[ Upstream commit 8f9cfeed3eae86c70d3b04445a6f2036b27b6304 ]
when gsmtty_remove put dlci, it will cause memory leak if dlci->port's refcount is zero.
So we do the cleanup work in .cleanup callback instead.
dlci will be last put in two call chains.
1) gsmld_close -> gsm_cleanup_mux -> gsm_dlci_release -> dlci_put
2) gsmld_remove -> dlci_put
so there is a race. the memory leak depends on the race.
In call chain 2. we hit the memory leak. below comment tells.
release_tty -> tty_driver_remove_tty -> gsmtty_remove -> dlci_put -> tty_port_destructor (WARN_ON(port->itty) and return directly)
tty->port->itty = NULL;
tty_kref_put ---> release_one_tty -> gsmtty_cleanup (added by our patch)
So our patch fix the memory leak by doing the cleanup work after tty core did.
Signed-off-by: Pan Xinhui <xinhuix.pan@intel.com>
Fixes: dfabf7ffa30585
Cc: stable <stable@vger.kernel.org> # 3.14+
Acked-by: Jiri Slaby <jslaby@suse.cz>
[ Upstream commit 60c8f783a18feb95ad967c87e9660caf09fb4700 ]
clkdiv is declared as an u32 but it can be set to a negative value
causing a huge divisor value. Change its type to int to avoid this case.
Signed-off-by: Ludovic Desroches <ludovic.desroches@atmel.com>
Cc: <stable@vger.kernel.org> # 3.4 and later
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit 903124fe1aa284f61745a9dd4fbfa0184e569fff ]
memset() to 0 interfaces array before reusing
usb_configuration structure.
This commit fix bug:
ln -s functions/acm.1 configs/c.1
ln -s functions/acm.2 configs/c.1
ln -s functions/acm.3 configs/c.1
echo "UDC name" > UDC
echo "" > UDC
rm configs/c.1/acm.*
rmdir functions/*
mkdir functions/ecm.usb0
ln -s functions/ecm.usb0 configs/c.1
[ 82.220969] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 82.229009] pgd = c0004000
[ 82.231698] [00000000] *pgd=00000000
[ 82.235260] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
[ 82.240638] Modules linked in:
[ 82.243681] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.0.0-rc2 #39
[ 82.249926] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[ 82.256003] task: c07cd2f0 ti: c07c8000 task.ti: c07c8000
[ 82.261393] PC is at composite_setup+0xe3c/0x1674
[ 82.266073] LR is at composite_setup+0xf20/0x1674
[ 82.270760] pc : [<c03510d4>] lr : [<c03511b8>] psr: 600001d3
[ 82.270760] sp : c07c9df0 ip : c0806448 fp : ed8c9c9c
[ 82.282216] r10: 00000001 r9 : 00000000 r8 : edaae918
[ 82.287425] r7 : ed551cc0 r6 : 00007fff r5 : 00000000 r4 : ed799634
[ 82.293934] r3 : 00000003 r2 : 00010002 r1 : edaae918 r0 : 0000002e
[ 82.300446] Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
[ 82.307910] Control: 10c5387d Table: 6bc1804a DAC: 00000015
[ 82.313638] Process swapper/0 (pid: 0, stack limit = 0xc07c8210)
[ 82.319627] Stack: (0xc07c9df0 to 0xc07ca000)
[ 82.323969] 9de0: 00000000 c06e65f4 00000000 c07c9f68
[ 82.332130] 9e00: 00000067 c07c59ac 000003f7 edaae918 ed8c9c98 ed799690 eca2f140 200001d3
[ 82.340289] 9e20: ee79a2d8 c07c9e88 c07c5304 ffff55db 00010002 edaae810 edaae860 eda96d50
[ 82.348448] 9e40: 00000009 ee264510 00000007 c07ca444 edaae860 c0340890 c0827a40 ffff55e0
[ 82.356607] 9e60: c0827a40 eda96e40 ee264510 edaae810 00000000 edaae860 00000007 c07ca444
[ 82.364766] 9e80: edaae860 c0354170 c03407dc c033db4c edaae810 00000000 00000000 00000010
[ 82.372925] 9ea0: 00000032 c0341670 00000000 00000000 00000001 eda96e00 00000000 00000000
[ 82.381084] 9ec0: 00000000 00000032 c0803a23 ee1aa840 00000001 c005d54c 249e2450 00000000
[ 82.389244] 9ee0: 200001d3 ee1aa840 ee1aa8a0 ed84f4c0 00000000 c07c9f68 00000067 c07c59ac
[ 82.397403] 9f00: 00000000 c005d688 ee1aa840 ee1aa8a0 c07db4b4 c006009c 00000032 00000000
[ 82.405562] 9f20: 00000001 c005ce20 c07c59ac c005cf34 f002000c c07ca780 c07c9f68 00000057
[ 82.413722] 9f40: f0020000 413fc090 00000001 c00086b4 c000f804 60000053 ffffffff c07c9f9c
[ 82.421880] 9f60: c0803a20 c0011fc0 00000000 00000000 c07c9fb8 c001bee0 c07ca4f0 c057004c
[ 82.430040] 9f80: c07ca4fc c0803a20 c0803a20 413fc090 00000001 00000000 01000000 c07c9fb0
[ 82.438199] 9fa0: c000f800 c000f804 60000053 ffffffff 00000000 c0050e70 c0803bc0 c0783bd8
[ 82.446358] 9fc0: ffffffff ffffffff c0783664 00000000 00000000 c07b13e8 00000000 c0803e54
[ 82.454517] 9fe0: c07ca480 c07b13e4 c07ce40c 4000406a 00000000 40008074 00000000 00000000
[ 82.462689] [<c03510d4>] (composite_setup) from [<c0340890>] (s3c_hsotg_complete_setup+0xb4/0x418)
[ 82.471626] [<c0340890>] (s3c_hsotg_complete_setup) from [<c0354170>] (usb_gadget_giveback_request+0xc/0x10)
[ 82.481429] [<c0354170>] (usb_gadget_giveback_request) from [<c033db4c>] (s3c_hsotg_complete_request+0xcc/0x12c)
[ 82.491583] [<c033db4c>] (s3c_hsotg_complete_request) from [<c0341670>] (s3c_hsotg_irq+0x4fc/0x558)
[ 82.500614] [<c0341670>] (s3c_hsotg_irq) from [<c005d54c>] (handle_irq_event_percpu+0x50/0x150)
[ 82.509291] [<c005d54c>] (handle_irq_event_percpu) from [<c005d688>] (handle_irq_event+0x3c/0x5c)
[ 82.518145] [<c005d688>] (handle_irq_event) from [<c006009c>] (handle_fasteoi_irq+0xd4/0x18c)
[ 82.526650] [<c006009c>] (handle_fasteoi_irq) from [<c005ce20>] (generic_handle_irq+0x20/0x30)
[ 82.535242] [<c005ce20>] (generic_handle_irq) from [<c005cf34>] (__handle_domain_irq+0x6c/0xdc)
[ 82.543923] [<c005cf34>] (__handle_domain_irq) from [<c00086b4>] (gic_handle_irq+0x2c/0x6c)
[ 82.552256] [<c00086b4>] (gic_handle_irq) from [<c0011fc0>] (__irq_svc+0x40/0x74)
[ 82.559716] Exception stack(0xc07c9f68 to 0xc07c9fb0)
[ 82.564753] 9f60: 00000000 00000000 c07c9fb8 c001bee0 c07ca4f0 c057004c
[ 82.572913] 9f80: c07ca4fc c0803a20 c0803a20 413fc090 00000001 00000000 01000000 c07c9fb0
[ 82.581069] 9fa0: c000f800 c000f804 60000053 ffffffff
[ 82.586113] [<c0011fc0>] (__irq_svc) from [<c000f804>] (arch_cpu_idle+0x30/0x3c)
[ 82.593491] [<c000f804>] (arch_cpu_idle) from [<c0050e70>] (cpu_startup_entry+0x128/0x1a4)
[ 82.601740] [<c0050e70>] (cpu_startup_entry) from [<c0783bd8>] (start_kernel+0x350/0x3bc)
[ 82.609890] Code: 0a000002 e3530005 05975010 15975008 (e5953000)
[ 82.615965] ---[ end trace f57d5f599a5f1bfa ]---
Most of kernel code assume that interface array in
struct usb_configuration is NULL terminated.
When gadget is composed with configfs configuration
structure may be reused for different functions set.
This bug happens because purge_configs_funcs() sets
only next_interface_id to 0. Interface array still
contains pointers to already freed interfaces. If in
second try we add less interfaces than earlier we
may access unallocated memory when trying to get
interface descriptors.
Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com>
Cc: <stable@vger.kernel.org> # 3.10+
Signed-off-by: Felipe Balbi <balbi@ti.com>
[ Upstream commit 172115090f5e739660b97694618a2ba86457063a ]
Without this flag some versions of these enclosures do not work.
Cc: stable@vger.kernel.org
Reported-and-tested-by: Christian Schaller <cschalle@redhat.com>
[ Upstream commit c735ed74d83f8ecb45c4c4c95a16853c9c3c8157 ]
Added the USB serial console device ID for KCF Technologies PRN device
which has a USB port for its serial console.
Signed-off-by: Mark Edwards <sonofaforester@gmail.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
[ Upstream commit 48ef23a4f686b1e4519d4193c20d26834ff810ff ]
This phone is already supported by the visor driver.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
[ Upstream commit 82ee3aeb9295c5fc37fd2ddf20f13ac2b40ec97d ]
Samsung has just released a portable USB3 SSD, coming in a very small
and nice form factor. It's USB ID is 04e8:8001, which unfortunately is
already used by the Palm Visor driver for the Samsung I330 phone cradle.
Having pl2303 or visor pick up this device ID results in conflicts with
the usb-storage driver, which handles the newly released portable USB3
SSD.
To work around this conflict, I've dug up a mailing list post [1] from a
long time ago, in which a user posts the full USB descriptor
information. The most specific value in this appears to be the interface
class, which has value 255 (0xff). Since usb-storage requires an
interface class of 0x8, I believe it's correct to disambiguate the two
devices by matching on 0xff inside visor.
[1] http://permalink.gmane.org/gmane.linux.usb.user/4264
[ Upstream commit 948fa13504f80b9765d2b753691ab94c83a10341 ]
If the xHCI host controller has died (ie, device removed) or suffered
other serious fatal error (STS_FATAL), then xhci_irq should handle this
condition with IRQ_HANDLED instead of -ESHUTDOWN.
Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
[ Upstream commit 18cc2f4cbbaf825a4fedcf2d60fd388d291e0a38 ]
Our event ring consists of only one segment, and we risk filling
the event ring in case we get isoc transfers with short intervals
such as webcams that fill a TD every microframe (125us)
With 64 TRB segment size one usb camera could fill the event ring in 8ms.
A setup with several cameras and other devices can fill up the
event ring as it is shared between all devices.
This has occurred when uvcvideo queues 5 * 32TD URBs which then
get cancelled when the video mode changes. The cancelled URBs are returned
in the xhci interrupt context and blocks the interrupt handler from
handling the new events.
A full event ring will block xhci from scheduling traffic and affect all
devices conneted to the xhci, will see errors such as Missed Service
Intervals for isoc devices, and and Split transaction errors for LS/FS
interrupt devices.
Increasing the TRB_PER_SEGMENT will also increase the default endpoint ring
size, which is welcome as for most isoc transfer we had to dynamically
expand the endpoint ring anyway to be able to queue the 5 * 32TDs uvcvideo
queues.
The default size used to be 64 TRBs per segment
[ Upstream commit d104d0152a97fade389f47635b73a9ccc7295d0b ]
Isoc TDs usually consist of one TRB, sometimes two. When all goes well we
receive only one success event for a TD, and move the dequeue pointer to
the next TD.
This fails if the TD consists of two TRBs and we get a transfer error
on the first TRB, we will then see two events for that TD.
Fix this by making sure the event we get is for the last TRB in that TD
before moving the dequeue pointer to the next TD. This will resolve some
of the uvc and dvb issues with the
"ERROR Transfer event TRB DMA ptr not part of current TD" error message
[ Upstream commit 5a7125c64def3b21f8147eca8b54949a60963942 ]
See https://bugzilla.redhat.com/show_bug.cgi?id=1025672
We need to put() the reference to the scsi host that we got in
pscsi_configure_device(). In VIRTUAL_HOST mode it is associated with
the dev_virt, not the hba_virt.
Signed-off-by: Andy Grover <agrover@redhat.com>
Cc: stable@vger.kernel.org # 2.6.38+
[ Upstream commit b23f14302e86628625ac3982a6d23e35888755f2 ]
Information for packet type is in ieee80211_tx_info
band IEEE80211_BAND_5GHZ for PK_TYPE_11A.
IEEE80211_TX_RC_USE_CTS_PROTECT via tx_rate flags selects PK_TYPE_11GB
This ensures that the packet is always the right type.
Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com>
Cc: <stable@vger.kernel.org> # v3.17+
[ Upstream commit 892c89d5d7ffd1bb794fe54d86c0eef18d215fab ]
Fix regression introduced by commit <29ef8a53542a>. After it writing
AT commands to /dev/GCT-ATM0 is unsuccessful (no echo, no response)
and dmesg show "gdmtty: invalid payload : 1 16 f011".
Before that commit value of dummy_cnt was only a padding size. After using
ALIGN() this value is increased by its first argument. So the following
usage of this variable needs correction.
Signed-off-by: Sławomir Demeszko <s.demeszko@wireless-instruments.com>
[ Upstream commit ec04847c0c5b471bab2dacceadfdb803a9d1a2ea ]
The string iwpm_ulib_name is recorded in a nlmsg as a netlink attribute.
Without this fix parsing of the nlmsg by the userspace port mapper service fails
because of unknown attribute length, causing the port mapper service not to
register the client, which has sent the nlmsg.
Signed-off-by: Tatyana Nikolova <tatyana.e.nikolova@intel.com>
Cc: <stable@vger.kernel.org> #v3.16
Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
[ Upstream commit c7bd6dc320b85445b6b36a0aff41f929210027c7 ]
The following error message is seen when loading the nct6683 driver
with DEBUG_LOCK_ALLOC enabled.
BUG: key ffff88040b2f0030 not in .data!
WARNING: CPU: 0 PID: 186 at kernel/locking/lockdep.c:2988
lockdep_init_map+0x469/0x630()
DEBUG_LOCKS_WARN_ON(1)
Caused by a missing call to sysfs_attr_init() when initializing
sysfs attributes.
Reported-by: Alexey Orishko <alexey.orishko@gmail.com>
Reviewed-by: Jean Delvare <jdelvare@suse.de>
Cc: stable@vger.kernel.org # v3.18+
[ Upstream commit 1b63bf617206ff35b93c57c67bbe067ac735a85a ]
The following error message is seen when loading the nct6775 driver
sysfs attributes.
Cc: stable@vger.kernel.org # v3.12+
[ Upstream commit 97ffae1d30c3f6ceee67d5b0d3e540c08c13c744 ]
The VREFN channel is bipolar, not unipolar. Small negative values do
occur (e.g., -1mV), and unsigned conversion maps them incorrectly to
large positive values (about +1V), so fix this.
Signed-off-by: Thomas Betker <thomas.betker@rohde-schwarz.com>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
[ Upstream commit 00db4e52f4541965f7fda225eb458a75f892017b ]
The scaling factor for VREFP is 3.0/4096, not 1.0/4096; fix this to get
correct readings.
[ Upstream commit d6c96c42283601e311a7a1a3d7e51cde9d7fdb6e ]
For the "vccaux" channel, read the VCCAUX register, not VCCINT.
[ Upstream commit 3960d2c0c4aafe98da47a4a2eb64dfa8e88d8df5 ]
Define the register addresses for MIN_VCCPINT, MIN_VCCPAUX, MIN_VCCO_DDR
correctly.
[ Upstream commit 964e2255f1d73fc0136bc206a78a1f86bdad72a7 ]
Fix "null" in the raw attribute and scan elements.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
[ Upstream commit c2aab3d58b96002555a3e70004f593b043830248 ]
Currently in_proximity_(null)_raw is getting presented as raw sysfs
attribute. Same with the scan_elements.
The modifier doesn't apply to this channel.
[ Upstream commit adba657533bdd255f7b78bc8a324091f46b294cd ]
When configured via device tree, the associated iio device needs to be
measuring voltage for the conversion to resistance to be correct.
Return -EINVAL if that is not the case.
Signed-off-by: Chris Lesiak <chris.lesiak@licor.com>
Cc: stable@vger.kernel.org # 3.10+
[ Upstream commit 77bb3dfdc0d554befad58fdefbc41be5bc3ed38a ]
A non-percpu VIRQ (e.g., VIRQ_CONSOLE) may be freed on a different
VCPU than it is bound to. This can result in a race between
handle_percpu_irq() and removing the action in __free_irq() because
handle_percpu_irq() does not take desc->lock. The interrupt handler
sees a NULL action and oopses.
Only use the percpu chip/handler for per-CPU VIRQs (like VIRQ_TIMER).
# cat /proc/interrupts | grep virq
40: 87246 0 xen-percpu-virq timer0
44: 0 0 xen-percpu-virq debug0
47: 0 20995 xen-percpu-virq timer1
51: 0 0 xen-percpu-virq debug1
69: 0 0 xen-dyn-virq xen-pcpu
74: 0 0 xen-dyn-virq mce
75: 29 0 xen-dyn-virq hvc_console
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
[ Upstream commit 83a35114d0e4583e6b0ca39502e68b6a92e2910c ]
This bug has been there since day 1; addresses in the top guest physical
page weren't considered valid. You could map that page (the check in
check_gpte() is correct), but if a guest tried to put a pagetable there
we'd check that address manually when walking it, and kill the guest.
Cc: stable@kernel.org
UCNA/DEFERRED error
[ Upstream commit e3480271f59253cb60d030aa5e615bf00b731fea ]
Until now, the mce_severity mechanism can only identify the severity
of UCNA error as MCE_KEEP_SEVERITY. Meanwhile, it is not able to filter
out DEFERRED error for AMD platform.
This patch extends the mce_severity mechanism for handling
UCNA/DEFERRED error. In order to do this, the patch introduces a new
severity level - MCE_UCNA/DEFERRED_SEVERITY.
In addition, mce_severity is specific to machine check exception,
and it will check MCIP/EIPV/RIPV bits. In order to use mce_severity
mechanism in non-exception context, the patch also introduces a new
argument (is_excp) for mce_severity. `is_excp' is used to explicitly
specify the calling context of mce_severity.
Reviewed-by: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com>
Signed-off-by: Chen Yucong <slaoub@gmail.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
[ Upstream commit 1d0a0b2f6df2bf2643fadc990eb143361eca6ada ]
ACPICA commit b60612373a4ef63b64a57c124576d7ddb6d8efb6
For physical addresses, since the address may exceed 32-bit address range
after calculation, we should use 0x%8.8X%8.8X instead of ACPI_PRINTF_UINT
and ACPI_FORMAT_UINT64() instead of
ACPI_FORMAT_NATIVE_UINT()/ACPI_FORMAT_TO_UINT().
This patch also removes above replaced macros as there are no users.
This is a preparation to switch acpi_physical_address to 64-bit on 32-bit
kernel builds.
Link: https://github.com/acpica/acpica/commit/b6061237
Signed-off-by: Lv Zheng <lv.zheng@intel.com>
Signed-off-by: Bob Moore <robert.moore@intel.com>
[ Upstream commit cc2080b0e5a7c6c33ef5e9ffccbc2b8f6f861393 ]
ACPICA commit 7f06739db43a85083a70371c14141008f20b2198
after calculation, we should use %8.8X%8.8X (see ACPI_FORMAT_UINT64()) to
convert the %p formats.
kernel builds.
Link: https://github.com/acpica/acpica/commit/7f06739d
ACPI_PHYSADDR_TO_PTR()/ACPI_PTR_TO_PHYSADDR().
[ Upstream commit 6d3fd3cc33d50e4c0d0c0bd172de02caaec3127c ]
ACPICA commit 154f6d074dd38d6ebc0467ad454454e6c5c9ecdf
There are code pieces converting pointers using "(acpi_physical_address) x"
or "ACPI_CAST_PTR (t, x)" formats, this patch cleans up them.
Known issues:
1. Cleanup of "(ACPI_PHYSICAL_ADDRRESS) x" for a table field
For the conversions around the table fields, it is better to fix it with
alignment also fixed. So this patch doesn't modify such code. There
should be no functional problem by leaving them unchanged.
Link: https://github.com/acpica/acpica/commit/154f6d07
[ Upstream commit f254e3c57b9d952e987502aefa0804c177dd2503 ]
ACPICA commit 7d9fd64397d7c38899d3dc497525f6e6b044e0e3
OSPMs like Linux expect an acpi_physical_address returning value from
acpi_find_root_pointer(). This triggers warnings if sizeof (acpi_size) doesn't
equal to sizeof (acpi_physical_address):
drivers/acpi/osl.c:275:3: warning: passing argument 1 of 'acpi_find_root_pointer' from incompatible pointer type [enabled by default]
In file included from include/acpi/acpi.h:64:0,
from include/linux/acpi.h:36,
from drivers/acpi/osl.c:41:
include/acpi/acpixf.h:433:1: note: expected 'acpi_size *' but argument is of type 'acpi_physical_address *'
This patch corrects acpi_find_root_pointer().
Link: https://github.com/acpica/acpica/commit/7d9fd643
[ Upstream commit bad4371d87d1d1ed1aecd9c9cc21c41ac3f289c8 ]
f9fd54f22e ("mmc: sh_mmcif: Use msecs_to_jiffies() for host->timeout")
changed the timeout value from 1000 jiffies to 1s. In the case where
HZ is 1000 the values are the same. However, for smaller HZ values the
timeout is now smaller, 1s instead of 10s in the case of HZ=100.
Since the timeout occurs in spite of a normal data transfer a timeout of
10s seems more appropriate. This restores the previous timeout in the
case where HZ=100 and results in an increase over the previous timeout
for larger values of HZ.
Fixes: f9fd54f22e ("mmc: sh_mmcif: Use msecs_to_jiffies() for host->timeout")
Signed-off-by: Takeshi Kihara <takeshi.kihara.df@renesas.com>
[horms: rewrote changelog to refer to HZ]
Signed-off-by: Simon Horman <horms+renesas@verge.net.au>
Signed-off-by: Yoshihiro Kaneko <ykaneko0929@gmail.com>
[ Upstream commit 184af16b09360d6273fd6160e6ff7f8e2482ef23 ]
The PM_RESTORE_PREPARE is not handled now in mmc_pm_notify(),
as result mmc_rescan() could be scheduled and executed at
late hibernation restore stages when MMC device is suspended
already - which, in turn, will lead to system crash on TI dra7-evm board:
WARNING: CPU: 0 PID: 3188 at drivers/bus/omap_l3_noc.c:148 l3_interrupt_handler+0x258/0x374()
44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_PER1_P3 (Idle): Data Access in User mode during Functional access
Hence, add missed PM_RESTORE_PREPARE PM event in mmc_pm_notify().
Fixes: 4c2ef25fe0b8 (mmc: fix all hangs related to mmc/sd card...)
Signed-off-by: Grygorii Strashko <Grygorii.Strashko@linaro.org>
[ Upstream commit 4e93b9a6abc0d028daf3c8a00cb77b679d8a4df4 ]
During kernel boot, it will try to read some logical sectors
of each block device node for the possible partition table.
But since RPMB partition is special and can not be accessed
by normal eMMC read / write CMDs, it will cause below error
messages during kernel boot:
mmc0: Got data interrupt 0x00000002 even though no data operation was in progress.
mmcblk0rpmb: error -110 transferring data, sector 0, nr 32, cmd response 0x900, card status 0xb00
mmcblk0rpmb: retrying using single block read
mmcblk0rpmb: timed out sending r/w cmd command, card status 0x400900
end_request: I/O error, dev mmcblk0rpmb, sector 0
Buffer I/O error on device mmcblk0rpmb, logical block 0
end_request: I/O error, dev mmcblk0rpmb, sector 8
Buffer I/O error on device mmcblk0rpmb, logical block 1
end_request: I/O error, dev mmcblk0rpmb, sector 16
Buffer I/O error on device mmcblk0rpmb, logical block 2
end_request: I/O error, dev mmcblk0rpmb, sector 24
Buffer I/O error on device mmcblk0rpmb, logical block 3
This patch will discard the access request in eMMC queue if
it is RPMB partition access request. By this way, it avoids
trigger above error messages.
Fixes: 090d25fe224c ("mmc: core: Expose access to RPMB partition")
Signed-off-by: Yunpeng Gao <yunpeng.gao@intel.com>
Signed-off-by: Chuanxiao Dong <chuanxiao.dong@intel.com>
Tested-by: Michael Shigorin <mike@altlinux.org>
[ Upstream commit c5272a28566b00cce79127ad382406e0a8650690 ]
Way back, when the world was a simpler place and there was no war, no
evil, and no kernel bugs, there was just a single pinctrl lock. That
was how the world was when (57291ce pinctrl: core device tree mapping
table parsing support) was written. In that case, there were
instances where the pinctrl mutex was already held when
pinctrl_register_map() was called, hence a "locked" parameter was
passed to the function to indicate that the mutex was already locked
(so we shouldn't lock it again).
A few years ago in (42fed7b pinctrl: move subsystem mutex to
pinctrl_dev struct), we switched to a separate pinctrl_maps_mutex.
...but (oops) we forgot to re-think about the whole "locked" parameter
for pinctrl_register_map(). Basically the "locked" parameter appears
to still refer to whether the bigger pinctrl_dev mutex is locked, but
we're using it to skip locks of our (now separate) pinctrl_maps_mutex.
That's kind of a bad thing(TM). Probably nobody noticed because most
of the calls to pinctrl_register_map happen at boot time and we've got
synchronous device probing. ...and even cases where we're
asynchronous don't end up actually hitting the race too often. ...but
after banging my head against the wall for a bug that reproduced 1 out
of 1000 reboots and lots of looking through kgdb, I finally noticed
this.
Anyway, we can now safely remove the "locked" parameter and go back to
a war-free, evil-free, and kernel-bug-free world.
Fixes: 42fed7ba44e4 ("pinctrl: move subsystem mutex to pinctrl_dev struct")
Signed-off-by: Doug Anderson <dianders@chromium.org>
[ Upstream commit d52cdfa4a0c6406bbfb33206341eaf1fb1555994 ]
MPEG 2/4 are only supported since UVD3.
Signed-off-by: Christian König <christian.koenig@amd.com>
CC: stable@vger.kernel.org
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
[ Upstream commit a1b403da70e038ca6c6c6fe434d1d873546873a3 ]
Invalid messages can crash the hw otherwise.
[ Upstream commit 29c63fe22a17c64e54016040cd882481bd45ee5a ]
Invalid handles can crash the hw.
[ Upstream commit db12973cd581d4e79f4aadd0960948f268d15af7 ]
Fixing a memory leak with userptrs.
v2: clean up the loop, use an iterator instead
v3: remove unused variable
Signed-off-by: monk.liu <monk.liu@amd.com>
[ Upstream commit 013ead48a843442e63b9426e3bd5df18ca5d054a ]
Hardware doesn't seem to work correctly, just block userspace in this case.
v2: add missing defines
Bugs: https://bugs.freedesktop.org/show_bug.cgi?id=85320
[ Upstream commit 9fcb1704d1d51b12e2f03c78bca013d0cbbb7c98 ]
The eDP port A register on PCH split platforms has a slightly different
register layout from the other ports, with bit 6 being either alternate
scrambler reset or reserved, depending on the generation. Our
misinterpretation of the bit as audio has lead to warning.
Fix this by not enabling audio on port A, since none of our platforms
support audio on port A anyway.
v2: DDI doesn't have audio on port A either (Sivakumar Thulasimani)
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=89958
Reported-and-tested-by: Chris Bainbridge <chris.bainbridge@gmail.com>
Reviewed-by: Sivakumar Thulasimani <sivakumar.thulasimani@intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
[ Upstream commit 3916e3fd81021fb795bfbdb17f375b6b3685bced ]
Single channel LVDS maxes out at 112 MHz. The 15" pre-retina models
shipped with 1440x900 (106 MHz) by default or 1680x1050 (119 MHz)
as a BTO option, both versions used dual channel LVDS even though
the smaller one would have fit into a single channel.
Notes:
Bug report showing that the MacBookPro8,2 with 1440x900 uses dual
channel LVDS (this lead to it being hardcoded in intel_lvds.c by
Daniel Vetter with commit 618563e3945b9d0864154bab3c607865b557cecc):
https://bugzilla.kernel.org/show_bug.cgi?id=42842
If i915.lvds_channel_mode=2 is missing even though the machine needs
it, every other vertical line is white and consequently, only the left
half of the screen is visible (verified by myself on a MacBookPro9,1).
Forum posting concerning a MacBookPro6,2 with 1440x900, author is
using i915.lvds_channel_mode=2 on the kernel command line, proving
that the machine uses dual channels:
https://bbs.archlinux.org/viewtopic.php?id=185770
Chi Mei N154C6-L04 with 1440x900 is a replacement panel for all
MacBook Pro "A1286" models, and that model number encompasses the
MacBookPro6,2 / 8,2 / 9,1. Page 17 of the panel's datasheet shows it's
driven with dual channel LVDS:
http://www.ebay.com/itm/-/400690878560
http://www.everymac.com/ultimate-mac-lookup/?search_keywords=A1286
http://www.taopanel.com/chimei/datasheet/N154C6-L04.pdf
Those three 15" models, MacBookPro6,2 / 8,2 / 9,1, are the only ones
with i915 graphics and dual channel LVDS, so that list should be
complete. And the 8,2 is already in intel_lvds.c.
Possible motivation to use dual channel LVDS even on the 1440x900
models: Reduce the number of different parts, i.e. use identical logic
boards and display cabling on both versions and the only differing
component is the panel.
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Acked-by: Jani Nikula <jani.nikula@intel.com>
[Jani: included notes in the commit message for posterity]
[ Upstream commit fdb68e09bbb1c981f24608d7022c7d93cc47b326 ]
Since commit 844b03f27739135fe1fed2fef06da0ffc4c7a081 we make
sure that after vblank irq off, we return the last valid
(vblank count, vblank timestamp) pair to clients, e.g., during
modesets, which is good.
An overlooked side effect of that commit for kms drivers without
support for precise vblank timestamping is that at vblank irq
enable, when we update the vblank counter from the hw counter, we
can't update the corresponding vblank timestamp, so now we have a
totally mismatched timestamp for the new count to confuse clients.
Restore old client visible behaviour from before Linux 3.17, but
zero out the timestamp at vblank counter update (instead of disable
as in original implementation) if we can't generate a meaningful
timestamp immediately for the new vblank counter. This will fix
this regression, so callers know they need to retry again later
if they need a valid timestamp, but at the same time preserves
the improvements made in the commit mentioned above.
Signed-off-by: Mario Kleiner <mario.kleiner.de@gmail.com>
Cc: <stable@vger.kernel.org> #v3.17+
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Daniel Vetter <daniel@ffwll.ch>
[ Upstream commit c0403ec0bb5a8c5b267fb7e16021bec0b17e4964 ]
This reverts Linux 4.1-rc1 commit 0618764cb25f6fa9fb31152995de42a8a0496475.
The problem which that commit attempts to fix actually lies in the
Freescale CAAM crypto driver not dm-crypt.
dm-crypt uses CRYPTO_TFM_REQ_MAY_BACKLOG. This means the the crypto
driver should internally backlog requests which arrive when the queue is
full and process them later. Until the crypto hw's queue becomes full,
the driver returns -EINPROGRESS. When the crypto hw's queue if full,
the driver returns -EBUSY, and if CRYPTO_TFM_REQ_MAY_BACKLOG is set, is
expected to backlog the request and process it when the hardware has
queue space. At the point when the driver takes the request from the
backlog and starts processing it, it calls the completion function with
a status of -EINPROGRESS. The completion function is called (for a
second time, in the case of backlogged requests) with a status/err of 0
when a request is done.
Crypto drivers for hardware without hardware queueing use the helpers,
crypto_init_queue(), crypto_enqueue_request(), crypto_dequeue_request()
and crypto_get_backlog() helpers to implement this behaviour correctly,
while others implement this behaviour without these helpers (ccp, for
example).
dm-crypt (before the patch that needs reverting) uses this API
correctly. It queues up as many requests as the hw queues will allow
(i.e. as long as it gets back -EINPROGRESS from the request function).
Then, when it sees at least one backlogged request (gets -EBUSY), it
waits till that backlogged request is handled (completion gets called
with -EINPROGRESS), and then continues. The references to
af_alg_wait_for_completion() and af_alg_complete() in that commit's
commit message are irrelevant because those functions only handle one
request at a time, unlink dm-crypt.
The problem is that the Freescale CAAM driver, which that commit
describes as having being tested with, fails to implement the
backlogging behaviour correctly. In cam_jr_enqueue(), if the hardware
queue is full, it simply returns -EBUSY without backlogging the request.
What the observed deadlock was is not described in the commit message
but it is obviously the wait_for_completion() in crypto_convert() where
dm-crypto would wait for the completion being called with -EINPROGRESS
in the case of backlogged requests. This completion will never be
completed due to the bug in the CAAM driver.
Commit 0618764cb25 incorrectly made dm-crypt wait for every request,
even when the driver/hardware queues are not full, which means that
dm-crypt will never see -EBUSY. This means that that commit will cause
a performance regression on all crypto drivers which implement the API
correctly.
Revert it. Correct backlog handling should be implemented in the CAAM
driver instead.
Cc'ing stable purely because commit 0618764cb25 did. If for some reason
a stable@ kernel did pick up commit 0618764cb25 it should get reverted.
Signed-off-by: Rabin Vincent <rabin.vincent@axis.com>
Reviewed-by: Horia Geanta <horia.geanta@freescale.com>
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
[ Upstream commit 8014bcc86ef112eab9ee1db312dba4e6b608cf89 ]
The variable for the 'permissive' module parameter used to be static
but was recently changed to be extern. This puts it in the kernel
global namespace if the driver is built-in, so its name should begin
with a prefix identifying the driver.
Fixes: af6fc858a35b ("xen-pciback: limit guest control of command register")
__startup_pirq()
[ Upstream commit 16e6bd5970c88a2ac018b84a5f1dd5c2ff1fdf2c ]
.. because bind_evtchn_to_cpu(evtchn, cpu) will map evtchn to
'info' and pass 'info' down to xen_evtchn_port_bind_to_cpu().
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Tested-by: Annie Li <annie.li@oracle.com>
[ Upstream commit b9d934f27c91b878c4b2e64299d6e419a4022f8d ]
After a resume the hypervisor/tools may change console event
channel number. We should re-query it.
[ Upstream commit 16f1cf3ba7303228372d3756677bf7d10e79cf9f ]
After a resume the hypervisor/tools may change xenbus event
[ Upstream commit 5cec98834989a014a9560b1841649eaca95cf00e ]
When a guest is resumed, the hypervisor may change event channel
assignments. If this happens and the guest uses 2-level events it
is possible for the interrupt to be claimed by wrong VCPU since
cpu_evtchn_mask bits may be stale. This can happen even though
evtchn_2l_bind_to_cpu() attempts to clear old bits: irq_info that
is passed in is not necessarily the original one (from pre-migration
times) but instead is freshly allocated during resume and so any
information about which CPU the channel was bound to is lost.
Thus we should clear the mask during resume.
We also need to make sure that bits for xenstore and console channels
are set when these two subsystems are resumed. While rebind_evtchn_irq()
(which is invoked for both of them on a resume) calls irq_set_affinity(),
the latter will in fact postpone setting affinity until handling the
interrupt. But because cpu_evtchn_mask will have bits for these two
cleared we won't be able to take the interrupt.
With that in mind, we need to bind those two channels explicitly in
rebind_evtchn_irq(). We will keep irq_set_affinity() so that we have a
pass through generic irq affinity code later, in case something needs
to be updated there as well.
(Also replace cpumask_of(0) with cpumask_of(info->cpu) in
rebind_evtchn_irq(): it should be set to zero in preceding
xen_irq_info_evtchn_setup().)
Reported-by: Annie Li <annie.li@oracle.com>
Cc: <stable@vger.kernel.org> # 3.14+
[ Upstream commit 483d821108791092798f5d230686868112927044 ]
Unregister GPIOs requested through sysfs at chip remove to avoid leaking
the associated memory and sysfs entries.
The stale sysfs entries prevented the gpio numbers from being exported
when the gpio range was later reused (e.g. at device reconnect).
This also fixes the related module-reference leak.
Note that kernfs makes sure that any on-going sysfs operations finish
before the class devices are unregistered and that further accesses
fail.
The chip exported flag is used to prevent gpiod exports during removal.
This also makes it harder to trigger, but does not fix, the related race
between gpiochip_remove and export_store, which is really a race with
gpiod_request that needs to be addressed separately.
Also note that this would prevent the crashes (e.g. NULL-dereferences)
at reconnect that affects pre-3.18 kernels, as well as use-after-free on
operations on open attribute files on pre-3.14 kernels (prior to
kernfs).
Fixes: d8f388d8dc8d ("gpio: sysfs interface")
Cc: stable <stable@vger.kernel.org> # v2.6.27: 01cca93a9491
[ Upstream commit 285214409a9e5fceba2215461b4682b6069d8e77 ]
When accepting a new IPv4 connect to an IPv6 socket, the CMA tries to
canonize the address family to IPv4, but does not properly process
the listening sockaddr to get the listening port, and does not properly
set the address family of the canonized sockaddr.
Fixes: e51060f08a61 ("IB: IP address based RDMA connection manager")
Reported-By: Yotam Kenneth <yotamke@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Tested-by: Haggai Eran <haggaie@mellanox.com>
