr ffff88007b44a104 This patch fixes the issue by moving the putting reference at the end of scsi_report_lun_scan(). [1] KASAN report ================================================================== [ 3.274597] PM: Adding info for serio:serio1 [ 3.275127] BUG: KASAN: use-after-free in __scsi_scan_target+0xd87/0xdf0 at addr ffff880254d8c304 [ 3.275653] Read of size 4 by task kworker/u10:0/27 [ 3.275903] CPU: 3 PID: 27 Comm: kworker/u10:0 Not tainted 4.8.0 #2121 [ 3.276258] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS Ubuntu-1.8.2-1ubuntu1 04/01/2014 [ 3.276797] Workqueue: events_unbound async_run_entry_fn [ 3.277083] ffff880254d8c380 ffff880259a37870 ffffffff94bbc6c1 ffff880078402d80 [ 3.277532] ffff880254d8bb80 ffff880259a37898 ffffffff9459fec1 ffff880259a37930 [ 3.277989] ffff880254d8bb80 ffff880078402d80 ffff880259a37920 ffffffff945a0165 [ 3.278436] Call Trace: [ 3.278528] [<ffffffff94bbc6c1>] dump_stack+0x65/0x84 [ 3.278797] [<ffffffff9459fec1>] kasan_object_err+0x21/0x70 [ 3.279063] device: 'psaux': device_add [ 3.279616] [<ffffffff945a0165>] kasan_report_error+0x205/0x500 [ 3.279651] PM: Adding info for No Bus:psaux [ 3.280202] [<ffffffff944ecd22>] ? kfree_const+0x22/0x30 [ 3.280486] [<ffffffff94bc2dc9>] ? kobject_release+0x119/0x370 [ 3.280805] [<ffffffff945a0543>] __asan_report_load4_noabort+0x43/0x50 [ 3.281170] [<ffffffff9507e1f7>] ? __scsi_scan_target+0xd87/0xdf0 [ 3.281506] [<ffffffff9507e1f7>] __scsi_scan_target+0xd87/0xdf0 [ 3.281848] [<ffffffff9507d470>] ? scsi_add_device+0x30/0x30 [ 3.282156] [<ffffffff94f7f660>] ? pm_runtime_autosuspend_expiration+0x60/0x60 [ 3.282570] [<ffffffff956ddb07>] ? _raw_spin_lock+0x17/0x40 [ 3.282880] [<ffffffff9507e505>] scsi_scan_channel+0x105/0x160 [ 3.283200] [<ffffffff9507e8a2>] scsi_scan_host_selected+0x212/0x2f0 [ 3.283563] [<ffffffff9507eb3c>] do_scsi_scan_host+0x1bc/0x250 [ 3.283882] [<ffffffff9507efc1>] do_scan_async+0x41/0x450 [ 3.284173] [<ffffffff941c1fee>] async_run_entry_fn+0xfe/0x610 [ 3.284492] [<ffffffff941a8954>] ? pwq_dec_nr_in_flight+0x124/0x2a0 [ 3.284876] [<ffffffff941d1770>] ? preempt_count_add+0x130/0x160 [ 3.285207] [<ffffffff941a9a84>] process_one_work+0x544/0x12d0 [ 3.285526] [<ffffffff941aa8e9>] worker_thread+0xd9/0x12f0 [ 3.285844] [<ffffffff941aa810>] ? process_one_work+0x12d0/0x12d0 [ 3.286182] [<ffffffff941bb365>] kthread+0x1c5/0x260 [ 3.286443] [<ffffffff940855cd>] ? __switch_to+0x88d/0x1430 [ 3.286745] [<ffffffff941bb1a0>] ? kthread_worker_fn+0x5a0/0x5a0 [ 3.287085] [<ffffffff956dde9f>] ret_from_fork+0x1f/0x40 [ 3.287368] [<ffffffff941bb1a0>] ? kthread_worker_fn+0x5a0/0x5a0 [ 3.287697] Object at ffff880254d8bb80, in cache kmalloc-2048 size: 2048 [ 3.288064] Allocated: [ 3.288147] PID = 27 [ 3.288218] [<ffffffff940b27ab>] save_stack_trace+0x2b/0x50 [ 3.288531] [<ffffffff9459f246>] save_stack+0x46/0xd0 [ 3.288806] [<ffffffff9459f4bd>] kasan_kmalloc+0xad/0xe0 [ 3.289098] [<ffffffff9459c07e>] __kmalloc+0x13e/0x250 [ 3.289378] [<ffffffff95078e5a>] scsi_alloc_sdev+0xea/0xcf0 [ 3.289701] [<ffffffff9507de76>] __scsi_scan_target+0xa06/0xdf0 [ 3.290034] [<ffffffff9507e505>] scsi_scan_channel+0x105/0x160 [ 3.290362] [<ffffffff9507e8a2>] scsi_scan_host_selected+0x212/0x2f0 [ 3.290724] [<ffffffff9507eb3c>] do_scsi_scan_host+0x1bc/0x250 [ 3.291055] [<ffffffff9507efc1>] do_scan_async+0x41/0x450 [ 3.291354] [<ffffffff941c1fee>] async_run_entry_fn+0xfe/0x610 [ 3.291695] [<ffffffff941a9a84>] process_one_work+0x544/0x12d0 [ 3.292022] [<ffffffff941aa8e9>] worker_thread+0xd9/0x12f0 [ 3.292325] [<ffffffff941bb365>] kthread+0x1c5/0x260 [ 3.292594] [<ffffffff956dde9f>] ret_from_fork+0x1f/0x40 [ 3.292886] Freed: [ 3.292945] PID = 27 [ 3.293016] [<ffffffff940b27ab>] save_stack_trace+0x2b/0x50 [ 3.293327] [<ffffffff9459f246>] save_stack+0x46/0xd0 [ 3.293600] [<ffffffff9459fa61>] kasan_slab_free+0x71/0xb0 [ 3.293916] [<ffffffff9459bac2>] kfree+0xa2/0x1f0 [ 3.294168] [<ffffffff9508158a>] scsi_device_dev_release_usercontext+0x50a/0x730 [ 3.294598] [<ffffffff941ace9a>] execute_in_process_context+0xda/0x130 [ 3.294974] [<ffffffff9508107c>] scsi_device_dev_release+0x1c/0x20 [ 3.295322] [<ffffffff94f566f6>] device_release+0x76/0x1e0 [ 3.295626] [<ffffffff94bc2db7>] kobject_release+0x107/0x370 [ 3.295942] [<ffffffff94bc29ce>] kobject_put+0x4e/0xa0 [ 3.296222] [<ffffffff94f56e17>] put_device+0x17/0x20 [ 3.296497] [<ffffffff9505201c>] scsi_device_put+0x7c/0xa0 [ 3.296801] [<ffffffff9507e1bc>] __scsi_scan_target+0xd4c/0xdf0 [ 3.297132] [<ffffffff9507e505>] scsi_scan_channel+0x105/0x160 [ 3.297458] [<ffffffff9507e8a2>] scsi_scan_host_selected+0x212/0x2f0 [ 3.297829] [<ffffffff9507eb3c>] do_scsi_scan_host+0x1bc/0x250 [ 3.298156] [<ffffffff9507efc1>] do_scan_async+0x41/0x450 [ 3.298453] [<ffffffff941c1fee>] async_run_entry_fn+0xfe/0x610 [ 3.298777] [<ffffffff941a9a84>] process_one_work+0x544/0x12d0 [ 3.299105] [<ffffffff941aa8e9>] worker_thread+0xd9/0x12f0 [ 3.299408] [<ffffffff941bb365>] kthread+0x1c5/0x260 [ 3.299676] [<ffffffff956dde9f>] ret_from_fork+0x1f/0x40 [ 3.299967] Memory state around the buggy address: [ 3.300209] ffff880254d8c200: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb [ 3.300608] ffff880254d8c280: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb [ 3.300986] >ffff880254d8c300: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb [ 3.301408] ^ [ 3.301550] ffff880254d8c380: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc [ 3.301987] ffff880254d8c400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 [ 3.302396] ================================================================== Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28Input: elantech - add Fujitsu Lifebook E556 to force crc_enabledDmitry Torokhov
commit 62837b3c1a95535d1a287c9c8c6563bbd8d37033 upstream. Another Lifebook machine that needs the same quirk as other similar models to make the driver working. Also let's reorder elantech_dmi_force_crc_enabled list so LIfebook enries are in alphabetical order. Reported-by: William Linna <william.linna@gmail.com> Tested-by: William Linna <william.linna@gmail.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28Input: elantech - force needed quirks on Fujitsu H760Matti Kurkela
commit f9a703a54d16ba2470391c4b12236ee56591d50c upstream. Just like Fujitsu CELSIUS H730, the H760 also has an Elantech touchpad with the same quirks. Without this patch, the touchpad is useless out-of-the-box as the mouse pointer won't move. This patch makes the driver aware of both the crc_enabled=1 requirement and the middle button, making the touchpad fully functional out-of-the-box. Signed-off-by: Matti Kurkela <Matti.Kurkela@iki.fi> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28Input: i8042 - skip selftest on ASUS laptopsMarcos Paulo de Souza
commit 930e19248e9b61da36c967687ca79c4d5f977919 upstream. On suspend/resume cycle, selftest is executed to reset i8042 controller. But when this is done in Asus devices, subsequent calls to detect/init functions to elantech driver fails. Skipping selftest fixes this problem. An easier step to reproduce this problem is adding i8042.reset=1 as a kernel parameter. On Asus laptops, it'll make the system to start with the touchpad already stuck, since psmouse_probe forcibly calls the selftest function. This patch was inspired by John Hiesey's change[1], but, since this problem affects a lot of models of Asus, let's avoid running selftests on them. All models affected by this problem: A455LD K401LB K501LB K501LX R409L V502LX X302LA X450LCP X450LD X455LAB X455LDB X455LF Z450LA [1]: https://marc.info/?l=linux-input&m=144312209020616&w=2 Fixes: "ETPS/2 Elantech Touchpad dies after resume from suspend" (https://bugzilla.kernel.org/show_bug.cgi?id=107971) Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28cx231xx: fix GPIOs for Pixelview SBTVD hybridMauro Carvalho Chehab
commit 24b923f073ac37eb744f56a2c7f77107b8219ab2 upstream. This device uses GPIOs: 28 to switch between analog and digital modes: on digital mode, it should be set to 1. The code that sets it on analog mode is OK, but it misses the logic that sets it on digital mode. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
