path: root/drivers
2013-10-10IB/mlx5: Fix send work queue size calculationEli Cohen
1. Make sure wqe_cnt does not exceed the limit published by firmware. 2. There is no requirement that the number of outstanding work requests will be a power of two. Remove the ilog2 in the calculation of sq.max_post to fix that. 3. Add case for IB_QPT_XRC_TGT in sq_overhead and return 0 as XRC target QPs do not have a send queue. Signed-off-by: Eli Cohen <eli@mellanox.com> Signed-off-by: Roland Dreier <roland@purestorage.com>
2013-10-10drm/radeon: re-enable sw ACR support on pre-DCE4Alex Deucher
HW ACR support may have issues on some older chips, so use SW ACR for now until we've tested further. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> CC: Rafał Miłecki <zajec5@gmail.com>
2013-10-10tpm: xen-tpmfront: fix missing declaration of xen_domainRob Herring
xen-tpmfront fails to build on arm64 with the following error: drivers/char/tpm/xen-tpmfront.c: In function ‘xen_tpmfront_init’: drivers/char/tpm/xen-tpmfront.c:422:2: error: implicit declaration of function ‘xen_domain’ [-Werror=implicit-function-declaration] Add include of xen/xen.h to fix this. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com> Reviewed-by: Ashley Lai <adlai@linux.vnet.ibm.com> Acked-by: Ashley Lai <adlai@linux.vnet.ibm.com> Cc: Leonidas Da Silva Barbosa <leosilva@linux.vnet.ibm.com> Cc: Rajiv Andrade <mail@srajiv.net> Cc: Marcel Selhorst <tpmdd@selhorst.net> Cc: Sirrix AG <tpmdd@sirrix.com> Cc: tpmdd-devel@lists.sourceforge.net
2013-10-10i2c: i2c-mux-pinctrl: use deferred probe when adapter not foundWolfram Sang
If it is not there yet, it might appear later. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-10-10i2c: i2c-arb-gpio-challenge: use deferred probe when adapter not foundWolfram Sang
2013-10-10i2c: i2c-mux-gpio: use deferred probingIonut Nicu
If the i2c-parent bus driver is not loaded, returning -ENODEV will force people to unload and then reload the module again to get it working. Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com> Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-10-10i2c: i2c-mux-gpio: don't ignore of_get_named_gpio errorsIonut Nicu
of_get_named_gpio could return -E_PROBE_DEFER or another error code. This error should be passed further instead of being ignored. Signed-off-by: Ionut Nicu <ioan.nicu.ext@nsn.com> Acked-by: Peter Korsgaard <peter.korsgaard@barco.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-10-10i2c: omap: Clear ARDY bit twiceTaras Kondratiuk
Initially commit cb527ede1bf6ff2008a025606f25344b8ed7b4ac "i2c-omap: Double clear of ARDY status in IRQ handler" added a workaround for undocumented errata ProDB0017052. But then commit 1d7afc95946487945cc7f5019b41255b72224b70 "i2c: omap: ack IRQ in parts" refactored code and missed one of ARDY clearings. So current code violates errata. It causes often i2c bus timeouts on my Pandaboard. This patch adds a second clearing in place. Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Taras Kondratiuk <taras.kondratiuk@linaro.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Cc: stable@kernel.org
2013-10-10i2c: Not all adapters have a parentJean Delvare
The code in acpi_i2c_register_devices() assumes that all i2c adapters have a parent. This is not necessarily the case, for example the i2c-stub driver instantiate a virtual i2c adapter without a parent. Check for this to avoid a NULL pointer deference. Signed-off-by: Jean Delvare <jdelvare@suse.de> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-10-10i2c: i2c-stu300: replace platform_driver_probe to support deferred probingWolfram Sang
Subsystems like pinctrl and gpio rightfully make use of deferred probing at core level. Now, deferred drivers won't be retried if they don't have a .probe function specified in the driver struct. Fix this driver to have that, so the devices it supports won't get lost in a deferred probe. Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-10-10i2c: i2c-mxs: replace platform_driver_probe to support deferred probingWolfram Sang
Subsystems like pinctrl and gpio rightfully make use of deferred probing at core level. Now, deferred drivers won't be retried if they don't have a .probe function specified in the driver struct. Fix this driver to have that, so the devices it supports won't get lost in a deferred probe. Acked-by: Marek Vasut <marex@denx.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-10-10i2c: i2c-imx: replace platform_driver_probe to support deferred probingWolfram Sang
Subsystems like pinctrl and gpio rightfully make use of deferred probing at core level. Now, deferred drivers won't be retried if they don't have a .probe function specified in the driver struct. Fix this driver to have that, so the devices it supports won't get lost in a deferred probe. Acked-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-10-10i2c: i2c-designware-platdrv: replace platform_driver_probe to support ↵Wolfram Sang
deferred probing Subsystems like pinctrl and gpio rightfully make use of deferred probing at core level. Now, deferred drivers won't be retried if they don't have a .probe function specified in the driver struct. Fix this driver to have that, so the devices it supports won't get lost in a deferred probe. Reported-by: Zhangfei Gao <zhangfei.gao@linaro.org> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-10-09drm/radeon/dpm: disable bapm on TN asicsAlex Deucher
Causes hangs on certain boards. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=70053 Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-10-09drm/radeon: improve soft reset on CIKAlex Deucher
Disable CG/PG before resetting. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-10-09drm/radeon: improve soft reset on SIAlex Deucher
Disable CG/PG and stop the rlc before resetting. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-10-09drm/radeon/dpm: off by one in si_set_mc_special_registers()Dan Carpenter
These checks should be ">=" instead of ">". j is used as an offset into the table->mc_reg_address[] array and that has SMC_SISLANDS_MC_REGISTER_ARRAY_SIZE (16) elements. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-10-09drm/radeon/dpm/btc: off by one in btc_set_mc_special_registers()Dan Carpenter
It should be ">=" instead of ">" here. The table->mc_reg_address[] array has SMC_EVERGREEN_MC_REGISTER_ARRAY_SIZE (16) elements. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-10-09drm/radeon: forever loop on error in radeon_do_test_moves()Dan Carpenter
The error path does this: for (--i; i >= 0; --i) { which is a forever loop because "i" is unsigned. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-10-09drm/radeon: fix hw contexts for SUMO2 asicswojciech kapuscinski
They have 4 rather than 8. Fixes: https://bugs.freedesktop.org/show_bug.cgi?id=63599 Signed-off-by: wojciech kapuscinski <wojtask9@wp.pl> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-10-09drm/radeon: fix typo in CP DMA register headersAlex Deucher
Wrong bit offset for SRC endian swapping. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2013-10-09drm/radeon/dpm: disable multiple UVD statesAlex Deucher
Always use the regular UVD state for now. This fixes a performance regression with UVD playback on certain APUs. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-10-09drm/radeon: use hw generated CTS/N values for audioAlex Deucher
Use the hw generated values rather than calculating them in the driver. There may be some older r6xx asics where this doesn't work correctly. This remains to be seen. See bug: https://bugs.freedesktop.org/show_bug.cgi?id=69675 Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-10-09drm/radeon: fix N/CTS clock matching for audioAlex Deucher
The drm code that calculates the 1001 clocks rounds up rather than truncating. This allows the table to match properly on those modes. See bug: https://bugs.freedesktop.org/show_bug.cgi?id=69675 Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-10-09drm/radeon: use 64-bit math to calculate CTS values for audio (v2)Alex Deucher
Avoid losing precision. See bug: https://bugs.freedesktop.org/show_bug.cgi?id=69675 v2: fix math as per Anssi's comments. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2013-10-09drm/edid: catch kmalloc failure in drm_edid_to_speaker_allocationAlex Deucher
Return -ENOMEM if the allocation fails. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Jani Nikula <jani.nikula@intel.com>
2013-10-10Revert "drm/fb-helper: don't sleep for screen unblank when an oops is in ↵Dave Airlie
progress" This reverts commit 928c2f0c006bf7f381f58af2b2786d2a858ae311. This patch double applied, two checks for the price of one. Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-10-09hwmon: (applesmc) Always read until end of dataHenrik Rydberg
The crash reported and investigated in commit 5f4513 turned out to be caused by a change to the read interface on newer (2012) SMCs. Tests by Chris show that simply reading the data valid line is enough for the problem to go away. Additional tests show that the newer SMCs no longer wait for the number of requested bytes, but start sending data right away. Apparently the number of bytes to read is no longer specified as before, but instead found out by reading until end of data. Failure to read until end of data confuses the state machine, which eventually causes the crash. As a remedy, assuming bit0 is the read valid line, make sure there is nothing more to read before leaving the read function. Tested to resolve the original problem, and runtested on MBA3,1, MBP4,1, MBP8,2, MBP10,1, MBP10,2. The patch seems to have no effect on machines before 2012. Tested-by: Chris Murphy <chris@cmurf.com> Cc: stable@vger.kernel.org Signed-off-by: Henrik Rydberg <rydberg@euromail.se> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-10-09Merge remote-tracking branch 'nouveau/drm-nouveau-next' into drm-fixesDave Airlie
Disable MSIs for now until we can fix them up * nouveau/drm-nouveau-next: drm/nouveau/mc: disable msi support by default, it's busted in tons of places
2013-10-09drm/gma500: fix things after get/put page helpersRob Clark
Commit 8b9ba7a3 'drm/gma500: use gem get/put page helpers' was missing a line, which resulted in garbled screen. Signed-off-by: Rob Clark <robdclark@gmail.com> Tested-by: Guillaume CLÉMENT <gclement@baobob.org> Signed-off-by: Dave Airlie <airlied@redhat.com>
2013-10-08drm/nouveau/mc: disable msi support by default, it's busted in tons of placesBen Skeggs
Signed-off-by: Ben Skeggs <bskeggs@redhat.com>
2013-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID fixes from Jiri Kosina: - fix for hidraw reference counting regression, by Manoj Chourasia - fix for minor number allocation for uhid, by David Herrmann - other small unsorted fixes / device ID additions * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: wiimote: fix FF deadlock HID: add Holtek USB ID 04d9:a081 SHARKOON DarkGlider HID: hidraw: close underlying device at removal of last reader HID: roccat: Fix "cannot create duplicate filename" problems HID: uhid: allocate static minor
2013-10-07HID: wiimote: fix FF deadlockDavid Herrmann
The input core has an internal spinlock that is acquired during event injection via input_event() and friends but also held during FF callbacks. That means, there is no way to share a lock between event-injection and FF handling. Unfortunately, this is what is required for wiimote state tracking and what we do with state.lock and input->lock. This deadlock can be triggered when using continuous data reporting and FF on a wiimote device at the same time. I takes me at least 30m of stress-testing to trigger it but users reported considerably shorter times (http://bpaste.net/show/132504/) when using some gaming-console emulators. The real problem is that we have two copies of internal state, one in the wiimote objects and the other in the input device. As the input-lock is not supposed to be accessed from outside of input-core, we have no other chance than offloading FF handling into a worker. This actually works pretty nice and also allows to implictly merge fast rumble changes into a single request. Due to the 3-layered workers (rumble+queue+l2cap) this might reduce FF responsiveness. Initial tests were fine so lets fix the race first and if it turns out to be too slow we can always handle FF out-of-band and skip the queue-worker. Cc: <stable@vger.kernel.org> # 3.11+ Reported-by: Thomas Schneider Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-10-07Merge remote-tracking branch 'spi/fix/s3c64xx' into spi-linusMark Brown
2013-10-07Merge remote-tracking branch 'spi/fix/pxa' into spi-linusMark Brown
2013-10-07Merge remote-tracking branch 'spi/fix/mpc512x' into spi-linusMark Brown
2013-10-07Merge remote-tracking branch 'spi/fix/hspi' into spi-linusMark Brown
2013-10-07Merge remote-tracking branch 'spi/fix/dspi' into spi-linusMark Brown
2013-10-07Merge remote-tracking branch 'spi/fix/clps711x' into spi-linusMark Brown
2013-10-07spi: atmel: Fix incorrect error pathSachin Kamat
'irq' was not released when clk_prepare_enable failed. Fix it. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Mark Brown <broonie@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Martin Schwidefsky: "A couple of bux fixes, notable are the regression with ptrace vs restarting system calls and the patch for kdump to be able to copy from virtual memory" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390: fix system call restart after inferior call s390: Allow vmalloc target buffers for copy_from_oldmem() s390/sclp: properly detect line mode console s390/kprobes: add exrl to list of prohibited opcodes s390/3270: fix return value check in tty3270_resize_work()
2013-10-07Merge tag 'drm-intel-fixes-2013-10-07' of ↵Dave Airlie
git://people.freedesktop.org/~danvet/drm-intel into drm-fixes Daniel writes: Just a few important fixes, all cc: stable (I've checked this time around and made sure they're really there ...). The dpms one is a regression from the modeset rework and has a good chance to rectify Linus' hdmi issues. * tag 'drm-intel-fixes-2013-10-07' of git://people.freedesktop.org/~danvet/drm-intel: drm/i915: Only apply DPMS to the encoder if enabled drm/i915: Mask LPSP to get PSR working even with Power Well in use by audio. drm/i915/hsw: Disable L3 caching of atomic memory operations. drm/i915: fix rps.vlv_work initialization
2013-10-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pendingLinus Torvalds
Pull SCSI target fixes from Nicholas Bellinger: "Here are the outstanding target fixes queued up for v3.12-rc4 code. The highlights include: - Make vhost/scsi tag percpu_ida_alloc() use GFP_ATOMIC - Allow sess_cmd_map allocation failure fallback to use vzalloc - Fix COMPARE_AND_WRITE se_cmd->data_length bug with FILEIO backends - Fixes for COMPARE_AND_WRITE callback recursive failure OOPs + non zero scsi_status bug - Make iscsi-target do acknowledgement tag release from RX context - Setup iscsi-target with extra (cmdsn_depth / 2) percpu_ida tags Also included is a iscsi-target patch CC'ed for v3.10+ that avoids legacy wait_for_task=true release during fast-past StatSN acknowledgement, and two other SRP target related patches that address long-standing issues that are CC'ed for v3.3+. Extra thanks to Thomas Glanzmann for his testing feedback with COMPARE_AND_WRITE + EXTENDED_COPY VAAI logic" * git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: iscsi-target; Allow an extra tag_num / 2 number of percpu_ida tags iscsi-target: Perform release of acknowledged tags from RX context iscsi-target: Only perform wait_for_tasks when performing shutdown target: Fail on non zero scsi_status in compare_and_write_callback target: Fix recursive COMPARE_AND_WRITE callback failure target: Reset data_length for COMPARE_AND_WRITE to NoLB * block_size ib_srpt: always set response for task management target: Fall back to vzalloc upon ->sess_cmd_map kzalloc failure vhost/scsi: Use GFP_ATOMIC with percpu_ida_alloc for obtaining tag ib_srpt: Destroy cm_id before destroying QP. target: Fix xop->dbl assignment in target_xcopy_parse_segdesc_02
2013-10-06Merge branch 'fixes' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull slave-dmaengine fixes from Vinod Koul: "Here is the slave dmanegine fixes. We have the fix for deadlock issue on imx-dma by Michael and Josh's edma config fix along with author change" * 'fixes' of git://git.infradead.org/users/vkoul/slave-dma: dmaengine: imx-dma: fix callback path in tasklet dmaengine: imx-dma: fix lockdep issue between irqhandler and tasklet dmaengine: imx-dma: fix slow path issue in prep_dma_cyclic dma/Kconfig: Make TI_EDMA select TI_PRIV_EDMA edma: Update author email address
2013-10-05Merge tag 'gpio-v3.12-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO fixes from Linus Walleij: "Two patches for the OMAP driver, dealing with setting up IRQs properly on the device tree boot path" * tag 'gpio-v3.12-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpio/omap: auto-setup a GPIO when used as an IRQ gpio/omap: maintain GPIO and IRQ usage separately
2013-10-05Merge tag 'usb-3.12-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB fixes from Greg KH: "Here are none fixes for various USB driver problems. The majority are gadget/musb fixes, but there are some new device ids in here as well" * tag 'usb-3.12-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: usb: chipidea: add Intel Clovertrail pci id usb: gadget: s3c-hsotg: fix can_write limit for non-periodic endpoints usb: gadget: f_fs: fix error handling usb: musb: dsps: do not bind to "musb-hdrc" USB: serial: option: Ignore card reader interface on Huawei E1750 usb: musb: gadget: fix otg active status flag usb: phy: gpio-vbus: fix deferred probe from __init usb: gadget: pxa25x_udc: fix deferred probe from __init usb: musb: fix otg default state
2013-10-05Merge tag 'tty-3.12-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty fixes from Greg KH: "Here are two tty driver fixes for 3.12-rc4. One fixes the reported regression in the n_tty code that a number of people found recently, and the other one fixes an issue with xen consoles that broke in 3.10" * tag 'tty-3.12-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: xen/hvc: allow xenboot console to be used again tty: Fix pty master read() after slave closes
2013-10-05Merge tag 'staging-3.12-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging fixes from Greg KH: "Here are 4 tiny staging and iio driver fixes for 3.12-rc4. Nothing major, just some small fixes for reported issues" * tag 'staging-3.12-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: comedi: ni_65xx: (bug fix) confine insn_bits to one subdevice iio:magnetometer: Bugfix magnetometer default output registers iio: Remove debugfs entries in iio_device_unregister() iio: amplifiers: ad8366: Remove regulator_put
2013-10-04Merge tag 'pm+acpi-3.12-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management fixes from Rafael Wysocki: - The resume part of user space driven hibernation (s2disk) is now broken after the change that moved the creation of memory bitmaps to after the freezing of tasks, because I forgot that the resume utility loaded the image before freezing tasks and needed the bitmaps for that. The fix adds special handling for that case. - One of recent commits changed the export of acpi_bus_get_device() to EXPORT_SYMBOL_GPL(), which was technically correct but broke existing binary modules using that function including one in particularly widespread use. Change it back to EXPORT_SYMBOL(). - The intel_pstate driver sometimes fails to disable turbo if its no_turbo sysfs attribute is set. Fix from Srinivas Pandruvada. - One of recent cpufreq fixes forgot to update a check in cpufreq-cpu0 which still (incorrectly) treats non-NULL as non-error. Fix from Philipp Zabel. - The SPEAr cpufreq driver uses a wrong variable type in one place preventing it from catching errors returned by one of the functions called by it. Fix from Sachin Kamat. * tag 'pm+acpi-3.12-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: ACPI: Use EXPORT_SYMBOL() for acpi_bus_get_device() intel_pstate: fix no_turbo cpufreq: cpufreq-cpu0: NULL is a valid regulator, part 2 cpufreq: SPEAr: Fix incorrect variable type PM / hibernate: Fix user space driven resume regression
2013-10-04x86, build, pci: Fix PCI_MSI build on !SMPThomas Petazzoni
Commit ebd97be635 ('PCI: remove ARCH_SUPPORTS_MSI kconfig option') removed the ARCH_SUPPORTS_MSI option which architectures could select to indicate that they support MSI. Now, all architectures are supposed to build fine when MSI support is enabled: instead of having the architecture tell *when* MSI support can be used, it's up to the architecture code to ensure that MSI support can be enabled. On x86, commit ebd97be635 removed the following line: select ARCH_SUPPORTS_MSI if (X86_LOCAL_APIC && X86_IO_APIC) Which meant that MSI support was only available when the local APIC and I/O APIC were enabled. While this is always true on SMP or x86-64, it is not necessarily the case on i386 !SMP. The below patch makes sure that the local APIC and I/O APIC support is always enabled when MSI support is enabled. To do so, it: * Ensures the X86_UP_APIC option is not visible when PCI_MSI is enabled. This is the option that allows, on UP machines, to enable or not the APIC support. It is already not visible on SMP systems, or x86-64 systems, for example. We're simply also making it invisible on i386 MSI systems. * Ensures that the X86_LOCAL_APIC and X86_IO_APIC options are 'y' when PCI_MSI is enabled. Notice that this change requires a change in drivers/iommu/Kconfig to avoid a recursive Kconfig dependencey. The AMD_IOMMU option selects PCI_MSI, but was depending on X86_IO_APIC. This dependency is no longer needed: as soon as PCI_MSI is selected, the presence of X86_IO_APIC is guaranteed. Moreover, the AMD_IOMMU already depended on X86_64, which already guaranteed that X86_IO_APIC was enabled, so this dependency was anyway redundant. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Link: http://lkml.kernel.org/r/1380794354-9079-1-git-send-email-thomas.petazzoni@free-electrons.com Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
