commit 89935315f192abf7068d0044cefc84f162c3c81f upstream.
Before commit b355cee88e3b (ACPI / resources: ignore invalid ACPI
device resources), if acpi_dev_resource_memory()/acpi_dev_resource_io()
returns false, it means the the resource is not a memeory/IO resource.
But after commit b355cee88e3b, those functions return false if the
given memory/IO resource entry is invalid (the length of the resource
is zero).
This breaks pnpacpi_allocated_resource(), because it now recognizes
the invalid memory/io resources as resources of unknown type. Thus
users see confusing warning messages on machines with zero length
ACPI memory/IO resources.
Fix the problem by rearranging pnpacpi_allocated_resource() so that
it calls acpi_dev_resource_memory() for memory type and IO type
resources only, respectively.
Fixes: b355cee88e3b (ACPI / resources: ignore invalid ACPI device resources)
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Reported-and-tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Reported-and-tested-by: Julian Wollrath <jwollrath@web.de>
Reported-and-tested-by: Paul Bolle <pebolle@tiscali.nl>
[rjw: Changelog]
commit b12bb60d6c350b348a4e1460cd68f97ccae9822e upstream.
If the initialization of storvsc fails, the storvsc_device_destroy()
causes NULL pointer dereference.
storvsc_bus_scan()
scsi_scan_target()
__scsi_scan_target()
scsi_probe_and_add_lun(hostdata=NULL)
scsi_alloc_sdev(hostdata=NULL)
sdev->hostdata = hostdata
now the host allocation fails
__scsi_remove_device(sdev)
calls sdev->host->hostt->slave_destroy() ==
storvsc_device_destroy(sdev)
access of sdev->hostdata->request_mempool
Signed-off-by: Ales Novak <alnovak@suse.cz>
Signed-off-by: Thomas Abraham <tabraham@suse.com>
Reviewed-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: K. Y. Srinivasan <kys@microsoft.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
commit f324777ea88bab2522602671e46fc0851d7d5e35 upstream.
This fixes requesting of the MSI-X vectors for the base response queue.
The iteration in the for loop in qla24xx_enable_msix() was incorrect.
We should only iterate of the first two MSI-X vectors and not the total
number of MSI-X vectors that have given to the driver for this device
from pci_enable_msix() in this function.
Signed-off-by: Chad Dupuis <chad.dupuis@qlogic.com>
Signed-off-by: Saurav Kashyap <saurav.kashyap@qlogic.com>
commit b77ed25c9f8402e8b3e49e220edb4ef09ecfbb53 upstream.
Signed-off-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
commit c59053a23d586675c25d789a7494adfdc02fba57 upstream.
In the first place, the loop 'for' in the macro 'for_each_isci_host'
(drivers/scsi/isci/host.h:314) is incorrect, because it accesses
the 3rd element of 2 element array. After the 2nd iteration it executes
the instruction:
ihost = to_pci_info(pdev)->hosts[2]
(while the size of the 'hosts' array equals 2) and reads an
out of range element.
In the second place, this loop is incorrectly optimized by GCC v4.8
(see http://marc.info/?l=linux-kernel&m=138998871911336&w=2).
As a result, on platforms with two SCU controllers,
the loop is executed more times than it can be (for i=0,1 and 2).
It causes kernel panic during entering the S3 state
and the following oops after 'rmmod isci':
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff8131360b>] __list_add+0x1b/0xc0
Oops: 0000 [#1] SMP
RIP: 0010:[<ffffffff8131360b>] [<ffffffff8131360b>] __list_add+0x1b/0xc0
Call Trace:
[<ffffffff81661b84>] __mutex_lock_slowpath+0x114/0x1b0
[<ffffffff81661c3f>] mutex_lock+0x1f/0x30
[<ffffffffa03e97cb>] sas_disable_events+0x1b/0x50 [libsas]
[<ffffffffa03e9818>] sas_unregister_ha+0x18/0x60 [libsas]
[<ffffffffa040316e>] isci_unregister+0x1e/0x40 [isci]
[<ffffffffa0403efd>] isci_pci_remove+0x5d/0x100 [isci]
[<ffffffff813391cb>] pci_device_remove+0x3b/0xb0
[<ffffffff813fbf7f>] __device_release_driver+0x7f/0xf0
[<ffffffff813fc8f8>] driver_detach+0xa8/0xb0
[<ffffffff813fbb8b>] bus_remove_driver+0x9b/0x120
[<ffffffff813fcf2c>] driver_unregister+0x2c/0x50
[<ffffffff813381f3>] pci_unregister_driver+0x23/0x80
[<ffffffffa04152f8>] isci_exit+0x10/0x1e [isci]
[<ffffffff810d199b>] SyS_delete_module+0x16b/0x2d0
[<ffffffff81012a21>] ? do_notify_resume+0x61/0xa0
[<ffffffff8166ce29>] system_call_fastpath+0x16/0x1b
The loop has been corrected.
This patch fixes kernel panic during entering the S3 state
and the above oops.
Signed-off-by: Lukasz Dorau <lukasz.dorau@intel.com>
Reviewed-by: Maciej Patelczyk <maciej.patelczyk@intel.com>
Tested-by: Lukasz Dorau <lukasz.dorau@intel.com>
commit ddfadd7736b677de2d4ca2cd5b4b655368c85a7a upstream.
Remove an erroneous BUG_ON() in the case of a hard reset timeout. The
reset timeout handler puts the port into the "awaiting link-up" state.
The timeout causes the device to be disconnected and we need to be in
the awaiting link-up state to re-connect the port. The BUG_ON() made
the incorrect assumption that resets never timeout and we always
complete the reset in the "resetting" state.
Testing this patch also uncovered that libata continues to attempt to
reset the port long after the driver has torn down the context. Once
the driver has committed to abandoning the link it must indicate to
libata that recovery ends by returning -ENODEV from
->lldd_I_T_nexus_reset().
Acked-by: Lukasz Dorau <lukasz.dorau@intel.com>
Reported-by: David Milburn <dmilburn@redhat.com>
Reported-by: Xun Ni <xun.ni@intel.com>
Tested-by: Xun Ni <xun.ni@intel.com>
commit d96e43e8fce28cf97df576a07af9d65657a41a6f upstream.
This patch adds the missing netif_napi_del() to the flexcan_remove() function.
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit f003698e23f6f56a791774f14d0ac35d04872490 upstream.
This patch moves the transceiver enable and disable into seperate functions,
where the NULL pointer check is hidden.
commit 9b00b300e7bce032c467c36ca47fe2a776887fc2 upstream.
In flexcan_chip_enable() and flexcan_chip_disable() fixed delays are used.
Experiments have shown that the transition from and to low power mode may take
several microseconds.
This patch adds a while loop which polls the Low Power Mode ACK bit (LPM_ACK)
that indicates a successfull mode change. If the function runs into a timeout a
error value is returned.
commit 7e9e148af01ef388efb6e2490805970be4622792 upstream.
If flexcan_chip_start() in flexcan_open() fails, the interrupt is not freed,
this patch adds the missing cleanup.
commit 5be93bdda64e85450598c6e97f79fb8f6acf30e0 upstream.
When shutting down the CAN interface (ifconfig canX down) during high CAN bus
loads, the CAN core might hang and freeze the whole CPU.
This patch fixes the shutdown sequence by first disabling the CAN core then
disabling all interrupts.
commit e893fba90c09f9b57fb97daae204ea9cc2c52fa5 upstream.
In order to avoid wasting cache space a partial block at the end of the
origin device is not cached. Unfortunately, the check for such a
partial block at the end of the origin device was flawed.
Fix accesses beyond the end of the origin device that occured due to
attempted promotion of an undetected partial block by:
- initializing the per bio data struct to allow cache_end_io to work properly
- recognizing access to the partial block at the end of the origin device
- avoiding out of bounds access to the discard bitset
Otherwise, users can experience errors like the following:
attempt to access beyond end of device
dm-5: rw=0, want=20971520, limit=20971456
device-mapper: cache: promotion failed; couldn't copy block
Signed-off-by: Heinz Mauelshagen <heinzm@redhat.com>
Acked-by: Joe Thornber <ejt@redhat.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
commit 8b9d96666529a979acf4825391efcc7c8a3e9f12 upstream.
During demotion or promotion to a cache's >2TB fast device we must not
truncate the cache block's associated sector to 32bits. The 32bit
temporary result of from_cblock() caused a 32bit multiplication when
calculating the sector of the fast device in issue_copy_real().
Use an intermediate 64bit type to store the 32bit from_cblock() to allow
for proper 64bit multiplication.
Here is an example of how this bug manifests on an ext4 filesystem:
EXT4-fs error (device dm-0): ext4_mb_generate_buddy:756: group 17136, 32768 clusters in bitmap, 30688 in gd; block bitmap corrupt.
JBD2: Spotted dirty metadata buffer (dev = dm-0, blocknr = 0). There's a risk of filesystem corruption in case of system crash.
commit cebc2de44d3bce53e46476e774126c298ca2c8a9 upstream.
This has been a relatively long-standing issue that wasn't nailed down
until Teng-Feng Yang's meticulous bug report to dm-devel on 3/7/2014,
see: http://www.redhat.com/archives/dm-devel/2014-March/msg00021.html
From that report:
"When decreasing the reference count of a metadata block with its
reference count equals 3, we will call dm_btree_remove() to remove
this enrty from the B+tree which keeps the reference count info in
metadata device.
The B+tree will try to rebalance the entry of the child nodes in each
node it traversed, and the rebalance process contains the following
steps.
(1) Finding the corresponding children in current node (shadow_current(s))
(2) Shadow the children block (issue BOP_INC)
(3) redistribute keys among children, and free children if necessary (issue BOP_DEC)
Since the update of a metadata block's reference count could be
recursive, we will stash these reference count update operations in
smm->uncommitted and then process them in a FILO fashion.
The problem is that step(3) could free the children which is created
in step(2), so the BOP_DEC issued in step(3) will be carried out
before the BOP_INC issued in step(2) since these BOPs will be
processed in FILO fashion. Once the BOP_DEC from step(3) tries to
decrease the reference count of newly shadow block, it will report
failure for its reference equals 0 before decreasing. It looks like we
can solve this issue by processing these BOPs in a FIFO fashion
instead of FILO."
Commit 5b564d80 ("dm space map: disallow decrementing a reference count
below zero") changed the code to report an error for this temporary
refcount decrement below zero. So what was previously a harmless
invalid refcount became a hard failure due to the new error path:
device-mapper: space map common: unable to decrement a reference count below 0
device-mapper: thin: 253:6: dm_thin_insert_block() failed: error = -22
device-mapper: thin: 253:6: switching pool to read-only mode
This bug is in dm persistent-data code that is common to the DM thin and
cache targets. So any users of those targets should apply this fix.
Fix this by applying recursive space map operations in FIFO order rather
than FILO.
Resolves: https://bugzilla.kernel.org/show_bug.cgi?id=68801
Reported-by: Apollon Oikonomopoulos <apoikos@debian.org>
Reported-by: edwillam1007@gmail.com
Reported-by: Teng-Feng Yang <shinrairis@gmail.com>
Signed-off-by: Joe Thornber <ejt@redhat.com>
commit 0a8d8c446b5429d15ff2d48f46e00d8a08552303 upstream.
Since commit d25f06ea466e "vmxnet3: fix netpoll race condition",
the vmxnet3 driver fails to build when CONFIG_PCI_MSI is disabled,
because it unconditionally references the vmxnet3_msix_rx()
function.
To fix this, use the same #ifdef in the caller that exists around
the function definition.
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Shreyas Bhatewara <sbhatewara@vmware.com>
Cc: "VMware, Inc." <pv-drivers@vmware.com>
commit d25f06ea466ea521b563b76661180b4e44714ae6 upstream.
vmxnet3's netpoll driver is incorrectly coded. It directly calls
vmxnet3_do_poll, which is the driver internal napi poll routine. As the netpoll
controller method doesn't block real napi polls in any way, there is a potential
for race conditions in which the netpoll controller method and the napi poll
method run concurrently. The result is data corruption causing panics such as this
one recently observed:
PID: 1371 TASK: ffff88023762caa0 CPU: 1 COMMAND: "rs:main Q:Reg"
#0 [ffff88023abd5780] machine_kexec at ffffffff81038f3b
#1 [ffff88023abd57e0] crash_kexec at ffffffff810c5d92
#2 [ffff88023abd58b0] oops_end at ffffffff8152b570
#3 [ffff88023abd58e0] die at ffffffff81010e0b
#4 [ffff88023abd5910] do_trap at ffffffff8152add4
#5 [ffff88023abd5970] do_invalid_op at ffffffff8100cf95
#6 [ffff88023abd5a10] invalid_op at ffffffff8100bf9b
[exception RIP: vmxnet3_rq_rx_complete+1968]
RIP: ffffffffa00f1e80 RSP: ffff88023abd5ac8 RFLAGS: 00010086
RAX: 0000000000000000 RBX: ffff88023b5dcee0 RCX: 00000000000000c0
RDX: 0000000000000000 RSI: 00000000000005f2 RDI: ffff88023b5dcee0
RBP: ffff88023abd5b48 R8: 0000000000000000 R9: ffff88023a3b6048
R10: 0000000000000000 R11: 0000000000000002 R12: ffff8802398d4cd8
R13: ffff88023af35140 R14: ffff88023b60c890 R15: 0000000000000000
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#7 [ffff88023abd5b50] vmxnet3_do_poll at ffffffffa00f204a [vmxnet3]
#8 [ffff88023abd5b80] vmxnet3_netpoll at ffffffffa00f209c [vmxnet3]
#9 [ffff88023abd5ba0] netpoll_poll_dev at ffffffff81472bb7
The fix is to do as other drivers do, and have the poll controller call the top
half interrupt handler, which schedules a napi poll properly to recieve frames
Tested by myself, successfully.
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
CC: Shreyas Bhatewara <sbhatewara@vmware.com>
CC: "VMware, Inc." <pv-drivers@vmware.com>
CC: "David S. Miller" <davem@davemloft.net>
Reviewed-by: Shreyas N Bhatewara <sbhatewara@vmware.com>
commit 3cdeb713dc66057b50682048c151eae07b186c42 upstream.
Andreas reported that after 1f42db786b14 ("PCI: Enable INTx if BIOS left
them disabled"), pciehp surprise removal stopped working.
This happens because pci_reenable_device() on the hotplug bridge (used in
the pciehp_configure_device() path) clears the Interrupt Disable bit, which
apparently breaks the bridge's MSI hotplug event reporting.
Previously we cleared the Interrupt Disable bit in do_pci_enable_device(),
which is used by both pci_enable_device() and pci_reenable_device(). But
we use pci_reenable_device() after the driver may have enabled MSI or
MSI-X, and we *set* Interrupt Disable as part of enabling MSI/MSI-X.
This patch clears Interrupt Disable only when MSI/MSI-X has not been
enabled.
Fixes: 1f42db786b14 PCI: Enable INTx if BIOS left them disabled
Link: https://bugzilla.kernel.org/show_bug.cgi?id=71691
Reported-and-tested-by: Andreas Noever <andreas.noever@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
CC: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 62c19c9d29e65086e5ae76df371ed2e6b23f00cd upstream.
The symbol is an orphan, don't depend on it anymore.
Signed-off-by: Richard Weinberger <richard@nod.at>
[wsa: enhanced commit message]
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Fixes: 687b81d083c0 (i2c: move OF helpers into the core)
commit 5b43c3cd07981619dbdb1fb935ef705a3e80955f upstream.
inverted logic.
Noticed-by: Sylvain BERTRAND <sylware@legeek.net>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
commit 407b6dfd9afa30cf963fa99bca91870e47965612 upstream.
Copy/paste typos from the ni code. Should not
have any functional change.
commit b2b3d8d952e4f8d6ac2ce80be96b937f29f6e42e upstream.
When we disable the rings, set the status properly. If
not other code pathes may try and use the rings which are
not functional at this point.
commit 07ae78c9798b79bad3d3adf983c94ba23fde54d4 upstream.
We always stop the rings when disabling the engines so just
call the stop functions directly from the sdma enable function.
This way the rings' status is set correctly on suspend so
there are no problems on resume. Fixes resume failures that
result in acceleration getting disabled.
commit 7b1bbe883b3ed962ca2be4daf321f318f5091340 upstream.
commit 01ac8794a77192236a4b91c33adf4177ac5a21f0 upstream.
We need to reorder the driver init sequence to better accomodate
dpm which needs to be loaded earlier in the init sequence. Move
fw init up so that it's available for dpm init.
commit 6375b768a9850b6154478993e5fb566fa4614a9c upstream.
Single-link DVI max dotclock is 165MHz. Filter out modes with higher
dotclock when the monitor doesn't support HDMI.
Modes higher than 165 MHz were allowed in
commit 7d148ef51a657fd04036c3ed7803da600dd0d451
Author: Daniel Vetter <daniel.vetter@ffwll.ch>
Date: Mon Jul 22 18:02:39 2013 +0200
drm/i915: fix hdmi portclock limits
Also don't attempt to use 12bpc mode with DVI monitors.
Cc: Adam Nielsen <a.nielsen@shikadi.net>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=75345
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=70331
Tested-by: Ralf Jung <post+kernel@ralfj.de>
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
commit bcdb72ac7c00d2b56359fc82bcc8fe50454717d5 upstream.
pci_get_class(class, from) drops the refcount for 'from', so the
extra pci_dev_put we do on it will result in a use after free bug
starting with the WARN below.
Regression introduced in
commit 6a9c4b35e6696a63805b6da5e4889c6986e9ee1b
Author: Rui Guo <firemeteor@users.sourceforge.net>
Date: Wed Jun 19 21:10:23 2013 +0800
drm/i915: Fix PCH detect with multiple ISA bridges in VM
[ 164.338460] WARNING: CPU: 1 PID: 2094 at include/linux/kref.h:47 klist_next+0xae/0x110()
[ 164.347731] CPU: 1 PID: 2094 Comm: modprobe Tainted: G O 3.13.0-imre+ #354
[ 164.356468] Hardware name: Intel Corp. VALLEYVIEW B0 PLATFORM/NOTEBOOK, BIOS BYTICRB1.X64.0062.R70.1310112051 10/11/2013
[ 164.368796] Call Trace:
[ 164.371609] [<ffffffff816a32a6>] dump_stack+0x4e/0x7a
[ 164.377447] [<ffffffff8104f75d>] warn_slowpath_common+0x7d/0xa0
[ 164.384238] [<ffffffff8104f83a>] warn_slowpath_null+0x1a/0x20
[ 164.390851] [<ffffffff8169aeae>] klist_next+0xae/0x110
[ 164.396777] [<ffffffff8130a110>] ? pci_do_find_bus+0x70/0x70
[ 164.403286] [<ffffffff813cb4a9>] bus_find_device+0x89/0xc0
[ 164.409719] [<ffffffff8130a373>] pci_get_dev_by_id+0x63/0xa0
[ 164.416238] [<ffffffff8130a4e4>] pci_get_class+0x44/0x50
[ 164.422433] [<ffffffffa034821f>] intel_dsm_detect+0x16f/0x1f0 [i915]
[ 164.429801] [<ffffffffa03482ae>] intel_register_dsm_handler+0xe/0x10 [i915]
[ 164.437831] [<ffffffffa02d30fe>] i915_driver_load+0xafe/0xf30 [i915]
[ 164.445126] [<ffffffff8158a150>] ? intel_alloc_coherent+0x110/0x110
[ 164.452340] [<ffffffffa0148c07>] drm_dev_register+0xc7/0x150 [drm]
[ 164.459462] [<ffffffffa014b23f>] drm_get_pci_dev+0x11f/0x1f0 [drm]
[ 164.466554] [<ffffffff816abb81>] ? _raw_spin_unlock_irqrestore+0x51/0x70
[ 164.474287] [<ffffffffa02cf7a6>] i915_pci_probe+0x56/0x60 [i915]
[ 164.481185] [<ffffffff8130a028>] pci_device_probe+0x78/0xf0
[ 164.487603] [<ffffffff813cd495>] driver_probe_device+0x155/0x350
[ 164.494505] [<ffffffff813cd74e>] __driver_attach+0x6e/0xa0
[ 164.500826] [<ffffffff813cd6e0>] ? __device_attach+0x50/0x50
[ 164.507333] [<ffffffff813cb2be>] bus_for_each_dev+0x6e/0xc0
[ 164.513752] [<ffffffff813ccefe>] driver_attach+0x1e/0x20
[ 164.519870] [<ffffffff813cc958>] bus_add_driver+0x138/0x260
[ 164.526289] [<ffffffffa0188000>] ? 0xffffffffa0187fff
[ 164.532116] [<ffffffff813cde78>] driver_register+0x98/0xe0
[ 164.538558] [<ffffffffa0188000>] ? 0xffffffffa0187fff
[ 164.544389] [<ffffffff813087b0>] __pci_register_driver+0x60/0x70
[ 164.551336] [<ffffffffa014b37d>] drm_pci_init+0x6d/0x120 [drm]
[ 164.558040] [<ffffffffa0188000>] ? 0xffffffffa0187fff
[ 164.563928] [<ffffffffa018806a>] i915_init+0x6a/0x6c [i915]
[ 164.570363] [<ffffffff810002da>] do_one_initcall+0xaa/0x160
[ 164.576783] [<ffffffff8103b140>] ? set_memory_nx+0x40/0x50
[ 164.583100] [<ffffffff810ce7f5>] load_module+0x1fb5/0x2550
[ 164.589410] [<ffffffff810caab0>] ? store_uevent+0x40/0x40
[ 164.595628] [<ffffffff810cee7d>] SyS_init_module+0xed/0x100
[ 164.602048] [<ffffffff816b3c52>] system_call_fastpath+0x16/0x1b
v2: simplify the loop further (Chris)
Signed-off-by: Imre Deak <imre.deak@intel.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Reported-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=65652
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=74161
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
commit 13714323f83ffa5a772fe0d8b74e0fa32ee08819 upstream.
Should be at 0x8 rather than 0.
fixes:
https://bugzilla.kernel.org/show_bug.cgi?id=60523
Noticed by ArtForz on #radeon
commit d03874c881a049a50e12f285077ab1f9fc2686e1 upstream.
We need to check for DVI vs. HDMI when setting up duallink since
HDMI is single link only. Fixes 4k modes on newer asics.
bug:
https://bugs.freedesktop.org/show_bug.cgi?id=75223
commit a2a99cea5ec7c1e47825559f0e75a4efbcf8aee3 upstream.
This patch fixes a bug in iscsit_get_tpg_from_np() where the
tpg->tpg_state sanity check was looking for TPG_STATE_FREE,
instead of != TPG_STATE_ACTIVE.
The latter is expected during a normal TPG shutdown once the
tpg_state goes into TPG_STATE_INACTIVE in order to reject any
new incoming login attempts.
commit b6b87a1df604678ed1be40158080db012a99ccca upstream.
This patch fixes the incorrect setting of ->post_send_buf_count
related to RDMA WRITEs + READs where isert_rdma_rw->send_wr_num
was not being taken into account.
This includes incrementing ->post_send_buf_count within
isert_put_datain() + isert_get_dataout(), decrementing within
__isert_send_completion() + isert_response_completion(), and
clearing wr->send_wr_num within isert_completion_rdma_read()
This is necessary because even though IB_SEND_SIGNALED is
not set for RDMA WRITEs + READs, during a QP failure event
the work requests will be returned with exception status
from the TX completion queue.
Acked-by: Sagi Grimberg <sagig@mellanox.com>
Cc: Or Gerlitz <ogerlitz@mellanox.com>
commit 9bb4ca68fc48eea618b1af1c1cde2a251ae32d1b upstream.
This patch changes IB_WR_FAST_REG_MR + IB_WR_LOCAL_INV related
work requests to include a ISER_FRWR_LI_WRID value in order to
signal isert_cq_tx_work() that these requests should be ignored.
This is necessary because even though IB_SEND_SIGNALED is not
set for either work request, during a QP failure event the work
requests will be returned with exception status from the TX
completion queue.
v2 changes:
- Rename ISER_FRWR_LI_WRID -> ISER_FASTREG_LI_WRID (Sagi)
commit defd884845297fd5690594bfe89656b01f16d87e upstream.
This patch addresses a couple of different hug shutdown issues
related to wait_event() + isert_conn->state. First, it changes
isert_conn->conn_wait + isert_conn->conn_wait_comp_err from
waitqueues to completions, and sets ISER_CONN_TERMINATING from
within isert_disconnect_work().
Second, it splits isert_free_conn() into isert_wait_conn() that
is called earlier in iscsit_close_connection() to ensure that
all outstanding commands have completed before continuing.
Finally, it breaks isert_cq_comp_err() into seperate TX / RX
related code, and adds logic in isert_cq_rx_comp_err() to wait
for outstanding commands to complete before setting ISER_CONN_DOWN
and calling complete(&isert_conn->conn_wait_comp_err).
commit 5159d763f60af693a3fcec45dce2021f66e528a4 upstream.
There are a handful of uses of list_empty() for cmd->i_conn_node
within iser-target code that expect to return false once a cmd
has been removed from the per connect list.
This patch changes all uses of list_del -> list_del_init in order
to ensure that list_empty() returns false as expected.
commit a4e90bed511220ff601d064c9e5d583e91308f65 upstream.
If the HW Reduced ACPI mode bit is set in the FADT, ACPICA uses
the optional sleep control and sleep status registers for making
the system enter sleep states (including S5), so it is not possible
to use system sleep states or power it off using ACPI if the HW
Reduced ACPI mode bit is set and those registers are not available.
For this reason, add a new function, acpi_sleep_state_supported(),
checking if the HW Reduced ACPI mode bit is set and whether or not
system sleep states are usable in that case in addition to checking
the return value of acpi_get_sleep_type_data() and make the ACPI
sleep setup routines use that function to check the availability of
system sleep states.
Among other things, this prevents the kernel from attempting to
use ACPI for powering off HW Reduced ACPI systems without the sleep
control and sleep status registers, because ACPI power off doesn't
have a chance to work on them. That allows alternative power off
mechanisms that may actually work to be used on those systems. The
affected machines include Dell Venue 8 Pro, Asus T100TA, Haswell
Desktop SDP and Ivy Bridge EP Demo depot.
References: https://bugzilla.kernel.org/show_bug.cgi?id=70931
Reported-by: Adam Williamson <awilliam@redhat.com>
Tested-by: Aubrey Li <aubrey.li@linux.intel.com>
commit 61d1cf163c8653934cc8cd5d0b2a562d0990c265 upstream.
The 'ath79_spi_setup_cs' function initializes the chip
select line of a given SPI device in order to make sure
that the device is inactive.
If the SPI_CS_HIGH bit is set for a given device, it
means that the CS line of that device is active HIGH
so it must be set to LOW initially. In case of GPIO
CS lines, the 'ath79_spi_setup_cs' function does the
opposite of that due to the wrong GPIO flags.
Fix the code to use the correct GPIO flags.
Reported-by: Ronald Wahl <ronald.wahl@raritan.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Signed-off-by: Mark Brown <broonie@linaro.org>
commit fd40dccb1a170ba689664481a3de83617b7194d2 upstream.
Currently, at module removal, one gets the following warnings:
WARNING: at drivers/clk/clk.c:780 clk_disable+0x18/0x24()
Modules linked in: spi_imx(-) [last unloaded: ev76c560]
CPU: 1 PID: 16337 Comm: rmmod Tainted: G W 3.10.17-80548-g90191eb-dirty #33
[<80013b4c>] (unwind_backtrace+0x0/0xf8) from [<800115dc>] (show_stack+0x10/0x14)
[<800115dc>] (show_stack+0x10/0x14) from [<800257b8>] (warn_slowpath_common+0x4c/0x68)
[<800257b8>] (warn_slowpath_common+0x4c/0x68) from [<800257f0>] (warn_slowpath_null+0x1c/0x24)
[<800257f0>] (warn_slowpath_null+0x1c/0x24) from [<803f60ec>] (clk_disable+0x18/0x24)
[<803f60ec>] (clk_disable+0x18/0x24) from [<7f02c9cc>] (spi_imx_remove+0x54/0x9c [spi_imx])
[<7f02c9cc>] (spi_imx_remove+0x54/0x9c [spi_imx]) from [<8025868c>] (platform_drv_remove+0x18/0x1c)
[<8025868c>] (platform_drv_remove+0x18/0x1c) from [<80256f60>] (__device_release_driver+0x70/0xcc)
[<80256f60>] (__device_release_driver+0x70/0xcc) from [<80257770>] (driver_detach+0xcc/0xd0)
[<80257770>] (driver_detach+0xcc/0xd0) from [<80256d90>] (bus_remove_driver+0x7c/0xc0)
[<80256d90>] (bus_remove_driver+0x7c/0xc0) from [<80068668>] (SyS_delete_module+0x144/0x1f8)
[<80068668>] (SyS_delete_module+0x144/0x1f8) from [<8000e080>] (ret_fast_syscall+0x0/0x30)
---[ end trace 1f5df9ad54996300 ]---
[<803f60ec>] (clk_disable+0x18/0x24) from [<7f02c9e8>] (spi_imx_remove+0x70/0x9c [spi_imx])
[<7f02c9e8>] (spi_imx_remove+0x70/0x9c [spi_imx]) from [<8025868c>] (platform_drv_remove+0x18/0x1c)
---[ end trace 1f5df9ad54996301 ]---
Since commit 9e556dcc55774c9a1032f32baa0e5cfafede8b70, "spi: spi-imx: only
enable the clocks when we start to transfer a message", clocks are always
disabled except when transmitting messages. There is thus no need to
disable them at module removal.
Fixes: 9e556dcc55774 (spi: spi-imx: only enable the clocks when we start to transfer a message)
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Acked-by: Huang Shijie <b32955@freescale.com>
commit 017145fef567430789e40f6a22a90ce2a766370b upstream.
Current code set platform drvdata to dspi. However, the code in dspi_suspend()
and dspi_resume() assumes the drvdata is the address of master.
Fix it by setting platform drvdata to master.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
commit ee73b4c6e3fc0755a91752ab8eebc8e070038b53 upstream.
dev_get_drvdata() returns the address of master rather than mcfqspi.
Fixes: af361079 (spi/coldfire-qspi: Drop extra calls to spi_master_get in suspend/resume functions)
commit 83493d7e782d2630f1a55def14a79f0e7c4faac3 upstream.
We're now blacklisting "Crucial_CT???M500SSD1" and
"Crucial_CT???M500SSD3". Also, "Micron_M500*" is blacklisted which is
about the same devices as the crucial branded ones. Let's merge the
two Crucial M500 entries and widen the match to
"Crucial_CT???M500SSD*" so that we don't have to fiddle with new
entries for similar devices.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
M8 (2BA30001)
commit b28a613e9138e4b3a64649bd60b13436f4b4b49b upstream.
Via commit 87809942d3fa "libata: add ATA_HORKAGE_BROKEN_FPDMA_AA quirk
for Seagate Momentus SpinPoint M8" we added a quirk for disks named
"ST1000LM024 HN-M101MBB" with firmware revision "2AR10001".
As reported on https://bugzilla.redhat.com/show_bug.cgi?id=1073901,
we need to also add firmware revision 2BA30001 as it is broken as well.
Reported-by: Nicholas <arealityfarbetween@googlemail.com>
Signed-off-by: Michele Baldessari <michele@acksyn.org>
Tested-by: Guilherme Amadio <guilherme.amadio@gmail.com>
commit 2564338b13e6e132ee224edb63e1e872adf431f4 upstream.
Queued TRIM commands cause problems and silent file system corruption
on Crucial M500 SSDs. This patch disables them for the mSATA model of
the drive.
Signed-off-by: Marios Andreopoulos <opensource@andmarios.com>
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=71371
commit 70044d71d31d6973665ced5be04ef39ac1c09a48 upstream.
PREPARE_[DELAYED_]WORK() are being phased out. They have few users
and a nasty surprise in terms of reentrancy guarantee as workqueue
considers work items to be different if they don't have the same work
function.
firewire core-device and sbp2 have been been multiplexing work items
with multiple work functions. Introduce fw_device_workfn() and
sbp2_lu_workfn() which invoke fw_device->workfn and
sbp2_logical_unit->workfn respectively and always use the two
functions as the work functions and update the users to set the
->workfn fields instead of overriding work functions using
PREPARE_DELAYED_WORK().
This fixes a variety of possible regressions since a2c1c57be8d9
"workqueue: consider work function when searching for busy work items"
due to which fw_workqueue lost its required non-reentrancy property.
Acked-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Cc: linux1394-devel@lists.sourceforge.net
commit 0ca49345b6f489e95f8d6edeb0b092e257475b2a upstream.
Since commit bd972688eb24
"firewire: ohci: Fix 'failed to read phy reg' on FW643 rev8",
there is a high chance that firewire-ohci fails to initialize LSI née
Agere controllers.
https://bugzilla.kernel.org/show_bug.cgi?id=65151
Peter Hurley points out the reason: IEEE 1394a:2000 clause 5A.1 (or
IEEE 1394:2008 clause 17.2.1) say: "The PHY shall insure that no more
than 10 ms elapse from the reassertion of LPS until the interface is
reset. The link shall not assert LReq until the reset is complete."
In other words, the link needs to give the PHY at least 10 ms to get
the interface operational.
With just the msleep(1) in bd972688eb24, the first read_phy_reg()
during ohci_enable() may happen before the phy-link interface reset was
finished, and fail. Due to the high variability of msleep(n) with small
n, this failure was not fully reproducible, and not apparent at all with
low CONFIG_HZ setting.
On the other hand, Peter can no longer reproduce the issue with FW643
rev8. The read phy reg failures that happened back then may have had an
unrelated cause. So, just revert bd972688eb24, except for the valid
comment on TSB82AA2 cards.
Reported-by: Mikhail Gavrilov
Reported-by: Jay Fenlason <fenlason@redhat.com>
Reported-by: Clemens Ladisch <clemens@ladisch.de>
Reported-by: Peter Hurley <peter@hurleysoftware.com>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
commit 8987583366ae9e03c306c2b7d73bdb952df1d08d upstream.
Commit 8408dc1c14c1 "firewire: net: use dev_printk API" introduced a
use-after-free in a failure path. fwnet_transmit_packet_failed(ptask)
may free ptask, then the dev_err() call dereferenced it. The fix is
straightforward; simply reorder the two calls.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
commit ad332c8a45330d170bb38b95209de449b31cd1b4 upstream.
A number of Samsung notebooks (530Uxx/535Uxx/540Uxx/550Pxx/900Xxx/etc)
continue to log events during sleep (lid open/close, AC plug/unplug,
battery level change), which accumulate in the EC until a buffer fills.
After the buffer is full (tests suggest it holds 8 events), GPEs stop
being triggered for new events. This state persists on wake or even on
power cycle, and prevents new events from being registered until the EC
is manually polled.
This is the root cause of a number of bugs, including AC not being
detected properly, lid close not triggering suspend, and low ambient
light not triggering the keyboard backlight. The bug also seemed to be
responsible for performance issues on at least one user's machine.
Juan Manuel Cabo found the cause of bug and the workaround of polling
the EC manually on wake.
The loop which clears the stale events is based on an earlier patch by
Lan Tianyu (see referenced attachment).
This patch:
- Adds a function acpi_ec_clear() which polls the EC for stale _Q
events at most ACPI_EC_CLEAR_MAX (currently 100) times. A warning is
logged if this limit is reached.
- Adds a flag EC_FLAGS_CLEAR_ON_RESUME which is set to 1 if the DMI
system vendor is Samsung. This check could be replaced by several
more specific DMI vendor/product pairs, but it's likely that the bug
affects more Samsung products than just the five series mentioned
above. Further, it should not be harmful to run acpi_ec_clear() on
systems without the bug; it will return immediately after finding no
data waiting.
- Runs acpi_ec_clear() on initialisation (boot), from acpi_ec_add()
- Runs acpi_ec_clear() on wake, from acpi_ec_unblock_transactions()
References: https://bugzilla.kernel.org/show_bug.cgi?id=44161
References: https://bugzilla.kernel.org/show_bug.cgi?id=45461
References: https://bugzilla.kernel.org/show_bug.cgi?id=57271
References: https://bugzilla.kernel.org/attachment.cgi?id=126801
Suggested-by: Juan Manuel Cabo <juanmanuel.cabo@gmail.com>
Signed-off-by: Kieran Clancy <clancy.kieran@gmail.com>
Reviewed-by: Lan Tianyu <tianyu.lan@intel.com>
Reviewed-by: Dennis Jansen <dennis.jansen@web.de>
Tested-by: Kieran Clancy <clancy.kieran@gmail.com>
Tested-by: Juan Manuel Cabo <juanmanuel.cabo@gmail.com>
Tested-by: Dennis Jansen <dennis.jansen@web.de>
Tested-by: Maurizio D'Addona <mauritiusdadd@gmail.com>
Tested-by: San Zamoyski <san@plusnet.pl>
commit b355cee88e3b1a193f0e9a81db810f6f83ad728b upstream.
ACPI table may export resource entry with 0 length.
But the current code interprets this kind of resource in a wrong way.
It will create a resource structure with
res->end = acpi_resource->start + acpi_resource->len - 1;
This patch fixes a problem on my machine that a platform device fails
to be created because one of its ACPI IO resource entry (start = 0,
end = 0, length = 0) is translated into a generic resource with
start = 0, end = 0xffffffff.
commit e2ed511400d41e0d136089d5a55ceab57c6a2426 upstream.
This reverts commit 247bf557273dd775505fb9240d2d152f4f20d304.
This commit, together with commit 3804fad45411b48233b48003e33a78f290d227c8
"USBNET: ax88179_178a: enable tso if usb host supports sg dma" were
origially added to get xHCI 1.0 hosts and usb ethernet ax88179_178a devices
working together with scatter gather. xHCI 1.0 hosts pose some requirement on how transfer
buffers are aligned, setting this requirement for 1.0 hosts caused USB 3.0 mass
storage devices to fail more frequently.
USB 3.0 mass storage devices used to work before 3.14-rc1. Theoretically,
the TD fragment rules could have caused an occasional disk glitch.
Now the devices *will* fail, instead of theoretically failing.
>From a user perspective, this looks like a regression; the USB device obviously
fails on 3.14-rc1, and may sometimes silently fail on prior kernels.
The proper soluition is to implement the TD fragment rules required, but for now
this patch needs to be reverted to get USB 3.0 mass storage devices working at the
level they used to.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit d86db25e53fa69e3e97f3b55dd82a70689787c5d upstream.
The DELAY_INIT quirk only reduces the frequency of enumeration failures
with the Logitech HD Pro C920 and C930e webcams, but does not quite
eliminate them. We have found that adding a delay of 100ms between the
first and second Get Configuration request makes the device enumerate
perfectly reliable even after several weeks of extensive testing. The
reasons for that are anyone's guess, but since the DELAY_INIT quirk
already delays enumeration by a whole second, wating for another 10th of
that isn't really a big deal for the one other device that uses it, and
it will resolve the problems with these webcams.
Signed-off-by: Julius Werner <jwerner@chromium.org>
commit e0429362ab15c46ea4d64c3f8c9e0933e48a143a upstream.
We've encountered a rare issue when enumerating two Logitech webcams
after a reboot that doesn't power cycle the USB ports. They are spewing
random data (possibly some leftover UVC buffers) on the second
(full-sized) Get Configuration request of the enumeration phase. Since
the data is random this can potentially cause all kinds of odd behavior,
and since it occasionally happens multiple times (after the kernel
issues another reset due to the garbled configuration descriptor), it is
not always recoverable. Set the USB_DELAY_INIT quirk that seems to work
around the issue.
commit 469d417b68958a064c09e7875646c97c6e783dfc upstream.
This reverts commit 3804fad45411b48233b48003e33a78f290d227c8.
This commit, together with commit 247bf557273dd775505fb9240d2d152f4f20d304
"xhci 1.0: Limit arbitrarily-aligned scatter gather." were
The proper soluition is to implement the TD fragment rules for xHCI 1.0 hosts,
but for now, revert this patch until scatter gather can be properly supported.
