path: root/drivers
2014-08-25Merge tag 'renesas-sh-drivers-for-v3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas Pull SH driver fix from Simon Horman: "Confine SH_INTC to platforms that need it" * tag 'renesas-sh-drivers-for-v3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: sh: intc: Confine SH_INTC to platforms that need it
2014-08-24Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "A couple of EFI fixes, plus misc fixes all around the map" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: efi/arm64: Store Runtime Services revision firmware: Do not use WARN_ON(!spin_is_locked()) x86_32, entry: Clean up sysenter_badsys declaration x86/doc: Fix the 'tlb_single_page_flush_ceiling' sysconfig path x86/mm: Fix sparse 'tlb_single_page_flush_ceiling' warning and make the variable read-mostly x86/mm: Fix RCU splat from new TLB tracepoints
2014-08-24Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A collection of fixes from this week, it's been pretty quiet and nothing really stands out as particularly noteworthy here -- mostly minor fixes across the field: - ODROID booting was fixed due to PMIC interrupts missing in DT - a collection of i.MX fixes - minor Tegra fix for regulators - Rockchip fix and addition of SoC-specific mailing list to make it easier to find posted patches" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: bus: arm-ccn: Fix warning message ARM: shmobile: koelsch: Remove non-existent i2c6 pinmux ARM: tegra: apalis/colibri t30: fix on-module 5v0 supplies MAINTAINERS: add new Rockchip SoC list ARM: dts: rockchip: readd missing mmc0 pinctrl settings ARM: dts: ODROID i2c improvements ARM: dts: Enable PMIC interrupts on ODROID ARM: dts: imx6sx: fix the pad setting for uart CTS_B ARM: dts: i.MX53: fix apparent bug in VPU clks ARM: imx: correct gpu2d_axi and gpu3d_axi clock setting ARM: dts: imx6: edmqmx6: change enet reset pin ARM: dts: vf610-twr: Fix pinctrl_esdhc1 pin definitions. ARM: imx: remove unnecessary ARCH_HAS_OPP select ARM: imx: fix TLB missing of IOMUXC base address during suspend ARM: imx6: fix SMP compilation again ARM: dt: sun6i: Add #address-cells and #size-cells to i2c controller nodes
2014-08-24Merge tag 'gpio-v3.17-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull gpio fixes from Linus Walleij: - a largeish fix for the IRQ handling in the new Zynq driver. The quite verbose commit message gives the exact details. - move some defines for gpiod flags outside an ifdef to make stub functions work again. - various minor fixes that we can accept for -rc1. * tag 'gpio-v3.17-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpio-lynxpoint: enable input sensing in resume gpio: move GPIOD flags outside #ifdef gpio: delete unneeded test before of_node_put gpio: zynq: Fix IRQ handlers gpiolib: devres: use correct structure type name in sizeof MAINTAINERS: Change maintainer for gpio-bcm-kona.c
2014-08-24Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "Intel and radeon fixes. Post KS/LC git requests from i915 and radeon stacked up. They are all fixes along with some new pci ids for radeon, and one maintainers file entry. - i915: display fixes and irq fixes - radeon: pci ids, and misc gpuvm, dpm and hdp cache" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: (29 commits) MAINTAINERS: Add entry for Renesas DRM drivers drm/radeon: add additional SI pci ids drm/radeon: add new bonaire pci ids drm/radeon: add new KV pci id Revert "drm/radeon: Use write-combined CPU mappings of ring buffers with PCIe" drm/radeon: fix active_cu mask on SI and CIK after re-init (v3) drm/radeon: fix active cu count for SI and CIK drm/radeon: re-enable selective GPUVM flushing drm/radeon: Sync ME and PFP after CP semaphore waits v4 drm/radeon: fix display handling in radeon_gpu_reset drm/radeon: fix pm handling in radeon_gpu_reset drm/radeon: Only flush HDP cache for indirect buffers from userspace drm/radeon: properly document reloc priority mask drm/i915: don't try to retrain a DP link on an inactive CRTC drm/i915: make sure VDD is turned off during system suspend drm/i915: cancel hotplug and dig_port work during suspend and unload drm/i915: fix HPD IRQ reenable work cancelation drm/i915: take display port power domain in DP HPD handler drm/i915: Don't try to enable cursor from setplane when crtc is disabled drm/i915: Skip load detect when intel_crtc->new_enable==true ...
2014-08-24bus: arm-ccn: Fix warning messagePawel Moll
A message warning a user about wrong vc value was printing out port instead. Reported-by: Drew Richardson <drew.richardson@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2014-08-22Merge tag 'pwm/for-3.17-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm Pull pwm fix from Thierry Reding: "Just one bugfix for the PWM lookup table code that would cause a PWM channel to be set to the wrong period and polarity for non-perfect matches" * tag 'pwm/for-3.17-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: pwm: Fix period and polarity in pwm_get() for non-perfect matches
2014-08-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: "Here are some bug fixes that have piled up during ksummit/linuxcon. 1) Fix endian problems in ibmveth, from Anton Blanchard. 2) IPV6 routing code does GFP_KERNEL allocation in atomic, fix from Benjamin Block. 3) SCTP association fixes from Daniel Borkmann. 4) When multiple VLAN headers are present we have to make sure the second and subsequent ones are pullable in the SKB otherwise we blindly dereference garbage. From Jiri Benc. 5) The argument adjustment of the signature of hlist_add_after*() introduced a regression in the batman-adv code, fix from Sven Eckelmann. 6) Fix TX hang handling to avoid a panic in i40e, from Anjali Singhai Jain. 7) PTP flag test is inverted in i40e driver, from Jesse Brandeburg. 8) ATM LEC driver needs to hold RTNL mutex over MTU changes, from Chas Williams. 9) Truncate packets larger then the TPACKET_V3 format configured buffers, otherwise we overwrite past the end of said buffers. From Eric Dumazet. 10) Fix endianness bugs in qlcnic firmware handling, from Rajesh Borundia and Shahed Shaikh. 11) CXGB4 sometimes doesn't get all of the TX completion events it should resulting in SKBs getting stuck in the TX queue, from Hariprasad Shenai. 12) When the FEC chip's PTP clock is disabled, you can't access the register. Add necessary checks to avoid the resulting hang, from Fugang Duan" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (37 commits) drivers: isdn: eicon: xdi_msg.h: Fix typo in #ifndef net: sctp: fix suboptimal edge-case on non-active active/retrans path selection net: sctp: spare unnecessary comparison in sctp_trans_elect_best net: ethernet: broadcom: bnx2x: Remove redundant #ifdef ibmveth: Fix endian issues with rx_no_buffer statistic net: xgene: fix possible NULL dereference in xgene_enet_free_desc_rings() openvswitch: fix panic with multiple vlan headers net: ipv6: fib: don't sleep inside atomic lock net: fec: ptp: avoid register access when ipg clock is disabled cxgb4: Free completed tx skbs promptly cxgb4: Fix race condition in cleanup sctp: not send SCTP_PEER_ADDR_CHANGE notifications with failed probe bnx2x: Revert UNDI flushing mechanism qlcnic: Fix endianess issue in firmware load from file operation qlcnic: Fix endianess issue in FW dump template header qlcnic: Fix flash access interface to application MAINTAINERS: Add section for MRF24J40 IEEE 802.15.4 radio driver macvlan: Allow setting multicast filter on all macvlan types packet: handle too big packets for PACKET_V3 MAINTAINERS: add entry for ec_bhf driver ...
2014-08-22drivers: isdn: eicon: xdi_msg.h: Fix typo in #ifndefRasmus Villemoes
Test for definedness of the macro which is actually defined (the change is hard to see: it is s/SSS/SSA/). Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22net: ethernet: broadcom: bnx2x: Remove redundant #ifdefRasmus Villemoes
Nothing defines _ASM_GENERIC_INT_L64_H, it is a weird way to check for 64 bit longs, and u64 should be printed using %llx anyway. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22ibmveth: Fix endian issues with rx_no_buffer statisticAnton Blanchard
Hidden away in the last 8 bytes of the buffer_list page is a solitary statistic. It needs to be byte swapped or else ethtool -S will produce numbers that terrify the user. Since we do this in multiple places, create a helper function with a comment explaining what is going on. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: stable@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22net: xgene: fix possible NULL dereference in xgene_enet_free_desc_rings()Iyappan Subramanian
A NULL pointer dereference is possible for the argument ring->buf_pool which is passed to xgene_enet_free_desc_ring(), as ring could be NULL. And now since NULL pointers are being checked for before the calls to xgene_enet_free_desc_ring(), might as well take advantage of them and not call the function if the argument would be NULL. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Iyappan Subramanian <isubramanian@apm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22net: fec: ptp: avoid register access when ipg clock is disabledNimrod Andy
The current kernel hang on i.MX6SX with rootfs mount from MMC. The root cause is that ptp uses a periodic timer to access enet register even if ipg clock is disabled. FEC ptp driver start one period timer to read 1588 counter register in the ptp init function that is called after FEC driver is probed. To save power, after FEC probe finish, FEC driver disable all clocks including ipg clock that is needed for register access. i.MX5x, i.MX6q/dl/sl FEC register access don't cause system hang when ipg clock is disabled, just return zero value. But for i.MX6sx SOC, it cause system hang. To avoid the issue, we need to check ptp clock status before ptp timer count access. Signed-off-by: Fugang Duan <B38611@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22Merge tag 'iommu-fixes-v3.17-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu Pull IOMMU fixes from Joerg Roedel: "The fixes include: - fix a crash in the VT-d driver when devices with a driver attached are hot-unplugged - fix a AMD IOMMU driver crash with device assignment of 32 bit PCI devices to KVM guests - fix for a copy&paste error in generic IOMMU code. Now the right function pointer is checked before calling" * tag 'iommu-fixes-v3.17-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: iommu/core: Check for the right function pointer in iommu_map() iommu/amd: Fix cleanup_domain for mass device removal iommu/vt-d: Defer domain removal if device is assigned to a driver
2014-08-22drm/radeon: add new KV pci idAlex Deucher
bug: https://bugs.freedesktop.org/show_bug.cgi?id=82912 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2014-08-22firmware: Do not use WARN_ON(!spin_is_locked())Guenter Roeck
spin_is_locked() always returns false for uniprocessor configurations in several architectures, so do not use WARN_ON with it. Use lockdep_assert_held() instead to also reduce overhead in non-debug kernels. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Cc: <stable@vger.kernel.org> Signed-off-by: Matt Fleming <matt.fleming@intel.com>
2014-08-21cxgb4: Free completed tx skbs promptlyHariprasad Shenai
Description of problem: The NIC card is not reporting back to the driver the transmitted skbs, so they get stuck in the TX ring causing issues with reference counters in other kernel components. Developed a new Automatic Egress Queue Update firmware facility to slowly tick through Egress Queues and send back any outstanding CIDX Updates which are laying around. Based on original work by Casey Leedom <leedom@chelsio.com> Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-21Merge tag 'linux-can-fixes-for-3.17-20140821' of ↵David S. Miller
git://gitorious.org/linux-can/linux-can Marc Kleine-Budde says: ==================== pull-request: can 2014-08-21 The first patch is from Mirza Krak, it fixes the initialization of the hardware in the sja1000 driver. The next patch is contributed by Dan Carpenter, it fixes the error handling in the c_can's probe function. Then there are two patches for the flexcan driver, one by Alexander Stein, which fixes the resetting of the bus error interrupt mask, the other one by Sebastian Andrzej Siewior which adds an additional error state transition message. ==================== Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-21cxgb4: Fix race condition in cleanupAnish Bhatt
There is a possible race condition when we unregister the PCI Driver and then flush/destroy the global "workq". This could lead to situations where there are tasks on the Work Queue with references to now deleted adapter data structures. Instead, have per-adapter Work Queues which were instantiated and torn down in init_one() and remove_one(), respectively. v2: Remove unnecessary call to flush_workqueue() before destroy_workqueue() Signed-off-by: Anish Bhatt <anish@chelsio.com> Signed-off-by: Casey Leedom <leedom@chelsio.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22sh: intc: Confine SH_INTC to platforms that need itGeert Uytterhoeven
Currently the sh-intc driver is compiled on all SuperH and non-multiplatform SH-Mobile platforms, while it's only used on a limited number of platforms: - SuperH: SH2(A), SH3(A), SH4(A)(L) (all but SH5) - ARM: sh7372, sh73a0 Drop the "default y" on SH_INTC, make all CPU platforms that use it select it, and protect all sub-options by "if SH_INTC" to fix this. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Acked-by: Magnus Damm <damm+renesas@opensource.se> Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
2014-08-21bnx2x: Revert UNDI flushing mechanismYuval Mintz
Commit 91ebb929b6f8 ("bnx2x: Add support for Multi-Function UNDI") [which was later supposedly fixed by de682941eef3 ("bnx2x: Fix UNDI driver unload")] introduced a bug in which in some [yet-to-be-determined] scenarios the alternative flushing mechanism which was to guarantee the Rx buffers are empty before resetting them during device probe will fail. If this happens, when device will be loaded once more a fatal attention will occur; Since this most likely happens in boot from SAN scenarios, the machine will fail to load. Notice this may occur not only in the 'Multi-Function' scenario but in the regular scenario as well, i.e., this introduced a regression in the driver's ability to perform boot from SAN. The patch reverts the mechanism and applies the old scheme to multi-function devices as well as to single-function devices. Signed-off-by: Yuval Mintz <Yuval.Mintz@qlogic.com> Signed-off-by: Ariel Elior <Ariel.Elior@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-21qlcnic: Fix endianess issue in firmware load from file operationShahed Shaikh
Firmware binary file is in little endian. On big-endian architecture, while writing this binary FW file to adapters memory, writel() swaps the data resulting into corruption of FW image. So, swap the data before writing into adapters memory. Signed-off-by: Shahed Shaikh <shahed.shaikh@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-21qlcnic: Fix endianess issue in FW dump template headerRajesh Borundia
Firmware dump template header is read from adapter using readl() which swaps the data. So, adjust structure element on the boundary of 32bit dword. Signed-off-by: Rajesh Borundia <rajesh.borundia@qlogic.com> Signed-off-by: Shahed Shaikh <shahed.shaikh@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-21qlcnic: Fix flash access interface to applicationJitendra Kalsaria
Application expects flash data in little endian, but driver reads/writes flash data using readl()/writel() APIs which swaps data on big endian machine. So, swap the data after reading from and before writing to flash memory. Signed-off-by: Jitendra Kalsaria <jitendra.kalsaria@qlogic.com> Signed-off-by: Shahed Shaikh <shahed.shaikh@qlogic.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-21macvlan: Allow setting multicast filter on all macvlan typesVlad Yasevich
Currently, macvlan code restricts multicast and unicast filter setting only to passthru devices. As a result, if a guest using macvtap wants to receive multicast traffic, it has to set IFF_ALLMULTI or IFF_PROMISC. This patch makes it possible to use the fdb interface to add multicast addresses to the filter thus allowing a guest to receive only targeted multicast traffic. CC: John Fastabend <john.r.fastabend@intel.com> CC: Michael S. Tsirkin <mst@redhat.com> CC: Jason Wang <jasowang@redhat.com> Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com> Acked-by: John Fastabend <john.r.fastabend@intel.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-22Merge tag 'drm-intel-fixes-2014-08-21' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel Display fixes from Ville and Imre, all cc: stable. * tag 'drm-intel-fixes-2014-08-21' of git://anongit.freedesktop.org/drm-intel: drm/i915: don't try to retrain a DP link on an inactive CRTC drm/i915: make sure VDD is turned off during system suspend drm/i915: cancel hotplug and dig_port work during suspend and unload drm/i915: fix HPD IRQ reenable work cancelation drm/i915: take display port power domain in DP HPD handler drm/i915: Don't try to enable cursor from setplane when crtc is disabled drm/i915: Skip load detect when intel_crtc->new_enable==true drm/i915: Fix locking for intel_enable_pipe_a()
2014-08-21Merge branch 'for-3.17-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata fixes from Tejun Heo: "Nothing drastic but pushing out early due to build breakage in the new tegra platform. Additionally: - M550 tagged trim blacklist pattern is widened so that it matches the new 1TB model - three controller specific fixes" * 'for-3.17-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: libata: widen Crucial M550 blacklist matching pata_scc: propagate return value of scc_wait_after_reset ata: ahci_tegra: Change include to fix compilation pata_samsung_cf: change ret type to signed ahci_xgene: Removing NCQ support from the APM X-Gene SoC AHCI SATA Host Controller driver.
2014-08-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid Pull HID fixes from Jiri Kosina: - fixes for a couple potential memory corruption problems (the HW would have to be manufactured to be deliberately evil to trigger those) found by Ben Hawkes - fix for potential infinite loop when using sysfs interface of logitech driver, from Simon Wood - a couple more simple driver fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: fix a couple of off-by-ones HID: logitech: perform bounds checking on device_id early enough HID: logitech: fix bounds checking on LED report size HID: logitech: Prevent possibility of infinite loop when using /sys interface HID: rmi: print an error if F11 is not found instead of stopping the device HID: hid-sensor-hub: use devm_ functions consistently HID: huion: Use allocated buffer for DMA HID: huion: Fail on parameter retrieval errors
2014-08-21Merge branch 'i2c/for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fixes from Wolfram Sang: "Here is the fixup for the 'lowlight' of my last pull request. I2C is not selected anymore by I2C_ACPI. Instead, the code in question now depends on I2C=y. Also, Mika has agreed to support me and be the maintainer for I2C-ACPI related patches. Finally, a new-ID-patch came along last week" * 'i2c/for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: MAINTAINERS: add maintainer for ACPI parts of I2C i2c: i801: Add PCI ID for Intel Braswell i2c: rework kernel config I2C_ACPI
2014-08-21HID: fix a couple of off-by-onesJiri Kosina
There are a few very theoretical off-by-one bugs in report descriptor size checking when performing a pre-parsing fixup. Fix those. Cc: stable@vger.kernel.org Reported-by: Ben Hawkes <hawkes@google.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-08-21HID: logitech: perform bounds checking on device_id early enoughJiri Kosina
device_index is a char type and the size of paired_dj_deivces is 7 elements, therefore proper bounds checking has to be applied to device_index before it is used. We are currently performing the bounds checking in logi_dj_recv_add_djhid_device(), which is too late, as malicious device could send REPORT_TYPE_NOTIF_DEVICE_UNPAIRED early enough and trigger the problem in one of the report forwarding functions called from logi_dj_raw_event(). Fix this by performing the check at the earliest possible ocasion in logi_dj_raw_event(). Cc: stable@vger.kernel.org Reported-by: Ben Hawkes <hawkes@google.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-08-21HID: logitech: fix bounds checking on LED report sizeJiri Kosina
The check on report size for REPORT_TYPE_LEDS in logi_dj_ll_raw_request() is wrong; the current check doesn't make any sense -- the report allocated by HID core in hid_hw_raw_request() can be much larger than DJREPORT_SHORT_LENGTH, and currently logi_dj_ll_raw_request() doesn't handle this properly at all. Fix the check by actually trimming down the report size properly if it is too large. Cc: stable@vger.kernel.org Reported-by: Ben Hawkes <hawkes@google.com> Reviewed-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-08-21gpio-lynxpoint: enable input sensing in resumegpio-v3.17-2Mathias Nyman
It appears that input sensing bit might be reset during suspend/resume. Set input sensing again for all requested gpios in resume Tested-by: Jerome Blin <jerome.blin@intel.com> Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-21can: flexcan: handle state passive -> warning transitionSebastian Andrzej Siewior
Once the CAN-bus is open and a packet is sent, the controller switches into the PASSIVE state. Once the BUS is closed again it goes the back err-warning. The TX error counter goes 0 -> 0x80 -> 0x7f. This patch makes sure that the user learns about this state chang (CAN_STATE_ERROR_WARNING => CAN_STATE_ERROR_PASSIVE) Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Matthias Klein <matthias.klein@optimeas.de> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2014-08-21can: flexcan: Disable error interrupt when bus error reporting is disabledAlexander Stein
In case we don't have FLEXCAN_HAS_BROKEN_ERR_STATE and the user set CAN_CTRLMODE_BERR_REPORTING once it can not be unset again until reboot. So in case neither hardware nor user wants the error interrupt disable the bit. Signed-off-by: Alexander Stein <alexander.stein@systec-electronic.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2014-08-21can: c_can: checking IS_ERR() instead of NULLDan Carpenter
devm_ioremap() returns NULL on error, not an ERR_PTR(). Fixes: 33cf75656923 ('can: c_can_platform: Fix raminit, use devm_ioremap() instead of devm_ioremap_resource()') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Cc: linux-stable <stable@vger.kernel.org> # >= v3.11 Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2014-08-21can: sja1000: Validate initialization state in start methodMirza Krak
When sja1000 is not compiled as module the SJA1000 chip is only initialized during device registration on kernel boot. Should the chip get a hardware reset there is no way to reinitialize it without re- booting the Linux kernel. This patch adds a check in sja1000_start if the chip is initialized, if not we initialize it. Signed-off-by: Mirza Krak <mirza.krak@hostmobility.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
2014-08-20Merge branch 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86Linus Torvalds
Pull x86 platform driver revert from Matthew Garrett: "This clearly shouldn't have been merged. No excuse on my part" * 'for_linus' of git://cavan.codon.org.uk/platform-drivers-x86: Revert "platform/x86/toshiba-apci.c possible bad if test?"
2014-08-20Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "These are the two bug fixes I mentioned in the final merge window pull. One is a reversed logic check in the device busy tests which can cause a nasty hang and another crash seen in the new SCSI pool support if the use count ever goes to zero" [ The device busy test already got merged from a patch earlier, so is now duplicated. ] * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: [SCSI] save command pool address of Scsi_Host [SCSI] fix qemu boot hang problem
2014-08-20Revert "platform/x86/toshiba-apci.c possible bad if test?"Matthew Garrett
This reverts commit bdc3ae7221213963f438faeaa69c8b4a2195f491. Signed-off-by: Matthew Garrett <matthew.garrett@nebula.com>
2014-08-19scsi: Fix qemu boot hang problemGuenter Roeck
The latest kernel fails to boot qemu arm images when using scsi for disk access. Boot gets stuck after the following messages. brd: module loaded sym53c8xx 0000:00:0c.0: enabling device (0100 -> 0103) sym0: <895a> rev 0x0 at pci 0000:00:0c.0 irq 93 sym0: No NVRAM, ID 7, Fast-40, LVD, parity checking sym0: SCSI BUS has been reset. scsi host0: sym-2.2.3 Bisect points to commit 71e75c97f97a ("scsi: convert device_busy to atomic_t"). Code inspection shows the following suspicious change in scsi_request_fn. out_delay: - if (sdev->device_busy == 0 && !scsi_device_blocked(sdev)) + if (atomic_read(&sdev->device_busy) && !scsi_device_blocked(sdev)) blk_delay_queue(q, SCSI_QUEUE_DELAY); } 'sdev->device_busy == 0' was replaced with 'atomic_read(&sdev->device_busy)', meaning the logic was reversed. Changing this expression to '!atomic_read(&sdev->device_busy)' fixes the problem. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Reviewed-by: Hannes Reinecke <hare@suse.de> Acked-by: Jens Axboe <axboe@fb.com> Reviewed-by: Venkatesh Srinivas <venkateshs@google.com> Reviewed-by: Webb Scales <webbnh@hp.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-19Revert "drm/radeon: Use write-combined CPU mappings of ring buffers with PCIe"Alex Deucher
This reverts commit 1490434f0da63afc6006411c8829c6a7935a4e7e. Several people have reported regressions with this patch on kabini.
2014-08-19drm/radeon: fix active_cu mask on SI and CIK after re-init (v3)Alex Deucher
Need to initialize the mask to 0 on init, otherwise it keeps increasing. bug: https://bugzilla.kernel.org/show_bug.cgi?id=82581 v2: also fix cu count v3: split count fix into separate patch Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Cc: stable@vger.kernel.org
2014-08-19drm/radeon: fix active cu count for SI and CIKAlex Deucher
This fixes the CU count reported to userspace for OpenCL. bug: https://bugzilla.kernel.org/show_bug.cgi?id=82581 Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Michel Dänzer <michel.daenzer@amd.com> Cc: stable@vger.kernel.org
2014-08-19drm/radeon: re-enable selective GPUVM flushingAlex Deucher
Now that the PFP and ME synchronization is fixed, we can enable this again reliably. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Tested-by: Michel Dänzer <michel.daenzer@amd.com>
2014-08-19drm/radeon: Sync ME and PFP after CP semaphore waits v4Christian König
Fixes lockups due to CP read GPUVM faults when running piglit on Cape Verde. v2 (chk): apply the fix to R600+ as well, on CIK only the GFX CP has a PFP, add more comments to R600 code, enable flushing again v3: (agd5f): only apply to 7xx+. r6xx does not have the packet. v4: (agd5f): split flush change into a separate patch, fix formatting Signed-off-by: Michel Dänzer <michel.daenzer@amd.com> Signed-off-by: Christian König <christian.koenig@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Tested-by: Michel Dänzer <michel.daenzer@amd.com>
2014-08-19drm/radeon: fix display handling in radeon_gpu_resetAlex Deucher
If the display hw was reset or a hard reset was used, we need to re-init some of the common display hardware as well. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2014-08-19drm/radeon: fix pm handling in radeon_gpu_resetAlex Deucher
pm_suspend is handled in the radeon_suspend callbacks. pm_resume has special handling depending on whether dpm or legacy pm is enabled. Change radeon_gpu_reset to mirror the behavior in the suspend and resume pathes. Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Reviewed-by: Christian König <christian.koenig@amd.com> Cc: stable@vger.kernel.org
2014-08-19i2c: i801: Add PCI ID for Intel BraswellAlan Cox
The SMBus host controller is the same as used in Baytrail so add the new PCI ID to the driver's list of supported IDs. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-08-19i2c: rework kernel config I2C_ACPILan Tianyu
Commit da3c6647(I2C/ACPI: Clean up I2C ACPI code and Add CONFIG_I2C_ACPI config) adds a new kernel config I2C_ACPI and make I2C core built in when the config is selected. This is wrong because distributions etc generally compile I2C as a module and the commit broken that. This patch is to rename I2C_ACPI to ACPI_I2C_OPREGION. New config only controls ACPI I2C operation region code and depends on I2C=y. Signed-off-by: Lan Tianyu <tianyu.lan@intel.com> Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com> [wsa: removed unrelated change for Kconfig] Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
